06 IP Multicast Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10006 IP Multicast Configuration Guide
12-IPv6 multicast VLAN configuration
12-IPv6 multicast VLAN configuration 192.62 KB
Overview
As shown in Figure 1, Host A, Host B, and Host C are in different VLANs and the same IPv6 multicast group. When Switch A (Layer 3 device) receives IPv6 multicast data for that group, it sends three copies of the data to Switch B (Layer 2 device). This occupies a large amount of bandwidth and increases the burden on the Layer 3 device.
Figure 1 Multicast transmission without the IPv6 multicast VLAN feature
After an IPv6 multicast VLAN is configured on Switch B, Switch A sends one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. This saves network bandwidth and lessens the burden on the Layer 3 device.
IPv6 multicast VLANs include sub-VLAN-based IPv6 multicast VLANs and port-based IPv6 multicast VLANs.
Sub-VLAN-based IPv6 multicast VLAN
As shown in Figure 2:
·     Host A, Host B, and Host C are in VLAN 2 through VLAN 4, respectively.
·     On Switch B, VLAN 10 is an IPv6 multicast VLAN.
VLAN 2 through VLAN 4 are sub-VLANs of VLAN 10.
MLD snooping is enabled for the multicast VLAN and its sub-VLANs.
Figure 2 Sub-VLAN-based multicast VLAN
MLD snooping manages router ports in the IPv6 multicast VLAN and member ports in each sub-VLAN. When Switch A receives IPv6 multicast data from the multicast source, it sends only one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. Then, Switch B sends a separate copy to each sub-VLAN of the IPv6 multicast VLAN.
Port-based IPv6 multicast VLAN
As shown in Figure 3:
All the user ports are hybrid ports and are assigned to VLAN 10.
MLD snooping is enabled for the IPv6 multicast VLAN and VLAN 2 through VLAN 4.
Figure 3 Port-based IPv6 multicast VLAN
MLD snooping manages the router ports and member ports in the IPv6 multicast VLAN. When Switch A receives IPv6 multicast data from the multicast source, it sends only one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. Then, Switch B sends a separate copy to each user port in the IPv6 multicast VLAN.
IPv6 multicast VLAN configuration task list
Tasks at a glance
(Required.) Perform one of the following tasks:
·     Configuring a sub-VLAN-based IPv6 multicast VLAN
·     Configuring a port-based IPv6 multicast VLAN
¡ Configuring user port attributes
¡ Assigning user ports to an IPv6 multicast VLAN
(Optional.) Setting the maximum number of IPv6 multicast VLAN forwarding entries
If you have configured both a sub-VLAN-based IPv6 multicast VLAN and a port-based IPv6 multicast VLAN on a device, the port-based IPv6 multicast VLAN configuration takes effect.
You must first configure a VLAN as an IPv6 multicast VLAN, and then assign the VLANs that contain multicast receivers to the IPv6 multicast VLAN as sub-VLANs.
Configuration prerequisites
Before you configure a sub-VLAN-based IPv6 multicast VLAN, complete the following tasks:
·     Create VLANs as required.
·     Enable MLD snooping for the VLAN to be configured as the IPv6 multicast VLAN, and for the VLANs to be configured as sub-VLANs.
Configuration guidelines
When you configure a sub-VLAN-based IPv6 multicast VLAN, follow these guidelines:
·     The VLAN to be configured as the IPv6 multicast VLAN must exist.
·     A VLAN to be configured as a sub-VLAN must exist and must not be an IPv6 multicast VLAN or a sub-VLAN of any other IPv6 multicast VLANs.
·     The total number of IPv6 multicast VLANs on a device must not exceed the upper limit.
Configuration procedure
To configure a sub-VLAN-based IPv6 multicast VLAN:
Step
Remarks
N/A
2.     Configure a VLAN as an IPv6 multicast VLAN and enter its view.
ipv6 multicast-vlan vlan-id
By default, a VLAN is not an IPv6 multicast VLAN.
