10-Security Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10010-Security Command Reference
09-PKI commands
09-PKI commands 217.36 KB
PKI commands
attribute
Use attribute to configure a rule to filter certificates based on an attribute in the certificate issuer name, subject name, or alternative subject name field.
Use undo attribute to remove an attribute rule.
attribute id { alt-subject-name { fqdn | ip } | { issuer-name | subject-name } { dn | fqdn | ip } } { ctn | equ | nctn | nequ } attribute-value
undo attribute id
No attribute rules exist.
Certificate attribute group view
id: Specifies a rule ID in the range of 1 to 16.
alt-subject-name: Specifies the alternative subject name.
fqdn: Specifies an FQDN of the PKI entity.
ip: Specifies an IP address of the PKI entity.
dn: Specifies the DN of the PKI entity.
issuer-name: Specifies the issuer name.
subject-name: Specifies the subject name.
ctn: Specifies the contain operation.
equ: Specifies the equal operation.
nctn: Specifies the not-contain operation.
nequ: Specifies the not-equal operation.
attribute-value: Sets an attribute value, a case-insensitive string of 1 to 128 characters.
The issuer name, subject name, and alternative subject name field can contain the following attributes in a certificate:
·     Each subject name and the issuer name can contain a single DN, multiple FQDNs, and multiple IP addresses.
·     The alternative subject name can contain multiple FQDNs and IP addresses but zero DNs.
An attribute rule is a combination of an attribute-value pair with an operation keyword, as listed in Table 1.
Table 1 Combinations of attribute-value pairs and operation keywords
Operation
DN
FQDN/IP
ctn
The DN contains the specified attribute value.
Any FQDN or IP address contains the specified attribute value.
nctn
The DN does not contain the specified attribute value.
None of the FQDNs or IP addresses contain the specified attribute value.
equ
The DN is the same as the specified attribute value.
Any FQDN or IP address is the same as the specified attribute value.
nequ
The DN is not the same as the specified attribute value.
None of the FQDNs or IP addresses are the same as the specified attribute value.
A certificate matches an attribute rule only if it contains an attribute that matches the criterion defined in the rule. For example, an attribute rule defines a criterion that the DN of the subject name contains the abc string. All certificates that have the DN in the subject name containing the abc string match the rule.
A certificate matches an attribute group if it matches all attribute rules in the group.
# Create a certificate attribute group and enter its view.
[Sysname] pki certificate attribute-group mygroup
# Specify an attribute rule to match certificates that contain the abc string in the subject DN.
[Sysname-pki-cert-attribute-group-mygroup] attribute 1 subject-name dn ctn abc
# Specify an attribute rule to match certificates that do not contain FQDN abc in the issuer name field.
[Sysname-pki-cert-attribute-group-mygroup] attribute 2 issuer-name fqdn nequ abc
# Specify an attribute rule to match certificates that do not contain IP address 10.0.0.1 in the alternative subject name field.
[Sysname-pki-cert-attribute-group-mygroup] attribute 3 alt-subject-name ip nequ 10.0.0.1
·     display pki certificate attribute-group
·     rule
ca identifier
Use ca identifier to specify the trusted CA.
Use undo ca identifier to remove the trusted CA.
ca identifier name
undo ca identifier
No trusted CA is specified.
PKI domain view
name: Specifies the name of the trusted CA, a case-sensitive string of 1 to 63 characters.
To obtain a CA certificate, you must specify the trusted CA name. The trusted CA name uniquely identifies the CA to be used if multiple CAs exist on the same CA server. The CA server's URL is specified by using the certificate request url command.
When you use this command, make sure the specified CA name is consistent with the name of the CA that owns the CA certificate to be obtained.
# Specify new-ca as the trusted CA.
[Sysname] pki domain aaa
[Sysname-pki-domain-aaa] ca identifier new-ca
certificate request entity
Use certificate request entity to specify the PKI entity for certificate request.
Use undo certificate request entity to remove the PKI entity for certificate request.
certificate request entity entity-name
No PKI entity is specified for certificate request.
PKI domain view
entity-name: Specifies a PKI entity by its name, a case-insensitive string of 1 to 31 characters.
A PKI entity describes the identity attributes of an entity for certificate request, including the following information:
·     Common name.
·     Organization.
·     Unit in the organization.
·     Locality.
·     State and country where the entity resides.
·     FQDN.
·     IP address.
You can specify only one PKI entity for a PKI domain. If you configure this command for a PKI domain multiple times, the most recent configuration takes effect.
# Specify PKI entity en1 for certificate request in PKI domain aaa.
[Sysname-pki-domain-aaa] certificate request entity en1
pki entity
certificate request from
Use certificate request from to specify the type of certificate request reception authority.
Use undo certificate request from to remove the configuration.
certificate request from { ca | ra }
The type of certificate request reception authority is not specified.
PKI domain view
ca: Specifies the CA to accept certificate requests.
ra: Specifies the RA to accept certificate requests.
The CA server determines whether CA or RA accepts certificate requests. This authority setting must be consistent with the setting on the CA server.
# Specify the RA to accept certificate requests.
[Sysname-pki-domain-aaa] certificate request from ra
certificate request mode
Use certificate request mode to set the certificate request mode.
Use undo certificate request mode to restore the default.
certificate request mode { auto [ password { cipher | simple } password ] | manual }
The certificate request mode is manual.
PKI domain view
auto: Specifies the auto certificate request mode.
password: Specifies a password for certificate revocation as required by the CA policy.
cipher: Sets a ciphertext password for certificate revocation.
simple: Sets a plaintext password for certificate revocation. For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
password: Specifies the password string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 31 characters. If cipher is specified, it must be a ciphertext string of 1 to 73 characters.
manual: Specifies the manual certificate request mode.
A certificate request can be submitted to a CA in offline or online mode. In online mode, a certificate request can be automatically or manually submitted:
·     Auto request mode—A PKI entity automatically obtains the CA certificate and submits a certificate request to the CA when both of the following conditions exist:
¡     A PKI-based application performs identity authentication.
¡     No certificate is available for the application on the device.
·     Manual request mode—You must manually obtain the CA certificate and submit certificate requests.
# Set the certificate request mode to auto.
[Sysname-pki-domain-aaa] certificate request mode auto
# Set the certificate request mode to auto, and set the certificate revocation password in plain text to 123456.
[Sysname-pki-domain-aaa] certificate request mode auto password simple 123456
pki request-certificate
certificate request polling
Use certificate request polling to set the polling interval and the maximum number of attempts to query certificate request status.
Use undo certificate request polling to restore the defaults.
certificate request polling { count count | interval minutes }
undo certificate request polling { count | interval }
The polling interval is 20 minutes, and the maximum number of attempts is 50.
PKI domain view
count count: Sets the maximum number of attempts to query certificate request status. The value range is 1 to 100.
interval minutes: Sets a polling interval in minutes, in the range of 5 to 168.
After a PKI entity submits a certificate request, it might take the CA server a while to issue the certificate if the CA administrator manually approves the certificate request. During this period, the PKI entity periodically queries the CA server for the certificate request status. The periodic query operation stops until the PKI entity obtains the certificate or the maximum number of query attempts is reached. If the maximum number of query attempts is reached, the certificate request fails.
If the CA server automatically approves a certificate request, the PKI entity can obtain the certificate immediately after it submits a certificate request. In this case, the PKI entity does not send queries to the CA server.
# Set the polling interval to 15 minutes, and the maximum number of query attempts to 40.
[Sysname-pki-domain-aaa] certificate request polling interval 15
[Sysname-pki-domain-aaa] certificate request polling count 40
display pki certificate request-status
Use certificate request url to specify the URL of the certificate request reception authority (CA or RA) to which the device should send SCEP certificate requests.
Use undo certificate request url to remove the configuration.
certificate request url url-string [ vpn-instance vpn-instance-name ]
The URL of the certificate request reception authority is not specified.
PKI domain view
url-string: Specifies the URL of the certificate request reception authority, a case-sensitive string of 1 to 511 characters. The URL length is restricted by the CLI string limitation or the url-string parameter, whichever is smaller.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the certificate request reception authority server belongs. A VPN instance name is a case-sensitive string of 1 to 31 characters. If the certificate request reception authority server is on the public network, do not specify this option.
The URL is in the format http://server_location/ca_script_location, where:
·     The server_location argument is the IPv4 address, IPv6 address, or domain name of the certificate request reception authority (CA or RA) server.
·     The cgi_script_location argument is the path of the application script on the server.
# Specify http://169.254.0.100/certsrv/mscep/mscep.dll as the URL where the device should send certificate requests.
[Sysname-pki-domain-aaa] certificate request url http://169.254.0.100/certsrv/mscep/mscep.dll
# Specify http://mytest.net/certsrv/mscep/mscep.dll in VPN instance vpn1 as the URL where the device should send certificate requests.
[Sysname-pki-domain-aaa] certificate request url http:// mytest.net /certsrv/mscep/mscep.dll vpn-instance vpn1
common-name
Use common-name to set the common name for a PKI entity.
