06-IP Multicast Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10006-IP Multicast Configuration Examples
03-H3C S12500 Multicast VPN Configuration Examples
Introduction
This document provides multicast VPN configuration examples.
This document assumes that you have basic knowledge of multicast VPN.
Example: Configuring intra-AS MD VPN
Network requirements
As shown in Figure 1:
·     Customer A has two branches that connect to the MPLS L3VPN network of a service provider.
·     PIM-SM runs within the two branches.
·     The multicast source and the receiver host are in different branches.
Configure intra-AS MD VPN so that the receiver host can receive the multicast data from the source.
Figure 1 Network diagram
Device
IP address
Device
IP address
S 1
10.11.3.2/24
PE 2
VLAN-interface 3
192.168.2.2/24
PE 1
VLAN-interface 2
192.168.1.2/24
PE 2
VLAN-interface 12
10.11.2.1/24
PE 1
VLAN-interface 11
10.11.1.1/24
PE 2
Loopback 1
1.1.1.2/32
PE 1
Loopback 1
1.1.1.1/32
CE a1
VLAN-interface 10
10.11.3.1/24
P
VLAN-interface 2
192.168.1.1/24
CE a1
VLAN-interface 11
10.11.1.2/24
P
VLAN-interface 3
192.168.2.1/24
CE a1
Loopback 0
2.2.2.2/32
P
Loopback 1
3.3.3.3/32
CE a2
VLAN-interface 20
10.11.4.1/24
R 1
10.11.4.2/24
CE a2
VLAN-interface 12
10.11.2.2/24
Requirements analysis
To meet the network requirement, you must run PIM on the devices of the public network, and configure MD VPN on each PE. In addition, make sure the PIM protocol on the public network is independent from the PIM protocol for the VPN instance.
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
When you configure the intra-AS MD VPN, follow these restrictions and guidelines:
·     The MTI interfaces take effect only after the default-group and the MD source interface are specified and the MD source interface obtains the public IP address.
·     You must enable the same PIM mode on all interfaces that belong to the same VPN instance (including the interfaces associated with the VPN instance on the PEs).
·     You must specify the same default-group for the same VPN instance on different PEs.
·     The IP address of the MD source interface must be the same as the source address used for establishing BGP peer relationship. Otherwise, correct routing information cannot be obtained.
·     By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. This example assumes that all these interfaces are already up.
Configuration procedures
1.     Assign an IP address and subnet mask to each interface on CE a1 according to Table 1.
<CEa1> system-view
[CEa1] interface vlan-interface 10
[CEa1-Vlan-interface10] ip address 10.11.3.1 24
[CEa1-Vlan-interface10] quit
[CEa1] interface loopback 0
[CEa1-LoopBack0] ip address 2.2.2.2 32
[CEa1-LoopBack0] quit
[CEa1] interface vlan-interface 11
[CEa1-Vlan-interface11] ip address 10.11.1.2 24
[CEa1-Vlan-interface11] quit
# Configure PE 1, P, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
2.     Configure a unicast routing protocol and basic MPLS VPN on all devices so that all devices are interoperable at the network layer. (Details not shown.)
For more information about configuring basic MPLS VPN, see MPLS Configuration Guide.
3.     Enable IP multicast routing on the public network, and enable PIM-SM on the public network interfaces (including Loopback interfaces):
# On PE 1, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[PE1] multicast routing
[PE1-mrib] quit
[PE1] interface vlan-interface 2
[PE1-Vlan-interface2] pim sm
[PE1-Vlan-interface2] quit
[PE1] interface loopback 1
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# On P, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[P] multicast routing
[P-mrib] quit
[P] interface vlan-interface 2
[P-Vlan-interface2] pim sm
[P-Vlan-interface2] quit
[P] interface vlan-interface 3
[P-Vlan-interface3] pim sm
[P-Vlan-interface3] quit
[P] interface loopback 1
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[P] pim
[P-pim] c-bsr 3.3.3.3
[P-pim] c-rp 3.3.3.3
[P-pim] quit
# On PE 2, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[PE2] multicast routing
[PE2-mrib] quit
[PE2] interface vlan-interface 3
[PE2-Vlan-interface3] pim sm
[PE2-Vlan-interface3] quit
[PE2] interface loopback 1
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
4.     Enable IP multicast routing for the VPN instance, enable PIM-SM on the private network interfaces, and enable IGMP on interfaces that have receiver hosts attached:
# On CE a1, enable IP multicast routing, and enable PIM-SM on each interface.
[CEa1] multicast routing
[CEa1-mrib] quit
[CEa1-Vlan-interface10] pim sm
[CEa1-Vlan-interface11] pim sm
[CEa1-LoopBack0] pim sm
# Configure Loopback 0 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 2.2.2.2
[CEa1-pim] c-rp 2.2.2.2
[CEa1-pim] quit
# On CE a2, enable IP multicast routing, enable PIM-SM on VLAN-interface 12, and enable IGMP on the receiver-side interface VLAN-interface 20.
[CEa2] multicast routing
[CEa2-mrib] quit
[CEa2] interface vlan-interface 12
[CEa2-Vlan-interface12] pim sm
[CEa2-Vlan-interface12] quit
[CEa2] interface vlan-interface 20
[CEa2-Vlan-interface20] igmp enable
[CEa2-Vlan-interface20] quit
# On PE 1, create VPN instance customerA.
[PE1] ip vpn-instance customerA
[PE1-vpn-instance-customerA] route-distinguisher 100:1
[PE1-vpn-instance-customerA] vpn-target 111:1
[PE1-vpn-instance-customerA] quit
# Associate VLAN-interface 11 with VPN instance customerA.
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip binding vpn-instance customerA
[PE1-Vlan-interface11] quit
# Enable IP multicast routing for VPN instance customerA.
[PE1] multicast routing vpn-instance customerA
[PE1-mrib-customerA] quit
# Enable PIM-SM on VLAN-interface 11.
[PE1-Vlan-interface11] pim sm
# On PE 2, create VPN instance customerA.
[PE2] ip vpn-instance customerA
[PE2-vpn-instance-customerA] route-distinguisher 100:1
[PE2-vpn-instance-customerA] vpn-target 111:1
[PE2-vpn-instance-customerA] quit
# Associate VLAN-interface 12 with VPN instance customerA.
[PE2-Vlan-interface12] ip binding vpn-instance customerA
[PE2-Vlan-interface12] quit
[PE2] multicast routing vpn-instance customerA
[PE2-mrib-customerA] quit
# Enable PIM-SM on VLAN-interface 12.
[PE2-Vlan-interface12] pim sm
5.     Configure the MD for the VPN instance:
# On PE 1, create an MD for VPN instance customerA, specify the default-group, MD source interface, and data-group range.
[PE1] multicast-domain vpn-instance customerA
[PE1-md-customerA] default-group 239.1.1.1
[PE1-md-customerA] source loopback 1
[PE1-md-customerA] data-group 225.2.2.0 28
[PE1-md-customerA] quit
# On PE 2, create an MD for VPN instance customerA, and specify the default-group, MD source interface, and data-group range.
[PE2] multicast-domain vpn-instance customerA
[PE2-md-customerA] default-group 239.1.1.1
[PE2-md-customerA] source loopback 1
[PE2-md-customerA] data-group 225.2.2.0 28
[PE2-md-customerA] quit
# Verify the establishment of the default-MDT for the public network on PEs and P. The following example shows PIM routing table for the public network on P.