3.     Assign the specified VLANs to the IPv6 multicast VLAN as sub-VLANs.
subvlan vlan-list
By default, an IPv6 multicast VLAN does not have any sub-VLANs.
To configure a port-based IPv6 multicast VLAN, perform the following steps:
1.     Configure a VLAN as an IPv6 multicast VLAN.
2.     Configure the attributes for user ports that are connected to the multicast receivers.
3.     Assign the user ports to the IPv6 multicast VLAN.
You can assign a port to an IPv6 multicast VLAN only when the port is an Ethernet port or a Layer 2 aggregate interface.
Before you configure a port-based IPv6 multicast VLAN, complete the following tasks:
·     Enable MLD snooping for the VLAN to be configured as the IPv6 multicast VLAN.
·     Enable MLD snooping for all the VLANs that contain the multicast receivers.
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure the link type of the user port as hybrid.
port link-type hybrid
The default setting is access.
For more information about this command, see Layer 2—LAN Switching Command Reference.
4.     Specify the PVID of the current user port as the VLAN to which the user port belongs.
port hybrid pvid vlan vlan-id
By default, the PVID for a hybrid port is VLAN 1.
5.     Configure the current user port to permit IPv6 multicast VLAN and to untag the packets.
port hybrid vlan vlan-id-list untagged
By default, a hybrid port permits only VLAN 1.
You can either assign the user ports to the IPv6 multicast VLAN in IPv6 multicast VLAN view, or assign the user ports to the IPv6 multicast VLAN in interface view.
When you perform this task, follow these guidelines:
·     The VLAN to be configured as an IPv6 multicast VLAN must exist.
·     A port can belong to only one IPv6 multicast VLAN.
Assigning ports to an IPv6 multicast VLAN in IPv6 multicast VLAN view
Step
Remarks
N/A
2.     Configure an IPv6 VLAN as an IPv6 multicast VLAN and enter its view.
3.     Assign ports to the IPv6 multicast VLAN.
port interface-list
By default, an IPv6 multicast VLAN does not have any user ports.
Assigning a port to an IPv6 multicast VLAN in interface view
Step
Remarks
N/A
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Assign the current port to the IPv6 multicast VLAN.
ipv6 port multicast-vlan vlan-id
By default, a user port does not belong to any IPv6 multicast VLAN.
You can set the maximum number of IPv6 multicast VLAN forwarding entries on the device. When the upper limit is reached, the device does not create IPv6 multicast VLAN forwarding entries until some entries age out or are manually removed.
If the total number of entries exceeds the upper limit value that you are setting, the system does not automatically remove existing entries or create new entries. In this case, H3C recommends that you remove excess entries manually.
To set the maximum number of IPv6 multicast VLAN forwarding entries:
Step
Remarks
N/A
2.     Set the maximum number of IPv6 multicast VLAN forwarding entries.
ipv6 multicast-vlan entry-limit limit
The default setting is 4000.
Displaying and maintaining IPv6 multicast VLANs
Display information about IPv6 multicast VLANs.
display ipv6 multicast-vlan [ vlan-id ]
Display information about IPv6 multicast groups in IPv6 multicast VLANs.
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | slot slot-number | verbose | vlan vlan-id ] *
Display IPv6 multicast VLAN forwarding entries.
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
Clear IPv6 multicast groups in IPv6 multicast VLANs.
reset ipv6 multicast-vlan group [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | vlan vlan-id ] *
IPv6 multicast VLAN configuration examples
Sub-VLAN-based IPv6 multicast VLAN configuration example
Network requirements
As shown in Figure 4:
·     MLDv1 runs on Layer 3 device Switch A, and MLDv1 snooping runs on Layer 2 device Switch B.
·     Switch A acts as the MLD querier.
·     The IPv6 multicast source sends IPv6 multicast data to the IPv6 multicast group FF1E::101. Receivers Host A, Host B, and Host C belong to VLAN 2, VLAN 3, and VLAN 4, respectively.
