08-IP Multicast Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18208-IP Multicast Configuration Guide
13-IPv6 Multicast VLAN Configuration
13-IPv6 Multicast VLAN Configuration 169.93 KB
Overview
In this chapter, the switch functions as a Layer 2 device (referred to as the switch in network diagrams); configurations for a Layer 3 device (referred to as the router in network diagrams) are implemented on an H3C router device.
As shown in Figure 1, in the traditional IPv6 multicast programs-on-demand mode, when receiver hosts (Host A, Host B, and Host C) that belong to different VLANs require IPv6 multicast programs on demand service, the Layer 3 device (Router A) needs to forward a separate copy of the multicast traffic in each user VLAN to the Layer 2 device (Switch A). In this case, a large amount of network bandwidth is used and an extra burden is added to the Layer 3 device.
Figure 1 Multicast transmission without the IPv6 multicast VLAN feature
The IPv6 multicast VLAN feature configured on the Layer 2 device is the solution to this issue. With the IPv6 multicast VLAN feature, the Layer 3 device needs to replicate the multicast traffic only in the IPv6 multicast VLAN instead of making a separate copy of the multicast traffic in each user VLAN. This saves the network bandwidth and lessens the burden of the Layer 3 device.
The switch supports only sub-VLAN-based IPv6 multicast VLANs.
As shown in Figure 2, Host A, Host B, and Host C are in three different user VLANs. On Switch A, configure VLAN 10 as an IPv6 multicast VLAN, configure all the user VLANs as sub-VLANs of this IPv6 multicast VLAN, and enable MLD snooping in the IPv6 multicast VLAN.
Figure 2 A sub-VLAN-based IPv6 multicast VLAN
After the configuration, MLD snooping manages router ports in the IPv6 multicast VLAN and member ports in the sub-VLANs. When forwarding multicast data to Switch A, Router A needs to send only one copy of multicast traffic to Switch A in the IPv6 multicast VLAN, and Switch A distributes the traffic to the IPv6 multicast VLAN's sub-VLANs that contain receivers.
For more information about MLD snooping, router ports, and member ports, see "Configuring MLD snooping."
For more information about VLAN tags, see Layer 2—LAN Switching Configuration Guide.
IPv6 multicast VLAN configuration task list
Remarks
Configuring an IPv6 multicast VLAN
Required.
Setting the maximum number of forwarding entries for IPv6 multicast VLANs
Optional.
Before you configure sub-VLAN-based IPv6 multicast VLAN, complete the following tasks:
·     Enable IPv6 forwarding.
·     Create VLANs as required.
·     Enable MLD snooping in the VLAN to be configured as an IPv6 multicast VLAN.
By using this method, you configure a VLAN as an IPv6 multicast VLAN, and configure user VLANs as sub-VLANs of the IPv6 multicast VLAN.
Configuration guidelines
·     You cannot configure an IPv6 multicast VLAN on a device with IP multicast routing enabled.
·     The VLAN to be configured as an IPv6 multicast VLAN must exist.
·     The VLANs to be configured as the sub-VLANs of the IPv6 multicast VLAN must exist and must not be IPv6 multicast VLANs or sub-VLANs of any other IPv6 multicast VLAN.
·     An IPv6 multicast VLAN can have up to 1024 sub-VLANs.
Configuration procedure
To configure a sub-VLAN-based IPv6 multicast VLAN:
Step
Remarks
N/A
2.     Configure the specified VLAN as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
multicast-vlan ipv6 vlan-id
No IPv6 multicast VLAN is configured by default.
3.     Assign the specified VLANs to the IPv6 multicast VLAN.
subvlan vlan-list
An IPv6 multicast VLAN has no sub-VLANs by default.
You can set the maximum number of entries in the MLD snooping forwarding table for IPv6 multicast VLANs. When the number of forwarding entries maintained for the IPv6 multicast VLANs reaches the threshold, the system informs you to remove excessive entries. In this case, the system does not automatically remove any existing entries or create new entries.
To set the maximum number of entries in the forwarding table:
Step
Remarks
N/A
2.     Set the maximum number of forwarding entries for IPv6 multicast VLANs.
multicast-vlan ipv6 entry-limit limit
The default upper limit depends on the system operating mode.
For more information, see Fundamentals Configuration Guide.
Displaying and maintaining an IPv6 multicast VLAN
Remarks
Display information about an IPv6 multicast VLAN.
display multicast-vlan ipv6 [ vlan-id ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
IPv6 multicast VLAN configuration example
IMPORTANT:
By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are in the state of DOWN. To configure such an interface, use the undo shutdown commands to bring it up first.
Network requirements
As shown in Figure 3, MLDv1 runs on Router A, and MLDv1 snooping runs on Switch A. Router A acts as the MLD querier.
The IPv6 multicast source sends IPv6 multicast data to the IPv6 multicast group FF1E::101. Host A, Host B, Host C, and Host D are receivers of the IPv6 multicast group. The hosts belong to VLAN 2 through VLAN 5.
Configure the sub-VLAN-based IPv6 multicast VLAN feature on Switch A so that Router A just sends IPv6 multicast data to Switch A through the IPv6 multicast VLAN and Switch A forwards the traffic to the receivers that belong to different user VLANs.
