04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18204-Layer 2 - LAN Switching Command Reference
14-MVRP Commands
14-MVRP Commands 101.23 KB
MVRP commands
display mvrp state
display mvrp state interface interface-type interface-number vlan vlan-id [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
interface interface-type interface-number: Displays the MVRP state of an interface specified by its type and number.
vlan vlan-id: Displays the MVRP state of an interface in an VLAN specified by its VLAN ID. The value range for the vlan-id argument is 1 to 4094.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display mvrp state to display the MVRP state of an interface in a VLAN.
# Display the MVRP state of port GigabitEthernet 3/0/1 in VLAN 2.
<Sysname> display mvrp state interface GigabitEthernet 3/0/1 vlan 2
MVRP state of VLAN 2 on port GE3/0/1
    Port      VLAN   App-state   Reg-state
 GE3/0/1        2       VO          MT
MVRP state of VLAN 2 on port GigabitEthernet3/0/1
MVRP state of GigabitEthernet 3/0/1 in VLAN 2.
App-state
The Applicant state machine that declares attributes. Its state can be VO, VP, VN, AN, AA, QA, LA, AO, QO, AP, QP, or LO. Each state consists of two letters.
The first letter indicates the state:
·     VVery anxious.
·     AAnxious.
·     QQuiet.
·     LLeaving.
The second letter indicates the membership state:
·     A—Active member.
·     P—Passive member.
·     O—Observer.
For example, VP indicates "Very anxious, Passive member."
Reg-state
The Registrar state machine that records the registration state of attributes declared by other participants. Its state can be IN, LV, or MT:
·     IN—Registered.
·     LV—Previously registered, but now being timed out.
·     MT—Not registered.
display mvrp running-status
display mvrp running-status [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-list: Displays the MVRP running status of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where interface-number2 must be greater than interface-number1. If this option is not specified, this command displays MVRP running status of all MVRP-enabled trunk ports.
Use display mvrp running-status to display the MVRP running status.
# Display the MVRP running status of all ports.
<Sysname> display mvrp running-status
-------[MVRP Global Info]-------
Global Status     : Enabled
Compliance-GVRP   : False
----[GigabitEthernet3/0/1] ----
Config Status                       : Enabled
Running Status                      : Enabled
Join Timer                          : 20 (centiseconds)
Leave Timer                         : 60 (centiseconds)
Periodic Timer                      : 100 (centiseconds)
LeaveAll Timer                      : 1000 (centiseconds)
Registration Type                   : Normal
Local VLANs :
  1(default), 2-10,
----[GigabitEthernet3/0/2] ----
Config Status                       : Disabled
Running Status                      : Disabled
Local VLANs :
  1(default),
MVRP Global Info
Global MVRP information.
Global Status
Global MVRP status:
·     Enabled.
·     Disabled.
Compliance-GVRP
GVRP compatibility status:
·     True—Compatible.
·     False—Incompatible.
Interface prompt. The information between the current interface prompt and the next interface prompt is information about the current interface.
Config  Status
Whether MVRP is enabled on the port:
·     Enabled.
·     Disabled.
Running Status
Whether MVRP takes effect on the port (determined by the link state and MVRP enabling status of the port):
·     Enabled.
·     Disabled.
Join Timer
Join timer, in centiseconds.
Leave Timer
Leave timer, in centiseconds.
Periodic Timer
Periodic timer, in centiseconds.
LeaveAll Timer
LeaveAll timer, in centiseconds.
Registration Type
MVRP registration mode:
·     Fixed.
·     Forbidden.
·     Normal.
Local VLANs
VLAN information in the local database, which displays the VLANs learned through MVRP.
display mvrp statistics
display mvrp statistics [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-list: Displays the MVRP statistics of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where interface-number2 must be greater than interface-number1. If this option is not specified, this command displays MVRP statistics of all MVRP-enabled trunk ports.
Use display mvrp statistics to display MVRP statistics.
