04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18204-Layer 2 - LAN Switching Command Reference
13-LLDP Commands
13-LLDP Commands 137 KB
LLDP configuration commands
display lldp local-information
display lldp local-information [ global | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
global: Displays the global LLDP information.
interface interface-type interface-number: Specifies a port by its type and number.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display lldp local-information to display the global LLDP information or the information contained in the LLDP TLVs to be sent to neighboring switches through a port.
If no keyword or argument is specified, this command displays all LLDP information to be sent, including the global LLDP information and the LLDP information about the LLDP-enabled ports.
# Display all LLDP information to be sent.
<Sysname> display lldp local-information
  Chassis ID         : 00e0-fc00-9512
  System name        : Sysname
  System description : H3C Comware software. H3C S12500 Product Version S12500-CMW520-B1131. Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
  System capabilities supported : Bridge,Router
  System capabilities enabled   : Bridge,Router
  MED information
  Device class: Connectivity device
  (MED inventory information of master board)
  HardwareRev               : Ver.A
  FirmwareRev               : 1.06
  SoftwareRev               : S12500-CMW520-B1131
  SerialNum                 : Unknown
  Manufacturer name         : Unknown
  Model name                : LST1MRPNC1
  Asset tracking identifier : Unknown
LLDP local-information of port 157[GigabitEthernet3/0/1]:
  Port ID subtype  : Interface name
  Port ID          : GigabitEthernet3/0/1
  Port description : GigabitEthernet3/0/1 Interface
  Management address type           : ipV4
  Management address                : 192.168.2.200
  Management address interface ID   : 32
  Management address OID            : 0
  Port VLAN ID(PVID): 1000
  Port and protocol VLAN ID(PPVID) : 1000
  Port and protocol VLAN supported : No
  Port and protocol VLAN enabled   : No
  VLAN name of VLAN 1000: VLAN 1000
  Auto-negotiation enabled   : Yes
  OperMau                    : speed(100)/duplex(Full)
  PoE supported: No
  Link aggregation enabled   : No
  Aggregation port ID        : 0
  Maximum frame Size: 1552
  MED information
  Media policy type        : Unknown
  Unknown Policy           : Yes
  VLAN tagged              : No
  Media policy VlanID      : 0
  Media policy L2 priority : 0
  Media policy Dscp        : 0
LLDP local-information of port 158[GigabitEthernet3/0/2]:
  Port ID          : GigabitEthernet3/0/2
  Port description : GigabitEthernet3/0/2 Interface
  Management address                : 192.168.1.100
  Management address interface ID   : 28
  VLAN name of VLAN 10: VLAN 0010
  PoE supported: No
  MED information
  VLAN tagged              : No
Global LLDP information.
Chassis ID
Switch MAC address.
Supported capabilities:
·     Bridge—Switching is supported.
·     Router—Routing is supported.
Enabled capabilities:
·     Bridge—Switching is enabled.
·     Router—Routing is enabled.
Device class
MED device type.
HardwareRev
Hardware version.
FirmwareRev
Firmware version.
SoftwareRev
Software version.
LLDP local-information of port XX
LLDP information about a port.
Port ID subtype
Port ID type:
·     MAC address.
·     Interface name.
Type of the interface identified by the management address.
ID of the interface identified by the management address.
Indicates whether or not protocol VLAN is supported on the port.
Indicates whether or not protocol VLAN is enabled on the port.
Indicates whether or not auto-negotiation is supported on the port.
Indicates whether or not auto-negotiation is enabled on the port.
OperMau
Speed and duplex state of the port.
PoE supported
Indicates whether or not PoE is supported.
Indicates whether or not link aggregation is supported.
Indicates whether or not link aggregation is enabled.
Aggregation port ID
Aggregation group ID, which is 0 when link aggregation is disabled.
Media policy type
Media policy type:
·     Voice—The switch is capable of processing voice data.
·     Unknown—The media policy is unknown.
Unknown Policy
VLAN tagged
Packets of the voice VLAN are tagged.
Media Policy VlanID
ID of the voice VLAN.
Media Policy L2 priority
Layer 2 priority.
