10-Security Configuration Guide
HomeSupportSwitchesH3C S7500E-X Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-X Configuration Guides-R7523P01-6W10010-Security Configuration Guide
16-ARP attack protection configuration
16-ARP attack protection configuration 225.81 KB
Configuring ARP attack protection· 1
ARP attack protection configuration task list 1
Configuring unresolvable IP attack protection· 1
Configuring ARP source suppression· 2
Configuring ARP blackhole routing· 2
Displaying and maintaining unresolvable IP attack protection· 2
Configuration example· 2
Configuring ARP packet rate limit 3
Configuration guidelines· 3
Configuration procedure· 4
Configuring source MAC-based ARP attack detection· 5
Configuration procedure· 5
Displaying and maintaining source MAC-based ARP attack detection· 6
Configuration example· 6
Configuring ARP packet source MAC consistency check· 7
Configuring ARP active acknowledgement 7
Configuring authorized ARP· 8
Configuration procedure· 8
Configuration example (on a DHCP server) 8
Configuration example (on a DHCP relay agent) 9
Configuring ARP attack detection· 11
Configuring user validity check· 11
Configuring ARP packet validity check· 12
Configuring ARP restricted forwarding· 13
Enabling ARP attack detection logging· 13
Displaying and maintaining ARP attack detection· 14
User validity check and ARP packet validity check configuration example· 14
ARP restricted forwarding configuration example· 15
Configuring ARP scanning and fixed ARP· 17
Configuration restrictions and guidelines· 17
Configuration procedure· 18
Configuring ARP gateway protection· 18
Configuration guidelines· 18
Configuration example· 19
Configuring ARP filtering· 19
Configuration guidelines· 19
Configuration procedure· 20
Configuration example· 20
Configuring ARP sender IP address checking· 21
ARP attacks and viruses are threatening LAN security. This chapter describes multiple features used to detect and prevent ARP attacks.
Although ARP is easy to implement, it provides no security mechanism and is vulnerable to network attacks. An attacker can exploit ARP vulnerabilities to attack network devices in the following ways:
·     Acts as a trusted user or gateway to send ARP packets so the receiving devices obtain incorrect ARP entries.
·     Sends a large number of unresolvable IP packets to have the receiving device busy with resolving IP addresses until its CPU is overloaded. Unresolvable IP packets refer to IP packets for which ARP cannot find corresponding MAC addresses.
·     Sends a large number of ARP packets to overload the CPU of the receiving device.
Tasks at a glance
Flood prevention:
·     Configuring unresolvable IP attack protection (configured on gateways)
¡     Configuring ARP source suppression
¡     Configuring ARP blackhole routing
·     Configuring ARP packet rate limit (configured on access devices)
·     Configuring source MAC-based ARP attack detection (configured on gateways)
User and gateway spoofing prevention:
·     Configuring ARP packet source MAC consistency check (configured on gateways)
·     Configuring ARP active acknowledgement (configured on gateways)
·     Configuring authorized ARP (configured on gateways)
·     Configuring ARP attack detection (configured on access devices)
·     Configuring ARP scanning and fixed ARP (configured on gateways)
·     Configuring ARP gateway protection (configured on access devices)
·     Configuring ARP filtering (configured on access devices)
·     Configuring ARP sender IP address checking (configured on gateways)
If a device receives a large number of unresolvable IP packets from a host, the following situations can occur:
·     The device sends a large number of ARP requests, overloading the target subnets.
·     The device keeps trying to resolve the destination IP addresses, overloading its CPU.
To protect the device from such IP attacks, you can configure the following features:
·     ARP source suppression—Stops resolving packets from an IP address if the number of unresolvable IP packets from the IP address exceeds the upper limit within 5 seconds. The device continues ARP resolution when the interval elapses. This feature is applicable if the attack packets have the same source addresses.
·     ARP blackhole routing—Creates a blackhole route destined for an unresolved IP address. The device drops all matching packets until the blackhole route is deleted. A blackhole route is deleted when its aging timer is reached or the route becomes reachable.
