06-Layer 3 - IP Services Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18206-Layer 3 - IP Services Command Reference
03-DHCP Commands
03-DHCP Commands 376.81 KB
DHCP server configuration commands 1
bims-server 1
bootfile-name· 2
dhcp enable (for DHCP server) 2
dhcp server apply ip-pool 3
dhcp select server global-pool 3
dhcp server client-detect enable· 4
dhcp server detect 5
dhcp server forbidden-ip· 5
dhcp server ip-pool 6
dhcp server ping packets 7
dhcp server ping timeout 8
dhcp server relay information enable· 8
dhcp server threshold· 9
dhcp update arp (for DHCP server) 10
display dhcp server conflict 10
display dhcp server expired· 11
display dhcp server free-ip· 12
display dhcp server forbidden-ip· 13
display dhcp server ip-in-use· 14
display dhcp server statistics 15
display dhcp server tree· 17
dns-list 19
domain-name· 19
expired· 20
forbidden-ip· 21
gateway-list 21
nbns-list 22
netbios-type· 23
network· 23
network ip range· 24
network mask· 25
next-server 26
option· 26
reset dhcp server conflict 27
reset dhcp server ip-in-use· 27
reset dhcp server statistics 29
static-bind client-identifier 30
static-bind ip-address 31
static-bind mac-address 31
tftp-server domain-name· 32
tftp-server ip-address 33
vendor-class-identifier 33
voice-config· 34
DHCP relay agent configuration commands 36
dhcp relay address-check enable· 36
dhcp relay check mac-address 36
dhcp relay client-detect enable· 37
dhcp relay information circuit-id format-type· 38
dhcp relay information circuit-id string· 38
dhcp relay information enable· 39
dhcp relay information format 40
dhcp relay information remote-id format-type· 41
dhcp relay information remote-id string· 41
dhcp relay information strategy· 42
dhcp relay release ip· 43
dhcp relay security static· 43
dhcp relay security refresh enable· 44
dhcp relay security tracker 45
dhcp relay server-detect 45
dhcp relay server-group· 46
dhcp relay server-select 47
dhcp select relay· 48
display dhcp relay· 48
display dhcp relay information· 49
display dhcp relay security· 50
display dhcp relay security statistics 51
display dhcp relay security tracker 52
display dhcp relay server-group· 53
display dhcp relay statistics 54
reset dhcp relay statistics 56
DHCP client configuration commands 57
display dhcp client 57
ip address dhcp-alloc· 59
DHCP snooping configuration commands 61
dhcp-snooping· 61
dhcp-snooping binding database filename· 61
dhcp-snooping binding database update interval 62
dhcp-snooping binding database update now·· 63
dhcp-snooping check mac-address 63
dhcp-snooping check request-message· 64
dhcp-snooping information circuit-id format-type· 65
dhcp-snooping information circuit-id string· 65
dhcp-snooping information enable· 66
dhcp-snooping information format 67
dhcp-snooping information remote-id format-type· 68
dhcp-snooping information remote-id string· 68
dhcp-snooping information strategy· 69
dhcp-snooping information sub-option· 70
dhcp-snooping trust 71
display dhcp-snooping· 72
display dhcp-snooping binding database· 73
display dhcp-snooping information· 74
display dhcp-snooping packet statistics 75
display dhcp-snooping trust 76
reset dhcp-snooping· 77
reset dhcp-snooping packet statistics 77
The DHCP server configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, Layer 3 aggregate interfaces, and loopback interfaces. The subaddress pool configuration is not supported on loopback interfaces.
bims-server
bims-server ip ip-address [ port port-number ] sharekey [ cipher | simple ] key
undo bims-server
View
DHCP address pool view
Default level
2: System level
ip ip-address: Specifies the IP address of a BIMS server.
port port-number: Specifies the port number of the BIMS server, in the range of 1 to 65534.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key.
key: Specifies a shared key for the BIMS server. This argument is case sensitive. If simple is specified, it must be a string of 1 to 16 characters. If cipher is specified, it must be a ciphertext string of 1 to 53 characters. If neither cipher nor simple is specified, you set a plaintext key string.
Use bims-server to specify the IP address, port number, and shared key of the BIMS server in the DHCP address pool for the client.
Use undo bims-server to remove the specified BIMS server information.
By default, no BIMS server information is specified.
If you execute the bims-server command multiple times, the most recent configuration takes effect.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
Related commands: dhcp server ip-pool and display dhcp server tree.
# Specify the IP address 1.1.1.1, port number 80, and shared key aabbcc of the BIMS server in DHCP address pool 0 for the client.
[Sysname] dhcp server ip-pool 0
[Sysname-dhcp-pool-0] bims-server ip 1.1.1.1 port 80 sharekey simple aabbcc
bootfile-name
bootfile-name bootfile-name
undo bootfile-name
View
Default level
2: System level
bootfile-name: Boot file name, a string of 1 to 63 characters.
Use bootfile-name to specify a bootfile name in the DHCP address pool for the client.
Use undo bootfile-name to remove the specified bootfile name.
By default, no bootfile name is specified.
If you execute the bootfile-name command multiple times, the most recent configuration takes effect.
# Specify the bootfile name aaa.cfg in DHCP address pool 0.
[Sysname-dhcp-pool-0] bootfile-name aaa.cfg
dhcp enable
undo dhcp enable
View
Default level
2: System level
None
Use dhcp enable to enable DHCP.
Use undo dhcp enable to disable DHCP.
By default, DHCP is disabled.
You need to enable DHCP before performing DHCP server and relay agent configurations.
# Enable DHCP.
[Sysname] dhcp enable
undo dhcp server apply ip-pool [ pool-name ]
View
Interface view
Default level
2: System level
pool-name: DHCP address pool name, a case-insensitive string in the range of 1 to 35 characters.
Use dhcp server apply ip-pool to apply an extended address pool on an interface.
Use undo dhcp server apply ip-pool to remove the configuration.
By default, no extended address pool is applied on an interface, and the server assigns an IP address from a common address pool to a client when the client's request arrives at the interface.
If you execute the dhcp server apply ip-pool command on an interface, when a client's request arrives at the interface, the server attempts to assign the client the statically bound IP address first and then an IP address from this extended address pool.
Only an extended address pool can be applied on an interface. The address pool to be referenced must already exist.
Related commands: dhcp server ip-pool.
# Apply extended DHCP address pool 0 on VLAN-interface 100.
[Sysname-Vlan-interface100] dhcp server apply ip-pool 0
dhcp select server global-pool [ subaddress ]
undo dhcp select server global-pool [ subaddress ]
View
Interface view
Default level
2: System level
subaddress: Supports secondary address allocation. When the DHCP server and client are on the same network segment, the server preferably assigns an IP address from an address pool that resides on the same subnet as the primary IP address of the server interface (connecting to the client). If the address pool contains no assignable IP address, the server assigns an IP address from an address pool that resides on the same subnet as the secondary IP addresses of the server interface. If the interface has multiple secondary IP addresses, each address pool is tried in turn for address allocation. Without the keyword subaddress specified, the DHCP server can only assign an IP address from the address pool that resides on the same subnet as the primary IP address of the server interface.
Use dhcp select server global-pool to enable the DHCP server on specified interfaces. After the interface receives a DHCP request, the DHCP server allocates an IP address from the address pool.
Use undo dhcp select server global-pool to remove the configuration. Upon receiving a DHCP request from a client, the interface neither assigns an IP address to the client, nor serves as a DHCP relay agent to forward the request.
Use the undo dhcp select server global-pool subaddress command to cancel the support for subaddress allocation.
By default, the DHCP server is enabled on an interface.
# Enable the DHCP server on VLAN-interface 2.
[Sysname-Vlan-interface2] dhcp select server global-pool
undo dhcp server client-detect enable
View
Interface view
Default level
2: System level
None
Use dhcp server client-detect enable to enable client off-line detection on the DHCP server.
Use undo dhcp server client-detect enable to disable the function.
By default, the function is disabled.
With this feature enabled, the DHCP server considers a DHCP client goes offline when the ARP entry for the client ages out. In addition, it removes the client entry and releases the IP address of the client.
# Enable client off-line detection on the DHCP server.
[Sysname-Vlan-interface2] dhcp server client-detect enable
dhcp server detect
dhcp server detect
undo dhcp server detect
View
Default level
2: System level
None
Use dhcp server detect to enable unauthorized DHCP server detection.
Use undo dhcp server detect to disable the function.
With this function enabled, upon receiving a DHCP request, the DHCP server records the IP addresses of DHCP servers which ever offered IP addresses to the DHCP client and the receiving interface. Each server detected is recorded only once. The administrator can use this information from logs to check for unauthorized DHCP servers.
With unauthorized DHCP server detection enabled, the switch puts a record once for each DHCP server, and the administrator needs to find unauthorized DHCP servers from the log information.
# Enable unauthorized DHCP server detection.
[Sysname] dhcp server detect
dhcp server forbidden-ip low-ip-address [ high-ip-address ]
undo dhcp server forbidden-ip low-ip-address [ high-ip-address ]
View
Default level
2: System level
low-ip-address: Start IP address of the IP address range to be excluded from dynamic allocation.
high-ip-address: End IP address of the IP address range to be excluded from dynamic allocation. The end IP address must have a higher sequence than the start one.
Use dhcp server forbidden-ip to exclude IP addresses from dynamic allocation.
Use undo dhcp server forbidden-ip to remove the configuration.
By default, all IP addresses in a DHCP address pool are assignable except IP addresses of the DHCP server interfaces.
When you use the dhcp server forbidden-ip command to exclude an IP address that is bound to a user from dynamic assignment, the address can be still assigned to the user.
When you use the undo dhcp server forbidden-ip command to remove the configuration, the specified address/address range must be consistent with the one specified with the dhcp server forbidden-ip command. If you have configured to exclude an address range from dynamic assignment, you need to specify the same address range in the undo dhcp server forbidden-ip command instead of specifying one IP address.
You can exclude multiple IP address ranges from allocation.
Related commands: display dhcp server forbidden-ip, dhcp server ip-pool, network, and static-bind ip-address.
# Exclude the IP address range 10.110.1.1 to 10.110.1.63 from dynamic allocation.
[Sysname] dhcp server forbidden-ip 10.110.1.1 10.110.1.63
dhcp server ip-pool
dhcp server ip-pool pool-name [ extended ]
undo dhcp server ip-pool pool-name
View
Default level
2: System level
pool-name: Global address pool name, which is a unique pool identifier, a string of 1 to 35 characters.
extended: Specifies the address pool as an extended address pool. If you do not specify this keyword, the address pool is a common address pool.
Use dhcp server ip-pool to create a DHCP address pool and enter its view. If the pool was created, you directly enter its view.
