06 IP Multicast Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10006 IP Multicast Configuration Guide
15-IPv6 PIM configuration
15-IPv6 PIM configuration 881.04 KB
Configuring IPv6 PIM··· 1
Overview·· 1
IPv6 PIM-DM overview·· 1
IPv6 PIM-SM overview·· 3
IPv6 BIDIR-PIM overview·· 8
IPv6 administrative scoping overview·· 11
IPv6 PIM-SSM overview·· 13
Relationship among IPv6 PIM protocols 14
IPv6 PIM support for VPNs 15
Protocols and standards 15
Configuring IPv6 PIM-DM··· 15
IPv6 PIM-DM configuration task list 16
Configuration prerequisites 16
Enabling IPv6 PIM-DM··· 16
Enabling the state refresh feature· 16
Configuring state refresh parameters 17
Configuring IPv6 PIM-DM graft retry timer 17
Configuring IPv6 PIM-SM··· 18
IPv6 PIM-SM configuration task list 18
Configuration prerequisites 18
Enabling IPv6 PIM-SM··· 18
Configuring an RP· 19
Configuring a BSR· 20
Configuring IPv6 multicast source registration· 22
Configuring the switchover to SPT· 22
Configuring IPv6 BIDIR-PIM··· 23
IPv6 BIDIR-PIM configuration task list 23
Configuration prerequisites 23
Enabling IPv6 BIDIR-PIM··· 23
Configuring an RP· 24
Configuring a BSR· 26
Configuring IPv6 PIM-SSM··· 28
IPv6 PIM-SSM configuration task list 28
Configuration prerequisites 28
Enabling IPv6 PIM-SM··· 28
Configuring the IPv6 SSM group range· 29
Configuring common IPv6 PIM features 29
Configuration task list 29
Configuration prerequisites 30
Configuring an IPv6 multicast source policy· 30
Configuring an IPv6 PIM hello policy· 30
Configuring IPv6 PIM hello message options 31
Configuring common IPv6 PIM timers 32
Setting the maximum size of each join or prune message· 34
Enabling BFD for IPv6 PIM··· 34
Enabling IPv6 PIM passive mode· 34
Enabling IPv6 PIM NSR· 35
Displaying and maintaining IPv6 PIM··· 35
IPv6 PIM configuration examples 36
IPv6 PIM-DM configuration example· 36
IPv6 PIM-SM non-scoped zone configuration example· 39
IPv6 PIM-SM admin-scoped zone configuration example· 42
IPv6 BIDIR-PIM configuration example· 48
IPv6 PIM-SSM configuration example· 53
Troubleshooting IPv6 PIM··· 56
A multicast distribution tree cannot be correctly built 56
IPv6 multicast data is abnormally terminated on an intermediate router 56
An RP cannot join an SPT in IPv6 PIM-SM··· 57
An RPT cannot be built or IPv6 multicast source registration fails in IPv6 PIM-SM··· 57
Overview
IPv6 Protocol Independent Multicast (IPv6 PIM) provides IPv6 multicast forwarding by leveraging IPv6 unicast static routes or IPv6 unicast routing tables generated by any IPv6 unicast routing protocol, such as RIPng, OSPFv3, IPv6 IS-IS, or IPv6 BGP. IPv6 PIM uses the underlying IPv6 unicast routing to generate an IPv6 multicast routing table without relying on any particular IPv6 unicast routing protocol.
IPv6 PIM uses the RPF mechanism to implement multicast forwarding. When an IPv6 multicast packet arrives on an interface of the device, the packet undergoes an RPF check. If the RPF check succeeds, the device creates an IPv6 multicast routing entry and forwards the packet. If the RPF check fails, the device discards the packet. For more information about RPF, see "Configuring IPv6 multicast routing and forwarding."
Based on the implementation mechanism, IPv6 PIM includes the following categories:
·     IPv6 Protocol Independent Multicast–Dense Mode (IPv6 PIM-DM)
·     IPv6 Protocol Independent Multicast–Sparse Mode (IPv6 PIM-SM)
·     IPv6 Bidirectional Protocol Independent Multicast (IPv6 BIDIR-PIM)
·     IPv6 Protocol Independent Multicast Source-Specific Multicast (IPv6 PIM-SSM)
The term "IPv6 PIM domain" in this chapter refers to a network composed of IPv6 PIM routers.
The term "interface" in this chapter collectively refers to VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
IPv6 PIM-DM uses the push mode for multicast forwarding and is suitable for small networks with densely distributed IPv6 multicast members.
IPv6 PIM-DM assumes that all downstream nodes want to receive IPv6 multicast data from a source, so IPv6 multicast data is flooded to all downstream nodes on the network. Branches without downstream receivers are pruned from the forwarding trees. When a pruned branch has new receivers, the graft mechanism turns the pruned branch into a forwarding branch.
In IPv6 PIM-DM, the multicast forwarding paths for an IPv6 multicast group constitute a forwarding tree. The forwarding tree is rooted at the IPv6 multicast source and has multicast group members as its "leaves." Because the source tree consists of the shortest paths from the IPv6 multicast source to the receivers, it is also called a "shortest path tree (SPT)."
Neighbor discovery
In an IPv6 PIM domain, each IPv6 PIM interface periodically multicasts IPv6 PIM hello messages to all other IPv6 PIM routers on the local subnet. Through the exchanging of hello messages, all IPv6 PIM routers determine their IPv6 PIM neighbors, maintain IPv6 PIM neighboring relationship with other routers, and build and maintain SPTs.
SPT building
The process of building an SPT is the flood-and-prune process:
1.     In an IPv6 PIM-DM domain, the IPv6 multicast data from the IPv6 multicast source S to the IPv6 multicast group G is flooded throughout the domain. A router performs an RPF check for the IPv6 multicast data. If the check succeeds, the router creates an (S, G) entry and forwards the data to all downstream nodes in the network. In the flooding process, all the routers in the IPv6 PIM-DM domain create the (S, G) entry.
2.     The nodes without downstream receivers are pruned. A router that has no downstream receivers multicasts a prune message to all IPv6 PIM routers on the subnet. When the upstream node receives the prune message, it removes the receiving interface from the (S, G) entry. In this way, the upstream stream node stops forwarding subsequent packets addressed to that IPv6 multicast group down to this node.
An (S, G) entry contains an IPv6 multicast source address S, an IPv6 multicast group address G, an outgoing interface list, and an incoming interface.
A prune process is initiated by a leaf router. As shown in Figure 1, the router interface that does not have any downstream receivers initiates a prune process by sending a prune message toward the IPv6 multicast source. This prune process goes on until only necessary branches are left in the IPv6 PIM-DM domain, and these necessary branches constitute an SPT.
Figure 1 SPT building
The pruned state of a branch has a finite holdtime timer. When the timer expires, IPv6 multicast data is again forwarded to the pruned branch. The flood-and-prune cycle takes place periodically to maintain the forwarding branches.
Graft
A previously pruned branch might have new downstream receivers. To reduce the latency for resuming the forwarding capability of this branch, a graft mechanism is used as follows:
1.     The node that needs to receive the IPv6 multicast data sends a graft message to its upstream node, telling it to rejoin the SPT.
2.     After receiving this graft message on an interface, the upstream node adds the receiving interface to the outgoing interface list of the (S, G) entry. It also sends a graft-ack message to the graft sender.
3.     If the graft sender receives a graft-ack message, the graft process finishes. Otherwise, the graft sender continues to send graft messages at a graft retry interval until it receives an acknowledgment from its upstream node.
Assert
On a subnet with more than one multicast router, the assert mechanism shuts off duplicate multicast flows to the network. It does this by electing a unique multicast forwarder for the subnet.
Figure 2 Assert mechanism
As shown in Figure 2, after Router A and Router B receive an (S, G) packet from the upstream node, they both forward the packet to the local subnet. As a result, the downstream node Router C receives two identical multicast packets. In addition, both Router A and Router B, on their own downstream interfaces, receive a duplicate packet forwarded by the other. After detecting this condition, both routers send an assert message to all IPv6 PIM routers on the local subnet through the interface that received the packet. The assert message contains the IPv6 multicast source address (S), the IPv6 multicast group address (G), and the metric preference and metric of the IPv6 unicast route to the IPv6 multicast source. By comparing these parameters, either Router A or Router B becomes the unique forwarder of the subsequent (S, G) packets on the subnet. The comparison process is as follows:
1.     The router with a higher metric preference to the IPv6 multicast source wins.
2.     If both routers have the same metric preference, the router with a smaller metric wins.
3.     If both routers have the same metric, the router with a higher IPv6 link-local address on the downstream interface wins.
IPv6 PIM-DM uses the flood-and-prune cycles to build SPTs for IPv6 multicast data forwarding. Although an SPT has the shortest paths from the IPv6 multicast source to the receivers, it is built with a low efficiency. Therefore, IPv6 PIM-DM is not suitable for large- and medium-sized networks.
IPv6 PIM-SM uses the pull mode for IPv6 multicast forwarding, and it is suitable for large-sized and medium-sized networks with sparsely and widely distributed IPv6 multicast group members.
IPv6 PIM-SM assumes that no hosts need IPv6 multicast data. A multicast receiver must express its interest in the IPv6 multicast data for an IPv6 multicast group before the data is forwarded to it. A rendezvous point (RP) is the core of an IPv6 PIM-SM domain. Relying on the RP, SPTs and rendezvous point trees (RPTs) are established and maintained to implement IPv6 multicast data forwarding. An SPT is rooted at the IPv6 multicast source and has the RPs as its leaves. An RPT is rooted at the RP and has the receiver hosts as its leaves.
Neighbor discovery
IPv6 PIM-SM uses the same neighbor discovery mechanism as IPv6 PIM-DM does. For more information, see "Neighbor discovery."
DR election
A DR is required on both the source-side network and receiver-side network. A source-side DR acts on behalf of the IPv6 multicast source to send register messages to the RP. The receiver-side DR acts on behalf of the receiver hosts to send join messages to the RP.
IMPORTANT:
MLD must be enabled on the device that acts as the receiver-side DR. Otherwise, the receiver hosts attached to the DR cannot join any IPv6 multicast groups. For more information about MLD, see "Configuring MLD."
Figure 3 DR election
As shown in Figure 3, the DR election process is as follows:
1.     The routers on the shared-media LAN send hello messages to one another. The hello messages contain the priority for DR election. The router with the highest DR priority is elected as the DR.
2.     The router with the highest IPv6 link-local address wins the DR election under one of the following conditions:
a.     All the routers have the same DR election priority.
b.     A router does not support carrying the DR-election priority in hello messages.
If the DR fails, its IPv6 PIM neighbor lifetime expires, and the other routers initiate a new DR election.
RP discovery
An RP is the core of an IPv6 PIM-SM domain. For a small-sized, simple network, one RP is enough for multicast forwarding throughout the network. In this case, you can specify a static RP on each router in the IPv6 PIM-SM domain. However, in an IPv6 PIM-SM network that covers a wide area, a huge amount of IPv6 multicast data is forwarded by the RP. To lessen the RP burden and optimize the topological structure of the RPT, you can configure multiple candidate-RPs (C-RPs) in an IPv6 PIM-SM domain. The bootstrap mechanism is used to dynamically elect an RP from multiple configured C-RPs. An elected RP provides services for a different IPv6 multicast group. For this purpose, you must configure a bootstrap router (BSR). A BSR acts as the administrative core of an IPv6 PIM-SM domain. An IPv6 PIM-SM domain has only one BSR, but can have multiple candidate-BSRs (C-BSRs) so that, if the BSR fails, a new BSR can be automatically elected from the C-BSRs and avoid service interruption.
