07-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18207-Layer 3 - IP Routing Command Reference
06-BGP Commands
06-BGP Commands 395.2 KB
BGP configuration commands 1
aggregate· 1
balance (BGP/BGP-VPN instance view) 2
bestroute as-path-neglect (BGP/BGP-VPN instance view) 3
bestroute compare-med (BGP/BGP-VPN instance view) 4
bestroute med-confederation (BGP/BGP-VPN instance view) 4
bgp· 5
compare-different-as-med (BGP/BGP-VPN instance view) 6
confederation id· 6
confederation nonstandard· 7
confederation peer-as 8
dampening (BGP/BGP-VPN instance view) 9
default ipv4-unicast 10
default local-preference (BGP/BGP-VPN instance view) 10
default med (BGP/BGP-VPN instance view) 11
default-route imported (BGP/BGP-VPN instance view) 12
display bgp group· 13
display bgp network· 14
display bgp paths 15
display bgp peer 16
display bgp peer received ip-prefix· 20
display bgp routing-table· 21
display bgp routing-table as-path-acl 22
display bgp routing-table cidr 23
display bgp routing-table community· 24
display bgp routing-table community-list 25
display bgp routing-table dampened· 26
display bgp routing-table dampening parameter 27
display bgp routing-table different-origin-as 28
display bgp routing-table flap-info· 29
display bgp routing-table label 30
display bgp routing-table peer 31
display bgp routing-table regular-expression· 32
display bgp routing-table statistic· 32
display router id· 33
ebgp-interface-sensitive· 34
filter-policy export (BGP/BGP-VPN instance view) 34
filter-policy import (BGP/BGP-VPN instance view) 36
graceful-restart (BGP view) 37
graceful-restart timer restart 37
graceful-restart timer wait-for-rib· 38
group (BGP/BGP-VPN instance view) 39
ignore-first-as 40
import-route (BGP/BGP-VPN instance view) 40
import-route guard· 41
ipv4-family vpn-instance· 42
log-peer-change· 43
network (BGP/BGP-VPN instance view) 43
network short-cut (BGP/BGP-VPN instance view) 44
peer advertise-community (BGP/BGP-VPN instance view) 45
peer advertise-ext-community (BGP/BGP-VPN instance view) 46
peer allow-as-loop (BGP/BGP-VPN instance view) 46
peer as-number (BGP/BGP-VPN instance view) 47
peer as-path-acl (BGP/BGP-VPN instance view) 48
peer bfd· 49
peer capability-advertise conventional 50
peer capability-advertise orf 50
peer capability-advertise orf non-standard· 52
peer capability-advertise route-refresh· 53
peer capability-advertise suppress-4-byte-as 53
peer connect-interface (BGP/BGP-VPN instance view) 54
peer default-route-advertise (BGP/BGP-VPN instance view) 55
peer description (BGP/BGP-VPN instance view) 56
peer ebgp-max-hop (BGP/BGP-VPN instance view) 57
peer enable (BGP/BGP-VPN instance view) 57
peer fake-as (BGP/BGP-VPN instance view) 58
peer filter-policy (BGP/BGP-VPN instance view) 59
peer group (BGP/BGP-VPN instance view) 60
peer ignore (BGP/BGP-VPN instance view) 60
peer ignore-originatorid (BGP/BGP-VPN instance view) 61
peer ip-prefix· 62
peer keep-all-routes (BGP/BGP-VPN instance view) 63
peer log-change (BGP/BGP-VPN instance view) 63
peer next-hop-local (BGP/BGP-VPN instance view) 64
peer password· 65
peer preferred-value (BGP/BGP-VPN instance view) 66
peer public-as-only (BGP/BGP-VPN instance view) 67
peer reflect-client (BGP/BGP-VPN instance view) 68
peer route-limit (BGP/BGP-VPN instance view) 69
peer route-policy (BGP/BGP-VPN instance view) 70
peer route-update-interval (BGP/BGP-VPN instance view) 71
peer substitute-as (BGP/BGP-VPN instance view) 71
peer timer (BGP/BGP-VPN instance view) 72
preference (BGP/BGP-VPN instance view) 73
reflect between-clients (BGP view/BGP-VPN instance view) 74
reflector cluster-id (BGP view/BGP-VPN instance view) 75
refresh bgp· 76
reset bgp· 76
reset bgp dampening· 77
reset bgp flap-info· 77
reset bgp ipv4 all 78
router id· 78
router-id· 79
summary automatic· 80
synchronization (BGP view) 81
timer (BGP/BGP-VPN instance view) 81
For more information about routing policy configuration commands in this document, see "Routing policy configuration commands."
aggregate
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
undo aggregate ip-address { mask | mask-length }
View
BGP view, BGP-VPN instance view
Default level
2: System level
ip-address: Summary address.
mask: Summary route mask, in dotted decimal notation.
mask-length: Length of summary route mask, in the range of 0 to 32.
as-set: Creates a summary with AS set.
attribute-policy route-policy-name: Sets the attributes of the summary route according to the routing policy The routing policy name is a case-sensitive string of 1 to 63 characters.
detail-suppressed: Only advertises the summary route.
suppress-policy route-policy-name: Suppresses specific routes defined in the routing policy. The routing policy name is a case-sensitive string of 1 to 63 characters.
origin-policy route-policy-name: References the routing policy to specify routes for summarization. The routing policy name is a case-sensitive string of 1 to 63 characters.
Table 1 Functions of the keywords
Keywords
Function
as-set
Used to create a summary route, whose AS path contains the AS path information for summarized routes. Use this keyword carefully when many AS paths need to be summarized, because the frequent changes of these specific routes might lead to route oscillation.
detail-suppressed
This keyword does not suppress the summary route, but it suppresses the advertisement of all the more specific routes. To summarize only some specific routes, use the peer filter-policy command.
suppress-policy
Used to create a summary route and suppress the advertisement of some summarized routes. If you want to suppress some routes selectively and leave other routes still advertised, use the if-match clause of the route-policy command.
origin-policy
Selects only routes meeting the routing policy for route summarization.
attribute-policy
Sets attributes except the AS_PATH attribute for the summary route. The same work can be done by using the peer route-policy command.
Use aggregate to create a summary route in the BGP routing table.
Use undo aggregate to remove a summary route.
By default, no summary route is configured.
# In BGP view, create a summary of 192.213.0.0/16 in the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp] aggregate 192.213.0.0 255.255.0.0
# In BGP-VPN instance view, create a summary of 192.213.0.0/16 in BGP routing table. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpn-instance vpn1
[Sysname-bgp-ipv4-vpn1] aggregate 192.213.0.0 255.255.0.0
balance number
undo balance
View
BGP view, VPN instance view
Default level
2: System level
number: Specifies the maximum number of BGP ECMP routes, in the range of 1 to 32. When it is set to 1, load balancing is disabled.
For more information about the system operating modes, see Fundamentals Configuration Guide.
Use balance to configure the number of BGP ECMP routes.
Use undo balance to disable load balancing.
By default, no load balancing is configured.
Unlike IGP, BGP has no explicit metric for making load balancing decision. Instead, it implements load balancing using route selection rules.
Related commands: display bgp routing-table.
# In BGP view, set the number of BGP ECMP routes to 2.
[Sysname] bgp 100
[Sysname-bgp] balance 2
# In BGP-VPN instance view, set the number of BGP ECMP routes to 2. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] balance 2
undo bestroute as-path-neglect
View
Default level
2: System level
None
Use bestroute as-path-neglect to configure BGP not to consider the AS_PATH during best route selection.
Use undo bestroute as-path-neglect to configure BGP to consider the AS_PATH during best route selection.
By default, BGP considers the AS_PATH during best route selection.
# In BGP view, ignore AS_PATH in route selection.
[Sysname] bgp 100
[Sysname-bgp] bestroute as-path-neglect
# In BGP-VPN instance view, ignore AS_PATH in route selection. (The VPN has been created).
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] bestroute as-path-neglect
undo bestroute compare-med
View
Default level
2: System level
None
Use bestroute compare-med to enable the comparison of the MED for routes on a per-AS basis.
Use undo bestroute compare-med to disable this comparison.
This comparison is not enabled by default.
# In BGP view, enable the comparison of MEDs for routes on a per-AS basis when selecting the best route.
[Sysname] bgp 100
[Sysname-bgp] bestroute compare-med
# In BGP-VPN instance view, enable the comparison of MEDs for routes on a per-AS basis when selecting the best route. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] bestroute compare-med
undo bestroute med-confederation
View
Default level
2: System level
None
Use bestroute med-confederation to enable the comparison of the MED for paths from confederation peers during best route selection.
Use undo bestroute med-confederation to disable the comparison.
By default, the comparison is not enabled.
The system only compares MED values for paths from peers within the confederation. Paths from external ASs are advertised throughout the confederation without MED comparison.
# In BGP view, enable the comparison of the MED for paths from peers within the confederation.
[Sysname] bgp 100
[Sysname-bgp] bestroute med-confederation
# In BGP-VPN instance view, enable the comparison of the MED for paths from peers within the confederation. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] bestroute med-confederation
bgp
bgp as-number
undo bgp [ as-number ]
View
Default level
2: System level
as-number: Specifies the local AS number in the range of 1 to 4294967295.
Use bgp to enable BGP and enter the BGP view.
Use undo bgp to disable BGP.
By default, BGP is not enabled.
# Enable BGP and set local AS number to 100.
[Sysname] bgp 100
[Sysname-bgp]
undo compare-different-as-med
View
Default level
2: System level
None
Use compare-different-as-med to enable the comparison of the MED for paths from peers in different ASs.
Use undo compare-different-as-med to disable the comparison.
The comparison is disabled by default.
If several paths to one destination are available, the path with the smallest MED is selected.
Do not use this command unless associated ASs adopt the same IGP protocol and routing selection method.
# In BGP view, enable the comparison of the MED for paths from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp] compare-different-as-med
# In BGP-VPN instance view, enable the comparison of the MED for paths from peers in different Ass. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] compare-different-as-med
confederation id
confederation id as-number
undo confederation id
View
BGP view
Default level
2: System level
as-number: Number of the AS that contains multiple sub-ASs, in the range of 1 to 4294967295.
Use confederation id to configure a confederation ID.
Use undo confederation id to remove a specified confederation.
By default, no confederation ID is configured.
Configuring a confederation can reduce IBGP connections in a large AS. You can split the AS into several sub-ASs, and each sub-AS remains fully meshed. These sub-ASs form a confederation. Key IGP attributes of a route, such as the next hop, MED, local preference, are not discarded when crossing each sub-AS. The sub-ASs still look like a whole from the perspective of other ASs. This can ensure the integrity of the former AS, and solve the problem of too many IBGP connections in the AS.
Related commands: confederation nonstandard and confederation peer-as.
