01-Fundamentals Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18201-Fundamentals Command Reference
08-Device Management Commands
08-Device Management Commands 370.46 KB
Device management commands 1
board-offline· 1
buffer-manage share-size· 2
clock datetime· 3
clock summer-time one-off 3
clock summer-time repeating· 4
clock timezone· 5
copyright-info enable· 6
display alarm·· 7
display buffer-manage configuration· 9
display clipboard· 10
display clock· 10
display cpu-usage· 11
display cpu-usage history· 14
display device· 16
display device manuinfo· 18
display device manuinfo chassis-only· 19
display device manuinfo fan· 20
display device manuinfo power 21
display diagnostic-information· 22
display environment 23
display fan· 25
display fan auto-control-mode· 26
display hardware-failure-detection· 26
display hardware-failure-protection· 28
display job· 29
display memory· 30
display power-supply· 31
display schedule job· 33
display schedule reboot 34
display system config file· 34
display system working mode· 35
display system-failure· 36
display transceiver alarm·· 36
display transceiver diagnosis 38
display transceiver interface· 40
display transceiver manuinfo· 41
display version· 42
display xbar 43
fan auto-control-mode· 45
forward-path check· 45
hardware-failure-detection· 46
hardware-failure-protection auto-down· 47
hardware-failure-protection aggregation· 48
header 49
job· 50
power-supply off 51
power-supply on· 52
reboot 52
reset unused porttag· 53
schedule job· 54
schedule reboot at 56
schedule reboot delay· 57
shutdown-interval 58
sysname· 59
system working mode· 59
system-failure· 60
temperature-limit 61
test diag-offline· 63
time· 66
view·· 68
xbar 69
board-offline
Standalone mode:
board-offline slot slot-number
undo board-offline slot slot-number
IRF mode:
board-offline chassis chassis-number slot slot-number
undo board-offline chassis chassis-number slot slot-number
View
Default level
3: Manage level
slot slot-number: Specifies the slot number of a card.
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. To display the member ID and slot number information, use the display device command.
Use board-offline to isolate the specified card. With this command executed, the specified card stops forwarding data packets. This operation allows for convenient on-site diagnosis or logic upgrading while causing no interference on system operations and services of other cards.
Use undo board-offline to restore the defaults.
No card is isolated by default.
You can use the display device command to view whether a card is isolated, that is, whether the card is in the offline state.
The active main processing unit (MPU) cannot be isolated from the system. If the standby MPU is isolated, the load mode of the active MPU becomes load-single.
When you upgrade the logic of an interface card, isolate the interface card first.
Do not perform configuration (except for the test diag-offline command) on an offline interface card because the configuration might not take effect.
Related commands: test diag-offline.
# Isolate the card in slot 3.
[Sysname] board-offline slot 3
Caution: This command is only for diagnostic purpose which will cause board normal service unusable. Continue? [Y/N]:y
%May 22 08:48:32:193 2008 H3C DIAG/4/WARN:slot 3 is offline
Config successfully
Standalone mode:
buffer-manage { ingress | egress } slot slot-number share-size size-value
undo buffer-manage { ingress | egress } slot slot-number share-size
IRF mode:
buffer-manage { ingress | egress } chassis chassis-number slot slot-number share-size size-value
undo buffer-manage { ingress | egress } chassis chassis-number slot slot-number share-size
View
Default level
3: Manage level
ingress: Sets the receive buffer shared by all interfaces.
egress: Sets the transmit buffer shared by all interfaces.
slot slot-number: Specifies the slot number of an interface card. If the slot-number argument is not provided, this command applies to all interface cards.
chassis chassis-number slot slot-number: Sets the size of the shared receive buffer or transmit buffer on an interface card of a certain IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the interface card resides.
size-value: Sets the size of the shared receive buffer or transmit buffer, with a step of 512. The size of the shared receive buffer is in the range of 0 to 2048 blocks, and that of the shared transmit buffer is in the range of 0 to 7168 blocks.
Use buffer-manage share-size to set the size of the receive or transmit buffer shared by all interfaces on an interface card.
Use undo buffer-manage share-size to restore the default.
By default, the size of the shared receive buffer is 1024 blocks, and that of the shared transmit buffer is 4608 blocks.
You can modify the shared buffer area depending on traffic patterns. If transient large traffic bursts occur on some interfaces, you can expand the shared buffer to accommodate the bursts to prevent traffic loss. If transient small traffic bursts often occur on the interfaces, you can decrease the shared buffer so that each port can get more dedicated buffer memory.
# In standalone mode, set the size of the shared transmit buffer for the card in slot 3 to 2048 blocks.
[Sysname] buffer-manage egress slot 3 share-size 2048
# In IRF mode, set the size of the shared transmit buffer for the card in slot 3 on member switch 1 to 2048 blocks.
[Sysname] buffer-manage egress chassis 1 slot 3 share-size 2048
clock datetime
clock datetime time date
View
Default level
3: Manage level
time: Configured time, in the hh:mm:ss format. The hh value is in the range of 00 to 23, the mm value is in the range of 00 to 59, and the ss value is in the range of 00 to 59. Zeros can be omitted, unless you specify 00:00:00.
date: Configured date, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value is in the range of 2000 to 2035, the MM value is in the range of 1 to 12, and the DD value is in the range of 1 to 31.
Use clock datetime to set the current time and date of the device.
You can leave the ss field blank when you specify the time parameters.
Related commands: clock summer-time one-off, clock summer-time repeating, clock timezone, and display clock.
# Set the current system time to 14:10:20 08/01/2008.
<Sysname> clock datetime 14:10:20 8/1/2008
# Set the current system time to 00:06:00 01/01/2008.
<Sysname> clock datetime 0:6 2008/1/1
clock summer-time zone-name one-off start-time start-date end-time end-date add-time
undo clock summer-time
View
Default level
3: Manage level
zone-name: Name of the daylight saving time, a case-sensitive string of 1 to 32 characters.
start-time: Start time, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
start-date: Start date, in the MM/DD/YYYY or YYYY/MM/DD format.
end-time: End time, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
end-date: End date, in the MM/DD/YYYY or YYYY/MM/DD format.
add-time: Time added to the standard time of the device, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
Use clock summer-time one-off to adopt daylight saving time from the start-time of the start-date to the end-time of the end-date. Daylight saving time adds the add-time to the standard time of the device.
Use undo clock summer-time to cancel the daylight saving time setting.
By default, daylight saving time is disabled and the UTC time zone applies.
The interval between start-time start-date and end-time end-date must be longer than 1 day and shorter than 1 year. If the current system time is in the specified daylight saving days, the add-time value automatically adds to the system time.
To verify the setting, use the display clock command.
The timestamps in system messages are adjusted in reference to the time zone and daylight saving schedule.
Related commands: clock datetime, clock summer-time repeating, clock timezone, and display clock.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01/2008 and 06:00:00 on 09/01/2008.
[Sysname] clock summer-time abc1 one-off 6 08/01/2008 6 09/01/2008 1
clock summer-time zone-name repeating start-time start-date end-time end-date add-time
View
Default level
3: Manage level
zone-name: Name of the daylight saving time, which is a string of 1 to 32 characters.
start-date: Start date, which can be set in the following ways:
·     Enter the year, month and date at one time, in the MM/DD/YYYY or YYYY/MM/DD format.
·     Enter the year, month and date one by one, separated by spaces. The year is in the range of 2000 to 2035; the month can be January, February, March, April, May, June, July, August, September, October, November or December; the start week can be the first, second, third, fourth, fifth or last week of the month; the start date is Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday.
end-date: End date which can be set in the following ways:
·     Enter the year, month and date one by one, separated by spaces. The year is in the range of 2000 to 2035; the month can be January, February, March, April, May, June, July, August, September, October, November or December; the end week can be the first, second, third, fourth, fifth or last week of the month; the end date is Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, Saturday.
