- 08-ACL and QoS Configuration Examples
- 01-H3C_S7500E_ACL_Configuration_Examples
- 02-H3C_S7500E_Traffic_Filtering_Configuration_Examples
- 03-H3C_S7500E_Control_Plane-Based_QoS_Policy_Configuration_Examples
- 04-H3C_S7500E_Traffic_Policing_Configuration_Examples
- 05-H3C_S7500E_GTS_and_Rate_Limiting_Configuration_Examples
- 06-H3C_S7500E_Congestion_Avoidance_and_Queue_Scheduling_Configuration_Examples
- 07-H3C_S7500E_Priority_and_Queue_Scheduling_Configuration_Examples
06-H3C_S7500E_Congestion_Avoidance_and_Queue_Scheduling_Configuration_Examples | 125.26 KB |
H3C S7500E Congestion Avoidance and Queue Scheduling Configuration Examples
Copyright © 2015 Hangzhou H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
Example: Configuring congestion avoidance and queue scheduling
Network requirements
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
· Voice traffic—Transmitted in VLAN 6 and carries 802.1p priority 6.
· Video traffic—Transmitted in VLAN 4 and carries 802.1p priority 4.
· Data traffic—Transmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
· The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
· WRED drop is used when serious congestion occurs.
Requirements analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
· To assign different types of traffic to different queues, configure the inbound interface to trust the 802.1p priority in packets.
· To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
· To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Traffic type |
Packet color |
Lower limit |
Upper limit |
Drop probability |
Voice |
Yellow |
1000 |
1500 |
3% |
Red |
500 |
1000 |
30% |
Video |
Yellow |
1000 |
1500 |
2% |
Red |
500 |
1000 |
20% |
Data |
Yellow |
1000 |
1500 |
1% |
Red |
500 |
1000 |
10% |
Software version used
This configuration example was created and verified on S7500E-CMW710-R7150.
Configuration procedures
1. Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface ten-gigabitethernet 2/0/1
[Device-Ten-GigabitEthernet2/0/1] port link-type trunk
[Device-Ten-GigabitEthernet2/0/1] port trunk permit vlan 2 4 6
[Device-Ten-GigabitEthernet2/0/1] quit
[Device] interface gigabitethernet 3/0/1
[Device-GigabitEthernet3/0/1] port link-type trunk
[Device-GigabitEthernet3/0/1] port trunk permit vlan 2 4 6
[Device-GigabitEthernet3/0/1] quit
[Device] interface gigabitethernet 3/0/2
[Device-GigabitEthernet3/0/2] port link-type trunk
[Device-GigabitEthernet3/0/2] port trunk permit vlan 2 4 6
[Device-GigabitEthernet3/0/2] quit
2. Configure interface Ten-GigabitEthernet 2/0/1 to trust the 802.1p priority in packets.
[Device-Ten-GigabitEthernet2/0/1] qos trust dot1p
3. Configure WRR on GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2:
# Enable weighted-based WRR on GigabitEthernet 3/0/1.
[Device-GigabitEthernet3/0/1] qos wrr weight
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device-GigabitEthernet3/0/1] display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp TYPE: pre-define DIRECTION: inbound
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-GigabitEthernet3/0/1] qos wrr 1 group 1 weight 2
[Device-GigabitEthernet3/0/1] qos wrr 4 group 1 weight 2
[Device-GigabitEthernet3/0/1] qos wrr 6 group 1 weight 1
# Enable weighted-based WRR on GigabitEthernet 3/0/2.
[Device-GigabitEthernet3/0/2] qos wrr weight
[Device-GigabitEthernet3/0/2] qos wrr 1 group 1 weight 2
[Device-GigabitEthernet3/0/2] qos wrr 4 group 1 weight 2
[Device-GigabitEthernet3/0/2] qos wrr 6 group 1 weight 1
4. Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[Device-GigabitEthernet3/0/1] qos wred apply droppolicy
[Device-GigabitEthernet3/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[Device] display qos queue wrr interface
Interface: display qos queue wrr interface
Interface: GigabitEthernet3/0/1
Output queue: Weighted Round Robin queuing
Queue ID Group Weight
be 1 1
af1 1 2
af2 1 3
af3 1 4
af4 1 4
ef 1 6
cs6 1 6
cs7 1 8
Interface: GigabitEthernet3/0/2
be 1 1
af1 1 2
af2 1 3
af3 1 4
af4 1 4
ef 1 6
cs6 1 6
cs7 1 8
# Display the WRED information for interfaces GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2.
[Device] display qos wred interface
Current WRED configuration:
Applied WRED table name: droppolicy
# Display the WRED table configuration.
[Device] display qos wred table
Table name: droppolicy
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 1000 1500 3 500 1000 30 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 1000 1500 2 500 1000 20 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 1000 1500 1 500 1000 10 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface GigabitEthernet3/0/1
port link-mode bridge
port trunk permit vlan 1 to 2 4 6
qos wrr weight
qos wrr af1 group 1 weight 2
qos wrr af4 group 1 weight 2
qos wrr cs6 group 1 weight 1
interface GigabitEthernet3/0/2
qos wrr weight
interface Ten-GigabitEthernet2/0/1
return
Related documentation
· H3C S7500E Switch Series ACL and QoS Configuration Guide-Release 7150
· H3C S7500E Switch Series ACL and QoS Command Reference-Release 7150
