10-Security Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10010-Security Command Reference
03-MAC authentication commands
03-MAC authentication commands 123.72 KB
display mac-authentication
Use display mac-authentication to display MAC authentication settings and statistics. The output includes the global settings, port-specific settings, MAC authentication statistics, and online user statistics.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays all global and port-specific MAC authentication information.
# Display all MAC authentication settings and statistics.
   MAC authentication     : Disabled
   User name format        : MAC address in lowercase(xxxxxxxxxxxx)
           Username       : mac
           Password       : Not configured
   Offline detect period  : 300 s
   Quiet period           : 60 s
   Server timeout         : 100 s
   Authentication domain  : Not configured, use default domain
 Max MAC-auth users       : 4294967295 per slot
 Online MAC-auth users    : 2
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
          0001-0000-0000    2        GigabitEthernet1/0/3    20
          0001-0000-0000    12       GigabitEthernet1/0/4    301
 GigabitEthernet1/0/1  is link-up
   MAC authentication         : Enabled
   Carry User-IP              : Enabled
   Auth-delay timer           : Enabled
       Auth-delay period      : 60 s
   Guest VLAN                 : 100
   Guest VLAN auth-period     : 30 s
   Critical VLAN              : Not configured
   Critical voice VLAN        : Disabled
   Host mode                  : Multiple VLAN
   Offline detection          : Enabled
   Authentication order       : Default
   Max online users           : 4294967295
   Authentication attempts    : successful 2, failed 3
   Current online users       : 2
          MAC address       Auth state
          0001-0000-0000    Authenticated
          0001-0000-0001    Unauthenticated
MAC authentication
Whether MAC authentication is enabled globally.
User name format
User account type: MAC-based or shared.
·     If MAC-based accounts are used, this field displays the format settings for the username. For example, MAC address in lowercase(xxxxxxxxxxxx) indicates that the MAC address is in the hexadecimal notation without hyphens, and letters are in lower case.
·     If a shared account is used, this field displays Fixed account.
Username:
Username for MAC authentication.
·     If MAC-based accounts are used, this field displays mac. The device uses the MAC address of each user as the username and password for MAC authentication.
·     If a shared account is used, this field displays the username of the shared account for MAC authentication users. By default, the username is mac.
Password:
Password for MAC authentication.
·     If MAC-based accounts are used or if a shared account is used but no password is configured, this field displays Not configured.
·     If a shared account is used and a password is configured, this field displays a string of asterisks (******).
Offline detect timer.
Quiet period
Quiet timer.
Server timeout
Server timeout timer.
MAC authentication domain specified in system view.
If no authentication domain is specified in system view, this field displays Not configured, use default domain.
Max MAC-auth users
Maximum number of MAC authentication users each card supports.
Number of online MAC authentication users.
Silent MAC users
Information about silent MAC addresses.
MAC address
Silent MAC address.
VLAN ID
ID of the VLAN to which the silent MAC address belongs.
From port
Name of the port that marks the MAC address as a silent MAC address.
Port index
Index of the port that marks the MAC address as a silent MAC address.
Status of the link on port GigabitEthernet 1/0/1. In this example, the link is up.
MAC authentication
Whether MAC authentication is enabled on the port.
Carry User-IP
Whether to carry user IP addresses in MAC authentication requests.
MAC authentication domain specified for the port.
Auth-delay timer
Status of MAC authentication delay:
·     Enabled.
·     Disabled.
Auth-delay period
MAC authentication delay timer.
Whether to log off online users or keep them online when no server is reachable for MAC reauthentication.
Guest VLAN
MAC authentication guest VLAN configured on the port.
If no MAC authentication guest VLAN is configured, this field displays Not configured.
Authentication interval for users in the MAC authentication guest VLAN on the port.
Critical VLAN
MAC authentication critical VLAN configured on the port.
If no MAC authentication critical VLAN is configured, this field displays Not configured.
Critical voice VLAN
Whether the MAC authentication critical voice VLAN is enabled on the port.
Host mode
If multi-VLAN mode is disabled, this field displays Single VLAN.
If multi-VLAN mode is enabled, this field displays Multiple VLAN.
Offline detection
Status of MAC authentication offline detection:
·     Enabled.
·     Disabled.
If parallel processing of MAC authentication and 802.1X authentication is disabled, this filed displays Default.
If parallel processing of MAC authentication and 802.1X authentication is enabled, this filed displays Parallel.
Max online users
Maximum number of concurrent online users allowed on the port.