·     An RP can provide services for multiple IPv6 multicast groups, but an IPv6 multicast group only uses one RP.
·     A device can act as a C-RP and a C-BSR at the same time.
As shown in Figure 4, each C-RP periodically unicasts its advertisement messages (C-RP-Adv messages) to the BSR. An advertisement message contains the address of the advertising C-RP and the IPv6 multicast group range to which it is designated. The BSR collects these advertisement messages and organizes the C-RP information into an RP-set, which is a database of mappings between IPv6 multicast groups and RPs. The BSR encapsulates the RP-set information in the bootstrap messages (BSMs) and floods the BSMs to the entire IPv6 PIM-SM domain.
Figure 4 Information exchange between C-RPs and BSR
Based on the information in the RP-set, all routers in the network can select an RP for a specific IPv6 multicast group based on the following rules:
1.     The C-RP that is designated to a smallest IPv6 multicast group range wins.
2.     If the C-RPs are designated to the same group range, the C-RP with the highest priority wins.
3.     If the C-RPs have the same priority, the C-RP with the largest hash value wins. The hash value is calculated through the hash algorithm.
4.     If the C-RPs have the same hash value, the C-RP with the highest IPv6 address wins.
Embedded RP
The embedded RP mechanism enables a router to resolve the RP address from an IPv6 multicast group address to map the IPv6 multicast group to an RP. This RP can take the place of the configured static RP or the RP dynamically elected by the bootstrap mechanism. A DR does not need to learn the RP address beforehand. The process is as follows:
·     At the receiver side:
a.     A receiver host initiates an MLD report to express its interest in an IPv6 multicast group.
b.     After receiving the MLD report, the receiver-side DR resolves the RP address embedded in the IPv6 multicast group address and sends a join message to the RP.
·     At the IPv6 multicast source side:
a.     The IPv6 multicast source sends IPv6 multicast traffic to an IPv6 multicast group.
b.     The source-side DR resolves the RP address embedded in the IPv6 multicast address, and sends a register message to the RP.
RPT building
Figure 5 RPT building in an IPv6 PIM-SM domain
As shown in Figure 5, the process of building an RPT is as follows:
1.     When a receiver wants to join the IPv6 multicast group G, it uses an MLD message to inform the receiver-side DR.
2.     After getting the receiver information, the DR sends a join message, which is forwarded hop by hop to the RP for the IPv6 multicast group.
3.     The routers along the path from the DR to the RP form an RPT branch. Each router on this branch adds to its forwarding table a (*, G) entry, where the asterisk (*) represents any IPv6 multicast source. The RPT is rooted at the RP and has the DR as its leaf.
When the IPv6 multicast data addressed to the IPv6 multicast group G reaches the RP, the RP forwards the data to the DR along the established RPT. Finally, the DR forwards the IPv6 multicast data to the multicast receivers.
When a receiver is no longer interested in the IPv6 multicast data addressed to the IPv6 multicast group G, the receiver-side DR sends a prune message. The prune message goes hop by hop along the RPT to the RP. After receiving the prune message, the upstream node deletes the interface that connects to this downstream node from the outgoing interface list. At the same time, the upstream router checks for the existence of receivers for that IPv6 multicast group. If no receivers for the IPv6 multicast group exist, the router continues to forward the prune message to its upstream router.
The IPv6 multicast source uses the registration process to inform an RP of its presence.
Figure 6 IPv6 multicast source registration
As shown in Figure 6, the IPv6 multicast source registers with the RP as follows:
1.     The IPv6 multicast source S sends the first multicast packet to the IPv6 multicast group G. When receiving the multicast packet, the source-side DR that directly connects to the IPv6 multicast source encapsulates the packet into an register message and unicasts the message to the RP.
2.     After the RP receives the register message, it decapsulates it and forwards it down to the RPT. Meanwhile, it sends an (S, G) source-specific join message toward the IPv6 multicast source. The routers along the path from the RP to the IPv6 multicast source constitute an SPT branch. Each router on this branch creates an (S, G) entry in its forwarding table.
3.     The subsequent IPv6 multicast data from the IPv6 multicast source are forwarded to the RP along the SPT. When the IPv6 multicast data reaches the RP along the SPT, the RP forwards the data to the receivers along the RPT. Meanwhile, it unicasts a register-stop message to the source-side DR to prevent the DR from unnecessarily encapsulating the data.
CAUTION:
If the switch is an RP, disabling switchover to SPT might cause multicast traffic forwarding failures on the source-side DR. When disabling switchover to SPT, be sure you fully understand its impact on your network.
Switchover to SPT
In an IPv6 PIM-SM domain, only one RP and one RPT provide services for a specific IPv6 multicast group. Before the switchover to SPT occurs, the source-side DR encapsulates all IPv6 multicast data addressed to the IPv6 multicast group in register messages and sends them to the RP. After receiving these register messages, the RP decapsulates them and forwards them to the receiver-side DR along the RPT.
Switchover to SPT has the following weaknesses:
·     Encapsulation and decapsulation are complex on the source-side DR and the RP.
·     The path for an IPv6 multicast packet might not be the shortest one.
·     The RP might be overloaded by IPv6 multicast traffic bursts.
To eliminate these weaknesses, IPv6 PIM-SM allows an RP or the receiver-side DR to initiate the switchover to SPT:
·     The RP initiates the switchover to SPT:
After receiving the first (S, G) multicast packet, the RP immediately sends an (S, G) source-specific join message toward the IPv6 multicast source. The routers along the path from the RP to the IPv6 multicast source constitute an SPT branch. The subsequent IPv6 multicast data for the IPv6 multicast group is forwarded to the RP along the SPT without being encapsulated in register messages.
For more information about the switchover to SPT initiated by the RP, see "IPv6 multicast source registration."
·     The receiver-side DR initiates the switchover to SPT:
After receiving the first (S, G) multicast packet, the receiver-side DR immediately initiates the switchover to SPT, as follows:
a.     The receiver-side DR sends an (S, G) source-specific join message toward the IPv6 multicast source. The routers along the path from the RP to the IPv6 multicast source create an (S, G) entry in their forwarding table to constitute an SPT branch.
b.     When the multicast packets reach the router where the RPT and the SPT branches, the router drops the multicast packets that travel along the RPT. Then, it sends a prune message with the RP bit to the RP.
c.     After receiving the prune message, the RP forwards it toward the IPv6 multicast source (supposed only one receiver exists). Thus, the switchover to SPT is completed. The subsequent IPv6 multicast packets travel along the SPT from the IPv6 multicast source to the receiver hosts.
With the switchover to SPT, IPv6 PIM-SM builds SPTs more economically than IPv6 PIM-DM does.
Assert
IPv6 PIM-SM uses a similar assert mechanism as IPv6 PIM-DM does. For more information, see "Assert."
In some many-to-many applications, such as a multi-side video conference, multiple receivers of an IPv6 multicast group might be interested in the IPv6 multicast data from multiple IPv6 multicast sources. With IPv6 PIM-DM or IPv6 PIM-SM, each router along the SPT must create an (S, G) entry for each IPv6 multicast source, consuming a lot of system resources.
IPv6 BIDIR-PIM addresses the problem. Derived from IPv6 PIM-SM, IPv6 BIDIR-PIM builds and maintains a bidirectional RPT, which is rooted at the RP and connects the IPv6 multicast sources and the receivers. Along the bidirectional RPT, the IPv6 multicast sources send IPv6 multicast data to the RP, and the RP forwards the data to the receivers. Each router along the bidirectional RPT needs to maintain only one (*, G) entry, saving system resources.
IPv6 BIDIR-PIM is suitable for a network with dense IPv6 multicast sources and receivers.
Neighbor discovery
IPv6 BIDIR-PIM uses the same neighbor discovery mechanism as IPv6 PIM-SM does. For more information, see "Neighbor discovery."
RP discovery
IPv6 BIDIR-PIM uses the same RP discovery mechanism as IPv6 PIM-SM does. For more information, see "RP discovery." In IPv6 BIDIR-PIM, an RPF interface is the interface toward an RP, and an RPF neighbor is the address of the next hop to the RP.
In IPv6 PIM-SM, an RP must be specified with a real IPv6 address. In IPv6 BIDIR-PIM, an RP can be specified with a virtual IPv6 address, which is called the "rendezvous point address (RPA)." The link corresponding to the RPA's subnet is called the "rendezvous point link (RPL)." All interfaces connected to the RPL can act as the RPs, and they back up one another.
DF election
On a subnet with multiple multicast routers, duplicate multicast packets might be forwarded to the RP. To address this issue, IPv6 BIDIR-PIM uses a designated forwarder (DF) election mechanism to elect a unique DF on each subnet. Only the DFs can forward IPv6 multicast data to the RP.
DF election is not necessary for an RPL.
Figure 7 DF election
As shown in Figure 7, without the DF election mechanism, both Router B and Router C can receive IPv6 multicast packets from Route A. They also can forward the packets to downstream routers on the local subnet. As a result, the RP (Router E) receives duplicate IPv6 multicast packets.
With the DF election mechanism, once receiving the RP information, Router B and Router C multicast a DF election message to all IPv6 PIM routers on the subnet to initiate a DF election process. The election message carries the RP's address, and the metric preference and metric of the unicast route to the RP. A DF is elected as follows:
1.     The router with higher metric preference becomes the DF.
2.     If the routers have the same metric preference, the router with lower metric becomes the DF.
3.     If the routers have the same metric, the router with the higher IP address becomes the DF.
Bidirectional RPT building
A bidirectional RPT comprises a receiver-side RPT and a source-side RPT. The receiver-side RPT is rooted at the RP and takes the routers that directly connect to the receivers as leaves. The source-side RPT is also rooted at the RP but takes the routers that directly connect to the IPv6 multicast sources as leaves. The processes for building these two RPTs are different.
Figure 8 RPT building at the receiver side
As shown in Figure 8, the process for building a receiver-side RPT is the same as the process for building an RPT in IPv6 PIM-SM:
1.     When a receiver wants to join the IPv6 multicast group G, it uses an MLD message to inform the directly connected router.
2.     After receiving the message, the router sends a join message, which is forwarded hop by hop to the RP for the IPv6 multicast group.
3.     The routers along the path from the receiver's directly connected router to the RP form an RPT branch. Each router on this branch adds a (*, G) entry to its forwarding table.
After a multicast receiver leaves the IPv6 multicast group G, the directly connected router multicasts a prune message to all IPv6 PIM routers on the subnet. The prune message goes hop by hop along the reverse direction of the RPT to the RP. After receiving the prune message, an upstream node removes the interface that connects to the downstream node from the outgoing interface list. At the same time, the upstream router checks for the existence of receivers for that IPv6 multicast group. If no receivers for the IPv6 multicast group exist, the router continues to forward the prune message to its upstream router.
Figure 9 RPT building at the IPv6 multicast source side
As shown in Figure 9, the process for building a source-side RPT is relatively simple:
1.     When an IPv6 multicast source sends multicast packets to the IPv6 multicast group G, the DF in each subnet unconditionally forwards the packets to the RP.