Use undo common-name to remove the configuration.
common-name common-name-sting
undo common-name
No common name is set for a PKI entity.
PKI entity view
common-name-sting: Specifies a common name, a case-sensitive string of 1 to 63 characters. No comma can be included. You can set the username of the PKI entity as the common name.
# Specify test as the common name of PKI entity en.
[Sysname] pki entity en
[Sysname-pki-entity-en] common-name test
country
Use country to set the country code of a PKI entity.
Use undo country to remove the configuration.
country country-code-string
undo country
No country code is set for a PKI entity.
PKI entity view
country-code-string: Specifies a country code, a case-sensitive string of two characters. For example, CN is the country code for China.
# Specify CN as the country code of PKI entity en.
[Sysname-pki-entity-en] country CN
crl check
Use crl check enable to enable CRL checking.
Use undo crl check enable to disable CRL checking.
crl check enable
CRL checking is enabled.
PKI domain view
A CA signs and publishes a list of revoked certificates, which is called CRL. Revoked certificates should no longer be trusted.
CRL checking is designed to check whether a certificate has been revoked.
# Disable CRL checking.
[Sysname-pki-domain-aaa] undo crl check enable
·     pki import
·     pki retrieve-certificate
·     pki validate-certificate
crl url
Use crl url to specify the URL of the CRL repository.
Use undo crl url to remove the configuration.
crl url url-string [ vpn-instance vpn-instance-name ]
undo crl url
The URL of the CRL repository is not specified.
PKI domain view
url-string: Specifies the URL of the CRL repository, a case-sensitive string of 1 to 511 characters. The URL format is ldap://server_location or http://server_location, where server_location can be an IP address or a domain name. The URL length is restricted by the CLI string limitation or the url-string parameter, whichever is smaller.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the CRL repository is on the public network, do not specify this option.
To use CRL checking, a CRL must be obtained from a CRL repository.
The device selects a CRL repository in the following order:
1.     CRL repository specified in the PKI domain by using this command.
2.     CRL repository in the certificate that is being verified.
3.     CRL repository in the CA certificate or CRL repository in the upper-level CA certificate if the CA certificate is the certificate being verified.
After the previous selection process, if the CRL repository is not found, the device obtains the CRL through SCEP. In this scenario, the CA certificate and the local certificates must have been obtained.
If an LDAP URL is specified, the device must connect to the LDAP server to obtain the CRL. If the LDAP server's host name is not included in the URL, the device can get the complete URL information based on the LDAP server address specified in the PKI domain.
# Specify http://169.254.0.30 as the URL of the CRL repository.
[Sysname-pki-domain-aaa] crl url http://169.254.0.30
# Specify ldap://169.254.0.30 in VPN instance vpn1 as the URL of the CRL repository.
[Sysname] pki domain 1
[Sysname-pki-domain-1] crl url ldap://169.254.0.30 vpn-instance vpn1
·     ldap-server
·     pki retrieve-crl
display pki certificate access-control-policy
Use display pki certificate access-control-policy to display information about certificate-based access control policies.
display pki certificate access-control-policy [ policy-name ]
policy-name: Specifies a certificate-based access control policy by its name, a case-insensitive string of 1 to 31 characters.
If you do not specify a policy name, this command displays information about all certificate-based access control policies.
# Display information about certificate-based access control policy mypolicy.
<Sysname> display pki certificate access-control-policy mypolicy
 Access control policy name: mypolicy
     Rule 1  deny    mygroup1
     Rule 2  permit  mygroup2
# Display information about all certificate-based access control policies.
 Total PKI certificate access control policies: 2
 Access control policy name: mypolicy1
 Access control policy name: mypolicy2
     Rule 1  deny    mygroup3
     Rule 2  permit  mygroup4
Total number of certificate-based access control policies.
permit
A certificate passes the check and is considered valid if it matches all attribute rules in the attribute group associated with the access control rule.
deny
A certificate fails the check and is considered invalid if it matches all attribute rules in the attribute group associated with the access control rule.
·     pki certificate access-control-policy
·     rule
Use display pki certificate attribute-group to display information about certificate attribute groups.
display pki certificate attribute-group [ group-name ]
group-name: Specifies a certificate attribute group by its name, a case-insensitive string of 1 to 31 characters.
If you do not specify a certificate attribute group, this command displays information about all certificate attribute groups.
# Display information about certificate attribute group mygroup.
<Sysname> display pki certificate attribute-group mygroup
 Attribute group name: mygroup
      Attribute  1 subject-name     dn    ctn   abc
      Attribute  2 issuer-name      fqdn  nctn  app
# Display information about all certificate attribute groups.
 Total PKI certificate attribute groups: 2.
 Attribute group name: mygroup1
Attribute group name: mygroup2
      Attribute  1 subject-name     dn    ctn   def
      Attribute  2 issuer-name      fqdn  nctn  fqd
Total number of certificate attribute groups.
ctn
Contain operation.
nctn
Not-contain operation.
equ
Equal operation.
nequ
Not-equal operation.
Attribute rule contents:
·     alt-subject-name—Alternative subject name.
·     issuer-name—Certificate issuer name.
·     subject-name—Certificate subject name.
·     fqdn—FQDN of the PKI entity.
·     ip—IP address of the PKI entity.
·     dn—DN of the PKI entity.
·     ctn—Indicates the contain operation.
·     equ—Indicates the equal operation.
·     nctn—Indicates the not-contain operation.
·     nequ—Indicates the not-equal operation.
·     attribute
·     pki certificate attribute-group
display pki certificate domain
Use display pki certificate domain to display information about certificates.
display pki certificate domain domain-name { ca | local | peer [ serial serial-num ] }
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 4.
Table 4 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
ca: Specifies the CA certificate.
local: Specifies the local certificates.
peer: Specifies the peer certificates.
serial serial-num: Specifies the serial number of a peer certificate.
If you specify the CA keyword, this command displays information about all CA certificates in the domain. If the domain has RA certificates, the RA certificates are also displayed.
If you specify the local keyword, this command displays information about all local certificates in the domain.
If you do not specify a serial number when using the peer keyword, this command displays brief information about all peer certificates. If you specify a serial number, this command display detailed information about the specified peer certificate.
# Display information about the CA certificate in PKI domain aaa.
<Sysname> display pki certificate domain aaa ca
Certificate:
    Data:
        Version: 1 (0x0)
        Serial Number:
            5c:72:dc:c4:a5:43:cd:f9:32:b9:c1:90:8f:dd:50:f6
        Signature Algorithm: sha1WithRSAEncryption
        Issuer: C=cn, O=docm, OU=rnd, CN=rootca
        Validity
            Not Before: Jan  6 02:51:41 2011 GMT
            Not After : Dec  7 03:12:05 2013 GMT
        Subject: C=cn, O=ccc, OU=test, CN=rootca
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (1024 bit)
                Modulus:
                    00:c4:fd:97:2c:51:36:df:4c:ea:e8:c8:70:66:f0:
                    28:98:ec:5a:ee:d7:35:af:86:c4:49:76:6e:dd:40:
                    4a:9e:8d:c0:cb:d9:10:9b:61:eb:0c:e0:22:ce:f6:
                    57:7c:bb:bb:1b:1d:b6:81:ad:90:77:3d:25:21:e6:
                    7e:11:0a:d8:1d:3c:8e:a4:17:1e:8c:38:da:97:f6:
                    6d:be:09:e3:5f:21:c5:a0:6f:27:4b:e3:fb:9f:cd:
                    c1:91:18:ff:16:ee:d8:cf:8c:e3:4c:a3:1b:08:5d:
                    84:7e:11:32:5f:1a:f8:35:25:c0:7e:10:bd:aa:0f:
                    52:db:7b:cd:5d:2b:66:5a:fb
                Exponent: 65537 (0x10001)
        6d:b1:4e:d7:ef:bb:1d:67:53:67:d0:8f:7c:96:1d:2a:03:98:
        3b:48:41:08:a4:8f:a9:c1:98:e3:ac:7d:05:54:7c:34:d5:ee:
        09:5a:11:e3:c8:7a:ab:3b:27:d7:62:a7:bb:bc:7e:12:5e:9e:
        4c:1c:4a:9f:d7:89:ca:20:46:de:c5:b3:ce:36:ca:5e:6e:dc:
        e7:c6:fe:3f:c5:38:dd:d5:a3:36:ad:f4:3d:e6:32:7f:48:df:
        07:f0:a2:32:89:86:72:22:cd:ed:e5:0f:95:df:9c:75:71:e7:
        fe:34:c5:a0:64:1c:f0:5c:e4:8f:d3:00:bd:fa:90:b6:64:d8:
        88:a6
# Display information about local certificates in PKI domain aaa.
<Sysname> display pki certificate domain aaa local
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            bc:05:70:1f:0e:da:0d:10:16:1e
        Signature Algorithm: sha256WithRSAEncryption
        Issuer: C=CN, O=sec, OU=software, CN=user
        Validity
            Not Before: Jan  7 20:05:44 2011 GMT
            Not After : Jan  7 20:05:44 2012 GMT
        Subject: O=OpenCA Labs, OU=Users, CN=fips fips-sec
                Modulus:
                    00:b2:38:ad:8c:7d:78:38:37:88:ce:cc:97:17:39:
                    52:e1:99:b3:de:73:8b:ad:a8:04:f9:a1:f9:0d:67:
                    d8:95:e2:26:a4:0b:c2:8c:63:32:5d:38:3e:fd:b7:
                    4a:83:69:0e:3e:24:e4:ab:91:6c:56:51:88:93:9e:
                    12:a4:30:ad:ae:72:57:a7:ba:fb:bc:ac:20:8a:21:
                    46:ea:e8:93:55:f3:41:49:e9:9d:cc:ec:76:13:fd:
                    a5:8d:cb:5b:45:08:b7:d1:c5:b5:58:89:47:ce:12:
                    bd:5c:ce:b6:17:2f:e0:fc:c0:3e:b7:c4:99:31:5b:
                    8a:f0:ea:02:fd:2d:44:7a:67
        X509v3 extensions:
            X509v3 Basic Constraints:
                CA:FALSE
            Netscape Cert Type:
                SSL Client, S/MIME
            X509v3 Key Usage:
                Digital Signature, Non Repudiation, Key Encipherment
            X509v3 Extended Key Usage:
                TLS Web Client Authentication, E-mail Protection, Microsoft Smartcardlogin
            Netscape Comment:
                User Certificate of OpenCA Labs
            X509v3 Subject Key Identifier:
                91:95:51:DD:BF:4F:55:FA:E4:C4:D0:10:C2:A1:C2:99:AF:A5:CB:30
            X509v3 Authority Key Identifier:
                keyid:DF:D2:C9:1A:06:1F:BC:61:54:39:FE:12:C4:22:64:EB:57:3B:11:9F
            X509v3 Subject Alternative Name:
                email:[email protected]
            X509v3 Issuer Alternative Name:
            Authority Information Access:
                CA Issuers - URI:http://titan/pki/pub/cacert/cacert.crt
                OCSP - URI:http://titan:2560/
                1.3.6.1.5.5.7.48.12 - URI:http://titan:830/
            X509v3 CRL Distribution Points:
                Full Name:
                  URI:http://titan/pki/pub/crl/cacrl.crl
        94:ef:56:70:48:66:be:8f:9d:bb:77:0f:c9:f4:65:77:e3:bd:
        ea:9a:b8:24:ae:a1:38:2d:f4:ab:e8:0e:93:c2:30:33:c8:ef:
        f5:e9:eb:9d:37:04:6f:99:bd:b2:c0:e9:eb:b1:19:7e:e3:cb:
        95:cd:6c:b8:47:e2:cf:18:8d:99:f4:11:74:b1:1b:86:92:98:
        af:a2:34:f7:1b:15:ee:ea:91:ed:51:17:d0:76:ec:22:4c:56:
        da:d6:d1:3c:f2:43:31:4f:1d:20:c8:c2:c3:4d:e5:92:29:ee:
        43:c6:d7:72:92:e8:13:87:38:9a:9c:cd:54:38:b2:ad:ba:aa:
        f9:a4:68:b5:2a:df:9a:31:2f:42:80:0c:0c:d9:6d:b3:ab:0f:
        dd:a0:2c:c0:aa:16:81:aa:d9:33:ca:01:75:94:92:44:05:1a:
        65:41:fa:1e:41:b5:8a:cc:2b:09:6e:67:70:c4:ed:b4:bc:28:
        04:50:a6:33:65:6d:49:3c:fc:a8:93:88:53:94:4c:af:23:64:
        cb:af:e3:02:d1:b6:59:5f:95:52:6d:00:00:a0:cb:75:cf:b4:
        50:c5:50:00:65:f4:7d:69:cc:2d:68:a4:13:5c:ef:75:aa:8f:
        3f:ca:fa:eb:4d:d5:5d:27:db:46:c7:f4:7d:3a:b2:fb:a7:c9:
        de:18:9d:c1
# Display brief information about all peer certificates in PKI domain aaa.
<Sysname> display pki certificate domain aaa peer
Total peer certificates: 1
Serial Number: 9a0337eb2156ba1f5476e4d754a5a9f7
Subject  Name: CN=sldsslserver
# Display detailed information about a specific peer certificate in PKI domain aaa.
<Sysname> display pki certificate domain aaa peer serial 9a0337eb2156ba1f5476e4d754a5a9f7
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            9a:03:37:eb:21:56:ba:1f:54:76:e4:d7:54:a5:a9:f7
        Issuer: C=cn, O=ccc, OU=sec, CN=ssl
        Validity
            Not Before: Oct 15 01:23:06 2010 GMT
            Not After : Jul 26 06:30:54 2012 GMT
        Subject: CN=sldsslserver
                Modulus:
                    00:c2:cf:37:76:93:29:5e:cd:0e:77:48:3a:4d:0f:
                    a6:28:a4:60:f8:31:56:28:7f:81:e3:17:47:78:98:
                    68:03:5b:72:f4:57:d3:bf:c5:30:32:0d:58:72:67:
                    04:06:61:08:3b:e9:ac:53:b9:e7:69:68:1a:23:f2:
                    97:4c:26:14:c2:b5:d9:34:8b:ee:c1:ef:af:1a:f4:
                    39:da:c5:ae:ab:56:95:b5:be:0e:c3:46:35:c1:52:
                    29:9c:b7:46:f2:27:80:2d:a4:65:9a:81:78:53:d4:
                    ca:d3:f5:f3:92:54:85:b3:ab:55:a5:03:96:2b:19:
                    8b:a3:4d:b2:17:08:8d:dd:81
        X509v3 extensions:
                keyid:9A:83:29:13:29:D9:62:83:CB:41:D4:75:2E:52:A1:66:38:3C:90:11
            X509v3 Key Usage: critical
                Digital Signature, Non Repudiation, Key Encipherment, Data Encipherment, Key Agreement
            Netscape Cert Type:
                SSL Server
                DNS:docm.com
                3C:76:95:9B:DD:C2:7F:5F:98:83:B7:C7:A0:F8:99:1E:4B:D7:2F:26
                Full Name:
                  URI:http://s03130.ccc.sec.com:447/ssl.crl
        61:2d:79:c7:49:16:e3:be:25:bb:8b:70:37:31:32:e5:d3:e3:
        31:2c:2d:c1:f9:bf:50:ad:35:4b:c1:90:8c:65:79:b6:5f:59:
        36:24:c7:14:63:44:17:1e:e4:cf:10:69:fc:93:e9:70:53:3c:
        85:aa:40:7e:b5:47:75:0f:f0:b2:da:b4:a5:50:dd:06:4a:d5:
        17:a5:ca:20:19:2c:e9:78:02:bd:19:77:da:07:1a:42:df:72:
        ad:07:7d:e5:16:d6:75:eb:6e:06:58:ee:76:31:63:db:96:a2:
        ad:83:b6:bb:ba:4b:79:59:9d:59:6c:77:59:5b:d9:07:33:a8:
        f0:a5
·     pki domain
Use display pki certificate request-status to display certificate request status.
display pki certificate request-status [ domain domain-name ]
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 5.
Table 5 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
If no PKI domain is specified, this command displays the status of all certificate requests.
# Display certificate request status for PKI domain aaa.
<Sysname> display pki certificate request-status domain aaa
Certificate Request Transaction 1
    Domain name: aaa
    Status: Pending
    Key usage: General
    Remain polling attempts: 10
    Next polling attempt after : 1191 seconds
# Display certificate request statuses for all PKI domains.
    Domain name: domain1
    Status: Pending
    Key usage: General
Certificate Request Transaction 2
    Domain name: domain2
    Status: Pending
    Key usage: Signature
    Next polling attempt after : 188 seconds
Table 6 Command output
Certificate Request Transaction number
Certificate request transaction number, starting from 1.
Status
Certificate request status, including only the pending status.
Key usage
Certificate purposes:
·     GeneralSignature and encryption.
·     Signature—Signature only.
·     Encryption—Encryption only.
Remaining number of attempts to query certificate request status.
Remaining seconds before the next request status polling.
·     certificate request polling
·     pki domain
display pki crl
Use display pki crl domain to display information about the locally saved CRLs.
display pki crl domain domain-name
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 7.
Table 7 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
Use this command to check whether a certificate has been revoked.
