08-IP Multicast Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release1828P04-6W18208-IP Multicast Configuration Guide
06-IGMP Configuration
06-IGMP Configuration 370.6 KB
Overview
As a TCP/IP protocol responsible for IP multicast group member management, the Internet Group Management Protocol (IGMP) is used by IP hosts and adjacent multicast routers to establish and maintain their multicast group memberships.
The term "router" in this document refers to both routers and Layer 3 switches.
IGMP versions
·     IGMPv1 (defined by RFC 1112)
·     IGMPv2 (defined by RFC 2236)
·     IGMPv3 (defined by RFC 3376)
All IGMP versions support the ASM model. In addition to the ASM model, IGMPv3 can directly implement the SSM model. IGMPv1 and IGMPv2 must work with the IGMP SSM mapping function to implement the SSM model.
For more information about the ASM and SSM models, see "Multicast overview."
Introduction to IGMPv1
IGMPv1 manages multicast group memberships mainly based on the query and response mechanism.
All multicast routers on the same subnet can get IGMP membership report messages (often called "reports") from hosts, but the subnet needs only one router to act as the IGMP querier to send IGMP query messages (often called "queries"). The querier election mechanism determines which router acts as the IGMP querier on the subnet.
In IGMPv1, the DR elected by the working multicast routing protocol (such as PIM) serves as the IGMP querier.
For more information about DR, see "Configuring PIM."
Figure 1 IGMP queries and reports
As shown in Figure 1, assume that Host B and Host C receive multicast data addressed to multicast group G1, and Host A receive multicast data addressed to G2. The following process describes how the hosts join the multicast groups and how the IGMP querier (Router B in the figure) maintains the multicast group memberships:
1.     The hosts send unsolicited IGMP reports to the addresses of the multicast groups that they want to join, without having to wait for the IGMP queries from the IGMP querier.
2.     The IGMP querier periodically multicasts IGMP queries (with the destination address of 224.0.0.1) to all hosts and routers on the local subnet.
3.     After receiving a query message, Host B or Host C (the delay timer of whichever expires first) sends an IGMP report to the multicast group address of G1, to announce its membership for G1. Assume that Host B sends the report message. After receiving the report from Host B, Host C (which is on the same subnet as Host B) suppresses its own report for G1, because the IGMP routers (Router A and Router B) have already known that at least one host on the local subnet is interested in G1. This mechanism (known as "IGMP report suppression") helps reduce traffic on the local subnet.
4.     At the same time, because Host A is interested in G2, it sends a report to the multicast group address of G2.
5.     Through the query/report process, the IGMP routers determine that members of G1 and G2 are attached to the local subnet, and the multicast routing protocol (PIM, for example) that is running on the routers generates (*, G1) and (*, G2) multicast forwarding entries. These entries will be the basis for subsequent multicast forwarding, where the asterisk (*) represents any multicast source.
6.     When the multicast data addressed to G1 or G2 reaches an IGMP router, because the (*, G1) and (*, G2) multicast forwarding entries exist on the IGMP router, the router forwards the multicast data to the local subnet, and then the receivers on the subnet receive the data.
IGMPv1 does not specifically define a leave group message (often called a "leave message"). When an IGMPv1 host is leaving a multicast group, it stops sending reports to the address of the multicast group that it listened to. If no member exists in a multicast group on the subnet, the IGMP router will not receive any report addressed to that multicast group. In this case, the router will delete the multicast forwarding entries for that multicast group after a period of time.
Enhancements in IGMPv2
Compared with IGMPv1, IGMPv2 has introduced a querier election mechanism and a leave-group mechanism.
Querier election mechanism
In IGMPv1, the DR elected by the Layer 3 multicast routing protocol (such as PIM) serves as the querier among multiple routers on the same subnet.
IGMPv2 introduced an independent querier election mechanism. The querier election process is as follows:
1.     Initially, every IGMPv2 router assumes itself as the querier and sends IGMP general query messages (often called "general queries") to all hosts and routers on the local subnet. The destination address is 224.0.0.1.
2.     After receiving a general query, every IGMPv2 router compares the source IP address of the query message with its own interface address. After comparison, the router with the lowest IP address wins the querier election and becomes the querier, and all other IGMPv2 routers become non-queriers.
3.     All the non-queriers start a timer, known as "other querier present timer." If a router receives an IGMP query from the querier before the timer expires, it resets this timer. Otherwise, it assumes the querier have timed out and initiates a new querier election process.
"Leave group" mechanism
In IGMPv1, when a host leaves a multicast group, it does not send any notification to the multicast router. The multicast router relies on host response timeout to determine whether a group has members. This increases the leave latency.
In IGMPv2, when a host leaves a multicast group, the following steps occur:
1.     This host sends a leave message to all routers on the local subnet with the destination address of 224.0.0.2.
2.     After receiving the leave message, the querier sends a configurable number of group-specific queries to the group that the host is leaving. The destination address field and group address field of the message are both filled with the address of the multicast group that is being queried.
3.     One of the remaining members (if any on the subnet) of the group should send a membership report within the maximum response delay advertised in the query messages.
4.     If the querier receives a membership report for the group within the maximum response delay, it maintains the memberships for the group. Otherwise, the querier assumes that the group has no member hosts on the local subnet and stops maintaining the memberships for the group.
