04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18204-Layer 2 - LAN Switching Command Reference
11-VLAN Termination Commands
11-VLAN Termination Commands 56.12 KB
The switch does not support QinQ termination when it is operating in standard mode. For more information about the commands of system operating modes, see Fundamentals Command Reference.
second-dot1q
Use second-dot1q to enable QinQ termination on an interface and specify a list of VLAN IDs that the interface can add to packets as the inner VLAN tag before sending them out.
Use undo second-dot1q to restore the default.
second-dot1q { vlan-list | any }
undo second-dot1q { vlan-list | any }
QinQ termination is disabled and VLAN interfaces process only the outermost VLAN tag of packets.
VLAN interface view
Default command level
2: System level
any: Configures the interface to add any VLAN in the range of 1 to 4094 as the inner VLAN tag to the packets before sending them out.
vlan-list: Specifies a list of inner VLAN IDs in the format of { vlan-id1 [ to vlan-id2 ] }&<1-10>, where the vlan-id argument is in the range of 1 to 4094 and &<1-10> indicates that you can specify up to 10 vlan-id1 [ to vlan-id2 ] parameters.
A VLAN interface always adds its interface number as the outer VLAN tag to the packets it sends out.
When the QinQ termination configuration on the current VLAN interface is changed, refresh the ARP entries on the Layer 2 physical interface to which the VLAN interface is bound by executing reset arp interface. For more information about this command, see Layer 3—IP Services Command Reference.
After you execute second-dot1q on an interface on which QinQ is disabled or cancel all the VLAN IDs related to QinQ termination, the interface restarts and the ARP table entry corresponding to the interface is removed.
# Enable QinQ termination on VLAN-interface 100 and specify VLANs 10 through 20 as the inner VLAN tags that the interface can add to packets before sending them out. Enable QinQ termination on VLAN-interface 12 and specify VLAN 100 as the inner VLAN tags that the interface can add to packets before sending them out.
[Sysname-Vlan-interface100] second-dot1q 10 to 20
[Sysname-Vlan-interface100] quit
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] second-dot1q 100
The following table shows the results of the previous configuration:
Outermost VLAN ID of VLAN-tagged packets that the interface can terminate
Inner VLAN IDs of VLAN-tagged packets that the interface can send
VLAN-interface 100
100
1020
VLAN-interface 12
12
100
vlan-termination broadcast enable
Use vlan-termination broadcast enable to enable the interface to transmit broadcast and multicast packets.
Use undo vlan-termination broadcast enable to restore the default.
An ambiguous QinQ termination-enabled interface drops broadcast and multicast packets.
VLAN interface view
2: System level
# Enable VLAN-interface 10 to transmit broadcast and multicast packets with VLAN IDs in the range of 10 to 20.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] second-dot1q 10 to 20
[Sysname-Vlan-interface10] vlan-termination broadcast enable