# Display information about the CRL saved at the local for PKI domain aaa.
<Sysname> display pki crl domain aaa
Certificate Revocation List (CRL):
        Version 2 (0x1)
        Issuer: /C=cn/O=docm/OU=sec/CN=therootca
        Last Update: Apr 28 01:42:13 2011 GMT
        Next Update: NONE
        CRL extensions:
            X509v3 CRL Number:
                6
                keyid:49:25:DB:07:3A:C4:8A:C2:B5:A0:64:A5:F1:54:93:69:14:51:11:EF
Revoked Certificates:
    Serial Number: CDE626BF7A44A727B25F9CD81475C004
        Revocation Date: Apr 28 01:37:52 2011 GMT
        CRL entry extensions:
            Invalidity Date:
                Apr 28 01:37:49 2011 GMT
    Serial Number: FCADFA81E1F56F43D3F2D3EF7EB56DE5
        Revocation Date: Apr 28 01:33:28 2011 GMT
            Invalidity Date:
                Apr 28 01:33:09 2011 GMT
        57:ac:00:3e:1e:e2:5f:59:62:04:05:9b:c7:61:58:2a:df:a4:
        5c:e5:c0:14:af:c8:e7:de:cf:2a:0a:31:7d:32:da:be:cd:6a:
        36:b5:83:e8:95:06:bd:b4:c0:36:fe:91:7c:77:d9:00:0f:9e:
        99:03:65:9e:0c:9c:16:22:ef:4a:40:ec:59:40:60:53:4a:fc:
        8e:47:57:23:e0:75:0a:a4:1c:0e:2f:3d:e0:b2:87:4d:61:8a:
        4a:cb:cb:37:af:51:bd:53:78:76:a1:16:3d:0b:89:01:91:61:
        52:d0:6f:5c:09:59:15:be:b8:68:65:0c:5d:1b:a1:f8:42:04:
        ba:aa
Table 8 Command output
Version
CRL version number.
Signature Algorithm
Signature algorithm used by the CA to sign the CRL.
Issuer
Name of the CA that issued the CRL.
Last Update
Most recent CRL update time.
Next Update
Next CRL update time.
X509v3 ID of the CA that issues the CRL.
keyid
Key ID.
This field identifies the key pair used to sign the CRL.
Signature algorithm and signature data.
pki retrieve-crl
fqdn
Use fqdn to set the FQDN of an entity.
Use undo fqdn to remove the configuration.
fqdn fqdn-name-string
undo fqdn
No FQDN is set for a PKI entity.
PKI entity view
fqdn-name-string: Specifies an FQDN, a case-sensitive string of 1 to 255 characters in the format hostname@domainname.
An FQDN uniquely identifies a PKI entity on a network.
# Specify pki.domain-name.com as the FQDN of PKI entity en.
[Sysname-pki-entity-en] fqdn [email protected]
ip
Use ip to assign an IP address to a PKI entity.
Use undo ip to remove the configuration.
ip { ip-address | interface interface-type interface-number }
undo ip
No IP address is assigned to the PKI entity.
PKI entity view
ip-address: Specifies an IPv4 address.
interface interface-type interface-number: Specifies an interface by its type and number. The primary IPv4 address of the interface will be used as the IP address of the PKI entity.
Use this command to assign an IP address to a PKI entity or specify an interface whose primary IPv4 address will be used as the IP address for the PKI entity. If you specify an interface, make sure the interface has an IP address before the PKI entity requests a certificate.
# Assign IP address 192.168.0.2 to PKI entity en.
[Sysname-pki-entity-en] ip 192.168.0.2
ldap-server
Use ldap-server to specify an LDAP server for a PKI domain.
Use undo ldap-server to remove the configuration.
ldap-server host hostname [ port port-number ] [ vpn-instance vpn-instance-name ]
undo ldap-server
No LDAP server is specified for a domain.
PKI domain view
host host-name: Specifies an LDAP server by its IPv4 address, IPv6 address, or domain name. The domain name is a case-sensitive string of 1 to 255 characters.
port port-number: Specifies the port number of the LDAP server. The value range is 1 to 65535, and the default is 389.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the LDAP server is on the public network, do not specify this option.
You must specify an LDAP server in a PKI domain in the following situations:
·     An LDAP URL is specified in the PKI domain (by using the crl url command).
·     The specified LDAP URL does not contain the IP address or host name of the LDAP server.
You can specify only one LDAP server in a PKI domain. If you configure this command multiple times, the most recent configuration takes effect.
# Specify an LDAP server 10.0.0.1 for PKI domain aaa.
[Sysname-pki-domain-aaa] ldap-server host 10.0.0.1
# Specify an LDAP server 10.0.0.11 in VPN instance vpn1 for PKI domain aaa. Set the port number to 333.
[Sysname-pki-domain-aaa] ldap-server host 10.0.0.11 port 333 vpn-instance vpn1
·     pki retrieve-crl
locality
Use locality to set the locality of a PKI entity.
Use undo locality to remove the configuration.
locality locality-name
undo locality
No locality is set for a PKI entity.
PKI entity view
locality-name: Specifies a locality, a case-sensitive string of 1 to 63 characters. No comma can be included. You can set a city name as the locality.
# Specify pukras as the locality of PKI entity en.
[Sysname-pki-entity-en] locality pukras
organization
Use organization to set an organization name for a PKI entity.
Use undo organization to remove the configuration.
organization org-name
undo organization
No organization name is set for a PKI entity.
PKI entity view
org-name: Specifies an organization name, a case-sensitive string of 1 to 63 characters. No comma can be included.
# Specify abc as the organization name of PKI entity en.
[Sysname-pki-entity-en] organization abc
organization-unit
Use organization-unit to set an organization unit name for a PKI entity.
Use undo organization-unit to remove the configuration.
organization-unit org-unit-name
No organization unit name is set for a PKI entity.
PKI entity view
org-unit-name: Specifies an organization unit name, a case-sensitive string of 1 to 63 characters. No comma can be included.
# Specify rdtest as the organization unit name for PKI entity en.
[Sysname-pki-entity-en] organization-unit rdtest
pki abort-certificate-request
Use pki abort-certificate-request to abort the certificate request for a PKI domain.
pki abort-certificate-request domain domain-name
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 9.
Table 9 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
You can abort a certificate request and change some parameters, such as common name, country code, or FQDN, in the certificate request before the CA issues the certificate. Use the display pki certificate request-status command to display the certificate request status.
# Abort the certificate request for PKI domain 1.
[Sysname] pki abort-certificate- request domain 1
The certificate request is in process.
Confirm to abort it? [Y/N]:y
·     display pki certificate request-status
·     pki request-certificate domain
Use pki certificate access-control-policy to create a certificate-based access control policy and enter its view.
Use undo pki certificate access-control-policy to remove a certificate-based access control policy.
pki certificate access-control-policy policy-name
undo pki certificate access-control-policy policy-name
No certificate-based access control policies exist.
policy-name: Specifies a policy name, a case-insensitive string of 1 to 31 characters.
Certificate-based access control policies allow you to authorize access to a device (for example, an HTTPS server) based on the attributes of an authenticated client's certificate.
A certificate-based access control policy is a set of access control rules (permit or deny statements), each associated with a certificate attribute group. A certificate attribute group contains multiple attribute rules, each defining a matching criterion for an attribute in the certificate issuer name, subject name, or alternative subject name field.
If a certificate matches all attribute rules in a certificate attribute group associated with an access control rule, the system determines that the certificate matches the access control rule. In this scenario, the match process stops, and the system performs the access control action defined in the access control rule.
# Create a certificate-based access control policy named mypolicy and enter its view.
[Sysname] pki certificate access-control-policy mypolicy
[Sysname-pki-cert-acp-mypolicy]
·     display pki certificate access-control-policy
·     rule
Use pki certificate attribute-group to create a certificate attribute group and enter its view.
Use undo pki certificate attribute-group to remove a certificate attribute group.
pki certificate attribute-group group-name
undo pki certificate attribute-group group-name
No certificate attribute groups exist.
group-name: Specifies a group name, a case-insensitive string of 1 to 31 characters.
A certificate attribute group is a set of attribute rules configured by using the attribute command. Each attribute rule defines a matching criterion for an attribute in the issuer name, subject name, or alternative subject name field of certificates.
A certificate attribute group must be associated with an access control rule (a permit or deny statement configured by using the rule command). If a certificate attribute group does not have any attribute rules, the system determines that the all certificates match the associated access control rule.
# Create a certificate attribute group named mygroup and enter its view.
·     attribute
·     rule
pki delete-certificate
Use pki delete-certificate to remove certificates from a PKI domain.
pki delete-certificate domain domain-name { ca | local | peer [ serial serial-num ] }
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 10.
Table 10 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
serial serial-num: Specifies a peer certificate by its serial number, a case-insensitive string of 1 to 127 characters. If you do not specify a peer certificate, this command removes all peer certificates in the PKI domain.
When you remove the CA certificate in a PKI domain, the system also removes the local certificates, peer certificates, and the CRL in the PKI domain.
# Remove the CA certificate in PKI domain aaa.
[Sysname] pki delete-certificate domain aaa ca
Local certificates, peer certificates and CRL will also be deleted while deleting the CA certificate.
Confirm to delete the CA certificate? [Y/N]:y
[Sysname]
# Remove the local certificates in PKI domain aaa.
[Sysname] pki delete-certificate domain aaa local
[Sysname]
# Remove all peer certificates in PKI domain aaa.
[Sysname] pki delete-certificate domain aaa peer
[Sysname]
# Display information about all peer certificates in PKI domain aaa, and remove a peer certificate with the specified serial number.
