06-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18206-Layer 3 - IP Services Command Reference
05-NAT Commands
05-NAT Commands 235.22 KB
You cannot configure NAT after you configure local PBR or interface PBR. For more information about PBR, see Layer 3—IP Routing Configuration Guide.
connection-limit default action
connection-limit default action { deny | permit }
undo connection-limit default action [ permit ]
View
Connection limit policy view
Default level
2: System level
deny: Disables the connection limit function.
permit: Enables the connection limit function.
Use connection-limit default action to specify the default connection limit action, for user connections not specified in the connection limit policy.
Use undo connection-limit default action to restore the default.
By default, connection limit is not enabled.
# Configure the default connection limit action as permit.
[Sysname] connection-limit policy 1
[Sysname-connection-limit-policy-1] connection-limit default action permit
connection-limit default amount
connection-limit default amount upper-limit max-amount lower-limit min-amount
undo connection-limit default amount [ upper-limit max-amount lower-limit min-amount ]
View
Default level
2: System level
upper-limit max-amount: Specifies the upper connection limit in the range of 1 to 4294967295.
lower-limit min-amount: Specifies the lower connection limit in the range of 1 to 4294967294. min-amount must be less than max-amount.
Use connection-limit default amount to set default connection limit parameters.
Use undo connection-limit default amount to restore the default.
By default, the upper connection limit is 512, and lower connection limit is 256.
# Set the default upper connection limit to 200 and the lower connection limit to 50.
[Sysname-connection-limit-policy-1] connection-limit default amount upper-limit 200 lower-limit 50
connection-limit policy policy-number
undo connection-limit policy { policy-number | all }
View
Default level
2: System level
policy-number: Connection limit policy number in the range of 0 to 19.
all: Specifies all connection limit policies.
Use connection-limit policy to create a connection limit policy and enter connection limit policy view.
Use undo connection-limit policy to delete the specified or all connection limit policies.
A connection limit policy contains a set of limit rules that are defined to limit specified connections. By default, the policy adopts default connection limit parameters.
When creating a connection limit policy, you need to assign it a number that uniquely identifies that policy. Polices are matched by number in descending order.
If a connection limit policy is bound to a NAT module, it is not allowed to modify existing limit rules in the policy, but you can add or remove limit rules.
If a connection limit policy is applied in system view, it is not allowed to modify, add, or remove existing limit rules in the policy.
# Create a connection limit policy numbered 1 and enter its view.
display connection-limit policy
display connection-limit policy { policy-number | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-number: Number of a connection limit policy.
all: Displays all connection limit policies.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display connection-limit policy to display a specific or all connection-limit policies.
# Display all connection limit policies configured.
<Sysname> display connection-limit policy all
 There is 1 policy:
  Connection-limit policy 1, refcount 0 ,3 limits
  limit 1 acl 2000 per-source amount 1111 10
  limit 2 acl 2001 per-destination amount 300 20
  limit 3 acl 2002 per-service amount 400 50
 There are 2 policies:
Connection-limit policy 0, refcount 1, 2 limits
  limit 0 source any amount dns 100 http 200 tcp 300 other 400 rate 100 shared
  limit 1 source 1.1.1.0 24 amount tcp 100 bandwidth 200 shared
 Connection-limit policy 1, refcount 0, 1 limit
  limit 4500 source 2.2.0.0 16 amount dns 200
Number of the connection limit policy.
Number of times that a policy is referenced and number of rules included in a policy.
limit
Number of rules in the policy. For more information, see the limit command in connection limit policy view.
display connection-limit statistics
display connection-limit statistics [ source src-address { mask-length | mask } ] [ destination dst-address { mask-length | mask } ] [ destination-port { eq | gt | lt | neq | range } port-number ] [ vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source src-address: Displays the connection limit statistics for the specified source address.
destination dst-address: Displays the connection limit statistics for the specified destination address.
mask-length: Mask length in the range of 1 to 32.
mask: Network mask.
destination-port: Displays connection limit statistics based on the destination port number.
{ eq | gt | lt | neq | range }: Specifies the ports in different ways through different keywords.
·     eq: Equal to the specified port number.
·     gt: Greater than the specified port number.
·     lt: Less than the specified port number.
·     neq: Not equal to the specified port number.
·     range: Specifies a port range.
port-number: Port number in the range of 0 to 65535. When the range keyword is specified, you need to specify the start-port and end-port. The start-port must be not greater than the end-port.
vpn-instance vpn-instance-name: Specifies the MPLS VPN to which a user belongs. vpn-instance-name is a case-sensitive character string of 1 to 31 characters. If you do not specify this option, this command displays the connection statistics of users on the public network.
Use display connection-limit statistics to display connection limit statistics.
# Display connection limit statistics.
<Sysname> display connection-limit statistics
      source-ip       dest-ip         dest-port       vpn-instance
      192.168.0.210   ---             ---             ---
 NAT       amount         upper-limit    lower-limit    limit-flag
           2              200            100            0
source-ip
Source IP address. Three hyphens (---) are displayed if no such information is available.
dest-ip
Destination IP address. Three hyphens (---) are displayed if no such information is available.
dest-port
Destination port number. Three hyphens (---) are displayed if no such information is available.
vpn-instance
Name of the MPLS VPN instance that a connection belongs to. Three hyphens (---)are displayed if the connection does not belong to any MPLS VPN instance.
amount
Number of connections allowed to be established.
upper-limit
Upper limit of connections.
lower-limit
Lower limit of connections.
limit-flag
Whether new connections are allowed:
·     0—Allows establishing new connections.