Media Policy Dscp
DSCP precedence.
display lldp neighbor-information
display lldp neighbor-information [ brief | interface interface-type interface-number [ brief ] | list [ system-name system-name ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
brief: Displays the summary of LLDP information sent from the neighboring switches. If this keyword is not specified, this command displays detailed LLDP information sent from the neighboring switches.
interface interface-type interface-number: Displays the LLDP information sent from the neighboring switches received through a port specified by its type and number. If this keyword-argument combination is not specified, this command displays the LLDP information sent from the neighboring switches received through all ports.
list: Displays the LLDP information sent from the neighboring switches in the form of a list.
system-name system-name: Displays the LLDP information sent from a neighboring switch specified by its system name. The system-name argument is a character string of 1 to 255 characters. If this keyword-argument combination is not specified, this command displays the LLDP information sent from all neighboring switches in a list.
Use display lldp neighbor-information to display the LLDP information carried in LLDP TLVs sent from the neighboring switches.
# Display the LLDP information sent from the neighboring switches received through all ports.
<Sysname> display lldp neighbor-information
LLDP neighbor-information of port 573[GigabitEthernet4/0/1]:
  Neighbor index   : 1
  Update time      : 0 days,0 hours,11 minutes,56 seconds
  Chassis type     : MAC address
  Chassis ID       : 00e0-fc00-0000
  Port ID type     : Interface name
  Port ID          : GigabitEthernet4/0/1
  Port description : GigabitEthernet4/0/1 Interface
  System name        : H3C
  System description : H3C Comware software. H3C S12508 Product Version S12500-CMW520-B1131. Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
  Management address                : 127.0.0.1
  Management address interface ID   : Unknown
  VLAN name of VLAN 1: VLAN 0001
  OperMau                    : speed(1000)/duplex(Full)
  Power port class          : PD
  PSE power supported       : No
  PSE power enabled         : No
  PSE pairs control ability : No
  Power pairs               : Signal
  Port power classification : Class 0
LLDP neighbor-information of port XX
LLDP information received through the port.
Update time
Time when LLDP information about a neighboring switch was last updated.
Chassis type
Chassis information:
·     Chassis component.
·     Interface alias.
·     Port component.
·     MAC address.
·     Network address (IPv4).
·     Interface name.
·     Locally assigned—Local configuration.
Chassis ID
Value of chassis type.
Port ID type
Port information:
·     Interface alias.
·     Port component.
·     MAC address.
·     Interface name.
·     Agent circuit ID.
Port ID
Value of the port ID type.
System name
System name of the neighboring switch.
System description
System description of the neighboring switch.
Capabilities supported on the neighboring switch:
Capabilities enabled on the neighboring switch:
Interface type identified by the management address.
OperMau
Power port class
PoE device type:
·     PSEPower supply device.
·     PDPowered device.
PSE power supported
The switch can operate as a PSE.
PSE power enabled
The switch is operating as a PSE.
The PSE-PD pair control is available.
Power pairs
PoE mode: Signal or Spare.
Port power classification of the PD:
·     Class 0.
·     Class 1.
·     Class 2.
·     Class 3.
·     Class 4.
Aggregation port ID
display lldp statistics
display lldp statistics [ global | interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
global: Displays the global LLDP statistics.
Use display lldp statistics to display the global LLDP statistics or the LLDP statistics of a port.
If no keyword or argument is specified, this command displays the global LLDP statistics and LLDP statistics on interfaces.
# Display LLDP statistics on GigabitEthernet 3/0/1.
<Sysname> display lldp statistics interface gigabitethernet 3/0/1
LLDP statistics Information of port 157 [GigabitEthernet3/0/1]:
The number of LLDP frames transmitted            : 15
The number of LLDP frames received               : 0
The number of LLDP frames discarded              : 0
The number of LLDP error frames                  : 0
The number of LLDP TLVs discarded                : 0
The number of LLDP TLVs unrecognized             : 0
The number of CDP frames transmitted             : 0
The number of CDP frames received                : 0
The number of CDP frames discarded               : 0
The number of CDP error frames                   : 0
display lldp status
display lldp status [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display lldp status to display the LLDP status of a port.
If no port is specified, this command displays the LLDP status for all ports.
# Display the LLDP status of GigabitEthernet 3/0/1.
<Sysname> display lldp status interface gigabitethernet 3/0/1
Port 157 [GigabitEthernet3/0/1]:
Port status of LLDP            : Enable
Admin status                   : Tx_Rx
Trap flag                      : No
Polling interval               : 0s
Number of neighbors:             0
Number of MED neighbors        : 0
Number of CDP neighbors        : 0
Number of sent optional TLV    : 22
Number of received unknown TLV : 0
Port status of LLDP
Indicates whether or not LLDP is enabled on the port.