# Confederation 9 consists of four sub-ASs numbered 38, 39, 40 and 41. The peer 10.1.1.1 is a member of the confederation and the peer 200.1.1.1 is outside of the confederation. Take sub-AS 41 as an example.
[Sysname] bgp 41
[Sysname-bgp] confederation id 9
[Sysname-bgp] confederation peer-as 38 39 40
[Sysname-bgp] group Confed38 external
[Sysname-bgp] peer Confed38 as-number 38
[Sysname-bgp] peer 10.1.1.1 group Confed38
[Sysname-bgp] group Remote98 external
[Sysname-bgp] peer Remote98 as-number 98
[Sysname-bgp] peer 200.1.1.1 group Remote98
undo confederation nonstandard
View
BGP view
Default level
2: System level
None
Use confederation nonstandard to make the router compatible with routers not compliant with RFC 3065 in the confederation.
Use undo confederation nonstandard to restore the default.
By default, all routers in the confederation comply with RFC 3065.
All devices should be configured with this command to interact with those nonstandard devices in the confederation.
Related commands: confederation id and confederation peer-as.
# AS 100 contains routers not compliant with RFC 3065 and comprises two sub-ASs, 64000 and 65000.
[Sysname] bgp 64000
[Sysname-bgp] confederation id 100
[Sysname-bgp] confederation peer-as 65000
[Sysname-bgp] confederation nonstandard
undo confederation peer-as [ as-number-list ]
View
BGP view
Default level
2: System level
as-number-list: Sub-AS number list. Up to 32 sub-ASs can be configured in one command line. The expression is as-number-list = as-number &<1-32>, in which as-number specifies a sub-AS number, and &<1-32> indicates up to 32 numbers can be specified.
Use confederation peer-as to specify confederation peer sub-ASs.
Use undo confederation peer-as to remove specified confederation peer sub-ASs.
By default, no confederation peer sub-ASs are configured.
Before this configuration, you must use the confederation id command to specify the confederation for the sub-ASs.
If the undo confederation peer-as command without the as-number-list argument is used, all confederation peer sub-ASs are removed.
Related commands: confederation nonstandard and confederation id.
# Specify confederation peer sub-ASs 2000 and 2001.
[Sysname] bgp 100
[Sysname-bgp] confederation peer-as 2000 2001
undo dampening
View
Default level
2: System level
half-life-reachable: Specifies a half-life for active routes from 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed routes from 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes from 1 to 20000. A suppressed route whose penalty value decreases under the value is reused. By default, the reuse value is 750.
suppress: Specifies a suppression threshold in the range of 1 to 20000. The route with a penalty value higher than the threshold is suppressed. The default value is 2000.
ceiling: Specifies a ceiling penalty value in the range of 1001 to 20000. The value must be bigger than the suppress value. By default, the value is 16000.
route-policy-name: Routing policy name, a case-sensitive string of 1 to 63 characters.
half-life-reachable, half-life-unreachable, reuse, suppress and ceiling are mutually dependent. Once any one is configured, all the others should also be specified.
Use dampening to enable BGP route dampening, configure dampening parameters, or both.
Use undo dampening to disable route dampening.
By default, no route dampening is configured.
The command dampens only EBGP routes rather than IBGP routes.
Related commands: reset bgp dampening, reset bgp flap-info, display bgp routing-table dampened, display bgp routing-table dampening parameter, and display bgp routing-table flap-info.
# In BGP view, configure BGP route dampening.
[Sysname] bgp 100
[Sysname-bgp] dampening 15 15 1000 2000 10000
# In BGP-VPN instance view, configure BGP route dampening. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] dampening 15 15 1000 2000 10000
undo default ipv4-unicast
View
BGP view
Default level
2: System level
None
Use default ipv4-unicast to enable the default use of IPv4 unicast address family for the peers that are established using the peer as-number command.
Use undo default ipv4-unicast to disable the default use of IPv4 unicast address family for the peers that are established using the peer as-number command.
By default, the use of IPv4 unicast address family is enabled.
The default ipv4-unicast or undo default ipv4-unicast command applies to only BGP peers that are established after it is executed.
The default ipv4-unicast or undo default ipv4-unicast command applies to only BGP peers that are established using the peer as-number command.
After executing the undo default ipv4-unicast command, you can use the peer enable command to enable the use of IPv4 address family for a peer.
# Enable the default use of IPv4 unicast address family for the peers that are established using the peer as-number command.
[Sysname] bgp 100
[Sysname-bgp] default ipv4-unicast
undo default local-preference
View
Default level
2: System level
value: Default local preference in the range of 0 to 4294967295. The larger the value is, the higher the preference is.
Use default local-preference to configure the default local preference.
Use undo default local-preference to restore the default value.
By default, the default local preference is 100.
Using this command can affect BGP route selection.
# In BGP view, set the default local preference to 180.
[Sysname] bgp 100
[Sysname-bgp] default local-preference 180
# In BGP-VPN instance view, set the default local preference to 180. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] default local-preference 180
default med med-value
undo default med
View
Default level
2: System level
med-value: Default MED value in the range of 0 to 4294967295.
Use default med to specify a default MED value.
Use undo default med to restore the default.
By default, the default med-value is 0.
Multi-exit discriminator (MED) is an external metric for routes. Different from local preference, MED is exchanged between ASs and will stay in the AS once it enters the AS. The route with a lower MED is preferred. When a router running BGP obtains several routes with an identical destination but different next-hops from various external peers, it will select the best route depending on the MED value. In the case that all other conditions are the same, the system first selects the route with the smallest MED as the best external route.
BGP selects a MED value in the following order:
1.     MED set by the apply cost command.
2.     MED set by the med keyword in the import-route command.
3.     MED set by the default med command.
4.     Original MED of a BGP route, or MED changed from the metric of a redistributed IGP route.
# In BGP view, configure the default MED as 25.
[Sysname] bgp 100
[Sysname-bgp] default med 25
# In BGP-VPN instance view, configure the default MED as 25. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] default med 25
undo default-route imported
View
Default level
2: System level
None
Use default-route imported to allow default route redistribution into the BGP routing table.
Use undo default-route imported to disallow the redistribution.
By default, default route redistribution is not allowed.
You must use the default-route imported command together with the import-route command to redistribute default routes from other protocols.
Related commands: import-route.
# In BGP view, allow default route redistribution from OSPF into BGP.
[Sysname] bgp 100
[Sysname-bgp] default-route imported
[Sysname-bgp] import-route ospf 1
# In BGP-VPN instance view, enable redistributing default route from OSPF into BGP. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] default-route imported
[Sysname-bgp-ipv4-vpn1] import-route ospf 1
display bgp group
display bgp group [ group-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-name: Peer group name, a string of 1 to 47 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display bgp group to display peer group information.
# Display information about the peer group aaa.
<Sysname> display bgp group aaa
 BGP peer-group is aaa
 Remote AS 200
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Peer Preferred Value: 0
  Members:
  Peer            AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  2.2.2.1         200        0        0     0       0 00:00:35 Active
BGP peer-group
Name of the BGP peer group.
Remote AS
AS number of peer group.
Type of the BGP peer group: IBGP or EBGP.
Maximum prefixes allowed to receive from the peer group.
Threshold
Percentage of received prefixes from the peer group to maximum prefixes allowed to receive from the peer group.
If the percentage is reached, the system generates alarm messages.
Holdtime interval.
Keepalive interval.
Minimum interval for route advertisements.
Preferred value specified for the routes from the peer.
No routing policy is configured.
Members
Detailed information about the members in the peer group.
Peer
IPv4 address of the peer.
V
BGP version running on the peer.
AS
AS number of the peer.
MsgRcvd
Number of messages received.
MsgSent
Number of messages sent.
OutQ
Number of messages to be sent.
PrefRcv
Number of prefixes received.
Up/Down
Lasting time of the session/lasting time of the current state (when no session is established)
State machine state of the peer.
display bgp network
display bgp network [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp network to display routing information advertised with the network command.
# Display routing information advertised with the network command.
<Sysname> display bgp network
  BGP Local Router ID is 10.1.4.2.
  Local AS Number is 400.
  Network          Mask            Route-policy        Short-cut
  100.1.2.0        255.255.255.0
  100.1.1.0        255.255.255.0                       Short-cut
BGP Local Router ID
BGP local router ID.
Local AS Number
Local AS Number.
Network
Network address.
Mask
Mask.
Route-policy
Routing policy.
Short-cut
Short-cut route.
display bgp paths
display bgp paths [ as-regular-expression | | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
as-regular-expression: AS path regular expression, a string of 1 to 80 characters.
Use display bgp paths to display information about BGP AS paths.
# Display information about BGP AS paths with AS number starting from 200.
<Sysname> display bgp paths ^200
    Address       Hash    Refcount  MED         Path/Origin
    0x5917100     11      1         0           200 300i
Address
Route address in the local database, in dotted hexadecimal notation.
Hash
Hash index.
Refcount
Count of routes that reference the path.
MED
MED of the path.
Path
AS_PATH attribute of the path, recording the ASs it has passed to avoid routing loops.
Origin
Origin attribute of the path:
·     iThe route is interior to the AS.
·     Summary routes and routes defined using the network command are considered IGP routes.
·     eA route is learned from the exterior gateway protocol (EGP).
·     ?—Short for INCOMPLETE. It indicates that the origin of a route is unknown and the route is learned by other means.
display bgp peer
display bgp peer [ ip-address { log-info | verbose } | group-name log-info | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: IP address of an peer to be displayed, in dotted decimal notation.
group-name: Name of a peer group to be displayed, a string of 1 to 47 characters.
log-info: Displays log information for the specified peer.
verbose: Displays detailed information about the peer/peer group.
Use display bgp peer to display peer/peer group information.
# Display detailed information about the peer 10.110.25.20.
<Sysname> display bgp peer 10.110.25.20 verbose
         Peer: 10.110.25.20 Local: 2.2.2.2
         Type: EBGP link
         BGP version 4, remote router ID 1.1.1.1
         BGP current state: Established, Up for 00h01m51s
         BGP current event: RecvKeepalive
         BGP last state: OpenConfirm
         Port:  Local - 1029     Remote - 179
         Configured: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keepalive Time: 60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Address family IPv4 Unicast: advertised and received
 Received: Total 5 messages, Update messages 1
 Sent: Total 4 messages, Update messages 0
 Threshold: 75%
 Optional capabilities:
  ORF advertise capability based on prefix (type 64):
    Local: both
    Negotiated: send
 BFD: Enabled
 Routing policy configured:
Table 5 Command output
Peer
IP address of the peer.
Local
Local router ID.
Peer type.
BGP version
BGP version.
remote router ID
Router ID of the peer.
BGP current state
Current state of the peer.
BGP current event
Current event of the peer.
BGP last state
Previous state of the peer.
Port
TCP port numbers of the local router and its peer.
Local holdtime interval.