[Sysname] display pki certificate domain aaa peer
Subject  Name: CN=abc
[Sysname] pki delete-certificate domain aaa peer serial 9a0337eb2156ba1f5476e4d754a5a9f7
pki domain
Use pki domain to create a PKI domain and enter its view.
Use undo pki domain to remove a PKI domain.
pki domain domain-name
undo pki domain domain-name
No PKI domain exists.
domain-name: Specifies a PKI domain name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 11.
Table 11 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
When you remove a PKI domain, the certificates and the CRL in the domain are also removed.
# Create a PKI domain named aaa and enter its view.
pki entity
Use pki entity to create a PKI entity and enter its view.
Use undo pki entity to remove a PKI entity.
pki entity entity-name
undo pki entity entity-name
No PKI entity exists.
entity-name: Specifies a name for a PKI entity, a case-insensitive string of 1 to 31 characters.
A PKI entity includes the identity information that can be used by a CA to identify a certificate applicant. You can configure multiple attributes for a PKI entity, such as common name, organization, organization unit, locality, state, country, FQDN, and IP address. The information will be included as subject contents in the certificate issued by the CA.
# Create a PKI entity named en and enter its view.
pki domain
pki export
Use pki export to export the CA certificate and the local certificates in a PKI domain to local files or a terminal.
pki export domain domain-name der { all | ca | local } filename filename
pki export domain domain-name p12 { all | local } passphrase p12passwordstring filename filename
pki export domain domain-name pem { { all | local } [ { 3des-cbc | aes-128-cbc | aes-192-cbc | aes-256-cbc | des-cbc } pempasswordstring ] | ca } [ filename filename ]
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 12.
Table 12 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
der: Specifies the certificate file format as DER.
p12: Specifies the certificate file format as PKCS12.
pem: Specifies the certificate file format as PEM.
all: Specifies both CA and local certificates. The RA certificate is excluded.
local: Specifies the local certificates or the local certificates and their private keys.
passphrase p12passwordstring: Specifies a password for encrypting the private key of a local PKCS12 certificate.
3des-cbc: Specifies 3DES_CBC for encrypting the private key of a local certificate.
aes-128-cbc: Specifies 128-bit AES_CBC for encrypting the private key of a local certificate.
aes-192-cbc: Specifies 192-bit AES_CBC for encrypting the private key of a local certificate.
aes-256-cbc: Specifies 256-bit AES_CBC for encrypting the private key of a local certificate.
des-cbc: Specifies DES_CBC for encrypting the private key of a local certificate.
pempasswordstring: Specifies a password for encrypting the private key of a local certificate in PEM format.
filename filename: Specifies a file name for storing a certificate. The file name is a case-insensitive string. If you do not specify a file name for the certificates in PEM format, this command displays the certificates on the terminal.
When you export the CA certificate, the following conditions might exist:
·     If the PKI domain has only one CA certificate, this command exports the CA certificate to a specified file or displays it on the terminal.
·     If the PKI domain has a CA certificate chain, this command exports the certificate chain to a specified file or displays it on the terminal.
When you export the local certificates, the local file names might not be the same as specified in the command. The file names depend on the usage of the key pairs of the certificates. In the following description, the filename is the specified file name in the command.
·     If the key pair of the local certificate is for signing, the local file name is filename-sign.
·     If the key pair of the local certificate is for encryption, the local file name is filename-encr.
·     If the key pair of the local certificate is for general use (RSA, ECDSA, or DSA), the local file name is filename.
If the PKI domain has two local certificates, one of the following results occurs:
·     If you specify a file name, the local certificates are exported to two different files.
·     If you do not specify a file name, the local certificates are displayed on the terminal, separated by the system prompts.
When you export all certificates, the following conditions might exist:
·     If the PKI domain has only the CA certificate or local certificates, the result is the same as when you export the CA certificate or local certificates separately.
·     If the PKI domain has both the CA certificate and the local certificates, you get the following results:
¡     If you specify a file name, each local certificate with its proper CA certificate chain is exported to a separate file.
¡     If you do not specify a file name, all local certificates and the CA certificate or the CA certificate chain are displayed on the terminal, separated by system prompts.
When you export all certificates in PKCS12 format, the PKI domain must have a local certificate. Otherwise, the export operation fails.
When you export the local certificates or all certificates in PEM format, you must specify the cryptographic algorithm and the challenge password for the private key. Otherwise, this command does not export the private keys of the local certificates. If you specify the cryptographic algorithm and the password, and the local certificates have their private keys, this command can export the local certificates with their private keys. If the local certificates do not have their private keys, the export operation fails.
When you export the local certificates, if the key pair in the PKI domain is changed and no longer matches the key in the local certificates, the export operation fails.
When you export the local certificates or all certificates, if the PKI domain has two local certificates, failure of exporting one local certificate does not affect export of the other.
The specified file name can contain an absolute path. If the specified path does not exist, the export operation fails.
# Export the CA certificate in the PKI domain to a file named cert-ca.der in DER format.
[Sysname] pki export domain domain1 der ca filename cert-ca.der
# Export the local certificates in the PKI domain to a file named cert-lo.der in DER format.
[Sysname] pki export domain domain1 der local filename cert-lo.der
# Export all certificates in the PKI domain to a file named cert-all.p7b in DER format.
[Sysname] pki export domain domain1 der all filename cert-all.p7b
# Export the CA certificate in the PKI domain to a file named cacert in PEM format.
[Sysname] pki export domain domain1 pem ca filename cacert
# Export the local certificates and their private keys in the PKI domain to a file named local.pem in PEM format. For the private keys, the cryptographic algorithm is DES_CBC and the password is 111.
[Sysname] pki export domain domain1 pem local des-cbc 111 filename local.pem
# Export the all certificates in the PKI domain to a file named all.pem in PEM format. No cryptographic algorithm or password is specified, and the private keys are not exported.
[Sysname] pki export domain domain1 pem all filename all.pem
# Display the local certificates and their private keys in the PKI domain on the terminal in PEM format. For the private keys, the cryptographic algorithm is DES_CBC and the password is 111.
%The signature usage local certificate:
Bag Attributes
    friendlyName:
    localKeyID: 99 0B C2 3B 8B D1 E4 33 42 2B 31 C3 37 C0 1D DF 0D 79 09 1D
subject=/C=CN/O=OpenCA Labs/OU=Users/CN=chktest chktest
issuer=/C=CN/O=OpenCA Labs/OU=software/CN=abcd
-----BEGIN CERTIFICATE-----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==
-----END CERTIFICATE-----
Bag Attributes
    friendlyName:
Key Attributes: <No Attributes>
-----BEGIN ENCRYPTED PRIVATE KEY-----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-----END ENCRYPTED PRIVATE KEY-----
# Display all certificates in the PKI domain in PEM format. For the private keys, the cryptographic algorithm is DES_CBC and the password is 111.
[Sysname] pki export domain domain1 pem all des-cbc 111
Bag Attributes
    friendlyName:
Bag Attributes: <No Attributes>
subject=/C=CN/O=OpenCA Labs/OU=software/CN=abcd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Bag Attributes
    friendlyName: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# Display the CA certificate in the PKI domain in PEM format.
[Sysname]pki export domain domain1 pem ca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# Display the CA certificate or the CA certificate chain in the PKI domain on the terminal.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MIIB8DCCAVkCEQD2PBUx/rvslNw9uTrZB3DlMA0GCSqGSIb3DQEBBQUAMDoxCzAJ
BgNVBAYTAmNuMQwwCgYDVQQKEwNoM2MxDDAKBgNVBAsTA2gzYzEPMA0GA1UEAxMG
cm9mdcGNhMB4XDTExMDEwNjAyNTY1OFoXDTEzMTIwNDAzMTMxMFowNzELMAkGA1UE
BhMCY24xDDAKBgNVBAoTA2gzYzEMMAoGA1UECxMDaDNjMQwwCgYDVQQDEwNhY2Ew
gZ8wDQYJKoZIhvcNAQEBBQADgY0AMIGJAoGBAOeklR7DpeEV72N1OLz+dydIDTx0
zVZDdPxF1gQYWSfIBwwFKJEyQ/4y8VIfDIm0EGTM4dsOX/QFwudhl/Czkio3dWLh
Q1y5XCJy68vQKrB82WZ2mah5Nuekus3LSZZBoZKTAOY5MCCMFcULM858dtSq15Sh
xF7tKSeAT7ARlJxTAgMBAAEwDQYJKoZIhvcNAQEFBQADgYEADJQCo6m0RNup0ewa
ItX4XK/tYcJXAQWMA0IuwaWpr+ofqVVgYBPwVpYglhJDOuIZxKdR2pfQOA4f35wM
Vz6kAujLATsEA1GW9ACUWa5PHwVgJk9BDEXhKSJ2e7odmrg/iROhJjc1NMV3pvIs
CuFiCLxRQcMGhCNHlOn4wuydssc=
MIIB8jCCAVsCEFxy3MSlQ835MrnBkI/dUPYwDQYJKoZIhvcNAQEFBQAwOjELMAkG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# Export the local certificates and their private keys in the PKI domain to a file named cert-lo.der in PKCS12 format. The password for the private keys is 123.