·     1—Does not allow establishing new connections.
display connection-limit statistics vpn-instance
display connection-limit statistic [ vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Specifies the MPLS VPN that a user belongs to. vpn-instance-name is a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays the connection limit statistics of all VPNs and non VPNs.
Use display connection-limit statistics vpn-instance to display connection limit statistics of the specified VPN.
# Display connection limit statistics of vpn 1.
<Sysname> display connection-limit statistics vpn-instance vpn1
VPN-instance                       Amount
vpn1                               500
VPN-instance
MPLS VPN instance name. Public indicates a public network user.
Amount
Connection limit statistics.
display nat address-group
display nat address-group [ group-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-number: NAT address group number in the range of 0 to 31. If you do not specify this argument, this command displays information about all NAT address pools.
Use display nat address-group to display the NAT address pool information.
Related commands: nat address-group.
# Display the NAT address pool information.
<Sysname> display nat address-group
NAT address-group information:
  There are currently 2 nat address-group(s)
  1     : from         202.110.10.10     to 202.110.10.15
  2     : from         202.110.10.20     to 202.110.10.25
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
The range of IP addresses in address pool 1 is from 202.110.10.10 to 202.110.10.15.
display nat aging-time
display nat aging-time [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat aging-time to display the NAT aging time settings for various protocols.
Related commands: nat aging-time.
# Display the NAT aging time settings for various protocols.
<Sysname> display nat aging-time
NAT aging-time value information:
       tcp ---- aging-time value is  86400 (seconds)
       udp ---- aging-time value is    300 (seconds)
      icmp ---- aging-time value is     60 (seconds)
      pptp ---- aging-time value is  86400 (seconds)
       dns ---- aging-time value is     60 (seconds)
   tcp-fin ---- aging-time value is     60 (seconds)
   tcp-syn ---- aging-time value is     60 (seconds)
  ftp-ctrl ---- aging-time value is   7200 (seconds)
  ftp-data ---- aging-time value is    300 (seconds)
    no-pat ---- aging-time value is    240 (seconds)
Table 5 Command output
tcp
NAT aging time for TCP.
udp
NAT aging time for UDP.
icmp
NAT aging time for ICMP.
pptp
NAT aging time for PPTP.
dns
NAT aging time for DNS.
tcp-fin
NAT aging time for TCP FIN and RST connections.
tcp-syn
NAT aging time for TCP SYN connection.
ftp-ctrl
NAT aging time for FTP control link.
ftp-data
NAT aging time for FTP data link.
no-pat
NAT aging time in NO-PAT mode.
display nat all
display nat all [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat all to display all NAT configuration information.
# Display all NAT configuration information.
<Sysname> display nat all
  There are currently 1 nat address-group(s)
NAT bound information:
  There are currently 1 nat bound rule(s)
  Interface: vlan-interface20
    Direction: outbound  ACL: 2009  Address-group: 1    NO-PAT: N
NAT server in private network information:
  There are currently 1 internal server(s)
  Interface: vlan-interface11, Protocol: 6(tcp)
    Global:         5.5.5.5 : 80(www)
    Local :       192.1.1.1 : 80(www)
NAT static information:
  There are currently 1 NAT static configuration(s)
  single static:
    Local-IP        : 1.1.1.1
    Global-IP       : 2.2.2.2
    Local-VPN       : ---
NAT static enabled information:
  Interface                                      Direction
  vlan-interface14                                    out-static
NAT log information:
  log enable  :  enable
  flow-begin  :  enable
  flow-active :  40(minutes)
  Interface: Vlan-interface15
    Direction: outbound  ACL: 2036  Address-group: ---  NO-PAT: N
    VPN-instance: ---
    Out-interface: ---
Next-hop: ---
  Interface: Vlan-interface10, Protocol: 6(tcp)
    Global:        50.1.1.1 : 23(telnet)
    Local :   192.168.10.15 : 23(telnet)
  single static:
    Local-IP        : 20.0.0.100
    Global-IP       : 10.0.0.100
    Local-VPN       :
  Interface                                      Direction
  Vlan-interface12                                out-static
Table 6 Command output
For description on the specific fields, see the display nat address-group command.
Configuration information about internal address-to-external address translation. For description on the specific fields, see the display nat bound command.
Internal server information. For description on the specific fields, see the display nat server command.
Information about static NAT. For description on the specific fields, see the display nat static command.
Information about static NAT entries and interfaces with static NAT enabled. For description on the specific fields, see the display nat static command.
NAT aging time information. For description on the specific fields, see the display nat aging-time command.
NAT log information
NAT logging configuration information. For description on the specific fields, see the display nat log command.
display nat bound
display nat bound [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat bound to display NAT configuration information.
Related commands: nat outbound.
# Display NAT configuration information.
<Sysname> display nat bound
  There are currently 2 nat bound rule(s)
  Interface:Vlan-interface10
    Direction: outbound  ACL: 2000  Address-group: 319  NO-PAT: Y
    VPN-instance: vpn1
    Out-interface: ---
    Next-hop: 100.100.100.1
  Interface:Vlan-interface20
    Direction: outbound  ACL: 2001  Address-group: ---  NO-PAT: N
    VPN-instance: ---
    Out-interface: ---
    Next-hop: ---
Table 7 Command output
Display configured NAT address translation information.