[P]display pim routing-table
 Total 1 (*, G) entry; 2 (S, G) entry
 (*, 239.1.1.1)
     RP: 3.3.3.3 (local)
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Register
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Total number of downstreams: 2
         1: Vlan-interface2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: -
         2: Vlan-interface3
             Protocol: pim-sm, UpTime: 02:33:57, Expires: -
 (1.1.1.1, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
     Upstream interface: Vlan-interface2
         Upstream neighbor: 192.168.1.2
         RPF prime neighbor: 192.168.1.2
     Downstream interface(s) information: None
(1.1.1.2, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
     Upstream interface: Vlan-interface3
         Upstream neighbor: 192.168.2.2
         RPF prime neighbor: 192.168.2.2
The output shows that an RPT for (*, 239.1.1.1), an SPT for (1.1.1.1, 239.1.1.1), and an SPT for (1.1.1.2, 239.1.1.1) have been established on the public network. The RPT and SPTs constitute the default-MDT for the public network.
Configuration files
·     PE 1:
 vpn-target 111:1 import-extcommunity
 vpn-target 111:1 export-extcommunity
vlan 2
vlan 11
interface LoopBack1
 ip address 1.1.1.1 255.255.255.255
 pim sm
interface Vlan-interface2
 ip address 192.168.1.2 255.255.255.0
 pim sm
interface Vlan-interface11
 ip address 10.11.1.1 255.255.255.0
 pim sm
multicast routing
 source LoopBack1
 data-group 225.1.1.0 255.255.255.240
·     PE 2:
vlan 3
vlan 12
interface LoopBack1
 ip address 1.1.1.2 255.255.255.255
 pim sm
interface Vlan-interface3
 ip address 192.168.2.2 255.255.255.0
 pim sm
interface Vlan-interface12
 ip address 10.11.2.1 255.255.255.0
 pim sm
multicast routing
 source LoopBack1
·     P:
vlan 2 to 3
interface LoopBack1
 ip address 3.3.3.3 255.255.255.255
 pim sm
 pim sm
 ip address 192.168.2.1 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 3.3.3.3
 c-rp 3.3.3.3
·     CE a1:
vlan 10 to 11
interface LoopBack0
 ip address 2.2.2.2 255.255.255.255
 pim sm
interface Vlan-interface10
 ip address 10.11.3.1 255.255.255.0
 pim sm
 ip address 10.11.1.2 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 2.2.2.2
 c-rp 2.2.2.2
·     CE a2:
vlan 12
vlan 20
 ip address 10.11.2.2 255.255.255.0
 pim sm
interface Vlan-interface20
 ip address 10.11.4.1 255.255.255.0
 igmp enable
multicast routing
Example: Configuring inter-AS option A MD VPN
As shown in Figure 2:
·     Customer A has two branches that separately connect to AS 100 and AS 200.
·     ASBR-PE 1 and ASBR-PE 2 are interconnected by using the inter-AS option A solution.
Configure inter-AS option A MD VPN so that the receiver host can receive the multicast data from the source.
Figure 2 Network diagram
Device
IP address
Device
IP address
S 1
10.11.3.2/24
R 1
10.11.4.2/24
PE 1
VLAN-interface 2
192.168.1.2/24
ASBR-PE 2
VLAN-interface 4
192.168.3.2/24
PE 1
VLAN-interface 11
10.11.1.1/24
ASBR-PE 2
VLAN-interface 3
192.168.2.2/24
PE 1
Loopback 1
1.1.1.1/32
ASBR-PE 2
Loopback 1
1.1.1.3/32
ASBR-PE 1
VLAN-interface 2
192.168.1.1/24
ASBR-PE 2
Loopback 2
22.22.22.22/32
ASBR-PE 1
VLAN-interface 3
192.168.2.1/24
PE 2
VLAN-interface 4
192.168.3.1/24
ASBR-PE 1
Loopback 1
1.1.1.2/32
PE 2
VLAN-interface 12
10.11.2.1/24
ASBR-PE 1
Loopback 2
11.11.11.11/32
PE 2
Loopback 1
1.1.1.4/32
CE a1
VLAN-interface 10
10.11.3.1/24
CE a2
VLAN-interface 20
10.11.4.1/24
CE a1
VLAN-interface 11
10.11.1.2/24
CE a2
VLAN-interface 12
10.11.2.2/24
CE a1
Loopback 0
2.2.2.2/32
To meet the network requirement, you must create a separate MD for each AS.