2.     The routers along the path from the source's directly connected router to the RP constitute an RPT branch. Each router on this branch adds a (*, G) entry to its forwarding table.
After a bidirectional RPT is built, the IPv6 multicast sources send multicast traffic to the RP along the source-side RPT. Then, the RP forwards the traffic to the receivers along the receiver-side RPT.
IMPORTANT:
If a receiver and an IPv6 multicast source are at the same side of the RP, the source-side RPT and the receiver-side RPT might meet at a node before reaching the RP. In this case, the multicast packets from the IPv6 multicast source to the receiver are directly forwarded by the node, instead of by the RP.
Typically, an IPv6 PIM-SM domain or an IPv6 BIDIR-PIM domain contains only one BSR. The BSR is responsible for advertising RP-set information within the entire IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain. Information about all IPv6 multicast groups is forwarded within the network that the BSR administers. This is called the "IPv6 non-scoped BSR mechanism."
IPv6 administrative scoping mechanism
To implement refined management, you can divide an IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain into an IPv6 global-scoped zone and multiple IPv6 administratively-scoped zones (admin-scoped zones). This is called the "IPv6 administrative scoping mechanism."
The administrative scoping mechanism effectively releases stress on the management in a single-BSR domain and enables provision of zone-specific services through private group addresses.
An IPv6 admin-scoped zone is designated to particular IPv6 multicast groups with the same scope field value in their group addresses. Zone border routers (ZBRs) form the boundary of an IPv6 admin-scoped zone. Each IPv6 admin-scoped zone maintains one BSR for IPv6 multicast groups with the same scope field value. IPv6 multicast protocol packets, such as assert messages and BSMs, of these IPv6 multicast groups cannot cross the boundary of the IPv6 admin-scoped zone for the group range. The IPv6 multicast group ranges to which different IPv6 admin-scoped zones are designated can have intersections. However, the IPv6 multicast groups in an IPv6 admin-scoped zone are valid only within its local zone, and theses IPv6 multicast groups are regarded as private group addresses.
The IPv6 global-scoped zone can be regarded as a special IPv6 admin-scoped zone, and it maintains a BSR for the IPv6 multicast groups with the scope field value as 14.
Relationship between IPv6 admin-scoped zones and the IPv6 global-scoped zone
The IPv6 global-scoped zone and each IPv6 admin-scoped zone have their own C-RPs and BSRs. These devices are effective only on their respective zones, and the BSR election and the RP election are implemented independently. Each IPv6 admin-scoped zone has its own boundary. The IPv6 multicast information within a zone cannot cross this boundary in either direction. You can have a better understanding of the IPv6 global-scoped zone and IPv6 admin-scoped zones based on geographical locations and the scope field values.
·     In view of geographical locations
An IPv6 admin-scoped zone is a logical zone for particular IPv6 multicast groups with the same scope field value. The IPv6 multicast packets for such IPv6 multicast groups are confined within the local IPv6 admin-scoped zone and cannot cross the boundary of the zone.
Figure 10 Relationship in view of geographical locations
As shown in Figure 10, for the IPv6 multicast groups with the same scope field value, the IPv6 admin-scoped zones must be geographically separated and isolated. The IPv6 global-scoped zone includes all routers in the IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain. IPv6 multicast packets that do not belong to any IPv6 admin-scoped zones are forwarded in the entire IPv6 PIM-SM domain or IPv6 BIDIR-PIM domain.
·     In view of the scope field values
In terms of the scope field values, the scope field in an IPv6 multicast group address shows the zone to which the IPv6 multicast group belongs.
Figure 11 IPv6 multicast address format
An IPv6 admin-scoped zone with a larger scope field value contains an IPv6 admin-scoped zone with a smaller scope field value. The zone with the scope field value of E is the IPv6 global-scoped zone. Table 1 lists the possible values of the scope field.
Table 1 Values of the Scope field
Value
Meaning
Remarks
0, F
Reserved
N/A
1
Interface-local scope
N/A
2
Link-local scope
N/A
3
Subnet-local scope
4
Admin-local scope
5
Site-local scope
6, 7, 9 through D
Unassigned
8
Organization-local scope
E
Global scope
The ASM model includes IPv6 PIM-DM and IPv6 PIM-SM. The SSM model can be implemented by leveraging part of the IPv6 PIM-SM technique. It is also called "IPv6 PIM-SSM."
The SSM model provides a solution for source-specific multicast. It maintains the relationship between hosts and routers through MLDv2.
In actual applications, part of MLDv2 and IPv6 PIM-SM techniques are adopted to implement the SSM model. In the SSM model, because receivers have located an IPv6 multicast source, no RP or RPT is required. No source registration process is required for discovering IPv6 multicast sources in other IPv6 PIM domains.
Neighbor discovery
IPv6 PIM-SSM uses the same neighbor discovery mechanism as IPv6 PIM-SM. For more information, see "Neighbor discovery."
DR election
IPv6 PIM-SSM uses the same DR election mechanism as IPv6 PIM-SM. For more information, see "DR election."
SPT building
The decision to build an RPT for IPv6 PIM-SM or an SPT for IPv6 PIM-SSM depends on whether the IPv6 multicast group that the multicast receiver joins is in the IPv6 SSM group range. The IPv6 SSM group range reserved by IANA is FF3x::/32, where "x" represents any legal address scope.
Figure 12 SPT building in IPv6 PIM-SSM
As shown in Figure 12, Host B and Host C are receivers. They send MLDv2 report messages to their DRs to express their interest in the multicast information that the IPv6 multicast source S sends to the IPv6 multicast group G.
After receiving a report message, the DR first checks whether the group address in the message is in the IPv6 SSM group range and does the following:
·     If the group address is in the IPv6 SSM group range, the DR sends a subscribe message hop by hop toward the IPv6 multicast source S. All routers along the path from the DR to the IPv6 multicast source create an (S, G) entry to build an SPT. The SPT is rooted the IPv6 multicast source S and has the receivers as its leaves. This SPT is the transmission channel in IPv6 PIM-SSM.
·     If the group address is not in the IPv6 SSM group range, the receiver-side DR sends a (*, G) join message to the RP. The IPv6 multicast source registers with the source-side DR.
In IPv6 PIM-SSM, the term "channel" refers to an IPv6 multicast group, and the term "subscribe message" refers to a join message.
In an IPv6 PIM network, IPv6 PIM-DM cannot run together with IPv6 PIM-SM, IPv6 BIDIR-PIM, or IPv6 PIM-SSM. However, IPv6 PIM-SM, IPv6 BIDIR-PIM, and IPv6 PIM-SSM can run together. Figure 13 shows how the device selects one protocol from among them for a receiver trying to join a group.
Figure 13 Relationship among IPv6 PIM protocols
To support IPv6 PIM for VPNs, a multicast router that runs IPv6 PIM maintains an independent set of IPv6 PIM neighbor table, IPv6 multicast routing table, BSR information, and RP-set information for each VPN.
After receiving an IPv6 multicast data packet, the multicast router checks which VPN  the IPv6 data packet belongs to. Then, the router forwards the IPv6 packet according to the IPv6 multicast routing table for that VPN or creates an IPv6 multicast routing entry for that VPN.
·     RFC 3973, Protocol Independent Multicast-Dense Mode (PIM-DM): Protocol Specification(Revised)
·     RFC 4601, Protocol Independent Multicast-Sparse Mode (PIM-SM): Protocol Specification (Revised)
·     RFC 3956, Embedding the Rendezvous Point (RP) Address in an IPv6 Multicast Address
·     RFC 5015, Bidirectional Protocol Independent Multicast (BIDIR-PIM)
·     RFC 5059, Bootstrap Router (BSR) Mechanism for Protocol Independent Multicast (PIM)
·     RFC 4607, Source-Specific Multicast for IP
·     Draft-ietf-ssm-overview-05, An Overview of Source-Specific Multicast (SSM)
This section describes how to configure IPv6 PIM-DM.
Tasks at a glance
(Required.) Enabling IPv6 PIM-SM
(Optional.) Enabling the state refresh feature
(Optional.) Configuring state refresh parameters
(Optional.) Configuring IPv6 PIM-DM graft retry timer
(Optional.) Configuring common IPv6 PIM features
Before you configure IPv6 PIM-DM, configure an IPv6 unicast routing protocol so that all devices in the domain can interoperate at the network layer.
Enable IPv6 multicast routing before configuring IPv6 PIM.
With IPv6 PIM-DM enabled on interfaces, routers can establish IPv6 PIM neighbor relationship and process IPv6 PIM messages from their IPv6 PIM neighbors. When you deploy an IPv6 PIM-DM domain, H3C recommends that you enable IPv6 PIM-DM on all non-border interfaces of routers.
IMPORTANT
IMPORTANT:
All the interfaces on a device must operate in the same IPv6 PIM mode in the public network or the same VPN instance.
To enable IPv6 PIM-DM:
Step
Remarks
N/A
2.     Enable IPv6 multicast routing and enter IPv6 MRIB view.
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
By default, IPv6 multicast routing is disabled.
3.     Return to system view.
4.     Enter interface view.
N/A
5.     Enable IPv6 PIM-DM.
ipv6 pim dm
By default, IPv6 PIM-DM is disabled.
In a PIM-DM domain, this feature enables the router that is directly connected to the source to originate state refresh messages. It also enable other routers to refresh pruned state timers after receiving the state refresh messages. It prevents the pruned interfaces from resuming multicast forwarding. You must enable this feature on all IPv6 PIM routers on a subnet.
To enable the state refresh feature:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Enable the state refresh feature.
ipv6 pim state-refresh-capable
By default, the state refresh feature is enabled.
The state refresh interval determines the interval at which a router sends state refresh messages. It is configurable.
A router might receive duplicate state refresh messages within a short time. To prevent this situation, you can configure the amount of time that the router must wait before receiving the next state refresh message. If the router receives a new state refresh message within the specified waiting time, it discards it. If this timer times out, the router accepts a new state refresh message, refreshes its own IPv6 PIM-DM state, and resets the waiting timer.
The hop limit value of a state refresh message decrements by 1 whenever it passes a router before it is forwarded to the downstream nod. The state refresh message stops being forwarded when the hop limit comes down to 0. A state refresh message with a large hop limit value might cycle on a small network. To control the propagation scope of state refresh messages, configure an appropriate hop limit value based on the network size on the router directly connected with the IPv6 multicast source.
To configure state refresh parameters:
Step
Remarks
N/A
2.     Enter IPv6 PIM view.
ipv6 pim [ vpn-instance vpn-instance-name ]
N/A
3.     Configure the state refresh interval.
The default setting is 60 seconds.
4.     Configure the amount of time to wait before receiving a new state refresh message.
state-refresh-rate-limit time
The default setting is 30 seconds.
5.     Configure the hop limit value of state refresh messages.
state-refresh-hoplimit hoplimit-value
The default setting is 255.
To configure the IPv6 PIM-DM graft retry timer:
Step
Remarks
N/A
N/A
3.     Configure the graft retry timer.
ipv6 pim timer graft-retry interval
By default, the graft retry timer is 3 seconds.
For more information about the configuration of other timers in IPv6 PIM-DM, see "Configuring common IPv6 PIM timers."
This section describes how to configure IPv6 PIM-SM.