[Sysname] pki export domain domain1 p12 local passphrase 123 filename cert-lo.der
# Export all certificates in the PKI domain to a file named cert-all.p7b in PKCS12 format.
[Sysname] pki export domain domain1 p12 all passphrase 123 filename cert-all.p7b
pki domain
pki import
Use pki import to import the CA certificate, local certificates, or peer certificates for a PKI domain.
pki import domain domain-name { der { ca | local | peer } filename filename | p12 local filename filename | pem { ca | local | peer } [ filename filename ] }
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 13.
Table 13 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
der: Specifies the certificate format as DER, including PKCS#7.
p12: Specifies the certificate format as PKCS12.
pem: Specifies the certificate format as PEM.
filename filename: Specifies a certificate file name, a case-insensitive string. For a certificate in PEM format, you can also choose to copy and paste the certificate contents on the terminal instead of importing from a file.
Use the command to import the certificates in the following situations:
·     The CRL repository is not specified or the CA server does not support SCEP.
·     Use a certificate that is packed with the server generated key pair in a single file. Only certificate files in PKCS12 or PEM format might contain key pairs.
Before you import the certificates, complete the following tasks:
·     Use FTP or TFTP to upload the certificate files to the storage media of the device. If FTP or TFTP is not available, you can import the certificates by copying and pasting the certificate contents through the terminal. In this case, make sure the certificate is in PEM format because only certificates in PEM format can be imported by this means.
·     For the local certificates or peer certificates to be imported, the proper CA certificate chain must exist. The CA certificate chain can be stored on the device, or carried in the local certificates or peer certificates. If the PKI domain, the local certificates, or the peer certificates do not have the CA certificate chain, you must import the CA certificate first. To import a local or peer certificate, a CA certificate chain must exist in the PKI domain, or be carried in the local or peer certificate. If not, obtain it first.
When you import the local certificates or peer certificates:
·     If the local certificates or peer certificates to be imported contain the CA certificate chain, you can import the CA certificate and the local certificates or peer certificates at the same time. If the certificate of the CA that issues the local certificates or peer certificates already exists in a PKI domain, the system displays a prompt to ask you whether to overwrite the existing CA certificate.
·     If the local certificates or peer certificates to be imported do not contain the CA certificate chain, but the certificate of the CA that issues the local certificate or peer certificate already exists in a PKI domain, you can directly import the local certificates or peer certificates.
When you import the CA certificate:
·     If the CA certificate to be imported is the CA root certificate or contains the certificate chain with the root certificate, you can import the CA certificate.
·     If the CA certificate to be imported contains a certificate chain without the root certificate, but can form a complete certificate chain with the CA certificate on the device, you can import the CA certificate. Otherwise, you cannot import it.
Contact the CA server administrator to get proper information in the following scenarios:
·     If the certificate file to be imported contains the root certificate, but the root certificate and its fingerprint are not specified on the device, the system asks you to confirm the fingerprint.
·     If the local certificate to be imported contains a key pair, the system asks you to enter the challenge password used for encrypting the private key.
When you import a local certificate file that contains a key pair, you can choose to update the domain with the key pair. Depending on the purpose of the key pair, the following conditions might exist:
·     If the purpose of the key pair is general, the device uses the key pair to replace the local key pair that is found in this order: general-purpose key pair, signature key pair, and encryption key pair.
·     If the purpose of the key pair is signature, the device uses the key pair to replace the local key pair that is found in this order: general-purpose key pair and signature key pair.
·     If the purpose of the key pair is encryption, the device searches the domain for an encryption key pair.
If a match is found, the device displays a prompt to ask you whether to overwrite the existing key pair on the device. If no match is found, the device asks you to enter a key pair name (defaulting to the PKI domain name). Then, it generates a proper key pair according to the algorithm and the purpose of the key pair defined in the certificate file.
The import operation automatically updates or generates the proper key pair. When you perform the import operation, be sure to save the configuration file to avoid data loss.
# Import CA certificate file rootca_pem.cer in PEM format to PKI domain aaa. The certificate file contains the root certificate.
[Sysname] pki import domain aaa pem ca filename rootca_pem.cer
The trusted CA's finger print is:
    MD5  fingerprint:FFFF 3EFF FFFF 37FF FFFF 137B FFFF 7535
    SHA1 fingerprint:FFFF FF7F FF2B FFFF 7618 FF4C FFFF 0A7D FFFF FF69
Is the finger print correct?(Y/N):y
[Sysname]
# Import CA certificate file aca_pem.cer in PEM format to PKI domain bbb. The certificate file does not contain the root certificate.
[Sysname] pki import domain bbb pem ca filename aca_pem.cer
[Sysname]
# Import local certificate file local-ca.p12 in PKCS12 format to PKI domain bbb. The certificate file contains a key pair.
[Sysname] pki import domain bbb p12 local filename local-ca.p12
Please input challenge password:
[Sysname]
# Import the local certificate in PEM format to PKI domain bbb by copying and pasting the contents of the certificate. The certificate contains the key pair and the CA certificate chain.
[Sysname] pki import domain bbb pem local
Enter PEM-formatted certificate.
End with a Ctrl+c on a line by itself.
Bag Attributes
localKeyID: 01 00 00 00
friendlyName: {F7619D96-3AC2-40D4-B6F3-4EAB73DEED73}
Microsoft CSP Name: Microsoft Enhanced Cryptographic Provider v1.0
Key Attributes
X509v3 Key Usage: 10
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK-Info: DES-EDE3-CBC,8DCE37F0A61A4B8C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-----END RSA PRIVATE KEY-----
Bag Attributes
subject=/CN=sldsslserver
issuer=/C=cn/O=ccc/OU=sec/CN=ssl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Bag Attributes: <Empty Attributes>
subject=/C=cn/O=ccc/OU=sec/CN=ssl
MIIB7DCCAVUCEG+jJTPxxiE67pl2ff0SnOMwDQYJKoZIhvcNAQEFBQAwNzELMAkG
A1UEBhMCY24xDDAKBgNVBAoTA2gzYzEMMAoGA1UECxMDc2VjMQwwCgYDVQQDEwNz
c2wwHhcNMDkwNzMxMDY0ODQ2WhcNMTIwNzI5MDYyODU4WjA3MQswCQYDVQQGEwJj
bjEMMAoGA1UEChMDaDNjMQwwCgYDVQQLEwNzZWMxDDAKBgNVBAMTA3NzbDCBnzAN
BgkqhkiG9w0BAQEFAAOBjQAwgYkCgYEAt8QSMetQ70GONiFh7iJkvGQ8nC15zCF1
cqC/RcJhE/88LkKyQcu9j+Tz8Bk9Qj2UPaZdrk8fOrgtBsa7lZ+UO3j3l30q84l+
HjWq8yxVLRQahU3gqJze6pGR2l0s76u6GRyCX/zizGrHKqYlNnxK44NyRZx2klQ2
tKQAfpXCPIkCAwEAATANBgkqhkiG9w0BAQUFAAOBgQBWsaMgRbBMtYNrrYCMjY6g
c7PBjvajVOKNUMxaDalePmXfKCxl91+PKM7+i8I/zLcoQO+sHbva26a2/C4sNvoJ
2QZs6GtAOahP6CDqXC5VuNBU6eTKNKjL+mf6uuDeMxrlDNha0iymdrXXVIp5cuIu
fl7xgArs8Ks6aXDXM1o4DQ==
Please input the password:********
Local certificate already exist, confirm to overwrite it? [Y/N]:y
The PKI domain already has a CA certificate. If it is overwritten, local certificates, peer certificates and CRL of this domain will also be deleted.
Overwrite it? [Y/N]:y
The system is going to save the key pair. You must specify a key pair name, which is a case-insensitive string of 1 to 64 characters. Valid characters include a to z, A to Z, 0 to 9, and hyphens (-).
Please enter the key pair name [default name: bbb]:
The key pair already exists.
Please enter the key pair name:
import-key
·     public-key dsa
·     public-key ecdsa
·     public-key rsa
Use pki request-certificate to submit a local certificate request or generate a certificate request in PKCS#10 format.
pki request-certificate domain domain-name [ password password ] [ pkcs10 [ filename filename ] ]
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 14.
Table 14 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
password password: Sets the password for certificate revocation, a case-sensitive string of 1 to 31 characters. The password is contained in the certificate request and must be provided if the certificate is revoked.
pkcs10: Displays BASE64-encoded PKCS#10 certificate request information, which can be used to request a certificate by an out-of-band means, like phone, disk, or email.
filename filename: Specifies a local file for saving the certificate request in PKCS#10 format. The filename argument is case-insensitive.
If SCEP fails, you can perform one of the following operations:
·     Use the pkcs10 keyword to print the BASE64-encoded request information.