Configure a sub-VLAN-based IPv6 multicast VLAN on Switch B to achieve the following goals:
·     Switch A sends the IPv6 multicast data to Switch B through the IPv6 multicast VLAN.
·     Switch B forwards the IPv6 multicast data to the receivers in different user VLANs.
Figure 4 Network diagram
1.     Configure Switch A:
# Enable IPv6 multicast routing.
[SwitchA-mrib6] quit
# Create VLAN 20, and assign FortyGigE 1/1/2 to the VLAN.
[SwitchA] vlan 20
[SwitchA-vlan20] port fortygige 1/1/2
[SwitchA-vlan20] quit
# Assign an IPv6 address to VLAN-interface 20, and enable IPv6 PIM-DM on the interface.
[SwitchA-Vlan-interface20] ipv6 address 1::2 64
[SwitchA-Vlan-interface20] ipv6 pim dm
# Create VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
# Configure FortyGigE 1/1/1 as a hybrid port, and assign it to VLAN 10 as a tagged VLAN member.
[SwitchA] interface fortygige 1/1/1
[SwitchA-FortyGigE1/1/1] port link-type hybrid
[SwitchA-FortyGigE1/1/1] port hybrid vlan 10 tagged
[SwitchA-FortyGigE1/1/1] quit
# Assign an IPv6 address to VLAN-interface 10, and enable MLD on the interface.
[SwitchA-Vlan-interface10] ipv6 address 2001::1 64
[SwitchA-Vlan-interface10] mld enable
2.     Configure Switch B:
# Enable MLD snooping globally.
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 2, assign FortyGigE 1/1/2 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 2
[SwitchB-vlan2] port fortygige 1/1/2
[SwitchB-vlan2] mld-snooping enable
[SwitchB-vlan2] quit
# Create VLAN 3, assign FortyGigE 1/1/3 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 3
[SwitchB-vlan3] port fortygige 1/1/3
[SwitchB-vlan3] mld-snooping enable
[SwitchB-vlan3] quit
# Create VLAN 4, assign FortyGigE1/1/4 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 4
[SwitchB-vlan4] port fortygige 1/1/4
[SwitchB-vlan4] mld-snooping enable
[SwitchB-vlan4] quit
# Create VLAN 10, and enable MLD snooping for the VLAN.
[SwitchB] vlan 10
[SwitchB-vlan10] mld-snooping enable
[SwitchB-vlan10] quit
[SwitchB] interface fortygige 1/1/1
[SwitchB-FortyGigE1/1/1] port link-type hybrid
[SwitchB-FortyGigE1/1/1] port hybrid vlan 10 tagged
[SwitchB-FortyGigE1/1/1] quit
# Configure VLAN 10 as an IPv6 multicast VLAN, and configure VLAN 2 through VLAN 4 as sub-VLANs.
[SwitchB] ipv6 multicast-vlan 10
[SwitchB-ipv6-mvlan-10] subvlan 2 to 4
[SwitchB-ipv6-mvlan-10] quit
# Display information about all IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan
Total 1 IPv6 multicast VLANs.
IPv6 multicast VLAN 10:
  Sub-VLAN list(3 in total):
     2-4
  Port list(0 in total):
# Display IPv6 multicast VLAN forwarding entries on Switch B.
[SwitchB] display ipv6 multicast-vlan group
Total 1 entries.
IPv6 multicast VLAN 10: Total 1 entries.
  (::, FF1E::101)
    Sub-VLANs (3 in total):
      VLAN 2
      VLAN 3
      VLAN 4
The output shows that the IPv6 multicast VLAN (VLAN 10) contains sub-VLANs VLAN 2 through VLAN 4. Switch B will replicate the IPv6 multicast data of VLAN 10 to VLAN 2 through VLAN 4.
Port-based IPv6 multicast VLAN configuration example
As shown in Figure 5:
·     MLDv1 runs on Switch A. MLDv1 snooping runs on Switch B.
