04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release752X-6W10004-Layer 2 - LAN Switching Configuration Guide
04-VLAN configuration
04-VLAN configuration 550.32 KB
Configuring VLANs· 3
Overview· 3
VLAN frame encapsulation· 3
Protocols and standards· 4
Configuring basic VLAN settings· 4
Configuring VLAN interfaces· 5
Configuring port-based VLANs· 6
Introduction· 6
Assigning an access port to a VLAN· 7
Assigning a trunk port to a VLAN· 8
Assigning a hybrid port to a VLAN· 8
Configuring MAC-based VLANs· 9
Introduction· 9
General configuration restrictions and guidelines· 12
Configuring static MAC-based VLAN assignment 12
Configuring dynamic MAC-based VLAN assignment 12
Configuring server-assigned MAC-based VLAN· 13
Configuring IP subnet-based VLANs· 14
Configuring protocol-based VLANs· 15
Configuring a VLAN group· 16
Displaying and maintaining VLANs· 16
VLAN configuration examples· 17
Port-based VLAN configuration example· 17
MAC-based VLAN configuration example· 18
IP subnet-based VLAN configuration example· 20
Protocol-based VLAN configuration example· 22
Configuring super VLANs· 25
Overview· 25
Super VLAN configuration task list 25
Creating a sub-VLAN· 26
Configuring a super VLAN· 26
Configuring a super VLAN interface· 26
Displaying and maintaining super VLANs· 27
Super VLAN configuration example· 27
Network requirements· 27
Configuration procedure· 28
Verifying the configuration· 29
Configuring the private VLAN·· 30
Configuration task list 31
Configuration restrictions and guidelines· 31
Configuration procedure· 32
Displaying and maintaining the private VLAN· 33
Private VLAN configuration examples· 34
Promiscuous port configuration example· 34
Trunk promiscuous port configuration example· 36
Trunk promiscuous and trunk secondary port configuration example· 39
Secondary VLAN Layer 3 communication configuration example· 43
Configuring voice VLANs· 45
Overview· 45
Methods of identifying IP phones· 45
Identifying IP phones through OUI addresses· 45
Automatically identifying IP phones through LLDP· 46
Advertising the voice VLAN information to IP phones· 46
IP phone access methods· 47
Connecting the host and the IP phone in series· 47
Connecting the IP phone to the device· 47
Voice VLAN assignment modes· 48
Automatic mode· 48
Manual mode· 48
Cooperation of voice VLAN assignment modes and IP phones· 49
Security mode and normal mode of voice VLANs· 49
Voice VLAN configuration task list 50
Configuring the QoS priority settings for voice traffic· 51
Configuring a port to operate in automatic voice VLAN assignment mode· 51
Configuration restrictions and guidelines· 51
Configuration procedure· 52
Configuring a port to operate in manual voice VLAN assignment mode· 53
Configuration restrictions and guidelines· 53
Configuration procedure· 53
Enabling LLDP for automatic IP phone discovery· 54
Configuration restrictions and guidelines· 54
Configuration procedure· 54
Configuring LLDP to advertise a voice VLAN· 54
Configuring CDP to advertise a voice VLAN· 55
Displaying and maintaining voice VLANs· 55
Voice VLAN configuration examples· 56
Automatic voice VLAN assignment mode configuration example· 56
Manual voice VLAN assignment mode configuration example· 57
Configuring VLANs
Overview
Ethernet is a family of shared-media LAN technologies based on the CSMA/CD mechanism. An Ethernet LAN is both a collision domain and a broadcast domain. Because the medium is shared, collisions and broadcasts are common in an Ethernet LAN. Typically, bridges and Layer 2 switches can reduce collisions in an Ethernet LAN. To confine broadcasts, a Layer 2 switch must use the Virtual Local Area Network (VLAN) technology.
VLANs enable a Layer 2 switch to break a LAN down into smaller broadcast domains, as shown in Figure 1.
Figure 1 A VLAN diagram
A VLAN is logically divided on an organizational basis rather than on a physical basis. For example, you can assign all workstations and servers used by a particular workgroup to the same VLAN, regardless of their physical locations. Hosts in the same VLAN can directly communicate with one another. You need a router or a Layer 3 switch for hosts in different VLANs to communicate with one another.
All these VLAN features reduce bandwidth waste, improve LAN security, and enable flexible virtual group creation.
To identify Ethernet frames from different VLANs, IEEE 802.1Q inserts a four-byte VLAN tag between the destination and source MAC address (DA&SA) field and the Type field.
Figure 2 VLAN tag placement and format
A VLAN tag includes the following fields:
·     TPID—16-bit tag protocol identifier that indicates whether a frame is VLAN-tagged. By default, the hexadecimal TPID value 8100 identifies a VLAN-tagged frame. A device vendor can set the TPID to a different value. For compatibility with a neighbor device, set the TPID value on the device to be the same as the neighbor device.
·     Priority—3-bit long, identifies the 802.1p priority of the frame. For more information, see ACL and QoS Configuration Guide.
·     CFI—1-bit long canonical format indicator that indicates whether the MAC addresses are encapsulated in the standard format when packets are transmitted across different media. Available values include:
¡     0 (default)—The MAC addresses are encapsulated in the standard format.
¡     1—The MAC addresses are encapsulated in a non-standard format.
This field is always set to 0 for Ethernet.
·     VLAN ID—12-bit long, identifies the VLAN to which the frame belongs. The VLAN ID range is 0 to 4095. VLAN IDs 0 and 4095 are reserved, and VLAN IDs 1 to 4094 are user configurable.
The way a network device handles an incoming frame depends on whether the frame has a VLAN tag and the value of the VLAN tag (if any). For more information, see "Introduction."
Ethernet supports encapsulation formats Ethernet II, 802.3/802.2 LLC, 802.3/802.2 SNAP, and 802.3 raw. The Ethernet II encapsulation format is used here. For information about the VLAN tag fields in other frame encapsulation formats, see related protocols and standards.
For a frame that has multiple VLAN tags, the device handles it according to its outermost VLAN tag and transmits its inner VLAN tags as the payload.
IEEE 802.1Q, IEEE Standard for Local and Metropolitan Area Networks: Virtual Bridged Local Area Networks
Step
Remarks
N/A
2.     (Optional.) Create a VLAN and enter its view, or create a list of VLANs.
vlan { vlan-id1 [ to vlan-id2 ] | all }
By default, only the system default VLAN (VLAN 1) exists.
3.     Enter VLAN view.
vlan vlan-id
To configure a VLAN after you create a list of VLANs, you must perform this step.
4.     Set a name for the VLAN.
name text
By default, the name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
5.     Configure the description for the VLAN.
By default, the description of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
·     As the system default VLAN, VLAN 1 cannot be created or deleted.
·     Before you delete a dynamic VLAN or a VLAN locked by an application, you must first remove the configuration from the VLAN.
Hosts of different VLANs use VLAN interfaces to communicate at Layer 3. VLAN interfaces are virtual interfaces that do not exist as physical entities on devices. For each VLAN, you can create one VLAN interface and assign an IP address to it. The VLAN interface acts as the gateway of the VLAN to forward packets destined for another IP subnet at Layer 3.
When you configure a VLAN interface, follow these restrictions and guidelines:
·     Before you create a VLAN interface for a VLAN, create the VLAN first.
·     You cannot create VLAN interfaces for sub-VLANs. For more information about sub-VLANs, see "Configuring super VLANs."
·     You cannot create VLAN interfaces for secondary VLANs that have the following characteristics:
¡     Associated with the same primary VLAN.
¡     Enabled with Layer 3 communication in VLAN interface view of the primary VLAN interface.
For more information about secondary VLANs, see "Configuring the private VLAN."
To configure basic settings of a VLAN interface:
Step
Remarks
N/A
2.     Create a VLAN interface and enter its view.
If the VLAN interface already exists, you enter its view directly.
By default, no VLAN interfaces exist.
3.     Assign an IP address to the VLAN interface.
By default, no IP address is assigned to a VLAN interface.
4.     Configure the description for the VLAN interface.
The default setting is the VLAN interface name. For example, Vlan-interface1 Interface.
5.     (Optional.) Specify a traffic processing slot for the interface.
·     Distributed devices in standalone mode:
service slot slot-number
·     Distributed devices in IRF mode:
service chassis chassis-number slot slot-number
By default, no traffic processing slot is specified for an interface.
6.     Set the MTU for the VLAN interface.
mtu size
The default setting is 1500 bytes.
7.     Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
8.     (Optional.) Restore the default settings for the VLAN interface.
default
N/A
9.     (Optional.) Bring up the VLAN interface.
N/A
Introduction
Port-based VLANs group VLAN members by port. A port forwards packets from a VLAN only after it is assigned to the VLAN.
Port link type
You can set the link type of a port to access, trunk, or hybrid. The port link type determines whether the port can be assigned to multiple VLANs. The link types use the following VLAN tag handling methods:
·     Access—An access port can forward packets only from one VLAN and send these packets untagged. An access port is typically used in the following conditions:
¡     Connecting to a terminal device that does not support VLAN packets.
¡     In scenarios that do not distinguish VLANs.
·     Trunk—A trunk port can forward packets from multiple VLANs. Except packets from the port VLAN ID (PVID), packets sent out of a trunk port are VLAN-tagged. Ports connecting network devices are typically configured as trunk ports.
·     Hybrid—A hybrid port can forward packets from multiple VLANs. The tagging status of the packets forwarded by a hybrid port depends on the port configuration. In one-to-two VLAN mapping, hybrid ports are used to remove SVLAN tags for downlink traffic. For more information about one-to-two VLAN mapping, see "Configuring VLAN mapping."
PVID
The PVID identifies the default VLAN of a port. Untagged packets received on a port are considered as the packets from the port PVID.
When you set the PVID for a port, follow these restrictions and guidelines:
·     An access port can join only one VLAN. The VLAN to which the access port belongs is the PVID of the port.
·     A trunk or hybrid port supports multiple VLANs and the PVID configuration.
·     When you use the undo vlan command to delete the PVID of a port, either of the following events occurs depending on the port link type:
¡     For an access port, the PVID of the port changes to VLAN 1.
¡     For a hybrid or trunk port, the PVID setting of the port does not change.
You can use a nonexistent VLAN as the PVID for a hybrid or trunk port, but not for an access port.
·     As a best practice, set the same PVID for a local port and its peer.
·     To prevent a port from dropping untagged packets or PVID-tagged packets, assign the port to its PVID.