After a blackhole route is created for an unresolved IP address, the device immediately starts the first ARP blackhole route probe by sending an ARP request. If the resolution fails, the device continues probing according to the probe settings. If the IP address resolution succeeds in a probe, the device converts the blackhole route to a normal route. If an ARP blackhole route ages out before the device finishes all probes, the device deletes the blackhole route and does not perform the remaining probes.
This feature is applicable regardless of whether the attack packets have the same source addresses.
Step
Remarks
N/A
2.     Enable ARP source suppression.
arp source-suppression enable
By default, ARP source suppression is disabled.
3.     Set the maximum number of unresolvable packets that the device can process per source IP address within 5 seconds.
By default, the maximum number is 10.
Step
Remarks
N/A
2.     Enable ARP blackhole routing.
arp resolving-route enable
By default, ARP blackhole routing is enabled.
3.     (Optional.) Set the number of ARP blackhole route probes for each unresolved IP address.
arp resolving-route probe-count count
The default setting is three probes.
4.     (Optional.) Set the interval at which the device probes ARP blackhole routes.
arp resolving-route probe-interval interval
The default setting is 1 second.
Display ARP source suppression configuration information.
display arp source-suppression
Network requirements
As shown in Figure 1, a LAN contains two areas: an R&D area in VLAN 10 and an office area in VLAN 20. Each area connects to the gateway (Device) through an access switch.
A large number of ARP requests are detected in the office area and are considered an attack caused by unresolvable IP packets. To prevent the attack, configure ARP source suppression or ARP blackhole routing.
Figure 1 Network diagram
·     If the attack packets have the same source address, configure ARP source suppression:
# Enable ARP source suppression.
[Device] arp source-suppression enable
# Configure the device to process a maximum of 100 unresolvable packets per source IP address within 5 seconds.
[Device] arp source-suppression limit 100
·     If the attack packets have different source addresses, configure ARP blackhole routing:
# Enable ARP blackhole routing.
[Device] arp resolving-route enable
The ARP packet rate limit feature allows you to limit the rate of ARP packets delivered to the CPU. An ARP attack detection-enabled device will send all received ARP packets to the CPU for inspection. Processing excessive ARP packets will make the device malfunction or even crash. To solve this problem, configure ARP packet rate limit.
Configure this feature when ARP attack detection, ARP snooping, ARP fast-reply, or MFF is enabled, or when ARP flood attacks are detected.
This task sets a rate limit for ARP packets received on an interface. When the receiving rate of ARP packets on the interface exceeds the rate limit, those packets are discarded.
You can enable sending notifications to the SNMP module or enable logging for ARP packet rate limit.
·     If notification sending is enabled, the device sends the highest threshold-crossed ARP packet rate within the sending interval in a notification to the SNMP module. You must use the snmp-agent target-host command to set the notification type and target host. For more information about notifications, see Network Management and Monitoring Command Reference.
·     If logging for ARP packet rate limit is enabled, the device sends the highest threshold-crossed ARP packet rate within the sending interval in a log message to the information center. You can configure the information center module to set the log output rules. For more information about information center, see Network Management and Monitoring Configuration Guide.
To configure ARP packet rate limit:
Step
Remarks
N/A
2.     (Optional.) Enable notification sending for ARP packet rate limit.
snmp-agent trap enable arp [ rate-limit ]
By default, notification sending for ARP packet rate limit is disabled.
3.     (Optional.) Enable logging for ARP packet rate limit.
arp rate-limit log enable
By default, logging for ARP packet rate limit is disabled.
4.     (Optional.) Set the notification and log message sending interval.
arp rate-limit log interval interval
By default, the device sends notifications and log messages every 60 seconds.
5.     Enter Layer 2 Ethernet interface, Layer 2 aggregate interface, Layer 3 Ethernet interface, or Layer 3 aggregate interface view.
N/A
6.     Enable ARP packet rate limit.
arp rate-limit [ pps ]
By default, ARP packet rate limit is enabled.
The rate limit is 2000 pps for the following modules:
·     EC interface modules:
¡     . LSQM1TGS12EC0.
·     SG interface modules:
¡     LSQM1QGS12SG0.
¡     LSQM1TGS48SG0.
The rate limit is 750 pps for other modules.