Use clock summer-time repeating to set a recurring daylight saving schedule.
Use undo clock summer-time to cancel the configuration of the daylight saving time.
By default, daylight saving time is disabled and UTC time zone applies.
Related commands: clock datetime, clock summer-time one-off, clock timezone, and display clock.
# Set the system time ahead 1 hour every year after 2008 (inclusive) for the period from August 1 at 06:00:00 to September 1 at 06:00:00.
[Sysname] clock summer-time abc2 repeating 06:00:00 08/01/2008 06:00:00 09/01/2008 01:00:00
clock timezone
undo clock timezone
View
Default level
3: Manage level
zone-name: Time zone name, a case-sensitive string of 1 to 32 characters.
add: Adds a specified offset to UTC time.
minus: Subtracts a specified offset to UTC time.
zone-offset: Offset to the UTC time, in the hh:mm:ss format. Zeros can be omitted, unless you specify 00:00:00.
Use clock timezone to set the local time zone.
Use undo clock timezone to restore the local time zone to the default UTC time zone.
By default, the local time zone is UTC zone.
Related commands: clock datetime, clock summer-time one-off, clock summer-time repeating, and display clock.
# Set the name of the local time zone to Z5, 5 hours ahead of UTC time.
[Sysname] clock timezone z5 add 5
undo copyright-info enable
View
Default level
3: Manage level
None
Use copyright-info enable to enable displaying the copyright statement.
Use undo copyright-info enable to disable displaying the copyright statement.
By default, this feature is enabled.
# Enable displaying the copyright statement.
[Sysname] copyright-info enable
·     When a Telnet user logs in, the following statement appears:
* Copyright (c) 2004-2009 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                               *
* no decompiling or reverse-engineering shall be allowed.                  *
<Sysname>
·     When a console user quits user view, the following message appears:
User interface con0 is available.
Please press ENTER.
# Disable displaying the copyright statement.
[Sysname] undo copyright-info enable
·     When a Telnet user logs in, the user view prompt appears:
<Sysname>
Please press ENTER.
display alarm
Standalone mode:
display alarm [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display alarm [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: Monitor level
slot slot-number: Displays the alarm information of the specified card. The slot-number argument represents the slot number of a card. If the slot-number argument is not specified, the command displays the alarm information of all cards.
chassis chassis-number slot slot-number: Displays the alarm information on the specified card on an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the card resides. If the option is not specified, this command displays the alarm information of all cards on the IRF member switches.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display alarm to display the alarm information.
After this command is executed, the system automatically queries and displays the current alarm information of the boards.
# In standalone mode, display the alarm information on the switch.
<Sysname> display alarm
Slot  Level    Info
6     ERROR    The board in slot 10 is faulty.
Level
Alarm severity.
The alarm severity levels include ERROR, WARNING, NOTICE, and INFO.
Info
Detailed alarm information.
# In IRF mode, display the alarm information on the switch.
Chassis  Slot  Level    Info
1        6     ERROR    The board in slot 10 is faulty.
Standalone mode:
display buffer-manage configuration [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display buffer-manage configuration [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the configuration of the shared buffer on the specified interface card. The slot-number argument represents the slot number of an interface card. If the slot-number argument is not specified, the command displays the configuration of the shared buffer on all interface cards.
chassis chassis-number slot slot-number: Displays the configuration of the shard buffer on the specified interface card on an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the interface card resides.
Use display buffer-manage configuration to display the configuration of the shared buffer on the specified interface card.
# In standalone mode, display the configuration of the shared buffer on interface card 3.
<Sysname> display buffer-manage configuration slot 3
Ingress: the number of shared buffer units for received packets
Egress: the number of shared buffer units for sent packets
Slot No. Ingress    Egress
3        1536       4608
# In IRF mode, display the configuration of the shared buffer on interface card 3 on the switch with the member ID of 1.
<Sysname> display buffer-manage configuration chassis 1 slot 3
Chassis No.  Slot No.  Ingress    Egress
1            3         1536       4608
display clipboard
display clipboard [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display clipboard to display the contents of the clipboard.
To copy the specified content to the clipboard:
·     Move the cursor to the starting position of the content and press <Esc+Shift+,> ("," is an English comma).
·     Move the cursor to the ending position of the content and press the <Esc+Shift+.> combination ("." is an English dot) to copy the specified content to the clipboard.
# Display the content of the clipboard.
<Sysname> display clipboard
---------------- CLIPBOARD-----------------
display ip routing-table
display clock
display clock [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display clock to display the current system time and date.
The current system time and date are decided by the clock datetime, clock summer-time one-off (or clock summer-time repeating), and clock timezone commands. For more information about how the system time and date are decided, see Fundamentals Configuration Guide.
Related commands: clock datetime, clock summer-time one-off, clock summer-time repeating, and clock timezone.
# Display the current time and date.
<Sysname> display clock
09:41:23 UTC Thu 12/15/2005
display cpu-usage
Standalone mode:
display cpu-usage [ slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
display cpu-usage entry-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] [ from-device ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display cpu-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
display cpu-usage entry-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ from-device ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
entry-number: Number of entries to be displayed, in the range of 1 to 60.
offset: Offset between the serial number of the first CPU usage statistics record to be displayed and that of the last CPU usage record to be displayed. It is in the range of 0 to 59.
For example, the idx of the latest statistics record is 12. If the offset is set to 3, the system will display the statistics records from the one with the idx of 9, where idx represents the serial number of the period for the statistics, and its value is in the range of 0 to 60 cyclically. The system makes CPU usage statistics periodically, and the system records the average CPU usage during this period, and the idx value is added by 1 automatically.
verbose: Displays the average CPU usage statistics for each task in the specified period. If this keyword is not provided, the command displays brief CPU usage statistics.
from-device: Displays the external storage medium, such as a Flash or hard disk.  This keyword is not supported in the current software version. This keyword is reserved for further support.
slot slot-number: Displays the CPU usage statistics for the specified card. The slot-number argument specifies the slot number of a card. If the slot-number argument is not provided, the system displays the CPU usage statistics for all cards.
chassis chassis-number slot slot-number: Displays the CPU usage statistics for the specified card on an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the card resides. If you do not provide these two arguments, all the cards of the IRF member switch are specified.
cpu cpu-number: Displays the CPU usage statistics for the specified CPU.
Use display cpu-usage to display the CPU usage statistics.
The system regularly (typically at 60-second intervals) collects CPU usage statistics and saves the statistical results in the history record area.
The display cpu-usage entry-number command displays entry-number latest records, starting from the latest record. The display cpu-usage entry-number offset command displays entry-number latest records, starting from the last (offset+1)th record.
# In standalone mode, display the current CPU usage statistics.
<Sysname> display cpu-usage
Slot 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
Slot 3 CPU usage:
       0% in last 5 seconds
       0% in last 1 minute
       0% in last 5 minutes
# In standalone or IRF mode, display the last fifth and sixth CPU usage statistics records.
<Sysname> display cpu-usage 2 4
===== CPU usage info (no:  0  idx: 45) =====
CPU Usage Stat. Cycle: 60 (Second)
CPU Usage            : 2%
CPU Usage Stat. Time : 2007-09-25  03:45:03
CPU Usage Stat. Tick : 0x4b(CPU Tick High) 0x4cd1c391(CPU Tick Low)
Actual Stat. Cycle   : 0x0(CPU Tick High) 0xb2d2e00f(CPU Tick Low)
===== CPU usage info (no:  1  idx: 44) =====
CPU Usage            : 2%
CPU Usage Stat. Time : 2007-09-25  03:44:03
CPU Usage Stat. Tick : 0x4a(CPU Tick High) 0x99f23a9f(CPU Tick Low)
Actual Stat. Cycle   : 0x0(CPU Tick High) 0xb2d2e0d6(CPU Tick Low)s
# In IRF mode, display the current CPU usage statistics.
Chassis 1 Slot 0 CPU usage:
       2% in last 5 seconds
       2% in last 1 minute
       2% in last 5 minutes
Chassis 1 Slot 3 CPU usage:
       1% in last 1 minute
After the switch boots, the system calculates and records the average CPU usage in every 5 seconds.