Figure 3 Network diagram
1.     Enable IPv6 forwarding on each device and configure an IPv6 address and address prefix for each interface as shown in Figure 3. (Details not shown.)
2.     On Router A, enable IPv6 multicast routing, enable IPv6 PIM-DM on each interface and enable MLD on the host-side interface GigabitEthernet 3/0/2.
[RouterA] multicast ipv6 routing-enable
[RouterA] interface GigabitEthernet 3/0/1
[RouterA-GigabitEthernet3/0/1] pim ipv6 dm
[RouterA-GigabitEthernet3/0/1] quit
[RouterA] interface GigabitEthernet 3/0/2
[RouterA-GigabitEthernet3/0/2] pim ipv6 dm
[RouterA-GigabitEthernet3/0/2] mld enable
3.     Configure Switch A:
# Enable MLD snooping globally.
[SwitchA] mld-snooping
[SwitchA-mld-snooping] quit
# Create VLAN 2 through VLAN 5.
[SwitchA] vlan 2 to 5
# Configure GigabitEthernet 3/0/2 as a trunk port that permits packets from VLAN 2 and VLAN 3 to pass through.
[SwitchA] interface GigabitEthernet 3/0/2
[SwitchA-GigabitEthernet3/0/2] port link-type trunk
[SwitchA-GigabitEthernet3/0/2] port trunk permit vlan 2 3
[SwitchA-GigabitEthernet3/0/2] quit
# Configure GigabitEthernet 3/0/3 as a trunk port that permits packets from VLAN 4 and VLAN 5 to pass through.
[SwitchA] interface GigabitEthernet 3/0/3
[SwitchA-GigabitEthernet3/0/3] port link-type trunk
[SwitchA-GigabitEthernet3/0/3] port trunk permit vlan 4 5
[SwitchA-GigabitEthernet3/0/3] quit
# Create VLAN 10, assign GigabitEthernet 3/0/1 to this VLAN and enable MLD snooping in the VLAN.
[SwitchA] vlan 10
[SwitchA-vlan10] port GigabitEthernet 3/0/1
[SwitchA-vlan10] mld-snooping enable
[SwitchA-vlan10] quit
# Configure VLAN 10 as an IPv6 multicast VLAN and configure VLAN 2 through VLAN 5 as its sub-VLANs.
[SwitchA] multicast-vlan ipv6 10
[SwitchA-ipv6-mvlan-10] subvlan 2 to 5
[SwitchA-ipv6-mvlan-10] quit
4.     Configure Switch B:
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 2, assign GigabitEthernet 3/0/2 to VLAN 2, and enable MLD snooping in the VLAN.
[SwitchB] vlan 2
[SwitchB-vlan2] port GigabitEthernet 3/0/2
[SwitchB-vlan2] mld-snooping enable
[SwitchB-vlan2] quit
# Create VLAN 3, assign GigabitEthernet 3/0/3 to VLAN 3, and enable MLD snooping in the VLAN.
[SwitchB] vlan 3
[SwitchB-vlan3] port GigabitEthernet 3/0/3
[SwitchB-vlan3] mld-snooping enable
[SwitchB-vlan3] quit
# Configure GigabitEthernet 3/0/1 as a trunk port that permits packets from VLAN 2 and VLAN 3 to pass through.
[SwitchB] interface GigabitEthernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] port link-type trunk
[SwitchB-GigabitEthernet3/0/1] port trunk permit vlan 2 3
5.     Configure Switch C in the same way as you configure Switch B. (Details not shown.)
# Display information about the IPv6 multicast VLAN.
[SwitchA] display multicast-vlan ipv6
 Total 1 IPv6 multicast-vlan(s)
 IPv6 Multicast vlan 10
   subvlan list:
    vlan 2-5
# Display the MLD snooping IPv6 multicast group information on Switch A.
[SwitchA] display mld-snooping group
  Total 5 IP Group(s).
  Total 5 IP Source(s).
  Total 5 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Total 1 IP Group(s).
    Total 1 IP Source(s).
    Total 1 MAC Group(s).
    Router port(s):total 0 port(s).
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:FF1E::101
        (::, FF1E::101):
          Host port(s):total 1 port(s).
            GE3/0/2                (D)
    MAC group(s):
      MAC group address:3333-0000-0101
            GE3/0/2
  Vlan(id):3.
        (::, FF1E::101):
            GE3/0/2                (D)
    MAC group(s):
            GE3/0/2
  Vlan(id):4.
        (::, FF1E::101):
            GE3/0/3                (D)
    MAC group(s):
            GE3/0/3
  Vlan(id):5.
        (::, FF1E::101):
            GE3/0/3                (D)
    MAC group(s):
            GE3/0/3
  Vlan(id):10.
    Router port(s):total 1 port(s).
            GE3/0/1                (D)
        (::, FF1E::101):
          Host port(s):total 0 port(s).
    MAC group(s):
The output shows that MLD snooping is maintaining the router port in the IPv6 multicast VLAN (VLAN 10) and the member ports in the sub-VLANs (VLAN 2 through VLAN 5).
