10-Security Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release752X-6W10010-Security Configuration Guide
21-MACsec configuration
21-MACsec configuration 215.62 KB
Configuring MACsec
Overview
Media Access Control Security (MACsec) secures data communication on IEEE 802 LANs. MACsec provides services such as data encryption, frame integrity check, and data origin validation for frames on the MAC sublayer of the Data Link Layer.
Basic concepts
CA
Connectivity association (CA) is a group of participants that use the same key and key algorithm. The encryption key used by the CA participants is called a connectivity association key (CAK). The following types of CAKs are available:
·     Pairwise CAK—Used by CAs that have two participants.
·     Group CAK—Used by CAs that have more than two participants.
The pairwise CAK is used most often because MACsec is typically applied to point-to-point networks.
A CAK can be an encryption key generated during 802.1X authentication or a user-configured preshared key. The user-configured preshared key takes precedence over the 802.1X-generated key.
SA
Secure association (SA) is an agreement negotiated by CA participants. The agreement includes a cipher suite and keys for integrity check.
A secure channel can contain more than one SA. Each SA uses a unique secure association key (SAK). The SAK is generated from the CAK, and MACsec uses the SAK to encrypt data transmitted along the secure channel.
MACsec Key Agreement (MKA) limits the number of packets that can be encrypted by an SAK. When the limit is exceeded, the SAK will be refreshed. For example, when packets with the minimum size are sent on a 10-Gbps link, an SAK rekey occurs about every 300 seconds.
MACsec services
MACsec provides the following services:
·     Data encryption—Enables a port to encrypt outbound frames and decrypt MACsec-encrypted inbound frames.
·     Integrity check—Performs integrity check when the device receives a MACsec-encrypted frame. The integrity check uses the following process:
a.     Uses a key negotiated by MKA to calculate an integrity check value (ICV) for the frame.
b.     Compares the calculated ICV with the ICV in the frame trailer.
-     If the ICVs are the same, the device verifies the frame as legal.
-     If the ICVs are different, the device determines whether to drop the frame based on the validation mode.
·     MACsec replay protection—When MACsec frames are transmitted over the network, frame disorder might occur. MACsec replay protection allows the device to accept the out-of-order packets within the replay protection window size and drop other out-of-order packets.
MACsec applications
MACsec supports the following application modes:
·     Client-oriented mode—Secures data transmission between the client and the access device. The client can be a user terminal seeking access to the LAN or a device that supports the 802.1X client feature. In this mode, the authentication server generates and distributes the CAK to the client and the access device. In this mode, MACsec must operate with 802.1X authentication.
Figure 1 Client-oriented mode
In client-oriented mode, an MKA-enabled port on the access device must perform port-based 802.1X access control. The authentication method must be EAP relay.
·     Device-oriented mode—Secures data transmission between devices. Unlike the client-oriented mode, in this mode, the devices do not perform identity authentication, and the same preshared key must be configured on the MACsec ports that connect the devices. The devices use the configured preshared key as the CAK.
Figure 2 Device-oriented mode
MACsec operating mechanism
Operating mechanism for client-oriented mode
Figure 3 illustrates how MACsec operates in client-oriented mode.
Figure 3 MACsec interactive process in client-oriented mode
The following shows the MACsec process:
1.     After the client passes 802.1X authentication, the RADIUS server distributes the generated CAK to the client and the access device.
2.     After receiving the CAK, the client and the access device exchange EAPOL-MKA packets.
The client and the access device exchange the MACsec capability and required parameters for session establishment. The parameters include MKA key server priority and MACsec desire.
During the negotiation process, the access device automatically becomes the key server. The key server generates an SAK from the CAK for packet encryption, and it distributes the SAK to the client.
3.     The client and the access device use the SAK to encrypt packets, and they send and receive the encrypted packets in secure channels.
4.     When the access device receives a logoff request from the client, it immediately removes the associated secure session from the port. The remove operation prevents an unauthorized client from using the secure session established by the previous authorized client to access the network.
The MKA protocol also defines a session keepalive timer. If one participant does not receive any MKA packets from the peer after the timer expires, the participant removes the established secure session. The keepalive time is 6 seconds.
Operating mechanism for device-oriented mode
As shown in Figure 4, the devices use the configured preshared keys to start the session negotiation.
In this mode, the session negotiation, secure communication, and session termination processes are the same as the processes in client-oriented mode. However, MACsec performs a key server selection in this mode. The port with higher MKA key server priority becomes the key server, which is responsible for the generation and distribution of SAKs.
