07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
05-IS-IS Commands
05-IS-IS Commands 337.69 KB
IS-IS configuration commands 1
area-authentication-mode· 1
auto-cost enable· 2
bandwidth-reference (IS-IS view) 2
circuit-cost 3
cost-style· 4
default-route-advertise (IS-IS view) 4
display isis brief 5
display isis debug-switches 7
display isis graceful-restart status 7
display isis interface· 9
display isis lsdb· 12
display isis mesh-group· 15
display isis name-table· 16
display isis peer 17
display isis route· 19
display isis spf-log· 22
display isis statistics 24
domain-authentication-mode· 26
fast-reroute· 27
filter-policy export (IS-IS view) 28
filter-policy import (IS-IS view) 29
flash-flood· 30
graceful-restart (IS-IS view) 31
graceful-restart interval (IS-IS view) 32
graceful-restart suppress-sa· 32
import-route (IS-IS view) 33
import-route isis level-2 into level-1· 34
import-route limit (IS-IS view) 35
isis 36
isis authentication-mode· 36
isis bfd enable· 37
isis circuit-level 38
isis circuit-type p2p· 39
isis cost 39
isis dis-name· 40
isis dis-priority· 41
isis enable· 42
isis mesh-group· 42
isis mib-binding· 43
isis silent 44
isis small-hello· 44
isis timer csnp· 45
isis timer hello· 46
isis timer holding-multiplier 47
isis timer lsp· 48
isis timer retransmit 48
is-level 49
is-name· 50
is-name map· 50
is-snmp-traps enable· 51
log-peer-change (IS-IS view) 51
lsp-fragments-extend· 52
lsp-length originate· 53
lsp-length receive· 53
maximum load-balancing (IS-IS view) 54
network-entity· 55
non-stop-routing· 55
non-stop-routing interval 56
preference (IS-IS view) 57
priority high· 58
reset isis all 58
reset isis peer 59
set-overload· 59
summary (IS-IS view) 60
timer lsp-generation· 61
timer lsp-max-age· 62
timer lsp-refresh· 63
timer spf 64
virtual-system·· 65
area-authentication-mode { md5 | simple } [ cipher ] password [ ip | osi ]
undo area-authentication-mode
View
IS-IS view
Default level
2: System level
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
cipher: Sets a ciphertext password. If this keyword is not specified, you set a plaintext password.
password: Sets the password. This argument is case sensitive. It must be a plaintext string of 1 to 16 characters, or a ciphertext string of 33 to 53 characters.
ip: Checks IP related fields in LSPs.
osi: Checks OSI related fields in LSPs.
Whether a password should use ip or osi is not affected by the actual network environment.
Use area-authentication-mode to specify the area authentication mode and a password.
Use undo area-authentication-mode to restore the default.
By default, no area authentication is configured.
The password in the specified mode is inserted into all outgoing Level-1 packets (LSP, CSNP, and PSNP) and is used for authenticating the incoming Level-1 packets.
With area authentication configured, IS-IS discards incoming routes from untrusted routers.
Routers in a common area must have the same authentication mode and password.
If neither ip nor osi is specified, OSI related fields are checked.
Related commands: reset isis all, domain-authentication-mode, and isis authentication-mode.
# Configure the area authentication mode as simple, and set the plaintext password to ivg.
[Sysname] isis 1
[Sysname-isis-1] area-authentication-mode simple ivg
auto-cost enable
auto-cost enable
undo auto-cost enable
View
IS-IS view
Default level
2: System level
None
Use auto-cost enable to enable automatic link cost calculation.
Use undo auto-cost enable to disable the function.
By default, this function is disabled.
After automatic link cost calculation is enabled, the link cost is automatically calculated based on the bandwidth reference value of an interface. When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the formula: Cost = (reference bandwidth value/link bandwidth) × 10. When the cost style is of another type: if the interface bandwidth does not exceed 10 Mbps, the interface cost equals 60; if the interface bandwidth does not exceed 100 Mbps, the interface cost equals 50; if the interface bandwidth does not exceed 155 Mbps, the interface cost equals 40; if the interface bandwidth does not exceed 622 Mbps, the interface cost equals 30; if the interface bandwidth does not exceed 2500 Mbps, the interface cost equals 20; if the interface bandwidth exceeds 2500 Mbps, the interface cost equals 10.
Related commands: bandwidth-reference and cost-style.
# Enable automatic link cost calculation.
[Sysname] isis 1
[Sysname-isis-1] auto-cost enable
bandwidth-reference value
undo bandwidth-reference
View
IS-IS view
Default level
2: System level
value: Specifies the bandwidth reference value in the range of 1 to 2147483648 Mbps.
Use bandwidth-reference to set the bandwidth reference value for automatic link cost calculation.
Use undo bandwidth-reference to restore the default.
By default, the bandwidth reference value is 100 Mbps.
Related commands: auto-cost enable.
# Configure the bandwidth reference of IS-IS process 1 as 200 Mbps.
[Sysname] isis 1
[Sysname-isis-1] bandwidth-reference 200
circuit-cost
circuit-cost value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
value: Specifies the link cost value. The value range varies with cost styles.
·     For styles narrow, narrow-compatible and compatible, the cost value is in the range of 0 to 63.
·     For styles wide and wide-compatible, the cost value is in the range of 0 to 16777215.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
Use circuit-cost to set a global IS-IS link cost.
Use undo circuit-cost to restore the default.
By default, no global link cost is configured.
If no level is specified, the specified cost applies to both Level-1 and Level-2.
Related commands: isis cost and cost-style.
# Set the global Level-1 link cost of IS-IS process 1 to 11.
[Sysname] isis 1
[Sysname-isis-1] circuit-cost 11 level-1
cost-style
undo cost-style
View
IS-IS view
Default level
2: System level
narrow: Receives and sends only narrow cost style packets (The narrow cost is in the range of 0 to 63).
wide: Receives and sends only wide cost style packets (the wide cost is in the range of 0 to 16777215).
compatible: Receives and sends both wide and narrow cost style packets.
narrow-compatible: Receives both narrow and wide cost style packets, but sends only narrow cost style packets.
wide-compatible: Receives both narrow and wide cost style packets, but sends only wide cost style packets.
relax-spf-limit: Allows receiving routes with a cost greater than 1023. If this keyword is not specified, any route with a cost bigger than 1023 will be discarded. This keyword is only available when compatible or narrow-compatible is included.
Use cost-style to set a cost style.
Use undo cost-style to restore the default.
By default, only narrow cost style packets can be received and sent.
Related commands: isis cost and circuit-cost.
# Configure the router to send only narrow cost style packets, but receive both narrow and wide cost style packets.
[Sysname] isis 1
[Sysname-isis-1] cost-style narrow-compatible
default-route-advertise [ route-policy route-policy-name | [ level-1 | level-1-2 | level-2 ] ] *
undo default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
Default level
2: System level
route-policy-name: Specifies the name of a routing policy, a case-sensitive string of 1 to 63 characters.
level-1: Advertises a Level-1 default route.
level-1-2: Advertises both Level-1 and Level-2 default routes.
level-2: Advertises a Level-2 default route.
Use default-route-advertise to advertise a default route.
Use undo default-route-advertise to disable default route advertisement.
By default, default route advertisement is disabled.
If no level is specified, a Level-2 default route is advertised.
The Level-1 default route is advertised to other routers in the same area, while the Level-2 default route is advertised to all the Level-2 and Level-1-2 routers.
Using the apply isis level-1 command in routing policy view will generate a default route in a Level-1 LSP. Using the apply isis level-2 command in routing policy view will generate a default route in a Level-2 LSP. Using the apply isis level-1-2 command in routing policy view will generate a default route in a Level-1 LSP and Level-2 LSP.
# Advertise a Level-2 default route.
[Sysname] isis 1
[Sysname-isis-1] default-route-advertise
display isis brief
display isis brief [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays IS-IS brief configuration information for the IS-IS process. The process ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS brief configuration information for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS brief configuration information of the public network is displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display isis brief to view IS-IS brief configuration information.
# Display IS-IS brief configuration information.
<Sysname> display isis brief
                  ISIS (1) Protocol Brief Information :
 network-entity:
     10.0000.0000.0001.00
 is-level :level-1-2
 cost-style:  narrow
 preference :  15
 Lsp-length receive :  1497
 Lsp-length originate :  level-1 1497
                         level-2 1497
 maximum imported routes number     : 10000
 Timers:
     lsp-max-age:  1200
     lsp-refresh:  900
     Interval between SPFs:  10
network-entity
Network entity name.
is-level
IS-IS Routing level.
cost-style
Cost style.
preference
Preference.
Lsp-length receive
Maximum LSP that can be received.
Maximum LSP that can be generated.
Maximum number of redistributed Level 1/Level 2 IPv4 routes.
Timers
·     lsp-max-age—Maximum life period of LSP.
·     lsp-refresh—Refresh interval of LSP.
·     Interval between SPFs—Interval between SPF calculations.
display isis debug-switches { process-id | vpn-instance vpn-instance-name } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS debugging switch state for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS debugging switch state for the public network is displayed.
Use display isis debug-switches to display IS-IS debugging switch state.