Authentication attempts: successful 1, failed 0
MAC authentication statistics, including the number of successful and unsuccessful authentication attempts.
MAC address
MAC address of the online user.
Auth state
User status:
·     Authenticated—The user has passed MAC authentication.
·     Unauthenticated—The user failed MAC authentication.
display mac-authentication connection
Use display mac-authentication connection to display information about online MAC authentication users.
In standalone mode:
display mac-authentication connection [ interface interface-type interface-number | slot slot-number | user-mac mac-addr | user-name user-name ]
In IRF mode:
display mac-authentication connection [ chassis chassis-number slot slot-number | interface interface-type interface-number | user-mac mac-addr | user-name user-name ]
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. (In IRF mode.)
user-mac mac-addr: Specifies an online MAC authentication user by MAC address. The mac-addr argument represents the MAC address of the user, in the form of H-H-H.
user-name user-name: Specifies an online MAC authentication user by username. The user name is a case-sensitive string of 1 to 55 characters, and it can include the domain name.
If you do not specify any parameters, this command displays information about online MAC authentication users for all cards. (In standalone mode.)
On an IRF fabric, this command displays information about online MAC authentication users for all cards if you do not specify any parameters. On an IRF 3 system, this command displays information about online MAC authentication users for all cards and PEXs if you do not specify any parameters. (In IRF mode.)
# (In standalone mode.) Display information about all online MAC authentication users.
Slot ID: 0
Username: ias
Authentication domain: h3c
Initial VLAN: 1
Authorization ACL ID: 3001
Session timeout period: 2 s
Online from: 2013/03/02  13:14:15
Online duration: 0h 2m 15s
Total 1 connection(s) matched.
# (In IRF mode.) Display information about all online MAC authentication users.
Chassis ID: 1
Slot ID: 0
Username: ias
Initial VLAN: 1
Chassis ID
Member ID of the IRF member device or virtual chassis number of the PEX. (In IRF mode.)
Slot ID
Slot number of the card or PEX.
User MAC address
MAC address of the user.
Access interface
Interface through which the user accesses the IRF member device or PEX.
MAC authentication domain to which the user belongs.
Initial VLAN
VLAN that holds the user before MAC authentication.
Untagged VLAN authorized to the user.
ACL authorized to the user.
Termination action
Action attribute assigned by the server when the session timeout timer expires.
The following server-assigned action attributes are available:
·     Default—Logs off the online authenticated user when the session timeout timer expires.
·     Radius-request—Reauthenticates the online user when the session timeout timer expires.
If the device performs local authentication, this field displays N/A.
Session timeout timer assigned by the server.
Online from
Time from which the MAC authentication user came online.
Online duration
Online duration of the MAC authentication user.
Total number of online MAC authentication users.
mac-authentication
Use mac-authentication to enable MAC authentication globally or on a port.
Use undo mac-authentication to disable MAC authentication globally or on a port.
mac-authentication
MAC authentication is not enabled globally or on any port.
System view, Layer 2 Ethernet interface view
To use MAC authentication on a port, you must enable the feature both globally and on the port.
# Enable MAC authentication globally.
[Sysname] mac-authentication
# Enable MAC authentication on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication
mac-authentication carry user-ip
Use mac-authentication carry user-ip to include user IP addresses in MAC authentication requests sent to an IMC server.
Use undo mac-authentication carry user-ip to restore the default.
A MAC authentication request does not include the user IP address.
This command takes effect only on MAC authentication users who use static IP addresses. It prevents those users from modifying their IP addresses to access the network. Users who obtain IP addresses through DHCP are not affected.
Do not configure this command together with the mac-authentication guest-vlan command on a port. If both commands are configured, users in the MAC authentication guest VLAN cannot perform a new round of authentication.
# Include user IP addresses in MAC authentication requests on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication carry user-ip
mac-authentication
mac-authentication critical vlan
Use mac-authentication critical vlan to specify the MAC authentication critical VLAN on a port.
Use undo mac-authentication critical vlan to restore the default.
No MAC authentication critical VLAN is specified on a port.
critical-vlan-id: Specifies a VLAN as the MAC authentication critical VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created and is not a super VLAN. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
The MAC authentication critical VLAN accommodates users who fail MAC authentication because all the servers in their ISP domains are unreachable. Users in this critical VLAN can access a limited set of network resources.
The critical VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication user fails local authentication after RADIUS authentication, the user is not assigned to the critical VLAN.
Before you delete a VLAN that has been set as a MAC authentication critical VLAN, use the undo mac-authentication critical vlan command to remove the critical VLAN configuration.