Use undo dhcp server ip-pool to remove the specified DHCP address pool.
By default, no DHCP address pool is created.
Related commands: dhcp enable and display dhcp server tree.
# Create the common address pool identified by 0.
undo dhcp server ping packets
View
Default level
2: System level
number: Number of ping packets, in the range of 0 to 10. 0 means no ping operation.
Use dhcp server ping packets to specify the maximum number of ping packets on the DHCP server.
Use undo dhcp server ping packets to restore the default.
The number defaults to 1.
To avoid IP address conflicts, the DHCP server checks whether an IP address is in use before assigning it to a DHCP client.
The DHCP server pings the IP address to be assigned by using ICMP. If the server gets a response within the specified period, the server selects and pings another IP address. If not, the server pings the IP addresses once again until the specified number of ping packets are sent. If still no response is received, the server assigns the IP address to the requesting client.
# Specify the maximum number of ping packets as 10.
[Sysname] dhcp server ping packets 10
undo dhcp server ping timeout
View
Default level
2: System level
milliseconds: Response timeout value for ping packets in milliseconds, in the range of 0 to 10000. 0 means no ping operation.
Use dhcp server ping timeout to configure response timeout time of the ping packet on the DHCP server.
Use undo dhcp server ping timeout to restore the default.
The time defaults to 500 ms.
# Specify the response timeout time as 1000 ms.
[Sysname] dhcp server ping timeout 1000
undo dhcp server relay information enable
View
Default level
2: System level
None
Use dhcp server relay information enable to enable the DHCP server to handle Option 82.
Use undo dhcp server relay information enable to configure the DHCP server to ignore Option 82.
By default, the DHCP server handles Option 82.
# Configure the DHCP server to ignore Option 82.
[Sysname] undo dhcp server relay information enable
dhcp server threshold { allocated-ip threshold-value | average-ip-use threshold-value | max-ip-use threshold-value }
undo dhcp server threshold { allocated-ip | average-ip-use | max-ip-use }
View
Default level
2: System level
allocated-ip threshold-value: Enables the DHCP server to send trap messages to the network management server when the ratio of successfully allocated IP addresses to received DHCP requests within 5 minutes reaches the threshold specified by the threshold-value argument. The threshold is a percentage value in the range of 1 to 100.
average-ip-use threshold-value: Enables the DHCP server to send trap messages to the network management server when the average IP address utilization of an address pool within 5 minutes reaches the threshold specified by the threshold-value argument. The threshold is a percentage value in the range of 1 to 100.
max-ip-use threshold-value: Enables the DHCP server to send trap messages to the network management server when the maximum IP address utilization of an address pool within 5 minutes reaches the threshold specified by the threshold-value argument. The threshold is a percentage value in the range of 1 to 100.
Use dhcp server threshold to enable the DHCP server to send trap messages to the network management server when the specified threshold is reached.
Use undo dhcp server threshold to restore the default.
By default, the DHCP server does not send trap messages to the network management server.
# Enable the DHCP server to send trap messages to the network management server when the ratio of successfully allocated IP addresses to received DHCP requests within 5 minutes exceeds 50%.
[Sysname] dhcp server threshold allocated-ip 50
# Enable the DHCP server to send trap messages to the network management server when the average IP address utilization of an address pool within 5 minutes exceeds 80%.
[Sysname] dhcp server threshold average-ip-use 80
# Enable the DHCP server to send trap messages to the network management server when the maximum IP address utilization of an address pool within 5 minutes exceeds 80%.
[Sysname] dhcp server threshold max-ip-use 80
dhcp update arp
undo dhcp update arp
View
Interface view
Default level
2: System level
None
Use dhcp update arp to configure the DHCP server to support authorized ARP.
Use undo dhcp update arp to restore the default.
By default, the DHCP server does not support authorized ARP.
This command can be configured only on Ethernet interfaces that are operating in Layer 3 mode. For more information about the operating mode of Ethernet interfaces, see Interface Configuration Guide.
# Configure GigabitEthernet 3/0/1 of the current DHCP server to support authorized ARP.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] port link-mode route
[Sysname-GigabitEthernet3/0/1] dhcp update arp
display dhcp server conflict { all | ip ip-address } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays information about all IP address conflicts.
ip-address: Displays conflict information about the specified IP address.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display dhcp server conflict to display information about IP address conflicts.
Related commands: reset dhcp server conflict.
# Display information about all IP address conflicts.
<Sysname> display dhcp server conflict all
    Address             Discover time
    4.4.4.1             Apr 25 2007 16:57:20
    4.4.4.2             Apr 25 2007 17:00:10
 --- total 2 entry ---
Address
Conflicted IP address.
Discover Time
Time when the conflict was discovered.
display dhcp server expired { all | ip ip-address | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays lease expiration information about all DHCP address pools.
ip ip-address: Displays lease expiration information about the specified IP address.
pool [ pool-name ]: Displays lease expiration information about the specified address pool. The pool name is a string of 1 to 35 characters. If you do not specify any pool name, this command displays the lease expiration information about all address pools.
Use display dhcp server expired to display lease expiration information about the specified DHCP address pools or an IP address.
DHCP assigns these expired IP addresses to DHCP clients after all addresses have been assigned.
# Display information about lease expirations in all DHCP address pools.
<Sysname> display dhcp server expired all
IP address       Client-identifier/    Lease expiration          Type
                    Hardware address
 4.4.4.6          3030-3066-2e65-3230-  Apr 25 2007 17:10:47     Release
                   302e-3130-3234-2d45-
                   7468-6572-6e65-7430-
                   2f31
 --- total 1 entry ---
IP address
Expired IP addresses.
Client-identifier/Hardware address
IDs or MACs of clients whose IP addresses were expired.
Lease expiration
Lease expiration time.
Types of lease expirations. This field is set to Release.
display dhcp server free-ip [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp server free-ip to display information about assignable IP addresses which have never been assigned.
# Display information about assignable IP addresses.
<Sysname> display dhcp server free-ip
IP Range from 10.0.0.1              to  10.0.0. 254
display dhcp server forbidden-ip [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp server forbidden-ip to display IP addresses excluded from dynamic allocation in DHCP address pool.
# Display IP addresses excluded from dynamic allocation in the DHCP address pool.
<Sysname> display dhcp server forbidden-ip
Global:
IP Range from 1.1.0.2              to  1.1.0.3
IP Range from 1.1.1.2              to  1.1.1.3
Pool name: 2
1.1.1.5          1.1.1.6
Global
Globally excluded IP addresses specified with the dhcp server forbidden-ip command in system view. No address pool can assign these IP addresses.
Pool name
Excluded IP addresses specified with the forbidden-ip command in DHCP address pool view. They cannot be assigned from the current extended address pool only.
display dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays binding information about all DHCP address pools.
ip ip-address: Displays binding information about the specified IP address.
pool [ pool-name ]: Displays the binding information about the specified address pool. The pool name is a string of 1 to 35 characters. If you do not specify any pool name, this command displays binding information about all address pools.
Use display dhcp server ip-in-use to display binding information about DHCP address pools or an IP address.
Related commands: reset dhcp server ip-in-use.
# Display binding information about all DHCP address pools.
<Sysname> display dhcp server ip-in-use all
Pool utilization: 0.39%
                 Hardware address
 10.1.1.1      4444-4444-4444         NOT Used                  Manual
  10.1.1.2      3030-3030-2e30-3030-   May  1 2009 14:02:49      Auto:COMMITTED
               662e-3030-3033-2d45-
               2f31
Pool utilization
Utilization rate of a DHCP address pool:
·     When binding information about all DHCP address pools is displayed, this field displays the total utilization rate of all DHCP address pools.
·     When binding information about a specific DHCP address pool is displayed, this field displays the utilization rate of the DHCP address pool.
·     When binding information about a specific IP address is displayed, this field is not displayed.
IP address
Bound IP address.
Client's ID or MAC of the binding.
Lease expiration
Lease expiration time:
·     Specific time (May 1 2009 14:02:49 in this example)Time when the lease expires.
·     NOT UsedThe IP address of the static binding has not been assigned to the specific client.
·     UnlimitedInfinite lease expiration time.
Binding types:
·     ManualStatic binding.
·     Auto:OFFERED—Binding sent in the DHCP-OFFER message from the server to the client.
·     Auto:COMMITTED—Binding sent in the DHCP-ACK message from the server to the client.
In the output from the display dhcp server ip-in-use command, the lease duration of a used static binding is displayed as Unlimited instead of the actual lease duration. To view the actual lease duration, use the display this command in DHCP address pool view.
display dhcp server statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp server statistics to display the statistics of the DHCP server.
Related commands: reset dhcp server statistics.
# Display the statistics on the DHCP server.
<Sysname> display dhcp server statistics
    Global Pool:
      Pool Number:                     1
      Binding:
        Auto:                          1
        Manual:                        0
        Expire:                        0
    BOOTP Request:                     10
      DHCPDISCOVER:                    5
      DHCPREQUEST:                     3
      DHCPDECLINE:                     0
      DHCPRELEASE:                     2
      DHCPINFORM:                      0
      BOOTPREQUEST:                    0
    BOOTP Reply:                       6
      DHCPOFFER:                       3
      DHCPACK:                         3
      DHCPNAK:                         0
      BOOTPREPLY:                      0
    Bad Messages:                      0
Table 5 Command output
Global Pool
Statistics of a DHCP address pool.
Pool Number
Number of address pools.
Auto
Number of dynamic bindings.
Manual
Number of static bindings.
Expire
Number of expired bindings.
BOOTP Request
Number of DHCP requests sent from DHCP clients to the DHCP server. The requests include:
·     DHCPDISCOVER.
·     DHCPREQUEST.
·     DHCPDECLINE.
·     DHCPRELEASE.
·     DHCPINFORM.
·     BOOTPREQUEST.
BOOTP Reply
Number of DHCP replies sent from the DHCP server to DHCP clients. The replies include:
·     DHCPOFFER.
·     DHCPACK.
·     DHCPNAK.
·     BOOTPREPLY.
Bad Messages
Number of erroneous messages.
display dhcp server tree { all | pool [ pool-name ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays information about all DHCP address pools.
pool [ pool-name ]: Displays information about the specified address pool. The pool name argument is a string of 1 to 35 characters. If you do not specify any pool name, this command displays information about all address pools.
Use display dhcp server tree to display information about DHCP address pools.
# Display information about all DHCP address pools.
<Sysname> display dhcp server tree all
Global pool:
Pool name: 0
 network 20.1.1.0 mask 255.255.255.0
 Sibling node:1
 option 2 ip-address 1.1.1.1
 expired 1 0 0 0
Pool name: 1
 static-bind ip-address 10.10.1.2 mask 255.0.0.0
 static-bind mac-address 00e0-00fc-0001
 PrevSibling node:0
 expired unlimited
Extended pool:
Pool name: 2
 network ip range 1.1.1.0 1.1.1.255
 network mask 255.255.255.0
 expired 0 0 2 0
Table 6 Command output
Global pool
Information about a common address pool.