When you configure the inter-AS option A MD VPN, follow these restrictions and guidelines:
·     You must enable the same PIM mode for all interfaces that belong to the same VPN instance (including the interface associated with the VPN instance). You may enable different PIM modes for the public network in different ASs.
·     You must specify the same default-group for the same VPN instance in the same AS. You may specify different default-groups for the same VPN instance in different ASs.
1.     Assign an IP address and subnet mask to each interface on CE a1 according to Table 2.
<CEa1> system-view
# Configure PE 1, ASBR-PE 1, ASBR-PE2, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
2.     Configure a unicast routing protocol and MPLS L3VPN inter-AS option A on all devices so that all devices in the ASs are interoperable at the network layer. (Details not shown)
[PE1-mrib] quit
# On ASBR-PE 1, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[ASBR-PE1] multicast routing
[ASBR-PE1-mrib] quit
[ASBR-PE1] interface vlan-interface 2
[ASBR-PE1-Vlan-interface2] pim sm
[ASBR-PE1-Vlan-interface2] quit
[ASBR-PE1] interface loopback 1
[ASBR-PE1-LoopBack1] pim sm
[ASBR-PE1-LoopBack1] quit
[ASBR-PE1] interface loopback 2
[ASBR-PE1-LoopBack2] pim sm
[ASBR-PE1-LoopBack2] quit
# Configure Loopback 2 as a C-BSR and a C-RP.
[ASBR-PE1] pim
[ASBR-PE1-pim] c-bsr 11.11.11.11
[ASBR-PE1-pim] c-rp 11.11.11.11
[ASBR-PE1-pim] quit
[PE2-mrib] quit
[PE2] interface vlan-interface 4
[PE2-Vlan-interface4] pim sm
[PE2-Vlan-interface4] quit
# On ASBR-PE 2, enable IP multicast routing, and enable PIM-SM on the public network interfaces.
[ASBR-PE2] multicast routing
[ASBR-PE2-mrib] quit
[ASBR-PE2] interface vlan-interface 4
[ASBR-PE2-Vlan-interface4] pim sm
[ASBR-PE2-Vlan-interface4] quit
[ASBR-PE2] interface loopback 1
[ASBR-PE2-LoopBack1] pim sm
[ASBR-PE2-LoopBack1] quit
[ASBR-PE2] interface loopback 2
[ASBR-PE2-LoopBack2] pim sm
[ASBR-PE2-LoopBack2] quit
[ASBR-PE2] pim
[ASBR-PE2-pim] c-bsr 22.22.22.22
[ASBR-PE2-pim] c-rp 22.22.22.22
[ASBR-PE2-pim] quit
4.     Enable IP multicast routing for the VPN instances, enable PIM-SM on the VPN instance interfaces, and enable IGMP on the interfaces that have receiver hosts attached:
The route targets for the same VPN instance on the ASBRs and PEs within the same AS must match. Those within different ASs do not need to match.
# On CE a1, enable IP multicast routing, enable PIM-SM on each interface.
[CEa1-mrib] quit
[CEa1] pim
[CEa1-pim] quit
# On CE a2, enable IP multicast routing, enable PIM-SM on VLAN-interface 12, and enable IGMP on VLAN-interface 20.
[CEa2-mrib] quit
[PE1-vpn-instance-customerA] vpn-target 100:1 both
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on VLAN-interface 11.
[PE2-vpn-instance-customerA] route-distinguisher 12:12
[PE2-vpn-instance-customerA] vpn-target 3:3 import-extcommunity
[PE2-vpn-instance-customerA] vpn-target 3:3 export-extcommunity
[PE2-vpn-instance] quit
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on VLAN-interface 12.