If you enable notification sending and logging for ARP packet rate limit on a Layer 2 aggregate interface, the features apply to all aggregation member ports.
This feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within 5 seconds exceeds a threshold, the device generates an ARP attack entry for the MAC address. Before the entry ages out, the device handles the attack by using either of the following methods:
·     Monitor—Only generates log messages.
·     Filter—Generates log messages and filters out subsequent ARP packets from the MAC address.
Make sure you have enabled the ARP logging feature before enabling the source MAC-based ARP attack detection feature. For information about the ARP logging feature, see Layer 3—IP Services Configuration Guide.
You can exclude the MAC addresses of some gateways and servers from this detection. This feature does not inspect ARP packets from those devices even if they are attackers.
To configure source MAC-based ARP attack detection:
Step
Remarks
N/A
2.     Enable source MAC-based ARP attack detection and specify the handling method.
arp source-mac { filter | monitor }
When you change the handling method from monitor to filter, the configuration takes effect immediately.
When you change the handling method from filter to monitor, the device continues filtering packets that match existing attack entries.
3.     Set the threshold.
arp source-mac threshold threshold-value
The default threshold is 30.
4.     Set the aging timer for ARP attack entries.
arp source-mac aging-time time
By default, the lifetime is 300 seconds.
5.     (Optional.) Exclude specific MAC addresses from this detection.
arp source-mac exclude-mac mac-address&<1-64>
By default, no MAC address is excluded.
When an ARP attack entry is aged out, ARP packets sourced from the MAC address in the entry can be processed correctly.
(In standalone mode.) Display ARP attack entries detected by source MAC-based ARP attack detection.
display arp source-mac { slot slot-number | interface interface-type interface-number }
(In IRF mode.) Display ARP attack entries detected by source MAC-based ARP attack detection.
display arp source-mac { chassis chassis-number slot slot-number | interface interface-type interface-number }
As shown in Figure 2, the hosts access the Internet through a gateway (Device). If malicious users send a large number of ARP requests to the gateway, the gateway might crash and cannot process requests from the clients. To solve this problem, configure source MAC-based ARP attack detection on the gateway.
Figure 2  Network diagram
Configuration considerations
An attacker might forge a large number of ARP packets by using the MAC address of a valid host as the source MAC address. To prevent such attacks, configure the gateway in the following steps:
1.     Enable source MAC-based ARP attack detection and specify the handling method as filter.
2.     Set the threshold.
3.     Set the lifetime for ARP attack entries.
4.     Exclude the MAC address of the server from this detection.
# Enable source MAC-based ARP attack detection, and specify the handling method as filter.
[Device] arp source-mac filter
# Set the threshold to 30.
[Device] arp source-mac threshold 30
# Set the lifetime for ARP attack entries to 60 seconds.
[Device] arp source-mac aging-time 60
# Exclude MAC address 0012-3f86-e94c from this detection.
[Device] arp source-mac exclude-mac 0012-3f86-e94c
This feature enables a gateway to filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body. This feature allows the gateway to learn correct ARP entries.
To enable ARP packet source MAC address consistency check:
Step
Remarks
N/A
2.     Enable ARP packet source MAC address consistency check.
arp valid-check enable
By default, ARP packet source MAC address consistency check is disabled.
Configure this feature on gateways to prevent user spoofing.
ARP active acknowledgement prevents a gateway from generating incorrect ARP entries.
In strict mode, a gateway performs more strict validity checks before creating an ARP entry:
·     Upon receiving an ARP request destined for the gateway, the gateway sends an ARP reply but does not create an ARP entry.
·     Upon receiving an ARP reply, the gateway determines whether it has resolved the sender IP address:
¡     If yes, the gateway performs active acknowledgement. When the ARP reply is verified as valid, the gateway creates an ARP entry.
¡     If no, the gateway discards the packet.
For ARP active acknowledgement to take effect in strict mode, make sure ARP blackhole routing is enabled.
To configure ARP active acknowledgement:
Step
Remarks
N/A
2.     Enable the ARP active acknowledgement feature.
arp active-ack [ strict ] enable
Authorized ARP entries are generated based on the DHCP clients' address leases on the DHCP server or dynamic client entries on the DHCP relay agent. For more information about DHCP server and DHCP relay agent, see Layer 3—IP Services Configuration Guide.