Tasks at a glance
Remarks
N/A
(Required.) Configuring an RP:
·     Configuring a static RP
·     Configuring a C-RP
You must configure a static RP, a C-RP, or both in an IPv6 PIM-SM domain.
Configuring a BSR:
·     (Required.) Configuring a C-BSR
·     (Optional.) Configuring an IPv6 PIM domain border
·     (Optional.) Disabling BSM semantic fragmentation
Skip the task of configuring a BSR on a network without C-RPs.
(Optional.) Configuring IPv6 multicast source registration
N/A
(Optional.) Configuring the switchover to SPT
N/A
N/A
Before you configure IPv6 PIM-SM, configure an IPv6 unicast routing protocol so that all devices in the domain can interoperate at the network layer.
With IPv6 PIM-SM enabled on interfaces, routers can establish IPv6 PIM neighbor relationship and process IPv6 PIM messages from their IPv6 PIM neighbors. When you deploy an IPv6 PIM-SM domain, H3C recommends that you enable IPv6 PIM-SM on all non-border interfaces.
IMPORTANT:
All the interfaces on the same router must operate in the same IPv6 PIM mode in the public network or the same VPN instance.
To enable IPv6 PIM-SM:
Step
Remarks
N/A
N/A
5.     Enable IPv6 PIM-SM.
ipv6 pim sm
By default, IPv6 PIM-SM is disabled.
Configuring an RP
An RP can provide services for multiple or all IPv6 multicast groups. However, only one RP at a time can forward IPv6 multicast traffic for an IPv6 multicast group.
An RP can be manually configured or dynamically elected through the BSR mechanism. For a large-scaled IPv6 PIM network, configuring static RPs is a tedious job. Generally, static RPs are backups for dynamic RPs to enhance the robustness and operational manageability on an IPv6 multicast network.
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP can also avoid waste of bandwidth due to frequent message exchange between C-RPs and the BSR.
You must configure the same static RP on all routers in the IPv6 PIM-SM domain.
To configure a static RP:
Step
Remarks
N/A
N/A
3.     Configure a static RP for IPv6 PIM-SM.
static-rp ipv6-rp-address [ acl6-number | preferred ] *
By default, no static RP is configured.
Configuring a C-RP
In an IPv6 PIM-SM domain, if you want a router to become the RP, you can configure the router as a C-RP. H3C recommends that you configure C-RPs on backbone routers.
The C-RPs periodically send advertisement messages to the BSR, which collects RP-set information for the RP election. You can configure the interval for sending the advertisement messages.
The holdtime option in C-RP advertisement messages defines the C-RP lifetime for the advertising C-RP. The BSR starts a holdtime timer for a C-RP after it receives an advertisement message from a C-RP. If the BSR does not receive any advertisement message when the timer expires, it considers the C-RP failed or unreachable.
A C-RP policy enables the BSR to filter C-RP advertisement messages by using an ACL that specifies the IPv6 multicast groups. You must configure the same C-RP policy on all C-BSRs in the IPv6 PIM-SM domain.
When you configure a C-RP, reserve a relatively large bandwidth between the C-RP and the other devices in the IPv6 PIM-SM domain.
To configure a C-RP:
Step
Remarks
N/A
N/A
3.     Configure a C-RP.
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy acl6-number | scope scope-id } | holdtime hold-time | priority priority ] *
By default, no C-RP is configured.
4.     (Optional.) Configure a C-RP policy.
crp-policy acl6-number
By default, C-RP policies are not configured.
Configuring a BSR
You must configure a BSR if C-RPs are configured to dynamically select the RP. You do not need to configure a BSR when you have configured only a static RP but no C-RPs.
An IPv6 PIM-SM domain can have only one BSR, but must have at least one C-BSR. Any router can be configured as a C-BSR. Elected from C-BSRs, the BSR is responsible for collecting and advertising RP information in the IPv6 PIM-SM domain.
Configuring a C-BSR
The BSR election process is summarized as follows:
1.     Initially, each C-BSR regards itself as the BSR of the IPv6 PIM-SM domain and sends BSMs to other routers in the domain.
2.     When a C-BSR receives the BSM from another C-BSR, it compares its own priority with the priority carried in the message. The C-BSR with a higher priority wins the BSR election. If a tie exists in the priority, the C-BSR with a higher IPv6 address wins. The loser uses the winner's BSR address to replace its own BSR address and no longer regards itself as the BSR. The winner retains its own BSR address and continues to regard itself as the BSR.
The elected BSR distributes the RP-set information collected from C-RPs to all routers in the IPv6 PIM-SM domain. All routers use the same hash algorithm to select an RP for a specific IPv6 multicast group from the RP-set.
A BSR policy enables the router to filter BSR messages by using an ACL that specifies the legal BSR addresses. It is used to guards against the following BSR spoofing cases:
·     Some maliciously configured hosts can forge BSMs to fool routers and change RP mappings. Such attacks often occur on border routers.
·     When an attacker controls a router on the network, the attacker can configure the router as a C-BSR to win the BSR election. Through this router, the attacker controls the advertising of RP information.
When you configure a C-BSR, follow these guidelines:
·     Configure C-BSRs on routers that are on the backbone network.
·     Reserve a relatively large bandwidth between the C-BSR and the other devices in the IPv6 PIM-SM domain.
·     You must configure the same BSR policy on all routers in the IPv6 PIM-SM domain. The BSR policy discards illegal BSR messages, but it partially guard against illegal BSR attacks on the network. If an attacker controls a legal BSR, the problem still exists.
To configure a C-BSR:
Step
Remarks
N/A
N/A
3.     Configure a C-BSR.
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
By default, no C-BSR is configured.
4.     (Optional.) Configure a BSR policy.
bsr-policy acl6-number
By default, BSR policies are not configured.
An IPv6 PIM domain border determines the transmission boundary of bootstrap messages from a BSR. Bootstrap messages cannot cross the domain border in either direction. A number of IPv6 PIM domain border interfaces partition a network into different IPv6 PIM-SM domains.
To configure an IPv6 PIM border domain:
Step
Remarks
N/A
N/A
3.     Configuring an IPv6 PIM domain border.
ipv6 pim bsr-boundary
By default, no IPv6 PIM domain border is configured.
BSM semantic fragmentation enables a BSR to split a BSM into multiple BSM fragments (BSMFs) if the BSM exceeds the MTU. In this way, a non-BSR router can update the RP-set information for a group range after receiving all BSMFs for the group range. The loss of one BSMF only affects the RP-set information of the group ranges that the fragment contains.
If the IPv6 PIM-SM domain contains a device that does not support this feature, you must disable BSM semantic fragmentation on all C-BSRs. If you do not disable this feature, such a device regards a BSMF as an entire BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election.
To disable BSM semantic fragmentation:
Step
Remarks
N/A
N/A
3.     Disable BSM semantic fragmentation.
undo bsm-fragment enable
By default, BSM semantic fragmentation is enabled.
Generally, a BSR performs BSM semantic fragmentation according to the MTU of its BSR interface. For BSMs originated due to learning of a new IPv6 PIM neighbor, semantic fragmentation is performed according to the MTU of the interface that sends the BSMs.
An IPv6 PIM register policy enables an RP to filter register messages by using an ACL that specifies the IPv6 multicast sources and groups. The policy limits the IPv6 multicast sources and groups to which an RP is designated. If a register message is denied by the ACL or does not match the ACL, the RP discards the register message and sends a register-stop message to the source-side DR. The registration process stops.
You can configure the device to calculate the checksum based on the entire register message to ensure the information integrity of a register message in the transmission process. If a device that does not support this function is present on the network, configure the device to calculate the checksum based on the register message header.
To configure IPv6 multicast source registration:
Step
Remarks
N/A
N/A
3.     Configure an IPv6 PIM register policy.
register-policy acl6-number
By default, IPv6 PIM register policies are not configured.
4.     Configure the device to calculate the checksum based on the entire register message.
register-whole-checksum
By default, the device calculates the checksum based on the header of a register message.
CAUTION
CAUTION:
If the router is an RP, disabling the switchover to SPT might cause multicast traffic forwarding failures on the source-side DR. When disabling the switchover to SPT, be sure you fully understand its impact on your network.
To configure the switchover to SPT:
Step
Remarks
N/A
N/A
3.     Configure the switchover to SPT.
spt-switch-threshold { immediacy | infinity } [ group-policy acl6-number ]
By default, the device immediately triggers the switchover to SPT after receiving the first IPv6 multicast packet.
This section describes how to configure IPv6 BIDIR-PIM.
Tasks at a glance
Remarks
(Required.) Enabling IPv6 BIDIR-PIM
N/A
·     Setting the maximum number of IPv6 BIDIR-PIM RPs
You must configure a static RP, a C-RP, or both in an IPv6 BIDIR-SM domain.
Configuring a BSR:
N/A
Before you configure IPv6 BIDIR-PIM, configure an IPv6 unicast routing protocol so that all devices in the domain can interoperate at the network layer.
Because IPv6 BIDIR-PIM is implemented on the basis of IPv6 PIM-SM, you must enable IPv6 PIM-SM before enabling IPv6 BIDIR-PIM. When you deploy an IPv6 BIDIR-PIM domain, H3C recommends that you enable IPv6 PIM-SM on all non-border interfaces of the domain.
IMPORTANT
IMPORTANT:
All interfaces on a device must be enabled with the same IPv6 PIM mode.
To enable IPv6 BIDIR-PIM:
Step
Remarks
N/A
2.     Enable IPv6 multicast routing and enter MRIB view.
N/A
N/A
ipv6 pim sm
6.     Return to system view.
N/A
7.     Enter IPv6 PIM view
N/A
8.     Enable IPv6 BIDIR-PIM
bidir-pim enable
By default, IPv6 BIDIR-SM is disabled.
Configuring an RP
CAUTION:
When both IPv6 PIM-SM and IPv6 BIDIR-PIM run on the IPv6 PIM network, do not use the same RP to provide services for IPv6 PIM-SM and IPv6 BIDIR-PIM. Otherwise, exceptions might occur to the IPv6 PIM routing table.
If only one dynamic RP exists on a network, you can configure a static RP to avoid communication interruption caused by single-point failures. The static RP can also avoid bandwidth waste due to frequent message exchange between C-RPs and the BSR. The static RP configuration must be the same on all routers in the IPv6 BIDIR-PIM domain.
In IPv6 BIDIR-PIM, a static RP can be specified with an unassigned IPv6 address. This address must be on the same subnet with the link on which the static RP is configured. For example, if the IPv6 addresses of the interfaces at the two ends of a link are 1001::1/64 and 1001::2/64, you can assign 1001::100/64 to the static RP. As a result, the link becomes an RPL.
Step
Remarks
N/A
N/A
3.     Configure a static RP for IPv6 BIDIR-PIM.
static-rp ipv6-rp-address bidir [ acl6-number | preferred ] *
Configuring a C-RP
IMPORTANT:
·     When you configure a C-RP, reserve a large bandwidth between the C-RP and other devices in the IPv6 BIDIR-PIM domain.
·     H3C recommends that you configure C-RPs on backbone routers.
In an IPv6 BIDIR-PIM domain, if you want a router to become the RP, you can configure the router as a C-RP. The BSR collects the C-RP information according to the received advertisement messages from C-RPs or the auto-RP announcements from other routers. Then, it organizes the C-RP information into the RP-set information, which is flooded throughout the entire network. The other routers in the network can determine the RPs for different IPv6 multicast group ranges based on the RP-set information.
