04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release752X-6W10004-Layer 2 - LAN Switching Configuration Guide
02-Ethernet link aggregation configuration
02-Ethernet link aggregation configuration 302.6 KB
Configuring Ethernet link aggregation· 1
Basic concepts· 1
Aggregation group, member port, and aggregate interface· 1
Aggregation states of member ports in an aggregation group· 1
Operational key· 2
Configuration types· 2
Link aggregation modes· 3
Aggregating links in static mode· 3
Choosing a reference port 3
Setting the aggregation state of each member port 3
Aggregating links in dynamic mode· 4
LACP· 5
How dynamic link aggregation works· 6
Edge aggregate interface· 8
Load sharing modes for link aggregation groups· 8
Ethernet link aggregation configuration task list 8
Configuring an aggregation group· 9
Configuration restrictions and guidelines· 9
Configuring a Layer 2 aggregation group· 10
Configuring a Layer 3 aggregation group· 11
Configuring an aggregate interface· 13
Configuring the description of an aggregate interface· 13
Specifying ignored VLANs for a Layer 2 aggregate interface· 13
Setting the MTU for a Layer 3 aggregate interface· 14
Setting the minimum and maximum numbers of Selected ports for an aggregation group· 14
Setting the expected bandwidth for an aggregate interface· 15
Configuring an edge aggregate interface· 15
Shutting down an aggregate interface· 16
Restoring the default settings for an aggregate interface· 17
Configuring load sharing for link aggregation groups· 17
Setting load sharing modes for link aggregation groups· 17
Enabling local-first load sharing for link aggregation· 18
Enabling link-aggregation traffic redirection· 19
Configuration restrictions and guidelines· 19
Configuration procedure· 20
Displaying and maintaining Ethernet link aggregation· 20
Ethernet link aggregation configuration examples· 21
Layer 2 static aggregation configuration example· 21
Layer 2 dynamic aggregation configuration example· 23
Layer 2 aggregation load sharing configuration example· 24
Layer 2 edge aggregate interface configuration example· 27
Layer 3 static aggregation configuration example· 28
Layer 3 dynamic aggregation configuration example· 29
Layer 3 aggregation load sharing configuration example· 31
Layer 3 edge aggregate interface configuration example· 33
Ethernet link aggregation bundles multiple physical Ethernet links into one logical link, called an aggregate link.
Link aggregation has the following benefits:
·     Increased bandwidth beyond the limits of any single link. In an aggregate link, traffic is distributed across the member ports.
·     Improved link reliability. The member ports dynamically back up one another. When a member port fails, its traffic is automatically switched to other member ports.
As shown in Figure 1, Device A and Device B are connected by three physical Ethernet links. These physical Ethernet links are combined into an aggregate link called link aggregation 1. The bandwidth of this aggregate link can reach up to the total bandwidth of the three physical Ethernet links. At the same time, the three Ethernet links back up one another. When a physical Ethernet link fails, the traffic previously transmitted on the failed link is switched to the other two links.
Figure 1 Ethernet link aggregation diagram
Basic concepts
An aggregation group is a group of Ethernet interfaces bundled together. These Ethernet interfaces are called member ports of the aggregation group. Each aggregation group has a corresponding logical interface (called an aggregate interface).
When an aggregate interface is created, the device automatically creates an aggregation group of the same type and number as the aggregate interface.
An aggregate interface can be one of the following types:
·     Layer 2—A Layer 2 aggregate interface is created manually. The member ports of the corresponding Layer 2 aggregation group can only be Layer 2 Ethernet interfaces.
·     Layer 3—A Layer 3 aggregate interface is created manually. The member ports of the corresponding Layer 3 aggregation group can only be Layer 3 Ethernet interfaces.
On a Layer 3 aggregate interface, you can create subinterfaces.
Do not use the VLAN whose ID matches a Layer 3 aggregate subinterface number.
The port rate of an aggregate interface equals the total rate of its Selected member ports. Its duplex mode is the same as that of the Selected member ports. For more information about Selected member ports, see "Aggregation states of member ports in an aggregation group."
A member port in an aggregation group can be in any of the following aggregation states:
·     Selected—A Selected port can forward traffic.
·     Unselected—An Unselected port cannot forward traffic.
·     Individual—An Individual port can forward traffic as a normal physical port. A port is placed in the Individual state when the following conditions exist:
¡     Its aggregate interface is configured as an edge aggregate interface.
¡     The port has not received Link Aggregation Control Protocol Data Units (LACPDUs) from its peer port.