With authorized ARP enabled, an interface is disabled from learning dynamic ARP entries. This feature prevents user spoofing and allows only authorized clients to access network resources.
To enable authorized ARP:
Step
Remarks
N/A
2.     Enter interface view.
The following interface types are supported:
·     Layer 3 Ethernet interfaces.
·     Layer 3 Ethernet subinterfaces.
·     Layer 3 aggregate interfaces.
·     Layer 3 aggregate subinterfaces.
·     VLAN interfaces.
3.     Enable authorized ARP on the interface.
arp authorized enable
By default, authorized ARP is disabled.
As shown in Figure 3, configure authorized ARP on GigabitEthernet 1/0/1 of Device A (a DHCP server) to ensure user validity.
Figure 3 Network diagram
1.     Configure Device A:
# Specify the IP address for GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] ip address 10.1.1.1 24
# Configure DHCP.
[DeviceA] dhcp enable
[DeviceA] dhcp server ip-pool 1
[DeviceA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.0
[DeviceA-dhcp-pool-1] quit
# Enter Layer 3 Ethernet interface view.
# Enable authorized ARP.
[DeviceA-GigabitEthernet1/0/1] port link-mode route
[DeviceA-GigabitEthernet1/0/1] arp authorized enable
2.     Configure Device B:
[DeviceB-GigabitEthernet1/0/1] ip address dhcp-alloc
# Display authorized ARP entry information on Device A.
[DeviceA] display arp all
  Type: S-Static   D-Dynamic   O-Openflow   M-Multiport  I-Invalid
IP Address       MAC Address     VLAN     Interface          Aging  Type
10.1.1.2         0012-3f86-e94c  N/A      GE1/0/1            16     D
The output shows that IP address 10.1.1.2 has been assigned to Device B.
Device B must use the IP address and MAC address in the authorized ARP entry to communicate with Device A. Otherwise, the communication fails. Thus user validity is ensured.
As shown in Figure 4, configure authorized ARP on GigabitEthernet 1/0/2 of Device B (a DHCP relay agent) to ensure user validity.
Figure 4 Network diagram
# Configure DHCP.
[DeviceA-dhcp-pool-1] network 10.10.1.0 mask 255.255.255.0
[DeviceA-dhcp-pool-1] gateway-list 10.10.1.1
[DeviceA] ip route-static 10.10.1.0 24 10.1.1.2
# Enable DHCP.
[DeviceB] dhcp enable
# Specify the IP addresses of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/1] ip address 10.1.1.2 24
[DeviceB-GigabitEthernet1/0/2] ip address 10.10.1.1 24
# Enable DHCP relay agent on GigabitEthernet 1/0/2.
[DeviceB-GigabitEthernet1/0/2] dhcp select relay
# Add the DHCP server 10.1.1.1 to DHCP server group 1.
[DeviceB-GigabitEthernet1/0/2] dhcp relay server-address 10.1.1.1
[DeviceB-GigabitEthernet1/0/2] arp authorized enable
# Enable recording of relay entries on the relay agent.
[DeviceB] dhcp relay client-information record
3.     Configure Device C:
<DeviceC> system-view
[DeviceC] ip route-static 10.1.1.0 24 10.10.1.1
[DeviceC-GigabitEthernet1/0/2] ip address dhcp-alloc
# Display authorized ARP information on Device B.
[DeviceB] display arp all
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP Address       MAC Address     VID     Interface/Link ID      Aging Type
10.10.1.2        0012-3f86-e94c  N/A     GE1/0/2                16    D
The output shows that Device A assigned the IP address 10.10.1.2 to Device C.
Device C must use the IP address and MAC address in the authorized ARP entry to communicate with Device B. Otherwise, the communication fails. Thus the user validity is ensured.
ARP attack detection enables access devices to block ARP packets from unauthorized clients to prevent user spoofing and gateway spoofing attacks. ARP attack detection does not check ARP packets received from ARP trusted interfaces.
ARP attack detection provides the following features:
·     User validity check.
·     ARP packet validity check.