Admin status
LLDP mode of the port:
·     TxRx—The port can send and receive LLDP frames.
·     Rx_Only—The port can only receive LLDP frames.
·     Tx_Only—The port can only send LLDP frames.
·     Disable—The port cannot send or receive LLDP frames.
Trap Flag
Indicates whether or not trapping is enabled.
Polling interval
LLDP polling interval, which is 0 when LLDP polling is disabled.
Number of neighbors
Number of LLDP neighbors connecting to the port.
Number of MED neighbors connecting to the port.
Number of CDP neighbors connecting to the port.
Number of optional TLVs contained in an LLDP frame sent through the port.
Number of unknown TLVs contained in a received LLDP frame.
display lldp tlv-config
display lldp tlv-config [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display lldp tlv-config to display the TLVs that are sent through a port.
If no port is specified, this command displays all TLVs that are sent through all ports.
# Display all TLVs that are sent through GigabitEthernet 3/0/1.
<Sysname> display lldp tlv-config interface gigabitethernet 3/0/1
LLDP tlv-config of port 157 [GigabitEthernet3/0/1] :
NAME                              STATUS    DEFAULT
Basic optional TLV :
Port Description TLV              YES       YES
System Name TLV                   YES       YES
System Description TLV            YES       YES
System Capabilities TLV           YES       YES
Management Address TLV            YES       YES
IEEE 802.1 extend TLV :
Port VLAN ID TLV                  YES       YES
Port And Protocol VLAN ID TLV     YES       YES
VLAN Name TLV                     YES       YES
IEEE 802.3 extend TLV :
MAC-Physic TLV                    YES       YES
Power via MDI TLV                 YES       YES
Link Aggregation TLV              YES       YES
Maximum Frame Size TLV            YES       YES
LLDP-MED extend TLV :
Network Policy TLV                YES        YES
Location Identification TLV       NO         NO
Extended Power via MDI TLV        YES        YES
Inventory TLV                     YES        YES
LLDP tlv-config of port number interface-type interface-number
NAME
TLV type.
STATUS
Indicates whether or not a specific type of TLV is sent through a port.
DEFAULT
Indicates whether or not a specific type of TLV is sent through a port by default.
Basic optional TLV
Basic TLVs:
·     Port description TLV.
·     System name TLV.
·     System description TLV.
·     System capabilities TLV.
·     Management address TLV.
IEEE 802.1 extended TLV
IEEE 802.1 extended TLVs:
·     Port VLAN ID TLV.
·     Port and protocol VLAN ID TLV.
·     VLAN name TLV.
IEEE 802.3 extended TLV
IEEE 802.3 extended TLVs:
·     MAC-Physic TLV.
·     Power via MDI TLV.
·     Link aggregation TLV.
·     Maximum frame size TLV.
LLDP-MED extend TLV
MED related LLDP TLVs:
·     Capabilities TLV.
·     Network Policy TLV.
·     Extended Power-via-MDI TLV.
·     Location Identification TLV.
·     Inventory TLV, which can be hardware revision TLV, firmware revision TLV, software revision TLV, serial number TLV, manufacturer name TLV, model name TLV, and asset id TLV.
lldp admin-status
lldp admin-status { disable | rx | tx | txrx }
undo lldp admin-status
View
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, port group view
Default level
2: System level
disable: Specifies the Disable mode. A port in this mode does not send or receive LLDP frames.
rx: Specifies the Rx mode. A port in this mode only receives LLDP frames.
tx: Specifies the Tx mode. A port in this mode only sends LLDP frames.
txrx: Specifies the TxRx mode. A port in this mode sends and receives LLDP frames.
Use lldp admin-status to specify the LLDP operating mode for a port or all ports in a port group.
Use undo lldp admin-status to restore the default LLDP operating mode.
By default, the LLDP operating mode is TxRx.
# Configure the LLDP operating mode as Rx for GigabitEthernet 4/0/1.
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] lldp admin-status rx
lldp check-change-interval
lldp check-change-interval interval
undo lldp check-change-interval
View
Default level
2: System level
interval: Sets the LLDP polling interval in the range of 1 to 30 seconds.