Figure 4 MACsec interactive process in device-oriented mode
Protocols and standards
·     IEEE 802.1X-2010, Port-Based Network Access Control
·     IEEE 802.1X-2006, Media Access Control (MAC) Security
Feature and hardware compatibility
MACsec is supported only on the following ports:
·     All ports on the LSQM3GP44TSSC0 module.
·     Ports that are numbered from 1 to 8 on the following SA interface modules:
¡     LSQM2GP24SA0.
¡     LSQM2GP24TSSA0.
¡     LSQM2GT48SA0.
·     Ports that are numbered from 1 to 8 on the following SC interface modules:
¡     LSQM2GP44TSSC0.
¡     LSQM2GP24TSSC0.
¡     LSQM2GT24PTSSC0.
¡     LSQM2GT24TSSC0.
¡     LSQM2GT48SC0.
¡     LSQM4GV48SC0.
General restrictions and guidelines
When you configure MACsec, follow these restrictions and guidelines:
·     In device-oriented mode, the MACsec configuration takes effect on Layer 2 and Layer 3 Ethernet ports.
·     MACsec is not supported on an aggregate interface, but it is supported on the member ports of an aggregation group.
·     The MACsec header occupies 38 bytes in each frame. Please take into consideration the header when you plan the network capacity.
MACsec configuration task list
In device-oriented mode, the MACsec configuration takes effect on Layer 2 and Layer 3 Ethernet ports. In client-oriented mode, the MACsec configuration takes effect only on 802.1X-enabled ports.
To configure MACsec, perform the following tasks:
Tasks at a glance
Remarks
(Required.) Enabling MKA
N/A
(Optional.) Enabling MACsec desire
N/A
(Optional.) Configuring a preshared key
This task is required in device-oriented mode.
(Optional.) Configuring the MKA key server priority
N/A
(Optional.) Use one of the following methods to configure MACsec protection parameters:
·     Configuring MACsec protection parameters in interface view:
¡     Configuring the MACsec confidentiality offset
¡     Configuring MACsec replay protection
¡     Configuring the MACsec validation mode
·     Configuring MACsec protection parameters by MKA policy:
¡     Configuring an MKA policy
¡     Applying an MKA policy
N/A
Enabling MKA
MKA establishes and manages MACsec secure channels on a port. It also negotiates keys used by MACsec.
You cannot enable MKA on a MACsec-incapable port.
To enable MKA:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Enable MKA.
mka enable
By default, MKA is disabled on the port.
The MACsec desire feature expects MACsec protection for outbound frames. The key server determines whether MACsec protects the outbound frames.
MACsec protects the outbound frames of a port when the following requirements are met:
·     The key server is MACsec capable.
·     Both the local participant and its peer are MACsec capable.
·     A minimum of one participant is enabled with MACsec desire.
To enable MACsec desire:
Step
Remarks
N/A
N/A
3.     Enable MACsec desire.
macsec desire
By default, the port does not expect MACsec protection for outbound frames.
In device-oriented mode, configure a preshared key as the CAK to be used during MKA negotiation. To successfully establish an MKA session between two devices, make sure the connected MACsec ports are configured with the same preshared key.
A user-configured preshared key has higher priority than the 802.1X-generated CAK. To ensure a successful MKA session establishment, do not configure a preshared key in client-oriented mode.
To configure a preshared key:
Step
Remarks
N/A
N/A
3.     Set a preshared key.
mka psk ckn name cak simple string
By default, no MKA preshared key exists.
The MACsec cipher suite supported by the device requires that the CKN and CAK each must be 32 characters long. If the configured CKN or CAK is not 32 characters long, the system performs the following operations when it runs the cipher suite:
·     Automatically increases the length of the CKN or CAK by zero padding if the CKN or CAK contains less than 32 characters.
·     Uses only the first 32 characters if the CKN or CAK contains more than 32 characters.
Configure an MKA key server priority for key server selection. The lower the priority value, the higher the priority.
In client-oriented mode, the access device port automatically becomes the key server. You do not have to configure the MKA key server priority.
In device-oriented mode, the port that has higher priority becomes the key server. If a port and its peers have the same priority, MACsec compares the secure channel identifier (SCI) values on the ports. The port with the lowest SCI value (a combination of MAC address and port ID) becomes the key server.
A port with priority 255 cannot become the key server. For a successful key server selection, make sure a minimum of one participant's key server priority is not 255.