Configure a port-based IPv6 multicast VLAN on Switch B to achieve the following goals:
·     Switch A sends IPv6 multicast data to Switch B through the IPv6 multicast VLAN.
Figure 5 Network diagram
[SwitchA] vlan 20
# Create VLAN 10, and assign FortyGigE 1/1/1 to VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] port fortygige 1/1/1
# Create VLAN 10, assign FortyGigE 1/1/1 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 10
[SwitchB-vlan10] port fortygige 1/1/1
# Create VLAN 2, and enable MLD snooping for the VLAN.
[SwitchB] vlan 2
# Create VLAN 3, and enable MLD snooping for the VLAN.
[SwitchB] vlan 3
# Create VLAN 4, and enable MLD snooping for the VLAN.
[SwitchB] vlan 4
# Configure FortyGigE 1/1/2 as a hybrid port, and configure VLAN 2 as the PVID of the hybrid port.
[SwitchB] interface fortygige 1/1/2
[SwitchB-FortyGigE1/1/2] port link-type hybrid
[SwitchB-FortyGigE1/1/2] port hybrid pvid vlan 2
# Assign FortyGigE 1/1/2 to VLAN 2 and VLAN 10 as an untagged VLAN member.
[SwitchB-FortyGigE1/1/2] port hybrid vlan 2 untagged
[SwitchB-FortyGigE1/1/2] port hybrid vlan 10 untagged
[SwitchB-FortyGigE1/1/2] quit
# Configure FortyGigE 1/1/3 as a hybrid port, and configure VLAN 3 as the PVID of the hybrid port.
[SwitchB] interface fortygige 1/1/3
[SwitchB-FortyGigE1/1/3] port link-type hybrid
[SwitchB-FortyGigE1/1/3] port hybrid pvid vlan 3
# Assign FortyGigE 1/1/3 to VLAN 3 and VLAN 10 as an untagged VLAN member.
[SwitchB-FortyGigE1/1/3] port hybrid vlan 3 untagged
[SwitchB-FortyGigE1/1/3] port hybrid vlan 10 untagged
[SwitchB-FortyGigE1/1/3] quit
# Configure FortyGigE 1/1/4 as a hybrid port, and configure VLAN 4 as the PVID of the hybrid port.
[SwitchB] interface fortygige 1/1/4
[SwitchB-FortyGigE1/1/4] port link-type hybrid
[SwitchB-FortyGigE1/1/4] port hybrid pvid vlan 4
# Assign FortyGigE 1/1/4 to VLAN 4 and VLAN 10 as an untagged VLAN member.
[SwitchB-FortyGigE1/1/4] port hybrid vlan 4 untagged
[SwitchB-FortyGigE1/1/4] port hybrid vlan 10 untagged
[SwitchB-FortyGigE1/1/4] quit
# Configure VLAN 10 as an IPv6 multicast VLAN.
# Assign FortyGigE 1/1/2 and FortyGigE 1/1/3 to VLAN 10.
[SwitchB-ipv6-mvlan-10] port fortygige 1/1/2 to fortygige 1/1/3
# Assign FortyGigE 1/1/4 to VLAN 10.
[SwitchB-FortyGigE1/1/4] ipv6 port multicast-vlan 10
# Display information about IPv6 multicast VLANs on Switch B.
  Sub-VLAN list(0 in total):
    FGE1/1/2
    FGE1/1/3
    FGE1/1/4
# Display MLD snooping forwarding entries for the dynamic IPv6 multicast groups on Switch B.
[SwitchB] display mld-snooping group
Total 1 entries.
  (::, FF1E::101)
    Host slots (0 in total):
    Host ports (3 in total):
      FGE1/1/2         (00:03:23)
      FGE1/1/3         (00:04:07)
      FGE1/1/4         (00:04:16)
The output shows that MLD snooping maintains the user ports in VLAN 10. Switch B will forward the IPv6 multicast data of VLAN 10 through these user ports.