Enhancements in IGMPv3
Only the Include mode but not the Exclude mode is supported by the switch. Descriptions of the Exclude mode in this document are for reference only.
IGMPv3 is based on and is compatible with IGMPv1 and IGMPv2. It provides hosts with enhanced control capabilities and provides enhancements of query and report messages.
Enhancements in control capability of hosts
IGMPv3 has introduced source filtering modes (Include and Exclude), so that a host not only can join a designated multicast group, but also can specify to receive or reject multicast data from designated multicast sources. When a host joins a multicast group, one of the following situations occurs:
·     If it needs to receive multicast data from specific sources like S1, S2, …, it sends a report with the Filter-Mode denoted as "Include Sources (S1, S2, …)."
·     If it needs to reject multicast data from specific sources like S1, S2, …, it sends a report with the Filter-Mode denoted as "Exclude Sources (S1, S2, …)."
As shown in Figure 2, the network comprises two multicast sources, Source 1 (S1) and Source 2 (S2), both of which can send multicast data to multicast group G. Host B is interested only in the multicast data that Source 1 sends to G but not in the data from Source 2.
Figure 2 Flow paths of source-and-group-specific multicast traffic
In the case of IGMPv1 or IGMPv2, Host B cannot select multicast sources when it joins multicast group G. Therefore, multicast streams from both Source 1 and Source 2 will flow to Host B whether it needs them or not.
When IGMPv3 is running between the hosts and routers, Host B can explicitly express that it needs to receive the multicast data that Source 1 sends to multicast group Gdenoted as (S1, G), rather than the multicast data that Source 2 sends to multicast group Gdenoted as (S2, G). Thus, only multicast data from Source 1 will be delivered to Host B.
Enhancements in query and report capabilities
1.     Query message carrying the source addresses
Compatible with IGMPv1 and IGMPv2, IGMPv3 supports general queries and group-specific queries. In addition, it introduces group-and-source-specific queries.
¡     A general query does not carry a group address, or a source address.
¡     A group-specific query carries a group address, but no source address.
¡     A group-and-source-specific query carries a group address and one or more source addresses.
2.     Reports containing multiple group records
Unlike an IGMPv1 or IGMPv2 report message, an IGMPv3 report message is destined to 224.0.0.22 and contains one or more group records. Each group record contains a multicast group address and a multicast source address list.
Group record has the following types:
¡     IS_IN—The source filtering mode is Include. The report sender requests the multicast data from only the sources defined in the specified multicast source list.
¡     IS_EX—The source filtering mode is Exclude. The report sender requests the multicast data from any sources but those defined in the specified multicast source list.
¡     TO_IN—The filtering mode has changed from Exclude to Include.
¡     TO_EX—The filtering mode has changed from Include to Exclude.
¡     ALLOW—The Source Address fields in this group record contain a list of the additional sources that the system wants to obtain data from, for packets sent to the specified multicast address. If the change was to an Include source list, these sources are the addresses that were added to the list. If the change was to an Exclude source list, these sources are the addresses that were deleted from the list.
¡     BLOCK—The Source Address fields in this group record contain a list of the sources that the system no longer wants to obtain data from, for packets sent to the specified multicast address. If the change was to an Include source list, these sources are the addresses that were deleted from the list. If the change was to an Exclude source list, these sources are the addresses that were added to the list.
IGMP SSM mapping
The IGMP SSM mapping feature enables you to configure static IGMP SSM mappings on the last hop router to provide SSM support for receiver hosts that are running IGMPv1 or IGMPv2. The SSM model assumes that the last hop router has already known the desired multicast sources when receivers join multicast groups.
·     When a host that is running IGMPv3 joins a multicast group, it can explicitly specify one or more multicast sources in its IGMPv3 report.
·     A host that is running IGMPv1 or IGMPv2, however, cannot specify multicast source addresses in its report. In this case, you must configure the IGMP SSM mapping feature to translate the (*, G) information in the IGMPv1 or IGMPv2 report into (G, INCLUDE, (S1, S2...)) information.
Figure 3 Network diagram
As shown in Figure 3, on an SSM network, Host A, Host B and Host C are running IGMPv1, IGMPv2 and IGMPv3 respectively. To provide SSM service for all the hosts if IGMPv3 is not available on Host A and Host B, you must configure the IGMP SSM mapping feature on Router A.
With the IGMP SSM mapping feature configured, when Router A receives an IGMPv1 or IGMPv2 report, it checks the multicast group address G carried in the message:
·     If G is not in the SSM group range, Router A cannot provide the SSM service but can provide the ASM service.
·     If G is in the SSM group range but no IGMP SSM mappings that correspond to the multicast group G have been configured on Router A, Router A cannot provide SSM service and drops the message.
·     If G is in the SSM group range and the IGMP SSM mappings have been configured on Router A for multicast group G, Router A translates the (*, G) information in the IGMP report into (G, INCLUDE, (S1, S2...)) information based on the configured IGMP SSM mappings and provides SSM service accordingly.
The IGMP SSM mapping feature does not process IGMPv3 reports.
For more information about the SSM group range, see "Configuring PIM."
IGMP proxying
In a simple tree-shaped topology, it is not necessary to configure multicast routing protocols, such as PIM, on edge devices. Instead, you can configure IGMP proxying on these devices. With IGMP proxying configured, the device serves as a proxy for the downstream hosts to send IGMP messages, maintain group memberships, and implement multicast forwarding based on the memberships. In this case, each edge device is a host but no longer a PIM neighbor to the upstream device.