This field displays the average CPU usage in the last 5 seconds.
1% in last 1 minute
After the switch boots, the system calculates and records the average CPU usage in every 1 minute.
This field displays the average CPU usage in the last minute.
After the switch boots, the system calculates and records the average CPU usage in every 5 minutes.
This field displays the average CPU usage in the last 5 minutes.
CPU usage info (no:  x  idx: x)
CPU usage records (no: The (no+1)th record is displayed. no numbers from 0, a smaller number equals a newer record. idx: index of the current record in the history record table). If only the information of the current record is displayed, no and idx are not displayed.
CPU usage measurement interval, in seconds. For example, if the value is 41, it indicates that the average CPU usage during the last 41 seconds is calculated. The value range of this field is 1 to 60.
CPU Usage
Average CPU usage in a measurement interval, in percentage.
CPU usage statistics time in seconds, that is, the system time when the command is executed.
System runtime in ticks, represented by a 64-bit hexadecimal. CPU Tick High represents the most significant 32 bits and the CPU Tick Low represents the least significant 32 bits.
Actual Stat. Cycle
Actual CPU usage measurement period in ticks, represented by a 64-bit hexadecimal. CPU Tick High represents the most significant 32 bits and the CPU Tick Low represents the least significant 32 bits. Owing to the precision of less than 1 second, the actual measurement periods of different CPU usage records might differ slightly.
Chassis n Slot m
A card in slot m on the switch with the member ID of n.
Standalone mode:
display cpu-usage history [ task task-id ] [ slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display cpu-usage history [ task task-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
task task-id: Displays the historical CPU usage statistics for the specified task, where task-id represents the task number. If the task-id argument is not provided, the system displays the historical CPU usage statistics for the entire system. The CPU utilization rates of the entire system is the sum of CPU utilization rates of all tasks.
slot slot-number: Displays the historical CPU usage statistics for the specified card. The slot-number argument specifies the slot number of a card. If no card is specified, this command displays the historical CPU usage statistics for the main CPU on the active MPU.
chassis chassis-number slot slot-number: Displays the historical CPU usage statistics for the specified card on an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the card resides. If you do not provide these two arguments, this command displays the historical CPU usage statistics for the main CPU on the global active MPU.
cpu cpu-number: Displays the historical CPU usage statistics for the specified CPU. If no CPU is specified, this command displays the historical CPU usage statistics for the main CPU in the specified slot.
Use display cpu-usage history to display the historical CPU usage statistics in a chart. If no argument is provided, the system displays the historical CPU usage statistics for the active MPU.
The system regularly collects CPU usage statistics and saves the statistics in the history record area. The display cpu-usage history command displays the CPU usage statistics for the last 60 minutes in axes, where:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step, whichever is closer. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Consecutive pound signs (#) indicate the CPU usage at a specific time. The value on the vertical axis for the topmost # sign at a specific time represents the CPU usage at that time.
# Display the CPU usage statistics for the main CPU of the system.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage last 60 minutes(SYSTEM)
The output shows the CPU usage for the main CPU of the whole system (with the task name SYSTEM) in the last 60 minutes:
·     5%: 12 minutes ago
·     10%: 13 minutes ago
·     15%: 14 minutes ago
·     10%: 15 minutes ago
·     5%: 16 and 17 minutes ago
·     10%: 18 minutes ago
·     5%: 19 minutes ago
·     2% or lower than 2%: other time
display device
Standalone mode:
display device [ cf-card ] [ slot slot-number [ subslot subslot-number ] | verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display device [ cf-card ] [ [ chassis chassis-number ] [ slot slot-number [ subslot subslot-number ] ] | verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
cf-card: Displays information about CF cards.
chassis chassis-number: Displays detailed information about the specified card on an IRF member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric. If you do not provide the argument, all the IRF member switches of the IRF fabric are specified.
slot slot-number: Displays information about the specified card. The slot-number argument represents the slot number of a card.
subslot subslot-number: Displays information about the specified subcard. The subslot-number represents the subslot of a subcard. If no subcard is installed, the subslot-number is fixed to 0.
verbose: Displays detailed information.
Use display device to display device information.
If the cf-card keyword is not provided, the command displays information of all cards on the device.
# In standalone mode, display brief information about all cards on the switch.
<Sysname> display device
Slot No.   Brd Type        Brd Status   Software Version
 0         LSR1SRP2B2      Master       S9500E-CMW520-A1729
 1         NONE            Absent       NONE
 2         NONE            Absent       NONE
 3         LSR1GT24LEC     Normal       S9500E-CMW520-A1729
 4         NONE            Absent       NONE
 5         NONE            Absent       NONE
 6         NONE            Absent       NONE
# In IRF mode, display brief information about all cards on the switch.
 1/0       LSR1SRP2B2      Master       S9500E-CMW520-A1729
 1/1       NONE            Absent       NONE
 1/2       NONE            Absent       NONE
 1/3       LSR1GT24LEC1    Normal       S9500E-CMW520-A1729
 1/4       NONE            Absent       NONE
 1/5       NONE            Absent       NONE
 1/6       NONE            Absent       NONE
Slot No.
·     Slot number of a card (in standalone mode).
·     Slot number of a card on the specified member switch in the format of member ID/slot number (in IRF mode).
Brd Type
Hardware type of a card:
·     Specific card model, such as LSR1GT24LEC, which is the same as the silkscreen.
·     NONE—No card is in the slot.
·     UNKNOWN—The card is not supported by the software version and thus cannot start correctly.
Brd Status
Card status:
·     Absent—No card is in the slot.
·     Master—The card is an active MPU.
·     Slave—The card is a standby MPU.
·     Normal—The card is operating correctly.
·     Fault—The card has not been booted or an error occurred to the card.
·     Off—The card is not powered on.
·     Illegal—The card is not supported by the software version and thus cannot start correctly.
·     Offline—The card is isolated.
Software Version
Software version of the current card:
·     Specific software version—The software version of the switch.
·     Mismatched—The software version does not support the card and thus cannot be uploaded.
Standalone mode:
display device manuinfo [ slot  slot-number [ subslot subslot-number ] ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display device manuinfo [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
3: Manage level
slot slot-number: Displays the electronic label data for the specified card. The slot-number argument represents the slot number of a card. If the slot-number argument is not provided, the system displays the electronic label data for all cards.
subslot subslot-number: Displays the electronic label data for the specified subcard. The subslot-number represents the subslot where the subcard resides. It no subcard is installed, the subslot number is 0.
chassis chassis-number: Displays the electronic label data for an IRF member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric.
Use display device manuinfo to display electronic label data.
An electronic label is a profile of a device or card and contains the permanent configuration including the serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during debugging or testing.
# In standalone mode, display the electronic label data for the card in slot 3 on the switch.
<Sysname> display device manuinfo slot 3
Slot 3:
DEVICE_NAME          : LSR1GT24LEC1
DEVICE_SERIAL_NUMBER : 210235A045B05B004350
MAC_ADDRESS          : 000f-e200-5600
MANUFACTURING_DATE   : 2008-04-13
VENDOR_NAME          : H3C
# In IRF mode, display the electronic label data for the card in slot 3 on member switch 1.
<Sysname> display device manuinfo chassis 1 slot 3
Chassis 1:
Slot 3:
VENDOR_NAME          : H3C
Standalone mode:
display device manuinfo chassis-only [ | { begin | exclude | include } regular-expression ]
IRF mode:
display device manuinfo chassis chassis-number chassis-only [ | { begin | exclude | include } regular-expression ]
View
Default level
3: Manage level
chassis chassis-number: Displays the electronic label data for the backplanes on an IRF member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric.
