07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
03-RIP Commands
03-RIP Commands 193.94 KB
checkzero
checkzero
undo checkzero
View
RIP view
Default level
2: System level
None
Use checkzero to enable zero field check on RIPv1 messages.
Use undo checkzero to disable zero field check.
By default, the zero field check function is enabled.
After the zero field check is enabled, the router discards RIPv1 messages in which zero fields are non-zero. If all messages are trusty, you can disable this feature to reduce the processing time of the CPU.
# Disable the zero field check on RIPv1 messages for RIP process 100.
[Sysname] rip 100
[Sysname-rip-100] undo checkzero
default cost (RIP view)
default cost value
undo default cost
View
RIP view
Default level
2: System level
value: Specifies a default metric of redistributed routes, in the range of 0 to 16.
Use default cost to configure the default metric for redistributed routes.
Use undo default cost to restore the default.
By default, the default metric of redistributed routes is 0.
When you use the import-route command to redistribute routes from other protocols without specifying a metric, the metric specified by the default cost command applies.
Related command: import-route.
# Configure the default metric for redistributed routes as 3.
[Sysname] rip 100
[Sysname-rip-100] default cost 3
default-route
default-route { only | originate } [ cost cost ]
undo default-route
View
RIP view
Default level
2: System level
only: Advertises only a default route.
originate: Advertises both a default route and other routes.
cost: Specifies a cost for the default route, in the range of 1 to 15. The default is 1.
Use default-route to configure all the interfaces under the RIP process to advertise a default route with the specified metric to RIP neighbors.
Use undo default-route to disable all the interfaces under the RIP process from sending a default route.
By default, no default route is sent to RIP neighbors.
The RIP router with this feature configured will not receive any default routes from RIP neighbors.
Related commands: rip default-route.
# Configure all the interfaces under RIP process 100 to send only a default route with a metric of 2 to RIP neighbors.
[Sysname] rip 100
[Sysname-rip-100] default-route only cost 2
display rip
display rip [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. If no process ID is specified, information about all configured RIP processes is displayed.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the information of the public network is displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display rip to display the current status and configuration information of the specified RIP process.
# Display the current status and configuration information of all configured RIP processes.
<Sysname> display rip
  Public VPN-instance name :
    RIP process : 1
       RIP version : 1
       Preference : 100
       Checkzero : Enabled
       Default-cost : 0
       Summary : Enabled
       Hostroutes : Enabled
       Maximum number of balanced paths : 32
       Update time   :   30 sec(s)  Timeout time         :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-collect time :  120 sec(s)
       update output delay :   20(ms)  output count :    3
       TRIP retransmit time :    5 sec(s)
       TRIP response packets retransmit count :   36
       Silent interfaces : None
       Default routes : Only  Default route cost : 3
       Verify-source : Enabled
       Networks :
           192.168.1.0
       Configured peers : None
       Triggered updates sent : 0
       Number of routes changes : 0
       Number of replies to queries : 0
Public VPN-instance name (or Private VPN-instance name)
The RIP process runs under a public VPN instance/The RIP process runs under a private VPN instance.
RIP process
RIP process ID.
RIP version
RIP version 1 or 2.
Preference
RIP route priority.
Checkzero
Indicates whether the zero field check is enabled for RIPv1 messages.
Default-cost
Default cost of the redistributed routes.
Summary
Indicates whether route summarization is enabled.
Hostroutes
Indicates whether to receive host routes.
Maximum number of load balanced routes.
Update time
RIP update interval.
Timeout time
RIP timeout time.
Suppress time
RIP suppress interval.
update output delay
RIP packet sending interval.
output count
Maximum number of RIP packets sent at each interval.
RIP garbage collection interval.
TRIP retransmit interval for sending update requests and responses.
Maximum retransmit times for update requests and responses.
Silent interfaces
Number of silent interfaces, which do not periodically send updates.
Default routes
Indicates whether a default route is sent to RIP neighbors.
·     only—Only a default route is advertised.
·     originate—A default route is advertised along with other routes.
·     disable—No default route is advertised.
Default route cost
Cost of the default route.
Verify-source
Indicates whether the source IP address is checked on the received RIP routing updates.
Networks
Networks enabled with RIP.