# Configure VLAN 100 as the MAC authentication critical VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication critical vlan 100
·     display mac-authentication
·     reset mac-authentication critical-vlan
mac-authentication critical-voice-vlan
Use mac-authentication critical-voice-vlan to enable the MAC authentication critical voice VLAN on a port.
Use undo mac-authentication critical-voice-vlan to restore the default.
The MAC authentication critical voice VLAN is disabled on a port.
The MAC authentication critical voice VLAN on a port accommodates MAC authentication voice users who have failed authentication because none of the RADIUS servers in their ISP domain are reachable.
Before you enable the MAC authentication critical voice VLAN on the port, make sure the following requirements are met:
·     The port is configured with the voice VLAN.
To configure a voice VLAN on a port, use the voice-vlan enable command (see Layer 2—LAN Switching Command Reference).
·     LLDP is enabled both globally and on the port.
The device uses LLDP to identify voice users. For information about LLDP commands, see Layer 2—LAN Switching Command Reference.
# Enable the MAC authentication critical voice VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication critical-voice-vlan
·     lldp enable (Layer 2—LAN Switching Command Reference)
·     lldp global enable (Layer 2—LAN Switching Command Reference)
·     reset mac-authentication critical-voice-vlan
·     voice-vlan enable (Layer 2—LAN Switching Command Reference)
mac-authentication domain
Use mac-authentication domain to specify a global or port-specific authentication domain.
Use undo mac-authentication domain to restore the default.
No authentication domain is specified for MAC authentication users. The system default authentication domain is used. For more information about the default authentication domain, see the domain default enable command in "AAA commands."
domain-name: Specifies the name of an ISP domain, a case-insensitive string of 1 to 24 characters.
The global authentication domain applies to all MAC authentication-enabled ports. A port-specific authentication domain applies only to the port. You can specify different authentication domains on different ports.
A port chooses an authentication domain for MAC authentication users in the following order:
1.     Authentication domain specified on the port.
2.     Global authentication domain specified in system view.
3.     Default authentication domain.
# Specify domain domain1 as the global MAC authentication domain.
# Specify domain aabbcc as the MAC authentication domain on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication domain aabbcc
·     domain default enable
Use mac-authentication guest-vlan to specify the MAC authentication guest VLAN on a port.
Use undo mac-authentication guest-vlan to restore the default.
No MAC authentication guest VLAN is specified on a port.
guest-vlan-id: Specifies a VLAN as the MAC authentication guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created and is not a super VLAN. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
Do not configure this command together with the mac-authentication carry user-ip command on a port. If both commands are configured, users in the MAC authentication guest VLAN cannot perform a new round of authentication.
Before you delete a VLAN that has been set as a MAC authentication guest VLAN, use the undo mac-authentication guest-vlan command to remove the guest VLAN configuration.
# Configure VLAN 100 as the MAC authentication guest VLAN on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication guest-vlan 100
·     reset mac-authentication guest-vlan
mac-authentication guest-vlan auth-period
Use mac-authentication guest-vlan auth-period to set the interval at which the device authenticates users in the MAC authentication guest VLAN.
Use undo mac-authentication guest-vlan auth-period to restore the default.
The device authenticates users in the MAC authentication guest VLAN every 30 seconds.
period-value: Specifies the authentication interval for users in the MAC authentication guest VLAN. The value range is 1 to 3600, in seconds.
# Set the authentication interval to 150 seconds for users in the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication guest-vlan auth-period 150
·     mac-authentication guest-vlan
mac-authentication host-mode
Use mac-authentication host-mode multi-vlan to enable MAC authentication multi-VLAN mode on a port.
Use undo mac-authentication host-mode to restore the default.
MAC authentication multi-VLAN mode is disabled on a port. When the port receives a packet sourced from an authenticated MAC address in a VLAN not matching the existing MAC-VLAN mapping, the device logs off and reauthenticates the user.
The MAC authentication multi-VLAN mode prevents an authenticated online user from service interruption caused by VLAN changes on a port. When the port receives a packet sourced from the user in a VLAN not matching the existing MAC-VLAN mapping, the device neither logs off the user nor reauthenticates the user. The device creates a new MAC-VLAN mapping for the user, and traffic transmission is not interrupted. The original MAC-VLAN mapping for the user remains on the device until it dynamically ages out. As a best practice, configure this feature on hybrid or trunk ports.
This feature improves transmission of data that is vulnerable to delay and interference. It is typically applicable to IP phone users.