Interface associated with a NAT address pool.
Direction
Address translation direction: inbound or outbound.
ACL
ACL number.
Address-group
Address group number. The field is displayed as null in Easy IP mode.
NO-PAT
Support for NO-PAT mode or not.
VPN-instance
VPN instance name of the private network where the NAT address pool belongs. The field displays three hyphens (---) if it is not configured.
Output-interface
The specified outbound interface. The field displays three hyphens (---) if it is not configured.
Next-hop
The specified next hop address. The field displays three hyphens (---) if it is not configured.
display nat connection-limit
display nat connection-limit [ source src-address { mask-length | mask } ] [ destination dst-address { mask-length | mask } ] [ destination-port { eq | gt | lt | neq | range } port-number ] [ vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
source src-address: Displays the connection limit statistics of the specified source address.
destination dst-address: Displays the connection limit statistics of the specified destination address.
mask: Network mask.
mask-length: The length of net mask, in the range of 1 to 32.
vpn-instance vpn-instance-name: Specifies the MPLS VPN that a user belongs to. The vpn-instance-name argument is a string of 1 to 31 characters. If you do not specify this option, this command displays the connection statistics of users on the public network.
Use display nat connection-limit to display NAT connection limit statistics.
# Display NAT connection limit statistics.
<Sysname> display nat connection-limit
           2              50             20             0
Table 8 Command output
source-ip
Source IP address of the connection. Three hyphens (---) are displayed if no source IP address is available.
dest-ip
Destination IP address of the connection. Three hyphens (---) are displayed if no destination IP address is available.
dest-port
Destination port of the connection. Three hyphens (---) are displayed if no destination port is available.
vpn-instance
MPLS VPN instance that a connection belongs to. Three hyphens (---) are displayed if the connection does not belong to any MPLS VPN instance.
NAT
Indicates that the connection is created through NAT.
amount
Number of active connections.
upper-limit
lower-limit
limit-flag
Whether new connections are allowed to establish:
·     1Does not allow establishing new connections.
display nat dns-map
display nat dns-map [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat dns-map to display NAT DNS mapping configuration information.
Related commands: nat dns-map.
# Display NAT DNS mapping configuration information.
<Sysname> display nat dns-map
NAT DNS mapping information:
  There are currently 2 NAT DNS mapping(s)
  Domain-name: www.server.com
  Global-IP  : 202.113.16.117
  Global-port: 80(www)
  Protocol   : 6(tcp)
  Domain-name: ftp.server.com
  Global-IP  : 202.113.16.100
  Global-port: 21(ftp)
  Protocol   : 6(tcp)
Table 9 Command output
Domain-name
Domain name of the internal server.
Global-IP
Public IP address of the internal server.
Global-port
Public port number of the internal server.
Protocol
Protocol type of the internal server.
display nat log
display nat log [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat log to display NAT logging configuration information.
Related commands: nat log enable, nat log flow-active, and nat log flow-begin.
# Display NAT logging configuration information.
<Sysname> display nat log
  log enable  :  enable acl 2000
  flow-begin  :  enable
  flow-active :  10(minutes)
Table 10 Command output
Logging data flows matching ACL 2000.
flow-begin  :  enable
Logging newly established sessions.
flow-active :  10 (minutes)
Interval in logging active flows (10 minutes).
display nat server
display nat server [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat server to display information about internal servers.
Related commands: nat server.
# Display information about internal servers.
<Sysname> display nat server
  There are currently 2 internal server(s)
    Global: 100.100.120.120 : 21(ftp)
    Local : 192.168.100.100 : 21(ftp)
  Interface: Vlan-interface11, Protocol: 6(tcp)
    Global: 100.100.100.121 : 80(www)
    Local : 192.168.100.101 : 80(www)            vpn2
Table 11 Command output
Server in private network information
Information about internal servers.
Internal server interface.
Protocol
Protocol type.
Global
Public IP address and port number of a server, and the name of the VPN that the public address belongs to.
Local
Private IP address and port number of a server, and the name of the VPN that the private IP address belongs to.
display nat session
In standalone mode:
display nat session [ vpn-instance vpn-instance-name ] slot slot-number [ source { global global-address | inside inside-address } ] [ destination dst-address ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display nat session [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number [ source { global global-address | inside inside-address } ] [ destination dst-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays NAT entries for the specified MPLS L3VPN. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays NAT entries of the public network.
slot slot-number: Specifies a card by its slot number. Use this option when your switch is operating in standalone (the default) mode (only supported on the main control board).
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode.
source global global-address: Displays NAT entries for the specified external source IP address.
source inside inside-address: Displays NAT entries for the specified internal source IP address.
destination dst-address: Displays NAT entries for the specified destination IP address.
Use display nat session to display dynamic NAT entries.
# Display dynamic NAT entries.
<Sysname> display nat session slot 2
There are currently 1 NAT session:
Protocol      GlobalAddr  Port      InsideAddr  Port        DestAddr  Port
     TCP   162.105.26.51 12288      200.0.0.28   512  162.105.26.246   512
     status:11      TTL:00:00:10   Left:00:00:02   VPN:vpn1
Table 12 Command output
Protocol
Protocol type.
GlobalAddr  Port
External IP address and port number after translation.
InsideAddr  Port
Internal IP address and port number before translation.