Keepalive Time
Local keepalive interval.
Received: Active Hold Time
Remote holdtime interval.
Negotiated holdtime interval.
Optional capabilities supported by the peer, including BGP multiprotocol extensions and route refresh.
Routes are advertised and received in IPv4 unicasts.
Received
Total numbers of received messages and updates.
Sent
Total numbers of sent messages and updates.
Maximum allowed prefix number.
Threshold
Percentage of received prefixes from the peer group to maximum prefixes allowed to receive from the peer group; If the percentage is reached, the system generates alarm messages.
Minimum route advertisement interval.
Optional capabilities enabled by the peer.
The route-refresh capability has been enabled.
The BGP peer supports the ORF capability based on IP prefix. The capability value is 64.
Local: both
The local BGP router supports both the ORF sending and receiving capabilities.
Negotiated: send
Negotiation result: The local BGP router can send Router-refresh messages carrying the ORF information, and the peer can receive Router-refresh messages carrying the ORF information. (This field is not displayed if neither the send nor the receive capability is supported.)
BFD
BFD state: enabled or disabled.
Local routing policy.
# Display log information for the peer 10.110.25.20.
<sysname> display bgp peer 10.110.25.20 log-info
 Peer : 10.110.25.20
     Date      Time    State Notification
                             Error/SubError
  10-Jul-2008 15:46:17 Down  Send Notification with Error 1/1
                             Message Header Error/Connection Not Synchronized
  10-Jul-2008 09:23:00 Up
  10-Jul-2008 07:46:17 Down  Receive Notification with Error 3/2
                             UPDATE Message Error/Unsupported optional Parameter
  10-Jul-2008 06:23:00 Up
  10-Jul-2008 05:46:17 Down  Send Notification with Error 6/4
                             Cease/Administrative Reset
Table 6 Command output
Peer
Date
Date on which the Notification was sent or received.
Time
Time at which the Notification was sent or received.
BGP session state:
·     UpThe BGP session is up.
·     DownThe BGP session is down.
Notification
Error code and subcode of the Notification message.
Error/SubError
Error refers to the error code, which identifies the type of the Notification.
SubError refers to the error subcode of the Notification, which identifies the specific information about the reported error.
display bgp peer ip-address received ip-prefix [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: IP address of a BGP peer.
regular-expression: Specifies a regular expression, a case sensitive string of 1 to 256 characters.
Use display bgp peer received ip-prefix to display the prefix information in the ORF message from the specified BGP peer.
# Display the prefix information in the ORF message from the BGP peer 10.110.25.20.
<Sysname> display bgp peer 10.110.25.20 received ip-prefix
ORF ip-prefix entries: 2
ge: greater-equal   le: less-equal
  index  rule   prefix                 ge    le
  10     permit 111.111.111.0/24       26    32
  20     deny   2.1.1.0/24             26    32
Table 7 Command output
Number of ORF prefix entries.
Index
Index of a prefix entry.
Rule
Matching rule of the prefix.
Prefix
Prefix information.
Ge
greater-equal, indicating the mask length must be greater than or equal to the specific value.
Le
less-equal, indicating the mask length must be less than or equal to the specific value.
display bgp routing-table [ ip-address [ { mask | mask-length } [ longer-prefixes ] ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Destination IP address.
mask: Network mask, in dotted decimal notation.
mask-length: Mask length in the range of 0 to 32.
longer-prefixes: Displays the routing entries selected through the following steps:
1.     AND the specified destination IP address with the specified mask.
2.     AND the destination IP address of each route with the specified mask.
3.     Find the calculation results of 2 that match the result of 1 and display the route with the longest mask among the matching routes that have a mask shorter than or equal to the specified mask.
Use display bgp routing-table to display specified BGP routing information in the BGP routing table.
# Display BGP routing table information.
<Sysname> display bgp routing-table
 Total Number of Routes: 1
 BGP Local router ID is 10.10.10.1
 Status codes: * - valid, ^ - VPNv4 best, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? – incomplete
 *>  40.40.40.0/24     20.20.20.1       0                     0       200 300i
Table 8 Command output
Total number of routes.
BGP Local router ID
Status codes
Status codes:
·     * – valid—Valid route.
·     ^ - VPNv4 best—Best VPNv4 route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     i – internal—Internal route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
Origin
·     Origin attributes:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Learned by some other means.
Network
Destination network address.
Next Hop
Next hop IP address.
MED
MULTI_EXIT_DISC attribute.
LocPrf
Local preference value.
PrefVal
Preferred value of the route.
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops.
PrefVal
Preferred value.
Ogn
Origin attribute of the route, which can be one of the following values:
·     iThe route is interior to the AS. Summary routes and the routes injected with the network command are considered IGP routes.
·     eThe route is learned from the Exterior Gateway Protocol (EGP).
·     ?—Short for INCOMPLETE. It indicates that the origin of the route is unknown and the route is learned by other means.
display bgp routing-table as-path-acl as-path-acl-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
as-path-acl-number: Displays routing information permitted by the AS path list, which is specifies with a number from 1 to 256.
Use display bgp routing-table as-path-acl to display BGP routes permitted by an AS path list.
# Display BGP routes permitted by AS path list 1.
<Sysname> display bgp routing-table as-path-acl 1
 BGP Local router ID is 20.20.20.1
 *>  40.40.40.0/24      30.30.30.1     0                      0       300i
For description of the fields, see Table 8.
display bgp routing-table cidr [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp routing-table cidr to display BGP CIDR (Classless Inter-Domain Routing) routing information.
# Display BGP CIDR routing information.
<Sysname> display bgp routing-table cidr
display bgp routing-table community [ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
aa:nn: Community number. Both aa and nn are in the range of 0 to 65535.
&<1-13>: Argument before it can be entered up to 13 times.
no-advertise: Displays BGP routes that cannot be advertised to any peer.
no-export: Displays BGP routes that cannot be advertised out of the AS. If a confederation is configured, it displays routes that cannot be advertised out of the confederation, but can be advertised to other sub-ASs in the confederation.
no-export-subconfed: Displays BGP routes that cannot be advertised out of the AS or to other sub-ASs in the configured confederation.
whole-match: Displays the BGP routes exactly matching the specified COMMUNITY attribute.
Use display bgp routing-table community to display BGP routing information with the specified BGP COMMUNITY attribute.
# Display BGP routing information with the specified BGP community.
<Sysname> display bgp routing-table community 11:22
 *>  10.10.10.0/24      0.0.0.0         0                      0       i
display bgp routing-table community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
basic-community-list-number: Specifies a basic community-list number from 1 to 99.
adv-community-list-number: Specifies an advanced community-list number from 100 to 199.
comm-list-name: Community list name, a string of 1 to 31 characters (not all are numbers).
whole-match: Displays routes exactly matching the specified basic-community-list.
Use display bgp routing-table community-list to display BGP routing information matching the specified BGP community list.
# Display BGP routing information matching BGP community list 100.
<Sysname> display bgp routing-table community-list 100
 BGP Local router ID is 1.2.3.4
 Origin codes: i - IGP, e - EGP, ? – incomplete
      Network            NextHop        Metric     LocPrf    PrefVal Path
 *>   3.3.3.0/30         1.2.3.4                             0       ?
 *>   4.4.0.0/20         1.2.3.4                             0       ?
 *>   4.5.6.0/26         1.2.3.4                             0       ?
display bgp routing-table dampened [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp routing-table dampened to display dampened BGP routes.
# Display dampened BGP routes.
<Sysname> display bgp routing-table dampened
 BGP Local router ID is 2.2.2.2
     Network            From              Reuse     Path/Origin
 *d  77.0.0.0           12.1.1.1          00:29:20  100?
Table 9 Command output
From
IP address from which the route was received.
Reuse
Reuse time of the route.
For description of the other fields, see Table 8.
display bgp routing-table dampening parameter [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp routing-table dampening parameter to display BGP route dampening parameters.
Related commands: dampening.
# Display BGP route dampening parameters.
<Sysname> display bgp routing-table dampening parameter
 Maximum Suppress Time(in second) : 3069
 Ceiling Value                    : 16000
 Reuse Value                      : 750
 Reach HalfLife Time(in  second)  : 900
 Unreach HalfLife Time(in  second): 900
 Suppress-Limit                   : 2000
Table 10 Command output
Maximum Suppress Time.
Ceiling Value
Ceiling penalty value.
Reuse Value
Reuse value.
Half-life time of active routes.
Half-life time of inactive routes.
Suppress-Limit
Limit for a route to be suppressed.
display bgp routing-table different-origin-as [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp routing-table different-origin-as to display BGP routes originating from different autonomous systems.
# Display BGP routes originating from different ASs.
<Sysname> display bgp routing-table different-origin-as
 *>  55.0.0.0         12.1.1.1         0                     0       100?
 *                    14.1.1.2         0                     0       300?
display bgp routing-table flap-info [ regular-expression as-regular-expression | [ as-path-acl as-path-acl-number | ip-address [ { mask | mask-length } [ longer-match ] ] ] [ | { begin | exclude | include } regular-expression ] ]
View
Default level
1: Monitor level
as-regular-expression: Displays route flap information that matches the AS path regular expression, which is a string of 1 to 80 characters.
as-path-acl-number: Displays route flap information matching the AS path list. The number is in the range of 1 to 256.
mask: Mask, in dotted decimal notation.
longer-match: Matches the longest prefix.
Use display bgp routing-table flap-info to display BGP route flap statistics.
# Display BGP route flap statistics.
<Sysname> display bgp routing-table flap-info
     Network        From        Flaps  Duration      Reuse  Path/Origin
 *>  55.0.0.0       12.1.1.1    2      00:00:16             100?
 *d  77.0.0.0       12.1.1.1    5      00:34:02   00:27:08  100?
Table 11 Command output
From
Source IP address of the route.
Flaps
Number of routing flaps.
Duration
Duration time of the flap route.
Reuse
display bgp routing-table label [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp routing-table label to display labeled BGP routing information.
# Display labeled BGP routing information.
<Sysname> display bgp routing-table label
 BGP Local router ID is 6.6.6.7
               Origin : i - IGP, e - EGP, ? - incomplete
 Total Number of Routes: 2
        Network              NextHop           In/Out Label
 *>     4.4.4.4/32           127.0.0.1         3/NULL
 *>     5.5.5.5/32           1.1.1.1           NULL/1024
The In/Out Label field refers to the inbound/outbound label. For the description of other fields, see Table 8.
display bgp routing-table peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: IP address of a peer.
advertised-routes: Displays routing information advertised to the specified peer.
received-routes: Displays routing information received from the specified peer.
network-address: IP address of the destination network.
mask: Mask of the destination network, in dotted decimal notation.
statistic: Displays route statistics.
Use display bgp routing-table peer to display BGP routing information advertised to or received from the specified BGP peer.
Related commands: display bgp peer.
