- 05-Layer 3 - IP Routing Configuration Examples
- 01-H3C_S7500E_BGP_Configuration_Examples
- 02-H3C_S7500E_BGP_Route_Selection_Configuration_Examples
- 03-H3C_S7500E_IPv6_IS-IS_Configuration_Examples
- 04-H3C_S7500E_IS-IS_Configuration_Examples
- 05-H3C_S7500E_IS-IS_Route_Summarization_Configuration_Examples
- 06-H3C_S7500E_OSPFv3_Configuration_Examples
- 07-H3C_S7500E_OSPF_Configuration_Examples
- 08-H3C_S7500E_Policy-Based_Routing_Configuration_Examples
- 09-H3C_S7500E_Routing_Policy_Configuration_Examples
09-H3C_S7500E_Routing_Policy_Configuration_Examples | 126.31 KB |
H3C S7500E Routing Policy Configuration Examples
Copyright © 2015 Hangzhou H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Introduction
This document provides routing policy configuration examples.
Routing policies control routing paths by filtering and modifying routing information. Routing policies can filter advertised, received, and redistributed routes, and modify attributes for specific routes.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of routing polices.
Example: Configuring routing polices
Network requirements
As shown in Figure 1, a company's two departments reside in different ASs. Device A and Device F are the egress devices of the two departments. OSPF is the IGP protocol in AS 100.
· Configure BGP to make the two departments reachable to each other.
· Configure routing polices to specify the link Device B<—>Device C<—>Device D as the primary link to forward traffic between Device A and Device F. When the primary link fails, the link Device B<—>Device E<—>Device D forwards the traffic.
Device |
IP address |
Device |
IP address |
Device A |
Vlan-int100 |
120.1.0.1/24 |
Device D |
Vlan-int20 |
10.2.0.101/24 |
Device B |
Vlan-int10 |
10.1.0.101/24 |
Vlan-int40 |
13.1.1.101/24 |
Vlan-int30 |
192.168.0.101/24 |
Vlan-int100 |
120.2.0.2/24 |
Vlan-int100 |
120.1.0.2/24 |
Device E |
Vlan-int30 |
192.168.0.102/24 |
Device C |
Vlan-int10 |
10.1.0.102/24 |
Vlan-int40 |
13.1.1.102/24 |
Vlan-int20 |
10.2.0.102/24 |
Device F |
Vlan-int100 |
120.2.0.1/24 |
Requirements analysis
To meet the network requirements, you must perform the following tasks:
· Configure the link Device B<—>Device C<—>Device D as the primary link:
¡ On Device B, set the local preference to 200 for the path Device D—>Device C—>Device B. The path Device D—>Device E—>Device B uses the default local preference 100.
¡ On Device D, set the local preference to 200 for the path Device B—>Device C—>Device D. The path Device B—>Device E—>Device D uses the default local preference 100.
· Set a higher preference for IBGP routes to ensure that IBGP routes rather than OSPF external routes are used in AS 100.
Software version used
This configuration example was created and verified on S7500E-CMW710-R7150.
Configuration procedures
Configuring IP addresses
# Configure an IP address for VLAN-interface 100.
[DeviceA] interface vlan-interface100
[DeviceA-Vlan-interface100] ip address 120.1.0.1 24
[DeviceA-Vlan-interface100] quit
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
Configuring OSPF
# Configure Device B.
[DeviceB] ospf
[DeviceB-ospf-1] import-route direct
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
# Configure Device C.
<DeviceC> system-view
[DeviceC] ospf
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 10.1.0.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 10.2.0.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
# Configure Device D.
<DeviceD> system-view
[DeviceD] ospf
[DeviceD-ospf-1] import-route direct
[DeviceD-ospf-1] area 0
[DeviceD-ospf-1-area-0.0.0.0] network 10.2.0.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.0] quit