# On ASBR-PE 1, create VPN instance customerA.
[ASBR-PE1] ip vpn-instance customerA
[ASBR-PE1-vpn-instance-customerA] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-customerA] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-customerA] quit
# Associate VLAN-interface 3 with VPN instance customerA.
[ASBR-PE1] interface vlan-interface 3
[ASBR-PE1-Vlan-interface3] ip binding vpn-instance customerA
[ASBR-PE1-Vlan-interface3] quit
# Enable IP multicast routing for VPN instance customerA, and enable PIM-SM on VLAN-interface 3.
[ASBR-PE1] multicast routing vpn-instance customerA
[ASBR-PE1-mrib-customerA] quit
[ASBR-PE1-Vlan-interface3] pim sm
# On ASBR-PE 2, create VPN instance customerA.
[ASBR-PE2] ip vpn-instance customerA
[ASBR-PE2-vpn-vpn-customerA] route-distinguisher 200:1
[ASBR-PE2-vpn-vpn-customerA] vpn-target 200:1 both
[ASBR-PE2-vpn-vpn-customerA] quit
[ASBR-PE2] interface vlan-interface 3
[ASBR-PE2-Vlan-interface3] ip binding vpn-instance customerA
[ASBR-PE2-Vlan-interface3] quit
[ASBR-PE2] multicast routing vpn-instance customerA
[ASBR-PE2-mrib-customerA] quit
[ASBR-PE2-Vlan-interface3] pim sm
# On PE 1, create an MD for VPN instance customerA, and specify the default-group, MD source interface, and data-group range for the MD.
# On ASBR-PE 1, create an MD for VPN instance customerA, and specify the default-group, MD source interface, and data-group range for the MD.
[ASBR-PE1] multicast-domain vpn-instance customerA
[ASBR-PE1-md-customerA] default-group 239.1.1.1
[ASBR-PE1-md-customerA] source loopback 1
[ASBR-PE1-md-customerA] data-group 225.2.2.0 28
[ASBR-PE1-md-customerA] quit
# On PE 2, create an MD for VPN instance customerA, and specify the default-group, MD source interface, and data-group range for the MD.
# On ASBR-PE 2, create an MD for VPN instance customerA, and specify the default-group, MD source interface, and data-group range for the MD.
[ASBR-PE2] multicast-domain vpn-instance customerA
[ASBR-PE2-md-customerA] default-group 239.1.1.1
[ASBR-PE2-md-customerA] source loopback 1
[ASBR-PE2-md-customerA] data-group 225.2.2.0 28
[ASBR-PE2-md-customerA] quit
# Verify that the default-MDT has been established on the public network in each AS on PEs and ASBR-PEs. The following example shows PIM routing table for the public network on ASBR-PE 1.
[ASBR-PE1]display pim routing-table
 (*, 239.1.1.1)
     RP: 11.11.11.11 (local)
     UpTime: 02:54:43
         1: Vlan-interface2
     UpTime: 01:57:13
The output shows that an RPT for (*, 239.1.1.1) and an SPT for (1.1.1.1, 239.1.1.1) have been established on the public network. The RPT and SPT constitute the default-MDT for the public network.