# Display BGP routing information advertised to BGP peer 20.20.20.1.
<Sysname> display bgp routing-table peer 20.20.20.1 advertised-routes
 BGP Local router ID is 30.30.30.1
 *>  30.30.30.0/24     0.0.0.0         0                     0       i
 *>  40.40.40.0/24     0.0.0.0         0                     0       i
display bgp routing-table regular-expression as-regular-expression
View
Default level
1: Monitor level
Use display bgp routing-table regular-expression to display BGP routing information matching the specified AS path regular expression.
# Display BGP routing information with AS number ended with 300.
<Sysname> display bgp routing-table regular-expression 300$
display bgp routing-table statistic [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display bgp routing-table statistic to display BGP routing statistics.
# Display BGP routing statistics.
<Sysname> display bgp routing-table statistic
 Total Number of Routes: 4
display router id
display router id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display router id to display the global router ID.
# Display the global router ID.
<Sysname> display router id
         Configured router ID is 1.1.1.1
undo ebgp-interface-sensitive
View
Default level
2: System level
None
Use ebgp-interface-sensitive to enable quick reestablishment of direct EBGP session.
Use undo ebgp-interface-sensitive to restore the default.
By default, this function is enabled.
When the link to a directly connected EBGP peer is down, the router, with quick EBGP session reestablishment enabled, will tear down the session to the peer, and then reestablish a session immediately. If the function is not enabled, the router does not tear down the session until the holdtime times out. A route flap will not affect the EBGP session state when the quick EBGP session reestablishment is disabled.
# In BGP view, enable quick reestablishment of direct EBGP session.
[Sysname] bgp 100
[Sysname-bgp] ebgp-interface-sensitive
# In BGP-VPN instance view, enable quick reestablishment of direct EBGP session. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] ebgp-interface-sensitive
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
undo filter-policy export [ direct | isis process-id | ospf process-id | rip process-id | static ]
View
Default level
2: System level
acl-number: Number of an ACL used to filter outgoing routing information, in the range of 2000 to 3999.
ip-prefix-name: Name of an IP prefix list used to filter outgoing routing information, a string of 1 to 19 characters.
direct: Filters direct routes.
isis process-id: Filters outgoing routes redistributed from an ISIS process. The ID is in the range of 1 to 65535.
ospf process-id: Filters outgoing routes redistributed from the OSPF process with an ID from 1 to 65535.
rip process-id: Filters outgoing routes redistributed from a RIP process. The ID is in the range of 1 to 65535.
static: Filters static routes.
Use filter-policy export to configure the filtering of outgoing routes.
Use undo filter-policy export to remove the filtering.
By default, no route filtering is configured.
If no routing protocol is specified, all outgoing routes are filtered.
If you want to reference an advanced ACL (with a number from 3000 to 3999) in the command, the ACL should be configured with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command to deny/permit a route with the specified destination, or with the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command to deny/permit a route with the specified destination and mask. The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route (the subnet mask must be valid; otherwise, the configuration is ineffective).
# In BGP view, reference ACL 2000 to filter all outgoing routes.
[Sysname] bgp 100
[Sysname-bgp] filter-policy 2000 export
# In BGP-VPN instance view, reference ACL 2000 to filter all outgoing routes. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] filter-policy 2000 export
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter outgoing routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] bgp 100
[Sysname-bgp] filter-policy 3000 export
filter-policy { acl-number | ip-prefix ip-prefix-name } import
undo filter-policy import
View
Default level
2: System level
acl-number: Number of an ACL used to filter incoming routing information, in the range of 2000 to 3999.
ip-prefix-name: Name of an IP prefix list used to filter incoming routing information, a string of 1 to 19 characters.
Use filter-policy import to configure the filtering of incoming routing information.
Use undo filter-policy import to disable the filtering.
By default, incoming routing information is not filtered.
# In BGP view, reference ACL 2000 to filter incoming routing information.
[Sysname] bgp 100
[Sysname-bgp] filter-policy 2000 import
# In BGP-VPN instance view, reference ACL 2000 to filter incoming routing information. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] filter-policy 2000 import
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass, and reference ACL 3000 to filter incoming route information.
[Sysname] bgp 100
[Sysname-bgp] filter-policy 3000 import
graceful-restart
undo graceful-restart
View
BGP view
Default level
2: System level
None
Use graceful-restart to enable BGP Graceful Restart capability.
Use undo graceful-restart to disable BGP Graceful Restart capability.
By default, BGP Graceful Restart capability is disabled.
During main and backup boards switchover, a GR-capable BGP speaker can maintain the packet forwarding table. During restart, it might not maintain the forwarding table.
# Enable the Graceful Restart capability for BGP process 100.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart
undo graceful-restart timer restart
View
BGP view
Default level
2: System level
timer: Maximum time for a peer to reestablish a BGP session, in the range of 3 to 600 seconds.
Use graceful-restart timer restart to configure the maximum time for a peer to reestablish a BGP session.
Use undo graceful-restart timer restart to restore the default.
By default, the maximum time for a peer to reestablish a BGP session is 150 seconds.
Related commands: graceful-restart.
IMPORTANT:
Before configuring this command, you must enable the BGP Graceful Restart capability.
# Configure the maximum time for a peer to reestablish a BGP session as 300 seconds.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart timer restart 300
undo graceful-restart timer wait-for-rib
View
BGP view
Default level
2: System level
timer: Time to wait for the End-of-RIB marker, in the range of 3 to 300 seconds.
Use graceful-restart timer wait-for-rib to configure the time to wait for the End-of-RIB marker on the local end.
Use undo graceful-restart timer wait-for-rib to restore the default.
By default, the time to wait for the End-of-RIB marker is 180 seconds.
After a BGP session has been successfully (re)established, the End-of-RIB marker must be received within the time specified with this command.
Using this command can speed up route convergence.
IMPORTANT:
# Set the time to wait for the End-of-RIB marker on the local end to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp] graceful-restart timer wait-for-rib 100
group group-name [ external | internal ]
undo group group-name
View
Default level
2: System level
group-name: Name of a peer group, a string of 1 to 47 characters.
external: Creates an EBGP peer group, which can be the group of another sub-AS in a confederation.
internal: Creates an IBGP peer group.
Use group to create a peer group.
Use undo group to delete a peer group.
An IBGP peer group is created if neither internal nor external is specified.
# In BGP view, create an EBGP peer group test with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group.
[Sysname] bgp 100
[Sysname-bgp] group test external
[Sysname-bgp] peer test as-number 200
[Sysname-bgp] peer 10.1.1.1 group test
[Sysname-bgp] peer 10.1.2.1 group test
# In BGP-VPN instance view, create an EBGP peer group test with AS number 200, and add EBGP peers 10.1.1.1 and 10.1.2.1 into the group. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] group test external
[Sysname-bgp-ipv4-vpn1] peer test as-number 200
[Sysname-bgp-ipv4-vpn1] peer 10.1.1.1 group test
[Sysname-bgp-ipv4-vpn1] peer 10.1.2.1 group test
ignore-first-as
ignore-first-as
undo ignore-first-as
View
BGP view
None
Use ignore-first-as to configure BGP to ignore the first AS number of EBGP route updates.
Use undo ignore-first-as to configure BGP to check the first AS number of EBGP route updates.
By default, BGP checks the first AS number of a received EBGP route update. If the first AS number is not that of the BGP peer, the BGP router discards the route update.
# Configure BGP to ignore the first AS number of EBGP route updates.
[Sysname] bgp 100
[Sysname-bgp] ignore-first-as
View
Default level
2: System level
protocol: Redistributes routes from the specified routing protocol, which can be direct, isis, ospf, rip or static.
process-id: Process ID in the range of 1 to 65535. The default is 1. It is available only when the protocol is isis, ospf, or rip.
all-processes: Redistributes routes from all the processes of the specified protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-direct: Redistributes direct routes from the specified protocol. This keyword is available only when the specified protocol is OSPF. Without this keyword, BGP does not redistribute direct routes from OSPF. If you specify the route-policy route-policy-name keyword together with the allow-direct keyword, make sure that no rule in the routing policy conflicts with any direct route. For example, do not configure the if-match route-type command for the routing policy to filter OSPF routes. Otherwise, the allow-direct keyword does not take effect.
med-value: Specifies a MED value for redistributed routes, in the range of 0 to 4294967295. If the argument is not specified, the cost of the redistributed route is used as its MED in the BGP routing domain.
route-policy-name: Name of a routing policy used to filter redistributed routes, a case-sensitive string of 1 to 63 characters.
Use import-route to configure BGP to redistribute routes from the specified IGP protocol.
Use undo import-route to disable route redistribution from a routing protocol.
By default, BGP does not redistribute routes from other protocols.
Only active routes can be redistributed. You can use the display ip routing-table protocol command to display route state information.
The ORIGIN attribute of routes redistributed with the import-route command is INCOMPLETE.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# In BGP view, redistribute routes from RIP process 1.
[Sysname] bgp 100
[Sysname-bgp] import-route rip
# In BGP-VPN instance view, redistribute routes from RIP process 1 (the VPN has been created).
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] import-route rip
import-route guard
import-route guard [ med med-value | route-policy route-policy-name ] *
undo import-route guard
View
BGP view
Default level
2: System level
med med-value: Specifies a MED value for redistributed Guard routes. It is in the range of 0 to 4294967295 and defaults to the cost of a Guard route. You can use a routing policy to specify a cost for Guard routes. If no routing policy is used, the cost of Guard routes is 0.
route-policy route-policy-name: Specifies a routing policy name, a case-sensitive string of 1 to 63 characters. Only the Guard routes permitted by the routing policy are redistributed.
Use import-route guard to enable Guard route redistribution into BGP.
Use undo import-route guard to disable Guard route redistribution into BGP.
By default, Guard route redistribution into BGP is disabled.
Guard routes redistributed into the BGP route table with the import-route guard command has an ORIGIN attribute of INCOMPLETE.
# In BGP view, enable Guard route redistribution.
[Sysname] bgp 100
[Sysname-bgp] import-route guard
ipv4-family vpn-instance vpn-instance-name
undo ipv4-family vpn-instance vpn-instance-name
View
BGP view
Default level
2: System level
vpn-instance-name: VPN instance name, a case-sensitive string of 1 to 31 characters.
Use ipv4-family vpn-instance to associate the specified VPN instance with the IPv4 address family, and enter BGP-VPN instance view.
Use undo ipv4-family vpn-instance to remove all configurations in BGP-VPN instance view.
Before you enter BGP-VPN instance view, the VPN instance must have been created.
# Associate the specified VPN instance with the IPv4 address family, and enter BGP-VPN instance view.
[Sysname] bgp 100
[Sysname-bgp-vpn1]
log-peer-change
log-peer-change
undo log-peer-change
View
BGP view
Default level
2: System level
None
Use log-peer-change to enable the global BGP logging on peers going up and down.