DestAddr  Port
Destination IP address and port number.
VPN
Name of the MPLS L3VPN instance to which NAT entries belong.
status
Status of NAT entries.
TTL
Lifetime of NAT entries, in the format of hh:mm:ss.
Left
Remaining lifetime of NAT entries, in the format of hh:mm:ss.
display nat static
display nat static [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display nat static to display static NAT entries and interfaces with static NAT enabled.
Related commands: nat static and nat outbound static.
# Display static NAT entries and interfaces with static NAT enabled.
<Sysname> display nat static
  single static:
    Local-VPN       : ---
  Interface                                      Direction
  Vlan-interface10                               out-static
Table 13 Command output
Configuration information about static NAT.
single static
One-to-one static NAT.
Local-IP
Private IP address.
Global-IP
Public IP address.
Local-VPN
Information about static NAT enabled on the interfaces.
Interface on which static NAT is configured.
Direction
Direction of packets to be translated.
display userlog export
In standalone mode:
display userlog export slot slot-number [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display userlog export chassis chassis-number slot slot-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot-number: Specifies a card by its slot number. Use this argument when your switch is operating in standalone (the default) mode (only supported on the main control board).
Use display userlog export to display information about NAT logs output to the log server.
Related commands: reset userlog nat export
# Display the configuration and statistics of the NAT logs for the card in Slot 2.
<Sysname> display userlog export slot 2
nat:
   Export Version 1 logs to log server : enabled
   Source address of exported logs   : 5.5.5.6
   Address of log server             : 1.1.1.2 (port: 2000)
   Total Logs/UDP packets exported   : 137/85
   VPN-instance                      : test
   Logs in buffer                    : 0
# Display the configuration and statistics of the NAT logs for the card in Slot 1.
<Sysname> display userlog export slot 1
nat:
   No userlog export is enabled
Table 14 Command output
nat
NAT log information.
NAT logs of version 1 are exported to the log server.
Export logs to (port:)
IP address and port number of the log server.
Source address of exported NAT logs. (If no source IP address is configured, this field is not displayed.)
Log server address, including the IP address and port number.
Total number of the logs sent and that of the UDP packets carrying NAT logs. (The term "UDP packets" refers to the UDP packets carrying NAT logs. A UDP packet can carry multiple pieces of NAT logs.)
VPN-instance
VPN where the log server resides.
Logs in buffer
Total number of flow or NAT logs buffered.
NAT log function is not enabled, or enabled but without exporting to the information center, or enabled to be exported to the log server, but without configuring the IP address and UDP port number of the corresponding log server.
limit acl
limit limit-id acl acl-number [ { per-destination | per-service | per-source } * amount max-amount min-amount ]
undo limit limit-id [ { per-destination | per-service | per-source } * amount max-amount min-amount ]
View
Default level
2: System level
limit-id: Number for a rule in the connection limit policy, in the range of 0 to 255.
acl-number: ACL number in the range of 2000 to 3999. User connections matching this ACL are to be limited.
per-destination: Limits connections by destination address.
per-service: Limits connections by service type.
per-source: Limits connections by source address.
amount: Limits the number of connections.
max-amount: Upper limit of connections, in the range of 1 to 4294967295.
min-amount: Lower limit of connections, in the range of 1 to 4294967294. min-amount must be less than max-amount.
Use limit acl to configure an ACL based connection limit rule.
Use undo limit to remove a connection limit rule.
If no limit type is specified, the command limits connections by source address using the default connection limit parameters (upper and lower limits) configured with the connection-limit default amount command.
If you specify multiple limit types in one limit rule, they work together to limit and count user connections. For example, with both per-destination and per-service limit types specified, the limit rule limits and counts the user connections of the specified service that are destined to the specified destination IP address.
Related commands: connection-limit policy and display connection-limit policy.
# Configure a limit rule for connection limit policy 1 to limit connections initiated from 192.168.0.0/24 by destination address, setting the upper and lower connection limits to 200 and 100 respectively. Suppose that users 192.168.0.1 and 192.168.0.100 access the same public network server. If the number of connections from the two users to the server reaches 200, no new connections can be established until the connection number goes below 100.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 192.168.0.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname-connection-limit-policy-1] limit 1 acl 2001 per-destination amount 200 100
nat address-group
nat address-group group-number [ start-address end-address ]
undo nat address-group group-number [ start-address end-address ]
View
Default level
2: System level
group-number: Index of the address pool, in the range of 0 to 31.
start-address: Start IP address of the address pool.
end-address: End IP address of the address pool. The end-address must be greater than or equal to the start-address. An address pool can contain a maximum of four IP addresses.
Use nat address-group to configure an address pool for NAT. When the start and end IP addresses are specified, this command specifies an address pool. Without the start and end IP addresses specified, the command places you into the address group view.
Use undo nat address-group to remove an address pool or address group.
An address pool consists of a set of consecutive IP addresses. When an internal packet is to be forwarded to the external network, an address is selected from the pool to replace the original source address. If the start-address and end-address parameters have the same value, there is only one IP address in the address pool.
You cannot remove an address pool that has been associated with an ACL.
An address pool is not needed in the case of Easy IP where the interface’s public IP address is used as the translated IP address.
The length of an address pool (the number of addresses in the pool) is 4.
Address pools cannot overlap each other.
Related commands: display nat address-group.