Configuration files
·     PE 1:
 vpn-target 100:1 import-extcommunity
 vpn-target 100:1 export-extcommunity
vlan 2
vlan 11
interface LoopBack1
 pim sm
 pim sm
 pim sm
multicast routing
 source LoopBack1
·     PE 2:
 route-distinguisher 200:2
 vpn-target 200:2 import-extcommunity
 vpn-target 200:2 export-extcommunity
vlan 4
vlan 12
interface LoopBack1
 ip address 1.1.1.4 255.255.255.255
 pim sm
interface Vlan-interface4
 ip address 192.168.3.1 255.255.255.0
 pim sm
 pim sm
multicast routing
 source LoopBack1
·     ASBR-PE 1:
vlan 2 to 3
interface LoopBack1
 pim sm
interface LoopBack2
 ip address 11.11.11.11 255.255.255.255
 pim sm
 pim sm
 pim sm
multicast routing
pim
 c-bsr 11.11.11.11
 c-rp 11.11.11.11
 source LoopBack1
·     ASBR-PE 2:
 vpn-target 200:1 import-extcommunity
 vpn-target 200:1 export-extcommunity
vlan 3 to 4
interface LoopBack1
 ip address 1.1.1.3 255.255.255.255
 pim sm
interface LoopBack2
 ip address 22.22.22.22 255.255.255.255
 pim sm
 pim sm
 ip address 192.168.3.2 255.255.255.0
 pim sm
multicast routing
pim
 c-bsr 22.22.22.22
 c-rp 22.22.22.22
 source LoopBack1
·     CE a1:
vlan 10 to 11
interface LoopBack0
 pim sm
 pim sm
 pim sm
multicast routing
pim
 c-bsr 2.2.2.2
 c-rp 2.2.2.2
·     CE a2:
vlan 12
vlan 20
 pim sm
 igmp enable
multicast routing
Example: Configuring inter-AS option C MD VPN
As shown in Figure 3:
·     ASBR-PE 1 and ASBR-PE 2 are interconnected by using the inter-AS option C solution.
Configure inter-AS option C MD VPN so that the receiver host can receive the multicast data from the source.
Figure 3 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.11.3.2/24
R 1
10.11.4.2/24
PE 1
VLAN-interface 2
192.168.1.2/24
ASBR-PE2
VLAN-interface 4
192.168.3.2/24
PE 1
VLAN-interface 11
10.11.1.1/24
ASBR-PE2
VLAN-interface 3
192.168.2.2/24
PE 1
Loopback 1
1.1.1.1/32
ASBR-PE2
Loopback 1
1.1.1.3/32
ASBR-PE1
VLAN-interface 2
192.168.1.1/24
ASBR-PE2
Loopback 2
22.22.22.22/32
ASBR-PE1
VLAN-interface 3
192.168.2.1/24
PE 2
VLAN-interface 4
192.168.3.1/24
ASBR-PE1
Loopback 1
1.1.1.2/32
PE 2
VLAN-interface 12
10.11.2.1/24
ASBR-PE1
Loopback 2
11.11.11.11/32
PE 2
Loopback 1
1.1.1.4/32
CE a1
VLAN-interface 10
10.11.3.1/24
CE a2
VLAN-interface 20
10.11.4.1/24
CE a1
VLAN-interface 11
10.11.1.2/24
CE a2
VLAN-interface 12
10.11.2.2/24
CE a1
Loopback 0
2.2.2.2/32
To meet the network requirement, you must perform the following tasks:
·     Create the same MD for each AS.
·     Establish MSDP peering relationships between the RPs in the ASs to share the multicast source information in different PIM-SM domains.
When you configure inter-AS option C MD VPN, follow these restrictions and guidelines:
·     If the system operates in standard mode, you must specify a different reserved VLAN for each VPN instance. Otherwise, system exceptions might occur.
Do not change the reserved VLAN for a VPN instance. Otherwise, you must reconfigure the multicast VPN.
For more information about reserved VLANs, see MPLS Configuration Guide. For more information about system operating modes, see Fundamentals Configuration Guide.
