- 06-IP Multicast Configuration Examples
- 00-H3C S12500 IGMP Snooping Configuration Examples
- 01-H3C S12500 IGMP Configuration Examples
- 02-H3C S12500 BIDIR-PIM Configuration Examples
- 03-H3C S12500 Multicast VPN Configuration Examples
- 04-H3C S12500 MLD Snooping Configuration Examples
- 05-H3C S12500 IPv6 Multicast VLAN Configuration Examples
| 04-H3C S12500 MLD Snooping Configuration Examples | 210.08 KB |
Example: Configuring IPv6 multicast group policies
Example: Configuring IPv6 static ports
Introduction
This document introduces MLD snooping configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of MLD snooping.
Network requirements
As shown in Figure 1:
· Router A runs MLDv1 and acts as the MLD querier in VLAN 100.
· Switch A runs MLDv1 snooping.
Configure an IPv6 multicast group policy on Switch A so that Host A and Host B receive only the IPv6 multicast data addressed to the group FF1E::101.
Requirements analysis
To meet the network requirements, you must perform the following tasks:
· To avoid receiver hosts in VLAN 100 from receiving IPv6 multicast data addressed to other groups, enable dropping unknown IPv6 multicast data in VLAN 100.
· To configure an IPv6 multicast group policy, specify an IPv6 basic ACL and create ACL rules to define the groups you want the receiver hosts to join.
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
When you configure IPv6 multicast group polices, follow these restrictions and guidelines:
· You must globally enable MLD snooping in system view before you enable MLD snooping for a VLAN in VLAN view.
· The IPv6 multicast group policy denies all groups if the specified ACL does not exist or the ACL does not have any rules.
Configuration procedures
1. Assign an IPv6 address and prefix length to each interface on the routers in the IPv6 PIM-DM domain. (Details not shown.)
2. Configure an IPv6 unicast routing protocol on the routers in the IPv6 PIM-DM domain. (Details not shown.)
3. Enable IPv6 multicast routing globally on the routers in the IPv6 PIM-DM domain. (Details not shown.)
4. Enable IPv6 PIM-DM for the interfaces through which routers connects with each other on the routers in the IPv6 PIM-DM domain. (Details not shown.)
5. Configure Switch A:
# Enable MLD snooping globally.
[SwitchA] mld-snooping
[SwitchA-mld-snooping] quit
# Create VLAN 100, and assign GigabitEthernet 3/0/1 through GigabitEthernet 3/0/4 to this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 3/0/1 to gigabitethernet 3/0/4
# Enable MLD snooping and dropping unknown IPv6 multicast data for VLAN 100.
[SwitchA-vlan100] mld-snooping drop-unknown
[SwitchA-vlan100] quit
# Bring up GigabitEthernet 3/0/1 through GigabitEthernet 3/0/4.
[SwitchA] interface gigabitethernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] undo shutdown
[SwitchA-GigabitEthernet3/0/1] quit
[SwitchA] interface gigabitethernet 3/0/2
[SwitchA-GigabitEthernet3/0/2] undo shutdown
[SwitchA-GigabitEthernet3/0/2] quit
[SwitchA] interface gigabitethernet 3/0/3
[SwitchA-GigabitEthernet3/0/3] undo shutdown
[SwitchA-GigabitEthernet3/0/3] quit
[SwitchA] interface gigabitethernet 3/0/4
[SwitchA-GigabitEthernet3/0/4] undo shutdown
[SwitchA-GigabitEthernet3/0/4] quit
# Configure an IPv6 multicast group policy for VLAN 100 so that receiver hosts in this VLAN can join only the group FF1E::101.
[SwitchA] acl ipv6 number 2001
[SwitchA-acl6-basic-2001] rule permit source ff1e::101 128
[SwitchA-acl6-basic-2001] quit
[SwitchA–mld-snooping] group-policy 2001 vlan 100
[SwitchA–mld-snooping] quit
# Send MLD reports from Host A and Host B to join the groups FF1E::101 and FF1E::202. (Details not shown.)
# Send IPv6 multicast data from the source to the groups FF1E::101 and FF1E::202. (Details not shown.)
# Display dynamic MLD snooping forwarding entries for VLAN 100 on Switch A.
[SwitchA] display mld-snooping group vlan 100
Total 1 entries.
VLAN 100: Total 1 entries.
(::, FF1E::101)
Host slots (1 in total):
3
Host ports (2 in total):
GE3/0/3 (00:03:23)
GE3/0/4 (00:04:10)
The output shows that Host A and Host B have joined the group FF1E::101 through the member ports GigabitEthernet 3/0/4 and GigabitEthernet 3/0/3, respectively. Host A and Host B do not join the group FF1E::202. The IPv6 multicast group policy has taken effect.
Configuration files
rule 0 permit source FF1E::101/128
mld-snooping
vlan 100
mld-snooping enable
interface GigabitEthernet3/0/1
port link-mode bridge
port access vlan 100
interface GigabitEthernet3/0/2
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
As shown in Figure 2:
· All switches in VLAN 100 run MLD snooping.
· Router A runs MLDv1 and acts as the MLD querier.
· STP runs in VLAN 100. The path of Switch A—Switch B is blocked to avoid loops.