Configured peers
Configured neighbors.
Number of sent triggered updates.
Number of changed routes in the database.
Number of RIP responses.
display rip database
display rip process-id database [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display rip database to display active routes in the database of the specified RIP process, which are sent in RIP routing updates.
# Display the active routes in the database of RIP process 100.
<Sysname> display rip 100 database
   10.0.0.0/8, cost 1, ClassfulSumm
   10.0.0.0/24, cost 1, nexthop 10.0.0.1, Rip-interface
   11.0.0.0/8, cost 1, ClassfulSumm
   11.0.0.0/24, cost 1, nexthop 10.0.0.1, Imported
X.X.X.X/X
Destination address and subnet mask.
cost
Cost of the route.
classful-summ
Indicates the route is a RIP summary route.
Nexthop
Address of the next hop.
Rip-interface
Routes learnt from a RIP-enabled interface.
imported
Routes redistributed from other routing protocols.
display rip interface
display rip process-id interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Specifies an interface.
Use display rip interface to display the RIP interface information of the RIP process.
If no interface is specified, information about all RIP interfaces of the RIP process is displayed.
# Display all the interface information of RIP process 1.
<Sysname> display rip 1 interface
Interface-name: Vlan-interface11
        Address/Mask:1.1.1.1/24        Version:RIPv1
        MetricIn:5                     MetricIn route policy:123
        MetricOut:5                    MetricOut route policy:234
        Split-horizon/Poison-reverse:on/off  Input/Output:on/on
        Default route:off
        Current packets number/Maximum packets number:234/2000
Interface-name
Name of an interface running RIP.
Address/Mask
IP address and mask of the interface.
Version
RIP version running on the interface.
MetricIn
Additional routing metric added to the incoming routes.
Name of the routing policy used to add the additional routing metric for the incoming routes. If no routing policy is referenced, the field displays Not designated.
MetricOut
Additional routing metric added to the outgoing routes.
Name of the routing policy used to add the additional routing metric for the outgoing routes. If no routing policy is referenced, the field displays Not designated.
Split-horizon
Indicates whether split-horizon is enabled:
·     on—Enabled.
·     off—Disabled.
Poison-reverse
Indicates whether poison-reverse is enabled:
·     on—Enabled.
·     off—Disabled.
Input/Output
Indicates if the interface is allowed to receive (Input) or send (Output) RIP messages:
·     on—It is allowed.
·     off—It is not allowed.
Default route
Indicates whether sending the default route to RIP neighbors is allowed:
·     on—It is allowed.
Packets to be sent/Maximum packets that can be sent on the interface.
display rip route
display rip process-id route [ ip-address { mask | mask-length } | peer ip-address| statistics ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address { mask | mask-length }: Displays route information about a specified IP address.
peer ip-address: Displays all routing information learned from a specified neighbor.
statistics: Displays the route statistics, including total number of routes and number of routes of each neighbor.
Use display rip route to display the routing information of a specified RIP process.
# Display all routing information of RIP process 1.
<Sysname> display rip 1 route
 Peer 111.1.1.2  on Vlan-interface11
      Destination/Mask        Nexthop     Cost    Tag   Flags   Sec
        122.0.0.0/8          111.1.1.2      1       0    RA      22
Route Flags
·     R—RIP route.
·     T—TRIP route.
·     P—The route never expires.
·     A—The route is aging.
·     S—The route is suppressed.
·     G—The route is in Garbage-collect state.
Peer 21.0.0.23 on Vlan-interface11
Routing information learned on a RIP interface from the specified neighbor.
Destination/Mask
Destination IP address and subnet mask.
Nexthop
Next hop of the route.
Cost
Cost of the route.
Tag
Route tag.
Flags
Indicates the route state.
Sec
Remaining time of the timer corresponding to the route state.
# Display the routing statistics of RIP process 1.
<Sysname> display rip 1 route statistics
Peer            Aging     Permanent    Garbage
 111.1.1.2        1         0             0
 Total            1         0             0
Table 5 Command output
Peer
IP address of a neighbor.
Aging
Total number of aging routes learned from the specified neighbor.
Permanent
Total number of permanent routes learned from the specified neighbor.
Garbage
Total number of routes in garbage-collection state learned from the specified neighbor.