Pool name
Address pool name.
network
Network segment for address allocation.
IP address and MAC address of the static binding.
Sibling node
Sibling node of the current node:
·     Child node—Child node (subnet segment) address pool of the current node.
·     Parent node—Parent node (nature network segment) address pool of the current node.
·     Sibling node—Latter sibling node of the current node (another subnet of the same nature network). The earlier the sibling node is configured, the higher order the sibling node has.
·     PrevSibling node—Previous sibling node of the current node.
option
Self-defined DHCP options.
expired
Lease duration, in the format of day, hour, minute, and second.
Extended pool
Information about an extended address pool.
network ip range
Range of assignable IP addresses in the extended address pool.
network mask
Mask of IP addresses assigned from the extended address pool.
dns-list
dns-list ip-address&<1-8>
undo dns-list { ip-address | all }
View
Default level
2: System level
ip-address&<1-8>: DNS server IP address. &<1-8> means you can specify up to eight DNS server addresses separated by spaces.
all: Specifies all DNS server addresses to be removed.
Use dns-list to specify DNS server addresses in a DHCP address pool.
Use undo dns-list to remove DNS server addresses from a DHCP address pool.
By default, no DNS server address is specified.
If you use the dns-list command multiple times, the most recent configuration takes effect.
# Specify the DNS server address 10.1.1.254 for the DHCP client in DHCP address pool 0.
[Sysname-dhcp-pool-0] dns-list 10.1.1.254
domain-name
domain-name domain-name
undo domain-name
View
Default level
2: System level
domain-name: Domain name suffix for DHCP clients, a string of 1 to 50 characters.
Use domain-name to specify a domain name suffix for the DHCP clients in the DHCP address pool.
Use undo domain-name to remove the specified domain name suffix.
No domain name suffix is specified by default.
# Specify a domain name suffix of mydomain.com for the DHCP clients in DHCP address pool 0.
[Sysname-dhcp-pool-0] domain-name mydomain.com
expired
expired { day day [ hour hour [ minute minute [ second second ] ] ] | unlimited }
undo expired
View
Default level
2: System level
day day: Specifies the number of days, in the range of 0 to 365.
hour hour: Specifies the number of hours, in the range of 0 to 23.
minute minute: Specifies the number of minutes, in the range of 0 to 59.
second second: Specifies the number of seconds, in the range of 0 to 59.
unlimited: Specifies the infinite duration, which is actually 136 years.
Use expired to specify the lease duration in a DHCP address pool.
Use undo expired to restore the default lease duration in a DHCP address pool.
By default, the lease duration of a static address pool is unlimited, and the lease duration of a dynamic address pool is one day.
·     The lease duration cannot be less than 5 seconds.
·     The specified lease duration takes effect for the static binding, but the lease duration displayed by the display dhcp server ip-in-use all command is still Unlimited.
# Specify the lease duration as 1 day, 2 hours, 3 minutes, and 4 seconds in DHCP address pool 0.
[Sysname-dhcp-pool-0] expired day 1 hour 2 minute 3 second 4
forbidden-ip
forbidden-ip ip-address&<1-8>
undo forbidden-ip { ip-address&<1-8> | all }
View
DHCP extended address pool view
Default level
2: System level
ip-address&<1-8>: IP addresses to be excluded from dynamic allocation. &<1-8> indicates that you can specify up to eight IP addresses, separated with spaces.
all: Specifies all the IP addresses excluded from dynamic allocation.
Use forbidden-ip to exclude IP addresses from dynamic allocation in an extended address pool.
Use undo forbidden-ip to cancel the specified or all excluded IP addresses.
By default, all IP addresses in an extended address pool are assignable except the IP addresses of the DHCP server interfaces.
Only the extended address pools support this command.
IP addresses specified with the forbidden-ip command in DHCP address pool view are excluded from dynamic address allocation in the current extended address pool only. They are assignable in other address pools.
You can exclude multiple IP address ranges from dynamic allocation.
Related commands: dhcp server ip-pool and display dhcp server forbidden-ip.
# Exclude IP addresses 192.168.1.3 and 192.168.1.10 from dynamic allocation for extended address pool 0.
[Sysname] dhcp server ip-pool 0 extended
[Sysname-dhcp-pool-0] forbidden-ip 192.168.1.3 192.168.1.10
gateway-list
gateway-list ip-address&<1-8>
undo gateway-list { ip-address | all }
View
Default level
2: System level
ip-address&<1-8>: Gateway IP address. &<1-8> means you can specify up to eight gateway addresses separated by spaces.
all: Specifies all gateway IP addresses to be removed.
Use gateway-list to specify gateway addresses in a DHCP address pool.
Use undo gateway-list to remove specified gateway addresses specified for the DHCP client from a DHCP address pool.
By default, no gateway address is specified.
If you use the gateway-list command multiple times, the most recent configuration takes effect.
# Specify the gateway address 10.110.1.99 in DHCP address pool 0.
[Sysname-dhcp-pool-0] gateway-list 10.110.1.99
nbns-list
nbns-list ip-address&<1-8>
undo nbns-list { ip-address | all }
View
Default level
2: System level
ip-address&<1-8>: WINS server IP address. &<1-8> means you can specify up to eight WINS server addresses separated by spaces.
all: Specifies all WINS server addresses to be removed.
Use nbns-list to specify WINS server addresses in a DHCP address pool.
Use undo nbns-list to remove the specified WINS server addresses.
By default, no WINS server address is specified.
If you use the nbns-list command multiple times, the most recent configuration takes effect.
Related commands: dhcp server ip-pool, netbios-type, and display dhcp server tree.
# Specify WINS server address 10.12.1.99 in DHCP address pool 0.
[Sysname-dhcp-pool-0] nbns-list 10.12.1.99
netbios-type
undo netbios-type
View
Default level
2: System level
b-node: Specifies the broadcast node. A b-node client sends the destination name in a broadcast message to get the name-to-IP mapping from a server.
h-node: Specifies the hybrid node. An h-node client unicasts the destination name to a WINS server, and if receiving no response, then broadcasts it to get the mapping from a server.
m-node: Specifies the mixed node. An m-node client broadcasts the destination name, and if receiving no response, then unicasts the destination name to the WINS server to get the mapping.
p-node: Specifies the peer-to-peer node. A p-node client sends the destination name in a unicast message to get the mapping from the WINS server.
Use netbios-type to specify the client NetBIOS node type in a DHCP address pool.
Use undo netbios-type to remove the specified client NetBIOS node type.
By default, no NetBIOS node type is specified.
Related commands: dhcp server ip-pool, nbns-list, and display dhcp server tree.
# Specify the NetBIOS node type as b-node in DHCP address pool 0.
[Sysname-dhcp-pool-0] netbios-type b-node
network
network network-address [ mask-length | mask mask ]
undo network
View
Default level
2: System level
network-address: Network segment for dynamic allocation. If no mask length and mask is specified, the natural mask is used.
mask-length: Mask length in the range of 1 to 30.
mask mask: Specifies the IP address network mask, in dotted decimal format.
Use network to specify the network segment for dynamic allocation in a DHCP address pool.
Use undo network to remove the specified network segment.
No IP address range is specified by default.
You can specify only one network segment for each DHCP global address pool. If you use the network command multiple times, the most recent configuration takes effect.
# Specify 192.168.8.0/24 as the network segment for dynamic allocation in DHCP address pool 0.
[Sysname-dhcp-pool-0] network 192.168.8.0 mask 255.255.255.0
network ip range
network ip range min-address max-address
undo network ip range
View
Default level
2: System level
min-address: Lowest IP address for dynamic allocation.
max-address: Highest IP address for dynamic allocation.
Use network ip range to specify the IP address range for dynamic allocation in an address pool.
Use undo network ip range to remove the specified address range.
In a common address pool, you can use the network ip range command to further specify an IP address range on a subnet for address allocation. The specified IP address range must belong to the subnet, otherwise the common address pool cannot assign IP addresses.
You can specify only one IP address range for each extended address pool. If you use the network ip range command multiple times, the most recent configuration takes effect.
Related commands: dhcp server ip-pool, network, and display dhcp server tree.
# Specify addresses 10.1.1.1 through 10.1.1.150 on subnet 10.1.1.0/24 as the address range for dynamic address allocation in common address pool 1.
[Sysname] dhcp server ip-pool 1
[Sysname-dhcp-pool-1] network 10.1.1.0 24
[Sysname-dhcp-pool-1] network ip range 10.1.1.1 10.1.1.150
# Specify addresses 192.168.8.1 through 192.168.8.150 as the address range for dynamic address allocation in extended address pool 0.
[Sysname-dhcp-pool-0] network ip range 192.168.8.1 192.168.8.150
network mask
network mask mask
undo network mask
View
Default level
2: System level
mask: Network mask, in dotted decimal notation.
Use network mask to specify the IP address mask for dynamic allocation in an extended address pool.
Use undo network mask to remove the specified IP address mask.
No IP address mask is specified by default.
If you specify an IP address range for an extended address pool without an IP address mask, the extended address pool is not valid, and the system cannot assign IP addresses from the extended address pool.
Related commands: dhcp server ip-pool, network ip range, and display dhcp server tree.
# Specify 255.255.255.0 as the IP address mask for dynamic allocation in extended address pool 0.
[Sysname-dhcp-pool-0] network mask 255.255.255.0
next-server
next-server ip-address
undo next-server
View
Default level
2: System level
ip-address: IP address of a server.
Use next-server to specify the IP address of a server for DHCP clients.
Use undo next-server to remove the server's IP address from the DHCP address pool.
By default, no server's IP address is specified in the address pool on the DHCP server.
# Specify a server's IP address 1.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] next-server 1.1.1.1
option
option code { ascii ascii-string | hex hex-string&<1-16> | ip-address ip-address&<1-8> }
undo option code
View
Default level
2: System level
code: Self-defined option number in the range of 2 to 254, excluding 12, 50 to 55, 57 to 61, and 82.
ascii ascii-string: Specifies an ASCII string with 1 to 255 characters.
hex hex-string&<1-16>: Specifies hex digit strings. &<1-16> indicates that you can specify up to 16 hex digit strings, separated by spaces. Each string contains 2, 4, 6 or 8 hex digits.
ip-address ip-address&<1-8>: Specifies IP addresses. &<1-8> indicates that you can specify up to eight IP addresses, separated by spaces.
Use option to configure a self-defined DHCP option in a DHCP address pool.