# Configure an address pool numbered 1 that contains addresses 202.110.10.10 to 202.110.10.15.
[Sysname] nat address-group 1 202.110.10.10 202.110.10.15
nat aging-time
nat aging-time { dns | ftp-ctrl | ftp-data | icmp | no-pat | pptp | tcp | tcp-fin | tcp-syn | udp } seconds
undo nat aging-time { dns | ftp-ctrl | ftp-data | icmp | no-pat | pptp | tcp | tcp-fin | tcp-syn | udp } [ seconds ]
View
Default level
2: System level
dns: Specifies the NAT aging time for DNS.
ftp-ctrl: Specifies the NAT aging time for FTP control link.
ftp-data: Specifies the NAT aging time for FTP data link.
icmp: Specifies the NAT aging time for ICMP.
no-pat: Specifies the NAT aging time in No-PAT mode.
pptp: Specifies the NAT aging time for PPTP.
tcp: Specifies the NAT aging time for TCP.
tcp-fin: Specifies the NAT aging time for TCP FIN or RST connection.
tcp-syn: Specifies the NAT aging time for TCP SYN connection.
udp: Specifies the NAT aging time for UDP.
seconds: NAT aging time in the range of 10 to 86400 seconds.
Use nat aging-time to set NAT aging time.
Use undo nat aging-time to restore the default.
The default NAT aging times of various protocols are as follows:
·     10 seconds for DNS
·     300 seconds for FTP control link
·     300 seconds for FTP data link
·     10 seconds for ICMP
·     240 seconds in NO-PAT mode
·     300 seconds for PPTP
·     300 seconds for TCP
·     10 seconds for TCP FIN and RST connections
·     10 seconds for TCP SYN connections
·     240 seconds for UDP
A NAT entry is not permanent. You can use this command to configure NAT aging time for TCP, UDP, ICMP, and other protocols. If a NAT entry is not used within the configured time, it will be aged out. For example, when a user with IP address 10.110.10.10 and port number 2000 establishes an external TCP connection, NAT assigns an IP address and a port number for the user. If, within a preconfigured aging time, the TCP connection is not used, the system will remove it.
In NO-PAT mode, if the private network is big and the users frequently go online and offline, you can set a smaller aging time to speed up the release of addresses.
Related commands: display nat aging-time.
# Set the NAT aging time for TCP to 240 seconds.
[Sysname] nat aging-time tcp 240
nat alg
nat alg { all | dns | ftp | h323 | ils | nbt | sip }
undo nat alg { all | dns | ftp | h323 | ils | nbt | sip }
View
Default level
2: System level
all: Supports all special protocols.
dns: Supports DNS.
ftp: Supports FTP.
h323: Supports H.323.
ils: Supports ILS.
nbt: Supports NBT.
sip: Supports SIP.
Use nat alg to enable NAT application layer gateway for one or more protocols.
Use undo nat alg to disable NAT application layer gateway.
By default, NAT application layer gateway is enabled.
# Enable NAT application layer gateway for FTP.
[Sysname] nat alg ftp
nat connection-limit-policy
nat connection-limit-policy policy-number
undo nat connection-limit-policy policy-number
View
Default level
2: System level
policy-number: Number of the connection limit policy, in the range of 0 to 19.
Use nat connection-limit-policy to bind a connection limit policy with the NAT module.
Use undo nat connection-limit-policy to remove the binding.
If you want to modify a connection limit policy that has been bound to NAT, you need to remove the binding with the undo nat connection-limit-policy command first.
# Bind connection limit policy 1 with the NAT module.
[Sysname] nat connection-limit-policy 1
# Remove the binding between connection limit policy 1 and the NAT module.
[Sysname] undo nat connection-limit-policy 1
nat dns-map
nat dns-map domain domain-name protocol pro-type ip global-ip port global-port
undo nat dns-map domain domain-name
View
Default level
2: System level
domain domain-name: Specifies the domain name of an internal server. A domain name is a string containing no more than 255 case-insensitive characters. It consists of several labels separated by dots (.). Each label has no more than 63 characters that must begin and end with letters or digits. (dashes (-) can be included).
protocol pro-type: Specifies the protocol type used by the internal server, tcp or udp.
ip global-ip: Specifies the public IP address used by the internal server to provide services to the external network.
port global-port: Specifies the port number used by the internal server to provide services to the external network. The global-port argument is in the range of 1 to 65535.
Use nat dns-map to map the domain name to the public network information about an internal server.
Use undo nat dns-map to remove a DNS mapping.
The switch supports up to 16 DNS mappings.
Related commands: display nat dns-map.
# A company provides Web service to external users. The domain name of the internal server is www.server.com, and the public IP address is 202.112.0.1. Configure a DNS mapping, so that internal users can access the Web server using its domain name.
[Sysname] nat dns-map domain  www.server.com protocol tcp ip 202.112.0.1 port www
nat link-down reset-session enable
undo nat link-down reset-session enable
View
Default level
2: System level
None
Use nat link-down reset-session enable to enable aging out NAT entries upon master link failure.
Use undo nat link-down reset-session enable to restore the default.
# Enable aging out NAT entries upon master link failure.
[Sysname] nat link-down reset-session enable
nat log enable
nat log enable [ acl acl-number ]
undo nat log enable
View
Default level
2: System level
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999. If you do not specify any ACL, the command enables NAT logging for all data flows.