Total
Total number of routes learned from all RIP neighbors.
fast-reroute
undo fast-reroute
View
RIP view
Default level
2: System level
route-policy route-policy-name: References a routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
Use fast-reroute to configure RIP fast reroute (FRR).
Use undo fast-reroute to restore the default.
By default, RIP FRR is disabled.
IMPORTANT:
·     RIP FRR is only effective for non-recursive RIP routes that are learned from directly connected neighbors.
·     Do not use RIP FRR and BFD for RIP at the same time; otherwise, RIP FRR might fail to take effect.
Example
# Enable RIP FRR and reference routing policy frr to specify a backup next hop.
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname] route-policy frr permit node 10
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy] apply fast-reroute backup-interface Vlan-interface 1000 backup-nexthop 193.1.1.8
[Sysname-route-policy] quit
[Sysname] rip 100
[Sysname-rip-100] fast-reroute route-policy frr
filter-policy export (RIP view)
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface-type interface-number ]
undo filter-policy export [ protocol [ process-id ] | interface-type interface-number ]
View
RIP view
Default level
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter outbound routes.
ip-prefix ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters, to filter outbound routes.
protocol: Filters outbound routes redistributed from a specified routing protocol, which can be bgp, direct, isis, ospf, rip, and static.
process-id: Specifies the process ID of the specified routing protocol, in the range of 1 to 65535. You need to specify a process ID when the routing protocol is rip, ospf, or isis.
Use filter-policy export to configure the filtering of RIP outgoing routes. Only routes not filtered out can be advertised.
Use undo filter-policy export to remove the filtering.
By default, RIP does not filter outbound routes.
·     If protocol is specified, RIP filters only the outgoing routes redistributed from the specified routing protocol. Otherwise, RIP filters all routes to be advertised.
·     If interface-type interface-number is specified, RIP filters only the routes advertised by the specified interface. Otherwise, RIP filters routes advertised by all RIP interfaces.
·     If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route while the destination keyword specifies the subnet mask of the route (the subnet mask must be valid; otherwise, the configuration is ineffective).
Related commands: ip ip-prefix; acl (ACL and QoS Command Reference).
# Reference ACL 2000 to filter outbound routes.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny ip source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 export
# Reference IP prefix list abc to filter outbound routes on VLAN-interface 11.
[Sysname-rip-1] filter-policy ip-prefix abc export Vlan-interface 11
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter outbound routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] rip 1
[Sysname-rip 1] filter-policy 3000 export
filter-policy import (RIP view)
filter-policy { acl-number | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import [ interface-type interface-number ]
undo filter-policy import [ interface-type interface-number ]
View
RIP view
Default level
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter incoming routes.
ip-prefix ip-prefix-name: References an IP prefix list to filter incoming routes. The ip-prefix-name is a string of 1 to 19 characters.
gateway ip-prefix-name: References an IP prefix list to filter routes from the gateway. ip-prefix-name is a string of 1 to 19 characters.
Use filter-policy import to configure RIP to filter the incoming routes.
Use undo filter-policy import to restore the default.
By default, RIP does not filter incoming routes.
# Reference ACL 2000 to filter incoming routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 import
# Reference IP prefix list abc on GigabitEthernet 3/0/1 to filter all received RIP routes.
[Sysname-rip-1] filter-policy ip-prefix abc import GigabitEthernet 3/0/1
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter incoming routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 3000 import
host-route
host-route
undo host-route
View
RIP view
Default level
2: System level
None
Use host-route to enable host route reception.
Use undo host-route to disable host route reception.
By default, receiving host routes is enabled.
In some cases, a router might receive many host routes from the same network segment. These routes are not helpful for routing and occupy a large amount of network resources. You can use the undo host-route command to disable receiving of host routes.
RIPv2 can be disabled from receiving host routes, but RIPv1 cannot.