How ports of different link types handle frames
Actions
Access
Trunk
Hybrid
In the inbound direction for an untagged frame
Tags the frame with the PVID tag.
·     If the PVID is permitted on the port, tags the frame with the PVID tag.
·     If not, drops the frame.
In the inbound direction for a tagged frame
·     Receives the frame if its VLAN ID is the same as the PVID.
·     Drops the frame if its VLAN ID is different from the PVID.
·     Receives the frame if its VLAN is permitted on the port.
·     Drops the frame if its VLAN is not permitted on the port.
In the outbound direction
Removes the VLAN tag and sends the frame.
·     Removes the tag and sends the frame if the frame carries the PVID tag and the port belongs to the PVID.
·     Sends the frame without removing the tag if its VLAN is carried on the port but is different from the PVID.
Sends the frame if its VLAN is permitted on the port. The tagging status of the frame depends on the port hybrid vlan command configuration.
In a VLAN-aware network, the default processing order for untagged packets is as follows, in descending order of priority:
·     MAC-based VLANs.
·     IP subnet-based VLANs.
·     Protocol-based VLANs.
·     Port-based VLANs.
You can assign an access port to a VLAN in VLAN view or interface view.
Make sure the VLAN has been created.
Assign one or multiple access ports to a VLAN in VLAN view
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Assign one or multiple access ports to the VLAN.
port interface-list
By default, all ports belong to VLAN 1.
Assign an access port to a VLAN in interface view
Step
Remarks
N/A
2.     Enter interface view.
·     Enter Layer 2 Ethernet interface view:
interface
interface-type interface-number
·     Enter Layer 2 aggregate interface view:
interface bridge-aggregation
interface-number
N/A
3.     Set the port link type to access.
port link-type access
By default, all ports are access ports.
4.     (Optional.) Assign the access port to a VLAN.
port access vlan vlan-id
By default, all access ports belong to VLAN 1.
A trunk port supports multiple VLANs. You can assign it to a VLAN in interface view.
When you assign a trunk port to a VLAN, follow these restrictions and guidelines:
·     To change the link type of a port from trunk to hybrid, set the link type to access first.
·     To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
To assign a trunk port to one or multiple VLANs:
Step
Remarks
N/A
interface
interface-number
N/A
3.     Set the port link type to trunk.
port link-type trunk
4.     Assign the trunk port to the specified VLANs.
By default, a trunk port permits only VLAN 1.
5.     (Optional.) Set the PVID for the trunk port.
port trunk pvid vlan vlan-id
The default setting is VLAN 1.
A hybrid port supports multiple VLANs. You can assign it to the specified VLANs in interface view. Make sure the VLANs have been created.
When you assign a hybrid port to a VLAN, follow these restrictions and guidelines:
·     To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
To assign a hybrid port to one or multiple VLANs:
Step
Remarks
N/A
interface
interface-number
N/A
3.     Set the port link type to hybrid.
port link-type hybrid
4.     Assign the hybrid port to the specified VLANs.
By default, the hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
5.     (Optional.) Set the PVID for the hybrid port.
port hybrid pvid vlan vlan-id
By default, the PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
Introduction
This feature is available only on hybrid ports.
The MAC-based VLAN feature assigns hosts to a VLAN based on their MAC addresses. This feature is also called user-based VLAN because VLAN configuration remains the same regardless of a user's physical location.
Static MAC-based VLAN assignment
Use static MAC-based VLAN assignment in networks that have a small number of VLAN users. To configure static MAC-based VLAN assignment on a port, perform the following tasks:
1.     Create MAC-to-VLAN entries.
2.     Enable the MAC-based VLAN feature on the port.
3.     Assign the port to the MAC-based VLAN.
A port configured with static MAC-based VLAN assignment processes a received frame as follows before sending the frame out:
·     For an untagged frame, the port determines its VLAN ID in the following workflow:
a.     The port first performs a fuzzy match as follows:
-     Searches for the MAC-to-VLAN entries whose masks are not all Fs.
-     Performs a logical AND operation on the source MAC address and each of these masks.
If an AND operation result matches the MAC address in a MAC-to-VLAN entry, the port tags the frame with the VLAN ID specific to this entry.
b.     If the fuzzy match fails, the port performs an exact match. It searches for MAC-to-VLAN entries whose masks are all Fs. If the source MAC address of the frame exactly matches the MAC address of a MAC-to-VLAN entry, the port tags the frame with the VLAN ID specific to this entry.
c.     If no matching VLAN ID is found, the port determines the VLAN for the packet by using the following VLAN match order:
-     IP subnet-based VLAN.
-     Protocol-based VLAN.
-     Port-based VLAN.
When a match is found, the port tags the packet with the matching VLAN ID.
·     For a tagged frame, the port determines whether the VLAN ID of the frame is permitted on the port.
¡     If the VLAN ID of the frame is permitted on the port, the port forwards the frame.
¡     If the VLAN ID of the frame is not permitted on the port, the port drops the frame.
Dynamic MAC-based VLAN assignment
When you cannot determine the target MAC-based VLANs of a port, use dynamic MAC-based VLAN assignment on the port. To use dynamic MAC-based VLAN assignment, perform the following tasks:
3.     Enable dynamic MAC-based VLAN assignment on the port.
Dynamic MAC-based VLAN assignment uses the following workflow, as shown in Figure 3:
1.     When a port receives a frame, it first determines whether the frame is tagged.
¡     If the frame is tagged, the port gets the source MAC address of the frame.
¡     If the frame is untagged, the port selects a VLAN for the frame by using the following matching order:
-     MAC-based VLAN (fuzzy and exact MAC address match).
-     Port-based VLAN.
After tagging the frame with the selected VLAN, the port gets the source MAC address of the frame.
2.     The port uses the source address and VLAN of the frame to match the MAC-to VLAN entries.
¡     If the source MAC address of the frame exactly matches the MAC address in a MAC-to-VLAN entry, the port checks whether the VLAN ID of the frame matches the VLAN in the entry.
-     If the two VLAN IDs match, the port joins the VLAN and forwards the frame.
-     If the two VLAN IDs do not match, the port drops the frame.
¡     If the source MAC address of the frame does not exactly match any MAC addresses in MAC-to-VLAN entries, the port checks whether the VLAN ID of the frame is its PVID.
-     If the VLAN ID of the frame is the PVID of the port, the port determines whether it allows the PVID.
If the PVID is allowed, the port forwards the frame within the PVID. If the PVID is not allowed, the port drops the frame.
-     If the VLAN ID of the frame is not the PVID of the port, the port determines whether the VLAN ID is the primary VLAN ID and the port PVID is a secondary VLAN ID.
If yes, the port forwards the frame. Otherwise, the port drops the frame.
Figure 3 Flowchart for processing a frame in dynamic MAC-based VLAN assignment
When you configure dynamic MAC-based VLAN assignment, follow these guidelines:
·     When a port joins a VLAN specified in the MAC-to-VLAN entry, one of the following events occurs depending on the port configuration:
¡     If the port has not been configured to allow packets from the VLAN to pass through, the port joins the VLAN as an untagged member.
¡     If the port has been configured to allow packets from the VLAN to pass through, the port configuration remains the same.
·     If you configure both static and dynamic MAC-based VLAN assignments on a port, dynamic MAC-based VLAN assignment takes effect.
·     The 802.1p priority of the VLAN in a MAC-to-VLAN entry determines the transmission priority of the matching packets.
Server-assigned MAC-based VLAN
Use this feature with access authentication, such as MAC-based 802.1X authentication, to implement secure and flexible terminal access.
To implement server-assigned MAC-based VLAN, perform the following tasks:
1.     Configure the server-assigned MAC-based VLAN feature on the access device.
2.     Configure username-to-VLAN entries on the access authentication server.
When a user passes authentication of the access authentication server, the server assigns the authorization VLAN information for the user to the device. The device then performs the following operations:
1.     Generates a MAC-to-VLAN entry by using the source MAC address of the user packet and the authorization VLAN information. The authorization VLAN is a MAC-based VLAN.
The generated MAC-to-VLAN entry cannot conflict with the existing static MAC-to-VLAN entries. If a confliction exists, the dynamic MAC-to-VLAN entry cannot be generated.
2.     Assigns the port that connects the user to the MAC-based VLAN.
When the user goes offline, the device automatically deletes the MAC-to-VLAN entry and removes the port from the MAC-based VLAN. For more information about 802.1X and MAC authentication, see Security Configuration Guide.
When you configure MAC-based VLANs, follow these restrictions and guideline:
·     Do not configure a VLAN as both a super VLAN and a MAC-based VLAN.
·     The MAC-based VLAN feature is mainly configured on downlink ports of user access devices. Do not use this feature with link aggregation.
Step
Remarks
N/A
2.     Create a MAC-to-VLAN entry.
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ dot1q priority ]
By default, no MAC-to-VLAN entries exist.
3.     Enter interface view.
interface
N/A
4.     Set the port link type to hybrid.
5.     Assign the hybrid port to the MAC-based VLANs.
By default, a hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
6.     Enable the MAC-based VLAN feature.
mac-vlan enable
7.     (Optional.) Configure the system to assign VLANs based on the MAC address preferentially.
vlan precedence mac-vlan
By default, the system assigns VLANs based on the MAC address preferentially when both the MAC-based VLAN and IP subnet-based VLAN are configured on a port.
When you configure dynamic MAC-based VLAN assignment, follow these restrictions and guideline:
·     As a best practice to ensure correct operation of 802.1X and MAC authentication, do not use dynamic MAC-based VLAN assignment with 802.1X or MAC authentication.
·     When dynamic MAC-based VLAN assignment is enabled on a port, the configuration of disabling of MAC address learning does not take effect.
·     For successful dynamic MAC-based VLAN assignment, use static VLANs when you create MAC-to-VLAN entries.
·     As a best practice, do not use dynamic MAC-based VLAN assignment with MSTP. In MSTP mode, if a port is blocked in the MSTI of its target VLAN, the port drops the received packets instead of delivering them to the CPU. As a result, the port will not be dynamically assigned to the target VLAN.
·     As a best practice, do not use dynamic MAC-based VLAN assignment with PVST. In PVST mode, if the target VLAN of a port is not permitted on the port, the port is placed in blocked state. The port drops the received packets instead of delivering them to the CPU. As a result, the port will not be dynamically assigned to the target VLAN.
·     As a best practice, do not configure both dynamic MAC-based VLAN assignment and automatic voice VLAN assignment mode on a port. They can have a negative impact on each other.