[DeviceD-ospf-1] quit
# Configure Device E.
<DeviceE> system-view
[DeviceE] ospf
[DeviceE-ospf-1] area 0
[DeviceE-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.0] quit
[DeviceE-ospf-1] quit
Configuring BGP
1. Configure Device A:
# Enable BGP, set the local AS number to 200, and set the router ID for BGP to 1.1.1.1.
[DeviceA] bgp 200
[DeviceA-bgp] router-id 1.1.1.1
# Establish an EBGP connection with Device B.
[DeviceA-bgp] peer 120.1.0.2 as-number 100
# Create the BGP IPv4 unicast address family and enter its view.
[DeviceA-bgp] address-family ipv4 unicast
# Enable Device A to exchange IPv4 unicast routing information with peer 120.1.0.2.
[DeviceA-bgp-ipv4] peer 120.1.0.2 enable
# Inject network 120.1.0.0/24 to the BGP routing table.
[DeviceA-bgp-ipv4] network 120.1.0.0 255.255.255.0
[DeviceA-bgp-ipv4] quit
2. Configure Device B:
# Enable BGP, set the local AS number to 100, and set the router ID for BGP to 2.2.2.2.
[DeviceB] bgp 100
[DeviceB-bgp] router-id 2.2.2.2
# Establish an EBGP connection with Device A.
[DeviceB-bgp] peer 120.1.0.1 as-number 200
# Establish IBGP connections with Device D.
[DeviceB-bgp] peer 10.2.0.101 as-number 100
[DeviceB-bgp] peer 13.1.1.101 as-number 100
[DeviceB-bgp] address-family ipv4 unicast
# Enable Device B to exchange IPv4 unicast routing information with peer 10.2.0.101.
[DeviceB-bgp-ipv4] peer 10.2.0.101 enable
# Specify Device B as the next hop for routes sent to peer 10.2.0.101.
[DeviceB-bgp-ipv4] peer 10.2.0.101 next-hop-local
# Enable Device B to exchange IPv4 unicast routing information with peer 13.1.1.101.
[DeviceB-bgp-ipv4] peer 13.1.1.101 enable
# Specify Device B as the next hop for routes sent to peer 13.1.1.101.
[DeviceB-bgp-ipv4] peer 13.1.1.101 next-hop-local
# Enable Device B to exchange IPv4 unicast routing information with peer 120.1.0.1.
[DeviceB-bgp-ipv4] peer 120.1.0.1 enable
[DeviceB-bgp-ipv4] quit
3. Configure Device D:
# Enable BGP, set the local AS number to 100, and set the router ID for BGP to 4.4.4.4.
[DeviceD] bgp 100
[DeviceD-bgp] router-id 4.4.4.4
# Establish IBGP connections with Device B.
[DeviceD-bgp] peer 10.1.0.101 as-number 100
[DeviceD-bgp] peer 192.168.0.101 as-number 100
# Establish an EBGP connection with Device F.
[DeviceD-bgp] peer 120.2.0.1 as-number 300
[DeviceD-bgp] address-family ipv4 unicast
# Enable Device D to exchange IPv4 unicast routing information with peer 10.1.0.101.
[DeviceD-bgp-ipv4] peer 10.1.0.101 enable
# Specify Device D as the next hop for routes sent to peer 10.1.0.101.
[DeviceD-bgp-ipv4] peer 10.1.0.101 next-hop-local
# Enable Device D to exchange IPv4 unicast routing information with peer 192.168.0.101.
[DeviceD-bgp-ipv4] peer 192.168.0.101 enable
# Specify Device D as the next hop for routes sent to peer 192.168.0.101.
[DeviceD-bgp-ipv4] peer 192.168.0.101 next-hop-local
# Enable Device D to exchange IPv4 unicast routing information with peer 120.2.0.1.
[DeviceD-bgp-ipv4] peer 120.2.0.1 enable
[DeviceD-bgp-ipv4] quit
4. Configure Device F:
# Enable BGP, set the local AS number to 300, and set the router ID for BGP to 6.6.6.6.
<DeviceF> system-view
[DeviceF] bgp 300
[DeviceF-bgp] router-id 6.6.6.6
# Establish an EBGP connection with Device D.
[DeviceF-bgp] peer 120.2.0.2 as-number 100
[DeviceF-bgp] address-family ipv4 unicast
# Inject network 120.2.0.0/24 to the BGP routing table.
[DeviceF-bgp-ipv4] network 120.2.0.0 255.255.255.0
# Enable Device F to exchange IPv4 unicast routing information with peer 120.2.0.2.
[DeviceF-bgp-ipv4] peer 120.2.0.2 enable
[DeviceF-bgp-ipv4] quit
5. Verify BGP peer information on Device B.
[DeviceB] display bgp peer ipv4
BGP local router ID: 2.2.2.2
Local AS number: 100
Total number of peers: 3 Peers in established state: 3
10.2.0.101 100 6 4 0 1 00:00:56 Established
13.1.1.101 100 6 5 0 1 00:00:56 Established
120.1.0.1 200 6 5 0 1 00:00:56 Established
The output shows that Device B has established two IBGP connections with Device D, and an EBGP connection with Device A. The connections are all in Established state.
6. Test the network connectivity between Device A and Device F.
[DeviceA] ping 120.2.0.1
Ping 120.2.0.1 (120.2.0.1): 56 data bytes, press CTRL_C to break
56 bytes from 120.2.0.1: icmp_seq=0 ttl=252 time=1.189 ms
56 bytes from 120.2.0.1: icmp_seq=1 ttl=252 time=1.095 ms
56 bytes from 120.2.0.1: icmp_seq=2 ttl=252 time=1.086 ms
56 bytes from 120.2.0.1: icmp_seq=3 ttl=252 time=1.097 ms
56 bytes from 120.2.0.1: icmp_seq=4 ttl=252 time=1.089 ms
--- Ping statistics for 120.2.0.1 ---
round-trip min/avg/max/std-dev = 1.086/1.111/1.189/0.039 ms
The output shows that Device A and Device F can reach each other.