# Disable RIP from receiving host routes.
[Sysname] rip 1
[Sysname-rip-1] undo host-route
import-route (RIP view)
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | route-policy route-policy-name | tag tag ] *
View
RIP view
Default level
2: System level
protocol: Specifies a routing protocol from which to redistribute routes. At present, it can be bgp, direct, isis, ospf, rip, or static.
process-id: Specifies a process ID in the range of 1 to 65535. The default is 1. It is available only when the protocol is isis, rip, or ospf.
all-processes: Enables route redistribution from all the processes of a protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows redistribution of IBGP routes. This keyword is available when the protocol argument is set to bgp.
cost: Specifies a cost for redistributed routes, in the range of 0 to 16. If cost is not specified, the default cost specified by the default cost command applies.
tag: Specifies a tag marking redistributed routes, in the range of 0 to 65535. The default is 0.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Use import-route to enable route redistribution from another routing protocol.
Use undo import-route to disable route redistribution.
By default, RIP does not redistribute routes from other routing protocols.
Related commands: default cost.
The import-route bgp command only redistributes EBGP routes, while the import-route bgp allow-ibgp command additionally redistributes IBGP routes, which might cause routing loops. Be cautious when using it.
Only active routes can be redistributed. You can use the display ip routing-table protocol command to display route state information.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute static routes, and set the cost to 4.
[Sysname] rip 1
[Sysname-rip-1] import-route static cost 4
# Configure the default cost for redistributed routes as 3.
[Sysname-rip-1] default cost 3
# Redistribute OSPF routes with the cost being the default cost.
[Sysname-rip-1] import-route ospf
maximum load-balancing (RIP view)
maximum load-balancing number
undo maximum load-balancing
View
RIP view
Default level
2: System level
number: Specifies the maximum number of ECMP routes, in the range of 1 to 32.
Use maximum load-balancing to specify the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
By default, the maximum number of ECMP routes is 32.
# Specify the maximum number of ECMP routes as 2.
[Sysname] rip
[Sysname-rip-1] maximum load-balancing 2
network
network network-address
undo network network-address
View
RIP view
Default level
2: System level
network-address: Specifies the IP address of a network segment, which can be the IP network address of any interface.
Use network to enable RIP on the interface attached to the specified network.
Use undo network to disable RIP on the interface attached to the specified network.
By default, RIP is disabled on an interface.
RIP runs only on the interfaces attached to the specified network. For an interface not on the specified network, RIP neither receives/sends routes nor forwards interface route on it. Therefore, you need to specify the network after enabling RIP to validate RIP on a specific interface.
For a single process, you can use the network 0.0.0.0 command to enable RIP on all interfaces, while the command is not applicable in case of multi-process.
If a physical interface is attached to multiple networks, you cannot advertise these networks in different RIP processes.
# Enable RIP on the interface attached to the network 129.102.0.0.
[Sysname] rip 100
[Sysname-rip-100] network 129.102.0.0
output-delay
output-delay time count count
undo output-delay
View
RIP view
Default level
2: System level
time: Specifies the RIP packet sending interval in the range of 10 to 100 milliseconds.
count: Specifies the maximum number of RIP packets sent at each interval. The value range is 1 to 20.
Use output-delay to configure the maximum RIP packets that can be sent at the specified interval for all interfaces under the RIP process.
Use undo output-delay to restore the default.
By default, an interface sends up to three RIP packets every 20 milliseconds.
# Configure all the interfaces under RIP process 1 to send up to 10 RIP packets every 30 milliseconds.
[Sysname] rip 1
[Sysname-rip-1] output-delay 30 count 10
peer
peer ip-address
undo peer ip-address
View
RIP view
Default level
2: System level
ip-address: Specifies the IP address of a RIP neighbor, in dotted decimal notation.
Use peer to specify the IP address of a neighbor in the non-broadcast multi-access (NBMA) network, where routing updates destined for the peer are unicast, rather than multicast or broadcast.
Use undo peer to remove the IP address of a neighbor.
By default, no neighbor is specified.
Note that you need not use the peer ip-address command when the neighbor is directly connected; otherwise the neighbor might receive both the unicast and multicast (or broadcast) of the same routing information.
# Specify to send unicast updates to peer 202.38.165.1.
[Sysname] rip 1
[Sysname-rip-1] peer 202.38.165.1
preference
preference [ route-policy route-policy-name ] value
undo preference [ route-policy ]
View
RIP view
Default level
2: System level
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 19 characters.
value: Specifies a priority for RIP route, in the range of 1 to 255. The smaller the value, the higher the priority.
Use preference to specify the RIP route priority.