# Display the debugging switch state of IS-IS process 1.
<Sysname> display isis debug-switches 1
IS-IS - Debug settings.
        IS-IS SPF Triggering Events debugging is on
display isis graceful-restart status [ level-1 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level-1: Displays the IS-IS Level-1 Graceful Restart state.
level-2: Displays the IS-IS Level-2 Graceful Restart state.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS Graceful Restart status for the public network is displayed.
Use display isis graceful-restart status to display IS-IS Graceful Restart status.
# Display IS-IS Graceful Restart status.
<Sysname> display isis graceful-restart status
IS-IS(1) Level-1 Restart Status
Restart Interval: 150
SA Bit Supported
  Total Number of Interfaces = 1
  Restart Status: RESTARTING
  Number of LSPs Awaited: 3
  T3 Timer Status:
    Remaining Time: 140
  T2 Timer Status:
    Remaining Time: 59
IS-IS(1) Level-2 Restart Status
SA Bit Supported
  T3 Timer Status:
    Remaining Time: 140
  T2 Timer Status:
    Remaining Time: 59
Restart Interval
Graceful Restart interval.
SA Bit Supported
The SA bit is set.
The current IS-IS interface number.
Restart Status
Number of LSPs not obtained by the GR restarter from GR helpers during LSDB synchronization.
T3 Timer Status
Remaining time of T3 timer.
T2 Timer Status
Remaining time of T2 Timer.
display isis interface [ statistics | [ interface-type interface-number ] [ verbose ] ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
statistics: Displays IS-IS interface statistics.
interface-type interface-number: Specifies an IS-IS interface whose statistics is to be displayed.
verbose: Displays detailed IS-IS interface information.
process-id: Displays the IS-IS interface information of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS interface information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS interface information of the public network is displayed.
Use display isis interface to display IS-IS interface information.
# Display brief IS-IS interface information.
<Sysname> display isis interface
                       Interface information for ISIS(1)
Interface: Vlan-interface 12
Id      IPV4.State        IPV6.State     MTU    Type    DIS
001        Up                 Down       1497   L1/L2   No/No
# Display detailed IS-IS interface information.
<Sysname> display isis interface verbose
  Interface:  Vlan-interface999
  SNPA Address                : 000f-e237-c6e0
  IP Address                  : 192.168.1.48
  Secondary IP Address(es)    :
  IPV6 Link Local Address     :
  IPV6 Global Address(es)     :
  Csnp Timer Value            :  L1    10  L2    10
  Hello Timer Value           :  L1    10  L2    10
  Hello Multiplier Value      :  L1     3  L2     3
  Lsp Timer Value             :  L12   33
  Lsp Transmit-Throttle Count :  L12   5
  Cost                        :  L1    10  L2    10
  Priority                    :  L1    64  L2    64
  BFD                         :  Disabled
  MPLS TE Status              :  ON
  INTF L1 TE Status           :  OFF
  INTF L2 TE Status           :  ON
  TE Cost                     :  0
  TE Admin Group              :  0
  TE Max Bandwidth            :  0
  TE Max Res Bandwidth        :  0
# Displays detailed information of the specified IS-IS interface.
<Sysname> display isis interface tunnel 1 verbose
  Interface:  Tunnel1
  Id      IPv4.State           IPv6.State        MTU  Type  DIS
  005          Up                  Down          16384L1/L2 --
  SNPA Address                : 0000-0000-0000
  IP Address                  : 10.1.1.4
  IPv6 Link Local Address     :
  IPv6 Global Address(es)     :
  Hello Timer Value           :        10
  Hello Multiplier Value      :         3
  Cost                        :  L1    10  L2    10
  Retransmit Timer Value      :  L12    5
  BFD                         :  Disabled
  Tunnel L1 State             :  OFF
  Tunnel L2 State             :  ON
  Tunnel Type                 :  AA
  Tunnel Metric               :  0
  Destination Router ID       :  5.5.5.5
Interface type and number.
Id
Circuit ID.
IPV4.State
IPv4 state.
IPV6.State
IPv6 state.
MTU
Interface MTU.
Interface link adjacency type.
DIS
Whether the interface is elected as the DIS or not.
SNPA Address
Subnet access point address.
IP Address
Primary IP address.
Secondary IP addresses.
IPv6 link local address.
IPv6 global address.
Csnp Timer Value
Interval for sending CSNP packets.
Hello Timer Value
Interval for sending Hello packets.
Number of invalid Hello packets.
Lsp Timer Value
Minimum interval for sending LSP packets.
Number of LSP packets sent each time.
Cost
Cost of the interface.
Priority
DIS priority.
LSP retransmission interval over the point-to-point link.
BFD
Whether BFD is enabled on the interface.
MPLS TE Status
Whether MPLS TE is enabled on the interface.
INTF L1 TE Status
Whether level-1 MPLS TE is enabled on the interface.
INTF L2 TE Status
Whether level-2 MPLS TE is enabled on the interface.
TE Cost
MPLS TE cost configured on the interface.
TE Admin Group
TE link administration group.
TE Max Bandwidth
TE link maximum bandwidth.
TE link maximum reserved bandwidth.
Tunnel L1 State
IS-IS TE tunnel level-1 state.
Tunnel L2 State
IS-IS TE tunnel level-2 state.
Tunnel Type
Tunnel type.
Tunnel Metric
IGP metric of the TE tunnel.
Destination address of TE tunnel interface.
# Display IS-IS interface statistics.
<sysname> display isis interface statistics
                  Interface Statistics information for ISIS(1)
  Type            IPv4 Up/Down           IPv6 Up/Down
  LAN                   0/1                   -/-
  P2P                   4/0                   -/-
Network type of the interface:
·     LAN for broadcast network.
·     P2P for point-to-point network.
IPv4 UP
Number of IS-IS interfaces in up state.
IPv4 DOWN
Number of IS-IS interfaces in down state.
IPv6 UP
Number of IS-ISv6 interfaces in up state. If IPv6 is not enabled, this field displays a hyphen (-).
IPv6 DOWN
Number of IS-ISv6 interfaces in down state. If IPv6 is not enabled, this field displays a hyphen (-).
display isis lsdb
display isis lsdb [ [ l1 | l2 | level-1 | level-2 ] | [ lsp-id lspid | lsp-name lspname ] | local | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
l1, level-1: Displays the level-1 LSDB.
l2, level-2: Displays the level-2 LSDB.
lspid: Specifies an LSP ID, in the form of sysID.Pseudo ID-fragment num, where sysID represents the originating node or pseudo node, and Pseudo ID is separated by a dot from sysID and by a hyphen from fragment num.
lspname: Specifies the LSP name, in the form of Symbolic name.Pseudo ID-fragment num, where Pseudo ID is separated by a dot from Symbolic name and by a hyphen from fragment num. If the Pseudo ID is 0, specify the LSP name in the form Symbolic name-fragment num.
local: Displays LSP information generated locally.
verbose: Displays LSDB detailed information.
process-id: Displays the LSDB of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the LSDB of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the LSDB of the public network is displayed.
Use display isis lsdb to display IS-IS link state database.
If no level is specified, both Level-1 and Level-2 link state databases are displayed.
# Display brief Level-1 LSDB information.
<Sysname> display isis lsdb level-1
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum      Holdtime      Length  ATT/P/OL
1111.1111.1111.00-00  0x00000004   0xa76         563           68      0/0/0
1111.1111.1112.00-00* 0x00000006   0x498d        578           84      0/0/0
1111.1111.1112.01-00* 0x00000001   0x4c0e        556           55      0/0/0
# Display detailed Level-1 LSDB information.
<Sysname> display isis lsdb level-1 verbose
                        Database information for ISIS(1)
1111.1111.1111.00-00  0x00000005   0x877         1090          68      0/0/0
 SOURCE       1111.1111.1111.00
 NLPID        IPV4
 AREA ADDR    10
 INTF ADDR    3.1.1.2
 NBR  ID      1111.1111.1112.01  COST: 10
 IP-Internal  3.1.1.0        255.255.255.0    COST: 10
1111.1111.1112.00-00* 0x00000007   0x478e        1120          84      0/0/0
 SOURCE       1111.1111.1112.00
 NLPID        IPV4
 AREA ADDR    10
 INTF ADDR    3.1.1.1
 INTF ADDR    2.1.2.2
 IP-Internal  2.1.2.0        255.255.255.0    COST: 10
1111.1111.1112.01-00* 0x00000002   0x4a0f        1118          55      0/0/0
 SOURCE       1111.1111.1112.01
 NLPID        IPV4
 NBR  ID      1111.1111.1112.00  COST: 0
 NBR  ID      1111.1111.1111.00  COST: 0
Table 5 Command output
LSPID
Link state packet ID.
Seq Num
LSP sequence number.
Checksum
LSP checksum.
Holdtime
LSP lifetime, which decreases as time elapses.
Length
LSP length.
ATT/P/OL
·     ATT—Attach bit.
·     P—Partition bit.
·     OL—Overload bit.
1 means the bit is set and 0 means the bit is not set.
SOURCE
System ID of the originating router.
NLPID
Network layer protocol the originating router runs.
AREA ADDR
Area address of the originating router.
INTF ADDR
IP address of the originating router's IS-IS interface.