# Enable MAC authentication multi-VLAN mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication host-mode multi-vlan
mac-authentication max-user
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication users on a port.
Use undo mac-authentication max-user to restore the default.
mac-authentication max-user user-number
A port can support a maximum of 4294967295 concurrent MAC authentication users.
user-number: Sets the maximum number of concurrent MAC authentication users on the port. The value range for this argument is 1 to 4294967295.
# Configure port GigabitEthernet 1/0/1 to support a maximum of 32 concurrent MAC authentication users.
[Sysname-GigabitEthernet1/0/1] mac-authentication max-user 32
mac-authentication offline-detect enable
Use mac-authentication offline-detect enable to enable MAC authentication offline detection on a port.
Use undo mac-authentication offline-detect enable to disable MAC authentication offline detection.
MAC authentication offline detection is enabled on a port.
This command allows the device to log out a user if the device does not receive any packets from the user within the offline detect timer. The device also requests to stop accounting for the user at the same time. To set the offline detect timer, use the mac-authentication timer command.
The undo mac-authentication offline-detect enable command disables the device from inspecting the online user status.
# Disable MAC authentication offline detection on the port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo mac-authentication offline-detect enable
mac-authentication parallel-with-dot1x
Use mac-authentication parallel-with-dot1x to enable parallel processing of MAC authentication and 802.1X authentication on a port.
Use undo mac-authentication parallel-with-dot1x to restore the default.
Parallel processing of MAC authentication and 802.1X authentication is disabled on a port.
This command enables a port that processes MAC authentication after 802.1X authentication is finished to process MAC authentication in parallel with 802.1X authentication.
When the port receives a packet from an unknown MAC address, it sends a unicast EAP-Request/Identity packet to the MAC address to initiate 802.1X authentication. After that, the port immediately processes MAC authentication without waiting for the 802.1X authentication result.
When you configure this command on a port, follow these restrictions and guidelines:
·     Make sure the port meets the following requirements:
¡     The port is configured with both 802.1X authentication and MAC authentication and performs MAC-based access control for 802.1X authentication.
¡     The port is enabled with the 802.1X unicast trigger.
·     For the port to perform MAC authentication before it is assigned to the 802.1X guest VLAN, use the dot1x guest-vlan-delay new-mac command to delay assigning the port to the 802.1X guest VLAN.
For information about the dot1x guest-vlan-delay new-mac command, see "802.1X commands."
·     Do not enable MAC authentication delay on the port. This operation will delay MAC authentication after 802.1X authentication is triggered.
·     To configure both 802.1X authentication and MAC authentication on the port, use one of the following methods:
¡     Enable the 802.1X and MAC authentication features separately on the port.
¡     Enable port security on the port. The port security mode must be userlogin-secure-or-mac or userlogin-secure-or-mac-ext.
For information about port security mode configuration, see port security in Security Configuration Guide.
# Enable parallel processing of MAC authentication and 802.1X authentication on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication parallel-with-dot1x
mac-authentication re-authenticate server-unreachable keep-online
Use mac-authentication re-authenticate server-unreachable keep-online to enable the keep-online feature on a port. This feature keeps authenticated MAC authentication users online when no server is reachable for MAC reauthentication.
Use undo mac-authentication re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online MAC authentication users if no server is reachable for MAC reauthentication.
This command takes effect only after the server assigns the Radius-request action attribute to the authenticated MAC authentication user (see "display mac-authentication connection"). The access device will reauthenticate the user when the session timeout timer expires.
# Enable the keep-online feature for authenticated MAC authentication users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-authentication re-authenticate server-unreachable keep-online
Use mac-authentication timer to set the MAC authentication timers.
Use undo mac-authentication timer to restore the defaults.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
undo mac-authentication timer { offline-detect | quiet | server-timeout }
The offline detect timer is 300 seconds, the quiet timer is 60 seconds, and the server timeout timer is 100 seconds.
offline-detect offline-detect-value: Sets the offline detect timer in the range of 60 to 2147483647, in seconds.
quiet quiet-value: Sets the quiet timer in the range of 1 to 3600, in seconds.
server-timeout server-timeout-value: Sets the server timeout timer in the range of 100 to 300, in seconds.
MAC authentication uses the following timers:
·     Offline detect timer—Sets the interval that the device waits for traffic from a user before the device regards the user idle. Whether the device logs the user out and requests to stop accounting for the user after the timer expires depending on the status of the offline detection feature.