Use undo preference route-policy to restore the default.
By default, the priority of a RIP route is 100.
You can specify a routing policy using the keyword route-policy to set the specified priority to routes matching the routing policy.
·     If a priority is set for matched routes in the routing policy, the priority applies to these routes. The priority of other routes is the one set by the preference command.
·     If no priority is set for matched routes in the routing policy, the priority of all routes is the one set by the preference command.
# Set the RIP route priority to 120.
[Sysname] rip 1
[Sysname-rip-1] preference 120
reset rip process
reset rip process-id process
View
Default level
2: System level
Use reset rip process to reset the specified RIP process.
After executing the command, you are prompted whether you want to reset the RIP process.
# Reset RIP process 100.
<Sysname> reset rip 100 process
Warning : Reset RIP process? [Y/N]:Y
reset rip statistics
reset rip process-id statistics
View
Default level
1: Monitor level
Use reset rip statistics to clear the statistics of the specified RIP process. This command can be used to clear the statistics of debugging.
# Clear statistics in RIP process 100.
<Sysname> reset rip 100 statistics
rip
rip [ process-id ] [ vpn-instance vpn-instance-name ]
undo rip [ process-id ] [ vpn-instance vpn-instance-name ]
View
Default level
2: System level
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. The default is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If no VPN is specified, the RIP process will run under the public network.
Use rip to create a RIP process and enter RIP view.
Use undo rip to disable a RIP process.
By default, no RIP process runs.
If no VPN instance is specified, the RIP process will run under public network instance.
You must create a VPN instance before you apply a RIP process to it. For related configuration, see the ip vpn-instance command in MPLS Command Reference.
You must enable the RIP process before configuring the global parameters. This limitation is not for configuration of interface parameters.
The configured interface parameters become invalid after you disable the RIP process.
# Create a RIP process and enter RIP process view.
[Sysname] rip
[Sysname-rip-1]
rip authentication-mode
rip authentication-mode { md5 { rfc2082 [ cipher ] key-string key-id | rfc2453 [ cipher ] key-string } | simple [ cipher ] password }
undo rip authentication-mode
View
Interface view
Default level
2: System level
md5: Specifies the MD5 authentication mode.
rfc2082: Uses the message format defined in RFC 2082.
cipher: Sets a ciphertext authentication key or password. If this keyword is not specified, you set a plaintext authentication key or password.
key-string: Specifies the MD5 key string. This argument is case sensitive. It must be a plaintext string of 1 to 16 characters, or a ciphertext string of 33 to 53 characters.
key-id: Specifies an MD5 key number in the range of 1 to 255.
rfc2453: Uses the message format defined in RFC 2453 (IETF standard).
simple: Specifies the simple authentication mode.
password: Sets the password in simple authentication mode. This argument is case sensitive. It must be a plaintext string of 1 to 16 characters, or a ciphertext string of 33 to 53 characters.
Use rip authentication-mode to configure RIPv2 authentication mode and parameters.
Use undo rip authentication-mode to cancel authentication.
A newly configured key string or password overwrites the old one, if any.
For security purposes, all keys or passwords, including keys or passwords configured in plain text, are saved in cipher text.
Related commands: rip version.
# Configure MD5 authentication on VLAN-interface 10, and specify a plaintext key rose in the format defined in RFC 2453.
[Sysname-Vlan-interface10] rip version 2
[Sysname-Vlan-interface10] rip authentication-mode md5 rfc2453 rose
rip bfd enable
rip bfd enable
undo rip bfd enable
View
Interface view
Default level
2: System level
None
Use rip bfd enable to enable BFD on the RIP interface.
Use undo rip bfd enable to restore the default and delete the relevant BFD session.
By default, a RIP interface is not enabled with BFD.
BFD echo-mode detection only works for a RIP neighbor one hop away.
Using the undo peer command does not delete the neighbor relationship at once and therefore cannot bring down the BFD session at once.
# Enable BFD on RIP interface VLAN-interface 11.
[Sysname-Vlan-interface11] rip bfd enable
rip default-route
rip default-route { { only | originate } [ cost cost ] | no-originate }
undo rip default-route
View
Interface view
Default level
2: System level
originate: Advertises a default route and other routes.
no-originate: Advertises routes other than a default route.