Figure 4 Network diagram
As shown in Figure 4, the following types of interfaces are defined on an IGMP proxy device:
·     Upstream interface—Also called the "proxy interface." A proxy interface is an interface on which IGMP proxying is configured. It is in the direction toward the root of the multicast forwarding tree. An upstream interface acts as a host that is running IGMP. Therefore, it is also called the "host interface."
·     Downstream interface—An interface that is running IGMP and is not in the direction toward the root of the multicast forwarding tree. A downstream interface acts as a router that is running IGMP. Therefore, it is also called the "router interface."
An IGMP proxy device maintains a group membership database, which stores the group memberships on all the downstream interfaces. Each entry comprises the multicast address, filter mode, and source list. Such an entry is a collection of members in the same multicast group on each downstream interface.
An IGMP proxy device performs host functions on the upstream interface based on the database. It responds to queries according to the information in the database or sends join/leave messages when the database changes. On the other hand, the IGMP proxy device performs router functions on the downstream interfaces by participating in the querier election, sending queries, and maintaining memberships based on the reports.
IGMP support for VPNs
IGMP maintains group memberships on a per-interface base. After receiving an IGMP message on an interface, IGMP processes the packet within the VPN to which the interface belongs. If IGMP that runs in a VPN needs to exchange information with another multicast protocol, it passes the information only to the protocol that runs in this VPN.
Protocols and standards
·     RFC 1112, Host Extensions for IP Multicasting
·     RFC 2236, Internet Group Management Protocol, Version 2
·     RFC 3376, Internet Group Management Protocol, Version 3
·     RFC 4605, Internet Group Management Protocol (IGMP)/Multicast Listener Discovery (MLD)-Based Multicast Forwarding ("IGMP/MLD Proxying")
IGMP configuration task list
Remarks
Configuring basic IGMP functions
Enabling IGMP
Required.
Configuring IGMP versions
Optional.
Configuring static joining
Optional.
Configuring a multicast group filter
Optional.
Setting the maximum number of multicast groups that an interface can join
Optional.
Adjusting IGMP performance
Configuring Router-Alert option handling methods
Optional.
Configuring IGMP query and response parameters
Optional.
Configuring IGMP fast-leave processing
Optional.
Enabling the IGMP host tracking function
Optional.
Configuring IGMP SSM mapping
Enabling SSM mapping
Optional.
Configuring SSM mappings
Optional.
Configuring IGMP proxying
Enabling IGMP proxying
Optional.
Configuring multicast forwarding on a downstream interface
Optional.
For the configuration tasks described in this section:
·     In IGMP view, the configuration takes effect on all interfaces. In interface view, the configuration takes effect on only the current interface.
·     If a feature is not configured on an interface in interface view, the global configuration in IGMP view will apply to that interface. If a feature is configured in both IGMP view and interface view, the configuration in interface view will be given priority, regardless of the configuration sequence.
Before you configure basic IGMP functions, complete the following tasks:
·     Configure any unicast routing protocol so that all devices in the domain are interoperable at the network layer.
·     Configure PIM-DM or PIM-SM.
·     Determine the IGMP version.
·     Determine the multicast group and multicast source addresses for static group member configuration.
·     Determine the ACL rule for multicast group filtering.
·     Determine the maximum number of multicast groups that an interface can join.
Enabling IGMP
To configure IGMP, you must enable IGMP on the interface on which the multicast group memberships will be established and maintained.
Enabling IGMP for the public network
Step
Remarks
N/A
2.     Enable IP multicast routing.
multicast routing-enable
Disabled by default.
3.     Enter interface view.
N/A
4.     Enable IGMP.
igmp enable
Enabling IGMP for a VPN instance
Step
Remarks
N/A
2.     Create a VPN instance and enter VPN instance view.
N/A
3.     Configure an RD for the VPN instance.
No RD is configured by default.
4.     Enable IP multicast routing.
5.     Enter interface view.
N/A
6.     Bind the interface with a VPN instance.
By default, an interface belongs to the public network, and is not bound with any VPN instance.
7.     Enable IGMP.
igmp enable
For more information about the ip vpn-instance, route-distinguisher, and ip binding vpn-instance commands, see MPLS Command Reference.
Because the protocol packets of different IGMP versions vary in structure and type, you must configure the same IGMP version for all routers on the same subnet before IGMP can operate correctly.
Configuring an IGMP version globally
Step
Remarks
N/A
2.     Enter public network IGMP view or VPN instance IGMP view.
igmp [ vpn-instance vpn-instance-name ]
N/A
3.     Configure an IGMP version globally.
version version-number
IGMPv2 by default.
Configuring an IGMP version on an interface
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure an IGMP version on the interface.
igmp version version-number
IGMPv2 by default.
After an interface is configured as a static member of a multicast group or a multicast source group, it will act as a virtual member of the multicast group to receive multicast data addressed to that multicast group for the purpose of testing multicast data forwarding.
Configuration guidelines
·     If you want to configure an interface that is IGMP and PIM-SM enabled as a static member of a multicast group or a multicast source and group, the interface must be a PIM-SM DR. If this interface is IGMP enabled but not PIM-SM enabled, it must be an IGMP querier. For more information about PIM-SM and a DR, see "Configuring PIM."