Operational key
When aggregating ports, the system automatically assigns each port an operational key based on port information, such as port rate and duplex mode. Any change to this information triggers a recalculation of the operational key.
In an aggregation group, all Selected ports have the same operational key.
Configuration types
Port configurations include attribute configurations and protocol configurations. Attribute configurations of a link aggregation member port affect its aggregation state.
·     Attribute configurations—To become a Selected port, a member port must have the same attribute configurations as the aggregate interface. Table 1 describes the attribute configurations.
Attribute configuration changes made on an aggregate interface are automatically synchronized to all member ports. If the changes fail to be synchronized to a Selected port, the port might change to the Unselected state. To make the port become Selected again, you can change the attribute configurations on the aggregate interface or the member port. The synchronization failure does not affect the attribute configuration changes made on the aggregate interface. The configurations that have been synchronized from the aggregate interface are retained on the member ports even after the aggregate interface is deleted.
Any attribute configuration change on a member port might affect the aggregation states and running services of the member ports. The system displays a warning message every time you try to change an attribute configuration setting on a member port.
Table 1 Attribute configurations
Feature
Considerations
Port isolation
Indicates whether the port has joined an isolation group and which isolation group the port belongs to.
QinQ
QinQ status (enabled/disabled), TPID for VLAN tags, and VLAN transparent transmission. For information about QinQ, see "Configuring QinQ."
VLAN mapping
VLAN mapping configured on the port. For more information about VLAN mapping, see "Configuring VLAN mapping."
VLAN
VLAN attribute configurations include the following:
·     Permitted VLAN IDs.
·     PVID.
·     Link type (trunk, hybrid, or access).
·     PVLAN port type (promiscuous, trunk promiscuous, host, or trunk secondary).
·     IP subnet-based VLAN configuration.
·     Protocol-based VLAN configuration.
·     VLAN tagging mode.
For information about VLANs, see "Configuring VLANs."
·     Protocol configurations—Protocol configurations of a member port do not affect the aggregation state of the member port. MAC address learning and spanning tree settings are examples of protocol configurations.
·     The protocol configurations for an aggregate interface take effect only on the current aggregate interface.
·     The protocol configurations for a member port take effect only when the port leaves its aggregation group.
An aggregation group operates in one of the following modes:
·     Static—Static aggregation is stable. An aggregation group in static mode is called a static aggregation group. The aggregation states of the member ports in a static aggregation group are not affected by the peer ports.
·     Dynamic—An aggregation group in dynamic mode is called a dynamic aggregation group. The local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
Layer 2 aggregation groups and Layer 3 aggregation groups support both the static and dynamic modes.
When setting the aggregation states of the ports in an aggregation group, the system automatically chooses a member port as the reference port. A Selected port must have the same operational key and attribute configurations as the reference port.
The system chooses a reference port from the member ports in up state.
The candidate reference ports are organized into different priority levels following these rules:
1.     In descending order of port priority.
2.     Full duplex.
3.     In descending order of speed.
4.     Half duplex.
5.     In descending order of speed.
From the candidate ports with the same attribute configurations as the aggregate interface, the one with the highest priority level is chosen as the reference port.
·     If multiple ports have the same priority level, the port that has been Selected (if any) is chosen. If multiple ports with the same priority level have been Selected, the one with the smallest port number is chosen.
·     If multiple ports have the same priority level and none of them has been Selected, the port with the smallest port number is chosen.
After the reference port is chosen, the system sets the aggregation state of each member port in the static aggregation group.
Figure 2 Setting the aggregation state of a member port in a static aggregation group
After the limit on Selected ports is reached, the aggregation state of a new member port varies by following conditions:
·     The port is placed in Unselected state if the port and the Selected ports have the same port priority. This mechanism prevents traffic interruption on the existing Selected ports. A device reboot can cause the device to recalculate the aggregation states of member ports.
·     The port is placed in Selected state when the following conditions are met:
¡     The port and the Selected ports have different port priorities, and the port has a higher port priority than a minimum of one Selected port.
¡     The port has the same attribute configurations as the aggregate interface.
Any operational key or attribute configuration change might affect the aggregation states of link aggregation member ports.
Dynamic aggregation is implemented through IEEE 802.3ad Link Aggregation Control Protocol (LACP).
LACP
LACP uses LACPDUs to exchange aggregation information between LACP-enabled devices. Each member port in a dynamic aggregation group can exchange information with its peer. When a member port receives an LACPDU, it compares the received information with information received on the other member ports. In this way, the two systems reach an agreement on which ports are placed in Selected state.
