06-IP Multicast Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10006-IP Multicast Configuration Examples
01-H3C S12500 IGMP Configuration Examples
01-H3C S12500 IGMP Configuration Examples 91.96 KB
Introduction
This document provides IGMP configuration examples.
This document assumes that you have basic knowledge of IGMP.
Example: Configuring basic IGMP features
Network requirements
As shown in Figure 1:
·     OSPF and PIM-DM run on the network.
·     VOD streams are sent to receiver hosts in multicast. Receiver hosts of different organizations form stub networks N1 and N2. Host A and Host C are receiver hosts in N1 and N2, respectively.
·     IGMPv2 runs between Switch A and N1, and between the other two switches and N2. Switch A acts as the IGMP querier in N1. Switch B acts as the IGMP querier in N2 because it has a lower IP address.
Configure basic IGMP features on the switches to meet the following requirements:
·     Multicast receivers in N1 can join any multicast groups.
·     Multicast receivers in N2 can join only the multicast group 224.1.1.1.
Figure 1 Network diagram
Requirements analysis
To limit the multicast groups that multicast receivers can join, create an IPv4 basic ACL and specify the multicast groups that the receivers can join.
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
When you configure basic IGMP features, follow these restrictions and guidelines:
·     The protocol packets of different IGMP versions are different in structures and types. You must enable the same IGMP version for all switches on the same subnet. Otherwise, IGMP cannot operate correctly.
·     You must configure the same multicast group policy for all switches on the same subnet.
·     By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are shut down. You must first use the undo shutdown command to bring them up. This example assumes that all these interfaces are already up.
Configuration procedures
1.     Assign an IP address and subnet mask to each interface according to Figure 1. (Details not shown.)
2.     Configure OSPF on the switches in the PIM-DM domain. (Details not shown.)
3.     Configure Switch A:
# Enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
# Enable IGMP on the receiver-side interface VLAN-interface 100.
[SwitchA-Vlan-interface100] igmp enable
# Enable PIM-DM on VLAN-interface 101.
[SwitchA-Vlan-interface101] pim dm
4.     Configure Switch B:
# Create ACL 2001 to permit IGMP reports for the multicast group 224.1.1.1.
[SwitchB] acl number 2001
[SwitchB-acl-basic-2001] rule permit source 224.1.1.1 0
[SwitchB-acl-basic-2001] quit
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Enable IGMP on the receiver-side interface VLAN-interface 200.
[SwitchB-Vlan-interface200] igmp enable
# Configure a multicast group policy referencing ACL 2001 so that multicast receivers attached to the interface can join only the group 224.1.1.1.
[SwitchB-Vlan-interface200] igmp group-policy 2001
# Enable PIM-DM on VLAN-interface 201.
[SwitchB] interface vlan-interface 201
[SwitchB-Vlan-interface201] pim dm
[SwitchB-Vlan-interface201] quit
5.     Configure Switch C:
[SwitchC] acl number 2001
[SwitchC-acl-basic-2001] rule permit source 224.1.1.1 0
[SwitchC-acl-basic-2001] quit
[SwitchC] multicast routing
[SwitchC-mrib] quit
[SwitchC-Vlan-interface200] igmp group-policy 2001
# Enable PIM-DM on VLAN-interface 202.
[SwitchC] interface vlan-interface 202
[SwitchC-Vlan-interface202] pim dm
[SwitchC-Vlan-interface202] quit
# Send IGMP reports from Host C (10.110.2.10) to join the multicast groups 224.1.1.1 and 224.1.1.2. (Details not shown.)
# Display IGMP information about multicast groups on Switch B.
[SwitchB] display igmp group
IGMP groups in total: 1
 Vlan-interface200(10.110.2.1):
  IGMP groups reported in total: 1
   Group address   Last reporter   Uptime      Expires
   224.1.1.1       10.110.2.10     04:36:03    00:01:23
# Display IGMP information about multicast groups on Switch C.
[SwitchC] display igmp group
 Vlan-interface200(10.110.2.2):
   224.1.1.1       10.110.2.10     04:21:03    00:01:13
The output shows that Switch B and Switch C each have IGMP information about only the multicast group, 224.1.1.1. The multicast group policy has taken effect, and multicast receivers in N2 can join only the multicast group 224.1.1.1.
Configuration files
·     Switch A:
 ospf 1
 area 0.0.0.0
  network 10.0.0.0 0.255.255.255
vlan 100 to 101
interface Vlan-interface100
 ip address 10.110.1.1 255.255.255.0
 pim dm
 igmp enable
interface Vlan-interface101
 ip address 10.111.1.1 255.255.255.0
 pim dm
 interface Ten-GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 100
 interface Ten-GigabitEthernet3/0/2
 port access vlan 101
multicast routing
·     Switch B:
ospf 1
 area 0.0.0.0
acl number 2001
 rule 0 permit source 224.1.1.1 0
vlan 200 to 201
interface Vlan-interface200
 ip address 10.110.2.1 255.255.255.0
 pim dm
 igmp enable
interface Vlan-interface201
 ip address 10.111.2.1 255.255.255.0
 pim dm
 port access vlan 200
 port access vlan 201
multicast routing
·     Switch C:
ospf 1
 area 0.0.0.0
acl number 2001
vlan 200
vlan 202
 ip address 10.110.2.2 255.255.255.0
 pim dm
 igmp enable
interface Vlan-interface202
 ip address 10.111.3.1 255.255.255.0
 pim dm
 port access vlan 202
 multicast routing
Related documentation
·     H3C S12500 Routing Switch Series IP Multicast Command Reference Release 7328
·     H3C S12500 Routing Switch Series IP Multicast Configuration Guide Release 7328