·     A static member port does not respond to queries from the IGMP querier. When you configure a port as a static member port or remove this configuration on the port, the port does not unsolicitedly send any IGMP report or IGMP leave message. In other words, the port is not a real member of the multicast group or the multicast source and group.
Configuration procedure
To configure an interface as a statically connected member of a multicast group or a multicast source and group:
Step
Remarks
N/A
N/A
3.     Configure the interface as a static member of a multicast group or a multicast source and group.
igmp static-group group-address [ source source-address ]
An interface is not a static member of any multicast group or multicast source and group by default.
To restrict the hosts on the network attached to an interface from joining certain multicast groups, you can set an ACL rule on the interface as a packet filter so that the interface maintains only the multicast groups the match the criteria.
To configure a multicast group filter:
Step
Remarks
N/A
N/A
3.     Configure a multicast group filter.
igmp group-policy acl-number [ version-number ]
By default, no multicast group filter is configured on this interface. Hosts on the current interface can join any valid multicast group.
Step
Remarks
N/A
N/A
3.     Configure the maximum number of multicast groups that the interface can join.
igmp group-limit limit
1024 by default.
This configuration takes effect in dynamically joined multicast groups but not in the statically configured multicast groups.
Before adjusting IGMP performance, complete the following tasks:
·     Configure basic IGMP functions.
·     Determine the startup query interval.
·     Determine the startup query count.
·     Determine the IGMP general query interval.
·     Determine the IGMP querier's robustness variable.
·     Determine the maximum response delay for IGMP general queries.
·     Determine the IGMP last-member query interval.
·     Determine the other querier present interval.
IGMP queries include group-specific queries and group-and-source-specific queries, and multicast groups change dynamically, so a device cannot maintain the information for all multicast sources and groups. For this reason, when an IGMP router receives a multicast packet but cannot locate the outgoing interface for the destination multicast group, it must use the Router-Alert option to pass the multicast packet to the upper-layer protocol for processing. For more information about the Router-Alert option, see RFC 2113.
An IGMP message is processed differently depending on whether it carries the Router-Alert option in the IP header:
·     By default, for the consideration of compatibility, the device does not verify the Router-Alert option. It processes all the IGMP messages that it received. In this case, IGMP messages are directly passed to the upper layer protocol, whether the IGMP messages carry the Router-Alert option or not.
·     To enhance the device performance and avoid unnecessary costs, and also for the consideration of protocol security, you can configure the device to discard IGMP messages that do not carry the Router-Alert option.
Configuring Router-Alert option handling methods globally
Step
Remarks
N/A
N/A
3.     Configure the router to discard any IGMP message that does not carry the Router-Alert option.
require-router-alert
By default, the device does not check the Router-Alert option.
4.     Enable insertion of the Router-Alert option into IGMP messages.
send-router-alert
By default, IGMP messages carry the Router-Alert option.
Configuring Router-Alert option handling methods on an interface
Step
Remarks
N/A
N/A
3.     Configure the interface to discard any IGMP message that does not carry the Router-Alert option.
igmp require-router-alert
igmp send-router-alert
On startup, the IGMP querier sends IGMP general queries at the startup query interval, which is one-quarter of the IGMP general query interval. The number of queries, or the startup query count, is user configurable.
After startup, the IGMP querier periodically sends IGMP general queries at the IGMP general query interval to check for multicast group members on the network. You can modify the IGMP general query interval based on actual condition of the network.
The IGMPv2 querier sends IGMP group-specific queries at the IGMP last-member query interval when it receives an IGMP leave message. The IGMPv3 querier sends IGMP group-and-source-specific queries at the IGMP last-member query interval when it receives a multicast group and multicast mapping change report. The number of queries, or the last-member query count, equals the robustness variable—the maximum number of packet retransmissions.
A multicast listening host starts a delay timer for each multicast group it has joined when it receives an IGMP query (general query, group-specific query, or group-and-source-specific query). The timer is initialized to a random value in the range of 0 to the maximum response delay advertised in the IGMP query. When the timer value decreases to 0, the host sends an IGMP report to the corresponding multicast group.
To speed up the response of hosts to IGMP queries and avoid simultaneous timer expirations causing IGMP report traffic bursts, you must correctly set the maximum response delay.
·     The maximum response delay for IGMP general queries is set by the max-response-time command.
·     The maximum response delay for IGMP group-specific queries and IGMP group-and-source-specific queries equals the IGMP last-member query interval.
When multiple multicast routers exist on the same subnet, the IGMP querier is responsible for sending IGMP queries. If a non-querier router receives no IGMP query from the querier when the other querier present interval expires, it considers that the querier as having failed and starts a new querier election. Otherwise, the non-querier router resets the other querier present timer.
·     To avoid frequent IGMP querier changes, set the other querier present interval greater than the IGMP general query interval.
·     To avoid incorrect multicast group member removals, set the IGMP general query interval greater than the maximum response time for IGMP general queries.
·     The configurations of the maximum response time for IGMP general queries, the IGMP last member query interval, and the IGMP other querier present interval take effect on only IGMPv2 and IGMPv3.
To configure IGMP query and response parameters globally:
Step
Remarks
N/A
N/A
3.     Configure the IGMP querier's robustness variable.
robust-count robust-value
2 by default.