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
By default, the NAT logging function is disabled.
# Enable NAT logging.
[Sysname] nat log enable acl 2001
nat log flow-active
nat log flow-active minutes
undo nat log flow-active
View
Default level
2: System level
minutes: Interval for logging active NAT sessions, in the range of 10 to 120 minutes.
Use nat log flow-active to enable logging for active NAT sessions and set the logging interval.
Use undo nat log flow-active to disable this function.
By default, this function is disabled.
This function helps track active flows by logging them regularly. Without this function, logs are generated only when a session is established or deleted and no logs are available for tracking a session that lasts for a long period of time.
# Enable logging for active NAT sessions and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
nat log flow-begin
nat log flow-begin
undo nat log flow-begin
View
Default level
2: System level
None
Use nat log flow-begin to enable logging of NAT session establishment events.
Use undo nat log flow-begin to restore the default.
By default, no log is generated when a session is established.
# Enable logging of NAT session establishment events.
[Sysname] nat log flow-begin
nat outbound
nat outbound acl-number [ address-group group-number [ vpn-instance vpn-instance-name ] [ no-pat ] ]
undo nat outbound acl-number [ address-group group-number [ vpn-instance vpn-instance-name ] [ no-pat ] ]
View
Interface view
Default level
2: System level
address-group group-number: Specifies an existing address pool for NAT by its index. The value range for the group-number argument is 0 to 31.
vpn-instance vpn-instance-name: Specifies the MPLS VPN to which the address pool belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. With this option, inter-VPN access through NAT is supported.
no-pat: Indicates that no many-to-many NAT is implemented. If this keyword is not configured, many-to-one NAT is implemented using the TCP/UDP port information.
Use nat outbound to associate an ACL with an address pool. Packets matching the associated ACL will be serviced by NAT. If you do not specify any address pool, the IP address of the interface will be used for NAT, which means Easy IP is enabled.
Use undo nat outbound to remove the address association on the outbound interface.
You can configure multiple associations or use the undo command to remove an association on an interface that serves as the egress of an internal network to external networks.
When an ACL rule is not operative, no new NAT session entry depending on the rule can be created. However, existing connections are still available for communication.
If a packet matches the specified next hop, the packet will be translated using an IP address in the address pool. If not, the packet will not be translated.
You can bind an ACL to only one address pool on an interface. An address pool can be bound to multiple ACLs.
For some devices, the ACL rules referenced by the same interface cannot conflict. The source IP address, destination IP address and VPN instance information in any two ACL rules cannot be the same. For basic ACLs (numbered from 2000 to 2999), if the source IP address and VPN instance information in any two ACL rules are the same, a conflict occurs.
# Enable NAT for hosts in the 10.110.10.0/24 segment, using addresses 202.110.10.10 to 202.110.10.12 as the external IP addresses. Assume that VLAN-interface 200 is connected to the external network.
[Sysname-acl-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-basic-2001] rule deny
# Configure a NAT address pool.
[Sysname] nat address-group 1 202.110.10.10 202.110.10.12
# To use TCP/UDP port information in translation, do the following:
[Sysname] interface vlan-interface 200
[Sysname-Vlan-interface200] nat outbound 2001 address-group 1
# To ignore the TCP/UDP port information in translation, do the following:
[Sysname] interface Vlan-interface 200
[Sysname-Vlan-interface200] nat outbound 2001 address-group 1 no-pat
# To use the IP address of VLAN-interface 200 for NAT, do the following:
nat outbound static
nat outbound static
undo nat outbound static
View
Interface view
Default level
2: System level
None
Use nat outbound static to enable static NAT on an interface, making the configured static NAT mappings take effect.
Use undo nat outbound static to disable static NAT on the interface.
Related commands: display nat static.
# Configure a one-to-one NAT mapping and enable static NAT on VLAN-interface 200.
[Sysname] nat static 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface200] nat outbound static
nat server
nat server protocol pro-type global { global-address | interface interface-type interface-number | current-interface } [ global-port ] [ vpn-instance global-name ] inside local-address [ local-port ] [ vpn-instance local-name ]
undo nat server protocol pro-type global { global-address | interface interface-type interface-number | current-interface } [ global-port ] [ vpn-instance global-name ] inside local-address [ local-port ] [ vpn-instance local-name ]
nat server protocol pro-type global { global-address | interface interface-type interface-number | current-interface } global-port1 global-port2 [ vpn-instance global-name ] inside local-address1 local-address2 local-port [ vpn-instance local-name ]
undo nat server protocol pro-type global { global-address | interface interface-type interface-number | current-interface } global-port1 global-port2 [ vpn-instance global-name ] inside local-address1 local-address2 local-port [ vpn-instance local-name ]
View
Interface view
Default level
2: System level
protocol pro-type: Specifies a protocol type. pro-type supports TCP, UDP, and ICMP. If ICMP is specified, do not specify any port number for the internal server.
global-address: Public IP address for the internal server.
interface: Specifies the address of the interface as the public IP address of the internal server.
interface-type interface-number: Specifies the interface type and interface number. The specified interface must be a loopback interface that already exists.
current-interface: Specifies the IP address of the current interface as the public address of the internal server.
global-port1, global-port2: Specifies a range of ports that have a one-to-one correspondence with the IP addresses of the internal hosts. global-port2 must be greater than global-port1.
local-address1, local-address2: Defines a consecutive range of addresses that have a one-to-one correspondence with the range of ports. local-address2 must be greater than local-address1 and that the number of addresses must match that of the specified ports.
local-port: Port number provided by the internal server, in the range of 0 to 65535 (excluding the FTP port number 20).