Use undo option to remove a self-defined DHCP option from a DHCP address pool.
The option command is not configured by default.
If you use the option command multiple times, the most recent configuration takes effect.
Related commands: dhcp server ip-pool and play dhcp server tree.
# Configure the hex digits 0x11 and 0x22 for the self-defined DHCP Option 100 in DHCP address pool 0.
[Sysname-dhcp-pool-0] option 100 hex 11 22
reset dhcp server conflict { all | ip ip-address }
View
Default level
2: System level
all: Clears the statistics of all IP address conflicts.
ip ip-address: Clears the conflict statistics of the specified IP address.
Use reset dhcp server conflict to clear statistics of IP address conflicts.
Related commands: display dhcp server conflict.
# Clear the statistics of all IP address conflicts.
<Sysname> reset dhcp server conflict all
View
Default level
1: Monitor level
pool [ pool-name ]: Displays binding information about the specified address pool. The pool name is a string of 1 to 35 characters. If you do not specify any pool name, this command displays binding information about all address pools.
                  Hardware address
               2f31
Table 7 Command output
Pool utilization
Utilization rate of IP addresses in a DHCP address pool, which is the ratio of assigned IP addresses to assignable IP addresses in the DHCP address pool.
·     When binding information about all DHCP address pools is displayed, this field displays the total utilization rate of IP addresses in all DHCP address pools.
·     When binding information about a specific DHCP address pool is displayed, this field displays the utilization rate of IP addresses in the DHCP address pool.
IP address
Bound IP address.
Lease expiration
Binding types:
View
Default level
2: System level
None
Use reset dhcp server statistics to clear the statistics of the DHCP server.
Related commands: display dhcp server statistics.
# Clear the statistics of the DHCP server.
<Sysname> reset dhcp server statistics
static-bind client-identifier client-identifier
undo static-bind client-identifier
View
Default level
2: System level
client-identifier: The client ID of a static binding, a string with 4 to 160 characters in the format of H-H-H…, each H indicates 4 hex digits except the last H indicates 2 or 4 hex digits. For example, aabb-cccc-dd is a valid ID, while aabb-c-dddd and aabb-cc-dddd are both invalid.
Use static-bind client-identifier to specify the client ID of a static binding in a DHCP address pool.
Use undo static-bind client-identifier to remove the client ID of a static binding from a DHCP address pool.
By default, no client ID is specified.
Use the static-bind client-identifier command together with the static-bind ip-address command to accomplish a static binding configuration.
The ID of the static binding of a client must be identical to the ID displayed by using the display dhcp client verbose command on the client. Otherwise, the client cannot obtain an IP address.
If you use the static-bind client-identifier or static-bind mac-address command multiple times, the most recent configuration takes effect.
Related commands: dhcp server ip-pool, static-bind ip-address, static-bind mac-address, display dhcp server tree, and display dhcp client verbose.
# Bind the client ID aaaa-bbbb to the IP address 10.1.1.1 with the mask 255.255.255.0 in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind ip-address 10.1.1.1 mask 255.255.255.0
[Sysname-dhcp-pool-0] static-bind client-identifier aaaa-bbbb
static-bind ip-address ip-address [ mask-length | mask mask ]
undo static-bind ip-address
View
Default level
2: System level
ip-address: IP address of a static binding. If no mask and mask length is specified, the natural mask is used.
mask-length: Mask length of the IP address, in the range of 1 to 30.
mask mask: Specifies the IP address mask, in dotted decimal format.
Use static-bind ip-address to specify an IP address in a DHCP address pool for a static binding.
Use undo static-bind ip-address to remove the statically bound IP address.
By default, no IP address is statically bound in a DHCP address pool.
Use the static-bind ip-address command together with the static-bind mac-address or static-bind client-identifier command to accomplish a static binding configuration.
If the statically bound IP address is an interface address of the DHCP server, the static binding does not take effect.
If you use the static-bind ip-address command multiple times, the most recent configuration takes effect.
Related commands: dhcp server ip-pool, static-bind client-identifier, static-bind mac-address, and display dhcp server tree.
# Bind the client MAC address 0000-e03f-0305 to the IP address 10.1.1.1 with the mask 255.255.255.0 in DHCP address pool 0.
[Sysname-dhcp-pool-0] static-bind mac-address 0000-e03f-0305
static-bind mac-address mac-address
undo static-bind mac-address
View
Default level
2: System level
mac-address: The MAC address of a static binding, in the format of H-H-H.
Use static-bind mac-address to statically bind a MAC address to an IP address in a DHCP address pool.
Use undo static-bind mac-address to remove the statically bound MAC address.
By default, no MAC address is statically bound.
Use the static-bind mac-address command together with the static-bind ip-address command to complete a static binding configuration.
The IP address of the static binding cannot be an interface address of the DHCP server. Otherwise, an IP address conflict might occur and the bound client cannot obtain an IP address correctly.
If you use the static-bind mac-address or static-bind client-identifier command multiple times, the most recent configuration takes effect.
Relate command: dhcp server ip-pool, static-bind client-identifier, static-bind ip-address, and display dhcp server tree.
undo tftp-server domain-name
View
Default level
2: System level
domain-name: TFTP server name, a string of 1 to 63 characters.
Use tftp-server domain-name to specify a TFTP server name in a DHCP address pool.
Use undo tftp-server domain-name to remove the TFTP server name from a DHCP address pool.
By default, no TFTP server name is specified.
If you use the tftp-server domain-name command multiple times, the most recent configuration takes effect.
# Specify the TFTP server name as aaa in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server domain-name aaa
undo tftp-server ip-address
View
Default level
2: System level
ip-address: TFTP server IP address.
Use tftp-server ip-address to specify the TFTP server IP address in a DHCP address pool.
Use undo tftp-server ip-address to remove the TFTP server IP address from a DHCP address pool.
By default, no TFTP server address is specified.
If you use the tftp-server ip-address command multiple times, the most recent configuration takes effect.
# Specify the TFTP server address 10.1.1.1 in DHCP address pool 0.
[Sysname-dhcp-pool-0] tftp-server ip-address 10.1.1.1
vendor-class-identifier hex-string&<1-255> ip range min-address max-address
undo vendor-class-identifier hex-string&<1-255>
View
Default level
2: System level
hex-string&<1-255>: A character string, which is used to match against Option 60 (vendor class identifier option). hex-string is a hexadecimal number in the range of 0 to FF. &<1-255> indicates that you can type up to 255 hexadecimal numbers, which are separated by spaces.
ip range min-address max-address: Specifies the IP address range for dynamic allocation. min-address is the lowest IP address and max-address is the highest IP address for dynamic allocation.
Use vendor-class-identifier to specify an IP address range for the DHCP clients of the specified vendor.
Use undo vendor-class-identifier to restore the default.
By default, no IP address range is specified for the DHCP clients of any vendor.
After this feature is configured in an extended DHCP address pool, the DHCP server, when using the extended DHCP address pool to assign an IP address to a DHCP client, checks whether Option 60 in the DHCP request is the same as the character string configured with the vendor-class-identifier command. If yes, the DHCP server selects an IP address from the address range specified with this command. If not, the DHCP server selects one from the address range specified with the network ip range command.
Only extended address pools support this command.
The IP address range specified with this command must be included in that specified with the network ip range command.
Related commands: network ip range and network mask.
# Specify IP address rang 10.1.1.1 to 10.1.1.5 for the DHCP clients of vender a0 b0 0c.
[Sysname-dhcp-pool-0] vendor-class-identifier a0 b0 0c ip range 10.1.1.1 10.1.1.5
voice-config
voice-config { as-ip ip-address | fail-over ip-address dialer-string | ncp-ip ip-address | voice-vlan vlan-id { disable | enable } }
undo voice-config [ as-ip | fail-over | ncp-ip | voice-vlan ]
View
Default level
2: System level
as-ip ip-address: Specifies the IP address for the backup network calling processor. When the primary network calling processor is unavailable, the DHCP client uses the backup network calling processor.
fail-over ip-address dialer-string: Specifies the failover IP address and dialer string. The dialer-string is a string of 1 to 39 characters, which can be 0 to 9, and "*".
ncp-ip ip-address: Specifies the IP address for the primary network calling processor.
voice-vlan vlan-id: Specifies the voice VLAN ID in the range of 2 to 4094.
·     disable: Disables the specified voice VLAN ID, meaning DHCP clients do not take this ID as their voice VLAN.
·     enable: Enables the specified voice VLAN ID, meaning DHCP clients take this ID as their voice VLAN.
Use voice-config to configure specified Option 184 contents in a DHCP address pool.
Use undo voice-config to remove specified Option 184 contents from a DHCP address pool.
By default, no Option 184 content is configured.
You must specify the IP address of a network calling processor first to make other configured parameters take effect.
# Configure Option 184 in DHCP address pool 0: the primary network calling processor 10.1.1.1, backup network calling processor 10.2.2.2, voice VLAN ID 3 that is enabled, the failover IP address 10.3.3.3 and dialer string 99*.
[Sysname-dhcp-pool-0] voice-config ncp-ip 10.1.1.1
[Sysname-dhcp-pool-0] voice-config as-ip 10.2.2.2
[Sysname-dhcp-pool-0] voice-config voice-vlan 3 enable
[Sysname-dhcp-pool-0] voice-config fail-over 10.3.3.3 99*
The DHCP relay agent configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, and Layer 3 aggregate interfaces.
undo dhcp relay address-check enable
View
Interface view
Default level
2: System level
None
Use dhcp relay address-check enable to enable address check on the relay agent.
Use undo dhcp relay address-check enable to disable address check on the relay agent.
With this feature enabled, the DHCP relay agent can dynamically record clients' IP-to-MAC bindings after clients get IP addresses through DHCP. It also supports static bindings. You can manually configure IP-to-MAC bindings on the DHCP relay agent, so that users can access external networks using fixed IP addresses.
Upon receiving an ARP packet, the DHCP relay agent matches the sender's IP and MAC addresses in the packet against the bindings (both dynamic and static). If no match is found, the DHCP relay agent does not learn the ARP entry, and thus the sending host cannot access external networks through the DHCP relay agent.
The dhcp relay address-check enable command only checks IP and MAC addresses of clients.
# Enable IP address match check on the DHCP relay agent.
[Sysname-Vlan-interface2] dhcp relay address-check enable
undo dhcp relay check mac-address
View
Interface view
Default level
2: System level
None
Use dhcp relay check mac-address to enable MAC address check on the DHCP relay agent.
Use undo dhcp relay check mac-address to disable MAC address check on the DHCP relay agent.
By default, this function is disabled.
With this function enabled, the DHCP relay agent compares the chaddr field of a received DHCP request with the source MAC address field of the frame. If they are the same, the DHCP relay agent decides this request as valid and forwards it to the DHCP server. If not, the DHCP request is discarded.
DHCP relay agents change the source MAC addresses when forwarding DHCP packets. Therefore, you can enable MAC address check only on a DHCP relay agent directly connected to the DHCP clients. Otherwise, valid DHCP packets might be discarded and clients cannot obtain IP addresses.
# Enable MAC address check on the DHCP relay agent.
[Sysname-Vlan-interface10] dhcp relay check mac-address
undo dhcp relay client-detect enable
View
Interface view
Default level
2: System level
None
Use dhcp relay client-detect enable to enable offline detection on the DHCP relay agent.
Use undo dhcp relay client-detect enable to disable offline detection on the DHCP relay agent.
With this feature enabled, the DHCP relay agent considers a DHCP client goes offline when the ARP entry for the client ages out. In addition, it removes the client entry and sends a DHCP-RELEASE message to the DHCP server to release the IP address of the client.
# Enable offline detection on the DHCP relay agent.
[Sysname-Vlan-interface10] dhcp relay client-detect enable
dhcp relay information circuit-id format-type { ascii | hex }
undo dhcp relay information circuit-id format-type
View
Interface view
Default level
2: System level
ascii: Specifies the code type for the circuit ID sub-option as ascii.
hex: Specifies the code type for the circuit ID sub-option as hex.
Use dhcp relay information circuit-id format-type to configure the code type for the non-user-defined circuit ID sub-option.
Use undo dhcp relay information circuit-id format-type to restore the default.
By default, the code type for the circuit ID sub-option depends on the specified padding format of Option 82. Each field has its own code type.
This command applies to configuring the non-user-defined circuit ID sub-option only. After you configure the padding content for the circuit ID sub-option using the dhcp relay information circuit-id string command, ASCII is adopted as the code type.
Related commands: display dhcp relay information.
# Configure the code type for the non-user-defined circuit ID sub-option as ascii.
[Sysname-Vlan-interface2] dhcp relay information circuit-id format-type ascii
dhcp relay information circuit-id string circuit-id
undo dhcp relay information circuit-id string
View
Interface view
Default level
2: System level
circuit-id: Padding content for the user-defined circuit ID sub-option, a case-sensitive string of 3 to 63 characters.
Use dhcp relay information circuit-id string to configure the padding content for the user-defined circuit ID sub-option.
Use undo dhcp relay information circuit-id string to restore the default.
By default, the padding content for the circuit ID sub-option depends on the padding format of Option 82.
After you configure the padding content for the circuit ID sub-option using this command, ASCII is adopted as the code type.
Related commands: dhcp relay information format and display dhcp relay information.
# Configure the padding content for the circuit ID sub-option as company001.
[Sysname-Vlan-interface2] dhcp relay information circuit-id string company001
undo dhcp relay information enable
View
Interface view
Default level
2: System level
None
Use dhcp relay information enable to enable the relay agent to support Option 82.
Use undo dhcp relay information enable to disable Option 82 support.
By default, DHCP relay is not allowed to support Option 82.
# Enable Option 82 support on the relay agent.
[Sysname-Vlan-interface2] dhcp relay information enable
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp relay information format
View
Interface view
Default level
2: System level
normal: Specifies the normal padding format.
verbose: Specifies the verbose padding format.
node-identifier { mac | sysname | user-defined node-identifier }: Specifies access node identifier. By default, the node MAC address is used as the node identifier.
·     mac indicates using MAC address as the node identifier.
·     sysname indicates using the device name of a node as the node identifier.
·     user-defined node-identifier indicates using the specified character string as the node identifier, in which node-identifier is a string with 1 to 50 characters.
Use dhcp relay information format to specify a padding format for Option 82.
Use undo dhcp relay information format to restore the default padding format.
The Option 82 padding format defaults to normal.
If configuring the handling strategy of the DHCP relay agent as replace, you need to configure a padding format of Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
If sub-option 1 (node identifier) of Option 82 is padded with the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP relay agent drops the message.
# Specify the verbose padding format for Option 82.
[Sysname-Vlan-interface2] dhcp relay information strategy replace
[Sysname-Vlan-interface2] dhcp relay information format verbose
dhcp relay information remote-id format-type { ascii | hex }
undo dhcp relay information remote-id format-type
View
Interface view
Default level
2: System view
ascii: Specifies the code type for the remote ID sub-option as ascii.
hex: Specifies the code type for the remote ID sub-option as hex.
Use dhcp relay information remote-id format-type to configure the code type for the non-user-defined remote ID sub-option.
Use undo dhcp relay information remote-id format-type to restore the default.
By default, the code type for the remote ID sub-option is HEX.
This command applies to configuring the non-user-defined remote ID sub-option only. After you configure the padding content for the remote ID sub-option using the dhcp relay information remote-id string command, ASCII is adopted as the code type.
# Configure the code type for the non-user-defined remote ID sub-option as ascii.
[Sysname-Vlan-interface2] dhcp relay information remote-id format-type ascii
dhcp relay information remote-id string { remote-id | sysname }
undo dhcp relay information remote-id string
View
Interface view
Default level
2: System level
remote-id: Padding content for the user-defined remote ID sub-option, a case-sensitive string of 1 to 63 characters.
sysname: Specifies the device name as the padding content for the remote ID sub-option.
Use dhcp relay information remote-id string to configure the padding content for the user-defined remote ID sub-option.
Use undo dhcp relay information remote-id string to restore the default.
By default, the padding content for the remote ID sub-option depends on the padding format of Option 82.
After you configure the padding content for the remote ID sub-option using this command, ASCII is adopted as the code type.
If you want to specify the character string sysname (a case-insensitive character string) as the padding content for the remote ID sub-option, you need to use quotation marks to make it take effect. For example, if you want to specify Sysname as the padding content for the remote ID sub-option, you need to enter the dhcp relay information remote-id string "Sysname" command.
# Configure the padding content for the remote ID sub-option as device001.
[Sysname-Vlan-interface2] dhcp relay information remote-id string device001
undo dhcp relay information strategy
View
Interface view
Default level
2: System level
drop: Specifies to drop messages containing Option 82.
keep: Specifies to forward messages containing Option 82 without any change.
replace: Specifies to forward messages containing Option 82 after replacing the original Option 82 with the Option 82 padded in the specified padding format.
Use dhcp relay information strategy to configure DHCP relay agent handling strategy for messages containing Option 82.
Use undo dhcp relay information strategy to restore the default handling strategy.
The handling strategy for messages containing Option 82 defaults to replace.
# Configure the DHCP relay agent handling strategy for messages containing Option 82 as keep.
[Sysname-Vlan-interface2] dhcp relay information strategy keep
dhcp relay release ip client-ip
View
Default level
2: System level
client-ip: DHCP client IP address.
Use dhcp relay release ip to request the DHCP server to release the specified client IP address.
# Request the DHCP server to release the IP address 1.1.1.1.
[Sysname] dhcp relay release ip 1.1.1.1
dhcp relay security static ip-address mac-address [ interface interface-type interface-number ]
undo dhcp relay security { ip-address | all | dynamic | interface interface-type interface-number | static }
View
Default level
2: System level
ip-address: Client IP address for creating a static binding.
mac-address: Client MAC address for creating a static binding, in the format H-H-H.
interface interface-type interface-number: Specifies a Layer 3 interface connecting to the DHCP client. interface-type interface-number specifies the interface type and interface number.
all: Specifies all client entries to be removed.
dynamic: Specifies dynamic client entries to be removed.
static: Specifies manual client entries to be removed.
Use dhcp relay security static to configure a static client entry. The binding between IP address, MAC address, and Layer 3 interface on the relay agent.
Use undo dhcp relay security to remove specified client entries from the relay agent.
No manual client entry is configured on the DHCP relay agent by default.
When using the dhcp relay security static command to bind an interface to a static client entry, make sure the interface is configured as a DHCP relay agent. Otherwise, entry conflicts might occur.
The undo dhcp relay security interface command is used to remove all the dynamic client entries from the interface.
Related commands: display dhcp relay security.
# Bind DHCP relay interface VLAN-interface 2 to IP address 10.10.1.1 and MAC address 0005-5d02-f2b3 of the client.
[Sysname] dhcp relay security static 10.10.1.1 0005-5d02-f2b3 interface vlan-interface 2
undo dhcp relay security refresh enable
View
Default level
2: System level
None
Use dhcp relay security refresh enable to enable the DHCP relay agent to periodically refresh dynamic client entries.
Use undo dhcp relay security refresh enable to disable periodic refresh of dynamic client entries.
By default, the DHCP relay agent is enabled to periodically refresh dynamic client entries.
If you disable the DHCP relay agent from periodically refreshing dynamic client entries, such entries do not age automatically. You must manually remove a dynamic client entry on the DHCP relay agent if a client relinquishes its IP address.
Related commands: dhcp relay security tracker and dhcp relay security static.
# Disable the DHCP relay agent from periodically refreshing dynamic client entries.
[Sysname] undo dhcp relay security refresh enable
dhcp relay security tracker { interval | auto }
undo dhcp relay security tracker [ interval ]
View
Default level
2: System level
interval: Refreshing interval in seconds, in the range of 1 to 120.
auto: Specifies the auto refreshing interval, which is the value of 60 seconds divided by the number of binding entries. Thus, the more entries are, the shorter interval is, but the shortest interval is no less than 500 ms.
Use dhcp relay security tracker to set a refreshing interval at which the relay agent contacts the DHCP server for refreshing dynamic bindings.
Use undo dhcp relay security tracker to restore the default interval.
The default refreshing interval is auto, the value of 60 seconds divided by the number of binding entries.
Related commands: display dhcp relay security tracker.
# Set the refreshing interval to 100 seconds.
[Sysname] dhcp relay security tracker 100
dhcp relay server-detect
undo dhcp relay server-detect
View
Default level
2: System level
None
Use dhcp relay server-detect to enable unauthorized DHCP server detection.
Use undo dhcp relay server-detect to disable unauthorized DHCP server detection.
By default, unauthorized DHCP server detection is disabled.
With this function enabled, upon receiving a DHCP request, the DHCP relay agent records the IP addresses of all DHCP servers which ever offered IP addresses to the DHCP client and the receiving interface. Each server detected is recorded only once. The administrator can use this information from logs to check for unauthorized DHCP servers.
After information about recorded DHCP servers is cleared, the relay agent re-records server information following this mechanism.
[Sysname] dhcp relay server-detect
dhcp relay server-group
dhcp relay server-group group-id ip ip-address
undo dhcp relay server-group group-id [ ip ip-address ]
View
Default level
2: System level
group-id: DHCP server group number in the range of 0 to 19.
ip ip-address: DHCP server IP address.
Use dhcp relay server-group to specify a DHCP server for a DHCP server group.
Use undo dhcp relay server-group to remove a DHCP server from a DHCP server group, if you do not specify any ip ip-address, all servers in the DHCP server group and the server group itself are removed.
By default, no DHCP server is specified for a DHCP server group.
The IP address of a DHCP server and that of the interface of a client connected to a DHCP relay agent cannot be in the same network segment. Otherwise, the client might fail to obtain an IP address.
If a server group has been correlated to multiple interfaces, you need to cancel these correlations before removing the server group.
Related commands: display dhcp relay server-group.
# Specify DHCP server 1.1.1.1 for DHCP server group 1 on the relay agent.
[Sysname] dhcp relay server-group 1 ip 1.1.1.1
dhcp relay server-select
dhcp relay server-select group-id
undo dhcp relay server-select
View
Interface view
Default level
2: System level
group-id: DHCP server group number to be correlated, in the range of 0 to 19.
Use dhcp relay server-select to correlate specified interfaces to the specified DHCP server group.
Use undo dhcp relay server-select to remove a configured correlation.
By default, no DHCP server group is correlated with an interface on the relay agent.
A DHCP server group can correlate with one or multiple DHCP relay agent interfaces.
A relay agent interface can only correlate with one DHCP server group, and a newly configured correlation overwrites the previous one. If the server group in the new correlation does not exist, the new configuration will not work. The interface still maintains the previous correlation.
The DHCP server group referenced in this command should have been configured by using the dhcp relay server-group command.
Related commands: dhcp relay server-group and display dhcp relay.
# Correlate VLAN-interface 2 to DHCP server group 1.
[Sysname-Vlan-interface2] dhcp relay server-select 1
dhcp select relay
dhcp select relay
undo dhcp select relay
View
Interface view
Default level
2: System level
None
Use dhcp select relay to enable the relay agent on the current interface. Upon receiving requests from an enabled interface, the relay agent forwards these requests to outside DHCP servers for IP address allocation.
Use undo dhcp select relay to restore the default.
After DHCP is enabled, the DHCP server is enabled on an interface by default. Upon receiving a client's request from the interface, the DHCP server allocates an IP address from the DHCP address pool to the client.
When the working mode of the interface is changed from DHCP server to DHCP relay agent, neither the IP address leases nor the authorized ARP entries are deleted. However, these ARP entries might conflict with new ARP entries generated on the DHCP relay agent. H3C recommends that you delete the existing IP address leases when changing the interface working mode to DHCP relay agent.
# Enable the DHCP relay agent on VLAN-interface 2.
[Sysname-Vlan-interface2] dhcp select relay
display dhcp relay
display dhcp relay { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays information about DHCP server groups that all interfaces correspond to.
interface interface-type interface-number: Displays information about the DHCP server group that the specified interface corresponds to.
Use display dhcp relay to display information about DHCP server groups correlated to an interface or all interfaces.
# Display information about DHCP server groups correlated to all interfaces.
<Sysname> display dhcp relay all
    Interface name            Server-group
    Vlan-interface 2         1
Table 8 Command output
Server-group
DHCP server group number correlated to the interface.
display dhcp relay information { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays Option 82 configuration information about all interfaces.
interface interface-type interface-number: Displays Option 82 configuration information about the specified interface.
Use display dhcp relay information to display Option 82 configuration information on the DHCP relay agent.
# Display Option 82 configuration information about all interfaces.
<Sysname> display dhcp relay information all
Interface: Vlan-interface100
    Status: Enable
    Strategy: Replace
    Format: Verbose
    Circuit ID format-type: HEX
    Remote ID format-type: ASCII
    Node identifier: aabbcc
    User defined:
         Circuit ID: company001
Interface: Vlan-interface200
    Status: Enable
    Strategy: Keep
    Format: Normal
    User defined:
         Remote ID: device001
Table 9 Command output
Interface name.
Status
Option 82 state, Enable or Disable.
Strategy
Handling strategy for requesting messages containing Option 82, Drop, Keep, or Replace.
Format
Padding format of Option 82, Normal or Verbose.
Non-user-defined code type of the circuit ID sub-option, ASCII or HEX.
Non-user-defined code type of the remote ID sub-option, ASCII or HEX.
Node identifier
Access node identifier.
User defined
Content of user-defined sub-options.
Circuit ID
User-defined padding content of the circuit ID sub-option.
Remote ID
User-defined padding content of the remote ID sub-option.
display dhcp relay security [ ip-address | dynamic | static ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip-address: Displays binding information about an IP address.
dynamic: Displays information about dynamic bindings.
static: Displays information about static bindings.
Use display dhcp relay security to display information about bindings of DHCP relay agents. If you do not specify any parameter, this command displays information about all bindings.
You need to enable address check, authorized ARP support, or IP Source Guard on the DHCP relay agent before it can generate dynamic client entries. For more information about IP source guard, see Security Configuration Guide.
# Display information about all bindings.
<Sysname> display dhcp relay security
IP Address      MAC Address     Type       Interface
10.1.1.5       00e0-0000-0000  Static     Vlan2
---   1 dhcp-security item(s) found   ---
Table 10 Command output
IP Address
Client IP address.
MAC Address
Client MAC address.
Binding types, dynamic, static, and temporary.
Layer 3 interface connecting to the DHCP client. If no interface is recorded in the binding entry, N/A is displayed.
display dhcp relay security statistics
display dhcp relay security statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp relay security statistics to display statistics information about bindings of DHCP relay agents.
You need to enable address check, authorized ARP support, or IP source guard on the DHCP relay agent before it can generate dynamic client entries. For more information about IP source guard, see Security Configuration Guide.
# Display statistics about bindings of DHCP relay agents.
<Sysname> display dhcp relay security statistics
Static Items      :1
Dynamic Items     :0
Temporary Items   :0
All Items         :1
Table 11 Command output
Static Items
Static binding items.
Dynamic Items
Dynamic binding items.
Temporary Items
Temporary binding items.
All Items
All binding items.
display dhcp relay security tracker [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp relay security tracker to display the interval for refreshing dynamic bindings on the relay agent.
# Display the interval for refreshing dynamic bindings on the relay agent.
<Sysname> display dhcp relay security tracker
Current tracker interval : 10s
The interval is 10 seconds.
display dhcp relay server-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: Displays information about the specified DHCP server group numbered from 0 to 19.
all: Displays information about all DHCP server groups.
Use display dhcp relay server-group to display configuration information about the specified or all DHCP server groups.
# Display IP addresses of DHCP servers in DHCP server group 1.
<Sysname> display dhcp relay server-group 1
    No.            Group IP
    1              1.1.1.1
    2              1.1.1.2
Table 12 Command output
No.
Sequence number.
Group IP
IP address in the server group.
display dhcp relay statistics
display dhcp relay statistics [ server-group { group-id | all } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-id: Specifies a server group number in the range of 0 to 19 about which to display DHCP packet statistics.
all: Specifies all server groups about which to display DHCP packet statistics. Information about each group is displayed.
Use display dhcp relay statistics to display DHCP packet statistics related to the specified or all DHCP server groups.
If you do not specify any parameter, this command displays all DHCP packet statistics on the relay agent.
Related commands: reset dhcp relay statistics.
# Display all DHCP packet statistics on the relay agent.
<Sysname> display dhcp relay statistics
     Bad packets received:                    0
     DHCP packets received from clients:      0
         DHCPDISCOVER packets received:       0
         DHCPREQUEST packets received:        0
         DHCPINFORM packets received:         0
         DHCPRELEASE packets received:        0
         DHCPDECLINE packets received:        0
         BOOTPREQUEST packets received:       0
     DHCP packets received from servers:      0
         DHCPOFFER packets received:          0
         DHCPACK packets received:            0
         DHCPNAK packets received:            0
         BOOTPREPLY packets received:         0
     DHCP packets relayed to servers:         0
         DHCPDISCOVER packets relayed:        0
         DHCPREQUEST packets relayed:         0
         DHCPINFORM packets relayed:          0
         DHCPRELEASE packets relayed:         0
         DHCPDECLINE packets relayed:         0
         BOOTPREQUEST packets relayed:        0
     DHCP packets relayed to clients:         0
         DHCPOFFER packets relayed:           0
         DHCPACK packets relayed:             0
         DHCPNAK packets relayed:             0
         BOOTPREPLY packets relayed:          0
     DHCP packets sent to servers:            0
         DHCPDISCOVER packets sent:           0
         DHCPREQUEST packets sent:            0
         DHCPINFORM packets sent:             0
         DHCPRELEASE packets sent:            0
         DHCPDECLINE packets sent:            0
         BOOTPREQUEST packets sent:           0
     DHCP packets sent to clients:            0
         DHCPOFFER packets sent:              0
         DHCPACK packets sent:                0
         DHCPNAK packets sent:                0
         BOOTPREPLY packets sent:             0
# Display DHCP packet statistics related to every server group on the relay agent.
<Sysname> display dhcp relay statistics server-group all
DHCP relay server-group           #0
     Packet type               Packet number
 Client -> Server:
     DHCPDISCOVER                   0
     DHCPREQUEST                    0
     DHCPINFORM                     0
     DHCPRELEASE                    0
     DHCPDECLINE                    0
     BOOTPREQUEST                   0
 Server -> Client:
     DHCPOFFER                      0
     DHCPACK                        0
     DHCPNAK                        0
     BOOTPREPLY                     0
reset dhcp relay statistics [ server-group group-id ]
View
Default level
1: Monitor level
server-group group-id: Specifies a server group ID (in the range of 0 to 19) about which to remove statistics from the relay agent.
Use reset dhcp relay statistics to remove statistics from the relay agent.
If you do not specify any server-group, this command removes all statistics from the relay agent.
Related commands: display dhcp relay statistics.
# Remove all statistics from the DHCP relay agent.
<Sysname> reset dhcp relay statistics
DHCP client configuration commands
The DHCP client configuration is supported only on Layer 3 Ethernet interfaces (or subinterfaces), VLAN interfaces, and Layer 3 aggregate interfaces.
An interface in an aggregation group cannot be enabled with the DHCP client.
To enable multiple VLAN interfaces with the same MAC address to use the DHCP client to get IP addresses through a relay agent, the DHCP server must not run on Windows Server 2000 or Windows Server 2003.
display dhcp client
display dhcp client [ verbose ] [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays detailed DHCP client information.
interface interface-type interface-number: Displays DHCP client information about the specified interface.
Use display dhcp client to display DHCP client information. If you do not specify any interface, this command displays DHCP client information about all interfaces.