·     Use the pkcs10 filename filename option to save the request information to a local file and send the file to the CA by an out-of-band means. The specified file name can contain an absolute path. If the specified path does exist, the request information cannot be saved.
This command is not saved in the configuration file.
# Display information about the certificate request in the PKCS#10 format.
[Sysname] pki request-certificate domain aaa pkcs10
*** Request for general certificate ***
-----BEGIN NEW CERTIFICATE REQUEST-----
MIIBTDCBtgIBADANMQswCQYDVQQDEwJqajCBnzANBgkqhkiG9w0BAQEFAAOBjQAw
gYkCgYEAw5Drj8ofs9THA4ezkDcQPBy8pvH1kumampPsJmx8sGG52NFtbrDTnTT5
ALx3LJijB3d/ndKpcHT/DfbJVDCn5gdw32tBZyCkEwMHZN3ol2z7Nmdcu5TED6iN8
4m+hfp1QWoV6lty3o9pxAXuQl8peUDcfN6WV3LBXYyl1WCtkLkECAwEAAaAAMA0G
CSqGSIb3DQEBBAUAA4GBAA8E7BaIdmT6NVCZgv/I/1tqZH3TS4e4H9Qo5NiCKiEw
R8owVmA0XVtGMbyqBNcDTG0f5NbHrXZQT5+MbFJOnm5K/mn1ro5TJKMTKV46PlCZ
JUjsugaY02GBY0BVcylpC9iIXLuXNIqjh1MBIqVsa1lQOHS7YMvnop6hXAQlkM4c
-----END NEW CERTIFICATE REQUEST-----
# Request the local certificates.
[Sysname] pki request-certificate domain openca
Start to request the general certificate ...
Request certificate of domain openca successfully
Use pki retrieve-certificate to obtain a certificate from the certificate distribution server.
pki retrieve-certificate domain domain-name { ca | local | peer entity-name }
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 15.
Table 15 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
peer entity-name: Specifies a peer entity by its name, a case-insensitive string of 1 to 31 characters.
In online mode:
·     You can obtain the CA certificate through the SCEP protocol. If a CA certificate already exists locally, do not obtain the CA certificate again. To obtain a new one, use the pki delete-certificate command to remove the CA certificate and local certificates, and then obtain the CA certificate again.
·     You can obtain local certificates or peer certificates through the LDAP protocol. If a PKI domain already has local certificates or peer certificates, you can still perform the obtain operation and the obtained local certificates or peer certificates overwrite the existing ones. If RSA is used, a PKI domain can have two local certificates, one for signing and the other for encryption. Certificates for different purposes do not overwrite each other.
The obtained CA certificate, local certificates, and peer certificates are automatically verified before they are saved locally. If the verification fails, they are not saved.
# Obtain the CA certificate from the certificate distribution server. (This operation requires the user to confirm the fingerprint of the CA root certificate.)
[Sysname] pki retrieve-certificate domain aaa ca
    MD5  fingerprint:5C41 E657 A0D6 ECB4 6BD6 1823 7473 AABC
    SHA1 fingerprint:1616 E7A5 D89A 2A99 9419 1C12 D696 8228 87BC C266
# Obtain the local certificates from the certificate distribution server.
[Sysname] pki retrieve-certificate domain aaa local
# Obtain the certificate of peer entity en1 from the certificate distribution server.
[Sysname] pki retrieve-certificate domain aaa peer en1
·     pki delete-certificate
pki retrieve-crl
Use pki retrieve-crl to obtain CRLs and save them locally.
pki retrieve-crl domain domain-name
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 16.
Table 16 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
CRLs are used to verify the validity of the local certificates and the peer certificates in a PKI domain. To obtain CRLs, a PKI domain must have the proper CA certificate.
The URL of the CRL repository is specified by using the crl url command.
The device can obtain CRLs from the CRL repository through the HTTP, LDAP, or SCEP protocol. Which protocol is used depends on the configuration of the CRL repository in the PKI domain:
·     If the specified URL of the CRL repository is in HTTP format, the device obtains CRLs through the HTTP protocol.
·     If the specified URL of the CRL repository is in LDAP format, the device obtains CRLs through the LDAP protocol. If the specified URL does not have a host name, for example, ldap:///CN=8088,OU=test,U=rd,C=cn, you must specify the LDAP server's URL for the PKI domain by using the ldap server command. The device can obtain the complete URL of the LDAP repository by combining the URLs of the LDAP server and of the CRL repository.
·     If the PKI domain is not configured with the CRL repository, the device looks up the local certificates and then the CA certificate for the CRL repository. If a CRL repository is found, the device obtains CRLs from the point. Otherwise, the device obtains CRLs through the SCEP protocol.
# Obtain CRLs from the CRL repository.
[Sysname] pki retrieve-crl domain aaa
·     crl url
·     ldap server
pki storage
Use pki storage to specify the storage path for the certificates or CRLs.
Use undo pki storage to restore the default.
pki storage { certificates | crls } dir-path
undo pki storage { certificates | crls }
The storage path for the certificates and CRLs is the PKI directory on the storage media of the device.
certificates: Specifies a storage path for the certificates.
crls: Specifies a storage path for the CRLs.
dir-path: Specifies a storage path, a case-sensitive string, which cannot start with a slash (/) or contains two dots plus a slash (../). The dir-path argument specifies an absolute path or a relative path, and the path must exist.
The specified storage path is a path on the active MPU rather than on other MPUs.
The default PKI directory on the device is automatically created when you successfully request, obtain, or import a certificate for the first time.
If the path to be specified does not exist, use the mkdir command to create the path before using this command. After you change the storage path for certificates or CRLs, the certificate files (with the .cer or .p12 extension) and CRL files (with the .crl extension) in the original path are moved to the new path.
# Specifies flash:/pki-new as the storage path for the certificates.
[Sysname] pki storage certificates flash:/pki-new
# Specifies pki-new as the storage path for the CRLs.
[Sysname] pki storage crls pki-new
pki validate-certificate
Use pki validate-certificate to verify the validity of certificates.
pki validate-certificate domain domain-name { ca | local }
domain-name: Specifies a PKI domain by its name, a case-insensitive string of 1 to 31 characters. The domain name cannot contain the special characters listed in Table 17.
Table 17 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Dot
Asterisk
Left angle bracket
Backslash
Right angle bracket
Vertical bar
Quotation marks
Colon
Apostrophe
Generally, certificates are automatically verified when you request, obtain, or import them, or when an application uses PKI.
You can also use this command to manually verify a certificate in the following aspects:
·     Whether the certificate is issued by a trusted CA.
·     Whether the certificate expires.
·     Whether the certificate is revoked if CRL checking is enabled.
When CRL checking is enabled:
·     To verify the local certificates, if the PKI domain has no CRLs, the device looks up the locally save CRLs. If a correct CRL is found, the device loads the CRL to the PKI domain. Otherwise, the device obtains the correct CRL from the CA server and saves it locally.
·     To verify the CA certificate, CRL checking is performed for the CA certificate chain from the current CA to the root CA.
# Verify the validity of the CA certificate in PKI domain aaa.
[Sysname] pki validate-certificate domain aaa ca
Verifying certificate......
        Serial Number:
            f6:3c:15:31:fe:bb:ec:94:dc:3d:b9:3a:d9:07:70:e5
        Issuer:
            C=cn
            O=ccc
            OU=test
            CN=rootca
        Subject:
            C=cn
            O=abc
            OU=test
            CN=aca
Verify result: OK
        Serial Number:
        Issuer:
            C=cn
            O=ccc
            OU=test
            CN=rootca
        Subject:
            C=cn
            O=ccc
            OU=test
            CN=rootca
Verify result: OK
# Verify the local certificates in PKI domain aaa.
[Sysname] pki validate-certificate domain aaa local
        Serial Number:
        Issuer:
            C=CN
            O=sec
            OU=software
            CN=bca
        Subject:
            O=OpenCA Labs
            OU=Users
            CN=fips fips-sec
Verify result: OK
·     crl check
·     pki domain
public-key dsa
Use public-key dsa to specify a DSA key pair for certificate request.
Use undo public-key to remove the configuration.
public-key dsa name key-name [ length key-length ]
undo public-key
No key pair is specified.
PKI domain view
name key-name: Specifies a DSA key pair by its name, a case-insensitive string of 1 to 64 characters. The key pair name can contain only letters, digits, and hyphens (-).
length key-length: Specifies the key length, in bits. In non-FIPS mode, the value range is 512 to 2048, and the default is 1024. In FIPS mode, the value must be 2048. A longer key means higher security but more public key calculation time.
You can specify a nonexistent key pair in this command. A key pair can be obtained in any of the following ways:
·     Use the public-key local create command to generate a key pair.
·     An application triggers the device to generate a key pair
·     Use the pki import command to import a certificate containing a key pair.
A PKI domain can have key pairs using only one type of cryptographic algorithm (DSA, ECDSA, or RSA).
·     If DSA or ECDSA is used, a PKI domain can have only one key pair.
·     If RSA is used, a PKI domain can have two key pairs: one is the signing key pair, and the other is the encryption key pair.