Use rip default-route to configure the RIP interface to advertise a default route with the specified metric.
Use undo rip default-route to disable the RIP interface from sending a default route.
By default, a RIP interface can advertise a default route if the RIP process is configured with default route advertisement.
A RIP router configured to advertise a default route will not receive any default routes from RIP neighbors.
Related commands: default-route.
# Configure VLAN-interface 10 to advertise only a default route with a metric of 2.
[Sysname-Vlan-interface10] rip default-route only cost 2
rip input
rip input
undo rip input
View
Interface view
Default level
2: System level
None
Use rip input to enable the interface to receive RIP messages.
Use undo rip input to disable the interface from receiving RIP messages.
By default, an interface is enabled to receive RIP messages.
Related commands: rip output.
# Disable VLAN-interface 10 from receiving RIP messages.
[Sysname-Vlan-interface10] undo rip input
rip metricin
rip metricin [ route-policy route-policy-name ] value
undo rip metricin
View
Interface view
Default level
2: System level
route-policy route-policy-name: Specifies the name of a routing policy used to add an additional metric for the routes matching it. The name is a string of 1 to 63 case-sensitive characters.
value: Adds an additional metric to received routes, in the range of 0 to 16.
Use rip metricin to configure the interface to add a metric to the routes it receives.
Use undo rip metricin to restore the default.
By default, the additional metric of a received route is 0.
When a valid RIP route is received, the system adds a metric to it and then installs it into the routing table. Therefore, the metric of the route received on the configured interface is increased. If the sum of the additional metric and the original metric is greater than 16, the metric of the route will be 16.
If a routing policy is referenced with the route-policy keyword:
·     Routes matching the policy is added with the metric specified in the apply cost command configured in the policy, while routes not matching it is added with the metric specified in the rip metricout command. Note that, the rip metricout command does not support the + or – keyword (used to add or reduce a metric) specified in the apply cost command. For more information about the apply cost command, see "Routing policy configuration commands."
·     If the apply cost command is not configured in the policy, all the advertised routes is added with the metric specified in the rip metricout command.
Related commands: rip metricout.
# Configure VLAN-interface 10 to add a metric of 6 for incoming route 1.0.0.0/8 and to add a metric of 2 for other incoming routes.
[Sysname] ip ip-prefix 123 permit 1.0.0.0 8
[Sysname] route-policy abc permit node 0
[Sysname-route-policy] if-match ip-prefix 123
[Sysname-route-policy] apply cost 6
[Sysname-Vlan-interface10] rip metricin route-policy abc 2
rip metricout
rip metricout [ route-policy route-policy-name ] value
undo rip metricout
View
Interface view
value: Adds an additional metric to sent routes, in the range of 1 to 16.
Use rip metricout to add a metric to sent routes.
Use undo rip metricout to restore the default.
By default, the additional metric for sent routes is 1.
With the command configured on an interface, the metric of RIP routes sent on the interface will be increased.
Related commands: rip metricin.
# Configure VLAN-interface 10 to add a metric of 6 for the outgoing route 1.0.0.0/8 and to add a metric of 2 for other outgoing routes.
[Sysname-Vlan-interface10] rip metricout route-policy abc 2
rip mib-binding
rip mib-binding process-id
undo rip mib-binding
View
Default level
2: System level
Use rip mib-binding to bind MIB operations with a specified RIP process, so that the RIP process can receive SNMP requests.
Use undo rip mib-binding to restore the default.
By default, MIB operations are bound to the RIP process 1, that is, RIP process 1 is enabled to receive SNMP requests.
# Configure RIP 100 to accept SNMP requests.
[Sysname] rip mib-binding 100
# Restore the default.
[Sysname] undo rip mib-binding
rip output
rip output
undo rip output
View
Interface view
Default level
2: System level
None
Use rip output to enable the interface to send RIP messages.
Use undo rip output to disable the interface from sending RIP messages.
By default, Sending RIP messages is enabled on an interface.
Related commands: rip input.
[Sysname-Vlan-interface10] undo rip output
rip poison-reverse
rip poison-reverse
undo rip poison-reverse
View
Interface view
Default level
2: System level
None
Use rip poison-reverse to enable the poison reverse function.
