07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
09-IPv6 Static Routing Commands
09-IPv6 Static Routing Commands 63.76 KB
delete ipv6 static-routes all
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, all IPv6 static routes of the public network are deleted.
Use delete ipv6 static-routes all to delete all IPv6 static routes.
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes..
To delete one IPv6 static route, use the undo ipv6 route-static command. To delete all IPv6 static routes, including the default route, use the delete ipv6 static-routes all command
Related commands: ipv6 route-static and display ipv6 routing-table.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all ipv6 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]y
ipv6 route-static
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ preference preference-value ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ipv6 route-static vpn-instance s-vpn-instance-name&<1-6> ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | nexthop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ preference preference-value ]
undo ipv6 route-static vpn-instance s-vpn-instance-name&<1-6> ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | nexthop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
View
Default level
2: System level
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is a non-P2P interface, such as an NBMA interface or broadcast interface (for example, an Ethernet interface, a virtual template interface, or a VLAN interface), the next hop address must be specified.
nexthop-address: Specifies the next hop IPv6 address.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN. d-vpn-instance-name is a case-sensitive string of 1 to 31 characters. If a destination VPN is specified, packets will search for the output interface in the destination VPN based on the specified next hop (IPv6 address) for the IPv6 static route.
preference preference-value: Specifies the route preference value in the range of 1 to 255. The default is 60.
vpn-instance s-vpn-instance-name&<1-6>: Specifies a source MPLS L3VPN. s-vpn-instance-name is a case-sensitive string of 1 to 31 characters. &<1-6> indicates the argument before it can be entered up to six times. Each VPN has its own routing table, and the configured IPv6 static route is installed in the routing tables of the specified VPNs.
public: Specifies a next hop in the public network.
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
By default, no IPv6 static route is configured.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route will be used to forward the packet.
When you configure static routes, you can configure either the output interface or the next hop address depending on the situations:
·     If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified. If both the output interface and the next hop must be specified, the next hop address must be a link-local address.
·     If the output interface is a point-to-point interface, you can specify either the output interface or the next hop address, but not both.
Related commands: delete ipv6 static-routes all and display ipv6 routing-table.
# Configure a static IPv6 route, with the destination address 1:1:2::/24 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 24 1:1:3::1