To configure the MKA key server priority:
Step
Remarks
N/A
N/A
3.     Set the MKA key server priority.
mka priority priority-value
The default setting is 0.
If you configure a parameter in interface view after applying an MKA policy, the configuration in interface view overwrites the configuration of the parameter in the MKA policy. Your configuration also removes the MKA policy application from the port. However, other parameter settings of the MKA policy are effective on the port.
If the parameter value in interface view is the same as the value in the MKA policy, your configuration does not take effect. The policy remains active on the port.
The MACsec confidentiality offset specifies the number of bytes starting from the frame header. MACsec encrypts only the bytes after the offset in a frame.
MACsec uses the confidentiality offset propagated by the key server.
To configure the MACsec confidentiality offset:
Step
Remarks
N/A
N/A
3.     Set the MACsec confidentiality offset.
macsec confidentiality-offset offset-value
The default setting is 0, and the entire frame needs to be encrypted.
The offset value can be 0, 30, or 50.
The MACsec replay protection feature allows a MACsec port to accept a number of out-of-order or repeated inbound frames. The configured replay protection window size is effective only when MACsec replay protection is enabled.
To configure MACsec replay protection:
Step
Remarks
N/A
N/A
3.     Enable MACsec replay protection.
macsec replay-protection enable
By default, MACsec replay protection is enabled on the port.
4.     Set the MACsec replay protection window size.
macsec replay-protection window-size size-value
The default setting is 0, and frames are accepted only in the correct order.
The MACsec validation allows a port to perform integrity check based on the following validation modes:
·     check—Performs validation only, and does not drop illegal frames.
·     strict—Performs validation, and drops illegal frames.
To avoid data loss, use the default validation mode check on the MACsec devices in case of MKA negotiation failure. After you use the display macsec command to verify that MKA negotiation has succeeded, change the validation mode to strict.
To configure the MACsec validation mode:
Step
Remarks
N/A
N/A
3.     Set a MACsec validation mode.
macsec validation mode { check | strict }
The default setting is check.
Step
Remarks
N/A
2.     Create an MKA policy and enter its view.
mka policy policy-name
By default, a system-defined MKA policy exists. The policy name is default-policy.
The settings for parameters in the default policy are the same as the default settings for the parameters on a port.
You cannot delete or modify the default MKA policy.
You can create multiple MKA policies.
3.     (Optional.) Set the MACsec confidentiality offset.
4.     (Optional.) Configure MACsec replay protection.
a     Enable MACsec replay protection:
b     Set the replay protection window size:
By default, MACsec replay protection is enabled.
The default replay protection window size is 0. Frames are accepted only in the correct order.
5.     Set a MACsec validation mode.
MKA policy provides a centralized method to configure MACsec confidentiality offset, replay protection, and validation mode. An MKA policy can be applied to a port or multiple ports. When you apply an MKA policy to a port, follow these restrictions and guidelines:
·     The MACsec parameter settings configured in the MKA policy overwrite the MACsec parameters previously configured on the port.
·     Any modifications to the MKA policy take effect immediately.
·     When you remove an MKA policy application from the port, the MACsec parameter settings on the port restore to the default.
·     When you apply a nonexistent MKA policy to the port, the port automatically uses the default MKA policy. If you create the policy, the policy will be automatically applied to the port.
To apply an MKA policy to a port:
Step
Remarks
N/A
N/A
3.     Apply an MKA policy.
mka apply policy policy-name
By default, no MKA policy is applied to the port.
Displaying and maintaining MACsec
Display MACsec information on ports.
display macsec [ interface interface-type interface-number ] [ verbose ]
Display MKA session information.
display mka session [ interface interface-type interface-number | local-sci sci-id ] [ verbose ]
Display MKA policy information.
display mka { default-policy | policy [ name policy-name ] }
Display MKA statistics on ports.
display mka statistics [ interface interface-type interface-number ]
Reset MKA sessions on ports.
reset mka session [ interface interface-type interface-number ]
Clear MKA statistics on ports.
reset mka statistics [ interface interface-type interface-number ]
MACsec configuration examples
Client-oriented MACsec configuration example (host as client)
Network requirements
As shown in Figure 5, the host accesses the network through GigabitEthernet 1/0/1. The device performs RADIUS-based 802.1X authentication for the host to control user access to the Internet.
To ensure secure communication between the host and device, perform the following tasks on the device:
·     Enable MACsec desire, and configure MKA to negotiate SAKs for packet encryption.