To configure dynamic MAC-based VLAN assignment:
Step
Remarks
N/A
mac-vlan mac-address mac-address vlan vlan-id [ dot1q priority ]
interface
N/A
5.     Enable the MAC-based VLAN feature.
mac-vlan enable
By default, MAC-based VLAN is disabled.
6.     Enable dynamic MAC-based VLAN assignment.
mac-vlan trigger enable
By default, dynamic MAC-based VLAN assignment is disabled.
The VLAN assignment for a port is triggered only when the source MAC address of its receiving packet exactly matches the MAC address in a MAC-to-VLAN entry.
8.     (Optional.) Disable the port from forwarding packets that fail the exact MAC address match in its PVID.
port pvid forbidden
By default, when a port receives packets whose source MAC addresses fail the exact match, the port forwards them in its PVID.
Step
Remarks
N/A
interface
N/A
4.     Assign the hybrid port to the MAC-based VLANs.
mac-vlan enable
6.     Configure 802.1X or MAC authentication.
For more information, see Security Command Reference.
N/A
In this method, untagged packets are assigned to VLANs based on their source IP addresses and subnet masks. A port configured with IP subnet-based VLANs assigns a received untagged packet to a VLAN based on the source address of the packet.
Use this feature when untagged packets from an IP subnet or IP address must be transmitted in a VLAN.
This feature is available only on hybrid ports, and it processes only untagged packets.
An IP subnet-based VLAN has one or multiple subnets to match inbound packets. Each subnet has a unique index in the IP subnet-based VLAN. All subnets in an IP subnet-based VLAN have the same VLAN ID.
To configure an IP subnet-based VLAN:
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Associate the VLAN with an IP subnet or IP address.
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
By default, a VLAN is not associated with an IP subnet or IP address.
A multicast subnet or a multicast address cannot be associated with a VLAN.
4.     Return to system view.
N/A
5.     Enter interface view.
N/A
6.     Set the port link type to hybrid.
7.     Assign the hybrid port to the specified IP subnet-based VLANs.
8.     Associate the hybrid port with the specified IP subnet-based VLAN.
port hybrid ip-subnet-vlan vlan vlan-id
By default, a hybrid port is not associated with a subnet-based VLAN.
The protocol-based VLAN feature assigns inbound packets to different VLANs based on their protocol types and encapsulation formats. The protocols available for VLAN assignment include IP, IPX, and AT. The encapsulation formats include Ethernet II, 802.3 raw, 802.2 LLC, and 802.2 SNAP.
This feature is available only on hybrid ports, and it processes only untagged packets. It associates the available network service types with VLANs and facilitates network management and maintenance.
A protocol-based VLAN has one or multiple protocol templates. A protocol template defines a protocol type and an encapsulation format as the match criteria to match inbound packets. Each protocol template has a unique index in the protocol-based VLAN. All protocol templates in a protocol-based VLAN have the same VLAN ID.
For a port to assign inbound packets to protocol-based VLANs, perform the following tasks:
·     Assign the port to the protocol-based VLANs.
·     Associate the port with the protocol templates of the protocol-based VLANs.
When an untagged packet arrives at the port, the port processes the packet as follows:
·     If the protocol type and encapsulation format in the packet match a protocol template, the port tags the packet with the VLAN tag specific to the protocol template.
·     If no protocol templates are matched, the port tags the packet with its PVID.
The voice VLAN in automatic mode processes only tagged voice traffic. Do not configure a VLAN as both a protocol-based VLAN and a voice VLAN.
To configure a protocol-based VLAN:
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Associate the VLAN with a protocol template.
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
By default, a VLAN is not associated with a protocol template.
4.     Exit VLAN view.
N/A
N/A
7.     Assign the hybrid port to the specified protocol-based VLANs.
8.     Associate the hybrid port with the specified protocol-based VLAN.
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
By default, a hybrid port is not associated with a protocol-based VLAN.
A VLAN group includes a set of VLANs.
On an authentication server, a VLAN group name represents a group of authorization VLANs. When an 802.1X user passes authentication, the authentication server assigns a VLAN group name to the device. The device then uses the received VLAN group name to match the locally configured VLAN group names. If a match is found, the device selects a VLAN from the group and assigns the VLAN to the user. For more information about 802.1X authentication, see Security Configuration Guide.
To configure a VLAN group:
Step
Remarks
N/A
2.     Create a VLAN group and enter its view.
vlan-group group-name
By default, no VLAN groups exist.
3.     Add VLANs to the VLAN group.
vlan-list vlan-id-list
By default, no VLANs exist in a VLAN group.
You can add multiple VLAN lists to a VLAN group.
Display VLAN interface information.
display interface vlan-interface [ interface-number ] [ brief [ description | down ] ]
Display information about IP subnet-based VLANs that are associated with the specified ports.
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
Display information about IP subnet-based VLANs.
display ip-subnet-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
Display information about protocol-based VLANs that are associated with the specified ports.
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
Display information about protocol-based VLANs.
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
Display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
Display brief VLAN information.
display vlan brief
Display VLAN group information.
display vlan-group [ group-name ]
Display hybrid ports or trunk ports on the device.
Clear statistics on a port.
reset counters interface vlan-interface [ interface-number ]
As shown in Figure 4:
·     Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
·     Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that only hosts in the same department can communicate with each other.
Figure 4 Network diagram
1.     Configure Device A:
# Create VLAN 100, and assign GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] port gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA] vlan 200
[DeviceA-vlan200] port gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure GigabitEthernet 1/0/3 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 100 200
Please wait... Done.
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
3.     Configure hosts:
a.     Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
b.     Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host A and Host C can ping each other, but they both fail to ping Host B and Host D. (Details not shown.)
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A and Host C. (Details not shown.)
# Verify that VLANs 100 and 200 are correctly configured on Device A.
[DeviceA-GigabitEthernet1/0/3] display vlan 100
 VLAN ID: 100
 VLAN type: Static
 Description: VLAN 0100
 Tagged ports:
 Untagged ports:
    GigabitEthernet1/0/1
[DeviceA-GigabitEthernet1/0/3] display vlan 200
 VLAN ID: 200
 VLAN type: Static
 Description: VLAN 0200
 Tagged ports:
 Untagged ports:
    GigabitEthernet1/0/2
As shown in Figure 5:
·     GigabitEthernet 1/0/1 of Device A and Device C are each connected to a meeting room. Laptop 1 and Laptop 2 are used for meetings and might be used in either of the two meeting rooms.
·     One department uses VLAN 100 and owns Laptop 1. The other department uses VLAN 200 and owns Laptop 2.
Configure MAC-based VLANs, so that Laptop 1 and Laptop 2 can access Server 1 and Server 2, respectively, no matter which meeting room they are used in.
Figure 5 Network diagram
# Create VLANs 100 and 200.
[DeviceA] vlan 100
[DeviceA] vlan 200
# Associate the MAC addresses of Laptop 1 and Laptop 2 with VLANs 100 and 200, respectively.
[DeviceA] mac-vlan mac-address 000d-88f8-4e71 vlan 100
[DeviceA] mac-vlan mac-address 0014-222c-aa69 vlan 200
# Configure GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLANs 100 and 200 as an untagged VLAN member.
[DeviceA-GigabitEthernet1/0/1] port link-type hybrid
[DeviceA-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# Enable the MAC-based VLAN feature on GigabitEthernet 1/0/1.
[DeviceA-GigabitEthernet1/0/1] mac-vlan enable
# Configure the uplink port (GigabitEthernet 1/0/2) as a trunk port, and assign it to VLANs 100 and 200.
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 100 200
2.     Configure Device B:
# Create VLAN 100, and assign GigabitEthernet 1/0/3 to VLAN 100.
[DeviceB] vlan 100
[DeviceB-vlan100] port gigabitethernet 1/0/3
[DeviceB-vlan100] quit
# Create VLAN 200 and assign GigabitEthernet 1/0/4 to VLAN 200.
[DeviceB] vlan 200
[DeviceB-vlan200] port gigabitethernet 1/0/4
[DeviceB-vlan200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 100 200
# Configure GigabitEthernet 1/0/2 as a trunk port, and assign the port to VLANs 100 and 200.
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 100 200
3.     Configure Device C in the same way as the Device A is configured. (Details not shown.)
# Verify that Laptop 1 can access only Server 1, and Laptop 2 can access only Server 2. (Details not shown.)
# Verify the MAC-to-VLAN entries on Device A and Device C, for example, on Device A.
[DeviceA] display mac-vlan all
  The following MAC VLAN addresses exist:
  S:Static  D:Dynamic
  MAC address      Mask             VLAN ID  Priority    State
  000d-88f8-4e71   ffff-ffff-ffff   100       0          S
  0014-222c-aa69   ffff-ffff-ffff   200       0          S
  Total MAC VLAN address count: 2
As shown in Figure 6, the hosts in the office belong to different IP subnets.
Configure Device C to transmit packets from 192.168.5.0/24 and 192.168.50.0/24 in VLANs 100 and 200, respectively.
Figure 6 Network diagram
1.     Configure Device C:
# Associate IP subnet 192.168.5.0/24 with VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
[DeviceC-vlan100] ip-subnet-vlan ip 192.168.5.0 255.255.255.0
[DeviceC-vlan100] quit
# Associate IP subnet 192.168.50.0/24 with VLAN 200.
[DeviceC] vlan 200
[DeviceC-vlan200] ip-subnet-vlan ip 192.168.50.0 255.255.255.0
[DeviceC-vlan200] quit
# Configure GigabitEthernet 1/0/2 as a hybrid port, and assign it to VLAN 100 as a tagged VLAN member.
[DeviceC-GigabitEthernet1/0/2] port link-type hybrid
[DeviceC-GigabitEthernet1/0/2] port hybrid vlan 100 tagged
# Configure GigabitEthernet 1/0/3 as a hybrid port, and assign it to VLAN 200 as a tagged VLAN member.
[DeviceC] interface gigabitethernet 1/0/3
[DeviceC-GigabitEthernet1/0/3] port link-type hybrid
[DeviceC-GigabitEthernet1/0/3] port hybrid vlan 200 tagged
[DeviceC-GigabitEthernet1/0/3] quit
[DeviceC-GigabitEthernet1/0/1] port link-type hybrid
[DeviceC-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# Associate GigabitEthernet 1/0/1 with the IP subnet-based VLANs 100 and 200.