# Display MVRP statistics of all ports.
<Sysname> display mvrp statistics
 Failed Registrations           : 1
 Last PDU Origin                : 000f-e200-0010
 Frames Received                : 201
  New Event Received                 : 0
  JoinIn Event Received              : 1167
  In Event Received                  : 0
  JoinMt Event Received              : 22387
  Mt Event Received                  : 31
  Leave Event Received               : 210
  LeaveAll Event Received            : 63
 Frames Transmitted             : 47
  New Event Transmitted              : 0
  JoinIn Event Transmitted           : 311
  In Event Transmitted               : 0
  JoinMt Event Transmitted           : 873
  Mt Event Transmitted               : 11065
  Leave Event Transmitted            : 167
  LeaveAll Event Transmitted         : 4
 Frames Discarded               : 0
 Failed Registrations           : 0
 Last PDU Origin                : 0000-0000-0000
 Frames Received                : 0
  JoinIn Event Received              : 0
  JoinMt Event Received              : 0
  Leave Event Received               : 0
  LeaveAll Event Received            : 0
 Frames Transmitted             : 0
  JoinIn Event Transmitted           : 0
  JoinMt Event Transmitted           : 0
  Leave Event Transmitted            : 0
  LeaveAll Event Transmitted         : 0
Interface prompt. The statistics between the current interface prompt and the next interface prompt are statistics of the current interface.
Number of MVRP registration failures.
Last PDU Origin
Source MAC address of the last MVRP PDU.
Frames Received
Number of MVRP protocol packets received.
New Event Received
Number of New attribute events received.
Number of JoinIn attribute events received.
In Event Received
Number of In attribute events received.
Number of JoinMt attribute events received.
Mt Event Received
Number of Mt attribute events received.
Number of Leave attribute events received.
Number of LeaveAll attribute events received.
Frames Transmitted
Number of MVRP protocol packets sent.
Number of New attribute events sent.
Number of JoinIn attribute events sent.
Number of In attribute events sent.
Number of JoinMt attribute events sent.
Number of Mt attribute events sent.
Number of Leave attribute events sent.
Number of LeaveAll attribute events sent.
Frames Discarded
Number of MVRP protocol packets dropped.
display mvrp vlan-operation
display mvrp vlan-operation interface interface-type interface-number [ | { begin | exclude | include } regular-expression ]
View
Default level
0: Visit level
interface interface-type interface-number: Displays the dynamic VLAN operations of an interface specified its type and number.
Use display mvrp vlan-operation to display the dynamic VLAN operations of an interface. These dynamic VLANs refer to the VLANs that the interface learns through MVRP but have not taken effect on the interface.
If a dynamic VLAN that the interface learns through MVRP is a static VLAN or a VLAN reserved for another protocol on the switch, the dynamic VLAN does not take effect on the switch.
# Display the dynamic VLAN operations of GigabitEthernet 3/0/1.
<Sysname> display mvrp vlan-operation interface GigabitEthernet 3/0/1
 Dynamic VLAN operations on port GigabitEthernet3/0/1
  Operations of creating VLAN:  2-100
  Operations of deleting VLAN:  none
  Operations of adding VLAN to TRUNK:  2-100
  Operations of deleting VLAN from TRUNK:  none
Operations of adding VLANs to trunk ports.
Operations of removing VLAN from trunk ports.
mrp timer join
mrp timer join timer-value
undo mrp timer join
View
Layer 2 Ethernet port view, Layer 2 aggregate interface view, port group view
Default level
2: System level
timer-value: Specifies the Join timer value in centiseconds. The Join timer must be less than half the Leave timer, and must be a multiple of 20.
Use mrp timer join to set the Join timer.
Use undo mrp timer join to restore the default. You will fail to restore the default Join timer if the default Join timer is not less than half the Leave timer.
By default, the Join timer is 20 centiseconds.
Related commands: display mvrp running-status and mrp timer leave.
# Set the Join timer to 40 centiseconds. (Suppose the Leave timer is 100 centiseconds)
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] mrp timer join 40
mrp timer leave
mrp timer leave timer-value
undo mrp timer leave
View
Default level
2: System level
timer-value: Specifies the Leave timer value in centiseconds. The Leave timer must be greater than two times the Join timer, less than the LeaveAll timer, and a multiple of 20.
Use mrp timer leave to set the Leave timer.
Use undo mrp timer leave to restore the default. You will fail to restore the default Leave timer if the default Leave timer is not greater than two times the Join timer or not less than the LeaveAll timer.
By default, the Leave timer is 60 centiseconds.
Related commands: display mvrp running-status, mrp timer join, and mrp timer leaveall.