A higher robustness variable makes the IGMP querier more robust, but results in longer multicast group timeout time.
4.     Configure the startup query interval.
startup-query-interval interval
By default, the startup query interval is one-quarter of the "IGMP general query interval."
5.     Configure the startup query count.
startup-query-count value
By default, the startup query count is the same as the IGMP querier's robustness variable.
6.     Configure the IGMP general query interval.
timer query interval
60 seconds by default.
7.     Configure the maximum response delay for IGMP general queries.
max-response-time interval
10 seconds by default.
8.     Configure the IGMP last-member query interval.
last-member-query-interval interval
1 second by default.
9.     Configure the other querier present interval.
timer other-querier-present interval
By default, the other querier present interval is [ IGMP general query interval ] × [ IGMP robustness variable ] + [ maximum response time for IGMP general queries ] / 2.
To configure IGMP query and response parameters on an interface:
Step
Remarks
N/A
N/A
igmp robust-count robust-value
2 by default.
igmp startup-query-interval interval
igmp startup-query-count value
igmp timer query interval
igmp max-response-time interval
8.     Configure the IGMP last member query interval.
igmp last-member-query-interval interval
igmp timer other-querier-present interval
In some applications, such as ADSL dial-up networking, only one multicast receiver host is attached to a port of the IGMP querier. To allow fast response to the leave messages of the host when it switches frequently from one multicast group to another, you can enable IGMP fast-leave processing on the IGMP querier.
With fast-leave processing enabled, after receiving an IGMP leave message from a host, the IGMP querier directly sends a leave notification to the upstream without sending IGMP group-specific queries or IGMP group-and-source-specific queries. Thus, the leave latency is reduced on one hand, and the network bandwidth is saved on the other hand.
·     The IGMP fast-leave processing configuration takes effect only if the switch is running IGMPv2 or IGMPv3.
·     The fast-leave command in IGMP view takes effect only on Layer 3 interfaces except VLAN interfaces.
·     To implement IGMP fast-leave on VLAN interfaces, use the igmp-snooping fast-leave command or fast-leave (IGMP-snooping view).
To configure IGMP fast-leave processing globally:
Step
Remarks
N/A
N/A
3.     Configure IGMP fast-leave processing.
fast-leave [ group-policy acl-number ]
To configure IGMP fast-leave processing on an interface:
Step
Remarks
N/A
N/A
igmp fast-leave [ group-policy acl-number ]
With the IGMP host tracking function, the switch can record the information of the member hosts that are receiving multicast traffic, including the host IP address, running duration, and timeout time. You can monitor and manage the member hosts according to the recorded information.
Enabling the IGMP host tracking function globally
Step
Remarks
N/A
N/A
3.     Enable the IGMP host tracking function globally.
host-tracking
Enabling the IGMP host tracking function on an interface
Step
Remarks
N/A
N/A
3.     Enable the IGMP host tracking function on the interface.
igmp host-tracking
Due to some possible restrictions, some receiver hosts on an SSM network might run IGMPv1 or IGMPv2. To provide SSM service support for these receiver hosts, configure the IGMP mapping feature on the last hop router.
Before you configure the IGMP SSM mapping feature, complete the following tasks:
Step
Remarks
N/A
N/A
3.     Enable the IGMP SSM mapping feature.
igmp ssm-mapping enable
IMPORTANT:
To make ensure SSM service can be provided for all hosts on a subnet regardless of the IGMP version running on the hosts, enable IGMPv3 on the interface that forwards multicast traffic onto the subnet.
By performing this configuration multiple times, you can map a multicast group to different multicast sources.
If IGMPv3 is enabled on a VLAN interface, and if a port in that VLAN is configured as a simulated host, the simulated host will send IGMPv3 reports even if you did not specify a multicast source when you configure simulated joining with the igmp-snooping host-join command. In this case, the corresponding multicast group will not be created based on the configured IGMP SSM mappings.
To configure an IGMP SSM mapping:
Step
Remarks
N/A
N/A
3.     Configure an IGMP SSM mapping.
ssm-mapping group-address { mask | mask-length } source-address
No IGMP mappings are configured by default.
Before you configure the IGMP proxying feature, complete the following tasks:
·     Enable IP multicast routing.
You can enable IGMP proxying on the interface in the direction toward the root of the multicast forwarding tree to make the device serve as an IGMP proxy.
·     Each device can have only one interface serving as the proxy interface. In scenarios with multiple instances, IGMP proxying is configured on only one interface per instance.
·     You cannot enable IGMP on an interface with IGMP proxying enabled. Moreover, only the igmp require-router-alert, igmp send-router-alert, and igmp version commands can take effect on such an interface.
·     You cannot enable other multicast routing protocols (such as PIM-DM or PIM-SM) on an interface with IGMP proxying enabled, or vice versa. However, the source-lifetime, source-policy, and ssm-policy commands configured in PIM view can still take effect. In addition, in IGMPv1, the designated router (DR) is elected by the working multicast routing protocol (such as PIM) to serve as the IGMP querier. Therefore, a downstream interface running IGMPv1 cannot be elected as the DR and thus cannot serve as the IGMP querier.
·     You cannot enable IGMP proxying on a VLAN interface with IGMP snooping enabled, or vice versa.