LACP functions
LACP offers basic LACP functions and extended LACP functions, as described in Table 2.
Table 2 Basic and extended LACP functions
Category
Basic LACP functions
Implemented through the basic LACPDU fields, including the system LACP priority, system MAC address, port priority, port number, and operational key.
Extended LACP functions
Implemented by extending the LACPDU with new TLV fields. Extended LACP can implement LACP MAD for the IRF feature.
If a device supports both extended LACP and IRF, it can participate in LACP MAD as either an IRF member device or an intermediate device.
For more information about IRF and the LACP MAD mechanism, see IRF Configuration Guide.
LACP operating modes
LACP can operate in active or passive mode.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
LACP priorities
LACP priorities include system LACP priority and port priority, as described in Table 3. The smaller the priority value, the higher the priority.
Table 3 LACP priorities
System LACP priority
Used by two peer devices (or systems) to determine which one is superior in link aggregation.
In dynamic link aggregation, the system that has higher system LACP priority sets the Selected state of member ports on its side. The system that has lower priority sets the aggregation state of local member ports the same as their respective peer ports.
Port priority
Determines the likelihood of a member port to be a Selected port on a system. A port with a higher port priority is more likely to become Selected.
LACP timeout interval
The LACP timeout interval specifies how long a member port waits to receive LACPDUs from the peer port. If a local member port has not received LACPDUs from the peer within the LACP timeout interval, the member port considers the peer as failed.
The LACP timeout interval also determines the LACPDU sending rate of the peer. LACP timeout intervals include the following types:
·     Short timeout interval—3 seconds. If you use the short timeout interval, the peer sends one LACPDU per second.
·     Long timeout interval—90 seconds. If you use the long timeout interval, the peer sends one LACPDU every 30 seconds.
The system chooses a reference port from the member ports in up state. A Selected port must have the same operational key and attribute configurations as the reference port.
The local system (the actor) and the peer system (the partner) negotiate a reference port by using the following workflow:
1.     The two systems determine the system with the smaller system ID.
A system ID contains the system LACP priority and the system MAC address.
a.     The two systems compare their LACP priority values.
The lower the LACP priority, the smaller the system ID. If the LACP priority values are the same, the two systems proceed to step b.
b.     The two systems compare their MAC addresses.
The lower the MAC address, the smaller the system ID.
2.     The system with the smaller system ID chooses the port with the smallest port ID as the reference port.
A port ID contains a port priority and a port number. The lower the port priority, the smaller the port ID.
a.     The system chooses the port with the lowest priority value as the reference port.
If the ports have the same priority, the system proceeds to step b.
b.     The system compares their port numbers.
The smaller the port number, the smaller the port ID.
The port with the smallest port number and the same attribute configurations as the aggregate interface is chosen as the reference port.
After the reference port is chosen, the system with the smaller system ID sets the state of each member port on its side.
Figure 3 Setting the state of a member port in a dynamic aggregation group
The system with the greater system ID can detect the aggregation state changes on the peer system. The system with the greater system ID sets the aggregation state of local member ports the same as their peer ports.
When you aggregate interfaces in dynamic mode, follow these guidelines:
·     A dynamic link aggregation group chooses only full-duplex ports as the Selected ports.
·     For stable aggregation and service continuity, do not change the operational key or attribute configurations on any member port.
·     After the Selected port limit is reached, a newly joining port becomes a Selected port if it is more eligible than a current Selected port.
Dynamic link aggregation fails on a server-facing aggregate interface if dynamic link aggregation is configured only on the device. The device forwards traffic by using only one of the physical ports that are connected to the server.
To improve link reliability, configure the aggregate interface as an edge aggregate interface. This feature enables all member ports of the aggregation group to forward traffic. When a member port fails, its traffic is automatically switched to other member ports.
After dynamic link aggregation is configured on the server, the device can receive LACPDUs from the server. Then, link aggregation between the device and the server operates correctly.
An edge aggregate interface takes effect only when it is configured on an aggregate interface corresponding to a dynamic aggregation group.
In a link aggregation group, traffic can be load shared across the Selected ports based on any of the following modes:
·     Per-flow load sharing—Load shares traffic on a per-flow basis. The load sharing mode classifies packets into flows and forwards packets of the same flow on the same link. This mode can be one or any combination of the following traffic classification criteria:
¡     Ingress port.
¡     Source or destination IP address.
¡     Source or destination MAC address.
¡     Source or destination port number.
¡     MPLS label.
·     Packet type-based load sharing—Load shares traffic automatically based on packet types (Layer 2 protocol, IPv4, MPLS, or IPv6).