·     You can use the service names to represent those well-known port numbers. For example, you can use www to represent port number 80, and ftp to represent port number 21.
·     You can use the keyword any to represent port number 0, which means all types of services are supported. This has the same effect as a static translation between the global-address and local-address.
global-port: Global port number for the internal server, in the range of 0 to 65535.
local-address: Internal IP address of the internal server.
vpn-instance global-name: Specifies the MPLS VPN to which the advertised external IP address belongs. The global-name argument is a case-sensitive string of 1 to 31 characters. Without this option, the advertised external IP address does not belong to any MPLS VPN.
vpn-instance local-name: Specifies the MPLS VPN to which the internal server belongs. local-name specifies the VPN instance name, a case-sensitive string of 1 to 31 characters. Without this option, the internal server is a common internal server that does not belong to any MPLS VPN.
Use nat server to define an internal server.
Using the address and port defined by the global-address and global-port parameters, external users can access the internal server with an IP address of local-address and a port of local-port.
Use undo nat server to remove the configuration.
If one of the two arguments global-port and local-port is set to any, the other must also be set to any or remain undefined.
Using this command, you can configure internal servers (such as Web, FTP, Telnet, POP3, and DNS servers) to provide services for external users. An internal server can reside on a private network or an MPLS VPN.
Up to 256 internal server configuration commands can be configured on an interface. The number of internal servers that each command can define equals the difference between global-port2 and global-port1. Up to 4096 internal servers can be configured on an interface. The system allows up to 1024 internal server configuration commands.
In general, this command is configured on an interface that serves as the egress of an internal network and connects to the external networks.
The switch supports using an interface address as the public IP address of an internal server, which is Easy IP.
If you specify the internal server to use the IP address of the current interface as its public IP address, other internal servers must not use that IP address as their public IP address.
Related commands: display nat server.
If pro-type is not TCP (protocol identifier 6) or UDP (protocol identifier 17), you can configure one-to-one NAT between an internal IP address and an external IP address only, but cannot specify port numbers.
# Allow external users to access the internal Web server 10.110.10.10 on the LAN through http://202.110.10.10:8080, and the internal FTP server 10.110.10.11 in MPLS VPN vrf10 through ftp://202.110.10.10/. VLAN-interface 10 is connected to the external network.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 inside 10.110.10.10 www
[Sysname- Vlan-interface10] quit
[Sysname] ip vpn-instance vrf10
[Sysname-vpn-instance] route-distinguisher 100:001
[Sysname-vpn-instance] vpn-target 100:1 export-extcommunity
[Sysname-vpn-instance] vpn-target 100:1 import-extcommunity
[Sysname-vpn-instance] quit
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# Allow external hosts to ping the host with an IP address of 10.110.10.12 in VPN vrf10 by using the command ping 202.110.10.11.
[Sysname-Vlan-interface100] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# Allow external hosts to access the Telnet services of internal servers 10.110.10.1 to 10.110.10.100 in MPLS VPN vrf10 through the public address of 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can telnet to 202.110.10.10:1001 to access 10.110.10.1, telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
# Remove the Web server.
[Sysname-Vlan-interface10] undo nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 www
# Remove the FTP server from VPN vrf10.
[Sysname-Vlan-interface10] undo nat server protocol tcp global 202.110.10.11 21 inside 10.110.10.11 ftp vpn-instance vrf10
nat static
nat static local-ip [ vpn-instance local-name ] global-ip [ vpn-instance global-name ]
undo nat static local-ip [ vpn-instance local-name ] global-ip [ vpn-instance global-name ]
View
Default level
2: System level
local-ip: Internal IP address.
vpn-instance local-name: Name of the VPN to which the internal IP address belongs. local-name specifies the MPLS VPN, a case-sensitive character string of 1 to 31 characters.
global-ip: External IP address.
vpn-instance global-name: Specifies the VPN to which the external IP address belongs. The global-name argument is a case-sensitive string of 1 to 31 characters.
Use nat static to configure a one-to-one static NAT mapping.
Use undo nat static to remove a one-to-one static NAT mapping.
If you do not specify vpn-instance local-name, the internal IP address is a common private network address.
If you do not specify vpn-instance global-name, the external IP address is a common public network address.
# In system view, configure static NAT mapping between internal IP address 192.168.1.1 that belongs to VPN vpn10 and external IP address 2.2.2.2 that belongs to VPN vpn20.
[Sysname] nat static 192.168.1.1 vpn-instance vpn10 2.2.2.2 vpn-instance vpn20
nat static net-to-net
nat static net-to-net local-start-address local-end-address global global-network { netmask-length | netmask }
undo nat static net-to-net local-start-address local-end-address global global-network { netmask-length | netmask }
View
Default level
2: System level
local-start-address local-end-address: Private network address range, which contains at most 255 IP addresses.
local-network: Private network address.
global-network: Public network address.
mask-length: Length of the network mask.
mask: Network mask.
Use nat static net-to-net to configure a net-to-net static NAT mapping.
Use undo nat static net-to-net to remove a net-to-net static NAT mapping.
The IP addresses of the private network must be on the same network segment according to the mask length of the public network address.