Use undo log-peer-change to disable the function.
By default, the function is enabled.
# Enable BGP logging on peers going up and down.
[Sysname] bgp 100
[Sysname-bgp] log-peer-change
network ip-address [ mask | mask-length ] [ route-policy route-policy-name ]
undo network ip-address [ mask | mask-length ]
View
Default level
2: System level
mask: Mask of the network address, in dotted decimal notation.
route-policy-name: Routing policy applied to the route. The name is a case-sensitive string of 1 to 63 characters.
Use network to inject a network to the local BGP routing table.
Use undo network to remove the configuration.
By default, no network route is injected.
The network route to be injected must exist in the local IP routing table, and using a routing policy makes route management more flexible.
The ORIGIN attribute of the network route injected with the network command is IGP.
# In BGP view, inject the network segment 10.0.0.0/16 to the BGP routing table.
[Sysname] bgp 100
[Sysname-bgp] network 10.0.0.0 255.255.0.0
# In BGP-VPN instance view, advertise the network segment 10.0.0.0/16 to the BGP routing table. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] network 10.0.0.0 255.255.0.0
network ip-address [ mask | mask-length ] short-cut
undo network ip-address [ mask | mask-length ] short-cut
View
Default level
2: System level
Use network short-cut to increase the preference of a received EBGP route.
Use undo network short-cut to cancel the configuration.
By default, a received EBGP route has a preference of 255.
The preference of an EBGP route is lower than a local route. The network short-cut command allows you to configure an EBGP route as a shortcut route that has the same preference as a local route and is more likely to become the optimal route.
# In BGP view, increase the preference of EBGP route 10.0.0.0/16.
[Sysname] bgp 100
[Sysname-bgp] network 10.0.0.0 255.255.0.0 short-cut
# In BGP-VPN instance view, increase the preference of EBGP route 10.0.0.0/16. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] network 10.0.0.0 255.255.0.0 short-cut
peer { group-name | ip-address } advertise-community
undo peer { group-name | ip-address } advertise-community
View
Default level
2: System level
Use peer advertise-community to advertise the COMMUNITY attribute to a peer/peer group.
Use undo peer advertise-community to disable the COMMUNITY attribute advertisement to a peer/peer group.
By default, no COMMUNITY attribute is advertised to any peer group/peer.
Related commands: ip community-list, if-match community, and apply community.
# In BGP view, advertise the COMMUNITY attribute to peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test advertise-community
# In BGP-VPN instance view, advertise the COMMUNITY attribute to peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test advertise-community
peer { group-name | ip-address } advertise-ext-community
undo peer { group-name | ip-address } advertise-ext-community
View
Default level
2: System level
Use peer advertise-ext-community to advertise the extended community attribute to a peer/peer group.
Use undo peer advertise-ext-community to disable the extended community attribute advertisement to a peer/peer group.
By default, no extended community attribute is advertised to a peer/peer group.
Related commands: ip extcommunity-list, if-match extcommunity, and apply extcommunity.
# In BGP view, advertise the extended community attribute to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test advertise-ext-community
# In BGP-VPN view, advertise the extended community attribute to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test advertise-ext-community
peer { group-name | ip-address } allow-as-loop [ number ]
undo peer { group-name | ip-address } allow-as-loop
View
Default level
2: System level
number: Specifies the number of times for which the local AS number can appear in routes from the peer/peer group, in the range of 1 to 10. The default number is 1.
Use peer allow-as-loop to allow the local AS number to exist in the AS_PATH attribute of routes from a peer/peer group, and to configure the number of times the local AS number can appear.
Use undo peer allow-as-loop to restore the default.
By default, the local AS number is not allowed in routes from a peer or peer group.
Related commands: display bgp routing-table peer.
# In BGP view, configure the number of times the local AS number can appear in AS_PATH attribute of routes from peer 1.1.1.1 as 2.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 allow-as-loop 2
# In BGP-VPN instance view, configure the number of times for which the local AS number can appear in AS_PATH attribute of routes from peer 1.1.1.1 as 2. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 1.1.1.1 allow-as-loop 2
peer { group-name | ip-address } as-number as-number
undo peer group-name as-number
undo peer ip-address
View
Default level
2: System level
as-number: AS number of the peer or peer group, in the range of 1 to 4294967295.
Use peer { group-name | ip-address } as-number as-number to specify a peer/peer group with an AS number.
Use undo peer group-name as-number to delete a peer group.
Use undo peer ip-address to delete a peer.
By default, no peer or peer group is specified.
You can specify the AS number of a peer in either of the following ways:
·     Use the peer ip-address as-number as-number command. After that, the system creates the specified peer by default.
·     Specify the AS number of the peer when adding it to the specified peer group by using the peer ip-address group group-name as-number as-number command; or use the peer as-number command to specify the AS number of a peer group, and then a newly added peer will belong to the AS.
The AS number of a peer/peer group cannot be modified directly. To do so, you have to delete the peer/peer group and configure it again.
# In BGP view, specify peer group test in AS 100.
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 100
# In BGP-VPN instance view, specify peer group test2 in AS 200. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test2 as-number 200
peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
undo peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
View
Default level
2: System level
as-path-acl-number: AS path list number in the range of 1 to 256.
export: Filters outgoing routes.
import: Filters incoming routes.
Use peer as-path-acl to configure the filtering of routes incoming from or outgoing to a peer/peer group based on a specified AS path list.
Use undo peer as-path-acl to remove the configuration.
By default, no AS path list filtering is configured.
Related commands: ip as-path, if-match as-path, and apply as-path.
# In BGP view, reference the AS path list 1 to filter routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test as-path-acl 1 export
# In BGP-VPN instance view, reference the AS path list  1 to filter routes outgoing to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test as-path-acl 1 export
peer bfd
peer ip-address bfd
undo peer ip-address bfd
View
Default level
2: System level
Use peer bfd to enable BFD for a BGP peer.
Use undo peer bfd to disable BFD for a BGP peer.
By default, BFD is disabled.
After the link to the BGP peer fails, BFD might detect the failure before the system performs GR. As a result, GR will fail. If GR capability is enabled for BGP, use BFD with caution. If GR and BFD are both enabled, do not disable BFD during a GR process; otherwise, GR might fail.
# Enable BFD for BGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 bfd
peer capability-advertise conventional
peer { group-name | ip-address } capability-advertise conventional
undo peer { group-name | ip-address } capability-advertise conventional
View
BGP view
Default level
2: System level
Use peer capability-advertise conventional to disable BGP multi-protocol extension and route refresh for a peer/peer group.
Use undo peer capability-advertise conventional to enable BGP multi-protocol extension and route refresh for a peer/peer group.
By default, BGP multi-protocol extension and route refresh are enabled.
# In BGP view, disable multi-protocol extension and route refresh for peer 160.89.2.33.
[Sysname] bgp 100
[Sysname-bgp] peer 160.89.2.33 as-number 100
[Sysname-bgp] peer 160.89.2.33 capability-advertise conventional
peer capability-advertise orf
peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send }
undo peer { group-name | ip-address } capability-advertise orf ip-prefix { both | receive | send }
View
Default level
2: System level
both: Supports sending and receiving route-refresh messages carrying the ORF information.
receive: Supports receiving route-refresh messages carrying the ORF information.
send: Supports sending route-refresh messages carrying the ORF information.
Use peer capability-advertise orf to enable the ORF capability for a BGP peer or peer group.
Use undo peer capability-advertise orf to disable the ORF capability for the BGP peer or peer group.
By default, the ORF capability is not enabled for a BGP peer or peer group.
·     After you enable the ORF capability, the local BGP router negotiates the ORF capability with the BGP peer through Open messages. After that, the BGP router can exchange ORF information in route-refresh messages with the peer. For non-standard ORF capability negotiation, you need also to configure the peer capability-advertise orf non-standard command.
·     After you disable the ORF capability, the local BGP router does not negotiate the ORF capability with the specified peer or peer group.
Table 12 Description of the both, send, and receive parameters and the negotiation result
Local parameter
Peer parameter
Negotiation result
send
·     receive
·     both
The ORF sending capability is enabled locally and the ORF receiving capability is enabled on the peer.
receive
·     send
·     both
The ORF receiving capability is enabled locally and the ORF sending capability is enabled on the peer.
both
both
Both the ORF sending and receiving capabilities are enabled locally and on the peer.
# Enable the ORF capability for the BGP peer 18.10.0.9. Then, after negotiation, the local router can exchange ORF information with the peer 18.10.0.9.
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 as-number 100
[Sysname-bgp] peer 18.10.0.9 capability-advertise orf ip-prefix both
The related configuration must be made on the peer.
# In BGP-VPN instance view, enable the ORF capability for the BGP peer 18.10.0.9. Then, after negotiation, the local router can exchange ORF information with the peer 18.10.0.9. (vpn1 must have been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 18.10.0.9 as-number 200
[Sysname-bgp-ipv4-vpn1] peer 18.10.0.9 capability-advertise orf ip-prefix both
The related configuration needs to be made on the peer.
peer { group-name | ip-address } capability-advertise orf non-standard
undo peer { group-name | ip-address } capability-advertise orf non-standard
View
BGP view, BGP-VPN instance view
Default level
2: System level
Use peer capability-advertise orf non-standard to enable the non-standard ORF capability (the early implementation of ORF is different from that defined in RFC) for a BGP peer or peer group.
Use undo peer capability-advertise orf non-standard to disable the non-standard ORF capability for the BGP peer or peer group.
By default, the non-standard ORF capability is not enabled for a BGP peer or peer group.
This command needs to be configured when the peer supports only non-standard ORF.
Related commands: peer capability-advertise orf.
# Enable the non-standard ORF capability for the BGP peer 18.10.0.9. (Suppose the BGP peer 18.10.0.9 can only send non-standard ORF messages.)
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 capability-advertise orf non-standard
# In BGP-VPN instance view, enable the non-standard ORF capability for the BGP peer 18.10.0.9 (suppose the BGP peer 18.10.0.9 can only send non-standard ORF messages). (vpn1 must have been created.)
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpn-instance vpn1
[Sysname-bgp-ipv4-vpn1] peer 18.10.0.9 capability-advertise orf non-standard
peer capability-advertise route-refresh
peer { group-name | ip-address } capability-advertise route-refresh
undo peer { group-name | ip-address } capability-advertise route-refresh
View
Default level
2: System level
Use peer capability-advertise route-refresh to enable the BGP route refresh capability.
Use undo peer capability-advertise route-refresh to disable the capability.
By default, the capability is enabled.