Tasks at a glance
(Required.) Configuring an aggregation group:
·     Configuring a Layer 2 aggregation group
·     Configuring a Layer 3 aggregation group
(Optional.) Configuring an aggregate interface:
·     Configuring the description of an aggregate interface
·     Specifying ignored VLANs for a Layer 2 aggregate interface
·     Setting the MTU for a Layer 3 aggregate interface
·     Setting the minimum and maximum numbers of Selected ports for an aggregation group
·     Setting the expected bandwidth for an aggregate interface
·     Configuring an edge aggregate interface
·     Shutting down an aggregate interface
·     Restoring the default settings for an aggregate interface
(Optional.) Configuring load sharing for link aggregation groups:
·     Setting load sharing modes for link aggregation groups
·     Enabling local-first load sharing for link aggregation
(Optional.) Enabling link-aggregation traffic redirection
This section explains how to configure an aggregation group.
When you configure an aggregation group, follow these restrictions and guidelines:
·     The maximum number of aggregation groups and the maximum number of Selected ports allowed in an aggregation group vary by the port location, as shown in the following matrix:
Port location
Maximum number of aggregation groups
Maximum number of Selected ports in an aggregation group
Some member ports or the ingress ports of the traffic are on any of these modules.
·     EB interface modules
·     SC interface modules:
¡     LSQ1TGS8SC0
¡     LSQ3GV48SC0
·     SD interface modules
·     OAP modules:
¡     LSU1FWCEA0
¡     LSU3FWCEA0
¡     LSU3WCMD0
128
8
No aggregation group contains member ports on any of these modules.
1024
32
·     Do not assign interfaces on the LSQM1SRP8X2QE0 MPU and service modules to the same aggregation group.
·     Table 4 shows the interfaces that cannot be assigned to a Layer 2 aggregation group.
Table 4 Interfaces that cannot be assigned to a Layer 2 aggregation group
Interface type
Reference
Interface configured with MAC authentication
MAC authentication in Security Configuration Guide
Interface configured with port security
Port security in Security Configuration Guide
Interface configured with 802.1X
802.1X in Security Configuration Guide
Interface whose service instance is bound to a cross connect
MPLS L2VPN in MPLS Configuration Guide
Interface whose service instance is bound to a VSI
VPLS in MPLS Configuration Guide
·     Table 5 shows the interfaces that cannot be assigned to a Layer 3 aggregation group.
Table 5 Interfaces that cannot be assigned to a Layer 3 aggregation group
Interface type
Reference
Interface bound to a cross connect
Interface bound to a VSI
·     Do not assign a reflector port for port mirroring to an aggregation group. For more information about reflector ports, see Network Management and Monitoring Configuration Guide.
·     Deleting an aggregate interface also deletes its aggregation group and causes all member ports to leave the aggregation group.
·     You must configure the same aggregation mode on the two ends of an aggregate link.
·     For a successful static aggregation, make sure the ports at both ends of each link are in the same aggregation state.
·     For a successful dynamic aggregation, make sure the peer ports of the ports aggregated at one end are also aggregated. The two ends can automatically negotiate the aggregation state of each member port.
Configuring a Layer 2 static aggregation group
Step
Remarks
N/A
2.     Create a Layer 2 aggregate interface and enter Layer 2 aggregate interface view.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 static aggregation group numbered the same.
3.     Exit to system view.
N/A
4.     Assign an interface to the specified Layer 2 aggregation group.
a     Enter Layer 2 Ethernet interface view:
b     Assign the interface to the specified Layer 2 aggregation group:
Repeat these two substeps to assign more Layer 2 Ethernet interfaces to the aggregation group.
5.     (Optional.) Set the port priority for the interface.
The default port priority of an interface is 32768.
Configuring a Layer 2 dynamic aggregation group
Step
Remarks
N/A
2.     Set the system LACP priority.
lacp system-priority priority
By default, the system LACP priority is 32768.
Changing the system LACP priority might affect the aggregation states of the ports in a dynamic aggregation group.
3.     Create a Layer 2 aggregate interface and enter Layer 2 aggregate interface view.
4.     Configure the aggregation group to operate in dynamic mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static mode.
5.     Exit to system view.
N/A
6.     Assign an interface to the specified Layer 2 aggregation group.
7.     Set the LACP operating mode for the interface.
·     Set the LACP operating mode to passive:
lacp mode passive
·     Set the LACP operating mode to active:
undo lacp mode
By default, LACP is operating in active mode.
8.     Set the port priority for the interface.
The default setting is 32768.