# Configure a bidirectional static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static net-to-net 192.168.1.0 2.2.2.0 24
reset nat session
In standalone mode:
reset nat session slot slot-number
In IRF mode:
reset nat session chassis chassis-number slot slot-number
View
Default level
2: System level
slot slot-number: Clears the address translation table on the card. The argument slot-number specifies a card by its slot number. Use this argument when your switch is operating in standalone (the default) mode (only supported on the main control board).
chassis chassis-number slot slot-number: Clears the address translation table on the specified card of the specified member device. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode (only supported on the main control board).
Use reset nat session to clear the address translation table and release the memory dynamically assigned for storing the table.
# Clear the address translation table of the card in slot 0.
<Sysname> reset nat session slot 0
In standalone mode:
reset userlog nat export slot slot-number
In IRF mode:
reset userlog nat export chassis chassis-number slot slot-number
View
Default level
2: System level
slot slot-number: Clears NAT log statistics on the specified card. The argument slot-number specifies a card by its slot number. Use this argument when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Clears NAT log statistics on the specified card of the specified member device. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode.
Use reset userlog nat export to clear NAT log statistics.
Once the NAT log function is enabled, the system will take statistics for NAT logs periodically.
Related commands: display userlog export.
# Clear NAT log information about slot 0.
<Sysname> reset userlog nat export slot 0
reset userlog nat logbuffer
In standalone mode:
reset userlog nat logbuffer slot slot-number
In IRF mode:
reset userlog nat logbuffer chassis chassis-number slot slot-number
View
Default level
2: System level
slot slot-number: Specifies a card by its slot number. Use this argument when your switch is operating in standalone mode (only supported on the main control board).
Use reset userlog nat logbuffer to clear the NAT log buffer.
Clear NAT log buffer only when necessary.
# Clear the NAT log buffer of the card in slot 0.
<Sysname> reset userlog nat logbuffer slot 0
userlog nat export host
In standalone mode:
userlog nat export slot slot-number host { ipv4-address | ipv6 ipv6-address } udp-port
undo userlog nat export slot slot-number host { ipv4-address | ipv6 ipv6-address }
In IRF mode:
userlog nat export chassis chassis-number slot slot-number host { ipv4-address | ipv6 ipv6-address } udp-port
undo userlog nat export chassis chassis-number slot slot-number host { ipv4-address | ipv6 ipv6-address }
View
Default level
2: System level
slot slot-number: Specifies a card by its slot number. Use this option when your switch is operating in standalone mode (only supported on the main control board).
ipv4-address: IPv4 address of the NAT log server. It must be a valid unicast IPv4 address and cannot be a loopback address.
ipv6 ipv6-address: IPv6 address of the NAT log server. It must be a valid unicast IPv6 address.
udp-port: UDP port number of the NAT log server, in the range of 0 to 65535.
Use userlog nat export host to specify the IP address and UDP port number of the NAT log server that receives NAT logs.
Use undo userlog nat export host to restore the default.
By default, no NAT log server IP address or UDP port number is configured.
In standalone mode, each interface card can be configured with a separate NAT log server for load sharing. The packets exported from these interface cards are numbered independently.
In IRF mode, each interface card of a member switch can be configured with a separate NAT log server for load sharing. The packets exported from these interface cards are numbered independently (sequence numbers in the packet headers).
You must specify the NAT log server to successfully export NAT logs in UDP packets.
H3C recommends that you use a UDP port number greater than 1024 to avoid conflicting with common UDP port numbers.
Each interface card can be configured with a separate NAT log server for load sharing. The packets exported from these interface cards are numbered independently (sequence numbers in the packet headers). If you do not specify the slot slot-number combination, this command applies to all interface cards with no NAT log server IP address or UDP port number configured.
Related commands: userlog nat export source-ip.
# Export the NAT logs of interface card 0 to NAT log server with IP address 169.254.1.1 and port number 2000.
[Sysname] userlog nat export slot 0 host 169.254.1.1 2000
userlog nat export source-ip ip-address
undo userlog nat export source-ip
View
Default level
2: System level
ip-address: Source IP address for the UDP packets.
Use userlog nat export source-ip to configure the source IP address for the UDP packets that carry NAT logs.
Use undo userlog nat export source-ip to restore the default.
By default, the source IP address of the UDP packets that carry NAT logs is the IP address of the interface that sends the UDP packets.
Related commands: userlog nat export host.
# Use 169.254.1.2 as the source IP address of the UDP packets that carry NAT logs.
[Sysname] userlog nat export source-ip 169.254.1.2
userlog nat export version
userlog nat export version version-number
undo userlog nat export version
View
Default level
2: System level
version-number: Version number for the NAT log packets. The system supports only version 1.
Use userlog nat export version to set the version number of the NAT log packets.
Use undo userlog nat export version to restore the default.
By default, the version number of NAT log packets is 1.
# Set the version number of NAT log packets to 1.
[Sysname] userlog nat export version 1
userlog nat syslog
userlog nat syslog
undo userlog nat syslog
View
Default level
2: System level
None
Use userlog nat syslog to configure the switch to export NAT logs to the information center.
Use undo userlog nat syslog to restore the default.
By default, NAT logs are exported to the NAT log server.
NAT logs might consume a large volume of memory. H3C recommends not exporting large amounts of NAT logs to the information center.
# Export NAT logs to the information center.
[Sysname] userlog nat syslog