[DeviceC-GigabitEthernet1/0/1] port hybrid ip-subnet-vlan vlan 100
[DeviceC-GigabitEthernet1/0/1] port hybrid ip-subnet-vlan vlan 200
2.     Configure Device A and Device B to forward packets from VLANs 100 and 200, respectively. (Details not shown.)
# Verify the IP subnet-based VLAN configuration on Device C.
[DeviceC] display ip-subnet-vlan vlan all
 VLAN ID: 100
  Subnet index      IP address      Subnet mask
  0                 192.168.5.0     255.255.255.0
 VLAN ID: 200
  0                 192.168.50.0    255.255.255.0
# Verify the IP subnet-based VLAN configuration on GigabitEthernet 1/0/1 of Device C.
[DeviceC] display ip-subnet-vlan interface gigabitethernet 1/0/1
  VLAN ID   Subnet index    IP address       Subnet mask       Status
  100       0               192.168.5.0      255.255.255.0     Active
  200       0               192.168.50.0     255.255.255.0     Active
As shown in Figure 7:
·     The majority of hosts in a lab environment run the IPv4 protocol.
·     The other hosts run the IPv6 protocol for teaching purposes.
To isolate IPv4 and IPv6 traffic at Layer 2, configure protocol-based VLANs to associate the IPv4 and ARP protocols with VLAN 100, and associate the IPv6 protocol with VLAN 200.
Figure 7 Network diagram
In this example, L2 Switch A and L2 Switch B use the factory configuration.
1.     Configure Device:
# Create VLAN 100, and configure the description for VLAN 100 as protocol VLAN for IPv4.
[Device] vlan 100
[Device-vlan100] description protocol VLAN for IPv4
# Assign GigabitEthernet 1/0/3 to VLAN 100.
[Device-vlan100] port gigabitethernet 1/0/3
[Device-vlan100] quit
# Create VLAN 200, and configure the description for VLAN 200 as protocol VLAN for IPv6.
[Device] vlan 200
[Device-vlan200] description protocol VLAN for IPv6
# Assign GigabitEthernet 1/0/4 to VLAN 200.
[Device-vlan200] port gigabitethernet 1/0/4
# Configure VLAN 200 as a protocol-based VLAN, and create an IPv6 protocol template with the index 1 for VLAN 200.
[Device-vlan200] protocol-vlan 1 ipv6
[Device-vlan200] quit
# Configure VLAN 100 as a protocol-based VLAN. Create an IPv4 protocol template with the index 1, and create an ARP protocol template with the index 2. (In Ethernet II encapsulation, the protocol type ID for ARP is 0806 in hexadecimal notation.)
[Device] vlan 100
[Device-vlan100] protocol-vlan 1 ipv4
[Device-vlan100] protocol-vlan 2 mode ethernetii etype 0806
[Device-GigabitEthernet1/0/1] port link-type hybrid
[Device-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# Associate GigabitEthernet 1/0/1 with the IPv4 and ARP protocol templates of VLAN 100 and the IPv6 protocol template of VLAN 200.
[Device-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 100 1 to 2
[Device-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 200 1
# Configure GigabitEthernet 1/0/2 as a hybrid port, and assign it to VLANs 100 and 200 as an untagged VLAN member.
[Device-GigabitEthernet1/0/2] port link-type hybrid
[Device-GigabitEthernet1/0/2] port hybrid vlan 100 200 untagged
# Associate GigabitEthernet 1/0/2 with the IPv4 and ARP protocol templates of VLAN 100 and the IPv6 protocol template of VLAN 200.
[Device-GigabitEthernet1/0/2] port hybrid protocol-vlan vlan 100 1 to 2
[Device-GigabitEthernet1/0/2] port hybrid protocol-vlan vlan 200 1
2.     Configure hosts and servers:
a.     Configure IPv4 Host A, IPv4 Host B, and IPv4 server to be on the same network segment (192.168.100.0/24, for example). (Details not shown.)
b.     Configure IPv6 Host A, IPv6 Host B, and IPv6 server to be on the same network segment (2001::1/64, for example). (Details not shown.)
1.     Verify the following:
¡     The hosts and the server in VLAN 100 can successfully ping one another. (Details not shown.)
¡     The hosts and the server in VLAN 200 can successfully ping one another. (Details not shown.)
¡     The hosts or the server in VLAN 100 cannot ping the hosts or server in VLAN 200. (Details not shown.)
2.     Verify the protocol-based VLAN configuration:
# Display protocol-based VLANs on Device.
[Device] display protocol-vlan vlan all
 VLAN ID: 100
  Protocol index  Protocol type
  1               IPv4
  2               Ethernet II Etype 0x0806
 VLAN ID: 200
  1               IPv6
# Display protocol-based VLANs on the ports of Device.
[Device] display protocol-vlan interface all
  VLAN ID  Protocol index  Protocol type             Status
  100      1               IPv4                      Active
  100      2               Ethernet II Etype 0x0806  Active
  200      1               IPv6                      Active
 Interface: GigabitEthernet 1/0/2
  100      1               IPv4                      Active
  200      1               IPv6                      Active
The super VLAN feature cannot be used together with the VXLAN IP gateway feature. For more information about VXLAN IP gateways, see VXLAN Configuration Guide.
Overview
Hosts in a VLAN typically use IP addresses in the same subnet. For Layer 3 interoperability with other VLANs, you can create a VLAN interface for the VLAN and assign an IP address to it. This requires a large number of IP addresses.
The super VLAN feature was introduced to save IP addresses. A super VLAN is associated with multiple sub-VLANs. These sub-VLANs use the VLAN interface of the super VLAN (also known as a super VLAN interface) as the gateway for Layer 3 communication.
You can create a VLAN interface for a super VLAN and assign an IP address to it. However, you cannot create a VLAN interface for a sub-VLAN. You can assign a physical port to a sub-VLAN, but you cannot assign a physical port to a super VLAN. Sub-VLANs are isolated at Layer 2.
To enable Layer 3 communication between sub-VLANs, perform the following tasks:
1.     Create a super VLAN and the VLAN interface for the super VLAN.
2.     Enable local proxy ARP or ND on the super VLAN interface as follows:
¡     In an IPv4 network, enable local proxy ARP on the super VLAN interface. The super VLAN can then process ARP requests and replies sent from the sub-VLANs.
¡     In an IPv6 network, enable local proxy ND on the super VLAN interface. The super VLAN can then process the NS and NA messages sent from the sub-VLANs.
Tasks at a glance
(Required.) Creating a sub-VLAN
(Required.) Configuring a super VLAN
(Required.) Configuring a super VLAN interface
Creating a sub-VLAN
Step
Remarks
N/A
2.     Create a sub-VLAN.
vlan vlan-id
When you configure a super VLAN, follow these restrictions and guidelines:
·     Do not configure the VLAN of a MAC address-to-VLAN entry as a super VLAN.
·     Do not configure a VLAN as both a super VLAN and a guest VLAN, Auth-Fail VLAN, or critical VLAN. For more information about guest VLANs, Auth-Fail VLANs, and critical VLANs, see Security Configuration Guide.
·     Do not configure a VLAN as both a super VLAN and a sub-VLAN.
·     Layer 2 multicast configuration for super VLANs does not take effect because they do not have physical ports.
To configure a super VLAN:
Step
Remarks
N/A
2.     Enter VLAN view.
vlan vlan-id
N/A
3.     Configure the VLAN as a super VLAN.
supervlan
By default, a VLAN is not a super VLAN.
4.     Associate the super VLAN with the sub-VLANs.
subvlan vlan-id-list
By default, a super VLAN is not associated with any sub-VLANs.
Make sure the sub-VLANs already exist before associating them with a super VLAN.
As a best practice, do not configure VRRP for a super VLAN interface because the configuration affects network performance. For more information about VRRP, see High Availability Configuration Guide.
To configure a VLAN interface for a super VLAN:
Step
Remarks
N/A
The value for the interface-number argument must be the super VLAN ID.
3.     Configure an IP address for the super VLAN interface.
·     Configure an IPv4 address:
·     Configure an IPv6 address:
By default, no IP address is configured for a VLAN interface.
4.     Configure Layer 3 communication between sub-VLANs.
·     Enable local proxy ARP for devices that run IPv4 protocols:
local-proxy-arp enable
·     Enable local proxy ND for devices that run IPv6 protocols:
local-proxy-nd enable
By default:
·     Sub-VLANs cannot communicate with each other at Layer 3.
·     Local proxy ARP or ND is disabled.
For more information about local proxy ARP and ND, see Layer 3—IP Services Configuration Guide. For more information about local-proxy-arp enable and local-proxy-nd enable commands, see Layer 3—IP Services Command Reference.
Display information about super VLANs and their associated sub-VLANs.
display supervlan [ supervlan-id ]
As shown in Figure 8:
·     GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are in VLAN 2.
·     GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 are in VLAN 3.
·     GigabitEthernet 1/0/5 and GigabitEthernet 1/0/6 are in VLAN 5.
To save IP addresses and enable sub-VLANs to be isolated at Layer 2 but interoperable at Layer 3, perform the following tasks:
·     Create a super VLAN and assign an IP address to its VLAN interface.
·     Associate the super VLAN with VLANs 2, 3, and 5.
Figure 8 Network diagram
# Create VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] quit
# Create VLAN-interface 10, and assign IP address 10.1.1.1/24 to it.
[DeviceA-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
# Enable local proxy ARP.
[DeviceA-Vlan-interface10] local-proxy-arp enable
# Create VLAN 2, and assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the VLAN.
[DeviceA] vlan 2
[DeviceA-vlan2] port gigabitethernet 1/0/1 gigabitethernet 1/0/2
[DeviceA-vlan2] quit
# Create VLAN 3, and assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to the VLAN.
[DeviceA] vlan 3
[DeviceA-vlan3] port gigabitethernet 1/0/3 gigabitethernet 1/0/4
[DeviceA-vlan3] quit
# Create VLAN 5, and assign GigabitEthernet 1/0/5 and GigabitEthernet 1/0/6 to the VLAN.
[DeviceA] vlan 5
[DeviceA-vlan5] port gigabitethernet 1/0/5 gigabitethernet 1/0/6
[DeviceA-vlan5] quit
# Configure VLAN 10 as a super VLAN, and associate sub-VLANs 2, 3, and 5 with the super VLAN.
[DeviceA] vlan 10
[DeviceA-vlan10] supervlan
[DeviceA-vlan10] subvlan 2 3 5
[DeviceA] quit
# Display information about super VLAN 10 and its associated sub-VLANs.
<DeviceA> display supervlan
 Super VLAN ID: 10
 Sub-VLAN ID: 2-3 5
 VLAN ID: 10
 VLAN type: Static
 It is a super VLAN.
