06-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18206-Layer 3 - IP Services Command Reference
07-Adjacency Table Commands
07-Adjacency Table Commands 62.8 KB
Adjacency table configuration commands
The adjacency table feature only applies to hardware forwarding, but not software forwarding.
The adjacency table feature does not apply to Ethernet networks that use ARP for storing and managing neighbor information.
You can only view adjacency tables of tunnel interfaces and POS interfaces. For more information about tunnel interfaces, see Layer 3—IP Services Configuration Guide. For more information about POS interfaces, see Interface Configuration Guide.
display adjacent-table
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-id } [ count | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all IPv4 adjacency table entries.
physical-interface interface-type interface-number: Displays IPv4 adjacency table entry information for the specified physical interface.
routing-interface interface-type interface-number: Displays IPv4 adjacency table entry information for the specified routing interface.
slot slot-id: Displays IPv4 adjacency table entry information for the specified slot.
count: Displays the number of IPv4 adjacency table entries.
verbose: Displays detailed IPv4 adjacency table entry information.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display adjacent-table to display IPv4 adjacency table entries.
# Display detailed information about all IPv4 adjacency table entries.
<Sysname> display adjacent-table all verbose
 IP Address                  : 1.1.1.1
 Routing Interface           : Pos2/1/3
 Physical Interface          : Pos2/1/3
 Logical Interface           : N/A
 Service Type                : PPP
 Action Type                 : FORWARDING
 Link Media Type             : P2P
 Slot                        : 2
 Virtual Circuit Information : N/A
 Link Head Information(IP)   : ff030021
 Link Head Information(MPLS) : ff030281
# Display the IPv4 adjacency table entries in slot 2.
<Sysname> display adjacent-table slot 2
IP Address       Routing Interface     Physical Interface    Type     Slot
1.1.1.1          Pos2/1/3               Pos2/1/3             PPP      2
# Display the number of IPv4 adjacency table entries of slot 2.
<Sysname> display adjacent-table slot 2 count
 Total ADJ entries on slot 2 : 1
IP Address
Next hop IP address.
Routing Interface
Adjacency table routing interface, namely, output interface in the route forwarding entry.
Physical Interface
Adjacency table physical interface.
Logical Interface
Adjacency table logical interface: An abstract interface that does not correspond to any physical entity and is used for adjacency table implementation.
Service Type
Adjacency table service type.
Action Type
Action to take on the packet that matches the entry, forward or drop.
Link Media Type
Link media type, which is related to the link layer protocol used by the output interface. P2P indicates point-to-point, such as PPP.
Slot
Slot number of the physical device, such as PVC and DLCI.
Virtual circuit information for the adjacency table entry.
Information about the link layer header corresponding to the IPv4 protocol.
Information about the link layer header corresponding to the MPLS protocol.
display ipv6 adjacent-table
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-id } [ count | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all IPv6 adjacency table entries.
physical-interface interface-type interface-number: Displays IPv6 adjacency table entry information for the specified physical interface.
routing-interface interface-type interface-number: Displays IPv6 adjacency table entry information for the specified routing interface.
slot slot-id: Displays IPv6 adjacency table entries about the specified slot.
count: Displays the number of IPv6 adjacency table entries.
verbose: Displays detailed IPv6 adjacency table entry information.
Use display ipv6 adjacent-table to display IPv6 adjacency table entries.
# Display detailed information about all IPv6 adjacency table entries.
<Sysname> display ipv6 adjacent-table all verbose
 IPv6 Address                : N/A
 Routing Interface           : Pos2/1/4
 Physical Interface          : Pos2/1/4
 Service Type                : PPP
 Slot                        : 0
 Link Head Information(IPv6) : ff030057
Time Stamp                  : 141225
# Display the IPv6 adjacency table entries in slot 2.
<Sysname> display ipv6 adjacent-table slot 2
IPv6 Address        Routing Interface    Physical Interface    Type  Slot
N/A                 Pos2/1/4               Pos2/1/4             PPP   1
# Display the number of IPv6 adjacency table entries in slot 2.
<Sysname> display ipv6 adjacent-table slot 2 count
 Total IPv6 ADJ entries : 1
IPv6 Address
Next hop IPv6 address.
Routing Interface
Physical Interface
Logical Interface
Adjacency table logical interface: An abstract interface that does not correspond to any physical entity and is used for adjacent table implementation.
Service Type
Adjacency table service type, such as PPP.
Action Type
Link Media Type
Slot
Slot number of the physical device.
Information about the link layer header corresponding to the IPv6 protocol.