INTF ADDR V6
IPv6 address of the originating router's IS-ISv6 interface.
NBR ID
Neighbor ID of the originating router.
IP-Internal
Internal IP address and mask of the originating router.
IP-External
External IP address and mask of the originating router.
IP-Extended
Extended IP address and mask of the originating router.
COST
Cost.
HOST NAME
Dynamic host name of the originating router.
ORG ID
Original system ID of the virtual system ID of the originating router.
Auth
Authentication information of the originating router.
IPV6
Internal IPv6 address and prefix of the originating router.
IPV6-Ext
External IPv6 address and prefix of the originating router.
display isis mesh-group [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays IS-IS mesh-group configuration information for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS mesh-group configuration information for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS mesh-group configuration information for the public network is displayed.
Use display isis mesh-group to display IS-IS mesh-group configuration information.
# Configure VLAN-interface 10 and VLAN-interface 20 to belong to mesh-group 100.
[Sysname-Vlan-interface10] isis mesh-group 100
[Sysname-Vlan-interface10] interface vlan-interface 20
[Sysname-Vlan-interface20] isis mesh-group 100
# Display the configuration information of IS-IS mesh-group.
[Sysname-Vlan-interface20] display isis mesh-group
                       Mesh Group information for ISIS(1)
 Interface          Status
 Vlan10              100
 Vlan20              100
Table 6 Command output
Interface name.
Status
Mesh-group the interface belongs to.
display isis name-table [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays the host name-to-system ID mapping table for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the host name-to-system ID mapping table for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the host name-to-system ID mapping table for the public network is displayed.
Use display isis name-table to display the host name-to-system ID mapping table.
# Configure a name for the local IS system.
[Sysname] isis 1
[Sysname-isis-1] is-name RUTA
# Configure a static mapping for the remote IS system (system ID 0000.0000.0041, host name RUTB).
[Sysname-isis-1] is-name map 0000.0000.0041 RUTB
# Display the IS-IS host name-to-system ID mapping table.
[Sysname-isis-1] display isis name-table
              Name table information for ISIS(1)
System ID            Hostname                            Type
6789.0000.0001       RUTA                                DYNAMIC
0000.0000.0041       RUTB                                STATIC
Table 7 Command output
System ID
System ID.
Hostname
Hostname name.
Mapping type (static or dynamic)
display isis peer
display isis peer [ statistics | verbose ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
statistics: Displays IS-IS neighbor statistics.
verbose: Displays detailed IS-IS neighbor information. Without the keyword, the command displays brief IS-IS neighbor information.
process-id: Displays the IS-IS neighbor information of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS neighbor information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS neighbor information of the public network is displayed.
Use display isis peer to display IS-IS neighbor information.
# Display brief IS-IS neighbor information.
<Sysname> display isis peer
                          Peer information for ISIS(1)
  System Id: 1111.1111.1111
  Interface: Vlan-interface11        Circuit Id: 1111.1111.1112.01
  State: Up     HoldTime: 23s        Type: L1(L1L2)     PRI: 64
  State: Up     HoldTime: 23s        Type: L2(L1L2)     PRI: 64
# Display detailed IS-IS neighbor information.
<Sysname>display isis peer verbose
  State: Up     HoldTime: 27s        Type: L1(L1L2)     PRI: 64
  Area Address(es):10
  Peer IP Address(es): 3.1.1.2
  Uptime: 00:38:15
  Adj Protocol:  IPV4
  State: Up     HoldTime: 28s        Type: L2(L1L2)     PRI: 64
  Area Address(es):10
  Uptime: 00:38:15
  Adj Protocol:  IPV4
Table 8 Command output
System Id
System ID of the neighbor.
Interface connecting to the neighbor.
Circuit Id
Circuit ID.
Circuit state.
HoldTime
Holdtime.
Within the holdtime if no hellos are received from the neighbor, the neighbor is considered down. If a hello is received, the holdtime is reset to the initial value.
Circuit type:
·     L1—Means the circuit type is Level-1 and the neighbor is a Level-1 router.
·     L2—Means the circuit type is Level-2 and the neighbor is a Level-2 router.
·     L1(L1L2)—Means the circuit type is Level-1 and the neighbor is a Level-1-2 router.
·     L2(L1L2)—Means the circuit type is Level-2 and the neighbor is a Level-1-2 router.
PRI
DIS priority of the neighbor.
Area Address(es)
The neighbor's area address.
Peer IP Address(es)
IP address of the neighbor.
Uptime
Time that elapsed since the neighbor relationship was formed.
Adj Protocol
Adjacency protocol.
# Display IS-IS neighbor statistics.
<Sysname> display isis peer statistics
                    Peer Statistics information for ISIS(1)
  Type              IPv4 Up/Init             IPv6 Up/Init
  LAN Level-1             0/0                      0/0
  LAN Level-2             0/0                      0/0
  P2P                     3/0                      0/0
Table 9 Command output
Neighbor type:
·     LAN Level-1—Number of Level-1 neighbors whose network type is broadcast.
·     LAN Level-2—Number of Level-2 neighbors whose network type is broadcast.
·     P2P— Number of neighbors whose network type is P2P.
IPv4 Up
Number of IPv4 neighbors in up state.
IPv4 Init
Number of IPv4 neighbors in init state.
IPv6 Up
Number of IPv6 neighbors in up state.
IPv6 Init
Number of IPv6 neighbors in init state.
display isis route
display isis route [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv4: Displays IS-IS IPv4 routing information (the default).
verbose: Displays detailed IS-IS IPv4 routing information.
process-id: Displays the IS-IS IPv4 routing information of the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS IPv4 routing information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS IPv4 routing information of the public network is displayed.
level-1: Displays Level-1 IS-IS routes.
level-2: Displays Level-2 IS-IS routes.
Use display isis route to display IS-IS IPv4 routing information.
If no level is specified, both Level-1 and Level-2  routing information will be displayed.
# Display IS-IS IPv4 routing information.
<Sysname> display isis route 1
                         Route information for ISIS(1)
                     ISIS(1) IPv4 Level-1 Forwarding Table
 IPV4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 1.1.0.0/16           20         NULL    Vlan11          1.2.1.1         R/L/-
 1.2.0.0/16           10         NULL    Vlan11          Direct          D/L/-
      Flags: D-Direct, R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
                     ISIS(1) IPv4 Level-2 Forwarding Table
Table 10 Command output
Route information for IS-IS process 1.
IS-IS IPv4 routing information for Level-1.
IS-IS IPv4 routing information for Level-2.
IPv4 Destination
IPv4 destination address.
IntCost
Interior routing cost.
ExtCost
Exterior routing cost.
ExitInterface
Exit interface.
NextHop
Next hop.
Flags
Routing state flag:
·     D—Direct route.
·     R—The route has been added into the routing table.
·     L—The route has been advertised in an LSP.
·     U—A route's penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
# Display detailed IS-IS IPv4 routing information.
<Sysname> display isis route verbose
 IPV4 Dest  : 1.1.0.0/16         Int. Cost : 20              Ext. Cost : NULL
 Admin Tag  : -                  Src Count : 2               Flag      : R/L/-
 NextHop    :                    Interface :                 ExitIndex :
    1.2.1.1                            Vlan11                  0x00000008
 IPV4 Dest  : 1.2.0.0/16         Int. Cost : 10              Ext. Cost : NULL
 Admin Tag  : -                  Src Count : 2               Flag      : D/L/-
    Direct                             Vlan11                  0x00000000
 Admin Tag  : -                  Src Count : 2               Flag      : -/-/-
 Admin Tag  : -                  Src Count : 3               Flag      : D/L/-
Table 11 Command output
IPV4 Dest
IPv4 destination.
Int. Cost
Internal route cost.
Ext. Cost
External route cost.
Admin Tag
Tag.
Src Count
Count of advertising sources.
Flag
Route state flag:
·     RThe route have been installed into the routing table.
·     L—The route has been flooded in an LSP.
·     U—Route leaking flag. If it is UP, routes from L2 to L1 cannot be advertised back to L2.
Next Hop
Next hop.
Output interface.
ExitIndex
Index of the output interface.
display isis spf-log [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Displays IS-IS SPF log information for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS SPF log information for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS SPF log information for the public network is displayed.
Use display isis spf-log to display IS-IS SPF log information.
# Display IS-IS SPF log information.
<Sysname> display isis spf-log
                        SPF Log information for ISIS(1)
   Level    Trig.Event                      No.Nodes  Duration   StartTime
   L2       IS_SPFTRIG_PERIODIC             2         0          13:3:24
   L1       IS_SPFTRIG_PERIODIC             2         0          13:18:8
   L2       IS_SPFTRIG_PERIODIC             2         0          13:18:8
   L1       IS_SPFTRIG_PERIODIC             2         0          13:32:28
   L2       IS_SPFTRIG_PERIODIC             2         0          13:32:28
   L1       IS_SPFTRIG_PERIODIC             2         0          13:44:0
   L2       IS_SPFTRIG_PERIODIC             2         0          13:44:0
   L1       IS_SPFTRIG_PERIODIC             2         0          13:55:43
-->L2       IS_SPFTRIG_PERIODIC             2         0          13:55:43
   L1       IS_SPFTRIG_PERIODIC             2         0          11:54:12
   L2       IS_SPFTRIG_PERIODIC             2         0          11:54:12
   L1       IS_SPFTRIG_PERIODIC             2         0          12:7:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:7:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:21:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:21:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:35:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:35:24
   L1       IS_SPFTRIG_PERIODIC             2         0          12:49:24
   L2       IS_SPFTRIG_PERIODIC             2         0          12:49:24
   L1       IS_SPFTRIG_PERIODIC             2         0          13:3:24
Table 12 Command output
SPF log information for IS-IS process 1.