·     Set the MACsec confidentiality offset to 30 bytes.
·     Enable MACsec replay protection, and set the replay protection window size to 100.
·     Set the MACsec validation mode to strict.
Figure 5 Network diagram
Configuration procedure
1.     Configure the RADIUS server to provide authentication, authorization, and accounting services. Add a user account for the host. (Details not shown.)
2.     Configure IP addresses for the Ethernet ports. (Details not shown.)
3.     Configure AAA:
# Enter system view.
# Configure RADIUS scheme radius1.
[Device] radius scheme radius1
[Device-radius-radius1] primary authentication 10.1.1.1
[Device-radius-radius1] primary accounting 10.1.1.1
[Device-radius-radius1] key authentication simple name
[Device-radius-radius1] key accounting simple money
[Device-radius-radius1] user-name-format without-domain
[Device-radius-radius1] quit
# Configure authentication domain bbb for 802.1X users.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access radius-scheme radius1
[Device-isp-bbb] authorization lan-access radius-scheme radius1
[Device-isp-bbb] accounting lan-access radius-scheme radius1
[Device-isp-bbb] quit
4.     Configure 802.1X:
# Enable 802.1X on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x
# Implement port-based access control on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x port-method portbased
# Specify bbb as the mandatory authentication domain for 802.1X users on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] dot1x mandatory-domain bbb
# Enable 802.1X globally, and sets the device to relay EAP packets.
[Device] dot1x
[Device] dot1x authentication-method eap
5.     Configure MACsec:
# Create an MKA policy named pls.
[Device] mka policy pls
# Set the MACsec confidentiality offset to 30 bytes.
[Device-mka-policy-pls] confidentiality-offset 30
# Enable MACsec replay protection.
[Device-mka-policy-pls] replay-protection enable
# Set the MACsec replay protection window size to 100.
[Device-mka-policy-pls] replay-protection window-size 100
# Set the MACsec validation mode to strict.
[Device-mka-policy-pls] validation mode strict
[Device-mka-policy-pls] quit
# Apply the MKA policy to GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mka apply policy pls
# Configure MACsec desire and enable MKA on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] macsec desire
[Device-GigabitEthernet1/0/1] mka enable
# Display MACsec information on GigabitEthernet 1/0/1.
[Device] display macsec interface gigabitethernet 1/0/1 verbose
  Protect frames         : Yes
  Active MKA policy      : pls
  Replay protection      : Enabled
  Replay window size     : 100 frames
  Confidentiality offset : 30 bytes
  Validation mode        : Strict
  Included SCI           : No
  SCI conflict           : No
  Cipher suite           : GCM-AES-128
  Transmit secure channel:
    SCI           : 00E00100000A0006
      Elapsed time: 00h:02m:07s
      Current SA  : AN 0        PN 1
  Receive secure channels:
    SCI           : 00E0020000000106
      Elapsed time: 00h:02m:03s
      Current SA  : AN 0        LPN 1
      Previous SA : AN N/A      LPN N/A
# Display MKA session information on GigabitEthernet 1/0/1 after a user logs in.
[Device] display mka session interface gigabitethernet 1/0/1 verbose
Tx-SCI    : 00E00100000A0006
Priority  : 0
Capability: 3
  CKN for participant: 1234
    Key server            : Yes
    MI (MN)               : A1E0D2897596817209CD2307 (2509)
    Live peers            : 1
    Potential peers       : 0
    Principal actor       : Yes
    MKA session status    : Secured
    Confidentiality offset: 30 bytes
    Current SAK status    : Rx & Tx
    Current SAK AN        : 0
    Current SAK KI (KN)   : A1E0D2897596817209CD230700000002 (2)
    Previous SAK status   : N/A
    Previous SAK AN       : N/A
    Previous SAK KI (KN)  : N/A
    Live peer list:
    MI                        MN         Priority  Capability  Rx-SCI
    B2CAF896C9BFE2ABFB135E63  2512       0         3           00E0020000000106
Client-oriented MACsec configuration example (device as client)
As shown in Figure 6:
·     The switch connects to the device through trunk ports GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3.
·     The device acts as an access device. You cannot configure a preshared key on the device for MKA negotiation and packet encryption.
·     The RADIUS server acts as an 802.1X authentication server.
To secure data between the switch and the device by MACsec, perform the following tasks on the switch:
·     Configure the 802.1X client feature, so that the switch acts as an 802.1X client and can use 802.1X-generated CAKs for MAcsec.