Use display device manuinfo chassis-only to display the electronic label data for the specified backplane.
# In standalone mode, display the electronic label data for the backplane.
<Sysname> display device manuinfo chassis-only
Chassis self:
DEVICE_NAME          : LST1Z9504AC
DEVICE_SERIAL_NUMBER : 210235A36L1234MMSSRR
MANUFACTURING_DATE   : 2012-03-03
VENDOR_NAME          : H3C
# In IRF mode, display the electronic label data for the backplane on IRF member switch 1.
<Sysname> display device manuinfo chassis 1 chassis-only
Chassis 1:
Chassis self:
VENDOR_NAME            : H3C
Standalone mode:
display device manuinfo fan fan-id [ | { begin | exclude | include } regular-expression ]
IRF mode:
display device manuinfo chassis chassis-number fan fan-id [ | { begin | exclude | include } regular-expression ]
View
Default level
3: Manage level
fan-id: Displays the electronic label data for the specified fan. On a switch with only one fan frame, for example, S9505E or S9508E, the fan ID is 1. On a switch with two fan frames, for example, S9512E, the fan ID of the upper fan frame is 1, and that of the lower one is 2.
chassis chassis-number: Displays the electronic label data for the fans on an IRF member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric.
Use display device manuinfo fan to display the electronic label data for the specified fan.
# Display the electronic label data for fan 2. (Standalone mode)
<Sysname> display device manuinfo fan 2
Fan 2:
DEVICE_NAME          : LSTM3FANH
DEVICE_SERIAL_NUMBER : 210231A36L1234567890
MANUFACTURING_DATE   : 2012-02-07
VENDOR_NAME          : H3C
# Display the electronic label data for fan 2 on IRF member switch 1. (IRF mode)
<Sysname> display device manuinfo chassis 1 fan 2
Chassis 1:
Fan 2:
DEVICE_SERIAL_NUMBER   : 210231A36L1234567891
VENDOR_NAME            : H3C
Standalone mode:
display device manuinfo power power-id [ | { begin | exclude | include } regular-expression ]
IRF mode:
display device manuinfo chassis chassis-number power power-id [ | { begin | exclude | include } regular-expression ]
View
Default level
3: Manage level
power-id: Displays the electronic label data for the specified power supply, where power-id represents the power supply number and is in the range of 1 to 2.
chassis chassis-number: Displays the electronic label data for the power supplies on an IRF member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric.
Use display device manuinfo power to display the electronic label data for the specified power supply.
# In standalone mode, display the electronic label data for power supply 2.
<Sysname> display device manuinfo power 2
Power 2:
DEVICE_NAME          : NONE
MANUFACTURING_DATE   : NONE
VENDOR_NAME          : NONE
# In IRF mode, display the electronic label data for power supply 2 on IRF member switch 1.
<Sysname> display device manuinfo chassis 1 power 2
Chassis 1:
Power 2:
DEVICE_NAME            : NONE
VENDOR_NAME            : NONE
display diagnostic-information [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display diagnostic-information to display or save running status data for multiple feature modules.
For diagnosis or troubleshooting, you can use separate display commands to collect running status data module by module, or use the display diagnostic-information command to bulk collect running data for multiple modules.
The command output can be saved on the active MPU instead of standby MPUs.
# Save the statistics of each module's running status in the system.
Save or display diagnostic information (Y=save, N=display)?[Y/N]y
Please input the file name(*.diag)[flash:/default.diag]:aa.diag
Diagnostic information is outputting to flash:/aa.diag.
Please wait...
Save succeeded.
To view the content of file aa.diag, execute the more.aa.diag command in user view, in combination of the Page Up and Page Down keys.
display environment
Standalone mode:
display environment [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display environment [ chassis chassis-number [ slot slot-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the temperature information of the sensors on a card. The slot-number argument is the slot number of the card.
chassis chassis-number: Displays the temperature information of the sensors on the specified member switch. chassis-number is the ID of an IRF member switch of the current IRF fabric.
Use display environment to display the temperature information of the switch, including the current temperature and temperature thresholds. If no card is specified, this command displays the temperature information for all sensors.
# In standalone mode, display the temperature information of the cards.
<Sysname> display environment
System temperature information (degree centigrade):
Slot  Sensor    Temperature  LowerLimit  WarningLimit  AlarmLimit ShutdownLimit
   0  inflow  1       26         -10           55           85          N/A
   0  outflow 1       30           5           75           90          N/A
   0  hotspot 1       29           0           70           85          N/A
   0  hotspot 2       30          20           80           95          N/A
   3  inflow  1       26         -10           55           75          N/A
   3  outflow 1       28          -5           65           85          N/A
   3  hotspot 1       28          -5           65           85          N/A
# In IRF mode, display the temperature information of the cards.
1/0   inflow  1       25         -10           55           85          N/A
1/0   outflow 1       31           5           75           90          N/A
1/0   hotspot 1       29           0           70           85          N/A
1/0   hotspot 2       32          20           80           95          N/A
1/3   inflow  1       25         -10           55           75          N/A
1/3   outflow 1       28          -5           65           85          N/A
1/3   hotspot 1       31          -5           65           85          N/A
System Temperature information (degree centigrade)
Temperature information of system cards (degree centigrade).
Slot
·     Slot number of the card (in standalone mode).
Sensor
Temperature sensor:
·     Hotspot—Hotspot temperature sensor.
·     Inflow—Inflow temperature sensor.
·     Outflow—Outflow temperature sensor.
Temperature
Current temperature.
Lower limit
Lower limit of temperature.
WarningLimit
Upper limit of temperature for warning.
AlarmLimit
Upper limit of temperature for alarming.
ShutdownLimit
Upper limit of temperature for shutting down the switch (not supported).
display fan
Standalone mode:
display fan [ fan-id ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display fan [ chassis chassis-number [ fan-id ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
fan-id: Displays the operating state of the specified fan, where fan-id represents the built-in fan number.
chassis chassis-number: Displays the operating state of fans of the specified IRF member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric. If you do not provide the argument, the system displays the operating states of fans of all the IRF member switches of the current IRF fabric.
Use display fan to display the operating state of built-in fans.
# In standalone mode, display detailed information about all fans on the switch.
<Sysname> display fan
Fan-tray state on chassis 0:
Fan-tray  1    state: Normal
# In IRF mode, display detailed information about all fans on the member switch in IRF mode:
Chassis 1:
 Fan   1 State: Normal
 Fan   2 State: Absent
Standalone mode:
display fan auto-control-mode [ | { begin | exclude | include } regular-expression ]
IRF mode:
display fan auto-control-mode chassis chassis-number [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
chassis-number: Specifies an IRF member switch.
Use display fan auto-control-mode to display the automatic speed adjustment mode of the fans on the switch.
# Display the automatic speed adjustment mode of the fans on the switch.
<Sysname> display fan auto-control-mode
Current fan auto-control mode: silence-mode
display hardware-failure-detection [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display hardware-failure-detection to display hardware failure detection information and fix operation records, including the fix actions configured to be taken for different failures, and the latest 10 fix operation records for each card. If the same operation is executed multiple times, only the most recent one is recorded.
The fix operation records for each card are stored in the MPU. You can use the display hardware-failure-detection command to display stored information even after a card is removed or has been replaced.
# Display hardware failure detection information and fix operation records on the switch.
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    board      : isolate
    forwarding : warning
----------------------------Slot  4 records:-------------------------------
Slot  0:
   1. 2010-06-09, 04:34:14 rebooted by board detection.