# In BGP view, enable BGP route refresh for peer 160.89.2.33.
[Sysname] bgp 100
[Sysname-bgp] peer 160.89.2.33 capability-advertise route-refresh
# In BGP-VPN instance view, enable BGP route refresh for peer 160.89.2.33. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 160.89.2.33 as-number 200
[Sysname-bgp-ipv4-vpn1] peer 160.89.2.33 capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer { group-name | ip-address } capability-advertise suppress-4-byte-as
undo peer { group-name | ip-address } capability-advertise suppress-4-byte-as
View
Default level
2: System level
Use peer capability-advertise suppress-4-byte-as to enable 4-byte AS number suppression.
Use undo peer capability-advertise suppress-4-byte-as to disable the function.
By default, the 4-byte AS number suppression function is disabled.
If the peer device supports 4-byte AS numbers, do not enable the suppression function; otherwise, the BGP peer relationship cannot be established.
# In BGP view, enable 4-byte AS number suppression for peer 160.89.2.33.
[Sysname] bgp 100
[Sysname-bgp] peer 160.89.2.33 capability-advertise suppress-4-byte-as
# In BGP-VPN instance view, enable 4-byte AS number suppression for peer 160.89.2.33. (The VPN must have been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 160.89.2.33 capability-advertise suppress-4-byte-as
peer connect-interface (BGP/BGP-VPN instance view)
peer { group-name | ip-address } connect-interface interface-type interface-number
undo peer { group-name | ip-address } connect-interface
View
Default level
2: System level
group-name: Name of a peer group, a string 1 to 47 characters.
interface-type interface-number: Specifies the type and number of the interface.
Use peer connect-interface to specify the source interface for establishing TCP connections to a peer/peer group.
Use undo peer connect-interface to restore the default.
By default, BGP uses the output interface of the best route to the BGP peer/peer group as the source interface for establishing a TCP connection to the peer/peer group.
Suppose interface A on the local device is connected to interface B on the peer device. When using the peer x.x.x.x as-number as-number command on the local device but x.x.x.x is not the IP address of interface B, you need to execute the peer connect-interface command on the peer to specify the source interface (the owner of IP address x.x.x.x) for establishing TCP connections.
To establish multiple BGP connections to another BGP router, you need to specify on the local router the respective source interfaces for establishing TCP connections to the peers on the peering BGP router; otherwise, the local BGP router might fail to establish TCP connections to the peers when using the output interfaces of the best routes as the source interfaces.
# In BGP view, specify loopback 0 as the source interface for routing updates to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test connect-interface loopback 0
# In BGP-VPN instance view, specify loopback 0 as the source interface for routing updates to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test connect-interface loopback 0
peer default-route-advertise (BGP/BGP-VPN instance view)
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { group-name | ip-address } default-route-advertise
View
Default level
2: System level
Use peer default-route-advertise to advertise a default route to a peer/peer group.
Use undo peer default-route-advertise to disable default route advertisement to a peer/peer group.
By default, no default route is advertised to a peer/peer group.
With this command used, the router unconditionally sends a default route with the next hop being itself to the peer/peer group regardless of whether the default route is available in the routing table.
# In BGP view, advertise a default route to peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test default-route-advertise
# In BGP-VPN instance view, advertise a default route to peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test default-route-advertise
peer description (BGP/BGP-VPN instance view)
peer { group-name | ip-address } description description-text
undo peer { group-name | ip-address } description
View
Default level
2: System level
description-text: Description information for the peer/peer group, a string of 1 to 79 characters.
Use peer description to configure the description information for a peer/peer group.
Use undo peer description to remove the description information for a peer/peer group.
By default, no description information is configured for a peer/peer group.
Create a peer/peer group before configuring a description for it.
# In BGP view, configure the description information for the peer group test as ISP1.
[Sysname] bgp 100
[Sysname-bgp] peer test description ISP1
# In BGP-VPN instance view, configure the description information for the peer group test as ISP1. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test description ISP1
peer ebgp-max-hop (BGP/BGP-VPN instance view)
peer { group-name | ip-address } ebgp-max-hop [ hop-count ]
undo peer { group-name | ip-address } ebgp-max-hop
View
Default level
2: System level
hop-count: Maximum hop count in the range of 1 to 255. The default is 64.
Use peer ebgp-max-hop to allow establishing an EBGP session with a peer or peer group that is on an indirectly connected network.
Use undo peer ebgp-max-hop to restore the default.
You can use the argument hop-count to specify the maximum route hop count of the EBGP session.
# In BGP view, allow establishing the EBGP session with the peer group test that is on an indirectly connected network.
[Sysname] bgp 100
[Sysname-bgp] peer test ebgp-max-hop
# In BGP-VPN instance view, allow establishing the EBGP session with the peer group test that is on an indirectly connected network. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test ebgp-max-hop
peer enable (BGP/BGP-VPN instance view)
peer ip-address enable
undo peer ip-address enable
View
BGP view, BGP VPN instance view
Default level
2: System level
Use peer enable to enable the specified peer.
Use undo peer enable to disable the specified peer.
By default, the BGP peer is enabled.
If a peer is disabled, the router will not exchange routing information with the peer.
# Disable peer 18.10.0.9.
[Sysname] bgp 100
[Sysname-bgp] peer 18.10.0.9 group group1
[Sysname-bgp] undo peer 18.10.0.9 enable
peer fake-as (BGP/BGP-VPN instance view)
peer { group-name | ip-address } fake-as as-number
undo peer { group-name | ip-address } fake-as
View
Default level
2: System level
as-number: Local autonomous system number in the range of 1 to 4294967295.
Use peer fake-as to configure a fake local AS number for a peer or peer group.
Use undo peer fake-as to restore the default.
By default, no fake local AS number is configured for a peer or peer group.
The peer fake-as command is only applicable to an EBGP peer or peer group.
# In BGP view, configure a fake AS number of 200 for the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test fake-as 200
# In BGP-VPN instance view, configure a fake AS number of 200 for the peer group test. (The VPN has been created).
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test fake-as 200
peer filter-policy (BGP/BGP-VPN instance view)
peer { group-name | ip-address } filter-policy acl-number { export | import }
undo peer { group-name | ip-address } filter-policy [ acl-number ] { export | import }
View
Default level
2: System level
acl-number: ACL number in the range of 2000 to 3999.
export: Applies the filter-policy to routes advertised to the peer/peer group.
import: Applies the filter-policy to routes received from the peer/peer group.
Use peer filter-policy to configure an ACL-based filter policy for a peer or peer group.
Use undo peer filter-policy to remove the configuration.
By default, no ACL-based filter policy is configured for a peer or peer group.
Related commands: peer as-path-acl.
# In BGP view, apply the ACL 2000 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test filter-policy 2000 export
# In BGP-VPN instance view, apply the ACL 2000 to filter routes advertised to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test filter-policy 2000 export
peer group (BGP/BGP-VPN instance view)
peer ip-address group group-name [ as-number as-number ]
undo peer ip-address group group-name
View
Default level
2: System level
as-number: AS number of the peer, in the range of 1 to 4294967295.
Use peer group to add a peer to a peer group.
Use undo peer group to delete a specified peer from a peer group.
By default, no peer exists in a peer group.
If you have specified an AS number for the peer to be added, make sure that the as-number argument is consistent with the specified peer AS number.
If you have not created the peer to be added, the system automatically creates the peer when you execute the command.
# In BGP view, add the peer 10.1.1.1 to the EBGP peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test as-number 2004
# In BGP-VPN view, add the peer 10.1.1.1 to the EBGP peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test as-number 2004
peer ignore (BGP/BGP-VPN instance view)
peer { group-name | ip-address } ignore
undo peer { group-name | ip-address } ignore
View
Default level
2: System level
Use peer ignore to disable session establishment with a peer or peer group.
Use undo peer ignore to remove the configuration.
By default, session establishment with a peer or peer group is allowed.
After the peer ignore command is executed, the system disables the session with the specified peer or peer group and clears all the related routing information. For a peer group, all sessions with the peer group will be torn down.
# In BGP view, disable session establishment with peer 10.10.10.10.
[Sysname] bgp 100
[Sysname-bgp] peer 10.10.10.10 ignore
# In BGP-VPN instance view, disable session establishment with peer 10.10.10.10. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 10.10.10.10 ignore
peer ignore-originatorid (BGP/BGP-VPN instance view)
peer { group-name | ip-address } ignore-originatorid
undo peer { group-name | ip-address } ignore-originatorid
View
Default level
2: System level
Use peer ignore-originatorid to ignore the ORIGINATOR_ID attribute of BGP routes received from the specified peer or peer group.
Use undo peer ignore-originatorid to restore the default.
By default, BGP saves the ORIGINATOR ID attribute of received BGP routes.
Before you execute the peer ignore-originatorid command, make sure that no routing loop exists among route reflectors in the network.
The peer ignore-originatorid also enables BGP to ignore the CLUSTER_LIST attribute of BGP routes.
# In BGP view, ignore the ORIGINATOR attribute of routes received from the route reflector 10.10.10.10.
[Sysname] bgp 100
[Sysname-bgp] peer 10.10.10.10 ignore-originatorid
peer ip-prefix
peer { group-name | ip-address } ip-prefix ip-prefix-name { export | import }
undo peer { group-name | ip-address } ip-prefix { export | import }
View
Default level
2: System level
ip-prefix-name: IP prefix list name, a string of 1 to 19 characters.
export: Applies the filter to routes advertised to the specified peer/peer group.
import: Applies the filter to routes received from the specified peer/peer group.
Use peer ip-prefix to reference an IP prefix list to filter routes received from or advertised to a peer or peer group.
Use undo peer ip-prefix to remove the configuration.
By default, no IP prefix list based filtering is configured.
# In BGP view, use the IP prefix list list1 to filter routes advertised to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test ip-prefix list1 export
# In BGP-VPN view, use the IP prefix list list1 to filter routes advertised to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test ip-prefix list1 export
peer keep-all-routes (BGP/BGP-VPN instance view)
peer { group-name | ip-address } keep-all-routes
undo peer { group-name | ip-address } keep-all-routes
View
Default level
2: System level
Use peer keep-all-routes to save all route updates from a peer or peer group, regardless of whether the routes have passed the configured routing policy.
Use undo peer keep-all-routes to disable this function.
By default, the function is not enabled.
# In BGP view, save all route updates from peer 131.100.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 131.100.1.1 as-number 200
[Sysname-bgp] peer 131.100.1.1 keep-all-routes
# In BGP-VPN instance view, save all route updates from peer 131.100.1.1. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 131.100.1.1 as-number 200
[Sysname-bgp-ipv4-vpn1] peer 131.100.1.1 keep-all-routes
peer log-change (BGP/BGP-VPN instance view)
peer { group-name | ip-address } log-change
undo peer { group-name | ip-address } log-change
View
Default level
2: System level
Use peer log-change to enable the logging of session state and event information for a specified peer or peer group.
Use undo peer log-change to remove the configuration.
The logging is enabled by default.
# In BGP view, enable the logging of session state and event information for peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test log-change
# In BGP-VPN instance view, enable the logging of session state and event information for peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test log-change
peer next-hop-local (BGP/BGP-VPN instance view)
peer { group-name | ip-address } next-hop-local
undo peer { group-name | ip-address } next-hop-local
View
BGP view /BGP-VPN instance view
Default level
2: System level
Use peer next-hop-local to specify the router as the next hop for routes sent to a peer/peer group.
Use undo peer next-hop-local to remove the configuration.
By default, routes advertised to an EBGP peer/peer group take the local router as the next hop, and routes sent to an IBGP peer/peer group do not take the local router as the next hop.
# In BGP view, set the next hop of routes advertised to peer group test to the router itself.
[Sysname] bgp 100
[Sysname-bgp] peer test next-hop-local
# In BGP-VPN instance view, set the next hop of routes advertised to peer group test to the router itself. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test next-hop-local
peer password
peer { group-name | ip-address } password { cipher | simple } password
undo peer { group-name | ip-address } password
View
Default level
2: System level
cipher: Displays the configured password in cipher text format.
simple: Displays the configured password in plain text format.
password: Sets the password. This argument is case sensitive. It must be a ciphertext string of 1 to 137 characters, or a plaintext string of 1 to 80 characters.
Use peer password to enable MD5 authentication for BGP peers.
Use undo peer password to disable the function.
By default, no MD5 authentication is performed.
You can enable MD5 authentication to enhance security in the following ways:
·     Perform MD5 authentication when establishing TCP connections. Only the two parties that have the same password configured can establish TCP connections.
·     Perform MD5 calculation on TCP packets to avoid modification to the encapsulated BGP packets.
# In BGP view, perform MD5 authentication on the TCP connection set up between the local router 10.1.100.1 and the peer router 10.1.100.2.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.100.2 password simple aabbcc
# Perform the similar configuration on the peer.
[Sysname] bgp 100
[Sysname-bgp] peer 10.1.100.1 password simple aabbcc
# In BGP-VPN instance view, perform MD5 authentication on the TCP connection set up between the local router 10.1.100.1 and the peer router 10.1.100.2. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 10.1.100.2 password simple aabbcc
[Sysname] bgp 200
[Sysname-bgp-ipv4-vpn1] peer 10.1.100.1 password simple aabbcc
peer preferred-value (BGP/BGP-VPN instance view)
peer { group-name | ip-address } preferred-value value
undo peer { group-name | ip-address } preferred-value
View
Default level
2: System level
value: Preferred value in the range of 0 to 65535.
Use peer preferred-value to assign a preferred value to routes received from a peer or peer group.
Use undo peer preferred-value to restore the default value.
The default preferred value is 0.
Routes learned from a peer have an initial preferred value. Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the route to the destination.
If you both reference a routing policy and use the peer { group-name | ip-address } preferred-value value command to set a preferred value for routes from a peer, the routing policy sets the specified preferred value for routes matching it. Other routes not matching the routing policy uses the value set with the command. If the preferred value specified in the routing policy is zero, the routes matching it will also use the value set with the peer { group-name | ip-address } preferred-value value command. For information about using a routing policy to set a preferred value, see the command peer { group-name | ip-address } route-policy route-policy-name { export | import } in this document, and the command apply preferred-value preferred-value in "Routing policy configuration commands."
# In BGP view, configure the preferred value as 50 for routes from peer 131.108.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 131.108.1.1 preferred-value 50
# In BGP-VPN instance view, configure the preferred value as 50 for routes from peer 131.108.1.1. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 131.108.1.1 preferred-value 50
peer public-as-only (BGP/BGP-VPN instance view)
peer { group-name | ip-address } public-as-only
undo peer { group-name | ip-address } public-as-only
View
Default level
2: System level
Use peer public-as-only to not keep private AS numbers in BGP updates sent to a peer/peer group.
Use undo peer public-as-only to keep private AS numbers in BGP updates sent to a peer/peer group.
By default, BGP updates carry private AS numbers.
The command does not take effect if the BGP update has both public and private AS numbers. The range of private AS number is from 64512 to 65535.
# In BGP view, carry no private AS number in BGP updates sent to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test public-as-only
# In BGP-VPN instance view, carry no private AS number in BGP updates sent to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test public-as-only
peer reflect-client (BGP/BGP-VPN instance view)
peer { group-name | ip-address } reflect-client
undo peer { group-name | ip-address } reflect-client
View
Default level
2: System level
Use peer reflect-client to configure the router as a route reflector and specify a peer/peer group as a client.
Use undo peer reflect-client to remove the configuration.
By default, neither the route reflector nor the client is configured.
The peer reflect-client command can be configured in both BGP view and BGP-VPNv4 subaddress family view. In BGP view, the command enables the router to reflect routes of the public network; in BGP-VPNv4 subaddress family view, the command enables the router to reflect routes of the private network. (You can enter BGP-VPNv4 subaddress family view by executing the ipv4-family vpnv4 command in BGP view. For more information about the ipv4-family vpnv4 command, see MPLS Command Reference.)
Related commands: reflect between-clients and reflect cluster-id.
# In BGP view, configure the local device as a route reflector and specify the IBGP peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp] peer test reflect-client
# In BGP-VPN instance view, configure the local device as a route reflector and specify the IBGP peer group test as a client. (vpn1 must have been created.)
[Sysname] bgp 109
[Sysname-bgp-ipv4-vpn1] peer test reflect-client
peer route-limit (BGP/BGP-VPN instance view)
peer { group-name | ip-address } route-limit prefix-number [ { alert-only | reconnect reconnect-time } | percentage-value ] *
undo peer { group-name | ip-address } route-limit
View
Default level
2: System level
prefix-number: Number of prefixes that can be received from the peer or peer group. If the number of prefixes received from the peer/peer group reaches the prefix-number, the router will tear down the connection to the peer/peer group.
alert-only: If the number of prefixes received from the peer/peer group reaches the prefix-number, the router will not tear down the connection to the peer/peer group but display an alarm message.
reconnect reconnect-time: Specifies a reconnect time, after which, the router will re-establish a connection to the peer/peer group. It has no default value and is in the range of 1 to 65535 seconds.
percentage-value: Threshold value for the router to display an alarm message (the router displays an alarm message when the ratio of the number of received prefixes to the prefix-number exceeds the percentage). It is in the range of 1 to 100 and defaults to 75.
Use peer route-limit to specify the maximum number of routes that can be received from a peer or peer group.
Use undo peer route-limit to cancel the configuration.
By default, the number of routes that can be received from a peer or peer group is not limited.
# In BGP view, specify the maximum number of routes that can be received from peer 129.140.6.6 to 10000, and configure the router to tear down the connection to the peer if the number is exceeded.
[Sysname] bgp 109
[Sysname-bgp] peer 129.140.6.6 as-number 110
[Sysname-bgp] peer 129.140.6.6 route-limit 10000
# In BGP-VPN instance view, specify the maximum number of routes that can be received from peer 129.140.6.6 to 10000, and configure the router to tear down the connection to the peer if the number is exceeded. (The VPN has been created.)
[Sysname] bgp 109
[Sysname-bgp-ipv4-vpn1] peer 129.140.6.6 as-number 110
[Sysname-bgp-ipv4-vpn1] peer 129.140.6.6 route-limit 10000
peer route-policy (BGP/BGP-VPN instance view)
undo peer { group-name | ip-address } route-policy route-policy-name { export | import }
View
Default level
2: System level
route-policy-name: Routing policy name, a case-sensitive string of 1 to 63 characters.
export: Applies the routing policy to routes outgoing to the peer (or peer group).
import: Applies the routing policy to routes incoming from the peer (or peer group).
Use peer route-policy to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use undo peer route-policy to remove the configuration.
By default, no routing policy is applied to routes from/to the peer/peer group.
The peer route-policy command does not apply the if-match interface clause in the referenced routing policy. For related commands, see "Routing policy configuration commands."
# In BGP view, apply routing policy test-policy to routes outgoing to the peer group test.
[Sysname] bgp 100
[Sysname-bgp] peer test route-policy test-policy export
# In BGP-VPN instance view, apply the routing policy test-policy to routes outgoing to the peer group test. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test route-policy test-policy export
peer route-update-interval (BGP/BGP-VPN instance view)
peer { group-name | ip-address } route-update-interval interval
undo peer { group-name | ip-address } route-update-interval
View
Default level
2: System level
group-name: Name of a peer group, a sting of 1 to 47 characters.
interval: Minimum interval for sending the same update message. The range is 0 to 600 seconds. A value of 0 means to send the update message immediately.
Use peer route-update-interval to specify the interval for sending the same update to a peer or peer group.
Use undo peer route-update-interval to restore the default.
By default, the interval is 15 seconds for IBGP peers, and 30 seconds for EBGP peers.
# In BGP view, specify the interval for sending the same update to peer group test as 10 seconds.
[Sysname] bgp 100
[Sysname-bgp] peer test route-update-interval 10
# In BGP-VPN instance view, specify the interval for sending the same update to peer group test as 10 seconds. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test as-number 100
[Sysname-bgp-ipv4-vpn1] peer test route-update-interval 10
peer substitute-as (BGP/BGP-VPN instance view)
peer { group-name | ip-address } substitute-as
undo peer { group-name | ip-address } substitute-as
View
Default level
2: System level
Use peer substitute-as to replace the AS number of a peer/peer group in the AS_PATH attribute with the local AS number.
Use undo peer substitute-as to remove the configuration.
No AS number is replaced by default.
# In BGP view, substitute local AS number for AS number of peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp] peer 1.1.1.1 substitute-as
# In BGP-VPN instance view, substitute local AS number for AS number of peer 1.1.1.1. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer 1.1.1.1 substitute-as
peer timer (BGP/BGP-VPN instance view)
peer { group-name | ip-address } timer keepalive keepalive hold holdtime
undo peer { group-name | ip-address } timer
View
Default level
2: System level
keepalive: Keepalive interval in seconds, in the range of 0 to 21845.
holdtime: Holdtime interval in seconds, whose value is 0 or in the range of 3 to 65535.
Use peer timer to configure the keepalive interval and holdtime for a peer or peer group.
Use undo peer timer to restore the default.
By default, the keepalive and holdtime are 60s and 180s.
The timers configured with this command are preferred to the timers configured with the timer command.
If the holdtime interval is configured as 0, no keepalive message will be sent to the peer, and the peer connection will never time out. If the keepalive interval is configured as 0 and the negotiated hold time is not 0, one third of the hold time is taken as the interval for sending keepalive messages.
If neither the holdtime interval nor the keepalive interval is configured as 0, the holdtime interval must be at least three times the keepalive interval.
After this command is executed, the peer connection is closed at once, and a new connection to the peer is negotiated using the configured hold time.
Related commands: timer.