# Display DHCP client information about all interfaces.
<Sysname> display dhcp client
Vlan-interface1 DHCP client information:
 Current machine state: BOUND
 Allocated IP: 40.1.1.20 255.255.255.0
 Allocated lease: 259200 seconds, T1: 129600 seconds, T2: 226800 seconds
 DHCP server: 40.1.1.2
# Display verbose DHCP client information.
<Sysname> display dhcp client verbose
 Lease from 2005.08.13 15:37:59   to   2005.08.16 15:37:59
 Transaction ID: 0x1c09322d
 Default router: 40.1.1.2
 Classless static route:
   Destination: 1.1.0.1, Mask: 255.0.0.0, NextHop: 192.168.40.16
   Destination: 10.198.122.63, Mask: 255.255.255.255, NextHop: 192.168.40.16
 DNS server: 44.1.1.11
 DNS server: 44.1.1.12
 Domain name: ddd.com
 Boot server: 200.200.200.200  1.1.1.1
 Client ID: 3030-3066-2e65-3234-
            392e-3830-3438-2d56-
            6c61-6e2d-696e-7465-
            7266-6163-6531
T1 will timeout in 1 day 11 hours 58 minutes 52 seconds.
Table 13 Command output
Interface enabled with the DHCP client.
Current state of the DHCP client:
·     HALT—The client stops applying for an IP address.
·     INIT—The initialization state.
·     SELECTING—The client has sent out a DHCP-DISCOVER message in search of a DHCP server and is waiting for the response from DHCP servers.
·     REQUESTING—The client has sent out a DHCP-REQUEST message requesting for an IP address and is waiting for the response from DHCP servers.
·     BOUND—The client has received the DHCP-ACK message from a DHCP server and obtained an IP address successfully.
·     RENEWING—The T1 timer expires.
·     REBOUNDING—The T2 timer expires.
Allocated IP
IP address allocated by the DHCP server.
Allocated lease
Allocated lease time.
T1
1/2 lease time (in seconds) of the DHCP client IP address.
T2
7/8 lease time (in seconds) of the DHCP client IP address.
Lease from….to….
Start and end time of the lease.
DHCP server
DHCP server IP address that assigned the IP address.
Transaction ID
Transaction ID, a random number chosen by the client to identify an IP address allocation.
Default router
Gateway address assigned to the client.
Classless static routes assigned to the client.
Static route
Classful static routes assigned to the client.
DNS server
DNS server address assigned to the client.
Domain name
Domain name suffix assigned to the client.
Boot server
PXE server addresses (up to 16 addresses) specified for the DHCP client, which are obtained through Option 43.
Client ID
Client ID.
How long the T1 (1/2 lease time) timer will expire.
ip address dhcp-alloc
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ]
undo ip address dhcp-alloc
View
Interface view
Default level
2: System level
client-identifier mac interface-type interface-number: Enables an interface to use its MAC address as the client ID to obtain an IP address.
Use ip address dhcp-alloc to enable the DHCP client on the interface.
Use undo ip address dhcp-alloc to disable the DHCP client on the interface.
By default, an interface does not use DHCP for IP address acquisition.
If you do not specify any parameter, the client uses a character string comprised of the current interface name and MAC address as the client ID for address acquisition.
If you release the IP address of the interface, the DHCP client sends a DHCP-RELEASE message to inform the server to release the IP address.
If a subinterface has obtained an IP address by using the DHCP client, using the shutdown command on the primary interface does not make the DHCP client send a DHCP-RELEASE message for releasing the subinterface's IP address.
# Enable the DHCP client on VLAN-interface 1.
[Sysname-Vlan-interface1] ip address dhcp-alloc
The DHCP snooping enabled switch can work only when it is between the DHCP client and relay agent or between the DHCP client and server, and it does not work if it is between the DHCP relay agent and DHCP server.
dhcp-snooping
dhcp-snooping
undo dhcp-snooping
View
Default level
2: System level
None
Use dhcp-snooping to enable DHCP snooping.
Use undo dhcp-snooping to disable DHCP snooping.
With DHCP snooping disabled, all ports can forward responses from any DHCP servers and does not record binding information about MAC addresses of DHCP clients and the obtained IP addresses.
By default, DHCP snooping is disabled.
Related commands: display dhcp-snooping.
# Enable DHCP snooping.
[Sysname] dhcp-snooping
dhcp-snooping binding database filename
dhcp-snooping binding database filename filename
undo dhcp-snooping binding database filename
View
Default level
2: System level
filename: File name. For information about defining the file name, see Fundamentals Configuration Guide.
Use dhcp-snooping binding database filename to specify the name of the file for storing DHCP snooping bindings.
Use undo dhcp-snooping binding database filename to restore the default.
By default, no file name is specified.
If no file with the specified name is found, the switch automatically creates the file upon storing a DHCP snooping binding.
DHCP snooping bindings are stored immediately after this command is used, and then updated at the interval set by the dhcp-snooping binding database update interval command.
If you specify a subdirectory in the name of the file that stores DHCP snooping entries, make sure the subdirectory is available on each MPU. Otherwise, the system fails to create the file on MPUs without the specified subdirectory. To solve this problem, cancel the current configuration and specify a new subdirectory in the file name.
Related commands: dhcp-snooping binding database update interval.
# Specify the name of the file for storing DHCP snooping bindings as database.dhcp.
[Sysname] dhcp-snooping binding database filename database.dhcp
dhcp-snooping binding database update interval minutes
undo dhcp-snooping binding database update interval
View
Default level
2: System level
minutes: Refresh interval in minutes, in the range of 1 to 14400.
Use dhcp-snooping binding database update interval to set the interval at which the DHCP snooping binding file is refreshed.
Use undo dhcp-snooping binding database update interval to restore the default.
By default, the DHCP snooping binding file is not refreshed periodically.
With this command configured, DHCP snooping checks bindings periodically. If a binding is added or removed during an interval, DHCP snooping adds or removes this binding to or from the file at the end of this interval. If no change occurs within the interval, DHCP snooping does not refresh the file.
This command takes effect only when the DHCP snooping binding file is specified.
Related commands: dhcp-snooping binding database filename.
# Configure the DHCP snooping binding file to be refreshed every 10 minutes.
[Sysname] dhcp-snoooping binding database update interval 10
dhcp-snooping binding database update now
View
Default level
2: System level
None
Use dhcp-snooping binding database update now to store DHCP snooping bindings to the file.
DHCP snooping bindings will be stored to the file each time this command is used.
# Store DHCP snooping bindings to the file.
[Sysname] dhcp-snooping binding database update now
dhcp-snooping check mac-address
undo dhcp-snooping check mac-address
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
Default level
2: System level
None
Use dhcp-snooping check mac-address to enable MAC address check on a DHCP snooping switch.
Use undo dhcp-snooping check mac-address to disable MAC address check of DHCP snooping.
With this function enabled, the DHCP snooping switch compares the chaddr field of a received DHCP request with the source MAC address field in the frame. If they are the same, the DHCP snooping switch decides this request valid and forwards it to the DHCP server. If not, the DHCP request is discarded.
# Enable MAC address check of DHCP snooping.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] dhcp-snooping check mac-address
dhcp-snooping check request-message
undo dhcp-snooping check request-message
View
Default level
2: System level
None
Use dhcp-snooping check request-message to enable DHCP-REQUEST message check of DHCP snooping.
Use undo dhcp-snooping check request-message to disable DHCP-REQUEST message check of the DHCP snooping.
With this function enabled, upon receiving a DHCP-REQUEST message, a DHCP snooping switch searches local DHCP snooping entries for the corresponding entry of the message. If an entry is found, the DHCP snooping switch compares the entry with the message information. If they are consistent, the DHCP-REQUEST message is considered as valid lease renewal request and forwarded to the DHCP server. If they are not consistent, the messages is considered as forged lease renewal request and discarded. If no corresponding entry is found locally, the message is considered valid and forwarded to the DHCP server.
# Enable DHCP-REQUEST message check of DHCP snooping.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping check request-message
dhcp-snooping information circuit-id format-type
dhcp-snooping information circuit-id format-type { ascii | hex }
undo dhcp-snooping information circuit-id format-type
View
Default level
2: System level
Use dhcp-snooping information circuit-id format-type to configure the code type for the non-user-defined circuit ID sub-option.
Use undo dhcp-snooping information circuit-id format-type to restore the default.
By default, the code type for the circuit ID sub-option depends on the padding format of Option 82. Each field has its own code type.
This command applies to configuring the non-user-defined circuit ID sub-option only. After you configure the padding content for the circuit ID sub-option using the dhcp-snooping information circuit-id string command, ASCII is adopted as the code type. The private padding format supports only the hex code type.
Related commands: display dhcp-snooping information and dhcp-snooping information format.
# Configure the padding format for the non-user-defined circuit ID sub-option as ascii.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information circuit-id format-type ascii
dhcp-snooping information [ vlan vlan-id ] circuit-id string circuit-id
undo dhcp-snooping information [ vlan vlan-id ] circuit-id string
View
Default level
2: System level
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
Use dhcp-snooping information circuit-id string to configure the padding content for the user-defined circuit ID sub-option.
Use undo dhcp-snooping information circuit-id string to restore the default.
If a VLAN is specified, the configured circuit ID sub-option only takes effect within the VLAN. If no VLAN is specified, the configured circuit ID sub-option takes effect in all VLANs. The former case has a higher priority. The circuit ID sub-option specified for a VLAN will be padded for packets within the VLAN.
Related commands: dhcp-snooping information format and display dhcp-snooping information.
# Configure the global padding content for the user-defined circuit ID sub-option as company001.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information circuit-id string company001
dhcp-snooping information enable
undo dhcp-snooping information enable
View
Default level
2: System level
None
Use dhcp-snooping information enable to configure DHCP snooping to support Option 82.
Use undo dhcp-snooping information enable to disable this function.
By default, DHCP snooping does not support Option 82.
Related commands: display dhcp-snooping information.
# Configure DHCP snooping to support Option 82.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information enable
dhcp-snooping information format { normal | private private | standard | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] }
undo dhcp-snooping information format
View
Default level
2: System level
private private: Specifies the private padding format. The private value can only be 1, which represents the private padding format.
standard: Specifies the standard padding format.
·     user-defined node-identifier indicates using the specified character string as the node identifier, in which node-identifier is a string of 1 to 50 characters.
Use dhcp-snooping information format to specify the padding format for Option 82.
Use undo dhcp-snooping information format to restore the default.
By default, the padding format for Option 82 is normal.
When you use the undo dhcp-snooping information format command, if you do not specify the verbose node-identifier argument, the padding format is restored to normal. If you specify the verbose node-identifier argument, the padding format is restored to verbose with MAC address as the node identifier.