9.     Set the short LACP timeout interval (3 seconds) for the interface.
lacp period short
By default, the long LACP timeout interval (90 seconds) is used by the interface.
To avoid traffic interruption during an ISSU, do not set the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
Configuring a Layer 3 static aggregation group
Step
Remarks
N/A
2.     Create a Layer 3 aggregate interface and enter Layer 3 aggregate interface view.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 static aggregation group numbered the same.
N/A
4.     Assign an interface to the specified Layer 3 aggregation group.
a     Enter Layer 3 Ethernet interface view:
b     Assign the interface to the specified Layer 3 aggregation group:
Repeat these two substeps to assign more Layer 3 Ethernet interfaces to the aggregation group.
Configuring a Layer 3 dynamic aggregation group
Step
Remarks
N/A
Changing the system LACP priority might affect the aggregation states of the ports in the dynamic aggregation group.
3.     Create a Layer 3 aggregate interface and enter Layer 3 aggregate interface view.
N/A
6.     Assign an interface to the specified Layer 3 aggregation group.
lacp mode passive
undo lacp mode
lacp period short
Most configurations that can be made on Layer 2 or Layer 3 Ethernet interfaces can also be made on Layer 2 or Layer 3 aggregate interfaces.
You can configure the description of an aggregate interface for administration purposes, for example, describing the purpose of the interface.
To configure the description of an aggregate interface:
Step
Remarks
N/A
2.     Enter aggregate interface or subinterface view.
·     Enter Layer 2 aggregate interface view:
·     Enter Layer 3 aggregate interface or subinterface view:
N/A
3.     Configure the description of the aggregate interface or subinterface.
By default, the description of an interface is interface-name Interface.
The system ignores the permit state and tagging mode of an ignored VLAN when choosing Selected ports.
By default, to become Selected, the member ports must have the same VLAN permit state and tagging mode as the corresponding Layer 2 aggregate interface.
To specify ignored VLANs for a Layer 2 aggregate interface:
Step
Remarks
N/A
2.     Enter Layer 2 aggregate interface view.
N/A
3.     Specify ignored VLANs.
link-aggregation ignore vlan vlan-id-list
By default, a Layer 2 aggregate interface does not ignore any VLANs.
The MTU of an interface affects IP packets fragmentation and reassembly on the interface.
To set the MTU for a Layer 3 aggregate interface:
Step
Remarks
N/A
2.     Enter Layer 3 aggregate interface or subinterface view.
N/A
3.     Set the MTU for the Layer 3 aggregate interface or subinterface.
mtu size
The default setting is 1500 bytes.
IMPORTANT
IMPORTANT:
The minimum and maximum numbers of Selected ports must be the same for the local and peer aggregation groups.
The bandwidth of an aggregate link increases as the number of Selected member ports increases. To avoid congestion, you can set the minimum number of Selected ports required for bringing up an aggregate interface.
This minimum threshold setting affects the aggregation states of aggregation member ports and the state of the aggregate interface.
·     When the number of member ports eligible to be Selected ports is smaller than the minimum threshold, the following events occur:
¡     The eligible member ports are placed in Unselected state.
¡     The link layer state of the aggregate interface becomes down.
·     When the number of member ports eligible to be Selected ports reaches or exceeds the minimum threshold, the following events occur:
¡     The eligible member ports are placed in Selected state.
¡     The link layer state of the aggregate interface becomes up.
The maximum number of Selected ports allowed in an aggregation group is limited by either manual configuration or hardware limitation, whichever value is smaller.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group, and the Unselected port acts as a backup port.
To set the minimum and maximum numbers of Selected ports for an aggregation group:
Step
Remarks
N/A
2.     Enter aggregate interface view.
·     Enter Layer 3 aggregate interface view:
N/A
3.     Set the minimum number of Selected ports for the aggregation group.
By default, the minimum number of Selected ports is not specified for an aggregation group.
4.     Set the maximum number of Selected ports for the aggregation group.
link-aggregation selected-port maximum max-number
By default, the maximum number of Selected ports for an aggregation group depends on hardware limitation.
Step
Remarks
N/A
N/A
3.     Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
When you configure an edge aggregate interface, follow these restrictions and guidelines:
·     This configuration takes effect only on the aggregate interface corresponding to a dynamic aggregation group.
·     Link-aggregation traffic redirection does not operate correctly on an edge aggregate interface. For more information about link-aggregation traffic redirection, see "Enabling link-aggregation traffic redirection."