 Route interface: Configured
 Ipv4 address: 10.1.1.1
 Ipv4 subnet mask: 255.255.255.0
 Description: VLAN 0010
 Tagged ports:   None
 Untagged ports: None
 VLAN ID: 2
 VLAN type: Static
 It is a sub VLAN.
 Description: VLAN 0002
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 It is a sub VLAN.
 Description: VLAN 0003
 Tagged ports:   None
 Untagged ports:
    GigabitEthernet1/0/4
 VLAN ID: 5
 VLAN type: Static
 It is a sub VLAN.
 Description: VLAN 0005
 Tagged ports:   None
 Untagged ports:
    GigabitEthernet1/0/5
    GigabitEthernet1/0/6
VLAN technology provides a method for isolating traffic from customers. At the access layer of a network, customer traffic must be isolated for security or accounting purposes. If VLANs are assigned on a per-user basis, a large number of VLANs will be required.
The private VLAN feature saves VLAN resources. It uses a two-tier VLAN structure as follows:
·     Primary VLAN—Used for connecting the upstream device. A primary VLAN can be associated with multiple secondary VLANs. The upstream device identifies only the primary VLAN.
·     Secondary VLANs—Used for connecting users. Secondary VLANs are isolated at Layer 2. To implement Layer 3 communication between secondary VLANs associated with the primary VLAN, enable local proxy ARP or ND on the upstream device (for example, L3 Device A in Figure 9).
As shown in Figure 9, the private VLAN feature is enabled on L2 Device B. VLAN 10 is the primary VLAN. VLANs 2, 5, and 8 are secondary VLANs that are associated with VLAN 10. L3 Device A is only aware of VLAN 10.
Figure 9 Private VLAN example
If the private VLAN feature is configured on a Layer 3 device, use one of the following methods on the Layer 3 device to enable Layer 3 communication. Layer 3 communication might be required between secondary VLANs that are associated with the same primary VLAN, or between secondary VLANs and other networks.
·     Method 1:
a.     Create VLAN interfaces for the secondary VLANs.
b.     Assign IP addresses to the secondary VLAN interfaces.
·     Method 2:
a.     Enable Layer 3 communication between the secondary VLANs that are associated with the primary VLAN.
b.     Create the VLAN interface for the primary VLAN and assign an IP address to it. (Do not create secondary VLAN interfaces if you use this method.)
c.     Enable local proxy ARP or ND on the primary VLAN interface.
To configure the private VLAN feature, perform the following tasks:
1.     Configure the primary VLAN.
2.     Configure the secondary VLANs.
3.     Associate the secondary VLANs with the primary VLAN.
4.     Configure the uplink and downlink ports:
¡     Configure the uplink port (for example, the port connecting L2 Device B to L3 Device A in Figure 9):
-     When the port allows only one primary VLAN, configure the port as a promiscuous port of the primary VLAN. The promiscuous port can be automatically assigned to the primary VLAN and its associated secondary VLANs.
-     When the port allows multiple primary VLANs, configure the port as a trunk promiscuous port of the primary VLANs. The trunk promiscuous port can be automatically assigned to the primary VLANs and their associated secondary VLANs.
¡     Configure a downlink port (for example, the port connecting L2 Device B to a host in Figure 9) as a host port. The host port can be automatically assigned to the secondary VLAN and its associated primary VLAN.
¡     If a downlink port allows multiple secondary VLANs, configure the port as a trunk secondary port. The trunk secondary port can be automatically assigned to the secondary VLANs and their associated primary VLANs.
For more information about promiscuous, trunk promiscuous, host, and trunk secondary ports, see Layer 2—LAN Switching Command Reference.
5.     Configure Layer 3 communication between the specified secondary VLANs that are associated with the primary VLAN.
When you configure the private VLAN feature, follow these restrictions and guidelines:
·     Make sure the following requirements are met:
¡     For a promiscuous port:
-     The primary VLAN is the PVID of the port.
-     The port is an untagged member of the primary VLAN and secondary VLANs.
¡     For a host port:
-     The PVID of the port is a secondary VLAN.
-     The port is an untagged member of the primary VLAN and the secondary VLAN.
¡     A trunk promiscuous or trunk secondary port must be a tagged member of the primary VLANs and the secondary VLANs.
·     After you configure a primary VLAN, the system automatically synchronizes the dynamic MAC address entries of the primary VLAN with the dynamic MAC address entries of the secondary VLANs.
·     VLAN 1 (system default VLAN) does not support the private VLAN configuration.
·     The private VLAN feature cannot be used with IP multicast.
·     The private VLAN feature cannot be used together with the VXLAN IP gateway feature. For more information about VXLAN IP gateways, see VXLAN Configuration Guide.
To configure the private VLAN feature:
Step
Remarks
N/A
2.     Create a VLAN and enter VLAN view.
vlan vlan-id
N/A
3.     Configure the VLAN as a primary VLAN.
private-vlan primary
By default, a VLAN is not a primary VLAN.
N/A
5.     Create one or multiple secondary VLANs.
N/A
6.     Return to system view.
N/A
7.     Enter VLAN view of the primary VLAN.
vlan vlan-id
N/A
8.     Associate the primary VLAN with the secondary VLANs.
private-vlan secondary vlan-id-list
By default, a primary VLAN is not associated with any secondary VLANs.
9.     Return to system view.
N/A
10.     Enter interface view of the uplink port.
N/A
11.     Configure the uplink port as a promiscuous or trunk promiscuous port of the specified VLANs.
·     Configure the uplink port as a promiscuous port of the specified VLAN:
port private-vlan vlan-id promiscuous
·     Configure the uplink port as a trunk promiscuous port of the specified VLANs:
port private-vlan vlan-id-list trunk promiscuous
By default, a port is not a promiscuous or trunk promiscuous port of any VLANs.
12.     Return to system view.
N/A
13.     Enter interface view of the downlink port.
N/A
14.     Assign the downlink port to secondary VLANs.
a     Set the link type of the port:
b     Assign the access port to the specified VLAN:
c     Assign the trunk port to the specified VLANs:
d     Assign the hybrid port to the specified VLANs:
Select substep b, c, or d depending on the port link type.
15.     Configure the downlink port as a host or trunk secondary port.
·     Configure the downlink port as a host port:
port private-vlan host
·     Configure the downlink port as a trunk secondary port of the specified VLANs:
port private-vlan vlan-id-list trunk secondary
By default, a port is not a host or trunk secondary port.
16.     Return to system view.
N/A
17.     Enter VLAN view of a secondary VLAN.
vlan vlan-id
N/A
18.     (Optional.) Enable Layer 2 communication for ports in the same secondary VLAN.
·     undo private-vlan isolated
·     private-vlan community
By default, ports in the same secondary VLAN can communicate with each other at Layer 2.
19.     Return to system view.
N/A
20.     (Optional.) Configure Layer 3 communication between the specified secondary VLANs.
a     Enter VLAN interface view of the primary VLAN interface:
b     Enable Layer 3 communication between secondary VLANs that are associated with the primary VLAN:
c     Assign an IPv4 address to the primary VLAN interface:
d     Assign an IPv6 address to the primary VLAN interface:
e     Enable local proxy ARP:
f     Enable local proxy ND:
Use substeps a, b, c, and e for devices that run IPv4 protocols.
Use substeps a, b, d, and f for devices that run IPv6 protocols.
By default:
·     Secondary VLANs cannot communicate with each other at Layer 3.
·     No IP address is configured for a VLAN interface.
·     Local proxy ARP and ND are disabled.
For more information about local proxy ARP and ND, see Layer 3—IP Services Configuration Guide. For more information about the local-proxy-arp enable and local-proxy-nd enable commands, see Layer 3—IP Services Command Reference.
Display information about primary VLANs and the secondary VLANs associated with each primary VLAN.
display private-vlan [ primary-vlan-id ]
As shown in Figure 10, configure the private VLAN feature to meet the following requirements:
·     On Device B, VLAN 5 is a primary VLAN that is associated with secondary VLANs 2 and 3. GigabitEthernet 1/0/5 is in VLAN 5. GigabitEthernet 1/0/2 is in VLAN 2. GigabitEthernet 1/0/3 is in VLAN 3.
·     On Device C, VLAN 6 is a primary VLAN that is associated with secondary VLANs 3 and 4. GigabitEthernet 1/0/5 is in VLAN 6. GigabitEthernet 1/0/3 is in VLAN 3. GigabitEthernet 1/0/4 is in VLAN 4.
·     Device A is aware of only VLAN 5 on Device B and VLAN 6 on Device C.
Figure 10 Network diagram
This example describes the configurations on Device B and Device C.
1.     Configure Device B:
# Configure VLAN 5 as a primary VLAN.
[DeviceB] vlan 5
[DeviceB-vlan5] private-vlan primary
[DeviceB-vlan5] quit
# Create VLANs 2 and 3.
[DeviceB] vlan 2 to 3
# Associate secondary VLANs 2 and 3 with primary VLAN 5.
[DeviceB] vlan 5
[DeviceB-vlan5] private-vlan secondary 2 to 3
# Configure the uplink port (GigabitEthernet 1/0/5) as a promiscuous port of VLAN 5.
[DeviceB] interface gigabitethernet 1/0/5
[DeviceB-GigabitEthernet1/0/5] port private-vlan 5 promiscuous
[DeviceB-GigabitEthernet1/0/5] quit
# Assign downlink port GigabitEthernet 1/0/2 to VLAN 2, and configure the port as a host port.
[DeviceB-GigabitEthernet1/0/2] port access vlan 2
[DeviceB-GigabitEthernet1/0/2] port private-vlan host
# Assign downlink port GigabitEthernet 1/0/3 to VLAN 3, and configure the port as a host port.
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] port access vlan 3
[DeviceB-GigabitEthernet1/0/3] port private-vlan host
2.     Configure Device C:
# Configure VLAN 6 as a primary VLAN.
[DeviceC] vlan 6
[DeviceC–vlan6] private-vlan primary
[DeviceC–vlan6] quit
# Create VLANs 3 and 4.
[DeviceC] vlan 3 to 4
# Associate secondary VLANs 3 and 4 with primary VLAN 6.
[DeviceC] vlan 6
[DeviceC-vlan6] private-vlan secondary 3 to 4
[DeviceC-vlan6] quit
# Configure the uplink port (GigabitEthernet 1/0/5) as a promiscuous port of VLAN 6.
[DeviceC] interface gigabitethernet 1/0/5
[DeviceC-GigabitEthernet1/0/5] port private-vlan 6 promiscuous
[DeviceC-GigabitEthernet1/0/5] quit
[DeviceC-GigabitEthernet1/0/3] port access vlan 3
[DeviceC-GigabitEthernet1/0/3] port private-vlan host
# Assign downlink port GigabitEthernet 1/0/4 to VLAN 4, and configure the port as a host port.
[DeviceC] interface gigabitethernet 1/0/4
[DeviceC-GigabitEthernet1/0/4] port access vlan 4
[DeviceC-GigabitEthernet1/0/4] port private-vlan host
[DeviceC-GigabitEthernet1/0/4] quit
# Verify the private VLAN configurations on the devices, for example, on Device B.
[DeviceB] display private-vlan
 Primary VLAN ID: 5
 Secondary VLAN ID: 2-3
 VLAN ID: 5
 VLAN type: Static
 Private VLAN type: Primary
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 2
 VLAN type: Static
 Private VLAN type: Secondary
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Tagged Ports:   None
 Untagged Ports:
The output shows that:
·     The promiscuous port (GigabitEthernet 1/0/5) is an untagged member of primary VLAN 5 and secondary VLANs 2 and 3.