·     ARP restricted forwarding.
·     ARP attack detection logging.
If both ARP packet validity check and user validity check are enabled, the former one applies first, and then the latter applies.
User validity check compares the sender IP and sender MAC in the received ARP packet with the matching criteria in the following order:
1.     User validity check rules.
¡     If a match is found, the device processes the ARP packet according to the rule.
¡     If no match is found or no user validity check rule is configured, proceeds to step 2.
2.     Static IP source guard bindings, DHCP snooping entries, and 802.1X security entries.
¡     If a match is found, the device forwards the ARP packet.
¡     If no match is found, the device discards the ARP packet.
Static IP source guard bindings are created by using the ip source binding command. For more information, see "Configuring IP source guard."
DHCP snooping entries are automatically generated by DHCP snooping. For more information, see Layer 3—IP Services Configuration Guide.
802.1X security entries record the IP-to-MAC mappings for 802.1X clients. After a client passes 802.1X authentication and uploads its IP address to an ARP attack detection enabled device, the device automatically generates an 802.1X security entry. The 802.1X client must be enabled to upload its IP address to the device. For more information, see "Configuring 802.1X."
When you configure user validity check, follow these guidelines:
·     Make sure one or more of the following items is configured for user validity check:
¡     User validity check rules.
¡     Static IP source guard bindings.
¡     DHCP snooping.
¡     802.1X.
If none of the items is configured, all incoming ARP packets on ARP untrusted interfaces are discarded.
·     Specify the VLAN where ARP attack detection is enabled as the VLAN for IP source guard bindings. Otherwise, the IP source guard bindings do not take effect for user validity check.
To configure user validity check:
Step
Remarks
N/A
2.     (Optional.) Configure a user validity check rule.
arp detection rule rule-id { deny | permit } ip { ip-address [ mask ] | any } mac { mac-address [ mask ] | any } [ vlan vlan-id ]
By default, no user validity check rule is configured.
3.     Enter VLAN view.
vlan vlan-id
N/A
4.     Enable ARP attack detection.
arp detection enable
By default, ARP attack detection is disabled.
5.     Return to system view.
N/A
6.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
N/A
7.     (Optional.) Configure the interface as a trusted interface excluded from ARP attack detection.
arp detection trust
By default, an interface is untrusted.
Enable validity check for ARP packets received on untrusted interfaces and specify the following objects to be checked:
·     src-mac—Checks whether the sender MAC address in the message body is identical to the source MAC address in the Ethernet header. If they are identical, the packet is forwarded. Otherwise, the packet is discarded.
·     dst-mac—Checks the target MAC address of ARP replies. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
·     ip—Checks the sender and target IP addresses of ARP replies, and the sender IP address of ARP requests. All-one or multicast IP addresses are considered invalid and the corresponding packets are discarded.
To configure ARP packet validity check:
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Enable ARP attack detection.
4.     Return to system view.
N/A
5.     Enable ARP packet validity check and specify the objects to be checked.
By default, ARP packet validity check is disabled.
N/A
arp detection trust
ARP restricted forwarding does not apply to ARP packets with multiport MAC as their destination MAC addresses.
ARP restricted forwarding controls the forwarding of ARP packets that are received on untrusted interfaces and have passed user validity check as follows:
·     If the packets are ARP requests, they are forwarded through the trusted interface.
·     If the packets are ARP replies, they are forwarded according to their destination MAC address. If no match is found in the MAC address table, they are forwarded through the trusted interface.
Configure user validity check before you configure ARP restricted forwarding.
To enable ARP restricted forwarding:
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Enable ARP restricted forwarding.
By default, ARP restricted forwarding is disabled.
The ARP attack detection logging feature enables a device to generate ARP attack detection log messages when illegal ARP packets are detected. An ARP attack detection log message contains the following information:
1.     Receiving interface of the ARP packets.
2.     Sender IP address.
3.     Total number of dropped ARP packets.
To enable ARP attack detection logging:
Step
Remarks
N/A
2.     Enable ARP attack detection logging.
arp detection log enable
By default, ARP attack detection logging is disabled.