To enable IGMP proxying:
Step
Remarks
N/A
N/A
3.     Enable the IGMP proxying feature.
igmp proxying enable
CAUTION:
On a multi-access network with more than one IGMP proxy device, you cannot enable multicast forwarding on any other non-querier downstream interface after one of the downstream interfaces of these IGMP proxy devices has been elected as the querier. Otherwise, duplicate multicast flows might be received on the multi-access network.
Only queriers can forward multicast traffic but non-queriers have no multicast forwarding capabilities, to avoid duplicate multicast flows. It is the same on IGMP proxy devices. Only the downstream interfaces acting as a querier can forward multicast traffic to downstream hosts.
However, when a downstream interface of a proxy device fails to win the querier election, you must enable multicast forwarding on this interface.
To enable multicast forwarding on a downstream interface:
Step
Remarks
N/A
N/A
3.     Enable multicast forwarding on a non-querier downstream interface.
igmp proxying forwarding
Displaying and maintaining IGMP
CAUTION:
The reset igmp group commands might cause multicast data transmission failures.
To display and maintain IGMP:
Remarks
Display IGMP group information.
display igmp [ all-instance | vpn-instance vpn-instance-name ] group [ group-address | interface interface-type interface-number ] [ static | verbose ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Display the Layer 2 port information of IGMP groups (in standalone mode).
display igmp group port-info [ vlan vlan-id ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display the Layer 2 port information of IGMP groups (in IRF mode).
display igmp group port-info [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display information about the hosts tracked by IGMP on an interface.
display igmp host interface interface-type interface-number group group-address [ source source-address ] [ | { begin | exclude | include } regular-expression ]
Display information about the hosts tracked by IGMP on the Layer 2 ports (in standalone mode).
display igmp host port-info vlan vlan-id group group-address [ source source-address ] [ vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display information about the hosts tracked by IGMP on the Layer 2 ports (in IRF mode).
display igmp host port-info vlan vlan-id group group-address [ source source-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display IGMP configuration and operation information.
display igmp [ all-instance | vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display the information of IGMP proxying groups.
display igmp [ all-instance | vpn-instance vpn-instance-name ] proxying group [ group-address ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display information in the IGMP routing table.
display igmp [ all-instance | vpn-instance vpn-instance-name ] routing-table [ source-address [ mask { mask | mask-length } ] | group-address [ mask { mask | mask-length } ] | flags { act | suc } ] * [ | { begin | exclude | include } regular-expression ]
Display IGMP SSM mappings.
display igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group-address [ | { begin | exclude | include } regular-expression ]
Display the multicast group information created from IGMPv1 and IGMPv2 reports based on the configured IGMP SSM mappings.
display igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group [ group-address | interface interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
Display information about the hosts that join the group based on IGMP SSM mappings on an interface.
display igmp ssm-mapping host interface interface-type interface-number group group-address source source-address [ | { begin | exclude | include } regular-expression ]
Remove all the dynamic IGMP group entries of an IGMP group or all IGMP groups.
reset igmp [ all-instance | vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
Available in user view.
This command cannot remove static IGMP group entries.
Remove all the dynamic Layer 2 port entries of an IGMP group or all IGMP groups.
reset igmp group port-info { all | group-address } [ vlan vlan-id ]
This command cannot remove the static Layer 2 port entries of IGMP groups.
Clear IGMP SSM mappings.
reset igmp [ all-instance | vpn-instance vpn-instance-name ] ssm-mapping group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
IGMP configuration examples
IMPORTANT:
By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are in the state of DOWN. To configure such an interface, use the undo shutdown commands to bring it up first.
Basic IGMP functions configuration example
Network requirements
As shown in Figure 5, receivers receive VOD information through multicast. Receivers of different organizations form stub networks N1 and N2, and Host A and Host C are receivers in N1 and N2 respectively.
IGMPv2 runs between Switch A and N1. IGMPv2 runs between the other two switches and N2. Switch B acts as the IGMP querier in N2 because it has a lower IP address.
The hosts in N1 can join only multicast group 224.1.1.1, and the hosts in N2 can join any multicast groups.
Figure 5 Network diagram
1.     Configure the IP address and subnet mask of each interface as shown in Figure 5. (Details not shown.)
2.     Configure OSPF for interoperation on the PIM network to make sure that the network-layer is interoperable on the PIM network and routing information among the switches can be dynamically updated. (Details not shown.)
3.     Enable IP multicast routing, and enable PIM-DM and IGMP:
# Enable IP multicast routing on Switch A, enable PIM-DM on each interface, and enable IGMP on VLAN-interface 100.
[SwitchA] multicast routing-enable
[SwitchA-Vlan-interface100] igmp enable
[SwitchA-Vlan-interface100] pim dm
[SwitchA-Vlan-interface101] pim dm
# Enable IP multicast routing on Switch B, enable PIM-DM on each interface, and enable IGMP on VLAN-interface 200.
[SwitchB] multicast routing-enable
[SwitchB-Vlan-interface200] igmp enable
[SwitchB-Vlan-interface200] pim dm
[SwitchB] interface vlan-interface 201
[SwitchB-Vlan-interface201] pim dm
[SwitchB-Vlan-interface201] quit
# Enable IP multicast routing on Switch C, enable PIM-DM on each interface, and enable IGMP on VLAN-interface 200.
[SwitchC] multicast routing-enable
[SwitchC-Vlan-interface200] pim dm
[SwitchC] interface vlan-interface 202
[SwitchC-Vlan-interface202] pim dm
[SwitchC-Vlan-interface202] quit
4.     Configure a multicast group filter on Switch A, so that the hosts connected to VLAN-interface 100 can join only multicast group 224.1.1.1.