To enable the BSR to distribute the RP-set information in the BIDIR-PIM domain, the C-RPs must periodically send advertisement messages to the BSR. The BSR learns the C-RP information, encapsulates the C-RP information and its own IPv6 address in a BSM, and floods the BSM to all IPv6 PIM routers in the domain.
An advertisement message contains a holdtime option, which defines the C-RP lifetime for the advertising C-RP. After the BSR receives an advertisement message from a C-RP, it starts a timer for the C-RP. If the BSR does not receive any advertisement message when the timer expires, it considers the C-RP failed or unreachable.
Step
Remarks
N/A
N/A
3.     Configure a C-RP to provide services for IPv6 BIDIR-PIM.
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy acl6-number | scope scope-id } | holdtime hold-time | priority priority ] * bidir
In an IPv6 BIDIR-PIM domain, one DF election per RP is implemented on all IPv6 PIM-enabled interfaces. To avoid unnecessary DF elections, H3C recommends not configuring multiple RPs for BIDIR-PIM.
This configuration sets a limit on the number of IPv6 BIDIR-PIM RPs. If the number of RPs exceeds the limit, excess RPs do not take effect and can be used only for DF election rather than IPv6 multicast data forwarding. The system does not delete these excess RPs. They must be deleted manually.
To set the maximum number of RPs:
Step
Remarks
N/A
N/A
3.     Set the maximum number of RPs.
bidir-rp-limit limit
The default setting is 6.
Configuring a BSR
An IPv6 BIDIR-PIM domain can have only one BSR, but must have at least one C-BSR. Any router can be configured as a C-BSR. Elected from C-BSRs, the BSR is responsible for collecting and advertising RP information in the IPv6 BIDIR-PIM domain.
Configuring a C-BSR
IMPORTANT:
Because the BSR and other devices exchange a large amount of information in the IPv6 BIDIR-PIM domain, reserve a large bandwidth between the C-BSR and other devices.
1.     Initially, each C-BSR regards itself as the BSR of the IPv6 BIDIR-PIM domain and sends BSMs to other routers in the domain.
The elected BSR distributes the RP-set information collected from C-RPs to all routers in the IPv6 BIDIR-PIM domain. All routers use the same hash algorithm to select an RP for a specific IPv6 multicast group from the RP-set.
A BSR policy enables the router to filter BSR messages by using an ACL that specifies the legal BSR addresses. It is used to guard against the following BSR spoofing cases:
·     C-BSRs should be configured on routers on the backbone network.
·     You must configure the same BSR policy on all routers in the IPv6 BIDIR-PIM domain. The BSR policy discards illegal BSR messages, but it partially guards against illegal BSR attacks on the network. If an attacker controls a legal BSR, the problem still exists.
Step
Remarks
N/A
N/A
An IPv6 PIM domain border determines the transmission boundary of bootstrap messages from a BSR. Bootstrap messages cannot cross the domain border in either direction. A number of PIM domain border interfaces partition a network into different IPv6 BIDIR-PIM domains.
Step
Remarks
N/A
N/A
3.     Configure an IPv6 PIM domain border.
By default, no PIM domain border is configured.
If the IPv6 BIDIR-PIM domain contains a device that does not support this feature, you must disable BSM semantic fragmentation on all C-BSRs. If you do not disable this feature, such a device regards a BSMF as an entire BSM and updates the RP-set information each time it receives a BSMF. It learns only part of the RP-set information, which further affects the RP election.
Step
Remarks
N/A
N/A
IPv6 PIM-SSM requires MLDv2 support. Enable MLDv2 on IPv6 PIM routers that connect to multicast receivers.
Tasks at a glance
(Optional.) Configuring the IPv6 SSM group range
Before you configure IPv6 PIM-SSM, configure an IPv6 unicast IPv6 routing protocol so that all devices in the domain can interoperate at the network layer.
The implementation of the IPv6 SSM model is based on subsets of IPv6 PIM-SM. Therefore, you must enable IPv6 PIM-SM before configuring IPv6 PIM-SSM.
When you deploy an IPv6 PIM-SSM domain, enable IPv6 PIM-SM on non-border interfaces of the routers.
IMPORTANT
IMPORTANT:
All the interfaces on a device must be enabled with the same IPv6 PIM mode.
Step
Remarks
N/A
2.     Enable IP multicast routing, and enter MRIB view.
N/A
N/A
ipv6 pim sm
When an IPv6 PIM-SM enabled interface receives an IPv6 multicast packet, it checks whether the Ipv6 multicast group address of the packet is in the IPv6 SSM group range. If the IPv6 multicast group address is in this range, the IPv6 PIM mode for this packet is IPv6 PIM-SSM. If the IPv6 multicast group address is not in this range, the IPv6 PIM mode is IPv6 PIM-SM.
Configuration guidelines
When you configure the IPv6 PIM-SSM group range, follow these guidelines:
·     Configure the same IPv6 SSM group range on all routers in the entire PIM-SSM domain. Otherwise, IPv6 multicast information cannot be delivered through the IPv6 SSM model.
·     When a member of an IPv6 multicast group in the IPv6 SSM group range sends an MLDv1 report message, the device does not trigger a (*, G) join.
Configuration procedure
To configure an IPv6 SSM group range:
Step
Remarks
N/A
ipv6 pim
N/A
3.     Configure the IPv6 SSM group range.
ssm-policy acl-number
The default range is FF3x::/32, where x can be any valid scope.
Tasks at a glance
(Optional.) Configuring an IPv6 multicast source policy
(Optional.) Configuring an IPv6 PIM hello policy
(Optional.) Configuring IPv6 PIM hello message options
(Optional.) Configuring common IPv6 PIM timers
(Optional.) Setting the maximum size of each join or prune message
(Optional.) Enabling BFD for IPv6 PIM
(Optional.) Enabling IPv6 PIM passive mode
(Optional.) Enabling IPv6 PIM NSR
Before you configure common IPv6 PIM features, complete the following tasks:
·     Configure an IPv6 unicast routing protocol so that all devices in the domain can interoperate at the network layer.
·     Configure IPv6 PIM-DM, IPv6 PIM-SM, or IPv6 BIDIR-PIM.
This feature enables the router to filter IPv6 multicast data by using an ACL that specifies the IPv6 multicast sources and the optional groups. It filters not only data packets but also register messages with IPv6 multicast data encapsulated. It controls the information available to downstream receivers.
To configure an IPv6 multicast source policy:
Step
Remarks
N/A
N/A
3.     Configure an IPv6 multicast source policy.
source-policy acl6-number
By default, IPv6 multicast source policies are not configured.
This feature enables the router to filter IPv6 PIM hello messages by using an ACL that specifies the packet source addresses. It is used to guard against IPv6 PIM message attacks and to establish correct IPv6 PIM neighboring relationships.
To configure an IPv6 PIM hello policy:
Step
Remarks
N/A
N/A
3.     Configure an IPv6 PIM hello policy.
ipv6 pim neighbor-policy acl6-number
By default, IPv6 PIM hello policies are not configured.
If an IPv6 PIM neighbor's hello messages cannot pass the policy, the neighbor is automatically removed when its maximum number of hello attempts is reached.
In either an IPv6 PIM-DM domain or an IPv6 PIM-SM domain, hello messages exchanged among routers contain the following configurable options:
·     DR_Priority (for IPv6 PIM-SM only)—Priority for DR election. The device with the highest priority wins the DR election. You can configure this option for all the routers in a shared-media LAN that directly connects to the IPv6 multicast source or the receivers.
·     Holdtime—IPv6 PIM neighbor lifetime. If a router receives no hello message from a neighbor when the neighbor lifetime expires, it regards the neighbor failed or unreachable.
·     LAN_Prune_Delay—Delay of pruning a downstream interface on a shared-media LAN. This option has LAN delay, override interval, and neighbor tracking support (the capability to disable join message suppression).
The LAN delay defines the IPv6 PIM message propagation delay. The override interval defines a time period for a downstream router to override a prune message. If the propagation delay or override interval on different IPv6 PIM routers on a shared-media LAN are different, the largest ones apply.
On the shared-media LAN, the propagation delay and override interval are used as follows:
?     If a router receives a prune message on its upstream interface, it means that there are downstream routers on the shared-media LAN. If this router still needs to receive multicast data, it must send a join message to override the prune message within the override interval.
?     When a router receives a prune message from its downstream interface, it does not immediately prune this interface. Instead, it starts a timer (the propagation delay plus the override interval). If interface receives a join message before the timer expires, the router does not prune the interface. Otherwise, the router prunes the interface.
You can enable neighbor tracking on an upstream router to track the states of the downstream nodes of which the joined state holdtime timer has not expired. If you want to enable neighbor tracking, you must enable it on all IPv6 PIM routers on a shared-media LAN. Otherwise, the upstream router cannot track join messages from every downstream routers.
·     Generation ID—A router generates a generation ID for hello messages when an interface is enabled with IPv6 PIM. The generation ID is a random value, but only changes when the status of the router changes. If an IPv6 PIM router finds that the generation ID in a hello message from the upstream router has changed, it assumes that the status of the upstream router has changed. In this case, it sends a join message to the upstream router for status update. You can configure an interface to drop hello messages without the generation ID options to promptly know the status of an upstream router.
You can configure hello message options for all interfaces in IPv6 PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in IPv6 PIM view.
Configuring hello message options globally
Step
Remarks
N/A
N/A
3.     Set the DR priority.
The default setting is 1.
4.     Set the neighbor lifetime.
hello-option holdtime time
The default setting is 105 seconds.
5.     Set the IPv6 PIM message propagation delay.
hello-option lan-delay delay
The default setting is 500 milliseconds.
6.     Set the override interval.
The default setting is 2500 milliseconds.
7.     Enable neighbor tracking.
hello-option neighbor-tracking
By default, neighbor tracking is disabled.
Configuring hello message options on an interface
Step
Remarks
N/A
N/A
ipv6 pim hello-option dr-priority priority
ipv6 pim hello-option holdtime time
ipv6 pim hello-option lan-delay delay
ipv6 pim hello-option override-interval interval
ipv6 pim hello-option neighbor-tracking
8.     Enable dropping hello messages without the Generation ID option.
ipv6 pim require-genid
By default, an interface accepts hello message without the Generation ID option.
IMPORTANT
IMPORTANT:
To prevent the upstream neighbors from aging out, you must configure the interval for sending join/prune messages to be less than the joined/pruned state holdtime timer.
The following are common timers in IPv6 PIM:
·     Hello interval—Interval at which an IPv6 PIM router sends hello messages to discover IPv6 PIM neighbors and maintain IPv6 PIM neighbor relationship.
·     Triggered hello delay—Maximum delay for sending a hello message to avoid collisions caused by simultaneous hello messages. After receiving a hello message, an IPv6 PIM router waits for a random time before sending a hello message. This random time is in the range of 0 to the triggered hello delay.
·     Join/Prune interval—Interval at which an IPv6 PIM router sends join/prune messages to its upstream routers for state update.
·     Joined/Pruned state holdtime—Time for which an IPv6 PIM router keeps the joined/pruned state for the downstream interfaces. This joined/pruned state holdtime is contained in a join/prune message.
·     IPv6 multicast source lifetimeLifetime that an IPv6 PIM router maintains for an IPv6 multicast source. If a router does not receive subsequent IPv6 multicast data from the IPv6 multicast source S when the timer expires, it deletes the (S, G) entry for the IPv6 multicast source.
You can configure common IPv6 PIM timers for all interfaces in IPv6 PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in IPv6 PIM view.
TIP
TIP:
For a network without special requirements, H3C recommends using the defaults.
Configuring common IPv6 PIM timers globally
Step
Remarks
N/A
N/A
3.     Set the hello interval.
timer hello interval
4.     Set the join/prune interval.
timer join-prune interval
This configuration takes effect after the current interval ends.
5.     Set the joined/pruned state holdtime.
holdtime join-prune time
The default setting is 210 seconds.
6.     Set the IPv6 multicast source lifetime.
source-lifetime time
Configuring common IPv6 PIM timers on an interface
Step
Remarks
N/A
N/A
ipv6 pim timer hello interval
4.     Set the triggered hello delay.
ipv6 pim triggered-hello-delay delay
The default setting is 5 seconds.
5.     Set the join/prune interval.
ipv6 pim timer join-prune interval
6.     Set the joined/pruned state holdtime.
ipv6 pim holdtime join-prune time
The loss of an oversized join or prune message might result in loss of massive information. You can set a small value for the size of each join or prune message to reduce the impact.
To set the maximum size of each join or prune message:
Step
Remarks
N/A
N/A
3.     Set the maximum size of each join or prune message.
jp-pkt-size size
By default, the maximum size of a join or prune message is 8100 bytes.
If a DR on a shared-media network fails, a new DR election process will start after the DR is aged out. However, it might take a long period of time before other routers detect the link failures and trigger a new DR election. To start a new DR election process immediately after the original DR fails, you can enable BFD for IPv6 PIM on a shared-media network. The BFD can detect failures of the links among IPv6 PIM neighbors.
You must enable BFD for IPv6 PIM on all IPv6 PIM routers on a shared-media network. For more information about BFD, see High Availability Configuration Guide.
You must enable IPv6 PIM-DM or IPv6 PIM-SM on an interface before you configure this feature on the interface.
To enable BFD for IPv6 PIM:
Step
Remarks
N/A
N/A
3.     Enable BFD for IPv6 PIM.
ipv6 pim bfd enable
By default, BFD is disabled for IPv6 PIM.
To guard against IPv6 PIM hello spoofing, you can enable IPv6 PIM passive mode on an interface which is directly connected to user hosts. The IPv6 PIM passive interface cannot receive or forward IPv6 PIM protocol messages (excluding register, register-stop and C-RP-Adv messages), and it acts as the DR on the subnet. In IPv6 BIDIR-PIM, it also acts as the DF.
When you enable IPv6 PIM passive mode, follow these restrictions and guidelines:
·     This feature takes effect only when IPv6 PIM-DM or IPv6 PIM-SM is enabled on the interface.
·     Do not enable this feature on a shared-media LAN with multiple IPv6 PIM routers. If you do this, the IPv6 PIM passive interface might become a second DR and DF. This cause duplicate data and flow loop.
To enable IPv6 PIM passive mode on an interface:
Step
Remarks
N/A
N/A
3.     Enable IPv6 PIM passive mode on the interface.
ipv6 pim passive
By default, IPv6 PIM passive mode is disabled.
Use this feature to avoid route flapping and forwarding interruption for IPv6 PIM when an active/standby switchover occurs. This feature enables IPv6 PIM to back up protocol state information and data including IPv6 PIM neighbor information and routes from the active process to the standby process. The standby process immediately takes over when the active process fails.
To enable IPv6 PIM NSR:
Step
Remarks
N/A
2.     Enable IPv6 PIM NSR.
ipv6 pim non-stop-routing
By default, IPv6 PIM NSR is disabled.
Displaying and maintaining IPv6 PIM
Display information about the register-tunnel interface.
display interface [ register-tunnel [ interface-number ] ] [ brief [ description| down ] ]
Display BSR information in the IPv6 PIM-SM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
Display information about the routes used by IPv6 PIM.
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
Display C-RP information in the IPv6 PIM-SM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
Display DF information in the IPv6 BIDIR-PIM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] df-info [ ipv6-rp-address ]
Display IPv6 PIM information on an interface.
display ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
Display IPv6 PIM neighbor information.
display ipv6 pim [ vpn-instance vpn-instance-name ] neighbor [ ipv6-neighbor-address | interface interface-type interface-number | verbose ] *
Display information about IPv6 PIM routing entries.
display ipv6 pim [ vpn-instance vpn-instance-name ] routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Display RP information in the IPv6 PIM-SM domain.
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
Display statistics for IPv6 PIM packets.
display ipv6 pim statistics
IPv6 PIM configuration examples
IPv6 PIM-DM configuration example
Network requirements
As shown in Figure 14:
·     OSPFv3 runs on the network.
·     VOD streams are sent to receiver hosts in multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist in each stub network. The entire IPv6 PIM domain is operating in the dense mode.
·     Host A and Host C are multicast receivers in two stub networks N1 and N2.
·     MLDv1 runs between Switch A and N1 and between Switch B, Switch C, and N2.
Figure 14 Network diagram
Table 2 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int100
1001::1/64
Switch C
Vlan-int102
3001::1/64
Switch A
Vlan-int103
1002::1/64
Switch D
Vlan-int300
4001::1/64
Switch B
Vlan-int200
2001::1/64
Switch D
Vlan-int103
1002::2/64
Switch B
Vlan-int101
2002::1/64
Switch D
Vlan-int101
2002::2/64
Switch C
Vlan-int200
2001::2/64
Switch D
Vlan-int102
3001::2/64
1.     Assign an IPv6 address and prefix length to each interface according to Figure 14. (Details not shown.)
2.     Configure OSPFv3 on the switches in the IPv6 PIM-DM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, MLD, and IPv6 PIM-DM:
# On Switch A, enable IPv6 multicast routing globally.
[SwitchA-mrib6] quit
# Enable MLD on the receiver-side interface VLAN-interface 100.
[SwitchA-Vlan-interface100] mld enable
# Enable IPv6 PIM-DM on VLAN-interface 103.
[SwitchA-Vlan-interface103] ipv6 pim dm
# Enable IPv6 multicast routing, MLD, and IPv6 PIM-DM on Switch B and Switch C in the same way Switch A is configured. (Details not shown.)
# On Switch D, enable IPv6 multicast routing, and enable IPv6 PIM-DM on each interface.
<SwitchD> system-view
[SwitchD] ipv6 multicast routing
[SwitchD-mrib6] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] ipv6 pim dm
[SwitchD-Vlan-interface300] quit
[SwitchD-Vlan-interface103] ipv6 pim dm
[SwitchD] interface vlan-interface 101
[SwitchD-Vlan-interface101] ipv6 pim dm
[SwitchD-Vlan-interface101] quit
[SwitchD] interface vlan-interface 102
[SwitchD-Vlan-interface102] ipv6 pim dm
[SwitchD-Vlan-interface102] quit
# Display IPv6 PIM information on Switch D.
[SwitchD] display ipv6 pim interface
 Interface          NbrCnt HelloInt   DR-Pri     DR-Address
 Vlan300            0      30         1          FE80::A01:201:1
                                                 (local)
 Vlan103            0      30         1          FE80::A01:201:2
                                                 (local)
 Vlan101            1      30         1          FE80::A01:201:3
                                                 (local)
 Vlan102            1      30         1          FE80::A01:201:4
                                                 (local)
# Display IPv6 PIM neighboring relationship on Switch D.
[SwitchD] display ipv6 pim neighbor
 Total Number of Neighbors = 3
 Neighbor        Interface           Uptime   Expires  Dr-Priority
 FE80::A01:101:1 Vlan103             00:04:00 00:01:29 1
 FE80::B01:102:2 Vlan101             00:04:16 00:01:29 3
 FE80::C01:103:3 Vlan102             00:03:54 00:01:17 5
# Send an MLD report from Host A to join the IPv6 multicast group FF0E::101. (Details not shown.)
# Send IPv6 multicast data from the IPv6 multicast source 4001::100/64 to the IPv6 multicast group FF0E::101. (Details not shown.)
# Display IPv6 PIM multicast routing table on Switch A.
[SwitchA] display ipv6 pim routing-table
 (*, FF0E::101)
     Protocol: pim-dm, Flag: WC
     UpTime: 00:01:24
     Upstream interface: NULL
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface100
             Protocol: mld, UpTime: 00:01:20, Expires: -
 (4001::100, FF0E::101)
     Protocol: pim-dm, Flag: ACT
     UpTime: 00:01:20
         Upstream neighbor: 1002::2
         RPF prime neighbor: 1002::2
             Protocol: pim-dm, UpTime: 00:01:20, Expires: -
# Display IPv6 PIM multicast routing table information on Switch D.
[SwitchD] display ipv6 pim routing-table
     UpTime: 00:02:19
     Upstream interface: Vlan-interface300
     Total number of downstreams: 2
         1: Vlan-interface103
             Protocol: pim-dm, UpTime: 00:02:19, Expires: -
         2: Vlan-interface102
·     Switches on the SPT path (Switch A and Switch D) have the correct (S, G) entries.
·     Switch A has a correct (*, G) entry.
IPv6 PIM-SM non-scoped zone configuration example
As shown in Figure 15:
·     VOD streams are sent to receiver hosts in multicast. The receivers of different subnets form stub networks, and at least one receiver host exist in each stub network. The entire IPv6 PIM-SM domain contains only one BSR.
·     Host A and Host C are multicast receivers in the stub networks N1 and N2.
·     Specify VLAN-interface 102 on Switch E as a C-BSR and a C-RP. The C-RP is designated to the IPv6 multicast group range FF0E::101/64. Specify VLAN-interface 101 of Switch D as the static RP on all the switches to back up the dynamic RP.
·     MLDv1 runs between Switch A and N1, and between Switch B, Switch C, and N2.
Figure 15 Network diagram
Table 3 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int100
1001::1/64
Switch D
Vlan-int300
4001::1/64
Switch A
Vlan-int101
1002::1/64
Switch D
Vlan-int101
1002::2/64
Switch A
Vlan-int102
1003::1/64
Switch D
Vlan-int105
4002::1/64
Switch B
Vlan-int200
2001::1/64
Switch E
Vlan-int104
3001::2/64
Switch B
Vlan-int103
2002::1/64
Switch E
Vlan-int103
2002::2/64
Switch C
Vlan-int200
2001::2/64
Switch E
Vlan-int102
1003::2/64
Switch C
Vlan-int104
3001::1/64
Switch E
Vlan-int105
4002::2/64
1.     Assign an IPv6 address and prefix length to each interface according to Figure 15. (Details not shown.)
2.     Configure OSPFv3 on all switches in the IPv6 PIM-SM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, MLD, and IPv6 PIM-SM:
# Enable IPv6 PIM-SM on the other interfaces.
[SwitchA-Vlan-interface102] ipv6 pim sm
# Enable IPv6 multicast routing, MLD, and IPv6 PIM-SM on Switch B and Switch C in the same way Switch A is configured. (Details not shown.)
# Enable IPv6 multicast routing and IPv6 PIM-SM on Switch D and Switch E in the same way Switch A is configured. (Details not shown.)
