06 IP Multicast Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10006 IP Multicast Configuration Guide
03-PIM snooping configuration
03-PIM snooping configuration 137.53 KB
Overview
PIM snooping runs on Layer 2 devices. It works with IGMP snooping to analyze received PIM messages, and adds the ports that are interested in specific multicast data to a PIM snooping routing entry. In this way, the multicast data can be forwarded to only the ports that are interested in the data.
Figure 1 Multicast packet transmission without or with PIM snooping
As shown in Figure 1, Source 1 sends multicast data to multicast group G1, and Source 2 sends multicast data to multicast group G2. Receiver 1 belongs to G1, and Receiver 2 belongs to G2. The Layer 2 switch's interfaces that connect to the PIM routers are in the same VLAN.
·     When the Layer 2 switch runs only IGMP snooping, it performs the following actions:
a.     Maintains the router ports according to the received PIM hello messages that PIM routers send.
b.     Broadcasts all other types of received PIM messages except PIM hello messages in the VLAN.
c.     Forwards all multicast data to all router ports in the VLAN.
Each PIM router in the VLAN, whether interested in the multicast data or not, can receive all multicast data and all PIM messages except PIM hello messages.
·     When the Layer 2 switch runs both IGMP snooping and PIM snooping, it performs the following actions:
a.     Examines whether a PIM router is interested in the multicast data addressed to a multicast group according to the received PIM messages that the router send.
b.     Adds only the ports that connect to the router and are interested in the data to a PIM snooping routing entry.
c.     Forwards PIM messages and multicast data to only the routers that are interested in the data, which saves network bandwidth.
For more information about IGMP snooping and the router port, see "Configuring IGMP snooping."
PIM snooping can run in PIM-SM and PIM-SSM networks. Do not configure PIM snooping in PIM-DM or BIDIR-PIM networks. For more information about PIM, see "Configuring PIM."
Configuring PIM snooping
To configure PIM snooping for a VLAN, enable IGMP snooping globally on the Layer 2 device and enable IGMP snooping and PIM snooping for the VLAN.
After you enable PIM snooping for a VLAN, PIM snooping works only on the member interfaces of the VLAN.
To configure PIM snooping:
Step
Remarks
N/A
2.     Enable IGMP snooping globally and enter IGMP-snooping view.
igmp-snooping
By default, IGMP snooping is disabled.
3.     Return to system view.
N/A
4.     Enter VLAN view.
vlan vlan-id
N/A
5.     Enable IGMP snooping for the VLAN.
igmp-snooping enable
By default, IGMP snooping is disabled in a VLAN.
6.     Enable PIM snooping for the VLAN.
pim-snooping enable
By default, PIM snooping is disabled in a VLAN.
7.     (Optional.) Set the aging time for the PIM snooping global neighbor ports on the new master device in IRF master election.
pim-snooping graceful-restart neighbor-aging-time interval
The default setting is 105 seconds.
A global neighbor port is a Layer 2 aggregate interface that acts as a neighbor port.
8.     (Optional.) Set the aging time for the PIM snooping global downstream ports and global router ports on the new master device in IRF master election.
pim-snooping graceful-restart join-aging-time interval
The default setting is 210 seconds.
A global downstream port or a global router port is a Layer 2 aggregate interface that acts as a downstream port or router port.
Displaying and maintaining PIM snooping
Display PIM snooping neighbor information.
display pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
Display PIM snooping routing entries.
display pim-snooping routing-table [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
Display PIM snooping router port information.
display pim-snooping router-port [ vlan vlan-id ] [ slot slot-number ]
Display statistics for the PIM messages learned through PIM snooping.
display pim-snooping statistics
Clear statistics for the PIM messages learned through PIM snooping.
reset pim-snooping statistics
PIM snooping configuration example
Network requirements
As shown in Figure 2:
·     OSPF runs on the network.
·     Source 1 sends multicast data to multicast group 224.1.1.1, and Source 2 sends multicast data to multicast group 225.1.1.1.
·     Receiver 1 belongs to multicast group 224.1.1.1, and Receiver 2 belongs to multicast group 225.1.1.1.
·     Router C and Router D run IGMP on FortyGigE 1/1/1. Router A, Router B, Router C, and Router D run PIM-SM.
·     FortyGigE 1/1/2 on Router A acts as a C-BSR and a C-RP.
Configure IGMP snooping and PIM snooping on Switch A. Then, Switch A forwards PIM protocol packets and multicast data packets to only the routers that connect to receivers.
Figure 2 Network diagram
Configuration procedure
1.     Assign an IP address and subnet mask to each interface according to Figure 2. (Details not shown.)
2.     Configure OSPF on all the routers. (Details not shown.)
3.     Configure Router A:
# Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable PIM-SM on each interface.