[SwitchA] acl number 2001
[SwitchA-acl-basic-2001] rule permit source 224.1.1.1 0
[SwitchA-acl-basic-2001] quit
[SwitchA-Vlan-interface100] igmp group-policy 2001
Use the display igmp interface command to view the IGMP configuration and operation status on each switch interface. For example:
# Display IGMP information on VLAN-interface 200 of Switch B.
[SwitchB] display igmp interface vlan-interface 200
 Vlan-interface200(10.110.2.1):
   IGMP is enabled
   Current IGMP version is 2
   Value of query interval for IGMP(in seconds): 60
   Value of other querier present interval for IGMP(in seconds): 125
   Value of maximum query response time for IGMP(in seconds): 10
   Querier for IGMP: 10.110.2.1 (this router)
  Total 1 IGMP Group reported
SSM mapping configuration example
As shown in Figure 6, the PIM-SM domain applies both the ASM model and SSM model for multicast delivery. Switch D's VLAN-interface 104 serves as the C-BSR and C-RP. The SSM group range is 232.1.1.0/24.
IGMPv3 runs on Switch D's VLAN-interface 400. The receiver host runs IGMPv2, and does not support IGMPv3. Therefore, the Receiver host cannot specify expected multicast sources in its membership reports.
Source 1, Source 2, and Source 3 send multicast packets to multicast groups in the SSM group range. You can configure the IGMP SSM mapping feature on Switch D so that the receiver host will receive multicast data from Source 1 and Source 3 only.
Figure 6 Network diagram
Device
IP address
Device
IP address
Source 1
133.133.1.1/24
Source 3
133.133.3.1/24
Source 2
133.133.2.1/24
Receiver
133.133.4.1/24
Switch A
Vlan-int100
133.133.1.2/24
Switch C
Vlan-int300
133.133.3.2/24
Switch A
Vlan-int101
192.168.1.1/24
Switch C
Vlan-int103
192.168.3.1/24
Switch A
Vlan-int104
192.168.4.2/24
Switch C
Vlan-int102
192.168.2.2/24
Switch B
Vlan-int200
133.133.2.2/24
Switch D
Vlan-int400
133.133.4.2/24
Switch B
Vlan-int101
192.168.1.2/24
Switch D
Vlan-int103
192.168.3.2/24
Switch B
Vlan-int102
192.168.2.1/24
Switch D
Vlan-int104
192.168.4.1/24
1.     Configure the IP address and subnet mask of each interface as shown in Figure 6. (Details not shown.)
2.     Configure OSPF on the switches to make sure the network-layer is interoperable on the PIM-SM domain and routing information among the switches can be dynamically updated. (Details not shown.)
3.     Enable IP multicast routing, enable PIM-SM on each interface, and enable IGMP and IGMP SSM mapping on the host-side interface:
# Enable IP multicast routing on Switch D, enable PIM-SM on each interface, and enable IGMPv3 and IGMP SSM mapping on VLAN-interface 400.
<SwitchD> system-view
[SwitchD] multicast routing-enable
[SwitchD-Vlan-interface400] igmp enable
[SwitchD-Vlan-interface400] igmp version 3
[SwitchD-Vlan-interface400] igmp ssm-mapping enable
[SwitchD-Vlan-interface400] pim sm
[SwitchD-Vlan-interface103] pim sm
[SwitchD] interface vlan-interface 104
[SwitchD-Vlan-interface104] pim sm
[SwitchD-Vlan-interface104] quit
# Enable IP multicast routing on Switch A, and enable PIM-SM on each interface.
[SwitchA] interface vlan-interface 104
[SwitchA-Vlan-interface104] pim sm
[SwitchA-Vlan-interface104] quit
# Enable IP multicast routing and PIM-SM on Switch B and Switch C in the same way. (Details not shown.)
4.     Configure C-BSR and C-RP interfaces on Switch D.
[SwitchD] pim
[SwitchD-pim] c-bsr vlan-interface 104
[SwitchD-pim] c-rp vlan-interface 104
[SwitchD-pim] quit
5.     Configure the SSM group range:
# Configure the SSM group range 232.1.1.0/24 on Switch D.
[SwitchD] acl number 2000
[SwitchD-acl-basic-2000] rule permit source 232.1.1.0 0.0.0.255
[SwitchD-acl-basic-2000] quit
[SwitchD] pim
[SwitchD-pim] ssm-policy 2000
[SwitchD-pim] quit
# Configure the SSM group range on Switch A, Switch B and Switch C in the same way. (Details not shown.)
6.     Configure IGMP SSM mappings on Switch D.
[SwitchD] igmp
[SwitchD-igmp] ssm-mapping 232.1.1.0 24 133.133.1.1
[SwitchD-igmp] ssm-mapping 232.1.1.0 24 133.133.3.1
[SwitchD-igmp] quit
# Display the IGMP SSM mapping information for multicast group 232.1.1.1 on Switch D.
[SwitchD] display igmp ssm-mapping 232.1.1.1
Vpn-Instance: public net
Group: 232.1.1.1
Source list:
             133.133.1.1
             133.133.3.1
# Display the IGMP group information created based on the IGMP SSM mappings on Switch D.
[SwitchD] display igmp ssm-mapping group
Total 1 IGMP SSM-mapping Group(s).