# Set the Leave timer to 100 centiseconds. (Suppose the Join and LeaveAll timer use their default settings)
[Sysname-GigabitEthernet3/0/1] mrp timer leave 100
mrp timer leaveall
mrp timer leaveall timer-value
undo mrp timer leaveall
View
Default level
2: System level
Parameter
timer-value: Specifies the LeaveAll timer value in centiseconds. The LeaveAll timer must be greater than any Leave timer on each port, no greater than 32760, and a multiple of 20.
Use mrp timer leaveall to set the LeaveAll timer.
Use undo mrp timer leaveall to restore the default. You will fail to restore the default LeaveAll timer if the default LeaveAll timer is not greater than any Leave timer on each port.
By default, the LeaveAll timer is 1000 centiseconds.
Each timer when the LeaveAll timer of a port expires, all attributes of the MSTIs on the port are deregistered throughout the network, and such a deregistration affects a large portion of the network. Do not set too small a value for the LeaveAll timer, and make sure the LeaveAll timer is greater than any Leave timer on each port.
To keep the dynamic VLANs learned through MVRP stable, do not set the LeaveAll timer smaller than its default value (1000 centiseconds).
# Set the LeaveAll timer to 1500 centiseconds. (Suppose the Leave timer is restored to the default)
[Sysname-GigabitEthernet3/0/1] mrp timer leaveall 1500
mrp timer periodic
mrp timer periodic timer-value
undo mrp timer periodic
View
Default level
2: System level
timer-value: Specifies the Periodic timer in centiseconds, which can be 0 or 100.
Use mrp timer periodic to set the Periodic timer.
Use undo mrp timer periodic to restore the default.
By default, the Periodic timer is 100 centiseconds.
Setting the Periodic timer to 0 disables periodic transmission of MRP messages.
Related commands: display mvrp running-status.
# Set the Periodic timer to 100 centiseconds.
[Sysname-GigabitEthernet3/0/1] mrp timer periodic 100
mvrp global enable
mvrp global enable
undo mvrp global enable
View
Default level
2: System level
None
Use mvrp global enable to enable MVRP globally.
Use undo mvrp global enable to disable MVRP globally.
By default, MVRP is disabled globally.
# Enable MVRP globally.
[Sysname] mvrp global enable
mvrp enable
mvrp enable
undo mvrp enable
View
Default level
2: System level
None
Use mvrp enable to enable MVRP on a port.
Use undo mvrp enable to disable MVRP on a port.
By default, MVRP is disabled on a port.
To enable MVRP on a port, first enable MVRP globally.
Globally disabling MVRP also disables MVRP on each port.
This command is available only on trunk ports.
You cannot change the link type of MVRP-enabled trunk port.
# Configure GigabitEthernet 3/0/1 as a trunk port, and enable MVRP on it.
[Sysname-GigabitEthernet3/0/1] port link-type trunk
[Sysname-GigabitEthernet3/0/1] mvrp enable
mvrp gvrp-compliance
mvrp gvrp-compliance enable
undo mvrp gvrp-compliance enable
View
Default level
2: System level
None
Use mvrp gvrp-compliance enable to enable GVRP compatibility, so that the device can process both MVRP protocol packets and GVRP protocol packets.
Use undo mvrp gvrp-compliance enable to restore the default.
By default, GVRP compatibility is disabled.
# Enable GVRP compatibility.
[Sysname] mvrp gvrp-compliance enable
mvrp registration
mvrp registration { fixed | forbidden | normal }
undo mvrp registration
View
Default level
2: System level
fixed: Specifies the fixed registration mode.
forbidden: Specifies the forbidden registration mode.
normal: Specifies the normal registration mode.
Use mvrp registration to set the MVRP registration mode on the port.
Use undo mvrp registration to restore the default.
By default, the MVRP registration mode is normal.
# Configure GigabitEthernet 3/0/1 as a trunk port, and set the MVRP registration mode to fixed on the port.
[Sysname-GigabitEthernet3/0/1] mvrp registration fixed
reset mvrp statistics
reset mvrp statistics [ interface interface-list ]
View
Default level
2: System level
interface interface-list: Clears the MVRP statistics of one or multiple ports. You can specify up to 10 port lists, by each of which you can specify a single port in the form of interface-type interface-number, or a port range in the form of interface-type interface-number1 to interface-type interface-number2, where interface-number2 must be greater than interface-number1.
Use reset mvrp statistics to clear the MVRP statistics of ports.
Related commands: display mvrp statistics.
# Clear the MVRP statistics of all ports.
<Sysname> reset mvrp statistics