·     In a PKI domain, key pairs for different purposes (RSA signing and RSA encryption) do not overwrite each other.
·     For DSA or ECDSA, the most recent configuration takes effect.
The length key-length option takes effect only if you specify a nonexistent key pair. The device will automatically create the key pair by using the specified name and length before submitting a certificate request. The length key-length option is ignored if the specified key pair already exists or is already contained in an imported certificate.
# Specify 2048-bit DSA key pair abc for certificate request.
[Sysname] pki domain aaa
[Sysname-pki-domain-aaa] public-key dsa name abc length 2048
·     pki import
·     public-key local create
public-key ecdsa
Use public-key ecdsa to specify an ECDSA key pair for certificate request.
public-key ecdsa name key-name [ secp192r1 | secp256r1 | secp384r1 | secp521r1 ]
undo public-key
PKI domain view
name key-name: Specifies an ECDSA key pair by its name, a case-insensitive string of 1 to 64 characters. The key pair name can contain only letters, digits, and hyphens (-).
secp192r1: Uses the secp192r1 curve to generate the key pair.
secp256r1: Uses the secp256r1 curve to generate the key pair.
secp384r1: Uses the secp384r1 curve to generate the key pair.
secp521r1: Uses the secp521r1 curve to generate the key pair.
The specified elliptic curve takes effect only if you specify a nonexistent key pair. The device will automatically create the key pair by using the specified name and curve before submitting a certificate request. The curve parameter is ignored if the specified key pair already exists or is already contained in an imported certificate.
# Specify ECDSA key pair abc for certificate request.
[Sysname-pki-domain-aaa] public-key ecdsa name abc
·     pki import
public-key rsa
Use public-key rsa to specify an RSA key pair for certificate request.
public-key rsa { { encryption name encryption-key-name [ length key-length ] | signature name signature-key-name [ length key-length ] } * | general name key-name [ length key-length ] }
undo public-key
PKI domain view
encryption: Specifies an RSA key pair for encryption.
name encryption-key-name: Specifies a key pair name, a case-insensitive string of 1 to 64 characters. The key pair name can contain only letters, digits, and hyphens (-).
signature: Specifies a key pair for signing.
name signature-key-name: Specifies a key pair name, a case-insensitive string of 1 to 64 characters. The key pair name contains only letters, digits, and hyphens (-).
general: Specifies a key pair for both signing and encryption.
name key-name: Specifies a key pair name, a case-insensitive string of 1 to 64 characters. The key pair name can contain only letters, digits, and hyphens (-).
You can specify a nonexistent key pair in this command. You can get a key pair in any of the following ways:
·     If RSA is used, a PKI domain can have two key pairs: one is the signing key pair, and the other is the encryption one.
If you specify a signing key pair and an encryption key pair separately, their key length can be different.
# Specify 2048-bit general purpose RSA key pair abc for certificate request.
[Sysname-pki-domain-aaa] public-key rsa general name abc length 2048
# Specify the following 2048-bit RSA key pairs for certificate request:
·     RSA encryption key pair rsa1.
·     RSA signing key pair sig1.
[Sysname-pki-domain-aaa] public-key rsa encryption name rsa1 length 2048
[Sysname-pki-domain-aaa] public-key rsa signature name sig1 length 2048
·     pki import
root-certificate fingerprint
Use root-certificate fingerprint to set the fingerprint for verifying the validity of the CA root certificate.
Use undo root-certificate fingerprint to remove the configuration.
In non-FIPS mode:
root-certificate fingerprint { md5 | sha1 } string
In FIPS mode:
root-certificate fingerprint sha1 string
No fingerprint is set.
PKI domain view
md5: Sets an MD5 fingerprint.
sha1: Sets a SHA1 fingerprint.
string: Sets the fingerprint information in hexadecimal notation. If you specify the MD5 keyword, the fingerprint is a string of 32 characters. If you specify the SHA1 keyword, the fingerprint is a string of 40 characters.
If you set the certificate request mode to auto, and if the PKI domain does not have a CA certificate, you must use this command to set the fingerprint for verifying the validity of the CA root certificate.
You can choose whether to set the fingerprint of the CA root certificate when performing the following operations:
·     Import the CA certificate by using the pki import command.
·     Obtain the CA certificate by using the pki retrieve-certificate command.
If you specify the fingerprint in the PKI domain, the device automatically verifies the fingerprint of the CA certificate to be imported or obtained against that configured in the domain. If the two fingerprints do not match, the device rejects the CA certificate. If no fingerprint is specified in the domain, the device asks you to manually verify the fingerprint of the CA certificate.
# Specify an MD5 fingerprint for verifying the validity of the CA root certificate. (This configuration is supported only in non-FIPS mode.)
[Sysname-pki-domain-aaa] root-certificate fingerprint md5 12EF53FA355CD23E12EF53FA355CD23E
# Set an SHA1 fingerprint for verifying the validity of the CA root certificate.
[Sysname-pki-domain-aaa] root-certificate fingerprint sha1 D1526110AAD7527FB093ED7FC037B0B3CDDDAD93
·     certificate request mode
·     pki import
·     pki retrieve-certificate
rule
Use rule to create an access control rule (or statement).
Use undo rule to remove an access control rule (or statement).
rule [ id ] { deny | permit } group-name
undo rule id
No statement exists.
PKI certificate-based access control policy view
id: Assigns an ID to the access control rule, in the range of 1 to 16. The default setting is the smallest unused ID in this range.
deny: Denies the certificates that match the associated certificate group.
permit: Permits the certificates that match the associated certificate group.
group-name: Specifies a certificate attribute group by its name, a case-insensitive string of 1 to 31 characters.
When you create an access control rule, you can associate it with a nonexistent certificate attribute group.
The system determines that a certificate matches an access control rule when either of the following conditions exists:
·     The associated certificate attribute group does not exist.
·     The associated certificate attribute group does not contain any attribute rules.
·     The certificate matches all attribute rules in the associated certificated attribute group.
You can create multiple access control rules for an access control policy. A certificate matches the rules one by one, starting with the rule with the smallest ID. When a match is found, the match process stops, and the system performs the access control action defined in the access control rule.
# Create rule 1 to permit all certificates that match certificate attribute group mygroup.
[Sysname-pki-cert-acp-mypolicy] rule 1 permit mygroup
·     attribute
·     pki certificate attribute-group
source
Use source to specify the source IP address for PKI protocol packets.
Use undo source to remove the configuration.
source { ip | ipv6 } { ip-address | interface interface-type interface-number }
undo source
The source IP address of PKI protocol packets is the IP address of their outgoing interface.
PKI domain view
ip ip-address: Specifies a source IPv4 address.
ipv6 ip-address: Specifies a source IPv6 address
interface interface-type interface-number: Specifies an interface by its type and number. The interface's primary IP address will be used as the source IP address for PKI protocol packets.
Use this command to specify the source IP address for PKI protocol packets. You can also specify a source interface if the IP address is dynamically obtained.
Make sure there is a route between the source IP address and the CA server.
You can specify only one source IP address in a PKI domain. If you configure this command multiple times, the most recent configuration takes effect.
# Specify 111.1.1.8 as the source IP address for PKI protocol packets.
[Sysname-pki-domain-aaa] source ip 111.1.1.8
# Specify 1::8 as the source IPv6 address for PKI protocol packets.
[Sysname] pki domain 1
[Sysname-pki-domain-1] source ipv6 1::8
# Specify GigabitEthernet 1/0/1 as the source interface for PKI protocol packets.
[Sysname-pki-domain-aaa] source ip interface gigabitethernet 1/0/1
# Specify the IPv6 address of GigabitEthernet 1/0/1 as the source IP address for PKI protocol packets.
[Sysname-pki-domain-1] source ipv6 interface gigabitethernet 1/0/1
state
Use state to set the state or province name for a PKI entity.
Use undo state to remove the configuration.
state state-name
undo state
No state name or province name is set for a PKI entity.
PKI entity view
state-name: Specifies a state or province by its name, a case-sensitive string of 1 to 63 characters. No comma can be included.
# Specify countryA as the state name of PKI entity en.
[Sysname] pki entity en
[Sysname-pki-entity-en] state countryA
usage
Use usage to specify the extensions for certificates.
Use undo usage to remove certificate extensions.
usage { ike | ssl-client | ssl-server } *
undo usage [ ike | ssl-client | ssl-server ] *
No extension is specified. A certificate can be used for all applications, including SSL clients and SSL servers.
PKI domain view
ike: Specifies the IKE certificate extension so IKE peers can use the certificates. The device does not support this keyword in the current software version.
ssl-client: Specifies the SSL client certificate extension so the SSL client ends can use the certificates.
ssl-server: Specifies the SSL server certificate extension so the SSL server ends can use the certificates.
If you do not specify any keywords for the undo usage command, the command removes all certificate extensions.
The extension options contained in a certificate depends on the CA policy, and might be different from those specified in the PKI domain.
# Specify the SSL client certificate extension.
[Sysname-pki-domain-aaa] usage ssl-client