Display the VLANs enabled with ARP attack detection.
display arp detection
Display the ARP attack detection statistics.
display arp detection statistics [ interface interface-type interface-number ]
Clear the ARP attack detection statistics.
reset arp detection statistics [ interface interface-type interface-number ]
As shown in Figure 5, configure Device B to perform ARP packet validity check and user validity check based on static IP source guard bindings and DHCP snooping entries for connected hosts.
Figure 5 Network diagram
1.     Add all interfaces on Device B to VLAN 10, and specify the IP address of VLAN-interface 10 on Device A. (Details not shown.)
2.     Configure the DHCP server on Device A, and configure DHCP address pool 0.
[DeviceA] dhcp server ip-pool 0
[DeviceA-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
3.     Configure Host A (DHCP client) and Host B. (Details not shown.)
4.     Configure Device B:
# Enable DHCP snooping.
[DeviceB] dhcp snooping enable
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] dhcp snooping trust
# Enable recording of client information in DHCP snooping entries on GigabitEthernet 1/0/1.
[DeviceB-GigabitEthernet1/0/1] dhcp snooping binding record
# Enable ARP attack detection for VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] arp detection enable
# Configure the upstream interface as a trusted interface. By default, an interface is an untrusted interface.
[DeviceB-vlan10] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] arp detection trust
# Configure a static IP source guard binding entry on interface GigabitEthernet 1/0/2 for user validity check.
[DeviceB-GigabitEthernet1/0/2] ip source binding ip-address 10.1.1.6 mac-address 0001-0203-0607 vlan 10
# Enable ARP packet validity check by checking the MAC addresses and IP addresses of ARP packets.
[DeviceB] arp detection validate dst-mac ip src-mac
After the configurations are completed, Device B first checks the validity of ARP packets received on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2. If the ARP packets are confirmed valid, Device B performs user validity check by using the static IP source guard bindings and finally DHCP snooping entries.
As shown in Figure 6, configure ARP restricted forwarding on Device B where ARP attack detection is configured. Port isolation configured on Device B can take effect for broadcast ARP requests.
Figure 6 Network diagram
1.     Configure VLAN 10, add interfaces to VLAN 10, and specify the IP address of VLAN-interface 10 on Device A. (Details not shown.)
# Enable DHCP snooping, and configure GigabitEthernet 1/0/3 as a DHCP trusted interface.
# Enable ARP attack detection for user validity check.
[DeviceB] vlan 10
# Configure GigabitEthernet 1/0/3 as an ARP trusted interface.
# Configure a static IP source guard entry on interface GigabitEthernet 1/0/2.
# Configure port isolation.
[DeviceB] port-isolate group 1
[DeviceB-GigabitEthernet1/0/1] port-isolate enable group 1
[DeviceB-GigabitEthernet1/0/2] port-isolate enable group 1
After the configurations are completed, Device B first checks the validity of ARP packets received on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2. If the ARP packets are confirmed valid, Device B performs user validity check by using the static IP source guard bindings and finally DHCP snooping entries. However, ARP broadcast requests sent from Host A can pass the check on Device B and reach Host B. Port isolation fails.
# Enable ARP restricted forwarding.
[DeviceB] vlan 10
[DeviceB-vlan10] arp restricted-forwarding enable
[DeviceB-vlan10] quit
After the configuration is completed, Device B forwards ARP broadcast requests from Host A to Device A through the trusted interface GigabitEthernet 1/0/3. Host B cannot receive such packets. Port isolation operates correctly.
ARP scanning is typically used together with the fixed ARP feature in small-scale networks.
ARP scanning automatically creates ARP entries for devices in an address range. The device performs ARP scanning in the following steps:
1.     Sends ARP requests for each IP address in the address range.
2.     Obtains their MAC addresses through received ARP replies.
3.     Creates dynamic ARP entries.
Fixed ARP converts existing dynamic ARP entries (including those generated through ARP scanning) to static ARP entries. This feature prevents ARP entries from being modified by attackers. Static ARP entries can also be manually configured by the arp static command.
Follow these restrictions and guidelines when you configure ARP scanning and fixed ARP:
·     IP addresses in existing ARP entries are not scanned.