·     Host port GigabitEthernet 1/0/2 is an untagged member of primary VLAN 5 and secondary VLAN 2.
·     Host port GigabitEthernet 1/0/3 is an untagged member of primary VLAN 5 and secondary VLAN 3.
As shown in Figure 11, configure the private VLAN feature to meet the following requirements:
·     VLANs 5 and 10 are primary VLANs on Device B. The uplink port (GigabitEthernet 1/0/1) on Device B permits the packets from VLANs 5 and 10 to pass through tagged.
·     On Device B, downlink port GigabitEthernet 1/0/2 permits secondary VLAN 2. Downlink port GigabitEthernet 1/0/3 permits secondary VLAN 3. Secondary VLANs 2 and 3 are associated with primary VLAN 5.
·     On Device B, downlink port GigabitEthernet 1/0/4 permits secondary VLAN 6. Downlink port GigabitEthernet 1/0/5 permits secondary VLAN 8. Secondary VLANs 6 and 8 are associated with primary VLAN 10.
·     Device A is aware of only VLANs 5 and 10 on Device B.
Figure 11 Network diagram
# Configure VLANs 5 and 10 as primary VLANs.
[DeviceB] vlan 5
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan primary
[DeviceB-vlan10] quit
# Create VLANs 2, 3, 6, and 8.
[DeviceB] vlan 6
[DeviceB-vlan6] quit
[DeviceB] vlan 8
[DeviceB-vlan8] quit
[DeviceB] vlan 5
# Associate secondary VLANs 6 and 8 with primary VLAN 10.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan secondary 6 8
# Configure the uplink port (GigabitEthernet 1/0/1) as a trunk promiscuous port of VLANs 5 and 10.
[DeviceB-GigabitEthernet1/0/1] port private-vlan 5 10 trunk promiscuous
# Assign downlink port GigabitEthernet 1/0/4 to VLAN 6, and configure the port as a host port.
[DeviceB] interface gigabitethernet 1/0/4
[DeviceB-GigabitEthernet1/0/4] port access vlan 6
[DeviceB-GigabitEthernet1/0/4] port private-vlan host
[DeviceB-GigabitEthernet1/0/4] quit
# Assign downlink port GigabitEthernet 1/0/5 to VLAN 8, and configure the port as a host port.
[DeviceB-GigabitEthernet1/0/5] port access vlan 8
[DeviceB-GigabitEthernet1/0/5] port private-vlan host
2.     Configure Device A:
# Create VLANs 5 and 10.
[DeviceA] vlan 5
[DeviceA] vlan 10
# Configure GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLANs 5 and 10 as a tagged VLAN member.
[DeviceA-GigabitEthernet1/0/1] port hybrid vlan 5 10 tagged
# Verify the primary VLAN configurations on Device B. The following output uses primary VLAN 5 as an example.
[DeviceB] display private-vlan 5
 Primary VLAN ID: 5
 VLAN ID: 5
 VLAN type: Static
 Tagged ports:
 Untagged ports:
 VLAN ID: 2
 VLAN type: Static
 Tagged ports:
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Tagged ports:
 Untagged ports:
·     The trunk promiscuous port (GigabitEthernet 1/0/1) is a tagged member of primary VLAN 5 and secondary VLANs 2 and 3.
As shown in Figure 12, configure the private VLAN feature to meet the following requirements:
·     VLANs 10 and 20 are primary VLANs on Device A. The uplink port (GigabitEthernet 1/0/5) on Device A permits the packets from VLANs 10 and 20 to pass through tagged.
·     VLANs 11, 12, 21, and 22 are secondary VLANs on Device A.
¡     Downlink port GigabitEthernet 1/0/2 permits the packets from secondary VLANs 11 and 21 to pass through tagged.
¡     Downlink port GigabitEthernet 1/0/1 permits secondary VLAN 22.
¡     Downlink port GigabitEthernet 1/0/3 permits secondary VLAN 12.
·     Secondary VLANs 11 and 12 are associated with primary VLAN 10.
·     Secondary VLANs 21 and 22 are associated with primary VLAN 20.
Figure 12 Network diagram
# Configure VLANs 10 and 20 as primary VLANs.
[DeviceA] vlan 10
[DeviceA-vlan10] private-vlan primary
[DeviceA] vlan 20
[DeviceA-vlan20] private-vlan primary
[DeviceA-vlan20] quit
# Create VLANs 11, 12, 21, and 22.
[DeviceA] vlan 11 to 12
[DeviceA] vlan 21 to 22
# Associate secondary VLANs 11 and 12 with primary VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] private-vlan secondary 11 12
# Associate secondary VLANs 21 and 22 with primary VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] private-vlan secondary 21 22
# Configure the uplink port (GigabitEthernet 1/0/5) as a trunk promiscuous port of VLANs 10 and 20.
[DeviceA] interface gigabitethernet 1/0/5
[DeviceA-GigabitEthernet1/0/5] port private-vlan 10 20 trunk promiscuous
[DeviceA-GigabitEthernet1/0/5] quit
# Assign downlink port GigabitEthernet 1/0/1 to VLAN 22 and configure the port as a host port.
[DeviceA-GigabitEthernet1/0/1] port access vlan 22
[DeviceA-GigabitEthernet1/0/1] port private-vlan host
# Assign downlink port GigabitEthernet 1/0/3 to VLAN 12 and configure the port as a host port.
[DeviceA-GigabitEthernet1/0/3] port access vlan 12
[DeviceA-GigabitEthernet1/0/3] port private-vlan host
# Configure downlink port GigabitEthernet 1/0/2 as a trunk secondary port of VLANs 11 and 21.
[DeviceA-GigabitEthernet1/0/2] port private-vlan 11 21 trunk secondary
# Create VLANs 11 and 21.
[DeviceB] vlan 11
[DeviceB-vlan11] quit
[DeviceB] vlan 21
[DeviceB-vlan21] quit
# Configure GigabitEthernet 1/0/2 as a hybrid port, and assign it to VLANs 11 and 21 as a tagged VLAN member.
[DeviceB-GigabitEthernet1/0/2] port link-type hybrid
[DeviceB-GigabitEthernet1/0/2] port hybrid vlan 11 21 tagged
# Assign GigabitEthernet 1/0/3 to VLAN 11.
[DeviceB-GigabitEthernet1/0/3] port access vlan 11
# Assign GigabitEthernet 1/0/4 to VLAN 21.
[DeviceB-GigabitEthernet1/0/4] port access vlan 21
3.     Configure Device C:
# Create VLANs 10 and 20.
[DeviceC] vlan 10
[DeviceC-vlan10] quit
[DeviceC] vlan 20
[DeviceC-vlan20] quit
# Configure GigabitEthernet 1/0/5 as a hybrid port, and assign it to VLANs 10 and 20 as a tagged VLAN member.
[DeviceC-GigabitEthernet1/0/5] port link-type hybrid
[DeviceC-GigabitEthernet1/0/5] port hybrid vlan 10 20 tagged
# Verify the primary VLAN configurations on Device A. The following output uses primary VLAN 10 as an example.
[DeviceA] display private-vlan 10
 Primary VLAN ID: 10
 Secondary VLAN ID: 11-12
 VLAN ID: 10
 VLAN type: Static
 Private-vlan type: Primary
 Tagged ports:
 Untagged ports:
 VLAN ID: 11
 VLAN type: Static
 Private-vlan type: Secondary
 Description: VLAN 0011
 Tagged ports:
 VLAN ID: 12
 VLAN type: Static
 Description: VLAN 0012
 Tagged ports:
 Untagged ports:
·     The trunk promiscuous port (GigabitEthernet 1/0/5) is a tagged member of primary VLAN 10 and secondary VLANs 11 and 12.
·     The trunk secondary port (GigabitEthernet 1/0/2) is a tagged member of primary VLAN 10 and secondary VLAN 11.
·     The host port (GigabitEthernet 1/0/3) is an untagged member of primary VLAN 10 and secondary VLAN 12.
Secondary VLAN Layer 3 communication configuration example
Network requirements
As shown in Figure 13, configure the private VLAN feature to meet the following requirements:
·     Primary VLAN 10 on Device A is associated with secondary VLANs 2 and 3. The IP address of VLAN-interface 10 is 192.168.1.1/24.
·     GigabitEthernet 1/0/1 belongs to VLAN 10. GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 belong to VLAN 2 and VLAN 3, respectively.
·     Secondary VLANs are isolated at Layer 2 but interoperable at Layer 3.