Figure 6 Network diagram
1.     Configure IP addresses for the Ethernet ports. Make sure the switch, the device, and the RADIUS server can reach one another. (Details not shown.)
2.     Configure the access device. (Details not shown.)
Configuration on the access device varies by manufacturer. For information about device configuration, see the corresponding product manual. This part illustrates only the switch configuration, and for information about 802.1X client commands, see Security Command Reference.
3.     Configure the RADIUS server to provide authentication, authorization, and accounting services. Add user accounts. (Details not shown.)
4.     Configure the switch:
# Create VLAN 2.
<Switch> system-view
[Switch] vlan 2
[Switch-vlan2] quit
# Configure GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLAN 2.
[Switch-GigabitEthernet1/0/2] port link-type trunk
[Switch-GigabitEthernet1/0/2] port trunk permit vlan 2
# Configure the 802.1X client username as aaaa, and set the password to 123456 in plaintext form on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant username aaaa
[Switch-GigabitEthernet1/0/2] dot1x supplicant password simple 123456
# Specify TTLS-GTC as the 802.1X client EAP authentication method on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant eap-method ttls-gtc
# Specify MAC address 1-1-1 for 802.1X client authentication on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant mac-address 1-1-1
# Enable the 802.1X client feature on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] dot1x supplicant enable
# Configure MACsec desire and enable MKA on GigabitEthernet 1/0/2.
[Switch-GigabitEthernet1/0/2] macsec desire
[Switch-GigabitEthernet1/0/2] mka enable
# Create VLAN 3.
[Switch] vlan 3
[Switch-vlan3] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLAN 3.
[Switch] interface gigabitethernet 1/0/3
[Switch-GigabitEthernet1/0/3] port link-type trunk
[Switch-GigabitEthernet1/0/3] port trunk permit vlan 3
# Configure the 802.1X client username as bbbb, and set the password to 654321 in plaintext form on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant username bbbb
[Switch-GigabitEthernet1/0/3] dot1x supplicant password simple 654321
# Specify TTLS-GTC as the 802.1X client EAP authentication method on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant eap-method ttls-gtc
# Specify MAC address 1-1-2 for 802.1X client authentication on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant mac-address 1-1-2
# Enable the 802.1X client feature on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] dot1x supplicant enable
# Configure MACsec desire and enable MKA on GigabitEthernet 1/0/3.
[Switch-GigabitEthernet1/0/3] macsec desire
[Switch-GigabitEthernet1/0/3] mka enable
[Switch-GigabitEthernet1/0/3] quit
# Display MACsec information on GigabitEthernet 1/0/2.
[Switch] display macsec interface gigabitethernet 1/0/2 verbose
Interface GigabitEthernet1/0/2
  Replay window size     : 0 frames
  Confidentiality offset : 0 bytes
  Validation mode        : Check
  Included SCI           : No
  SCI conflict           : No
# Display MACsec information on GigabitEthernet 1/0/3.
[Switch] display macsec interface gigabitethernet 1/0/3 verbose
Interface GigabitEthernet1/0/3
  Included SCI           : No
  SCI conflict           : No
    SCI           : A087100801000103
      Elapsed time: 00h:00m:55s
    SCI           : A0872B3602000003
      Elapsed time: 00h:00m:52s
# Display MKA session information on GigabitEthernet 1/0/2 after 802.1X client user aaaa comes online.
[Switch] display mka session interface gigabitethernet 1/0/2 verbose
Priority  : 0
Capability: 3
   Key server            : No
   Live peers            : 1
   Potential peers       : 0
   Confidentiality offset: 0 bytes
   Current SAK AN        : 0
   Live peer list:
# Display MKA session information on GigabitEthernet 1/0/3 after 802.1X client user bbbb comes online.
[Switch] display mka session interface gigabitethernet 1/0/3 verbose
Tx-SCI    : A087100801000103
Priority  : 0
Capability: 3
  CKN for participant: 7B8784F16F85ED8F9D0130AA9B93D0F0
    Key server            : No
    MI (MN)               : D3F6D374598C8FD1F1819D6C (78)
    Live peers            : 1
    Potential peers       : 0
    Current SAK AN        : 0
    Current SAK KI (KN)   : FCA71854FCAE51398EC2DA7900000001 (1)
    Live peer list:
    FCA71854FCAE51398EC2DA79  71         0         3           A0872B3602000003
Device-oriented MACsec configuration example
As shown in Figure 7, Device A is the MACsec key server.
To secure data transmission between the two devices by MACsec, perform the following tasks on Device A and Device B, respectively:
·     Configure the CAK name (CKN) and the CAK as E9AC and 09DB3EF1, respectively.
Figure 7 Network diagram
1.     Configure Device A:
# Enter GigabitEthernet 1/0/1 interface view.
# Enable MACsec desire on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] macsec desire
# Set the MKA key server priority to 5.
[DeviceA-GigabitEthernet1/0/1] mka priority 5
# Configure the CKN as E9AC and the CAK as 09DB3EF1 in plain text.
[DeviceA-GigabitEthernet1/0/1] mka psk ckn E9AC cak simple 09DB3EF1
[DeviceA-GigabitEthernet1/0/1] macsec confidentiality-offset 30
[DeviceA-GigabitEthernet1/0/1] macsec replay-protection enable
[DeviceA-GigabitEthernet1/0/1] macsec replay-protection window-size 100
[DeviceA-GigabitEthernet1/0/1] macsec validation mode strict
# Enable MKA on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] mka enable
2.     Configure Device B:
[DeviceB-GigabitEthernet1/0/1] macsec desire
# Set the MKA key server priority to 10.
[DeviceB-GigabitEthernet1/0/1] mka priority 10
[DeviceB-GigabitEthernet1/0/1] mka psk ckn E9AC cak simple 09DB3EF1
[DeviceB-GigabitEthernet1/0/1] macsec confidentiality-offset 30
[DeviceB-GigabitEthernet1/0/1] macsec replay-protection enable
[DeviceB-GigabitEthernet1/0/1] macsec replay-protection window-size 100
[DeviceB-GigabitEthernet1/0/1] macsec validation mode strict
[DeviceB-GigabitEthernet1/0/1] mka enable
# Display MACsec information on GigabitEthernet 1/0/1 of Device A.
[DeviceA] display macsec interface gigabitethernet 1/0/1 verbose
  Included SCI           : No
  SCI conflict           : No
      Elapsed time: 00h:05m:00s
      Elapsed time: 00h:03m:18s
# Display MKA session information on GigabitEthernet 1/0/1 of Device A.
[DeviceA] display mka session interface gigabitethernet 1/0/1 verbose
Priority  : 5
Capability: 3
  CKN for participant: E9AC
    Key server            : Yes
    MI (MN)               : 85E004AF49934720AC5131D3 (182)
    Live peers            : 1
    Potential peers       : 0
    Current SAK AN        : 0
    Current SAK KI (KN)   : 85E004AF49934720AC5131D300000003 (3)
    Live peer list:
    12A1677D59DD211AE86A0128  182        10        3           00E0020000000106
# Display MACsec information on GigabitEthernet 1/0/1 of Device B.
[DeviceB] display macsec interface gigabitethernet 1/0/1 verbose
  Included SCI           : No
  SCI conflict           : No
      Elapsed time: 00h:05m:36s
      Elapsed time: 00h:03m:21s
# Display MKA session information on GigabitEthernet 1/0/1 of Device B.
[DeviceB] display mka session interface gigabitethernet 1/0/1 verbose
Tx-SCI    : 00E0020000000106
Priority  : 10
Capability: 3
    Key server            : No
    MI (MN)               : 12A1677D59DD211AE86A0128 (1219)
    Live peers            : 1
    Potential peers       : 0
    Current SAK AN        : 0
    Live peer list:
    85E004AF49934720AC5131D3  1216       5         3           00E00100000A0006
Troubleshooting MACsec
Cannot establish MKA sessions between MACsec devices
Symptom
The devices cannot establish MKA sessions when the following conditions exist:
·     The link connecting the devices is up.
·     The ports at the ends of the link are MACsec capable.
Analysis
The symptom might occur for the following reasons:
·     The ports at the link are not enabled with MKA.
·     A port at the link is not configured with a preshared key or configured with a preshared key different from the peer.
Solution
To resolve the problem:
1.     Enter interface view.
2.     Use the display this command to check the MACsec configuration:
¡     If MKA is not enabled on the port, execute the mka enable command.
¡     If a preshared key is not configured or the preshared key is different from the peer, use the mka psk command to configure a preshared key. Make sure the preshared key is the same as the preshared key on the peer.
3.     If the problem persists, contact H3C Support.