1. Configure Device B:
# Configure ACL 2000 to permit route 120.1.0.0/24.
[DeviceB] acl number 2000
[DeviceB-acl-basic-2000] rule permit source 120.1.0.0 0.0.0.255
[DeviceB-acl-basic-2000] quit
# Configure routing policy local-pre to set the local preference to 200 for route 120.1.0.0/24.
[DeviceB] route-policy local-pre permit node 10
[DeviceB-route-policy-local-pre-10] if-match ip address acl 2000
[DeviceB-route-policy-local-pre-10] apply local-preference 200
[DeviceB-route-policy-local-pre-10] quit
# Apply routing policy local-pre to routes outgoing to peer 10.2.0.101.
[DeviceB] bgp 100
[DeviceB-bgp-ipv4] peer 10.2.0.101 route-policy local-pre export
# Set the preference for IBGP routes to 100 (higher than the default preference of OSPF external routes 150).
[DeviceB-bgp-ipv4] preference 255 100 130
2. Configure Device D:
# Configure ACL 2000 to permit route 120.2.0.0/24.
[DeviceD] acl number 2000
[DeviceD-acl-basic-2000] rule permit source 120.2.0.0 0.0.0.255
[DeviceD-acl-basic-2000] quit
# Configure routing policy local-pre to set the local preference to 200 for route 120.2.0.0/24.
[DeviceD] route-policy local-pre permit node 10
[DeviceD-route-policy-local-pre-10] if-match ip address acl 2000
[DeviceD-route-policy-local-pre-10] apply local-preference 200
[DeviceD-route-policy-local-pre-10] quit
# Apply routing policy local-pre to routes outgoing to peer 10.1.0.101.
[DeviceD] bgp 100
[DeviceD-bgp-ipv4] peer 10.1.0.101 route-policy local-pre export
[DeviceD-bgp-ipv4] preference 255 100 130
# On Device B, display the BGP routing table.
[DeviceB]display bgp routing-table ipv4
Total number of routes: 3
* >e 120.1.0.0/24 120.1.0.1 0 0 200i
* >i 120.2.0.0/24 10.2.0.101 0 200 0 300i
* i 13.1.1.101 0 100 0 300i
The output shows that Device B has two routes to 120.2.0.0/24 with local preferences 100 and 200.
# Trace the path that traffic traverses from Device A to Device F.
[DeviceA] tracert 120.2.0.1
traceroute to 120.2.0.1 (120.2.0.1), 30 hops at most, 52 bytes each packet, pres
s CTRL_C to break
1 120.1.0.2 (120.1.0.2) 2.208 ms 1.119 ms 1.085 ms
2 10.1.0.102 (10.1.0.102) 1.083 ms 1.100 ms 1.085 ms
3 10.2.0.101 (10.2.0.101) 2.364 ms 1.099 ms 1.086 ms
4 120.2.0.1 (120.2.0.1) 3.825 ms 3.693 ms 4.008 ms
The output shows that traffic is forwarded along the path Device A—>Device B—>Device C—>Device D—>Device F.
# When the primary link fails, display the BGP routing table on Device B.
Total number of routes: 2
* >i 120.2.0.0/24 13.1.1.101 0 100 0 300i
The output shows that Device B has one route to 120.2.0.0/24.
s CTRL_C to break
1 120.1.0.2 (120.1.0.2) 2.308 ms 1.127 ms 1.091 ms
2 192.168.0.102 (192.168.0.102) 1.086 ms 1.102 ms 1.096 ms
3 13.1.1.101 (13.1.1.101) 2.451 ms 2.087 ms 1.092 ms
4 120.2.0.1 (120.2.0.1) 3.533 ms 3.818 ms 4.002 ms
The output shows that traffic is forwarded along the path Device A—>Device B—>Device E—>Device D—>Device F.
Configuration files
· Device A:
vlan 100
interface Vlan-interface100
ip address 120.1.0.1 255.255.255.0
bgp 200
router-id 1.1.1.1
· Device B:
ospf 1
import-route direct
area 0.0.0.0
vlan 10
vlan 30
vlan 100
ip address 10.1.0.101 255.255.255.0
interface Vlan-interface30
ip address 192.168.0.101 255.255.255.0
ip address 120.1.0.2 255.255.255.0
bgp 100
router-id 2.2.2.2
acl number 2000
rule 0 permit source 120.1.0.0 0.0.0.255
· Device C:
ospf 1
area 0.0.0.0
vlan 10
vlan 20
ip address 10.1.0.102 255.255.255.0
interface Vlan-interface20
ip address 10.2.0.102 255.255.255.0
· Device D:
ospf 1
import-route direct
area 0.0.0.0
vlan 20
vlan 40
vlan 100
ip address 10.2.0.101 255.255.255.0
interface Vlan-interface40
ip address 13.1.1.101 255.255.255.0
ip address 120.2.0.2 255.255.255.0
bgp 100
router-id 4.4.4.4
acl number 2000
rule 0 permit source 120.2.0.0 0.0.0.255
· Device E:
ospf 1
area 0.0.0.0
vlan 30
vlan 40
ip address 192.168.0.102 255.255.255.0
ip address 13.1.1.102 255.255.255.0
· Device F:
vlan 100
ip address 120.2.0.1 255.255.255.0
bgp 300
router-id 6.6.6.6
Related documentation
· H3C S7500E Switch Series Layer 3—IP Routing Configuration Guide-Release 7150
· H3C S7500E Switch Series Layer 3—IP Routing Command Reference -Release 7150