Interface group report information of VPN-Instance: public net
 Vlan-interface400(133.133.4.2):
  Total 1 IGMP SSM-mapping Group reported
   Group Address       Last Reporter   Uptime      Expires
   232.1.1.1           133.133.4.1     00:02:04    off
# Display PIM routing table information on Switch D.
[SwitchD] display pim routing-table
Vpn-instance: public net
Total 0 (*, G) entry; 2 (S, G) entry
 (133.133.1.1, 232.1.1.1)
     Protocol: pim-ssm, Flag:
     UpTime: 00:13:25
     Upstream interface: Vlan-interface104
         Upstream neighbor: 192.168.4.2
         RPF prime neighbor: 192.168.4.2
         1: Vlan-interface400
                 Protocol: igmp, UpTime: 00:13:25, Expires: -
 (133.133.3.1, 232.1.1.1)
     UpTime: 00:13:25
         Upstream neighbor: 192.168.3.1
         RPF prime neighbor: 192.168.3.1
IGMP proxying configuration example
As shown in Figure 7, PIM-DM runs on the core network. Host A and Host C in the stub network receive VOD information destined to multicast group 224.1.1.1.
Configure the IGMP proxying feature on Switch B so that Switch B can maintain group memberships and forward multicast traffic without running PIM-DM.
Figure 7 Network diagram
1.     Configure the IP address and subnet mask of each interface as shown in Figure 7. (Details not shown.)
2.     Enable IP multicast routing, PIM-DM, IGMP, and IGMP proxying:
# Enable IP multicast routing on Switch A, PIM-DM on VLAN-interface 101, and IGMP on VLAN-interface 100.
# Enable IP multicast routing on Switch B, IGMP proxying on VLAN-interface 100, and IGMP on VLAN-interface 200.
[SwitchB-Vlan-interface100] igmp proxying enable
# Display IGMP configuration information on VLAN-interface 100 of Switch B.
[SwitchB] display igmp interface vlan-interface 100 verbose
 Vlan-interface100(192.168.1.2):
   IGMP proxy is enabled
   Multicast routing on this interface: enabled
   Require-router-alert: disabled
   Version1-querier-present-timer-expiry: 00:00:20
# Display IGMP group information on Switch A.
[SwitchA] display igmp group
Total 1 IGMP Group(s).
 Vlan-interface100(192.168.1.1):
  Total 1 IGMP Groups reported
   224.1.1.1       192.168.1.2     00:02:04    00:01:15
The output shows that IGMP reports from the hosts are forwarded to Switch A through the proxy interface, VLAN-interface 100 on Switch B.
Troubleshooting IGMP
No membership information on the receiver-side switch
Symptom
When a host sends a report for joining multicast group G, no membership information of the multicast group G exists on the switch closest to that host.
Analysis
·     The correctness of networking and interface connections and whether the protocol layer of the interface is up directly affect the generation of group membership information.
·     Multicast routing must be enabled on the switch, and IGMP must be enabled on the interface connecting to the host.
·     If the IGMP version on the router port is lower than that on the host, the switch will not be able to recognize the IGMP report from the host.
·     If the igmp group-policy command has been configured on the interface, the interface cannot receive report messages that fail to pass filtering.
Solution
1.     Check that the networking, interface connection, and IP address configuration are correct. Check the interface information with the display igmp interface command. If no information is output, the interface is in an abnormal state. This is usually because you have configured the shutdown command on the interface, the interface is not correctly connected, or the IP address configuration is not correctly done.
2.     Use the display current-configuration command to verify that the multicast routing-enable command has been executed. If not, use the multicast routing-enable command in system view to enable IP multicast routing. In addition, check that IGMP is enabled on the corresponding interfaces.
3.     Use the display igmp interface command to verify that the version of IGMP on the interface is lower than that on the host.
4.     Use the display current-configuration interface command to verify that the igmp group-policy command has been executed. If the host is restricted from joining the multicast group G, the ACL rule must be modified to allow receiving the reports for the multicast group G.
Inconsistent memberships on switches on the same subnet
Symptom
Different memberships are maintained on different IGMP-enabled switches on the same subnet.
Analysis
·     A switch that is running IGMP maintains multiple parameters for each interface, and these parameters influence one another, forming very complicated relationships. Inconsistent IGMP interface parameter configurations for switches on the same subnet will surely result in inconsistency of memberships.
·     In addition, although an IGMP-enabled switch is compatible with a host that is running a different IGMP version, all switches on the same subnet must run the same version of IGMP. Inconsistent IGMP versions running on switches on the same subnet also leads to inconsistency of IGMP memberships.
Solution
1.     Use the display current-configuration command to verify the IGMP configuration on the interfaces.
2.     Use the display igmp interface command on all switches on the same subnet to verify the IGMP-related timer settings. Make sure that the settings are consistent on all the switches.
3.     Use the display igmp interface command to verify that all switches on the same subnet are running the same version of IGMP.