Slot  4:
   1. 2010-06-09, 11:16:39 rebooted by forwarding detection.
Slot  6:
   1. 2010-06-09, 11:13:37 some auto-down ports on this slot are down by forwarding detection.
   2. 2010-06-09, 11:13:16 some auto-down ports on this slot are down by forwarding detection.
   3. 2010-06-09, 11:12:54 some auto-down ports on this slot are down by forwarding detection.
   4. 2010-06-09, 11:12:54 some auto-down ports on this slot are down by forwarding detection.
   5. 2010-06-08, 17:55:20 some auto-down ports on this slot are down by forwarding detection.
   6. 2010-06-08, 17:55:00 some auto-down ports on this slot are down by forwarding detection.
Slot  7:
   1. 2010-06-09, 11:13:16 some auto-down ports on this slot are down by forwarding detection.
   2. 2010-06-09, 10:42:44 some auto-down ports on this slot are down by forwarding detection.
   3. 2010-06-09, 10:33:59 some auto-down ports on this slot are down by forwarding detection.
Slot  8:
   1. 2010-06-08, 14:03:40 some auto-down ports on this slot are down by forwarding detection.
   2. 2010-06-08, 14:03:11 some auto-down ports on this slot are down by forwarding detection..
Table 5 Command output
Current level
Fix actions corresponding to different failures.
Slot slotid records
Fix operation records stored on the MPU.
Slot slotid:
Fix operation records for the card.
This output is displayed after a port configured with the hardware-failure-protection auto-down command is automatically shut down in case of hardware failure.
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
aggregation: Displays whether hardware failure protection is enabled for aggregation groups.
port: Displays port hardware failure protection information.
auto-down: Displays the ports configured with the hardware-failure-protection auto-down command.
interface-type interface-number: Displays whether hardware failure protection is enabled on the specified port.
Use display hardware-failure-protection to display hardware failure protection information.
Without any keyword specified, this command displays all hardware failure protection information on the switch, including whether hardware failure protection is enabled for aggregation groups, and the ports that are configured with the hardware-failure-protection auto-down command.
# Display hardware failure protection information on the switch.
<Sysname> display hardware-failure-protection
Aggregation: on
Ports: Ge2/0/1  Ge3/0/1
# Display the ports that are configured with the hardware-failure-protection auto-down command.
<Sysname> display hardware-failure-protection port auto-down
Ports allowed auto-down: Ge2/0/1  Ge3/0/1
# Displays whether hardware failure protection is enabled on GigabitEthernet 2/0/2.
<Sysname> display hardware-failure-protection port GigabitEthernet 2/0/2
Auto-down is NOT allowed while hardware-failure happened.
Table 6 Command output
Aggregation
Whether hardware failure protection is enabled for aggregation groups.
Ports that are configured with the hardware-failure-protection auto-down command.
display job
display job [ job-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
job-name: Specifies a job name, which is a string of 1 to 32 characters.
Use display job to display information about scheduled jobs configured by using the job command.
If no job is specified, this command displays information about all scheduled jobs.
Related commands: job, time, and view.
# Display detailed information about the scheduled job saveconfig.
<Sysname> display job saveconfig
Job name: saveconfig
  Specified view: monitor
  Time 1: Execute command save 1.cfg after 40 minutes
The output shows that the current configuration will be automatically saved to the configuration file 1.cfg in 40 minutes.
Table 7 Command output
Job name
Name of the scheduled job.
Specified view
View containing the commands in the job.
Time timeid
Execution time of each command in the job.
Execute command
Command string.
display memory
Standalone mode:
display memory [ slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the memory of a CPU of the specified card. The slot-number argument represents the slot number of the card.
chassis chassis-number slot slot-number: Displays the memory of a CPU of the specified card of an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the card resides.
cpu cpu-number: Displays the memory of a specified CPU, where the cpu-number argument represents the ID of the CPU.
Use display memory to display the usage of the memory of a device.
·     Standalone mode:
If the keyword slot is not provided, the system displays the usage of the memory of the active MPU. If the keyword cpu is not provided, the system displays the memory of the main CPU.
·     IRF mode:
If the keyword chassis is not provided, the system displays the usage of the memory of the active MPU of the master. If the keyword cpu is not provided, the system displays the memory of the main CPU.
# Display the usage of the memory of the switch.
<Sysname> display memory
System Total Memory(bytes): 732833120
Total Used Memory(bytes): 143874744
Used Rate: 19%
Table 8 Command output
Total size of the system memory (in bytes).
Size of the memory used (in bytes).
Used Rate
Percentage of the memory used to the total memory.
CAUTION CAUTION:
When this value exceeds 96%, memory leakage might have occurred to the switch. Please consult H3C technical support engineers for troubleshooting.
Standalone mode:
display power-supply [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display power-supply [ chassis chassis-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
chassis chassis-number: Displays information about the power supply of an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, which you can display with the display device command. If you do not provide this option, this command displays information about the power supplies of all IRF member switches.
verbose: Displays detailed information about the power supply.
Use display power-supply to display information about the power supply of a device, including:
·     Whether the power supply management function is enabled or disabled
·     Power supply type, rated input voltage, and rated output power
·     Number of redundant power supplies
·     Available, redundant, used, and remaining power of each power supply
·     States of the existing power supplies
·     Power supply states of the cards
# In standalone mode, display detailed information about the power supply system.
<Sysname> display power-supply verbose
Power info on chassis 0:
PSU  1    state: Normal
PSU  2    state: Fault
Line-card power status:
Slot  Board-Type       Watts  Status
 2    None             --     Absent
 3    None             --     Absent
 4    None             --     Absent
 5    None             --     Absent
 6    None             --     Absent
# In IRF mode, display detailed information about the power supply system.
Power info on chassis 1:
PSU  1    state: Normal
PSU  2    state: Absent
 2    LSR1GT24LEC1     85     On
 3    LSR1GP48LEC1     115    On
 4    None             --     Absent
 5    Unknown          200    Wait
 6    LSR1GT24LEC1     85     On
Table 9 Command output
Watts
Power in watts.
Status
Power supply status of the card:
·     On—The card is supplied with power.
·     Absent—The card is not in the slot.
·     Wait—The card is waiting to be powered on.
·     Off—The card is unsolicitedly powered off due to user operation or over-temperature protection.
display schedule job [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display schedule job to display the job configured by using the schedule job command.
Related commands: schedule job.
# Display the configuration of the job configured by using the schedule job command.
<Sysname> display schedule job
Specified command: execute 1.bat
Specified view: system view
Executed time: at 12:00 03/31/2008 (in 0 hours and 16 minutes)
If you change the system time within 16 minutes after you execute the schedule job command, the scheduled job becomes invalid. Then, if you execute the display schedule job command again, no information is displayed.
display schedule reboot [ | { begin | exclude | include } regular-expression ]
View
Default level
3: Manage level
Use display schedule reboot to display the reboot schedule.
Related commands: schedule reboot at and schedule reboot delay.
# Display the reboot schedule.
<Sysname> display schedule reboot
System will reboot at 16:00:00 03/10/2008 (in 2 hours and 5 minutes).
The output shows that the system will reboot at 16:00:00 on March 10, 2008 (in 2 hours and 5 minutes).
display system config file [ file-url ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
file file-url: Specifies the saving path and name of the hardware configuration file.
Use display system config file to display brief information about the specified hardware configuration file. If no argument is provided, this command displays the brief information of the hardware configuration file of the system, that is, SysConfigMode.cfg saved in the directory flash:/.