4.     Configure C-BSRs, C-RPs, and the static RP:
# On Switch E, configure the service scope of RP advertisements.
<SwitchE> system-view
[SwitchE] acl ipv6 number 2005
[SwitchE-acl6-basic-2005] rule permit source ff0e::101 64
[SwitchE-acl6-basic-2005] quit
# Configure VLAN-interface 102 as a C-BSR and a C-RP, and configure VLAN-interface 101 of Switch D as the static RP.
[SwitchE] ipv6 pim
[SwitchE-pim6] c-bsr 1003::2
[SwitchE-pim6] c-rp 1003::2 group-policy 2005
[SwitchE-pim6] static-rp 1002::2
[SwitchE-pim6] quit
# On Switch A, configure VLAN-interface 101 of Switch D as the static RP
[SwitchA] ipv6 pim
[SwitchA-pim6] static-rp 1002::2
[SwitchA-pim6] quit
# Configure the static RP on Switch B, Switch C, and Switch D in the same way Switch A is configured. (Details not shown.)
# Display IPv6 PIM information on Switch A.
[SwitchA] display ipv6 pim interface
 Vlan100              0      30         1         FE80::A01:201:1
                                                  (local)
 Vlan101              1      30         1         FE80::A01:201:2
 Vlan102              1      30         1         FE80::A01:201:3
# Display BSR information on Switch A.
[SwitchA] display ipv6 pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 1003::2
       Priority: 64
       Hash mask length: 126
       Uptime: 00:11:18
# Display BSR information on Switch E.
[SwitchE] display ipv6 pim bsr-info
 Scope: non-scoped
     State: Elected
       Priority: 64
       Uptime: 00:11:18
     Candidate BSR address: 1003::2
       Priority: 64
# Display RP information on Switch A.
[SwitchA] display ipv6 pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: FF0E::101/64
       RP address               Priority  HoldTime  Uptime    Expires
       1003::2                  192       150       00:05:19  00:02:11
Static RP information:
       RP address               ACL   Mode    Preferred
       1002::2                  ----  pim-sm  No
IPv6 PIM-SM admin-scoped zone configuration example
As shown in Figure 16:
·     VOD streams are sent to receiver hosts in multicast. The entire IPv6 PIM-SM domain is divided into IPv6 admin-scoped zone 1, IPv6 admin-scoped zone 2, and the IPv6 global-scoped zone. Switch B, Switch C, and Switch D are ZBRs of the three zones, respectively.
·     Source 1 and Source 2 send different IPv6 multicast data to the IPv6 multicast group FF14::101. Host A receives the IPv6 multicast data only from Source 1, and Host B receives the IPv6 multicast data only from Source 2. Source 3 sends IPv6 multicast data to the IPv6 multicast group FF1E::202. Host C is an IPv6 multicast receiver for the IPv6 multicast group FF1E::202.
·     VLAN-interface 101 of Switch B acts as a C-BSR and a C-RP for IPv6 admin-scoped zone 1, and VLAN-interface 105 of Switch D acts as a C-BSR and a C-RP for IPv6 admin-scoped zone 2. Both of the two interfaces are designated to the IPv6 multicast groups with the scope field value of 4. VLAN-interface 109 of Switch F acts as a C-BSR and a C-RP for the IPv6 global-scoped zone, and it is designated to the IPv6 multicast groups with the scope field value of 14.
·     MLDv1 runs between Switch A, Switch E, Switch I, and the receivers that directly connect to them, respectively.
Figure 16 Network diagram
Table 4 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int100
1001::1/64
Switch D
Vlan-int105
3003::2/64
Switch A
Vlan-int101
1002::1/64
Switch D
Vlan-int108
6001::1/64
Switch B
Vlan-int200
2001::1/64
Switch D
Vlan-int107
6002::1/64
Switch B
Vlan-int101
1002::2/64
Switch E
Vlan-int400
7001::1/64
Switch B
Vlan-int103
2002::1/64
Switch E
Vlan-int104
3002::2/64
Switch B
Vlan-int102
2003::1/64
Switch E
Vlan-int108
6001::2/64
Switch C
Vlan-int300
3001::1/64
Switch F
Vlan-int109
8001::1/64
Switch C
Vlan-int104
3002::1/64
Switch F
Vlan-int107
6002::2/64
Switch C
Vlan-int105
3003::1/64
Switch F
Vlan-int102
2003::2/64
Switch C
Vlan-int103
2002::2/64
Switch G
Vlan-int500
9001::1/64
Switch C
Vlan-int106
3004::1/64
Switch G
Vlan-int109
8001::2/64
Switch H
Vlan-int110
4001::1/64
Source 1
2001::100/64
Switch H
Vlan-int106
3004::2/64
Source 2
3001::100/64
Switch I
Vlan-int600
5001::1/64
Source 3
9001::100/64
Switch I
Vlan-int110
4001::2/64
1.     Assign an IPv6 address and prefix length to each interface according to Figure 16. (Details not shown.)
# Enable IPv6 PIM-SM on VLAN-interface 101.
# Enable IPv6 multicast routing, MLD, and IPv6 PIM-SM on Switch E and Switch I in the same way Switch A is configured. (Details not shown.)
# On Switch B, enable IPv6 multicast routing globally, and enable IPv6 PIM-SM on each interface.
[SwitchB] ipv6 multicast routing
[SwitchB-mrib6] quit
[SwitchB-Vlan-interface200] ipv6 pim sm
[SwitchB-Vlan-interface101] ipv6 pim sm
[SwitchB-Vlan-interface102] ipv6 pim sm
[SwitchB] interface vlan-interface 103
[SwitchB-Vlan-interface103] ipv6 pim sm
[SwitchB-Vlan-interface103] quit
# Enable IPv6 multicast routing and IPv6 PIM-SM on Switch C, Switch D, Switch F, Switch G, and Switch H in the same way Switch B is configured. (Details not shown.)
4.     Configure IPv6 admin-scoped zone boundaries:
# On Switch B, configure VLAN-interface 102 and VLAN-interface 103 as the boundaries of IPv6 admin-scoped zone 1.
[SwitchB-Vlan-interface102] ipv6 multicast boundary scope 4
[SwitchB-Vlan-interface103] ipv6 multicast boundary scope 4
# On Switch C, configure VLAN-interface 103 and VLAN-interface 106 as the boundaries of IPv6 admin-scoped zone 2.
[SwitchC] interface vlan-interface 103
[SwitchC-Vlan-interface103] ipv6 multicast boundary scope 4
[SwitchC-Vlan-interface103] quit
[SwitchC] interface vlan-interface 106
[SwitchC-Vlan-interface106] ipv6 multicast boundary scope 4
[SwitchC-Vlan-interface106] quit
# On Switch D, configure VLAN-interface 107 as the boundary of IPv6 admin-scoped zone 2.
[SwitchD] interface vlan-interface 107
[SwitchD-Vlan-interface107] ipv6 multicast boundary scope 4
[SwitchD-Vlan-interface107] quit
5.     Configure C-BSRs and C-RPs:
# On Switch B, configure VLAN-interface 101 as a C-BSR and a C-RP for IPv6 admin-scoped zone 1.
[SwitchB] ipv6 pim
[SwitchB-pim6] c-bsr 1002::2 scope 4
[SwitchB-pim6] c-rp 1002::2 scope 4
[SwitchB-pim6] quit
# On Switch D, configure VLAN-interface 105 as a C-BSR and a C-RP for IPv6 admin-scoped zone 2.
[SwitchD] ipv6 pim
[SwitchD-pim6] c-bsr 3003::2 scope 4
[SwitchD-pim6] c-rp 3003::2 scope 4
[SwitchD-pim6] quit
# On Switch F, configure VLAN-interface 109 as a C-BSR and a C-RP for the IPv6 global-scoped zone.
<SwitchF> system-view
[SwitchF] ipv6 pim
[SwitchF-pim6] c-bsr 8001::1
[SwitchF-pim6] c-rp 8001::1
[SwitchF-pim6] quit
# Display BSR information on Switch B.
[SwitchB] display ipv6 pim bsr-info
 Scope: non-scoped
     Bootstrap timer: 00:01:25
     Elected BSR address: 8001::1
       Priority: 64
       Uptime: 00:01:45
 Scope: 4
     State: Elected
     Bootstrap timer: 00:00:06
     Elected BSR address: 1002::2
       Priority: 64
       Uptime: 00:04:54
     Candidate BSR address: 1002::2
       Priority: 64
# Display BSR information on Switch D.
[SwitchD] display ipv6 pim bsr-info
 Scope: non-scoped
       Priority: 64
       Uptime: 00:01:45
 Scope: 4
     State: Elected
     Elected BSR address: 3003::2
       Priority: 64
       Uptime: 00:01:45
     Candidate BSR address: 3003::2
       Priority: 64
# Display BSR information on Switch F.
[SwitchF] display ipv6 pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:00:49
       Priority: 64
       Uptime: 00:01:11
     Candidate BSR address: 8001::1
       Priority: 64
# Display RP information on Switch B.
[SwitchB] display ipv6 pim rp-info
 BSR RP information:
 Scope: non-scoped
     Group/MaskLen: FF00::/8
       8001::1                  192       180       00:01:14  00:02:46
   Scope: 4
     Group/MaskLen: FF04::/16
       1002::2 (local)          192       180       00:02:03  00:02:56
     Group/MaskLen: FF14::/16
     Group/MaskLen: FF24::/16
     Group/MaskLen: FF34::/16
     Group/MaskLen: FF44::/16
     Group/MaskLen: FF54::/16
     Group/MaskLen: FF64::/16
     Group/MaskLen: FF74::/16
     Group/MaskLen: FF84::/16
     Group/MaskLen: FF94::/16
     Group/MaskLen: FFA4::/16
     Group/MaskLen: FFB4::/16
     Group/MaskLen: FFC4::/16
     Group/MaskLen: FFD4::/16
     Group/MaskLen: FFE4::/16
     Group/MaskLen: FFF4::/16
# Display RP information on Switch F.
[SwitchF] display ipv6 pim rp-info
 BSR RP information:
   Scope: non-scoped
       8001::1 (local)          192       180       00:10:28  00:02:31
IPv6 BIDIR-PIM configuration example
As shown in Figure 17:
·     VOD streams are sent to receiver hosts in IPv6 multicast.
·     Source 1 and Source 2 send IPv6 multicast data to the IPv6 multicast group FF14::101.
·     Host A and Host B are receivers of this IPv6 multicast group.
·     MLDv1 runs between Switch B and Host A and between Switch D and Host B.