# In BGP view, configure the keepalive interval and holdtime for peer group test as 60s and 180s.
[Sysname] bgp 100
[Sysname-bgp] peer test timer keepalive 60 hold 180
# In BGP-VPN instance view, configure the keepalive interval and holdtime for peer group test as 60s and 180s. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test timer keepalive 60 hold 180
# In BGP view, configure both the keepalive interval and holdtime for peer group test as 0 seconds, indicating the peer group will never time out.
[Sysname] bgp 100
[Sysname-bgp] peer test timer keepalive 0 hold 0
# In BGP-VPN instance view, configure both the keepalive interval and holdtime for peer group test as 0 seconds, indicating the peer group will never time out. (vpn1 must have been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] peer test timer keepalive 0 hold 0
preference (BGP/BGP-VPN instance view)
undo preference
View
Default level
2: System level
external-preference: Preference of EBGP routes, in the range of 1 to 255.
internal-preference: Preference of IBGP routes, in the range of 1 to 255.
local-preference: Preference of local routes, in the range of 1 to 255.
route-policy-name: Routing policy name, a case-sensitive string of 1 to 63 characters. Using the routing policy can set a preference for routes matching it. The default value applies to routes not matching the routing policy.
Use preference to configure preferences for external, internal, and local routes.
Use undo preference to restore the default.
For external-preference, internal-preference and local-preference, the greater the preference value is, the lower the preference is, and the default values are 255, 255, and 130.
# In BGP view, configure preferences for EBGP, IBGP and local routes as 20, 20 and 200.
[Sysname] bgp 100
[Sysname-bgp] preference 20 20 200
# In BGP-VPN instance view, configure preferences for EBGP, IBGP and local routes as 20, 20 and 200. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] preference 20 20 200
reflect between-clients (BGP view/BGP-VPN instance view)
undo reflect between-clients
View
Default level
2: System level
None
Use reflect between-clients to enable route reflection between clients.
Use undo reflect between-clients to disable this function.
By default, route reflection between clients is enabled.
After a route reflector is configured, it reflects the routes of a client to other clients. If the clients of a route reflector are fully meshed, you need disable route reflection between clients to reduce routing costs.
Related commands: reflector cluster-id and peer reflect-client.
# Disable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp] undo reflect between-clients
# In BGP-VPN instance view, disable route reflection between clients. (vpn1 must have been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] undo reflect between-clients
reflector cluster-id (BGP view/BGP-VPN instance view)
undo reflector cluster-id
View
Default level
2: System level
cluster-id: Cluster ID in the format of an integer from 1 to 4294967295.
ip-address: Cluster ID in the format of an IPv4 address in dotted decimal notation.
Use reflector cluster-id to configure the cluster ID of the route reflector.
Use undo reflector cluster-id to remove the configured cluster ID.
By default, each route reflector uses its router ID as the cluster ID.
Typically, a cluster has only one route reflector. The router ID of the route reflector is the ID of the cluster. You can configure multiple route reflectors to improve network stability. Using this command can configure the identical cluster ID for all the route reflectors to avoid routing loops.
Related commands: reflect between-clients and peer reflect-client.
# Set the cluster ID to 80.
[Sysname] bgp 100
[Sysname-bgp] reflector cluster-id 80
# In BGP-VPN instance view, set the cluster ID to 80. (vpn1 must have been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] reflector cluster-id 80
refresh bgp
refresh bgp { ip-address | all | group group-name | external | internal } { export | import }
View
Default level
1: Monitor level
ip-address: Soft-resets the BGP connection to a peer.
all: Soft-resets all BGP sessions.
group-name: Soft-resets connections to a peer group, name of which is a sting of 1 to 47 characters.
external: EBGP sessions.
internal: IBGP sessions.
export: Outbound soft reset.
import: Inbound soft reset.
Use refresh bgp to perform soft reset on specified BGP sessions. Using this function can refresh the BGP routing table without tearing down BGP sessions and apply a newly configured routing policy.
To perform BGP soft reset, all routers in the network must support route-refresh. If a router not supporting route-refresh exists in the network, you need to configure the peer keep-all-routes command to save all route updates before performing soft reset.
# Perform inbound BGP soft reset.
<Sysname> refresh bgp all import
reset bgp
reset bgp { as-number | ip-address  | all | external | group group-name | internal }
View
Default level
2: System level
as-number: Resets BGP sessions to peers in the AS.
ip-address: Specifies the IP address of a peer with which to reset the sessions.
all: Resets all BGP sessions.
external: Resets all the EBGP sessions.
group group-name: Resets sessions with the specified BGP peer group.
internal: Resets all the IBGP sessions.
Use reset bgp to reset specified BGP sessions.
# Reset all the BGP sessions.
<Sysname> reset bgp all
reset bgp dampening
reset bgp dampening [ ip-address [ mask | mask-length ] ]
View
Default level
1: Monitor level
ip-address: Destination IP address of a route.
mask: Mask, in dotted decimal notation.
mask-length: Mask length in the range of 0 to 32.
Use reset bgp dampening to clear route dampening information and release suppressed routes.
Related commands: dampening and display bgp routing-table dampened.
# Clear damping information for route 20.1.0.0/16 and release the suppressed route.
<Sysname> reset bgp dampening 20.1.0.0 255.255.0.0
reset bgp flap-info
reset bgp flap-info [ ip-address [ mask-length | mask ] | as-path-acl as-path-acl-number | regexp as-path-regular-expression ]
reset bgp peer-ip-address flap-info
View
Default level
1: Monitor level
ip-address: Clears the flap statistics of a route.
mask: Network mask, in dotted decimal notation.
as-path-acl-number: Clears the flap statistics of routes matching an AS path ACL, number of which is in the range of 1 to 256.
as-path-regular-expression: Clears the flap statistics of routes matching the AS path regular expression, which is a string of 1 to 80 characters.
peer-ip-address: Clears the flap statistics of routes received from the specified peer.
Use reset bgp flap-info to clear the flap statistics of routes matching the specified filter.
# Clear the flap statistics of all routes matching AS path ACL 10.
<Sysname> reset bgp flap-info as-path-acl 10
reset bgp ipv4 all
reset bgp ipv4 all
View
Default level
2: System level
None
Use reset bgp ipv4 all to reset all the BGP sessions of IPv4 unicast address family.
# Reset all the BGP sessions of IPv4 unicast address family.
<Sysname> reset bgp ipv4 all
router id
router id router-id
undo router id
View
Default level
2: System level
router-id: Router ID, in the form of a dotted decimal IPv4 address.
Use router id to configure a global router ID.
Use undo router id to remove the global router ID.
By default, no global router ID is configured.
Some routing protocols use a router ID to identify a device. You can configure a global router ID, which is used by routing protocols that have no router ID configured.
If no global router ID is configured, the highest loopback interface IP address, if any, is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status.
During an active/standby switchover, the standby main processing unit (MPU) checks whether the previous router ID that is backed up before switchover is valid. If not, it selects a new router ID.
If the interface whose IP address is the router ID is removed or modified, a new router ID is selected. Other events, (the interface goes down; after a physical interface address is selected as the router ID, an IP address is configured for a loopback interface; a higher interface IP address is configured) will not trigger a router ID re-selection.
# Configure a global router ID.
[Sysname] router id 1.1.1.1
router-id
router-id [ auto-select | router-id ]
undo router-id
View
Default level
2: System level
auto-select: Select an address from the addresses in the BGP-VPN instance as the router ID. This keyword takes effect only in BGP-VPN view.
router-id: Router ID in IP address format.
Use router-id to specify a router ID.
Use undo router-id to remove the router ID.
By default, a BGP router uses the global router ID. You can execute the router id command in system view to configure the global router ID.
To run BGP protocol, a router must have a router ID, which is an unsigned 32-bit integer, the unique ID of the router in the AS.
You can configure a router ID manually. If no router ID is configured, BGP selects an interface IP address as the router ID. If the keyword auto-select is configured, BGP selects an IP address in the BGP-VPN instance as the router ID. To enhance network reliability, you can specify the IP address of a local loopback interface as the router ID.
# Specifies the router ID as 10.18.4.221.
[Sysname] bgp 100
[Sysname-bgp] router-id 10.18.4.221
summary automatic
summary automatic
undo summary automatic
View
Default level
2: System level
None
Use summary automatic to enable automatic summarization for redistributed subnets.
Use undo summary automatic to disable automatic summarization.
By default, automatic summarization is disabled.
Neither the default route nor the routes imported using the network command can be summarized automatically.
The summary automatic command helps BGP limit the number of routes redistributed from IGP to reduce the size of the routing table.
# In BGP view, enable automatic route summarization.
[Sysname] bgp 100
[Sysname-bgp] summary automatic
# In BGP-VPN instance view, enable automatic summarization. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] summary automatic
synchronization (BGP view)
synchronization
undo synchronization
View
BGP view
Default level
2: System level
None
Use synchronization to enable the synchronization between the BGP and IGP routes.
Use undo synchronization to disable the synchronization.
The feature is disabled by default.
With this feature enabled and when a non-BGP router is responsible for forwarding packets in an AS, BGP speakers in the AS cannot advertise routing information to other ASs unless all routers in the AS know the latest routing information.
When a BGP router receives an IBGP route, it checks only whether the next hop is reachable by default. If the synchronization is enabled, the IBGP route is synchronized and advertised to EBGP peers only when the route is also advertised by IGP. Otherwise, the IBGP route cannot be advertised to EBGP peers.
# Enable the synchronization between BGP and IGP routes.
[Sysname] bgp 100
[Sysname-bgp] synchronization
undo timer
View
Default level
2: System level
Use timer to configure the global keepalive interval and holdtime.
Use undo timer to restore the default.
By default, the BGP keepalive interval and the holdtime are 60 seconds and 180 seconds.
The timers configured with the peer timer command are preferred to the timers configured with this command.
The configured timers apply to all BGP peers, but they become valid for a BGP peer only after the relevant BGP connection is reset.
After this command is executed, no peer connection is closed at once. The configured hold time is used for negotiation when a peer relationship is reestablished.
Related commands: peer timer.
# Configure the global keepalive interval and holdtime as 60s and 180s.
[Sysname] bgp 100
[Sysname-bgp] timer keepalive 60 hold 180
# In BGP-VPN instance view, configure keepalive interval and holdtime for all BGP sessions in vpn1 as 60s and 180s. (The VPN has been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] timer keepalive 60 hold 180
# In BGP view, configure both the BGP keepalive interval and holdtime as 0 seconds, indicating no peer connection will time out.
[Sysname] bgp 100
[Sysname-bgp] timer keepalive 0 hold 0
# In BGP-VPN instance view, configure both the keepalive interval and holdtime for all BGP sessions in vpn1 as 0 seconds, indicating no peer connection will time out. (vpn1 must have been created.)
[Sysname] bgp 100
[Sysname-bgp-ipv4-vpn1] timer keepalive 0 hold 0