# Display brief information about the hardware configuration file on the current device.
<Sysname> display system config file
Sysconfigname     : TrafficDistributeForSecurity
FileSerialNum     : TDFS-200908201
SupportBoard      : ALL
Description       : Traffic Distribute For Security
Limit             : Traffic Distribute For Security
display system working mode [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display system working mode to display the operating mode of the switch.
# Display the operating mode.
<Sysname> display system working mode
Current system working mode      : routee
Working mode after system restart: bridgee
Notice: Changing working mode will take effect only after system restart.
The output shows that the system operates in enhanced Layer 3 mode, and the system will operate in enhanced Layer 2 mode at next reboot.
display system-failure [ | { begin | exclude | include } regular-expression ]
View
Default level
3: Manage level
·     Standalone mode:
Use display system-failure to display the exception handling method of the active MPU and standby MPU.
Related commands: system-failure.
·     IRF mode:
Use display system-failure to display the exception handling method of all IRF member switches of an IRF fabric.
# Display the exception handling method.
<Sysname> display system-failure
 System failure handling method: reboot
display transceiver alarm interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface [ interface-type interface-number ]: Displays alarms that are present on the specified transceiver modules. The interface-type interface-number argument represents interface type and interface number. If no interface is specified, the command displays alarm information for all transceiver modules.
Use display transceiver alarm to display alarms present on transceiver modules.
If no error occurs, None is displayed. Table 10 describes the transceiver module alarms that might occur.
Table 10 Common transceiver module alarms
Remarks
SFP/SFP+:
RX loss of signal
Incoming (RX) signal is lost.
TX fault
Transmit (TX) fault.
RX power high
Incoming (RX) power level is high.
RX power low
Incoming (RX) power level is low.
TX power high
TX power is high.
TX power low
TX power is low.
TX bias high
TX bias current is high.
TX bias low
TX bias current is low.
Temp high
Temperature is high.
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
Transceiver info I/O error
Transceiver information read and write error.
Transceiver info checksum error
Transceiver information checksum error.
Transceiver type and port configuration mismatch
Transceiver type does not match port configuration.
Transceiver type not supported by port hardware
Transceiver type is not supported on the port.
XFP:
RX loss of signal
RX not ready
RX is not ready.
RX CDR loss of lock
RX clock cannot be recovered.
TX fault
TX fault.
TX not ready
TX is not ready.
TX CDR loss of lock
TX clock cannot be recovered.
Module not ready
Module is not ready.
APD supply fault
APD (Avalanche Photo Diode) supply fault.
TEC fault
TEC (Thermoelectric Cooler) fault.
Wavelength unlocked
Wavelength of optical signal exceeds the manufacturer’s tolerance.
RX power high
RX power is high.
RX power low
RX power is low.
TX power high
TX power is high.
TX power low
TX power is low.
TX bias high
TX bias low
Temp high
Temp low
Temperature is low.
Voltage high
Voltage is high.
Voltage low
Voltage is low.
# Display alarm information for the transceiver module in interface GigabitEthernet 3/0/1.
<Sysname> display transceiver alarm interface GigabitEthernet 3/0/1
GigabitEthernet3/0/1 transceiver current alarm information:
TX fault
display transceiver diagnosis interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface [ interface-type interface-number ]: Displays the measured value of digital diagnosis parameters of the transceiver module in the specified interface. The interface-type interface-number argument represents interface type and interface number. If it is not specified, the command displays the measured value of digital diagnosis parameters of all transceiver modules.
Use display transceiver diagnosis to display the measured values of the digital diagnosis parameters for transceiver modules.
# Display the measured values of the digital diagnosis parameters for the transceiver module in interface GigabitEthernet 3/0/1.
<Sysname> display transceiver diagnosis interface gigabitethernet 3/0/1
GigabitEthernet3/0/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
36        3.31        6.13      -35.64          -5.19
Table 11 Command output
Digital diagnosis information of the transceiver in the interface.
Current diagnostic parameters.
Temp.(°C)
Digital diagnosis parameter-temperature, in °C, with the precision to 1°C.
Voltage(V)
Digital diagnosis parameter-voltage, in V, with the precision to 0.01 V.
Bias(mA)
Digital diagnosis parameter-bias current, in mA, with the precision to 0.01 mA.
RX power(dBM)
Digital diagnosis parameter-RX power, in dBM, with the precision to 0.01 dBM.
TX power(dBM)
Digital diagnosis parameter-TX power, in dBM, with the precision to 0.01 dBM.
display transceiver interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface [ interface-type interface-number ]: Displays the key parameters of all transceiver modules or the transceiver module in the specified interface. The interface-type interface-number arguments specify an interface by its type and number. If no interface is specified, the command displays the key parameters of all transceiver modules.
Use display transceiver to display the key parameters of transceiver modules.
# Display the key parameters of the transceiver module in interface GigabitEthernet 3/0/19.
<Sysname> display transceiver interface Gigabitethernet 3/0/19
GigabitEthernet2/3 transceiver information:
  Transceiver Type              : 1000_BASE_SX_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 550(50um),270(62.5um)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : SFP-GE-SX-MM850
Table 12 Command output
Transceiver module information.
Transceiver Type
Transceiver module type.
Connector Type
Connector type options:
·     SC—Fiber connector developed by NTT.
·     LC—1.25 mm/RJ-45 fiber connector developed by Lucent.
·     RJ-45.
·     CX 4.
Wavelength(nm)
·     Fiber transceiver—Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
·     Copper transceiver—Displayed as N/A.
Transfer Distance(xx)
Transfer distance, with xx representing km for single-mode transceivers and m for other transceivers. If the transceiver supports multiple transfer medium, every two values of the transfer distance are separated by a comma. The corresponding transfer medium is included in the bracket following the transfer distance value. The following are the transfer media:
·     9 um—9/125 um single-mode fiber.
·     50 um—50/125 um multi-mode fiber.
·     62.5 um—62.5/125 um multi-mode fiber.
·     TP—Twisted pair.
·     CX4—CX4 cable.
Support for the digital diagnosis function:
·     YES—Supported.
·     NO—Not supported.
Ordering Name
Product code.
display transceiver manuinfo interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface [ interface-type interface-number ]: Displays the electronic label data for the transceiver module in the specified interface. The interface-type interface-number argument represents interface type and interface number. If it is not specified, the command displays part of the electronic label data for all transceiver modules.
Use display transceiver manuinfo to display the electronic label data for transceiver modules.
# Display the electronic label data for the transceiver module in interface GigabitEthernet 3/0/19.
<Sysname> display transceiver manuinfo interface gigabitethernet 3/0/19
GigabitEthernet3/0/19 transceiver manufacture information:
  Manu. Serial Number  : XXXXXXXXXXXXXXXXXX
  Manufacturing Date   : 2008-09-01
Vendor Name          : H3C
Table 13 Command output
Manu. Serial Number
Serial number of the transceiver, generated during device commissioning.
Manufacturing Date
Commissioning date of the transceiver, which is the date of the computer used for commissioning the switch.
Vendor Name
Name of vendor who customizes the transceiver.
display version
display version [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display version to display system version information, including the system software version, chassis model, and card data.
# Display system version information.
<Sysname> display version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1729
Copyright (c) 2004-2012 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S9505E uptime is 0 week, 0 day, 9 hours, 15 minutes
Last reboot reason : User reboot
LSR1SRP2B2 0:  uptime is 0 week, 0 day, 9 hours, 15 minutes
1024    Mbytes SDRAM
1024    Kbytes NVRAM Memory
Type     : LSR1SRP2B2
BootRom  : 1.20
Software : S9500E-CMW520-R1729
Patch    : P001
PCB      : Ver.A
FPGA     : NONE
CPLD     : 001F
Mbus card
    Type      : LSR1MBCB
    Software  : 110
    PCB       : Ver.B
LSR1GT24LEC1 5:  uptime is 0 week, 0 day, 9 hours, 13 minutes
512     Mbytes SDRAM
0       Kbytes NVRAM Memory
Type     : LSR1GT24LEC1
Patch    : P001
PCB      : Ver.A
FPGA     : NONE
CPLD     : 002
CpuCard
    Type      : LSR1CPA
    PCB       : Ver.B
    CPLD      : 001
    BootRom   : 1.20
display xbar
Standalone mode:
display xbar [ | { begin | exclude | include } regular-expression ]
IRF mode:
display xbar [ chassis chassis-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
chassis chassis-number: Displays the load mode of the active MPU and standby MPU of a specified member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric.