Use lldp check-change-interval to enable LLDP polling and set the polling interval.
Use undo lldp check-change-interval to restore the default.
By default, LLDP polling is disabled.
# Enable LLDP polling on GigabitEthernet 4/0/1, setting the polling interval to 30 seconds.
[Sysname-GigabitEthernet4/0/1] lldp check-change-interval 30
lldp compliance admin-status cdp
lldp compliance admin-status cdp { disable | txrx }
undo lldp compliance admin-status cdp
View
Default level
2: System level
disable: Specifies the disable mode, where CDP-compatible LLDP cannot receive or transmit CDP packets.
txrx: Specifies the TxRx mode, where CDP-compatible LLDP can send and receive CDP packets.
Use lldp compliance admin-status cdp to configure the operating mode of CDP-compatible LLDP on a port or port group.
Use undo lldp compliance admin-status cdp to restore the default.
By default, CDP-compatible LLDP operates in disable mode.
For your switch to work with Cisco IP phones, you must enable CDP-compatible LLDP globally and then configure CDP-compatible LLDP to operate in TxRx mode on the specified ports.
Related commands: lldp compliance cdp.
# Configure CDP-compatible LLDP to operate in TxRx mode on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] lldp compliance admin-status cdp txrx
lldp compliance cdp
lldp compliance cdp
undo lldp compliance cdp
View
Default level
2: System level
None
Use lldp compliance cdp to enable global CDP compatibility.
Use undo lldp compliance cdp to restore the default.
By default, CDP compatibility is globally disabled.
Because the maximum TTL allowed by CDP is 255 seconds, the TTL configuration must be no more than 255 seconds for CDP-compatible LLDP to operate with Cisco IP phones. The TTL configuration is the product of the TTL multiplier and the LLDP frame transmission interval.
Related commands: lldp hold-multiplier and lldp timer tx-interval.
# Enable LLDP to be compatible with CDP globally.
[Sysname] lldp compliance cdp
lldp enable
lldp enable
undo lldp enable
View
System view, Layer 2 Ethernet interface view, Layer 3 Ethernet interface view, port group view
Default level
2: System level
None
Use lldp enable to enable LLDP.
Use undo lldp enable to disable LLDP.
By default, LLDP is enabled on ports, but globally disabled.
LLDP takes effect on a port only when it is enabled both globally and on the port.
# Disable LLDP on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] undo lldp enable
lldp encapsulation snap
undo lldp encapsulation
View
Default level
2: System level
None
Use lldp encapsulation snap to configure the encapsulation format for LLDP frames as SNAP on a port or a group of ports.
Use the undo lldp encapsulation command to restore the default encapsulation format for LLDP frames.
By default, the encapsulation format for LLDP frames is Ethernet II.
# Configure the encapsulation format for LLDP frames as SNAP on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] lldp encapsulation snap
lldp fast-count
lldp fast-count count
undo lldp fast-count
View
Default level
2: System level
count: Sets the number of the LLDP frames sent each time fast LLDP transmission is triggered. The value range is 1 to 10.
Use lldp fast-count to set the number of the LLDP frames sent each time fast LLDP transmission is triggered.
Use undo lldp fast-count to restore the default.
By default, the number is 3.
# Configure the switch to send four LLDP frames each time fast LLDP transmission is triggered.
[Sysname] lldp fast-count 4
lldp hold-multiplier value
undo lldp hold-multiplier
View
Default level
2: System level
value: Sets the TTL multiplier in the range of 2 to 10.
Use lldp hold-multiplier to set the TTL multiplier.
Use undo lldp hold-multiplier to restore the default.
By default, the TTL multiplier is 4.
The TTL configuration of a switch is determined by the following expression:
TTL multiplier × LLDP frame transmission interval
The TTL can be up to 65535 seconds. Longer TTLs will be rounded off to 65535 seconds.
Related commands: lldp timer tx-interval.
# Set the TTL multiplier to 6.
lldp management-address-format string
undo lldp management-address-format
View
Default level
2: System level
None
Use lldp management-address-format string to configure the encapsulation format of the management address as strings in TLVs.
Use the undo lldp management-address-format command to restore the default.
By default, the management address is encapsulated in the form of numbers in TLVs.
# Configure GigabitEthernet 4/0/1 to encapsulate the management address in the form of strings in management address TLVs.