Figure 17 Network diagram
Table 5 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int100
1001::1/64
Switch D
Vlan-int300
4001::1/64
Switch A
Vlan-int101
1002::1/64
Switch D
Vlan-int400
5001::1/64
Switch B
Vlan-int200
2001::1/64
Switch D
Vlan-int103
3001::2/64
Switch B
Vlan-int101
1002::2/64
Source 1
1001::2/64
Switch B
Vlan-int102
2002::1/64
Source 2
5001::2/64
Switch C
Vlan-int102
2002::2/64
Receiver 1
2001::2/64
Switch C
Vlan-int103
3001::1/64
Receiver 2
4001::2/64
Switch C
Loop0
6001::1/128
1.     Assign an IPv6 address and prefix length to each interface according to Figure 17. (Details not shown.)
2.     Configure OSPFv3 on the switches in the IPv6 BIDIR-PIM domain. (Details not shown.)
3.     Enable IPv6 multicast routing, IPv6 PIM-SM, IPv6 BIDIR-PIM, and MLD:
# On Switch A, enable IPv6 multicast routing globally, enable IPv6 PIM-SM on each interface, and enable IPv6 BIDIR-PIM.
[SwitchA] ipv6 pim
[SwitchA-pim6] bidir-pim enable
[SwitchA-pim6] quit
# On Switch B, enable IPv6 multicast routing globally.
# Enable MLD on the receiver-side interface VLAN interface 200.
[SwitchB-Vlan-interface200] mld enable
# Enable IPv6 BIDIR-PIM.
[SwitchB] ipv6 pim
[SwitchB-pim6] bidir-pim enable
[SwitchB-pim6] quit
# On Switch C, enable IPv6 multicast routing globally, enable IPv6 PIM-SM on each interface, and enable IPv6 BIDIR-PIM.
[SwitchC-mrib6] quit
[SwitchC-Vlan-interface102] ipv6 pim sm
[SwitchC-Vlan-interface103] ipv6 pim sm
[SwitchC-LoopBack0] ipv6 pim sm
[SwitchC-LoopBack0] quit
[SwitchC] ipv6 pim
[SwitchC-pim6] bidir-pim enable
# On Switch D, enable IPv6 multicast routing globally.
# Enable MLD in VLAN interface 300 (the interface that connects to the receiver host).
[SwitchD-Vlan-interface300] mld enable
[SwitchD-Vlan-interface400] ipv6 pim sm
[SwitchD-Vlan-interface103] ipv6 pim sm
[SwitchD] ipv6 pim
[SwitchD-pim6] bidir-pim enable
[SwitchD-pim6] quit
4.     On Switch C, configure VLAN interface 102 as the C-BSR, and loopback interface 0 as the C-RP for the entire IPv6 BIDIR-PIM domain.
[SwitchC-pim6] c-bsr 2002::2
[SwitchC-pim6] c-rp 6001::1 bidir
[SwitchC-pim6] quit
1.     Display the DF information of BIDIR-PIM:
# Display the DF information of IPv6 BIDIR-PIM on Switch A.
[SwitchA] display ipv6 pim df-info
 RP address: 6001::1
  Interface           State   DF-Pref    DF-Metric  DF-Uptime DF-Address
  Vlan100             Win     100        2          01:08:50  FE80::200:5EFF:
                                                              FE71:2800 (local)
  Vlan101             Lose    100        1          01:07:49  FE80::20F:E2FF:
                                                              FE38:4E01
# Display the DF information of IPv6 BIDIR-PIM on Switch B.
[SwitchB] display ipv6 pim df-info
 RP address: 6001::1
  Vlan200             Win     100        1          01:24:09  FE80::200:5EFF:
                                                              FE71:2801 (local)
  Vlan101             Win     100        1          01:24:09  FE80::20F:E2FF:
                                                              FE38:4E01 (local)
  Vlan102             Lose    0          0          01:23:12  FE80::20F:E2FF:
                                                              FE15:5601
# Display the DF information of IPv6 BIDIR-PIM on Switch C.
[SwitchC] display ipv6 pim df-info
 RP address: 6001::1
  Loop0               -       -          -          -         -
  Vlan102             Win     0          0          01:06:07  FE80::20F:E2FF:
                                                              FE15:5601 (local)
  Vlan103             Win     0          0          01:06:07  FE80::20F:E2FF:
                                                              FE15:5602 (local)
# Display the DF information of IPv6 BIDIR-PIM on Switch D.
[SwitchD] display ipv6 pim df-info
 RP address: 6001::1
  Vlan300             Win     100        1          01:19:53  FE80::200:5EFF:
                                                              FE71:2803 (local)
  Vlan400             Win     100        1          00:39:34  FE80::200:5EFF:
                                                              FE71:2802 (local)
  Vlan103             Lose    0          0          01:21:40  FE80::20F:E2FF:
                                                              FE15:5602
2.     Display information about the DF for IPv6 multicast forwarding:
# Display information about the DF for IPv6 multicast forwarding on Switch A.
[SwitchA] display ipv6 multicast forwarding df-info
Total 1 RP, 1 matched
00001. RP address: 6001::1
     Flags: 0x0
     Uptime: 00:08:32
     RPF interface: Vlan-interface101
     List of 1 DF interfaces:
# Display information about the DF for IPv6 multicast forwarding on Switch B.
[SwitchB] display ipv6 multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:06:24
     RPF interface: Vlan-interface102
     List of 2 DF interfaces:
       1: Vlan-interface101
       2: Vlan-interface200
# Display information about the DF for IPv6 multicast forwarding on Switch C.
[SwitchC] display ipv6 multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:07:21
     RPF interface: LoopBack0
       1: Vlan-interface102
       2: Vlan-interface103
# Display information about the DF for IPv6 multicast forwarding on Switch D.
[SwitchD] display ipv6 multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:05:12
     RPF interface: Vlan-interface103
       1: Vlan-interface300
       2: Vlan-interface400
IPv6 PIM-SSM configuration example
As shown in Figure 18:
·     Receivers receive VOD information through multicast. The receiver groups of different organizations form stub networks, and one or more receiver hosts exist in each stub network. The entire IPv6 PIM domain operates in the SSM mode.
·     Host A and Host C are IPv6 multicast receivers in two stub networks N1 and N2.
·     The SSM group range is FF3E::/64.
·     MLDv2 runs between Switch A and N1 and between Switch B, Switch C, and N2.
Figure 18 Network diagram
Table 6 Interface and IPv6 address assignment
Device
IPv6 address
Device
IPv6 address
Switch A
Vlan-int100
1001::1/64
Switch D
Vlan-int300
4001::1/64
Switch A
Vlan-int101
1002::1/64
Switch D
Vlan-int101
1002::2/64
Switch A
Vlan-int102
1003::1/64
Switch D
Vlan-int105
4002::1/64
Switch B
Vlan-int200
2001::1/64
Switch E
Vlan-int104
3001::2/64
Switch B
Vlan-int103
2002::1/64
Switch E
Vlan-int103
2002::2/64
Switch C
Vlan-int200
2001::2/64
Switch E
Vlan-int102
1003::2/64
Switch C
Vlan-int104
3001::1/64
Switch E
Vlan-int105
4002::2/64
1.     Assign an IPv6 address and prefix length to each interface according to Figure 18. (Details not shown.)
2.     Configure OSPFv3 on the switches in the IPv6 PIM-SSM domain. (Details not shown.)
# Enable MLDv2 on the receiver-side interface VLAN-interface 100.
[SwitchA-Vlan-interface100] mld version 2
4.     Configure the IPv6 SSM group range to be FF3E::/64 on Switch A.
[SwitchA] acl ipv6 number 2000
[SwitchA-acl6-basic-2000] rule permit source ff3e:: 64
[SwitchA-acl6-basic-2000] quit
[SwitchA] ipv6 pim
[SwitchA-pim6] ssm-policy 2000
[SwitchA-pim6] quit
5.     Configure the IPv6 SSM group range on Switch B, Switch C, Switch D, and Switch E in the same way Switch B is configured. (Details not shown.)
                                                  (local)
# Send an MLDv2 report from Host A to join the IPv6 multicast source and group (4001::100/64, FF3E::101). (Details not shown.)
 (4001::100, FF3E::101)
     Protocol: pim-ssm, Flag:
     UpTime: 00:00:11
     Upstream interface: Vlan-interface101
             Protocol: mld, UpTime: 00:00:11, Expires: 00:03:25
# Display IPv6 PIM multicast routing table on Switch B.
     Protocol: pim-ssm, Flag: LOC
     UpTime: 00:08:02
         1: Vlan-interface105
             Protocol: pim-ssm, UpTime: 00:08:02, Expires: 00:03:25
The output shows that switches on the SPT path (Switch A and Switch D) have generated the correct (S, G) entries.
Troubleshooting IPv6 PIM
A multicast distribution tree cannot be correctly built
Symptom
No IPv6 multicast forwarding entries are established on the routers (including routers directly connected with multicast sources or receivers) in an IPv6 PIM network. This means that an IPv6 multicast distribution tree cannot be correctly built.
Solution
To resolve the problem:
1.     Use display ipv6 routing-table to verify that an IPv6 unicast route to the IPv6 multicast source or the RP is available.
2.     Use display ipv6 pim interface to verify IPv6 PIM information on each interface, especially on the RPF interface. If IPv6 PIM is not enabled on the interfaces, use ipv6 pim dm or ipv6 pim sm to enable IPv6 PIM-DM or IPv6 PIM-SM for the interfaces.
3.     Use display ipv6 pim neighbor to verify that the RPF neighbor is an IPv6 PIM neighbor.
4.     Verify that IPv6 PIM and MLD are enabled on the interfaces that directly connect to the IPv6 multicast sources or the receivers.
5.     Use display ipv6 pim interface verbose to verify that the same IPv6 PIM mode is enabled on the RPF interface on a router and the connected interface of the router's RPF neighbor.
6.     Use display current-configuration to verify that the same IPv6 PIM mode is enabled on all routers on the network. For IPv6 PIM-SM, verify that the BSR and C-RPs are correctly configured.
7.     If the problem persists, contact H3C Support.
IPv6 multicast data is abnormally terminated on an intermediate router
Symptom
An intermediate router can receive IPv6 multicast data successfully, but the data cannot reach the last-hop router. An interface on the intermediate router receives IPv6 multicast data but does not create an (S, G) entry in the IPv6 PIM routing table.
Solution
1.     Use display current-configuration to verify the IPv6 multicast forwarding boundary settings. Use ipv6 multicast boundary to change the multicast forwarding boundary settings to make the IPv6 multicast packet able to cross the boundary.
2.     Use display current-configuration to verify the IPv6 multicast source policy. Change the ACL rule defined in the source-policy command so that the source/group address of the IPv6 multicast data can pass ACL filtering.
3.     If the problem persists, contact H3C Support.
An RP cannot join an SPT in IPv6 PIM-SM
Symptom
An RPT cannot be correctly built, or an RP cannot join the SPT toward the IPv6 multicast source.
Solution
1.     Use display ipv6 routing-table to verify that an IPv6 unicast route to the RP is available on each router.
2.     Use display ipv6 pim rp-info to verify that the dynamic RP information is consistent on all routers.
3.     Use display ipv6 pim rp-info to verify that the same static RPs are configured on all routers on the network.
4.     If the problem persists, contact H3C Support.
An RPT cannot be built or IPv6 multicast source registration fails in IPv6 PIM-SM
Symptom
The C-RPs cannot unicast advertisement messages to the BSR. The BSR does not advertise BSMs containing C-RP information and has no IPv6 unicast route to any C-RP. An RPT cannot be correctly established, or the source-side DR cannot register the IPv6 multicast source with the RP.
Solution
1.     Use display ipv6 routing-table to verify that the following conditions are met:
?     The IPv6 unicast routes to the C-RPs and the BSR are available on each router.
?     A route is available between each C-RP and the BSR.
2.     Use display ipv6 pim bsr-info to verify that the BSR information exists on each router.
3.     Use display ipv6 pim rp-info to verify that the RP information is correct on each router.
4.     Use display ipv6 pim neighbor to verify that IPv6 PIM neighboring relationship has been correctly established among the routers.
5.     If the problem persists, contact H3C Support.