Use undo rip poison-reverse to disable the poison reverse function.
By default, the poison reverse function is disabled.
# Enable the poison reverse function for RIP routing updates on VLAN-interface 10.
[Sysname-Vlan-interface10] rip poison-reverse
rip split-horizon
rip split-horizon
undo rip split-horizon
View
Interface view
Default level
2: System level
None
Use rip split-horizon to enable the split horizon function.
Use undo rip split-horizon to disable the split horizon function.
By default, the split horizon function is enabled.
The split horizon function is necessary for preventing routing loops. To disable it in special cases, make sure it is necessary.
Only the poison reverse function takes effect if both the split horizon and poison reverse functions are enabled.
# Enable the split horizon function on VLAN-interface 10.
[Sysname-Vlan-interface10] rip split-horizon
rip summary-address
rip summary-address ip-address { mask | mask-length }
undo rip summary-address ip-address { mask | mask-length }
View
Interface view
Default level
2: System level
ip-address: Specifies the destination IP address of summary route.
mask: Specifies the subnet mask of summary route, in dotted decimal notation.
mask-length: Specifies the subnet mask length of summary route, in the range of 0 to 32.
Use rip summary-address to configure RIPv2 to advertise a summary route through the interface.
Use undo rip summary-address to remove the configuration.
The summary address is valid only when the automatic summarization is disabled.
Related commands: summary.
# Advertise a local summary address on VLAN-interface 10.
[Sysname-Vlan-interface10] rip summary-address 10.0.0.0 255.255.255.0
rip version
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
View
Interface view
Default level
2: System level
1: Specifies the RIP version as RIPv1.
2: Specifies the RIP version as RIPv2.
broadcast: Sends RIPv2 messages in broadcast mode.
multicast: Sends RIPv2 messages in multicast mode.
Use rip version to specify a RIP version for the interface.
Use undo rip version to remove the specified RIP version.
By default, no RIP version is configured for an interface, which uses the global RIP version. If the global RIP version is not configured, the interface can only send RIPv1 broadcasts and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
If RIPv2 is specified with no sending mode configured, RIPv2 messages will be sent in multicast mode.
When RIPv1 runs on an interface, the interface can perform the following operations:
·     Sends RIPv1 broadcast messages
·     Receives RIPv1 broadcast and unicast messages
When RIPv2 runs on the interface in broadcast mode, the interface can perform the following operations:
·     Sends RIPv2 broadcast messages.
·     Receives RIPv1 broadcast and unicast messages, and RIPv2 broadcast, multicast, and unicast messages.
When RIPv2 runs on the interface in multicast mode, the interface can perform the following operations:
·     Sends RIPv2 multicast messages.
·     Receives RIPv2 broadcast, multicast, and unicast messages.
# Configure VLAN-interface 10 to broadcast RIPv2 messages.
[Sysname-Vlan-interface10] rip version 2 broadcast
silent-interface (RIP view)
View
RIP view
Default level
2: System level
all: Silents all interfaces.
Use silent-interface to disable an interface or all interfaces from sending routing updates. That is, the interface only receives but does not send RIP messages.
Use undo silent-interface to restore the default.
By default, all interfaces are allowed to send routing updates.
# Configure all VLAN interfaces to operate in silent mode, and activate VLAN-interface 10.
[Sysname] rip 100
[Sysname-rip-100] silent-interface all
[Sysname-rip-100] undo silent-interface vlan-interface 10
[Sysname-rip-100] network 131.108.0.0
summary
summary
undo summary
View
RIP view
Default level
2: System level
None
Use summary to enable automatic RIPv2 summarization. Natural masks are used to advertise summary routes so as to reduce the size of routing tables.
Use undo summary to disable automatic RIPv2 summarization so that all subnet routes can be broadcast.
By default, automatic RIPv2 summarization is enabled.
Enabling automatic RIPv2 summarization can reduce the size of the routing table to enhance the scalability and efficiency of large networks.