·     Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user who has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
·     Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device regards the RADIUS server unavailable. If the timer expires during MAC authentication, the user cannot access the network.
# Set the server timeout timer to 150 seconds.
mac-authentication timer auth-delay
Use mac-authentication timer auth-delay to enable MAC authentication delay and set the delay time.
Use undo mac-authentication timer auth-delay to restore the default.
mac-authentication timer auth-delay time
MAC authentication delay is disabled.
time: Sets the delay time for MAC authentication in seconds. The value range is 1 to 180.
When both 802.1X authentication and MAC authentication are enabled on a port, you can delay MAC authentication so that 802.1X authentication is preferentially triggered. If no 802.1X authentication is triggered or if 802.1X authentication fails within the delay period, the port continues to process MAC authentication.
Do not set the port security mode to mac-else-userlogin-secure or mac-else-userlogin-secure-ext when you want to use MAC authentication delay. The delay does not take effect on a port in either of the two modes. For more information about port security modes, see "Port security commands."
# Enable MAC authentication delay on interface GigabitEthernet 1/0/1, and set the delay time to 10 seconds.
[Sysname-GigabitEthernet1/0/1] mac-authentication timer auth-delay 10
·     port-security port-mode
mac-authentication user-name-format
Use mac-authentication user-name-format to configure the type of user accounts for MAC authentication users.
Use undo mac-authentication user-name-format to restore the default.
mac-authentication user-name-format { fixed [ account name ] [ password { cipher | simple } password ] | mac-address [ { with-hyphen | without-hyphen } [ lowercase | uppercase ] ] }
Each user's MAC address is used as the username and password for MAC authentication. A MAC address is in the hexadecimal notation without hyphens, and letters are in lower case.
fixed: Uses a shared account for all MAC authentication users.
account name: Specifies the username for the shared account. The name takes a case-sensitive string of 1 to 55 characters, excluding the at sign (@). If you do not specify a username, the default name mac applies.
password: Specifies the password for the shared user account:
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Specifies the password. This argument is case sensitive.
·     If the simple keyword is specified, the password must be a string of 1 to 117 characters.
·     If the cipher keyword is specified, the password must be a ciphertext string of 1 to 88 characters.
mac-address: Uses MAC-based user accounts for MAC authentication users. You can also specify the format of username and password by using the following keywords:
·     with-hyphen: Includes hyphens in the MAC address, for example xx-xx-xx-xx-xx-xx.
·     without-hyphen: Excludes hyphens from the MAC address, for example, xxxxxxxxxxxx.
·     lowercase: Enters letters in lower case.
·     uppercase: Enters letters in upper case.
If you specify the MAC-based user account, the device uses the MAC address of a user as the username and password for MAC authentication of the user. This user account type ensures high authentication security. However, you must create on the authentication server a user account for each user, using the MAC address of the user as both the username and password.
If you specify a shared user account, the device uses the specified username and password for MAC authentication of all users. Because all MAC authentication users use a single account for authentication, you only need to create one account on the authentication server. This user account type is suitable for trusted networks.
For security purposes, all passwords, including passwords configured in plain text, are saved in cipher text.
# Configure a shared account for MAC authentication users, set the username as abc and password as plaintext string of xyz.
# Use MAC-based user accounts for MAC authentication users. Each MAC address must be in the hexadecimal notation with hyphens, and letters are in upper case.
[Sysname] mac-authentication user-name-format mac-address with-hyphen uppercase
Use reset mac-authentication critical-vlan to remove users from the MAC authentication critical VLAN on a port.
reset mac-authentication critical-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
·     mac-authentication critical vlan
Use reset mac-authentication critical-voice-vlan to remove MAC authentication users from the MAC authentication critical voice VLAN on a port.
reset mac-authentication critical-voice-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies a user by its MAC address. If you do not specify this option, the command removes all users from the MAC authentication critical voice VLAN on the port.
# Remove the user with MAC address 1-1-1 from the MAC authentication critical voice VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication critical-voice-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
·     mac-authentication critical-voice-vlan
Use reset mac-authentication guest-vlan to remove users from the MAC authentication guest VLAN on a port.
# Remove the user with MAC address 1-1-1 from the MAC authentication guest VLAN on GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication guest-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
reset mac-authentication statistics
Use reset mac-authentication statistics to clear MAC authentication statistics.
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command clears all global and port-specific MAC authentication statistics.
# Clear MAC authentication statistics on port GigabitEthernet 1/0/1.
<Sysname> reset mac-authentication statistics interface gigabitethernet 1/0/1