# Specify the padding format as verbose for Option 82.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information strategy replace
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information format verbose
dhcp-snooping information remote-id format-type
dhcp-snooping information remote-id format-type { ascii | hex }
undo dhcp-snooping information remote-id format-type
View
Default level
2: System level
Use dhcp-snooping information remote-id format-type to configure the code type for the non-user-defined remote ID sub-option.
Use undo dhcp-snooping information remote-id format-type to restore the default.
This command applies to configuring a non-user-defined remote ID sub-option only. After you configure the padding content for the remote ID sub-option using the dhcp-snooping information remote-id string command, ASCII is adopted as the code type. The private padding format supports only the hex code type.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information remote-id format-type ascii
dhcp-snooping information [ vlan vlan-id ] remote-id string { remote-id | sysname }
undo dhcp-snooping information [ vlan vlan-id ] remote-id string
View
Default level
2: System level
remote-id: Padding content for the user-defined circuit ID sub-option, a case-sensitive string of 1 to 63 characters.
Use dhcp-snooping information remote-id string to configure the padding content for the user-defined remote ID sub-option.
Use undo dhcp-snooping information remote-id string to restore the default.
If a VLAN is specified, the configured remote ID sub-option only takes effect within the VLAN. If no VLAN is specified, the configured remote ID sub-option takes effect in all VLANs. The former case has a higher priority. The remote ID sub-option configured for a VLAN will be padded for the packets within the VLAN.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information remote-id string device001
dhcp-snooping information strategy { append | drop | keep | replace }
undo dhcp-snooping information strategy
View
Default level
2: System level
append: Forwards messages containing Option 82 after adding content to the sub-option 9 of option 82. The append strategy is supported only when the private padding format and sub-option 9 are configured. In other cases, the device forwards the message without changing Option 82.
drop: Drops messages containing Option 82.
keep: Does not change Option 82.
replace: Replaces the original Option 82 with the configured Option 82.
Use dhcp-snooping information strategy to configure the handling strategy for Option 82 in requesting messages.
Use undo dhcp-snooping information strategy to restore the default.
By default, the handling strategy for Option 82 in requesting messages is replace.
Related commands: display dhcp-snooping information, dhcp-snooping information format, and dhcp-snooping information sub-option.
# Configure the handling strategy for Option 82 in requesting messages as keep.
[Sysname] interface gigabitethernet3/0/1
[Sysname-GigabitEthernet3/0/1] dhcp-snooping information strategy keep
dhcp-snooping information [ vlan vlan-id ] sub-option sub-option-code [ string user-string&<1-8> ]
undo dhcp-snooping information [ vlan vlan-id ] sub-option sub-option-code
View
Layer 2 Ethernet port view, Layer 2 aggregate interface view, WLAN-BSS interface, WLAN-ESS interface
Default level
2: System level
sub-option sub-option-code: Specifies the number of the sub-option. Only sub-option 9 is supported.
string user-string&<1-8>: Configures the content of the sub-option, a case-sensitive string of 1 to 63 characters. &<1-8> represents that you can enter a maximum of 8 strings separated by spaces.
Use dhcp-snooping information sub-option to configure a sub-option.
Use undo dhcp-snooping information sub-option to restore the default.
By default, no sub-option is configured.
This configuration applies to the private padding format only. To configure the private padding format, use the dhcp-snooping information format private 1 command.
If no content is configured for sub-option 9 with the string user-string option, the primary device uses sysname and the primary address of the Loopback0 interface to pad sub-option 9 and the secondary device uses sysname to pad sub-option 9. The device configured with the dhcp-snooping information strategy append command is the primary device and a device configured with some other strategy is a secondary device.
After you use the string user-string option to configure sub-option 9, the device uses the ASCII code type to pad the characters into sub-option 9 in the order that they are configured. When the total length of all sub-options reaches 255, the device stops padding automatically.
The sub-option 9 content configured only applies to the VLAN that is specified by the vlan vlan-id option. If no VLAN ID is specified, the sub-option 9 content applies to all VLANs. A VLAN prefers its own sub-option 9 content over the one configured for all VLANs.
Related commands: dhcp-snooping information format, dhcp-snooping information strategy, and display dhcp-snooping information.
# Configure the user-defined sub-option 9 as group001.
[Sysname-GigabitEthernet 1/0/1] dhcp-snooping information sub-option 9 string group001
dhcp-snooping trust
dhcp-snooping trust [ no-user-binding ]
undo dhcp-snooping trust
View
Layer 2 Ethernet interface view, Layer 2 aggregation interface view
Default level
2: System level
no-user-binding: Specifies the port not to record the clients' IP-to-MAC bindings in DHCP requests it receives. The command without this keyword records the IP-to-MAC bindings of clients.
Use dhcp-snooping trust to configure a port as a trusted port.
Use undo dhcp-snooping trust to restore the default state of a port.
All ports are untrusted by default.
After enabling DHCP snooping, you need to specify the ports connected to the valid DHCP servers as trusted to make sure DHCP clients can obtain valid IP addresses.
Related commands: display dhcp-snooping trust.
# Specify GigabitEthernet 3/0/1 as a trusted port and enable it to record the IP-to-MAC bindings of clients.
[Sysname-GigabitEthernet3/0/1] dhcp-snooping trust
display dhcp-snooping [ ip ip-address ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ip ip-address: Displays DHCP snooping entry information corresponding to the specified IP address.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display dhcp-snooping to display DHCP snooping entries.
Using the display dhcp-snooping command displays the DHCP snooping entries containing IP-to-MAC bindings that are present both in the DHCP-ACK and DHCP-REQUEST messages.
Related commands: dhcp-snooping and reset dhcp-snooping.
# Display all DHCP snooping entries.
<Sysname> display dhcp-snooping
 DHCP Snooping is enabled.
 The client binding table for all untrusted ports.
 Type : D--Dynamic , S--Static , R--Recovering
 Type IP Address      MAC Address    Lease        VLAN SVLAN Interface
 D    10.1.1.1        00e0-fc00-0006 286          1    2     GigabitEthernet3/0/1
---   1 dhcp-snooping item(s) found   ---
Table 14 Command output
Binding type:
·     DDynamic.
·     SStatic. Static DHCP snooping entries are not supported.
·     R—Recovering. It specifies that the DHCP snooping entry is being restored through the DHCP snooping entry file, and the interface in the entry is invalid.
IP Address
IP address assigned to the DHCP client.
MAC Address
MAC address of the DHCP client.
Lease
Lease period left in seconds.
VLAN
Outer VLAN tag when DHCP snooping and QinQ are both enabled or the DHCP snooping device receives a packet with two VLAN tags, or VLAN where the port connecting the DHCP client resides.
SVLAN
Inner VLAN tag when DHCP snooping and QinQ are both enabled or the DHCP snooping device receives a packet with two VLAN tags, or 0.
Port to which the DHCP client is connected.
display dhcp-snooping binding database
display dhcp-snooping binding database [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp-snooping binding database to display the DHCP snooping binding file information.
# Display the DHCP snooping binding file information.
<Sysname> display dhcp-snooping binding database
File name               :   cfa0:/database.dhcp
Update interval         :   10 minutes
Latest read time        :   Jul 15 2008 16:38:22
Latest write time       :   Jul 15 2008 16:38:24
Table 15 Command output
File name
File name.
Update interval
Interval at which the DHCP snooping binding file is refreshed.
Latest read time
Last time when the file is read.
Latest write time
Last time when the file is written.
Status
Indicates whether the file was written successfully last time.
display dhcp-snooping information { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays Option 82 configuration information about all Layer 2 Ethernet interfaces.
Use display dhcp-snooping information to display Option 82 configuration information on the DHCP snooping device.
<Sysname> display dhcp-snooping information all
Interface: GigabitEthernet 3/0/1
    Status: Enable
    Strategy: Replace
    Format: Verbose
    Sub-option 9: Enabled
    User defined:
        Sub-option 9 content: group1
Interface: GigabitEthernet 3/0/2
    Status: Disable
    Strategy: Keep
    Format: Normal
    User defined:
        VLAN 10:
            Circuit ID: vlan10@company001
        VLAN 20:
display dhcp-snooping packet statistics
In standalone mode:
display dhcp-snooping packet statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display dhcp-snooping packet statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Specifies a card by its slot number. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the member ID and slot number with the display device command. Use this option when your switch is operating in IRF mode.
Use display dhcp-snooping packet statistics to display DHCP packet statistics on the DHCP snooping switch.
Executing the display dhcp-snooping packet statistics command on the switch without a slot specified displays DHCP packet statistics on the card where the command is executed.
In IRF mode, executing the display dhcp-snooping packet statistics command without chassis chassis-number slot slot-number specified displays DHCP packet statistics on the member switch card where the command is executed.
Related commands: reset dhcp-snooping packet statistics.
# Display DHCP packet statistics on the DHCP snooping switch.
<Sysname> display dhcp-snooping packet statistics
 DHCP packets received                  : 100
 DHCP packets sent                      : 200
 Packets dropped due to rate limitation : 20
 Dropped invalid packets                : 0
display dhcp-snooping trust [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display dhcp-snooping trust to display information about trusted ports.
Related commands: dhcp-snooping trust.
# Display information about trusted ports.
<Sysname> display dhcp-snooping trust
 DHCP Snooping trust becomes active.
 Interface                                       Trusted
 GigabitEthernet3/0/1                         Trusted
The output shows that DHCP snooping is enabled, DHCP snooping trust is active, and port GigabitEthernet 3/0/1 is trusted.
reset dhcp-snooping
reset dhcp-snooping { all | ip ip-address }
View
Default level
1: Monitor level
all: Clears all DHCP snooping binding information.
ip ip-address: Clears DHCP snooping binding information about the specified IP address.
Use reset dhcp-snooping to clear DHCP snooping binding information.
DHCP snooping binding information on all slots is cleared after you execute this command.
# Clear all DHCP binding information.
<Sysname> reset dhcp-snooping all
In standalone mode:
reset dhcp-snooping packet statistics [ slot slot-number ]
In IRF mode:
reset dhcp-snooping packet statistics [ chassis chassis-number slot slot-number ]
View
Default level
2: System level
slot slot-number: slot slot-number: Specifies a card by its slot number. Use this option when your switch is operating in standalone (the default) mode.
Use reset dhcp-snooping packet statistics to clear DHCP packet statistics on the DHCP snooping switch.
Executing the reset dhcp-snooping packet statistics command on the switch without a slot specified clears DHCP packet statistics on the card where the command is executed.
In the IRF mode, executing the reset dhcp-snooping packet statistics command on the switch without chassis chassis-number slot slot-number specified clears DHCP packet statistics on the member switch card where the command is executed.
Related commands: display dhcp-snooping packet statistics.
# Clear DHCP packet statistics on the DHCP snooping switch.
<Sysname> reset dhcp-snooping packet statistics