·     ARP scanning will take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
·     The arp fixup command is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
·     Due to the limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
·     To delete a static ARP entry converted from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. Use the reset arp all command to delete all ARP entries or the reset arp static command to delete all static ARP entries.
To configure ARP scanning and fixed ARP:
Step
3.     Trigger an ARP scanning.
arp scan [ start-ip-address to end-ip-address ]
5.     Convert existing dynamic ARP entries to static ARP entries.
arp fixup
Configure this feature on interfaces not connected with a gateway to prevent gateway spoofing attacks.
When such an interface receives an ARP packet, it checks whether the sender IP address in the packet is consistent with that of any protected gateway. If yes, it discards the packet. If not, it handles the packet correctly.
Follow these guidelines when you configure ARP gateway protection:
·     You can enable ARP gateway protection for a maximum of eight gateways on an interface.
·     Do not configure both the arp filter source and arp filter binding commands on an interface.
·     If ARP gateway protection works with ARP attack detection, MFF, ARP snooping, and ARP fast-reply, ARP gateway protection applies first.
To configure ARP gateway protection:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface and Layer 2 aggregate interface view.
N/A
3.     Enable ARP gateway protection for the specified gateway.
arp filter source ip-address
By default, ARP gateway protection is disabled.
As shown in Figure 7, Host B launches gateway spoofing attacks to Device B. As a result, traffic that Device B intends to send to Device A is sent to Host B.
Configure Device B to block such attacks.
Figure 7 Network diagram
# Configure ARP gateway protection on Device B.
[DeviceB-GigabitEthernet1/0/1] arp filter source 10.1.1.1
[DeviceB-GigabitEthernet1/0/2] arp filter source 10.1.1.1
# Verify that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 discard the incoming ARP packets whose sender IP address is the IP address of the gateway.
The ARP filtering feature can prevent gateway spoofing and user spoofing attacks.
An interface enabled with this feature checks the sender IP and MAC addresses in a received ARP packet against permitted entries. If a match is found, the packet is handled correctly. If not, the packet is discarded.
Follow these guidelines when you configure ARP filtering:
·     You can configure a maximum of eight permitted entries on an interface.
·     If ARP filtering works with ARP attack detection, MFF, ARP snooping, and ARP fast-reply, ARP filtering applies first.
To configure ARP filtering:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface or Layer 2 aggregate interface view.
N/A
3.     Enable ARP filtering and configure a permitted entry.
By default, ARP filtering is disabled.
As shown in Figure 8, the IP and MAC addresses of Host A are 10.1.1.2 and 000f-e349-1233, respectively. The IP and MAC addresses of Host B are 10.1.1.3 and 000f-e349-1234, respectively.
Configure ARP filtering on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 of Device B to permit ARP packets from only Host A and Host B.
Figure 8 Network diagram
# Configure ARP filtering on Device B.
[DeviceB-GigabitEthernet1/0/1] arp filter binding 10.1.1.2 000f-e349-1233
[DeviceB-GigabitEthernet1/0/2] arp filter binding 10.1.1.3 000f-e349-1234
# Verify that GigabitEthernet 1/0/1 permits ARP packets from Host A and discards other ARP packets.
# Verify that GigabitEthernet 1/0/2 permits ARP packets from Host B and discards other ARP packets.
This feature allows a gateway to check the sender IP address of an ARP packet in a VLAN before ARP learning. If the sender IP address is within the allowed IP address range, the gateway continues ARP learning. If the sender IP address is out of the range, the gateway determines the ARP packet as an attack packet and discards it.
When you configure the ARP sender IP address checking feature in a VLAN, follow these restrictions and guidelines:
·     If the VLAN is a sub-VLAN and is associated with a super VLAN, configure this checking feature only in the sub-VLAN.
·     If Layer 3 communication is configured between the secondary VLANs associated with a primary VLAN, configure this feature in the primary VLAN. If Layer 3 communication is not configured between the secondary VLANs associated with a primary VLAN, configure this feature in the intended VLAN.
To configure the ARP sender IP address checking feature:
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Enable the ARP sender IP address checking feature and specify the IP address range.
arp sender-ip-range start-ip-address end-ip-address
By default, the ARP sender IP address checking feature is disabled.