[Sysname-GigabitEthernet4/0/1] lldp management-address-format string
lldp management-address-tlv
lldp management-address-tlv [ ip-address ]
undo lldp management-address-tlv
View
Default level
2: System level
ip-address: Specifies a management address to be advertised in LLDP frames.
Use lldp management-address-tlv to enable management address advertising and set the management address.
Use undo lldp management-address-tlv to disable management address advertising in LLDP frames.
By default, the management address is advertised through LLDP frames. For a Layer 2 Ethernet port, the management address is the main IP address of the lowest-ID VLAN carried on the port. If none of the carried VLANs is assigned an IP address, no management address will be advertised. For a Layer 3 Ethernet port, the management address is its own IP address. If no IP address is configured for the Layer 3 Ethernet port, no management address will be advertised.
An LLDPDU carries only one management address TLV. If you set the management address multiple times, the most recent configuration takes effect.
In Layer 2 Ethernet interface view, if you run the lldp management-address-tlv command without specifying the ip-address argument, the advertised management address is the main IP address of the lowest-ID VLAN carried on the interface. If none of the carried VLANs is assigned an IP address, no management address will be advertised.
In Layer 3 Ethernet interface view, if you run the lldp management-address-tlv command without specifying the ip-address argument, the advertised management address is the IP address of the Layer 3 Ethernet port. If no IP address is configured for the port, no management address will be advertised.
# Set the management address to 192.6.0.1 for GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] lldp management-address-tlv 192.6.0.1
lldp notification remote-change enable
undo lldp notification remote-change enable
View
Default level
2: System level
None
Use lldp notification remote-change enable to enable LLDP trapping for a port or all ports in a port group.
Use undo lldp notification remote-change enable to restore the default.
By default, LLDP trapping is disabled on ports.
# Enable LLDP trapping for GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] lldp notification remote-change enable
lldp timer notification-interval
undo lldp timer notification-interval
View
Default level
2: System level
interval: Sets the interval to send LLDP traps, in the range of 5 to 3600 seconds.
Use lldp timer notification-interval to set the interval to send LLDP traps.
Use undo lldp timer notification-interval to restore the default.
By default, the interval to send LLDP traps is 5 seconds.
# Set the interval to send LLDP traps to 8 seconds.
lldp timer reinit-delay
lldp timer reinit-delay delay
undo lldp timer reinit-delay
View
Default level
2: System level
delay: Sets the LLDP re-initialization delay in the range of 1 to 10 seconds.
Use lldp timer reinit-delay to set the LLDP re-initialization delay.
Use undo lldp timer reinit-delay to restore the default.
By default, the LLDP re-initialization delay is 2 seconds.
# Set the LLDP re-initialization delay to 4 seconds.
lldp timer tx-delay
lldp timer tx-delay delay
undo lldp timer tx-delay
View
Default level
2: System level
delay: Sets the LLDP frame transmission delay in the range of 1 to 8192 seconds.
Use lldp timer tx-delay to set the LLDP frame transmission delay.
Use undo lldp timer tx-delay to restore the default.
By default, the LLDP frame transmission delay is 2 seconds.
H3C recommends that you set the LLDP frame transmission delay to be no greater than a quarter of the LLDP frame transmission interval.
If the LLDP frame transmission delay is greater than the LLDP frame transmission interval, the switch uses the LLDP frames transmission delay as the transmission interval.
# Set the LLDP frame transmission delay to 4 seconds.
[Sysname] lldp timer tx-delay 4
undo lldp timer tx-interval
View
Default level
2: System level
interval: Sets the LLDP frame transmission interval in the range of 5 to 32768 seconds.
Use lldp timer tx-interval to set the LLDP frame transmission interval.
Use undo lldp timer tx-interval to restore the default.
By default, the LLDP frame transmission interval is 30 seconds.
To enable local switch information to be updated on neighboring switches before being aged out, make sure the LLDP frame transmission interval is shorter than the TTL of the local switch information.
H3C recommends that you set the LLDP frame transmission interval to be no smaller than four times the LLDP frame transmission delay.
If the LLDP frame transmission interval is smaller than the LLDP frame transmission delay, the switch uses the LLDP frames transmission delay as the transmission interval.
Related commands: lldp timer tx-delay.