Figure 13 Network diagram
Configuration procedure
# Create VLAN 10 and configure it as a primary VLAN.
[DeviceA] vlan 10
[DeviceA] vlan 2 to 3
# Associate primary VLAN 10 with secondary VLANs 2 and 3.
[DeviceA] vlan 10
[DeviceA-vlan10] private-vlan secondary 2 3
# Configure the uplink port (GigabitEthernet 1/0/1) as a promiscuous port of VLAN 10.
[DeviceA-GigabitEthernet1/0/1] port private-vlan 10 promiscuous
[DeviceA-GigabitEthernet1/0/2] port access vlan 2
[DeviceA-GigabitEthernet1/0/2] port private-vlan host
[DeviceA-GigabitEthernet1/0/3] port access vlan 3
# Enable Layer 3 communication between secondary VLANs 2 and 3 that are associated with primary VLAN 10.
[DeviceA-Vlan-interface10] private-vlan secondary 2 3
# Assign IP address 192.168.1.1/24 to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 192.168.1.1 255.255.255.0
# Enable local proxy ARP on VLAN-interface 10.
# Display the configuration of primary VLAN 10.
 Primary VLAN ID: 10
 VLAN ID: 10
 VLAN type: Static
 IPv4 address: 192.168.1.1
 IPv4 subnet mask: 255.255.255.0
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 2
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
The Route interface field in the output is Configured, indicating that secondary VLANs 2 and 3 are interoperable at Layer 3.
Configuring voice VLANs
Overview
A voice VLAN is used for transmitting voice traffic. The device can configure QoS parameters for voice packets to ensure higher transmission priority of the voice packets.
Common voice devices include IP phones and integrated access devices (IADs). This chapter uses IP phones as an example.
For an IP phone to access a device, the device must perform the following operations:
1.     Identify the IP phone in the network and obtain the MAC address of the IP phone.
2.     Advertise the voice VLAN information to the IP phone.
After receiving the voice VLAN information, the IP phone performs automatic configuration. Voice packets sent from the IP phone can then be transmitted within the voice VLAN.
Methods of identifying IP phones
Devices can use the OUI addresses or LLDP to identify IP phones.
Identifying IP phones through OUI addresses
A device identifies voice packets based on their source MAC addresses. A packet whose source MAC address complies with an Organizationally Unique Identifier (OUI) address of the device is regarded as a voice packet.
You can use system default OUI addresses (see Table 1) or configure OUI addresses for the device. You can manually remove or add the system default OUI addresses.
Table 1 Default OUI addresses
Number
OUI address
Vendor
1
0001-e300-0000
Siemens phone
2
0003-6b00-0000
Cisco phone
3
0004-0d00-0000
Avaya phone
4
000f-e200-0000
H3C Aolynk phone
5
0060-b900-0000
Philips/NEC phone
6
00d0-1e00-0000
Pingtel phone
7
00e0-7500-0000
Polycom phone
8
00e0-bb00-0000
3Com phone
Typically, an OUI address refers to the first 24 bits of a MAC address (in binary notation) and is a globally unique identifier that IEEE assigns to a vendor. However, OUI addresses in this chapter are addresses that the system uses to identify voice packets. They are the logical AND results of the mac-address and oui-mask arguments in the voice-vlan mac-address command.
Automatically identifying IP phones through LLDP
If IP phones support LLDP, configure LLDP for automatic IP phone discovery on the device. The device can then automatically discover the peer through LLDP, and exchange LLDP TLVs with the peer.
If the LLDP System Capabilities TLV received on a port indicates that the peer can act as a telephone, the device performs the following operations:
1.     Sends an LLDP TLV with the voice VLAN configuration to the peer.
2.     Assigns the receiving port to the voice VLAN.
3.     Increases the transmission priority of the voice packets sent from the IP phone.
4.     Adds the MAC address of the IP phone to the MAC address table to ensure that the IP phone can pass authentication.
Use LLDP instead of the OUI list to identify IP phones if the network has more IP phone categories than the maximum number of OUI addresses supported on the device. LLDP has higher priority than the OUI list.
For more information about LLDP, see "Configuring LLDP."
Advertising the voice VLAN information to IP phones
Figure 14 shows the workflow of advertising the voice VLAN information to IP phones.
Figure 14 Workflow of advertising the voice VLAN information to IP phones
IP phone access methods
Connecting the host and the IP phone in series
As shown in Figure 15, the host is connected to the IP phone, and the IP phone is connected to the device. In this scenario, the following requirements must be met:
·     The host and the IP phone use different VLANs.
·     The IP phone is able to send out VLAN-tagged packets, so that the device can differentiate traffic from the host and the IP phone.
·     The port connecting to the IP phone forwards packets from the voice VLAN and the PVID.
Figure 15 Connecting the host and IP phone in series
Connecting the IP phone to the device
As shown in Figure 16, IP phones are connected to the device without the presence of the host. Use this connection method when IP phones sends out untagged voice packets. In this scenario, you must configure the voice VLAN as the PVID of the access port of the IP phone, and configure the port to forward the packets from the PVID.
Figure 16 Connecting the IP phone to the device
Voice VLAN assignment modes
A port can be assigned to a voice VLAN automatically or manually.
Automatic mode
Use automatic mode when PCs and IP phones are connected in series to access the network through the device, as shown in Figure 15. Ports on the device transmit both voice traffic and data traffic.
When an IP phone is powered on, it sends out protocol packets. After receiving these protocol packets, the device uses the source MAC address of the protocol packets to match its OUI addresses. If the match succeeds, the device performs the following operations:
·     Assigns the receiving port of the protocol packets to the voice VLAN.
·     Issues ACL rules to set the packet precedence.
·     Starts the voice VLAN aging timer.
If no voice packet is received from the port before the aging timer expires, the device will remove the port from the voice VLAN. The aging timer is also configurable.
When the IP phone reboots, the port is reassigned to the voice VLAN to ensure the correct operation of the existing voice connections. The reassignment occurs automatically without being triggered by voice traffic as long as the voice VLAN operates correctly.
Manual mode
Use manual mode when only IP phones access the network through the device, as shown in Figure 16. In this mode, ports are assigned to a voice VLAN that transmits voice traffic exclusively. No data traffic affects the voice traffic transmission.
You must manually assign the port that connects to the IP phone to a voice VLAN. The device uses the source MAC address of the received voice packets to match its OUI addresses. If the match succeeds, the device issues ACL rules to set the packet precedence.
To remove the port from the voice VLAN, you must manually remove it.
Cooperation of voice VLAN assignment modes and IP phones
Some IP phones send out VLAN-tagged packets, and others send out only untagged packets. For correct packet processing, ports of different link types must meet specific configuration requirements in different voice VLAN assignment modes.
Access ports do not transmit tagged packets.
Table 2 Configuration requirements for trunk and hybrid ports to support tagged voice traffic
Port link type
Trunk
Automatic
The PVID of the port cannot be the voice VLAN.
Manual
The port must forward packets from the voice VLAN.
Hybrid
Automatic
Manual
The port must forward packets from the voice VLAN with VLAN tags.
When IP phones send out untagged packets, you must set the voice VLAN assignment mode to manual.
Table 3 Configuration requirements for ports in manual mode to support untagged voice traffic
Port link type
Access
The voice VLAN must be the PVID of the port.
Trunk
Hybrid
The port must forward packets from the voice VLAN without VLAN tags.
If an IP phone sends out tagged voice traffic, and its access port is configured with 802.1X authentication, guest VLAN, Auth-Fail VLAN, or critical VLAN, VLAN IDs must be different for the following VLANs:
·     Voice VLAN.
·     PVID of the access port.
·     802.1X guest, Auth-Fail, or critical VLAN.
If an IP phone sends out untagged voice traffic, the PVID of the access port must be the voice VLAN. In this scenario, 802.1X authentication is not supported.
Security mode and normal mode of voice VLANs
Depending on the filtering mechanisms to incoming packets, a voice VLAN-enabled port can operate in one of the following modes:
·     Normal mode—The port receives voice-VLAN-tagged packets and forwards them in the voice VLAN without examining their MAC addresses. If the PVID of the port is the voice VLAN and the port operates in manual VLAN assignment mode, the port forwards all the received untagged packets in the voice VLAN.
In this mode, voice VLANs are vulnerable to traffic attacks. Malicious users might send a large number of forged voice-VLAN-tagged or untagged packets to affect voice communication.
·     Security mode—The port uses the source MAC addresses of voice packets to match the OUI addresses of the device. Packets that fail the match will be dropped.
In a safe network, you can configure the voice VLANs to operate in normal mode. This mode reduces system resource consumption in source MAC address checking.
In either mode, the device modifies the transmission priority only for voice VLAN packets whose source MAC addresses match OUI addresses of the device.
As a best practice, do not transmit both voice traffic and non-voice traffic in a voice VLAN. If you must transmit different traffic in a voice VLAN, make sure the voice VLAN security mode is disabled.
Table 4 Packet processing on a voice VLAN-enabled port in normal or security mode
Voice VLAN mode
Packet type
Packet processing
Normal
·     Untagged packets
·     Packets with the voice VLAN tags
The port does not examine their source MAC addresses. Both voice traffic and non-voice traffic can be transmitted in the voice VLAN.
Packets with other VLAN tags
The port forwards or drops them depending on whether the port permits packets from these VLANs to pass through.
Security
·     Untagged packets
·     If the source MAC address of a packet matches an OUI address on the device, the packet is forwarded in the voice VLAN.
·     If the source MAC address of a packet does not match an OUI address on the device, the packet is dropped.
Voice VLAN configuration task list
Tasks at a glance
(Required.) Configuring the QoS priority settings for voice traffic
(Required.) Use one of the following methods:
·     Configuring a port to operate in automatic voice VLAN assignment mode
·     Configuring a port to operate in manual voice VLAN assignment mode
(Optional.) Enabling LLDP for automatic IP phone discovery
(Optional.) Use one of the following methods:
·     Configuring LLDP to advertise a voice VLAN
·     Configuring CDP to advertise a voice VLAN
The QoS priority settings carried in voice traffic include the CoS and DSCP values. You can configure the device to modify the QoS priority settings for voice traffic.
You cannot configure the QoS priority settings on a voice VLAN-enabled port. Before you configure the QoS priority settings for voice traffic on a port, you must disable the voice VLAN feature on it.
To configure the QoS priority settings for voice traffic:
Step
Remarks
N/A
2.     Enter interface view.
·     Enter Layer 2 Ethernet interface view:
interface
·     Enter Layer 2 aggregate interface view:
interface bridge-aggregation
interface-number
N/A
3.     Configure QoS priority settings for incoming voice VLAN packets.
·     Configure the port to trust the QoS priority settings:
voice-vlan qos trust
·     Configure the port to modify the CoS and DSCP values:
voice-vlan qos cos-value dscp-value
By default, a port modifies the CoS and DSCP values for voice VLAN packets to 6 and 46, respectively.
If a port trusts the QoS priority settings in incoming voice VLAN packets, the port does not modify their CoS and DSCP values.