1.     Assign an IP address and subnet mask to each interface on CE a1 according to Table 3.
<CEa1> system-view
# Configure PE 1, ASBR-PE 1, ASBR-PE 2, PE 2, and CE a2 in the same way CE a1 is configured. (Details not shown.)
2.     Configure a unicast routing protocol and basic MPLS VPN on all devices so that all devices are interoperable at the network layer. (Details not shown)
3.     Enable IP multicast routing on the public network in each AS, enable PIM-SM on the public network interfaces (including Loopback interfaces), and configure PIM-SM domain boarders:
[PE1-mrib] quit
[ASBR-PE1] pim
[ASBR-PE1-pim] quit
# Configure VLAN-interface 3 as a PIM-SM domain boarder.
[ASBR-PE1-Vlan-interface3] pim bsr-boundary
[PE2-mrib] quit
[ASBR-PE2] pim
[ASBR-PE2-pim] quit
[ASBR-PE2-Vlan-interface3] pim bsr-boundary
4.     Establish MSDP peering relationships between the RPs on the public network in the ASs:
# On ASBR-PE 1, specify an MSDP peer.
[ASBR-PE1] msdp
[ASBR-PE1-msdp] encap-data-enable
[ASBR-PE1-msdp] peer 192.168.2.2 connect-interface vlan-interface 3
# On ASBR-PE 2, specify an MSDP peer.
[ASBR-PE2] msdp
[ASBR-PE2-msdp] encap-data-enable
[ASBR-PE2-msdp] peer 192.168.2.1 connect-interface vlan-interface 3
5.     Enable IP multicast routing for the VPN instance, enable PIM-SM on the private network interfaces, and enable IGMP on the interfaces that have receiver hosts attached:
[CEa1-mrib] quit
[CEa1] pim
[CEa1-pim] quit
[CEa2-mrib] quit
[PE1-vpn-instance-customerA] route-distinguisher 11:11
[PE1-vpn-instance-customerA] vpn-target 3:3 import-extcommunity
[PE1-vpn-instance-customerA] vpn-target 3:3 export-extcommunity
6.     Create the same MD for the ASs, and specify the default-group, MD source interface, and data-group for the MD:
# On PE 1, create an MD for the VPN instance customerA, and specify the default-group, MD source interface, and data-group.
# On PE 2, create an MD for VPN instance customerA, and specify the default-group, MD source interface, and data-group.
 (*, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 02:54:43
         1: Vlan-interface2
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
(1.1.1.4, 239.1.1.1)
     RP: 3.3.3.3 (local)
     UpTime: 01:57:13
The output shows that an RPT for (*, 239.1.1.1), an SPT for (1.1.1.1, 239.1.1.1), and an SPT for (1.1.1.4, 239.1.1.1) have been established on the public network. The RPT and SPTs constitute the default-MDT for the public network.
Configuration files
·     PE 1:
vlan 2
vlan 11
interface LoopBack1
 pim sm
 pim sm
 pim sm
multicast routing
 source LoopBack1
·     PE 2:
vlan 4
vlan 12
interface LoopBack1
 pim sm
 pim sm
 pim sm
multicast routing
 source LoopBack1
·     ASBR-PE 1:
vlan 2 to 3
interface LoopBack1
 pim sm
interface LoopBack2
 pim sm
 pim sm
 pim sm
 pim bsr-boundary
multicast routing
pim
 c-bsr 11.11.11.11
 c-rp 11.11.11.11
msdp
 encap-data-enable
 peer 192.168.2.2 connect-interface Vlan-interface3
·     ASBR-PE 2:
vlan 3 to 4
interface LoopBack1
 pim sm
interface LoopBack2
 pim sm
 pim sm
 pim bsr-boundary
 pim sm
multicast routing
pim
 c-bsr 22.22.22.22
 c-rp 22.22.22.22
msdp
 encap-data-enable
 peer 192.168.2.1 connect-interface Vlan-interface3
·     CE a1:
vlan 10 to 11
interface LoopBack0
 pim sm
 pim sm
 pim sm
multicast routing
pim
 c-bsr 2.2.2.2
 c-rp 2.2.2.2
·     CE a2:
vlan 12
vlan 20
 pim sm
 igmp enable
multicast routing
Related documentation
·     H3C S12500 Routing Switch Series IP Multicast Command Reference Release 7328
·     H3C S12500 Routing Switch Series IP Multicast Configuration Guide Release 7328