Configure MLD snooping static ports to meet the following requirements:
· IPv6 multicast data uninterruptedly flows to Host A and Host B after a link switchover occurs between Switch A and Switch B.
· Host A and Host B permanently receive the IPv6 multicast data addressed to the group FF1E::101.
· By default, when a link switchover occurs, multicast data can flow along the new link after a minimum of one MLD query-response cycle. Multicast delivery is interrupted during this process.
Configure GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 on Switch A and GigabitEthernet 3/0/2 on Switch C as static router ports. Then, IPv6 multicast data will always be forwarded to these ports, and multicast delivery is uninterrupted.
· Configure GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 on Switch B as static member ports of the group FF1E::101. Then, IPv6 multicast data for the group will always be forwarded out of these ports, and Host A and Host B can always receiver the data.
# Create VLAN 100, assign GigabitEthernet 3/0/1 through GigabitEthernet 3/0/4 to this VLAN, and enable MLD snooping for this VLAN.
[SwitchA] vlan 100
# Configure GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 as static router ports.
[SwitchA-GigabitEthernet3/0/2] mld-snooping static-router-port vlan 100
[SwitchA-GigabitEthernet3/0/3] mld-snooping static-router-port vlan 100
6. Configure Switch B:
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 100, assign GigabitEthernet 3/0/1 and GigabitEthernet 3/0/4 to this VLAN, and enable MLD snooping for this VLAN.
[SwitchB] vlan 100
[SwitchB-vlan100] port gigabitethernet 3/0/1 gigabitethernet 3/0/4
[SwitchB-vlan100] mld-snooping enable
[SwitchB-vlan100] quit
[SwitchB] interface gigabitethernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] undo shutdown
[SwitchB-GigabitEthernet3/0/1] quit
[SwitchB] interface gigabitethernet 3/0/2
[SwitchB-GigabitEthernet3/0/2] undo shutdown
[SwitchB-GigabitEthernet3/0/2] quit
[SwitchB] interface gigabitethernet 3/0/3
[SwitchB-GigabitEthernet3/0/3] undo shutdown
[SwitchB-GigabitEthernet3/0/3] quit
[SwitchB] interface gigabitethernet 3/0/4
[SwitchB-GigabitEthernet3/0/4] undo shutdown
[SwitchB-GigabitEthernet3/0/4] quit
# Configure GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 as static member ports for the group FF1E::101 in VLAN 100.
[SwitchB-GigabitEthernet3/0/2] mld-snooping static-group ff1e::101 vlan 100
[SwitchB-GigabitEthernet3/0/3] mld-snooping static-group ff1e::101 vlan 100
7. Configure Switch C:
[SwitchC] mld-snooping
[SwitchC-mld-snooping] quit
[SwitchC] vlan 100
[SwitchC-vlan100] port gigabitethernet 3/0/1 to gigabitethernet 3/0/4
[SwitchC-vlan100] mld-snooping enable
[SwitchC-vlan100] quit
[SwitchC] interface gigabitethernet 3/0/1
[SwitchC-GigabitEthernet3/0/1] undo shutdown
[SwitchC-GigabitEthernet3/0/1] quit
[SwitchC] interface gigabitethernet 3/0/2
[SwitchC-GigabitEthernet3/0/2] undo shutdown
[SwitchC-GigabitEthernet3/0/2] quit
[SwitchC] interface gigabitethernet 3/0/3
[SwitchC-GigabitEthernet3/0/3] undo shutdown
[SwitchC-GigabitEthernet3/0/3] quit
[SwitchC] interface gigabitethernet 3/0/4
[SwitchC-GigabitEthernet3/0/4] undo shutdown
[SwitchC-GigabitEthernet3/0/4] quit
# Configure GigabitEthernet3/0/2 as a static router port in VLAN 100.
[SwitchC-GigabitEthernet3/0/2] mld-snooping static-router-port vlan 100
# Display static router port information for VLAN 100 on Switch A.
[SwitchA] display mld-snooping static-router-port vlan 100
VLAN 100:
Router slots (1 in total):
3
Router ports (2 in total):
GE3/0/2
GE3/0/3
The output shows that GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 on Switch A have become static router ports in VLAN 100.
# Display static MLD snooping forwarding entries for VLAN 100 on Switch B.
[SwitchB] display mld-snooping static-group vlan 100
Total 1 entries.
(::, FF1E::101)
3
GE3/0/2
GE3/0/3
The output shows that GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 on Switch B have become static member ports of the group FF1E::101 in VLAN 100.
# Display static router port information for VLAN 100 on Switch C.
[SwitchC] display mld-snooping static-router-port vlan 100
VLAN 100:
3
Router ports (1 in total):
GE3/0/2
The output shows that GigabitEthernet 3/0/2 on Switch C has become a static router port in VLAN 100.
Configuration files
· Switch A:
mld-snooping
vlan 100
mld-snooping enable
· Switch B:
mld-snooping
vlan 100
mld-snooping enable
mld-snooping static-group FF1E::101 vlan 100
· Switch C:
mld-snooping
vlan 100
mld-snooping enable
Related documentation
· H3C S12500 Routing Switch Series IP Multicast Command Reference-Release 7328
· H3C S12500 Routing Switch Series IP Multicast Configuration Guide-Release 7328