# Disable RIPv2 automatic summarization.
[Sysname] rip
[Sysname-rip-1] undo summary
timers
timers { garbage-collect garbage-collect-value | suppress suppress-value | timeout timeout-value | update update-value }*
undo timers { garbage-collect | suppress | timeout | update } *
View
RIP view
Default level
2: System level
garbage-collect-value: Specifies the garbage-collect timer time in seconds, in the range of 1 to 3600.
suppress-value: Specifies the suppress timer time in seconds, in the range of 0 to 3600.
timeout-value: Specifies the timeout timer time in seconds, in the range of 1 to 3600.
update-value: Specifies the update timer time in seconds, in the range of 1 to 3600.
Use timers to configure RIP timers. By adjusting RIP timers, you can improve network performance.
Use undo timers to restore the default.
By default, the garbage-collect timer is 120 seconds, the suppress timer 120 seconds, the timeout timer 180 seconds, and the update timer 30 seconds.
RIP is controlled by the above four timers.
·     Update timer—Defines the interval between routing updates.
·     Timeout timer—defines the route aging time. If no routing update related to a route is received after the aging time, the metric of the route is set to 16 in the routing table.
·     Suppress timer—Defines how long a RIP route stays in suppressed state. When the metric of a route is 16, the route enters the suppressed state. In suppressed state, only routes that come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
·     Garbage-collect timer—Defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the Garbage-Collect timer length, RIP advertises the route with the routing metric set to 16. If no routing update is announced for that route after the Garbage-Collect timer expires, the route will be deleted from the routing table.
IMPORTANT:
·     H3C recommends not changing the default values of these timers.
·     The time lengths of these timers must be kept consistent on all routers in the network.
# Specifies the update, timeout, suppress, and garbage-collect timers as 5, 15, 15 and 30.
[Sysname] rip 100
[Sysname-rip-100] timers update 5 timeout 15 suppress 15 garbage-collect 30
trip retransmit count
trip retransmit count retransmit-count-value
undo trip retransmit count
View
RIP view
Default level
2: System level
retransmit-count-value: Specifies the upper limit for retransmitting an Update Request or Update Response, in the range of 1 to 3600.
Use trip retransmit count to configure the upper limit for retransmitting an Update Request or Update Response.
Use undo validate-source-address to restore the default.
The default upper limit is 36.
# Configure an upper limit of 20 for retransmitting an Update Request or Update Response.
[Sysname] rip 100
[Sysname-rip-100] trip retransmit count 20
trip retransmit timer
trip retransmit timer retransmit-time-value
undo trip retransmit timer
View
RIP view
Default level
2: System level
retransmit-time-value: Specifies the interval in seconds for retransmitting an Update Request or Update Response, in the range of 1 to 3600.
Use trip retransmit timer to configure the interval for retransmitting an Update Request or Update Response.
The default interval is 5 seconds.
For two routers on an analog dial-up link, the difference between retransmission intervals on the two ends must be greater than 50 seconds; otherwise, they cannot become TRIP neighbors.
# Configure an interval of 80 seconds for retransmitting an Update Request or Update Response.
[Sysname] rip 100
[Sysname-rip-100] trip retransmit timer 80
View
RIP view
Default level
2: System level
None
Use validate-source-address to enable the source IP address validation on incoming RIP routing updates.
Use undo validate-source-address to disable the source IP address validation.
By default, the source IP address validation is enabled.
H3C recommends not disabling the validation in normal cases.
# Disable source IP address validation on incoming RIP routing updates.
[Sysname-rip] rip 100
[Sysname-rip-100] undo validate-source-address
version
version { 1 | 2 }
undo version
View
RIP view
Default level
2: System level
2: Specifies the RIP version as RIPv2. RIPv2 messages are multicast.
Use version to specify a global RIP version.
Use undo version to remove the configured global RIP version.
By default, if an interface has a RIP version specified, the RIP version takes effect; if it has no RIP version specified, it can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, RIPv2 multicasts, and RIPv2 unicasts.
If an interface has an RIP version specified, the RIP version takes precedence over the global RIP version.
If no RIP version is specified for the interface and the global version is RIPv1, the interface inherits RIPv1, and it can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts.
If no RIP version is specified for the interface and the global version is RIPv2, the interface operates in the RIPv2 multicast mode, and it can send RIPv2 multicasts, and receive RIPv2 broadcasts, multicasts, and unicasts.
# Specify RIPv2 as the global RIP version.
[Sysname] rip 100
[Sysname-rip-100] version 2