[RouterA] interface fortygige 1/1/1
[RouterA-FortyGigE1/1/1] pim sm
[RouterA-FortyGigE1/1/1] quit
[RouterA] interface fortygige 1/1/2
[RouterA-FortyGigE1/1/2] pim sm
[RouterA-FortyGigE1/1/2] quit
# Configure FortyGigE 1/1/2 as a C-BSR and a C-RP.
[RouterA] pim
[RouterA-pim] c-bsr 10.1.1.1
[RouterA-pim] c-rp 10.1.1.1
[RouterA-pim] quit
4.     Configure Router B:
<RouterB> system-view
[RouterB] multicast routing
[RouterB-mrib] quit
[RouterB] interface fortygige 1/1/1
[RouterB-FortyGigE1/1/1] pim sm
[RouterB-FortyGigE1/1/1] quit
[RouterB] interface fortygige 1/1/2
[RouterB-FortyGigE1/1/2] pim sm
[RouterB-FortyGigE1/1/2] quit
5.     Configure Router C:
<RouterC> system-view
[RouterC] multicast routing
[RouterC-mrib] quit
# Enable IGMP on FortyGigE 1/1/1.
[RouterC] interface fortygige 1/1/1
[RouterC-FortyGigE1/1/1] igmp enable
[RouterC-FortyGigE1/1/1] quit
# Enable PIM-SM on FortyGigE 1/1/2.
[RouterC] interface fortygige 1/1/2
[RouterC-FortyGigE1/1/2] pim sm
[RouterC-FortyGigE1/1/2] quit
6.     Configure Router D:
<RouterD> system-view
[RouterD] multicast routing
[RouterD-mrib] quit
[RouterD] interface fortygige 1/1/1
[RouterD-FortyGigE1/1/1] igmp enable
[RouterD-FortyGigE1/1/1] quit
[RouterD] interface fortygige 1/1/2
[RouterD-FortyGigE1/1/2] pim sm
[RouterD-FortyGigE1/1/2] quit
7.     Configure Switch A:
# Enable IGMP snooping globally.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Create VLAN 100, assign FortyGigE 1/1/1 through FortyGigE 1/1/4 to the VLAN, and enable IGMP snooping and PIM snooping for the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port fortygige 1/1/1 to fortygige 1/1/4
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] pim-snooping enable
[SwitchA-vlan100] quit
# On Switch A, display information about PIM snooping neighbors for VLAN 100.
[SwitchA] display pim-snooping neighbor vlan 100
Total 4 neighbors.
VLAN 100: Total 4 neighbors.
  10.1.1.1
    Slots (0 in total):
    Ports (1 in total):
      FGE1/1/1                  (00:32:43)
  10.1.1.2
    Slots (0 in total):
    Ports (1 in total):
      FGE1/1/2                  (00:32:43)
  10.1.1.3
    Slots (0 in total):
    Ports (1 in total):
      FGE1/1/3                  (00:32:43)
  10.1.1.4
    Slots (0 in total):
    Ports (1 in total):
      FGE1/1/4                  (00:32:43)
The output shows that Router A, Router B, Router C, and Router D are PIM snooping neighbors.
# On Switch A, display information about PIM snooping routing entries for VLAN 100.
[SwitchA] display pim-snooping routing-table vlan 100
Total 2 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 100: Total 2 entries.
  (*, 224.1.1.1)
    Upstream neighbor: 10.1.1.1
      Upstream Slots (0 in total):
      Upstream Ports (1 in total):
        FGE1/1/1
      Downstream Slots (0 in total):
      Downstream Ports (1 in total):
        FGE1/1/3
          Expires: 00:03:01, FSM: J
  (*, 225.1.1.1)
    Upstream neighbor: 10.1.1.2
        FGE1/1/2
        FGE1/1/4
          Expires: 00:03:11, FSM: J
·     Switch A will forward the multicast data intended for multicast group 224.1.1.1 to only Router C.
·     Switch A will forward the multicast data intended for multicast group 225.1.1.1 to only Router D.
Troubleshooting PIM snooping
PIM snooping does not work on a Layer 2 device
Symptom
PIM snooping does not work on a Layer 2 device.
Solution
To resolve the problem:
1.     Use the display current-configuration command to display information about IGMP snooping and PIM snooping.
2.     If IGMP snooping is not enabled, enable IGMP snooping globally, and then enable IGMP snooping and PIM snooping for the VLAN.
3.     If PIM snooping is not enabled, enable PIM snooping for the VLAN.
4.     If the problem persists, contact H3C Support.