Use display xbar to display the load mode of the active MPU and standby MPU of the device, including configured load mode and current load mode.
The configured load mode might be different from the running load mode. The load balancing mode becomes valid only when both the active MPU and the standby MPU are in the slot. Otherwise, even if the load balancing mode is configured the active MPU automatically switches to the active-standby mode.
Related commands: xbar.
# In standalone mode, display the load mode of the active MPU and standby MPU.
<Sysname> display xbar
The configured system HA xbar load mode is BALANCE
The activated system HA xbar load mode is SINGLE
The output shows that the configured mode is load mode and the running load mode is standby.
# In IRF mode, display the load mode of the active MPU and standby MPU of all IRF member switches.
Chassis 1:
Chassis 2:
The configured system HA xbar load mode is SINGLE
The output shows that two member switches exist. On device 1, the configured mode is load mode and the running load mode is standby; on device 2, the configured mode is standby and the running mode is also standby.
Standalone mode:
fan auto-control-mode { low-temperature-mode | silence-mode }
undo fan auto-control-mode
IRF mode:
fan auto-control-mode { low-temperature-mode | silence-mode } chassis chassis-number
undo fan auto-control-mode chassis chassis-number
View
Default level
3: Manage level
low-temperature-mode: Configures the automatic speed adjustment mode as low temperature mode. In this mode, the fans operate at a high speed to ensure low temperature of the switch.
silence-mode: Configures the automatic speed adjustment mode as silent mode. In this mode, the fans operate at a low speed with low noise, but the temperature is a little higher than that in lower temperature mode. This mode is suitable for a noise-sensitive environment.
Use fan auto-control-mode to configure the automatic speed adjustment mode of fans.
By default, the fans operate in low temperature mode.
# Configure the automatic speed adjustment mode of fans on the switch with the member ID of 2 to silent mode.
[Sysname]fan auto-control-mode silence-mode chassis 2
[Sysname]display fan auto-control-mode chassis 2
Current fan automatic control mode : silence-mode
# Restore the default of the automatic speed adjustment mode of fans on the switch with the member ID of 2.
[Sysname]undo fan auto-control-mode chassis 2
Current fan automatic control mode : low-temperature-mode
forward-path check
forward-path check { enable | disable }
View
Default level
3: Manage level
enable: Enables automatic forwarding path check.
disable: Disables automatic forwarding path check.
Use forward-path check enable to enable automatic forwarding path check. The automatic forwarding path check function can check whether traffic forwarding of the switch is operating correctly.
By default, the automatic forwarding path check function is enabled.
# Disable automatic forwarding path check.
[Sysname] forward-path check disable
hardware-failure-detection { chip | board | forwarding } { off | warning | reset | isolate }
View
Default level
3: Manage level
chip: Enables in-service hardware failure detection for chips (including chips, capacitors, and resistors)
board: Enables in-service hardware failure detection for cards, including control channel detection and card status fast detection.
forwarding: Enables in-service hardware failure detection for the forwarding service.
off: Takes no action.
warning: Sends warning messages.
reset: Resets the failed card.
isolate: Shuts down the failed port, isolates the failed card, prohibits the failed card from loading software, or powers off the failed card to reduce the impact of the failure to the system.
Use hardware-failure-detection to enable in-service hardware failure detection and configure fix actions taken in case of hardware failures.
You can enable this feature for chips, cards, and the forwarding service respectively. The fix actions include off, warning, reset, and isolate.
By default, the fix action taken for all hardware failures is warning.
# Enable in-service hardware failure detection for chips and send warning messages in case of chip failures.
[Sysname]hardware-failure-detection chip warning
Config successfully
# Configure in-service hardware failure detection for cards and reset a card in case that the card fails.
[Sysname]hardware-failure-detection board reset
Config successfully
undo hardware-failure-protection auto-down
View
Ethernet interface view
Default level
3: Manage level
None
CAUTION
CAUTION:
Before configuring the hardware-failure-protection auto-down command on a port, make sure a backup link exists to avoid service interruption in case the port is shut down.
Use hardware-failure-protection auto-down to enable hardware failure protection on a port.
Use undo hardware-failure-protection auto-down to disable hardware failure protection on a port.
By default, hardware failure protection is enabled on a port.
The hardware-failure-protection auto-down command is effective only when the fix action for detected failures is configured as isolate.
After this command is configured on a port, the port is automatically shut down when a hardware failure is detected on the port. The port status displayed with the display interface command is Protect DOWN. To bring up the port, use the undo shutdown command on the port.
The hardware-failure-protection auto-down command does not take effect on a port in either of the following cases:
·     The port is configured with the loopback { external | internal } command.
·     The port is configured with the port up-mode command.
·     The port is configured as an IRF physical port.
For information about IRF physical ports, see IRF Configuration Guide.
# Enable hardware failure protection on GigabitEthernet 7/0/47.
[Sysname] interface GigabitEthernet 7/0/47
[Sysname-GigabitEthernet7/0/47] hardware-failure-protection auto-down
Config successfully
# Disable hardware failure protection on GigabitEthernet 7/0/47
[Sysname]interface GigabitEthernet 7/0/47
[Sysname-GigabitEthernet7/0/47]undo hardware-failure-protection auto-down
Config successfully
hardware-failure-protection aggregation
undo hardware-failure-protection aggregation
View
Default level
3: Manage level
None
Use hardware-failure-protection aggregation to enable hardware failure protection for aggregation groups.
Use undo hardware-failure-protection aggregation to disable hardware failure protection for aggregation groups.
By default, hardware failure protection for aggregation groups is disabled.
The hardware-failure-protection aggregation command is effective only when the fix action for detected failures is configured as isolate.
After this command is configured, the hardware failure of a member port in an aggregation group is handled as follows:
·     If the member port is not configured with the hardware-failure-protection auto-down command, and it is not the final port in up state in the aggregation group, the port is shut down automatically.
·     If the member port is not configured with the hardware-failure-protection auto-down command and it is the final port in up state in the aggregation group, the port will not be shut down.
·     If the member port is configured with the hardware-failure-protection auto-down command, the port is shut down automatically no matter whether it is the final port in up state in the aggregation group.
The hardware-failure-protection aggregation command does not take effect on a member port in an aggregation group in either of the following cases:
Because hardware failure protection is enabled on member ports of an aggregation group, use the undo hardware-failure-protection auto-down command to disable this feature for the member ports of all aggregation groups before you enable hardware failure protection for the aggregation groups.
If a port is automatically shut down due to hardware failure protection, its status displayed with the display interface command is Protect DOWN. To bring up the port, use the undo shutdown command on the port.
# Enable hardware failure protection for aggregation groups.
[Sysname] hardware-failure-protection aggregation
Config successfully
Note: make sure 'undo hardware-failure-protection auto-down' is
configured on every aggregate group member port
# Disable hardware failure protection for aggregation groups.
[Sysname] undo hardware-failure-protection aggregation
Config successfully
header
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
View
Default level
2: System level
incoming: Configures the banner displayed before a Modem dial-up user accesses user view. If authentication is required, the incoming banner appears after the authentication is passed.
legal: Configures the banner displayed before a user inputs the username and password to access the CLI.
login: Configures the banner displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner displayed before the legal banner appears.
shell: Configures the banner displayed before a non-Modem dial-in user accesses user view.
text: Banner message, which can be input in two formats. For more information, see Fundamentals Configuration Guide.