Level
SPF calculation level.
Trig.Event
SPF triggered event.
No.Nodes
Number of SPF calculation nodes.
Duration
SPF calculation duration.
StartTime
SPF calculation start time.
display isis statistics [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level-1: Displays IS-IS Level-1 statistics.
level-1-2: Displays IS-IS Level-1-2 statistics.
level-2: Displays IS-IS Level-2 statistics.
process-id: Displays IS-IS statistics for the IS-IS process. The ID is in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays IS-IS statistics for the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS statistics for the public network is displayed.
Use display isis statistics to display IS-IS statistics.
# Display IS-IS statistics.
<Sysname> display isis statistics
                               Level-1 Statistics
Learnt routes information:
         Total IPv4 Learnt Routes in IPv4 Routing Table: 1
         Total IPv6 Learnt Routes in IPv6 Routing Table: 0
Imported routes information:
         IPv4 Imported Routes:
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
         IPv6 Imported Routes:
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
Lsp information:
                  LSP Source ID:          No. of used LSPs
                  0000.0000.0003                  002
                               Level-2 Statistics
         Total IPv4 Learnt Routes in IPv4 Routing Table: 0
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
Lsp information:
                  0000.0000.0003                  002
Table 13 Command output
Statistics information for ISIS(processid)
Statistics for the IS-IS process.
Level-1 Statistics
Level-1 Statistics.
Level-2 Statistics
Level-2 Statistics.
Numbers of learnt IPv4 and IPv6 routes.
IPv4 Imported Routes.
Redistributed IPv4 routes:
·     Static.
·     Direct.
·     IS-IS.
·     BGP.
·     RIP.
·     OSPF.
IPv6 Imported Routes.
Redistributed IPv6 routes:
·     Static.
·     Direct.
·     IS-ISv6.
·     BGP4+.
·     RIPng.
·     OSPFv3.
Lsp information
LSP information:
·     LSP Source ID—ID of the source system.
·     No. of used LSPs—number of used LSPs.
domain-authentication-mode { md5 | simple } [ cipher ] password [ ip | osi ]
undo domain-authentication-mode
View
IS-IS view
Default level
2: System level
Use domain-authentication-mode to specify the routing domain authentication mode and a password.
Use undo domain-authentication-mode to restore the default.
By default, no routing domain authentication is configured.
The configured password in the specified mode is inserted into all outgoing Level-2 packets (LSP, CSNP, and PSNP) and is used for authenticating the incoming Level-2 packets.
All the backbone routers must have the same authentication mode and password.
If neither ip nor osi is specified, the OSI related fields in LSPs are checked.
Related commands: area-authentication-mode and isis authentication-mode.
# Specify the routing domain authentication mode as simple and password as 123456.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication-mode simple 123456
fast-reroute
fast-reroute { auto | route-policy route-policy-name }
undo fast-reroute
View
IS-IS view
Default level
2: System level
auto: Calculates a backup next hop automatically for all routes.
route-policy route-policy-name: References a routing policy to designate a next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters. You can specify the backup next hop in the routing policy.
Use fast-reroute to configure IS-IS fast reroute (FRR).
Use undo fast-reroute to restore the default.
By default, IS-IS FRR is disabled.
IMPORTANT:
·     Do not use IS-IS FRR and BFD (for IS-IS) at the same time; otherwise, IS-IS FRR might fail to take effect.
·     The automatic backup next hop calculation of IS-IS FRR and that of MPLS TE are mutually exclusive.
Example
# Enable IS-IS FRR to automatically calculate a backup next hop for all routes.
[Sysname] isis
[Sysname-isis-1] fast-reroute auto
# Enable IS-IS FRR to designate a backup next hop by using a routing policy named frr.
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname] route-policy frr permit node 10
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy] apply fast-reroute backup-interface Vlan-interface 1000 backup-nexthop 193.1.1.8
[Sysname-route-policy] quit
[Sysname] isis 100
[Sysname-isis-100] fast-reroute route-policy frr
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
View
IS-IS view
Default level
2: System level
acl-number: Specifies the number of an ACL that is used to filter redistributed routes. The value range is 2000 to 3999. For ACL configuration information, see ACL and QoS Command Reference.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter redistributed routes, a case-sensitive string of 1 to 19 characters. For IP prefix list configuration information, see "Routing policy configuration commands."
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter redistributed routes, a case-sensitive string of 1 to 63 characters. For routing policy configuration information, see "Routing policy configuration commands."
protocol: Filters routes redistributed from the routing protocol, which can be BGP, direct, IS-IS, OSPF, RIP, or static.
process-id: Specifies a process by its ID in the range of 1 to 65535. It is optional only when the protocol is IS-IS, OSPF, or RIP.
Use filter-policy export to configure IS-IS to filter redistributed routes.
Use undo filter-policy export to disable IS-IS from filtering redistributed routes.
By default, IS-IS does not filter redistributed routes.
If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command or in the routing policy, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route while the destination keyword specifies the subnet mask of the route (the subnet mask must be valid; otherwise, the configuration is ineffective).
Related commands: filter-policy import.
# Reference ACL 2000 to filter redistributed routes.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny ip source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] isis 1
[Sysname-isis-1] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter the redistributed routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] isis 1
[Sysname-isis 1] filter-policy 3000 export
filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } import
undo filter-policy import
View
IS-IS view
Default level
2: System level
acl-number: Specifies the number of an ACL that is used to filter routes calculated from received LSPs. The value range is 2000 to 3999. For ACL configuration information, see ACL and QoS Command Reference.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter routes calculated from received LSPs, a case-sensitive string of 1 to 19 characters. For IP prefix list configuration information, see "Routing policy configuration commands."
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter routes calculated from received LSPs, a case-sensitive string of 1 to 63 characters. For routing policy configuration information, see "Routing policy configuration commands."
Use filter-policy import to configure IS-IS to filter routes calculated from received LSPs.
Use undo filter-policy import to disable IS-IS from filtering routes calculated from received LSPs.
By default, IS-IS does not filter routes calculated from received LSPs.
Related commands: filter-policy export.
# Reference ACL 2000 to filter routes calculated from received LSPs.
[Sysname] isis 1
[Sysname-isis-1] filter-policy 2000 import
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter the routes calculated from received LSPs.
[Sysname] isis 1
[Sysname-isis 1] filter-policy 3000 import
flash-flood
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
undo flash-flood [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
flood-count flooding-count: Specifies the maximum number of LSPs to be flooded before the next SPF calculation. The value range is 1 to 15, and the default is 5.
max-timer-interval flooding-interval: Specifies the delay of the flash flooding, in the range of 10 to 50000 milliseconds. The default is 10.
level-1: Enables flash flooding for level-1.
level-2: Enables fast-flooding for level-2.
Use flash-flood to enable IS-IS LSP flash flooding.
Use undo flash-flood to disable IS-IS LSP flash flooding.
By default, IS-IS LSP flash flooding is disabled.
If no level is specified, the command enables IS-IS LSP flash flooding for both Level-1 and Level-2.
# Enable fast flooding and specify the maximum LSPs to be sent as 10 and the delay time as 100 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] flash-flood flood-count 10 max-timer-interval 100
graceful-restart
undo graceful-restart
View
IS-IS view
Default level
2: System level
None
Use graceful-restart to enable IS-IS Graceful Restart capability.
Use undo graceful-restart to disable IS-IS Graceful Restart capability.
By default, IS-IS Graceful Restart capability is disabled.
The IS-IS GR and IS-IS non-stop routing (NSR) features are mutually exclusive. That is, the graceful-restart and non-stop-routing commands cannot be configured at the same time.
Before performing a master/backup switchover between IRF member switches, you must configure the irf mac-address persistent always command to prevent bridge MAC address changes that can cause IS-IS GR failure after the switchover.
# Enable the Graceful Restart capability for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart
graceful-restart interval interval-value
undo graceful-restart interval
View
IS-IS view
Default level
2: System level
interval-value: Specifies the Graceful Restart interval in the range of 30 to 1800 seconds.
Use graceful-restart interval to configure the Graceful Restart interval.
Use undo graceful-restart interval to restore the default Graceful Restart interval.
By default, the Graceful Restart interval is 300 seconds.
# Configure the Graceful Restart interval for IS-IS process 1 as 120 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart interval 120
undo graceful-restart suppress-sa
View
IS-IS view
Default level
2: System level
None
Use graceful-restart suppress-sa to suppress the SA (Suppress-Advertisement) bit during restart.
Use undo graceful-restart suppress-sa to set the SA bit.
By default, the SA bit is set during restart.
Suppressing the SA bit is mainly for avoiding black hole routing. If a router starts or reboots without keeping the local forwarding table, the router will discard incoming packets, causing black hole routing. To avoid this, you can set the SA bit of hello packets sent by the GR restarter to 1. Upon receiving such hello packets, the GR helpers will not advertise the GR restarter through LSPs.
# Suppress the SA bit during Graceful Restart.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart suppress-sa
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
View
IS-IS view
Default level
2: System level
topology-name: Specifies a topology by its name, a case-sensitive character string of 1 to 31 characters.
protocol: Redistributes routes from a routing protocol, which can be BGP, direct, IS-IS, OSPF, RIP, or static.
process-id: Specifies a process by its ID in the range of 1 to 65535. It is available only when the protocol is IS-IS, OSPF, or RIP.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows redistribution of IBGP routes. It is available when the protocol is BGP.
cost: Specifies a cost for redistributed routes.
The range of the cost depends on its style:
·     For the styles of narrow, narrow-compatible and compatible, the cost is in the range of 0 to 63.
·     For the styles of wide, wide-compatible, the cost is in the range of 0 to 4261412864.
cost-type { external | internal }: Specifies the cost type. The internal type indicates internal routes, and the external type indicates external routes. If external is specified, the cost of a redistributed route to be advertised is added by 64 to make internal routes take priority over external routes. The type is external by default. The keywords are available only when the cost type is narrow, narrow-compatible or compatible.
level-1: Redistributes routes into the Level-1 routing table.
level-1-2: Redistributes routes into both Level-1 and Level-2 routing tables.
level-2: Redistributes routes into the Level-2 routing table. If no level is specified, routes will be redistributed into the Level-2 routing table by default.
route-policy route-policy-name: Redistributes only routes matching the criteria of a routing policy, the name of which is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag value for redistributed routes from 1 to 4294967295.
Use import-route to redistribute routes from another routing protocol or another IS-IS process.
Use undo import-route to disable route redistribution from another routing protocol or another IS-IS process.
By default, no route redistribution is configured.
IS-IS takes all the redistributed routes as external routes to destinations outside the IS-IS routing domain.
Related commands: import-route isis level-2 into level-1.
Using the import-route bgp command redistributes only EBGP routes. Using the import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes, but this might cause routing loops; thus, be cautious when using this command.
Only active routes can be redistributed. You can use the display ip routing-table protocol command to display route state information.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute static routes and set the cost to 15.
[Sysname] isis 1
[Sysname-isis-1] import-route static cost 15
import-route isis level-2 into level-1 [ filter-policy { acl-number | ip-prefix ip-prefix-name | route-policy route-policy-name } | tag tag ] *
undo import-route isis level-2 into level-1
View
IS-IS view
Default level
2: System level
acl-number: Specifies the number of an ACL that is used to filter routes from Level-2 to Level-1. The value range is 2000 to 3999. For ACL configuration information, see ACL and QoS Command Reference.
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list that is used to filter routes from Level-2 to Level-1, a case-sensitive string of 1 to 19 characters. For IP prefix list configuration information, see "Routing policy configuration commands."
route-policy route-policy-name: Specifies the name of a routing policy that is used to filter routes from Level-2 to Level-1, a case-sensitive string of 1 to 63 characters. For routing policy configuration information, see "Routing policy configuration commands."
tag tag: Specifies a tag value from 1 to 4294967295 for redistributed routes.
Use import-route isis level-2 into level-1 to enable route leaking from Level-2 to Level-1.
Use undo import-route isis level-2 into level-1 to disable routing leaking.
By default, no route leaking is configured.
You can specify a routing policy in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
If a filter policy is configured, only routes passing it can be advertised into the Level-1 area.
Related commands: import-route.
# Enable route leaking from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1] import-route isis level-2 into level-1
import-route limit number
undo import-route limit
View
IS-IS view
Default level
2: System level
number: Specifies the maximum number of redistributed Level 1/Level 2 IPv4 routes, in the range of 1 to 262144.
Use import-route limit to configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
Use undo import-route limit to restore the default.
# Configure IS-IS process 1 to redistribute up to 1000 Level 1/Level 2 IPv4 routes.
[Sysname] isis 1
[Sysname-isis-1] import-route limit 1000
isis
undo isis [ process-id ]
View
Default level
2: System level
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. The default is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the IS-IS process belongs to the public network.
Use isis to enable an IS-IS process and specify an associated VPN instance and/or enter IS-IS view.
Use undo isis to disable an IS-IS process.
Related commands: isis enable and network-entity.
# Enable IS-IS routing process 1, with the system ID being 0000.0000.0002, and area ID being 01.0001.
[Sysname] isis 1
[Sysname-isis-1] network-entity 01.0001.0000.0000.0002.00
isis authentication-mode { md5 | simple } [ cipher ] password [ level-1 | level-2 ] [ ip | osi ]
undo isis authentication-mode { md5 | simple } [ cipher ] password [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
level-1: Configures the password for Level-1.
level-2: Configures the password for Level-2.
ip: Checks IP related fields in LSPs and SNPs.
osi: Checks OSI related fields in LSPs and SNPs.
·     This command is not available in loopback interface view.
·     Whether a password should use ip or osi is not affected by the actual network environment.
Use isis authentication-mode to set the IS-IS authentication mode and password for an interface.
Use undo isis authentication-mode to restore the default.
By default, no neighbor relationship authentication is configured.
The password in the specified mode is inserted into all outgoing hello packets and is used for authenticating the incoming hello packets. Only the authentication succeeds can the neighbor relationship be formed.
For two routers to become neighbors, the same authentication mode and password must be specified at both ends.
If you configure a password without specifying a level, the password applies to both Level-1 and Level-2,
The level-1 and level-2 keywords are available only on the Ethernet interfaces with IS-IS enabled with the isis enable command.
Related commands: area-authentication-mode and domain authentication-mode.
# On VLAN-interface 10, configure the authentication mode as simple, and set the plaintext password to 123456.
[Sysname-Vlan-interface10] isis authentication-mode simple 123456 level-1
isis bfd enable
isis bfd enable
undo isis bfd enable
View
Interface view
Default level
2: System level
None
Use isis bfd enable to enable BFD on an IS-IS interface for link failure detection.
Use undo isis bfd enable to disable BFD on an IS-IS interface.
By default, an IS-IS interface is not enabled with BFD.
# Enable BFD for IS-IS on VLAN-interface 11.
[Sysname-Vlan-interface11] isis enable
[Sysname-Vlan-interface11] isis bfd enable
isis circuit-level
isis circuit-level [ level-1 | level-1-2 | level-2 ]
undo isis circuit-level
View
Interface view
Default level
2: System level
level-1: Sets the circuit level to Level-1.
level-1-2: Sets the circuit level to Level-1-2.
level-2: Sets the circuit level to Level-2.
Use isis circuit-level to set the circuit level for the interface.
Use undo isis circuit-level to restore the default.
By default, an interface can establish either the Level-1 or Level-2 adjacency.
For a Level-1 (Level-2) router, the circuit level can only be Level-1 (Level-2). For a Level-1-2 router, you need to specify a circuit level for a specific interface to form only the specified level neighbor relationship.
Related commands: is-level.
# VLAN-interface 10 is connected to a non backbone router in the same area. Configure the circuit level of VLAN-interface 10 as Level-1 to prevent sending and receiving Level-2 Hello packets.
[Sysname-Vlan-interface10] isis enable
[Sysname-Vlan-interface10] isis circuit-level level-1
undo isis circuit-type
View
Interface view
Default level
2: System level
None
Use isis circuit-type p2p to configure the network type for an interface as P2P.
Use undo isis circuit-type to cancel the configuration.
By default, the network type of an interface depends on the physical media. (The network type of a VLAN interface is broadcast.)
Interfaces with different network types operate differently. For example, broadcast interfaces on a network need to elect a DIS and flood CSNP packets to synchronize the LSDBs, while P2P interfaces on a network need not elect a DIS and have a different LSDP synchronization mechanism.
If there are only two routers on a broadcast network, you can configure the network type of attached interfaces as P2P to avoid DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
You can perform this configuration only for a broadcast network with only two attached routers.
# Configure the network type of VLAN-interface 10 as P2P.
[Sysname-Vlan-interface10] isis circuit-type p2p
isis cost
isis [ ipv6-unicast ] cost value [ level-1 | level-2 ]
undo isis [ ipv6-unicast ] cost [ value ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
ipv6-unicast: Specifies an IPv6 unicast topology.
value: Specifies an IS-IS cost for the interface. The cost range differs with cost styles:
·     For cost styles narrow, narrow-compatible and compatible, the cost is in the range of 1 to 63.
·     For cost styles wide and wide-compatible, the cost is in the range of 1 to 16777215.
level-1: Applies the cost to Level-1.
level-2: Applies the cost to Level-2.
Use isis cost to set the IS-IS cost of an interface.
Use undo isis cost to restore the default.
No cost is configured by default.
If neither level-1 nor level-2 is included, the cost applies to both level-1 and level-2.
Configure a proper IS-IS cost for each interface to guarantee correct route calculation.
Relate command: circuit-cost.
# Configure the Level-2 IS-IS cost as 5 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis cost 5 level-2
isis dis-name
isis dis-name symbolic-name
undo isis dis-name
View
Interface view
Default level
2: System level
symbolic-name: Specifies a DIS name, a string of 1 to 64 characters.
Use isis dis-name to configure a name for a DIS to represent the pseudo node on a broadcast network.
Use undo isis dis-name to remove the configuration.
By default, no name is configured for the DIS.
This command takes effect only on a switch that must have dynamic system ID to host name mapping enabled. This command is not supported on a Point-to-Point interface.
# Configure the DIS name as LOCALAREA.
[Sysname-Vlan-interface10] isis dis-name LOCALAREA
isis dis-priority
isis dis-priority value [ level-1 | level-2 ]
undo isis dis-priority [ value ] [  level-1 | level-2 ]
View
Interface view
Default level
2: System level
value: Specifies a DIS priority for the interface, in the range of 0 to 127.
level-1: Applies the DIS priority to Level-1.
level-2: Applies the DIS priority to Level-2.
Use isis dis-priority to specify a DIS priority at a specified level for an interface.
Use undo isis dis-priority to restore the default priority of 64 for Level-1 and Level-2.
If neither level-1 nor level-2 is specified in this command, the DIS priority applies to both Level-1 and Level-2.
On an IS-IS broadcast network, a router should be elected as the DIS at each routing level. You can specify a DIS priority at a level for an interface. The greater the interface's priority is, the more likelihood it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest SNPA (Subnetwork Point of Attachment) address (SNPA addresses are MAC addresses on a broadcast network) becomes the DIS.
There is no backup DIS in IS-IS and the router with a priority of 0 can also participate in DIS election.
# Configure the Level-2 DIS priority as 127 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis dis-priority 127 level-2
isis enable
isis enable [ process-id ]
undo isis enable
View
Interface view
Default level
2: System level
Use isis enable to enable an IS-IS process on the interface.
Use undo isis enable to disable IS-IS.
By default, no IS-IS routing process is enabled on an interface.
Related commands: isis and network-entity.
# Create IS-IS routing process 1, and enable the IS-IS routing process on VLAN-interface 10.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] quit
[Sysname-Vlan-interface10] isis enable 1
isis mesh-group
isis mesh-group { mesh-group-number | mesh-blocked }
undo isis mesh-group
View
Interface view
Default level
2: System level
mesh-group-number: Specifies a mesh group by its number in the range of 1 to 4294967295.
mesh-blocked: Blocks the interface, which sends LSPs only after receiving LSP requests.
Use isis mesh-group to add the interface into a specified mesh group or block the interface.
Use undo isis mesh-group to restore the default.
By default, an interface does not belong to any mesh group.
For an interface not in a mesh group, it follows the normal process to flood the received LSPs to other interfaces. For the NBMA network with high connectivity and multiple point-to-point links, this will cause repeated LSP flooding and bandwidth waste.
After an interface is added to a mesh group, it will only flood a received LSP or a generated LSP to interfaces not belonging to the same mesh group.
If you block an interface, the interface can send LSPs only after receiving LSP requests.
·     The mesh-group feature is only available for a point-to-point link interface.
# Add interface VLAN-interface 1000 to mesh-group 3.
[Sysname] interface Vlan-interface 1000
[Sysname-Vlan-interface1000] isis mesh-group 3
isis mib-binding
isis mib-binding process-id
undo isis mib-binding
View
Default level
2: System level
Use isis mib-binding to bind MIBs with an IS-IS process.
Use undo isis mib-binding to restore the default.
By default, MIBs are bound with IS-IS process 1.
# Bind MIBs with IS-IS process 100.
[Sysname] isis mib-binding 100
isis silent
isis silent
undo isis silent
View
Interface view
Default level
2: System level
None
Use isis silent to disable the interface from sending and receiving IS-IS packets.
Use undo isis silent to restore the default.
By default, an interface is not disabled from sending and receiving IS-IS packets.
The feature is not supported on the loopback interface.
# Disable VLAN-interface 10 from sending and receiving IS-IS packets.
[Sysname-Vlan-interface10] isis silent
isis small-hello
isis small-hello
undo isis small-hello
View
Interface view
Default level
2: System level
None
Use isis small-hello to configure the interface to send small hello packets without CLVs.
Use undo isis small-hello to restore the default.
By default, an interface sends standard hello packets.
# Configure VLAN-interface 10 to send small Hello packets.
[Sysname-Vlan-interface10] isis small-hello
isis timer csnp
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ seconds ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
seconds: Specifies on the DIS of a broadcast network the interval in seconds for sending CSNP packets. The value range is 1 to 600.
level-1: Applies the interval to Level-1.
level-2: Applies the interval to Level-2.
Use isis timer csnp to specify on the DIS of a broadcast network the interval for sending CSNP packets.
Use undo isis timer csnp to restore the default.
The default CSNP interval is 10 seconds.
If no level is specified, the CSNP interval applies to both Level-1 and Level-2.
This command only applies to the DIS of a broadcast network, which sends CSNP packets periodically for LSDB synchronization.
# Configure Level-2 CSNP packets to be sent every 15 seconds over VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer csnp 15 level-2
isis timer hello
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ seconds ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
seconds: Specifies the interval in seconds for sending hello packets. The value range is 3 to 255.
level-1: Specifies the interval for sending Level-1 hello packets.
level-2: Specifies the interval for sending Level-2 hello packets.
Use isis timer hello to specify the interval for sending hello packets.
Use undo isis timer hello to restore the default.
The default hello interval is 10 seconds.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you must specify an interval for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify an interval for each level.
You can configure keywords level-1 and level-2 only on broadcast interfaces. Before doing that, you must enable IS-IS on the interface.
As the shorter the interval is, the more system resources will be occupied, configure a proper interval as needed.
If no level is specified, the hello interval applies to both Level-1 and Level-2.
This command is not supported in loopback interface view.
Related commands: isis timer holding-multiplier.
# Configure Level-2 hello packets to be sent every 20 seconds over VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer hello 20 level-2
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ value ] [ level-1 | level-2 ]
View
Interface view
Default level
2: System level
value: Specifies the number of hello intervals, in the range of 3 to 1000.
level-1: Applies the number to the Level-1 IS-IS neighbor.
level-2: Applies the number to the Level-2 IS-IS neighbor.
Use isis timer holding-multiplier to specify the IS-IS hello multiplier.
Use undo isis timer holding-multiplier to restore the default.
The default IS-IS hello multiplier is 3.
With the IS-IS hello multiplier configured, a router can uses hello packets to notify its neighbor router of the adjacency hold time (hello multiplier times hello interval). If the neighbor router receives no hello packets from this router within the hold time, it declares the adjacency down. You can adjust the adjacency hold time by changing the hello multiplier or the hello interval on an interface.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify a hello multiplier for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify Level-1 or Level-2.
If no level is specified, the hello multiplier applies to the current level.
Related commands: isis timer hello.
# Configure the hello multiplier as 6 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer holding-multiplier 6 level-2
isis timer lsp
isis timer lsp time [ count count ]
undo isis timer lsp
View
Interface view
Default level
2: System level
time: Specifies the minimum interval in milliseconds for sending link-state packets. The value range is 1 to 1000.
count: Specifies the maximum number of link-state packets to be sent at one time. The value range is 1 to 1000. The default is 5.
Use isis timer lsp to configure the minimum interval for sending LSPs on the interface and specify the maximum LSPs that can be sent per time.
Use undo isis timer lsp to restore the default of 33 milliseconds.
Related commands: isis timer retransmit.
# Configure the interval as 500 milliseconds for sending LSPs on interface VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer lsp 500
isis timer retransmit seconds
undo isis timer retransmit
View
Interface view
Default level
2: System level
seconds: Specifies the interval in seconds for retransmitting LSP packets. The value range is 1 to 300.
Use isis timer retransmit to configure the interval for retransmitting LSP packets over a point-to-point link.
Use undo isis timer retransmit to restore the default.
By default, the retransmission interval is 5 seconds.
A P2P link requires a response to a sent LSP. If no response is received within the retransmission interval, the LSP is retransmitted.
You need not use this command over a broadcast link where CSNPs are broadcast periodically.
Configure a proper retransmission interval to avoid unnecessary retransmissions.
Perform this configuration only when the link layer protocol is PPP.
Related commands: isis timer lsp.
# Configure the LSP retransmission interval as 10 seconds for VLAN-interface 1000.
[Sysname-Vlan-interface1000] isis timer retransmit 10
is-level
is-level { level-1 | level-1-2 | level-2 }
undo is-level
View
IS-IS view
Default level
2: System level
level-1: Configures the router to work on Level-1, which means it only calculates routes within the area, and maintains the L1 LSDB.
level-1-2: Configures the router to work on Level-1-2, which means it calculates routes and maintains the LSDBs for both L1 and L2.
level-2: Configures the router to work on Level-2, which means it calculates routes and maintains the LSDB for L2 only.
Use is-level to specify the IS level.
Use undo is-level to restore the default.
The default IS level is level-1-2.
You can configure all the routers as either Level-1 or Level-2 if there is only one area, because there is no need for all routers to maintain two identical databases at the same time. If the only area is an IP network, configure all the routers as Level-2 for scalability.
Related commands: isis circuit-level.
# Configure the router to work in Level-1.
[Sysname] isis 1
[Sysname-isis-1] is-level level-1
is-name
is-name sys-name
undo is-name
View
IS-IS view
Default level
2: System level
sys-name: Specifies a host name for the local IS, a string of 1 to 64 characters.
Use is-name to specify a host name for the IS to enable dynamic system ID to hostname mapping.
Use undo is-name to disable dynamic system ID to hostname mapping.
Dynamic system ID to hostname mapping is not enabled by default.
# Configure a host name for the local IS.
[Sysname] isis 1
is-name map
is-name map sys-id map-sys-name
undo is-name map sys-id
View
IS-IS view
Default level
2: System level
sys-id: Specifies the system ID or pseudonode ID of a remote IS.
map-sys-name: Specifies a host name for the remote IS, a string of 1 to 64 characters.
Use is-name map to configure a system ID to host name mapping for a remote IS.
Use undo is-name map to remove the mapping.
Each remote IS system ID corresponds to only one name.
# Map the host name RUTB to the system ID 0000.0000.0041 of the remote IS.
[Sysname] isis 1
is-snmp-traps enable
undo is-snmp-traps
View
IS-IS view
Default level
2: System level
None
Use is-snmp-traps enable to enable the SNMP Trap function of IS-IS.
Use undo is-snmp-traps to disable this function.
By default, SNMP Trap is enabled.
# Enable SNMP Trap.
[Sysname] isis 1
[Sysname-isis-1] is-snmp-traps enable
log-peer-change (IS-IS view)
log-peer-change
undo log-peer-change
View
IS-IS view
Default level
2: System level
None
Use log-peer-change to enable the logging of IS-IS neighbor state changes.
Use undo log-peer-change to disable the logging.
By default, the logging is enabled.
After the logging is enabled, information about IS-IS adjacency state changes is sent to the configuration terminal.
# Enable logging on the IS-IS adjacency state changes.
[Sysname] isis 1
[Sysname-isis-1] log-peer-change
lsp-fragments-extend
lsp-fragments-extend [ [ level-1 | level-1-2 | level-2 ] | [ mode-1 | mode-2 ] ] *
undo lsp-fragments-extend
View
IS-IS view
Default level
2: System level
level-1: Applies the fragment extension mode to Level-1 LSPs.
level-1-2: Applies the fragment extension mode to both Level-1 and Level-2 LSPs.
level-2: Applies the fragment extension mode to Level-2 LSPs.
mode-1: Specifies the fragment extension mode 1, used on a network where some routers do not support LSP fragment extension.
mode-2: Specifies the fragment extension mode 2, used on a network where all routers support LSP fragment extension.
Use lsp-fragments–extend to enable an LSP fragment extension mode for a level.
Use undo lsp-fragments–extend  to disable LSP fragment extension for a level.
By default, LSP fragment extension is disabled.
If no mode is specified, LSP fragment extension mode 1 is enabled.
If no level is specified, the LSP fragment extension mode is enabled for both Level-1 and Level-2.
# Enable LSP fragment extension mode 1 for Level-2.
[Sysname] isis 1
[Sysname-isis-1] lsp-fragments-extend mode-1 level-2
lsp-length originate
lsp-length originate size [ level-1 | level-2 ]
undo lsp-length originate [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
size: Specifies the maximum size in bytes of LSP packets. The value range is 512 to 16384.
level-1: Applies the size to Level-1 LSP packets.
level-2: Applies the size to Level-2 LSP packets.
Use lsp-length originate to configure the maximum size of generated Level-1 or Level-2 LSPs.
Use undo lsp-length originate to restore the default.
By default, the maximum size of generated Level-1 and Level-2 LSPs is 1497 bytes.
If neither Level-1 nor Level-2 is specified in the command, the configured maximum size applies to the current IS-IS level.
# Configure the maximum size of the generated Level-2 LSPs as 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length originate 1024 level-2
lsp-length receive
lsp-length receive size
undo lsp-length receive
View
IS-IS view
Default level
2: System level
size: Specifies the maximum size of received LSPs, in the range of 512 to 16384 bytes.
Use lsp-length receive to configure the maximum size of received LSPs.
Use undo lsp-length receive to restore the default.
By default, the maximum size of received LSPs is 1497 bytes.
# Configure the maximum size of received LSPs.
[Sysname] isis 1
[Sysname-isis-1] lsp-length receive 1024
maximum load-balancing (IS-IS view)
maximum load-balancing number
undo maximum load-balancing
View
IS-IS view
Default level
2: System level
number: Specifies the maximum number of ECMP routes, in the range of 1 to 32.
Use maximum load-balancing to configure the maximum number of equal-cost multi-path (ECMP) routes.
Use undo maximum load-balancing to restore the default.
By default, the maximum number of ECMP routes is 32.
# Configure the maximum number of ECMP routes as 2.
[Sysname] isis 100
[Sysname-isis-100] maximum load-balancing 2
# Restore the default.
[Sysname-isis-100] undo maximum load-balancing
network-entity
network-entity net
undo network-entity net
View
IS-IS view
Default level
2: System level
net: Specifies a Network Entity Title (NET) in the format of X…X.XXXX....XXXX.00 in hexadecimal notation, with the first part X…X being the area address, the middle part XXXX....XXXX (a total of 12 "X") being the router's system ID and the last part 00 being SEL.
Use network-entity to configure the Network Entity Title for an IS-IS routing process.
Use undo network-entity to delete a NET.
By default, no NET is configured.
A NET is a special NSAP address with the SEL being 0. The length of the NET is in the range of 8 bytes to 20 bytes.
A NET comprises the following parts:
·     Area IDIts length is in the range of 1 to 13 bytes.
·     System IDA system ID uniquely identifies a host or router in the area and has a fixed 6-byte length.
·     SELIt has a value of 0 and a fixed 1-byte length.
For example, a NET is ab.cdef.1234.5678.9abc.00, where area ID is ab.cdef, system ID is 1234.5678.9abc, and SEL is 00.
Related commands: isis and isis enable.
# Specify the NET as 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
[Sysname] isis 1
non-stop-routing
non-stop-routing
undo non-stop-routing
View
IS-IS view
Default level
2: System level
None
Use non-stop-routing to enable IS-IS NSR.
Use undo non-stop-routing to disable IS-IS NSR.
By default, IS-IS NSR is disabled.
The IS-IS GR and IS-IS NSR features are mutual exclusive. That is, the non-stop-routing and graceful-restart commands cannot be configured at the same time.
Before performing a master/backup switchover between IRF member switches, you must configure the irf mac-address persistent always command to prevent bridge MAC address changes that can cause IS-IS NSR failure after the switchover.
# Enable NSR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] non-stop-routing
non-stop-routing interval
non-stop-routing interval interval-value
undo non-stop-routing interval
View
IS-IS view
Default level
2: System view
interval-value: Specifies the NSR interval in the range of 30 to 1800 seconds. The NSR interval refers to the expected interval of an active/standby main board switchover on a distributed switch.
Use non-stop-routing interval to set the NSR interval.
Use undo non-stop-routing interval to restore the default.
By default, the NSR interval is 0 seconds, that is, no NSR interval is set.
If an NSR interval is set on a switch, a neighbor of the switch uses the larger value of the NSR interval and hold time of the switch as the hold time to ensure the neighbor relationship does not time out during an active/standby switchover on the switch.
If no NSR interval is configured on the switch, the hold time configured on a specific interface is used by the corresponding neighbor.
# Set the NSR interval to 40 seconds for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] non-stop-routing interval 40
preference (IS-IS view)
undo preference
View
IS-IS view
Default level
2: System level
preference: Specifies the preference for IS-IS protocol, in the range of 1 to 255.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. The preference applies to routes passing the routing policy.
Use preference to configure the preference for IS-IS.
Use undo preference to restore the default.
By default, IS-IS preference is 15.
If a routing policy is specified in this command, the preference (if any) set by the routing policy applies to those matched routes. Other routes use the preference set by the preference command.
When a router runs multiple routing protocols at the same time, the system will set a preference to each routing protocol. If several protocols find routes to the same destination, the route of the routing protocol with the highest preference is selected.
# Configure the preference of IS-IS protocol as 25.
[Sysname] isis
[Sysname-isis-1] preference 25
priority high
priority high { ip-prefix prefix-name | tag tag-value }
undo priority high [ ip-prefix | tag ]
View
IS-IS view
Default level
2: System level
ip-prefix ip-prefix-name: Specifies the name of an IP prefix list, a case-sensitive string of 1 to 19 characters.
tag tag-value: Specifies a tag value in the range of 1 to 4294967295.
Use priority high to assign a high priority to specific routes for faster network convergence.
Use undo priority high to restore the default.
By default, no IS-IS route is assigned a high priority.
If no IS-IS route is assigned a high priority, IS-IS host routes are processed first in network convergence because they have higher priority than other types of IS-IS routes.
# Assign a high priority to the IS-IS routes matching IP prefix list standtest.
[Sysname] isis 1
[Sysname-isis-1] priority high ip-prefix standtest
reset isis all
reset isis all [ process-id | vpn-instance vpn-instance-name ]
View
Default level
2: System level
process-id: Clears the data structure information of an IS-IS process numbered from 1 to 65535.
vpn-instance vpn-instance-name: Clears the data structure information of the MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the data structure information of the public network is cleared.
Use reset isis all to clear all IS-IS data structure information.
By default, no data structure information is cleared.
This command is used when the LSP needs to be updated immediately. For example, after performing the area-authentication-mode and domain-authentication-mode commands, you can use this command to clear old LSPs.
# Clear all IS-IS data structure information.
<Sysname> reset isis all
reset isis peer
reset isis peer system-id [ process-id | vpn-instance vpn-instance-name ]
View
Default level
2: System level
system-id: Specifies the system ID of an IS-IS neighbor.
process-id: Clears the data structure information of an IS-IS process with an ID from 1 to 65535.
Use reset isis peer to clear the data structure information of a specified IS-IS neighbor.
This command is used when you need to re-establish an IS-IS neighbor relationship.
# Clear the data structure information of the neighbor with the system ID 0000.0c11.1111.
<Sysname> reset isis peer 0000.0c11.1111
set-overload
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ] [ allow { external | interlevel } * ]
undo set-overload
View
IS-IS view
Default level
2: System level
on-startup: Sets the overload bit upon system startup.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Starts the nbr-timeout timer when the router begins to establish the neighbor relationship with the neighbor after system startup. If the neighbor relationship is formed within the nbr-timeout interval, IS-IS keeps the overload bit set; if not, the bit is cleared. IS-IS keeps the overload bit set within the timeout1 interval after the neighbor relationship is formed within the nbr-timeout interval.
·     system-id: Specifies the neighbor.
·     timeout1: The timeout1 interval is in the range of 5 to 86400 seconds and defaults to 600 seconds.
·     nbr-timeout: The timer has an interval from 5 to 86400 seconds. The default is 1200 seconds.
timeout2: Sets the overload bit within the timeout2 interval after system startup. The interval is in the range of 5 to 86400 seconds and defaults to 600 seconds.
allow: Allows advertising address prefixes. By default, no address prefixes are allowed to be advertised when the overload bit is set.
external: Allows advertising IP address prefixes redistributed from other routing protocols with the allow keyword specified.
interlevel: Allows advertising IP address prefixes learnt from different IS-IS levels with the allow keyword specified.
Use set-overload to configure the overload bit.
Use undo set-overload to clear the overload bit.
By default, no overload bit is configured.
If the on-startup keyword is not specified, the command sets the overload bit immediately until the undo set-overload command is executed.
If the on-startup keyword is specified, IS-IS sets the overload bit upon system startup and keeps it set within the timeout2 interval.
# Configure overload bit on the current router.
[Sysname] isis 1
[Sysname-isis-1] set-overload
summary (IS-IS view)
summary ip-address { mask | mask-length } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ip-address { mask | mask-length } [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Default level
2: System level
ip-address: Specifies the destination IP address of the summary route.
mask: Specifies the mask of the destination IP address, in dotted decimal notation.
mask-length: Specifies the mask length in the range of 0 to 32.
avoid-feedback: Avoids learning summary routes by route calculation.
generate_null0_route: Generates the Null 0 route to avoid routing loops.
level-1: Summarizes only the routes redistributed to Level-1.
level-1-2: Summarizes the routes redistributed to both Level-1 and Level-2.
level-2: Summarizes only the routes redistributed to Level-2.
tag tag: Specifies a management tag in the range of 1 to 4294967295.
Use summary to configure a summary route.
Use undo summary to remove a summary route.
By default, no summarization is configured.
If no level is specified, only the level-2 routes will be summarized by default.
You can summarize multiple contiguous networks into a single network to reduce the size of the routing table, as well as that of LSP and LSDB generated by the router. It is allowed to summarize native IS-IS routes and redistributed routes. After summarization, the cost of the summary route is the smallest cost of those summarized routes.
The router summarizes only routes in local LSPs.
# Configure a summary route of 202.0.0.0/8.
[Sysname] isis 1
[Sysname-isis-1] summary 202.0.0.0 255.0.0.0
timer lsp-generation
timer lsp-generation maximum-interval [ initial-interval [ second-wait-interval ] ] [ level-1 | level-2 ]
undo timer lsp-generation [ level-1 | level-2 ]
View
IS-IS view
Default level
2: System level
maximum-interval: Specifies the maximum wait interval in seconds for generating IS-IS LSPs. The value range is 1 to 120.
initial-interval: Specifies the initial wait interval in milliseconds before generating the first IS-IS LSP. The value range is 10 to 60000, and the default is 0.
second-wait-interval: Specifies the wait interval in milliseconds before generating the second LSP. The value range is 10 to 60000, and the default is 0.
level-1: Applies the intervals to Level-1.
level-2: Applies the intervals to Level-2 .If no level is specified, the specified intervals apply to both Level-1 and Level-2.
Use timer lsp-generation to specify the wait interval before generating IS-IS LSPs.
Use undo timer lsp-generation to restore the default.
By default, the wait interval before LSP generation is 2 seconds.
If only the maximum interval is specified, IS-IS waits the maximum interval before generating an LSP.
If both the maximum and initial intervals are specified, the following happens:
·     IS-IS waits the initial interval before generating the first LSP.
·     If the network topology is unstable, that is, triggers occur at intervals shorter than the maximum interval, IS-IS waits the maximum interval before generating the first LSP until the network topology is stable.
If the maximum, initial, and second wait intervals are specified, the following happens:
·     If the network topology is unstable, that is, triggers occur at intervals shorter than the maximum interval, IS-IS waits the second-wait-interval before generating the second LSP and penalty is applied on the wait interval before generating the next LSP. That is, for each subsequent trigger, the wait interval before generating the LSP will be twice the previous wait interval until the maximum interval is reached.
·     After the network topology is stable; that is, triggers occur at intervals greater than the maximum interval, the wait interval before generating LSPs is restored to the initial interval.
# Set the maximum, initial, and second wait intervals to 10 seconds, 100 milliseconds and 200 milliseconds.
[Sysname] isis 1
[Sysname-isis-1]timer lsp-generation 10 100 200
timer lsp-max-age
timer lsp-max-age seconds
undo timer lsp-max-age
View
IS-IS view
Default level
2: System level
seconds: Specifies the LSP maximum aging time in seconds, in the range of 1 to 65535.
Use timer lsp-max-age to set the LSP maximum age in the LSDB.
Use undo timer lsp-max-age to restore the default.
The default LSP maximum age is 1200 seconds.
Related commands: timer lsp-refresh.
# Set the maximum LSP age to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-max-age 1500
timer lsp-refresh
timer lsp-refresh seconds
undo timer lsp-refresh
View
IS-IS view
Default level
2: System level
seconds: Specifies the LSP refresh interval in seconds, in the range of 1 to 65534.
Use timer lsp-refresh to set the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
The default LSP refresh interval is 900 seconds.
Related commands: timer lsp-max-age.
IMPORTANT:
To refresh LSPs before they are aged out, the interval set by the timer lsp-refresh command must be smaller than that set by the timer lsp-max-age command.
# Set the LSP refresh interval to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-refresh 1500
timer spf
timer spf maximum-interval [ initial-interval [ second-interval ] ]
undo timer spf
View
IS-IS view
Default level
2: System level
maximum-interval: Specifies the maximum SPF calculation interval in the range of 1 to 120 seconds.
initial-interval: Specifies the wait interval before the first SPF calculation, in the range of 10 to 60000 milliseconds. The default is 0.
second-interval: Specifies the wait interval before the second SPF calculation, in the range of 10 to 60000 milliseconds. The default is 0.
Use timer spf to set the SPF calculation interval.
Use undo timer spf to restore the default.
The default IS-IS SPF calculation interval is 10 seconds.
If only the maximum interval is specified, IS-IS waits the maximum interval before performing the SPF calculation.
·     IS-IS waits the initial interval before performing the first SPF calculation.
·     When SPF calculation triggers occur at intervals shorter than the maximum interval, the topology is considered unstable and IS-IS waits the maximum interval before performing the SPF calculation until the topology is stable.
If maximum-interval, initial-interval, and second-interval are specified, the following happens:
·     When SPF calculation triggers occur at intervals shorter than the maximum interval, the topology is considered unstable, IS-IS will wait the second-interval before performing the second SPF calculation and penalty is applied on the wait interval for the next SPF calculation. That is, for each subsequent trigger, the wait interval before SPF calculation will be twice the previous wait interval until the maximum interval is reached.
·     After the network topology becomes stable; that is, triggers occur at intervals greater than the maximum interval, the wait interval before SPF calculation is restored to the initial interval.
# Set the maximum SPF calculation interval to 10 seconds, the wait interval before the first SPF calculation to 100 milliseconds, and the wait interval before the second SPF calculation to 200 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] timer spf 10 100 200
virtual-system
virtual-system virtual-system-id
undo virtual-system virtual-system-id
View
IS-IS view
Default level
2: System level
virtual-system-id: Specifies the virtual system ID of the IS-IS process.
Use virtual-system to configure a virtual system ID for the IS-IS process. Use undo virtual-system to remove a virtual system ID.
Up to 50 virtual system IDs can be configured for the IS-IS process.
# Configure a virtual system ID of 2222.2222.2222 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] virtual-system 2222.2222.2222