To configure an edge aggregate interface:
Step
Remarks
N/A
N/A
3.     Configure the aggregate interface as an edge aggregate interface.
lacp edge-port
By default, an aggregate interface does not operate as an edge aggregate interface.
Shutting down or bringing up an aggregate interface affects the aggregation states and link states of member ports in the corresponding aggregation group as follows:
·     When an aggregate interface is shut down, all Selected ports in the corresponding aggregation group become Unselected ports and all member ports go down.
·     When an aggregate interface is brought up, the aggregation states of member ports in the corresponding aggregation group are recalculated.
To shut down an aggregate interface:
Step
Remarks
N/A
N/A
3.     Shut down the aggregate interface or subinterface.
shutdown
By default, an aggregate interface or subinterface is up.
You can restore all configurations on an aggregate interface to the default settings.
To restore the default settings for an aggregate interface:
Step
3.     Restore the default settings for the aggregate interface.
default
This section explains how to configure the load sharing modes for link aggregation groups and how to enable local-first load sharing for link aggregation.
You can set the global or group-specific load sharing mode. A link aggregation group preferentially uses the group-specific load sharing mode. If the group-specific load sharing mode is not available, the group uses the global load sharing mode.
Setting the global link-aggregation load sharing mode
In system view, the switch supports the following load sharing modes:
·     Source IP address.
·     Destination IP address.
·     Source MAC address.
·     Destination MAC address.
·     Source IP address and destination IP address.
·     Source IP address and source port.
·     Destination IP address and destination port.
·     Source IP address, source port, destination IP address, and destination port.
·     Any combination of ingress port, source MAC address, and destination MAC address.
To set the global link-aggregation load sharing mode:
Step
Remarks
N/A
2.     Set the global link-aggregation load sharing mode.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
By default, the device load shares traffic automatically based on packet types.
Setting the group-specific load sharing mode
In Layer 2 aggregate interface view, the switch supports the following load sharing modes:
·     Layer 1 MPLS label.
·     Destination IP address and source IP address.
·     Destination MAC address and source MAC address.
·     Layer 1 MPLS label and Layer 2 MPLS label.
To set the load sharing mode for an aggregation group:
Step
Remarks
N/A
N/A
3.     Set the load sharing mode for the aggregation group.
link-aggregation load-sharing mode { { destination-ip | destination-mac | mpls-label1 | mpls-label2 | source-ip | source-mac } * | flexible }
By default, the load sharing mode is the same as the global load sharing mode.
Use local-first load sharing in a multidevice link aggregation scenario to distribute traffic preferentially across member ports on the ingress card or device.
When you aggregate ports on different member devices in an IRF fabric, you can use local-first load sharing to reduce traffic on IRF links, as shown in Figure 4. For more information about IRF, see IRF Configuration Guide.
Figure 4 Load sharing for multidevice link aggregation in an IRF fabric
To enable local-first load sharing for link aggregation:
Step
Remarks
N/A
2.     Enable local-first load sharing for link aggregation.
link-aggregation load-sharing mode local-first
By default, local-first load sharing for link aggregation is enabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports after the port is shut down by using the shutdown command. This feature minimizes packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature avoids traffic interruption when a card or device in a multicard or multichassis aggregation group reboots.
You can enable link-aggregation traffic redirection globally or for an aggregation group. Global link-aggregation traffic redirection settings take effect on all aggregation groups. A link aggregation group preferentially uses the group-specific link-aggregation traffic redirection settings. If group-specific link-aggregation traffic redirection is not configured, the group uses the global link-aggregation traffic redirection settings.
When you enable link-aggregation traffic redirection, follow these restrictions and guidelines:
·     Link-aggregation traffic redirection applies only to dynamic link aggregation groups.
·     To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
·     To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
·     As a best practice, enable link-aggregation traffic redirection on aggregate interfaces. If you enable this feature globally, communication with a third-party peer device might be affected if the peer is not compatible with this feature.
To enable link-aggregation traffic redirection globally:
Step
Remarks
N/A
2.     Enable link-aggregation traffic redirection globally.
link-aggregation lacp traffic-redirect-notification enable
By default, link-aggregation traffic redirection is disabled globally.
To enable link-aggregation traffic redirection for an aggregation group:
Step
Remarks
N/A
N/A
3.     Enable link-aggregation traffic redirection for the aggregation group.
By default, link-aggregation traffic redirection is disabled for an aggregation group.
Display information for an aggregate interface or multiple aggregate interfaces.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
Display the local system ID.
display lacp system-id
Display the global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
Display detailed link aggregation information for link aggregation member ports.
display link-aggregation member-port [ interface-list ]
Display summary information about all aggregation groups.
display link-aggregation summary
Display detailed information about the specified aggregation groups.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
Clear LACP statistics for the specified link aggregation member ports.
Clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
Network requirements
On the network shown in Figure 5, perform the following tasks:
·     Configure a Layer 2 static aggregation group on both Device A and Device B.
·     Enable VLAN 10 at one end of the aggregate link to communicate with VLAN 10 at the other end.
·     Enable VLAN 20 at one end of the aggregate link to communicate with VLAN 20 at the other end.
Figure 5 Network diagram
1.     Configure Device A:
# Create VLAN 10, and assign port GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 1/0/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-Aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
# Assign ports GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to link aggregation group 1.
[DeviceA-GigabitEthernet1/0/1] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/2] port link-aggregation group 1
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 1
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port link-type trunk
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about all aggregation groups on Device A.
[DeviceA] display link-aggregation verbose
Port Status: S -- Selected, U -- Unselected, I -- Individual, * -- Management port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Mode: Static
Management VLAN : None
  Port             Status  Priority Oper-Key
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
The output shows that link aggregation group 1 is a Layer 2 static aggregation group that contains three Selected ports.
On the network shown in Figure 6, perform the following tasks:
·     Configure a Layer 2 dynamic aggregation group on both Device A and Device B.
Figure 6 Network diagram
# Create VLAN 10, and assign the port GigabitEthernet 1/0/4 to VLAN 10.
[DeviceA] vlan 10
# Create VLAN 20, and assign the port GigabitEthernet 1/0/5 to VLAN 20.
[DeviceA] vlan 20
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and set the link aggregation mode to dynamic.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
Aggregation Mode: Dynamic
Local:
  Port             Status  Priority Oper-Key  Flag
  GE1/0/1          S       32768    1         {ACDEF}
  GE1/0/2          S       32768    1         {ACDEF}
  GE1/0/3          S       32768    1         {ACDEF}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  GE1/0/1          1       32768    1         0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/2          2       32768    1         0x8000, 000f-e267-57ad {ACDEF}
  GE1/0/3          3       32768    1         0x8000, 000f-e267-57ad {ACDEF}
The output shows that link aggregation group 1 is a Layer 2 dynamic aggregation group that contains three Selected ports.
On the network shown in Figure 7, perform the following tasks:
·     Configure Layer 2 static aggregation groups 1 and 2 on Device A and Device B, respectively.
·     Configure link aggregation groups 1 and 2 to load share traffic across aggregation group member ports.
¡     Configure link aggregation group 1 to load share packets based on source MAC addresses.
¡     Configure link aggregation group 2 to load share packets based on destination MAC addresses.
Figure 7 Network diagram
# Create VLAN 10, and assign the port GigabitEthernet 1/0/5 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 1/0/5
# Create VLAN 20, and assign the port GigabitEthernet 1/0/6 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port gigabitethernet 1/0/6
# Configure Layer 2 aggregation group 1 to load share packets based on source MAC addresses.
[DeviceA-Bridge-Aggregation1] link-aggregation load-sharing mode source-mac
# Assign ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to link aggregation group 1.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a trunk port and assign it to VLAN 10.
# Create Layer 2 aggregate interface Bridge-Aggregation 2.
[DeviceA] interface bridge-aggregation 2
# Configure Layer 2 aggregation group 2 to load share packets based on destination MAC addresses.
[DeviceA-Bridge-Aggregation2] link-aggregation load-sharing mode destination-mac
[DeviceA-Bridge-Aggregation2] quit
# Assign ports GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to link aggregation group 2.
[DeviceA-GigabitEthernet1/0/3] port link-aggregation group 2
[DeviceA] interface gigabitethernet 1/0/4
[DeviceA-GigabitEthernet1/0/4] port link-aggregation group 2
[DeviceA-GigabitEthernet1/0/4] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 2 as a trunk port and assign it to VLAN 20.
[DeviceA-Bridge-Aggregation2] port link-type trunk
[DeviceA-Bridge-Aggregation2] port trunk permit vlan 20
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
Aggregate Interface: Bridge-Aggregation2
  GE1/0/3            S       32768    2
  GE1/0/4            S       32768    2
The output shows that:
·     Link aggregation groups 1 and 2 are both load-shared Layer 2 static aggregation groups.
·     Each aggregation group contains two Selected ports.
# Display all the group-specific load sharing modes on Device A.
[DeviceA] display link-aggregation load-sharing mode interface
Bridge-Aggregation1 Load-Sharing Mode:
source-mac address
Bridge-Aggregation2 Load-Sharing Mode:
destination-mac address
·     Link aggregation group 1 load shares packets based on source MAC addresses.