# Set the LLDP frame transmission interval to 20 seconds.
lldp tlv-enable
In Layer 2 Ethernet interface view or port group view:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | network-policy | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id | vlan-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | network-policy | power-over-ethernet } }
In Layer 3 Ethernet interface view:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | power-over-ethernet } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id | power-over-ethernet } }
View
Default level
2: System level
all: Advertises all basic LLDP TLVs, IEEE 802.1 organizationally specific LLDP TLVs, or IEEE 802.3 organizationally specific LLDP TLVs when the all keyword is specified for basic-tlv, dot1-tlv, or dot3-tlv in Layer 2 Ethernet interface view; advertises all basic LLDP TLVs or IEEE 802.3 organizationally specific LLDP TLVs when the all keyword is specified for basic-tlv or dot3-tlv in Layer 3 Ethernet interface view; or advertises all LLDP-MED TLVs except location identification TLVs when the all keyword is specified for med-tlv, regardless of whether in Layer 2 or Layer 3 Ethernet interface view.
basic-tlv: Advertises basic LLDP TLVs.
port-description: Advertises port description TLVs.
system-capability: Advertises system capabilities TLVs.
system-description: Advertises system description TLVs.
system-name: Advertises system name TLVs.
dot1-tlv: Advertises IEEE 802.1 organizationally specific LLDP TLVs.
port-vlan-id: Advertises port VLAN ID TLVs.
protocol-vlan-id: Advertises port and protocol VLAN ID TLVs.
vlan-name: Advertises VLAN name TLVs.
vlan-id: Specifies the VLAN ID in the TLVs (port and protocol VLAN ID TLVs or VLAN name TLVs) to be advertised. It defaults to the least protocol VLAN ID.
dot3-tlv: Advertises IEEE 802.3 organizationally specific LLDP TLVs.
link-aggregation: Advertises link aggregation group TLVs.
mac-physic: Advertises MAC/PHY configuration/status TLVs.
max-frame-size: Advertises maximum frame size TLVs.
power: Advertises power via MDI TLVs.
med-tlv: Advertises MED related LLDP TLVs.
capability: Advertises LLDP-MED capabilities TLVs.
inventory: Advertises hardware revision, firmware revision, software revision, serial number, manufacturer name, model name, and asset ID TLVs.
location-id: Advertises location identification TLVs.
civic-address: Inserts the address information about the intermediate device in location identification TLVs .
device-type: Sets a device type value. Value 0 specifies a DHCP server, value 1 specifies a switch, and value 2 specifies an LLDP-MED endpoint.
country-code: Sets a country code, corresponding to ISO 3166.
{ ca-type ca-value }&<1-10>: Configures address information, where ca-type represents the address information type in the range of 0 to 255, ca-value represents address information, a string of 1 to 250 characters, and &<1-10> indicates that you can enter up to 10 parameters.
elin-address: Inserts telephone numbers for emergencies in location identification TLVs.
tel-number: Telephone number for emergencies, a string of 10 to 25 characters.
network-policy: Advertises network policy TLVs.
power-over-ethernet: Advertises extended power-via-MDI TLVs.
Use lldp tlv-enable to configure the types of advertisable TLVs for a port or all ports in a port group.
Use undo lldp tlv-enable to disable the switch from advertising specific types of TLVs.
By default, the switch can advertise on a Layer 2 Ethernet port all types of LLDP TLVs, except location identification TLVs, and advertise on a Layer 3 Ethernet port all types of LLDP TLVs, except IEEE 802.1 organizationally specific TLVs, network policy TLVs, and location identification TLVs.
To enable the switch to advertise MED related LLDP TLVs, you must first enable it to advertise LLDP-MED capabilities TLVs.
To disable the switch from advertising LLDP-MED capabilities TLVs, you must first disable it from advertising other LLDP-MED TLVs.
To disable the switch from advertising MAC/PHY configuration/status TLVs, you must first disable it from advertising LLDP-MED capabilities TLVs.
If you enable the switch to advertise LLDP-MED capabilities TLVs, you also enable it to advertise MAC/PHY configuration/status TLVs.
To enable the switch to advertise multiple types of TLVs, you can execute the lldp tlv-enable command multiple times without the all keyword specified.
# Enable the switch to advertise link aggregation TLVs of the IEEE 802.3 organizationally specific TLVs on GigabitEthernet 4/0/1.
[Sysname-GigabitEthernet4/0/1] lldp tlv-enable dot3-tlv link-aggregation