If you execute the voice-vlan qos and voice-vlan qos trust commands multiple times, the most recent configuration takes effect.
When you configure a port to operate in automatic voice VLAN assignment mode, follow these restrictions and guidelines:
·     Do not configure a VLAN as both a voice VLAN and a protocol-based VLAN.
¡     A voice VLAN in automatic mode on a hybrid port processes only tagged incoming voice traffic.
¡     A protocol-based VLAN on a hybrid port processes only untagged incoming packets. For more information about protocol-based VLANs, see "Configuring protocol-based VLANs."
·     As a best practice, do not use this mode with MSTP. In MSTP mode, if a port is blocked in the MSTI of the target voice VLAN, the port drops the received packets instead of delivering them to the CPU. As a result, the port will not be dynamically assigned to the voice VLAN.
·     As a best practice, do not use this mode with PVST. In PVST mode, if the target voice VLAN is not permitted on a port, the port is placed in blocked state. The port drops the received packets instead of delivering them to the CPU. As a result, the port will not be dynamically assigned to the voice VLAN.
To configure a port to operate in automatic voice VLAN assignment mode:
Step
Remarks
N/A
2.     (Optional.) Set the voice VLAN aging timer.
voice-vlan aging minutes
By default, the aging timer of a voice VLAN is 1440 minutes.
The voice VLAN aging timer takes effect only on ports in automatic voice VLAN assignment mode.
3.     (Optional.) Enable the voice VLAN security mode.
voice-vlan security enable
By default, the voice VLAN security mode is enabled.
4.     (Optional.) Add an OUI address for voice packet identification.
voice-vlan mac-address oui mask oui-mask [ description text ]
By default, system default OUI addresses exist. For more information, see Table 1.
interface
interface-number
N/A
6.     Configure the link type of the port.
·     port link-type trunk
·     port link-type hybrid
N/A
7.     Configure the port to operate in automatic voice VLAN assignment mode.
voice-vlan mode auto
By default, the automatic voice VLAN assignment mode is enabled.
8.     Enable the voice VLAN feature on the port.
voice-vlan vlan-id enable
By default, the voice VLAN feature is disabled.
Before you execute this command, make sure the specified VLAN already exists.
When you configure a port to operate in manual voice VLAN assignment mode, follow these restrictions and guidelines:
·     You can configure different voice VLANs for different ports on the same device. Make sure the following requirements are met:
¡     One port can be configured with only one voice VLAN.
¡     Voice VLANs must be existing static VLANs.
·     Do not enable voice VLAN on the member ports of a link aggregation group. For more information about link aggregation, see "Configuring Ethernet link aggregation."
·     To make a voice VLAN take effect on a port operating in manual mode, you must manually assign the port to the voice VLAN.
To configure a port to operate in manual voice VLAN assignment mode:
Step
Remarks
N/A
2.     (Optional.) Enable the voice VLAN security mode.
3.     (Optional.) Add an OUI address for voice packet identification.
4.     Enter interface view.
interface
interface-number
N/A
5.     Configure the port to operate in manual voice VLAN assignment mode.
undo voice-vlan mode auto
By default, a port operates in automatic voice VLAN assignment mode.
6.     Assign the access, trunk, or hybrid port to the voice VLAN.
·     For the access port, see "Assigning an access port to a VLAN."
·     For the trunk port, see "Assigning a trunk port to a VLAN."
·     For the hybrid port, see "Assigning a hybrid port to a VLAN."
After you assign an access port to the voice VLAN, the voice VLAN becomes the PVID of the port.
7.     (Optional.) Configure the voice VLAN as the PVID of the trunk or hybrid port.
This step is required for untagged incoming voice traffic and prohibited for tagged incoming voice traffic.
When you enable LLDP for automatic IP phone discovery, following these restrictions and guidelines:
·     Before you enable this feature, enable LLDP both globally and on access ports.
·     Use this feature only with the automatic voice VLAN assignment mode.
·     Do not use this feature together with CDP compatibility.
To enable LLDP for automatic IP phone discovery:
Step
Remarks
N/A
2.     Enable LLDP for automatic IP phone discovery.
voice-vlan track lldp
For IP phones that support LLDP, the device advertises the voice VLAN information to the IP phones through the LLDP-MED TLVs.
Before you configure this feature, enable LLDP both globally and on access ports.
To configure LLDP to advertise a voice VLAN:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface view.
N/A
3.     Configure an advertised voice VLAN ID.
lldp tlv-enable med-tlv network-policy vlan-id
By default, no advertised voice VLAN ID is configured.
For more information about the command, see Layer 2—LAN Switching Command Reference.
4.     (Optional.) Display the voice VLAN advertised by LLDP.
display lldp local-information
If an IP phone supports CDP but does not support LLDP, it will send out CDP packets to the device to request the voice VLAN ID. If the IP phone does not receive the voice VLAN ID within a time period, it will send out untagged packets. The device cannot differentiate untagged voice packets from other types of packets.
You can configure CDP compatibility on the device to enable it to perform the following operations:
·     Receive and identify CDP packets from the IP phone.
·     Send CDP packets to the IP phone. The voice VLAN information is carried in the CDP packets.
After receiving the advertised VLAN information, the IP phone performs automatic voice VLAN configuration. Packets from the IP phone will be transmitted in the dedicated voice VLAN.
LLDP packets sent from the device carry the priority information. CDP packets sent from the device do not carry the priority information.
Before you configure this feature, enable LLDP globally and on access ports.
To configure CDP to advertise a voice VLAN:
Step
Remarks
N/A
2.     Enable CDP compatibility.
lldp compliance cdp
By default, CDP compatibility is disabled.
3.     Enter Layer 2 Ethernet interface view.
N/A
4.     Configure CDP-compatible LLDP to operate in TxRx mode.
lldp compliance admin-status cdp txrx
CDP-compatible LLDP operating in TxRx mode can send and receive CDP packets.
5.     Configure an advertised voice VLAN ID.
cdp voice-vlan vlan-id
Displaying and maintaining voice VLANs
Display the voice VLAN state.
display voice-vlan state
Display OUI addresses on a device.
display voice-vlan mac-address
Voice VLAN configuration examples
Automatic voice VLAN assignment mode configuration example
As shown in Figure 17, Device A transmits traffic from IP phones and hosts.
For correct voice traffic transmission, perform the following tasks on Device A:
·     Configure voice VLANs 2 and 3 to transmit voice packets from IP phone A and IP phone B, respectively.
·     Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to operate in automatic voice VLAN assignment mode.
·     Add MAC addresses of IP phones A and B to the device for voice packet identification. The mask of the two MAC addresses is FFFF-FF00-0000.
·     Set an aging timer for voice VLANs.
Figure 17 Network diagram
1.     Configure voice VLANs:
# Set the voice VLAN aging timer to 30 minutes.
[DeviceA] voice-vlan aging 30
# Enable security mode for voice VLANs.
[DeviceA] voice-vlan security enable
# Add MAC addresses of IP phones A and B to the device with mask FFFF-FF00-0000.
[DeviceA] voice-vlan mac-address 0011-1100-0001 mask ffff-ff00-0000 description IP phone A
[DeviceA] voice-vlan mac-address 0011-2200-0001 mask ffff-ff00-0000 description IP phone B
2.     Configure GigabitEthernet 1/0/1:
# Configure GigabitEthernet 1/0/1 as a hybrid port.
# Configure GigabitEthernet 1/0/1 to operate in automatic voice VLAN assignment mode.
[DeviceA-GigabitEthernet1/0/1] voice-vlan mode auto
# Enable voice VLAN on GigabitEthernet 1/0/1 and configure VLAN 2 as the voice VLAN for it.
[DeviceA-GigabitEthernet1/0/1] voice-vlan 2 enable
3.     Configure GigabitEthernet 1/0/2:
# Configure GigabitEthernet 1/0/2 as a hybrid port.
[DeviceA-GigabitEthernet1/0/2] port link-type hybrid
# Configure GigabitEthernet 1/0/2 to operate in automatic voice VLAN assignment mode.
[DeviceA-GigabitEthernet1/0/2] voice-vlan mode auto
# Enable voice VLAN on GigabitEthernet 1/0/2 and configure VLAN 3 as the voice VLAN for it.
[DeviceA-GigabitEthernet1/0/2] voice-vlan 3 enable
# Display the OUI addresses supported on Device A.
[DeviceA] display voice-vlan mac-address
OUI Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
0011-1100-0000  ffff-ff00-0000  IP phone A
0011-2200-0000  ffff-ff00-0000  IP phone B
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
# Display the voice VLAN state.
[DeviceA] display voice-vlan state
 Current voice VLANs: 2
 Voice VLAN security mode: Security
 Voice VLAN aging time: 30 minutes
 Voice VLAN enabled ports and their modes:
 Port                        VLAN        Mode        CoS        DSCP
 GE1/0/1                     2           Auto        6          46
 GE1/0/2                     3           Auto        6          46
Manual voice VLAN assignment mode configuration example
As shown in Figure 18, IP phone A send untagged voice traffic.
To enable GigabitEthernet 1/0/1 to transmit only voice packets, perform the following tasks on Device A:
·     Create VLAN 2. This VLAN will be used as a voice VLAN.
·     Configure GigabitEthernet 1/0/1 to operate in manual voice VLAN assignment mode and add it to VLAN 2.
·     Add the OUI address of IP phone A to the OUI list of Device A.
Figure 18 Network diagram
# Add MAC address 0011-2200-0001 with mask FFFF-FF00-0000.
[DeviceA] voice-vlan mac-address 0011-2200-0001 mask ffff-ff00-0000 description test
# Create VLAN 2.
[DeviceA] vlan 2
# Configure GigabitEthernet 1/0/1 to operate in manual voice VLAN assignment mode.
[DeviceA-GigabitEthernet1/0/1] undo voice-vlan mode auto
# Set the PVID of GigabitEthernet 1/0/1 to VLAN 2.
[DeviceA-GigabitEthernet1/0/1] port hybrid pvid vlan 2
# Assign GigabitEthernet 1/0/1 to VLAN 2 as an untagged VLAN member.
[DeviceA-GigabitEthernet1/0/1] port hybrid vlan 2 untagged
# Enable voice VLAN and configure VLAN 2 as the voice VLAN on GigabitEthernet 1/0/1.
0011-2200-0000  ffff-ff00-0000  test
 Current voice VLANs: 1
 Voice VLAN aging time: 1440 minutes
 GE1/0/1                     2           Manual      6          46