·     Link aggregation group 2 load shares packets based on destination MAC addresses.
As shown in Figure 8, a Layer 2 dynamic aggregation group is configured on the device. The server is not configured with dynamic link aggregation.
Configure an edge aggregate interface so that both GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 can forward traffic to improve link reliability.
Figure 8 Network diagram
[Device] interface bridge-aggregation 1
[Device-Bridge-Aggregation1] link-aggregation mode dynamic
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
[Device-Bridge-Aggregation1] lacp edge-port
[Device-Bridge-Aggregation1] quit
[Device-GigabitEthernet1/0/1] port link-aggregation group 1
[Device-GigabitEthernet1/0/2] port link-aggregation group 1
# Display detailed information about all aggregation groups on the device when the server is not configured with dynamic link aggregation.
[Device] display link-aggregation verbose
Local:
  GE1/0/1          I       32768    1         {AG}
  GE1/0/2          I       32768    1         {AG}
Remote:
  GE1/0/1          0       32768    0         0x8000, 0000-0000-0000 {DEF}
  GE1/0/2          0       32768    0         0x8000, 0000-0000-0000 {DEF}
The output shows that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are in Individual state when they do not receive LACPDUs from the server. Both GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 can forward traffic. When one port fails, its traffic is automatically switched to the other port.
On the network shown in Figure 9, perform the following tasks:
·     Configure a Layer 3 static aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 9 Network diagram
# Create Layer 3 aggregate interface Route-Aggregation 1, and configure an IP address and subnet mask for the aggregate interface.
[DeviceA] interface route-aggregation 1
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/1 through GigabitEthernet 1/0/3 to aggregation group 1.
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
  GE1/0/3          S       32768    1
The output shows that link aggregation group 1 is a Layer 3 static aggregation group that contains three Selected ports.
On the network shown in Figure 10, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
Figure 10 Network diagram
# Create Layer 3 aggregate interface Route-Aggregation 1.
# Set the link aggregation mode to dynamic.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Route-Aggregation 1.
Local:
Remote:
The output shows that link aggregation group 1 is a Layer 3 dynamic aggregation group that contains three Selected ports.
On the network shown in Figure 11, perform the following tasks:
·     Configure Layer 3 static aggregation groups 1 and 2 on Device A and Device B, respectively.
·     Configure link aggregation group 1 to load share packets based on source IP addresses.
·     Configure link aggregation group 2 to load share packets based on destination IP addresses.
Figure 11 Network diagram
# Configure Layer 3 aggregation group 1 to load share packets based on source IP addresses.
[DeviceA-Route-Aggregation1] link-aggregation load-sharing mode source-ip
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to aggregation group 1.
# Create Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA] interface route-aggregation 2
# Configure Layer 3 aggregation group 2 to load share packets based on destination IP addresses.
[DeviceA-Route-Aggregation2] link-aggregation load-sharing mode destination-ip
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 2.
[DeviceA-Route-Aggregation2] ip address 192.168.2.1 24
[DeviceA-Route-Aggregation2] quit
# Assign Layer 3 Ethernet interfaces GigabitEthernet 1/0/3 and GigabitEthernet 1/0/4 to aggregation group 2.
  GE1/0/1          S       32768    1
  GE1/0/2          S       32768    1
Aggregate Interface: Route-Aggregation2
  GE1/0/3          S       32768    2
  GE1/0/4          S       32768    2
·     Link aggregation groups 1 and 2 are both load-shared Layer 3 static aggregation groups.
Route-Aggregation1 Load-Sharing Mode:
source-ip address
Route-Aggregation2 Load-Sharing Mode:
destination-ip address
·     Link aggregation group 1 load shares packets based on source IP addresses.
·     Link aggregation group 2 load shares packets based on destination IP addresses.
As shown in Figure 12, a Layer 3 dynamic aggregation group is configured on the device. The server is not configured with dynamic link aggregation.
Figure 12 Network diagram
# Create Layer 3 aggregate interface Route-Aggregation 1, and set the link aggregation mode to dynamic.
[Device] interface route-aggregation 1
[Device-Route-Aggregation1] link-aggregation mode dynamic
[Device-Route-Aggregation1] ip address 192.168.1.1 24
# Configure Layer 3 aggregate interface Route-Aggregation 1 as an edge aggregate interface.
[Device-Route-Aggregation1] lacp edge-port
[Device-Route-Aggregation1] quit
Local:
Remote:
