06-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18206-Layer 3 - IP Services Command Reference
02-IP Addressing Commands
02-IP Addressing Commands 76.47 KB
IP addressing configuration commands
display ip interface
display ip interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip interface to display IP configuration information for the specified Layer 3 interface or all Layer 3 interfaces.
# Display IP configuration information for VLAN-interface 1.
<Sysname> display ip interface vlan-interface 1
Vlan-interface1 current state :DOWN
Line protocol current state :DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
ARP packet input number:           0
  Request packet:                  0
  Reply packet:                    0
  Unknown packet:                  0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
# Display IP configuration information for the network management interface.
<Sysname>display ip interface M-Ethernet 0/0/0
M-Ethernet0/0/0 current state :DOWN
current state
Current physical state of the interface:
·     Administrative DOWN—The interface is shut down by the shutdown command.
·     DOWNThe interface is administratively up but its physical state is down, which might be caused by a connection or link failure.
·     UPBoth the administrative and physical states of the interface are up.
Current state of the link layer protocol:
·     DOWNThe protocol state of the interface is down.
·     UPThe protocol state of the interface is up.
·     UP (spoofing)The protocol state of the interface pretends to be up. However, no corresponding link is present, or the corresponding link is not present permanently but is established as needed.
Internet Address
IP address of an interface followed by:
·     Primary—Identifies a primary IP address.
·     Sub—Identifies a secondary IP address.
·     negotiated—Identifies a PPP negotiated IP address.
·     unnumbered—Identifies an unnumbered IP address.
·     acquired via DHCP—Identifies an IP address obtained through DHCP.
·     acquired via BOOTP—Identifies an IP address obtained through BOOTP.
·     Cluster—Identifies a cluster IP address.
·     Mad—Identifies a MAD IP address.
Broadcast address
Broadcast address of the subnet attached to an interface.
Maximum transmission units on an interface, in bytes.
input packets, bytes, multicasts
output packets, bytes, multicasts
Unicast packets, bytes, and multicast packets received on an interface (the statistics start at the switch startup).
  Request packet
  Reply packet
  Unknown packet
Total number of ARP packets received on an interface (the statistics start at the switch startup):
·     ARP request packets.
·     ARP reply packets.
·     Unknown packets.
Number of TTL-invalid packets received on an interface (the statistics start at the switch startup).
  Echo reply
  Unreachable
  Source quench
  Routing redirect
  Echo request
  Router advert
  Router solicit
  Time exceed
  IP header bad
  Timestamp request
  Timestamp reply
  Information request
  Information reply
  Netmask request
  Netmask reply
  Unknown type
Total number of ICMP packets received on an interface (the statistics start at the switch startup):
·     Echo reply packets.
·     Unreachable packets.
·     Source quench packets.
·     Routing redirect packets.
·     Echo request packets.
·     Router advertisement packets.
·     Router solicitation packets.
·     Time exceeded packets.
·     IP header bad packets.
·     Timestamp request packets.
·     Timestamp reply packets.
·     Information request packets.
·     Information reply packets.
·     Netmask request packets.
·     Netmask reply packets.
·     Unknown type packets.
display ip interface brief
display ip interface [ interface-type [ interface-number ] ] brief [ description ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays a maximum of 23 characters for each interface description. If the description is longer than 23 characters, the first 20 characters are displayed, followed by an ellipsis (...).
Use display ip interface brief to display brief IP configuration information for the specified Layer 3 interface or all Layer 3 interfaces.
If you do not specify the interface type and interface number, this command displays brief IP configuration information for all Layer 3 interfaces.
If you specify only the interface type, this command displays brief IP configuration information for all Layer 3 interfaces of the specified type.
If you specify both the interface type and interface number, this command displays only brief IP configuration information for the specified interface.
Related commands: display ip interface.
# Display brief IP configuration information for VLAN interfaces.
<Sysname> display ip interface vlan-interface brief
(s): spoofing  (l): loopback
Interface              Physical Protocol IP Address      Description
Vlan1                  up       up       6.6.6.6         --
Vlan2                  up       up       7.7.7.7         ABCDEFGHIJKLMNOPQRST...
# Display brief IP configuration information for VLAN interfaces and complete interface descriptions.
<Sysname> display ip interface vlan-interface brief description
Vlan2                  up       up       7.7.7.7         ABCDEFGHIJKLMNOPQRSTUVW
XYZ
(s): spoofing
Spoofing attribute of the interface. It indicates that an interface might have no link present even when its link layer protocol is displayed up or the link is set up only on demand.
(l): loopback
Link loopback test that PPP and HDLC support.
Interface name.
Physical
Physical state of interface:
·     *downThe interface is administratively down. The interface is shut down by the shutdown command.
·     downThe interface is administratively up but its physical state is down, which might be caused by a connection or link failure.
·     upBoth the administrative and physical states of the interface are up.
Protocol
Link layer protocol state:
·     downThe link layer protocol state of the interface is down.
·     upThe link layer protocol state of the interface is up.
·     up(s)The protocol state of the interface is up (spoofing).
·     up(l)The protocol state of the interface is up (loopback).
·     down(l)The protocol state of the interface is down (loopback).
IP Address
IP address of interface. If no IP address is configured, two hyphens (--) are displayed.
Interface description information. If no description is configured, two hyphens (--) are displayed.
ip address
undo ip address [ ip-address { mask-length | mask } [ sub ] ]
View
Interface view
Default level
2: System level
ip-address: IP address of interface, in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask.
mask: Subnet mask in dotted decimal notation.
sub: Secondary IP address for the interface.
Use ip address to assign an IP address and mask to the interface.
Use undo ip address to remove all IP addresses from the interface.
Use the undo ip address ip-address { mask | mask-length } command to remove the primary IP address.
Use the undo ip address ip-address { mask | mask-length } sub command to remove a secondary IP address.
By default, no IP address is assigned to any interface.
When assigning IP addresses to an interface:
·     You can assign only one primary IP address to an interface.
·     The primary and secondary IP addresses can be located in the same network segment.
·     Before removing the primary IP address, remove all secondary IP addresses.
·     An interface can have up to 128 IP addresses configured, in which, one is the primary IP address, and all others are secondary IP addresses.
·     Do not assign a secondary IP address to an interface that is configured to obtain an IP address through PPP negotiation.
# Assign VLAN-interface 1 a primary IP address 129.12.0.1 and a secondary IP address 202.38.160.1, with subnet masks 255.255.255.0.
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