Use header to create a banner.
Use undo header to clear a banner.
Banners are greeting or alert messages that the system displays during the login process of a user.
# Configure banners.
[Sysname] header incoming %
Welcome to incoming(header incoming)%
[Sysname] header legal %
Welcome to legal (header legal)%
[Sysname] header login %
Welcome to login(header login)%
[Sysname] header motd %
Welcome to motd(header motd)%
[Sysname] header shell %
Welcome to shell(header shell)%
In this example, the percentage sign (%) is the starting and ending characters of text. Entering % after the displayed test quits the header command. As the starting and ending characters, % is not part of the banners.
# Verify the configuration by using Telnet. (Password authentication is configured.)
* Copyright (c) 2004-2009 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
 Press Y or ENTER to continue, N to exit.
Login authentication
Password:
job
job job-name
undo job job-name
View
Default level
3: Manage level
job-name: Specifies a job name, a string of 1 to 32 characters.
Use job to schedule a job or enter job view.
Use undo job to delete a scheduled job.
By default, no scheduled job is created.
You can add commands to execute in a job in job view.
You can use the job command to schedule multiple jobs.
Related commands: time and view.
# Create the job saveconfiguration or enter its view.
[Sysname] job saveconfiguration
[Sysname-job-saveconfiguration]
power-supply off
Standalone mode:
power-supply off slot slot-number
IRF mode:
power-supply off chassis chassis-number slot slot-number
View
Default level
3: Manage level
slot slot-number: Specifies a card by its slot number.
chassis chassis-number slot slot-number: Specifies a card on an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch, and the slot-number argument refers to the number of the slot where the card resides. To view the member ID and slot number information, use the display device command.
Use power-supply off to stop power supply to the specified card.
The specified card cannot be the MPU.
# In standalone mode, stop power supply to the card in slot 9.
<Sysname> power-supply off slot 9
# In IRF mode, stop power supply to the card in slot 3 on member switch 1.
<Sysname> power-supply off chassis 1 slot 3
power-supply on
Standalone mode:
power-supply on slot slot-number
IRF mode:
power-supply on chassis chassis-number slot slot-number
View
Default level
3: Manage level
Use power-supply on to start power supply to the specified card.
# In standalone mode, start power supply to the card in slot 9.
<Sysname> power-supply on slot 9
# In IRF mode, start power supply to the card in slot 3 on member switch 1.
<Sysname> power-supply on chassis 1 slot 3
reboot
Standalone mode:
reboot [ slot slot-number ]
IRF mode:
reboot [ chassis chassis-number [ slot slot-number ] ]
View
Default level
3: Manage level
slot slot-number: Specifies the slot number of a card. If you do not specify this option, this command applies to all cards.
chassis chassis-number: Specifies an IRF member switch by its member ID. If you do not specify this option, this command applies to all member switches.
CAUTION
CAUTION:
·     Device reboot can interrupt network services.
·     If the main system software image file has been corrupted or does not exist, the reboot command cannot reboot the switch. You must re-specify a main system software image file, or power off the switch and then power it on so the system can reboot with the backup system software image file.
·     In standalone mode:
Use reboot to reboot a card, a subcard, or the whole system.
If the slot keyword is not provided, the whole system will reboot.
Do not use the reboot command to reboot the standby MPU. Instead, use the slave restart command (see High Availability Command Reference).
·     In IRF mode:
Use reboot to reboot an IRF member switch, a subcard, or all the IRF member switches.
You can use the reboot [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ] command on the master to reboot the master or a slave.
¡     If no member switch is specified, all member switches reboot.
¡     If a member switch is specified but no card is specified, the specified member switch reboots.
¡     If a card is specified, only the specified card reboots.
For data security, if you are performing file operations at the reboot time, the system does not reboot.
You cannot reboot a card in the power-off state. You can use the display device command to display the power supply status of a card.
# In standalone mode, reboot the device. The output information is omitted here.
<Sysname> reboot
# In IRF mode, reboot the card in slot 2 on member switch 2. The output information is omitted here.
<Sysname> reboot chassis 2 slot 2
reset unused porttag
View
Default level
1: Monitor level
None
Use reset unused porttag to clear unused 16-bit indexes of the active MPU and the standby MPU. (In standalone mode)
Use reset unused porttag to clear used 16-bit indexes of all IRF member switches. (IRF mode)
A confirmation is required when you execute this command. If you fail to make a confirmation within 30 seconds or enter "N" to cancel the operation, the command will not be carried out.
# Clear unused 16-bit indexes.
<Sysname> reset unused porttag
Current operation will delete all unused port tag(s). Continue? [Y/N]:y
<Sysname>
schedule job
schedule job { at time1 [ date ] | delay time2 } view view command
undo schedule job
View
Default level
3: Manage level
at time1 [ date ]: Specifies the time and/or date to execute a command.
·     time1: Sets time to execute the command, in the hh:mm format. The hh value is in the range of 0 to 23, and the mm value is in the range of 0 to 59.
·     date: Sets the date to execute the command, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value is in the range of 2000 to 2035, the MM value is in the range of 1 to 12, and the DD value is in the range of 1 to 31.
delay time2: Runs the job after a delay. The time2 argument specifies the delay in one of the following formats:
·     hh:mm format—The hh value is in the range of 0 to 720, and the mm value is in the range of 0 to 59. When the hh value is 720, the mm value cannot be more than 0.
·     mm format—It is in the range of 0 to 432000 minutes, with 0 indicating that the command is executed immediately.
view view: Specifies the view in which the command is executed. The view argument represents the view name, and it can take only one of the following keywords:
·     shell—Represents user view.
·     system—Represents system view.
command: Command to execute.
Use schedule job to schedule a job by using the non-modular method.
Use undo schedule job to remove the scheduled job.
You can schedule a job to automatically run a command or a set of commands without administrative interference. The commands in a job are polled every minute. When the scheduled time for a command is reached, the job automatically executes the command. If a confirmation is required while the command is running, the system automatically enters Y or Yes. If characters are required, the system automatically enters a default character string or an empty character string when no default character string is available.
Follow these guidelines when you schedule a job by using the non-modular method:
·     You can schedule only one job and run only one command with this method. If you perform the schedule job command multiple times, the most recent configuration takes effect.
·     To have the command successfully executed, check that the specified view and command are valid. The system does not verify their validity.
·     If you specify both the time1 and date arguments, the execution time or date must be later than the current system time or date.
·     If you specify the time1 argument, but not the date argument:
¡     When time1 is earlier than the current system time, the command runs at time1 the next day.
¡     When time1 is later than the current system time, the command runs at time1 of the current day.
·     The interval between the scheduled time and the current system time cannot exceed 720 hours, or 30 days.
·     Changing any clock setting can cancel the job set by using the schedule job command.
·     After job execution, the configuration interface, view, and user status that you have before job execution restore even if the job has run a command that changes the user interface (for example, telnet, ftp, and ssh2), the view (for example, system-view, quit and interface GigabitEthernet), or the user status (for example, super).
·     The job scheduled by using the schedule job command cannot be saved. When an active/standby MPU switchover or master/slave switchover occurs, the job is lost.
·     To check whether the job is executed, use the display logbuffer command.
# Configure the switch to execute the batch file 1.bat in system view in 60 minutes (supposing that the current time is 11:43).
<Sysname> schedule job delay 60 view system execute 1.bat
Info: Command execute 1.bat in system view will be executed at 12:43 10/31/2007 (in 1 hours and 0 minutes).
# Configure the switch to execute the batch file 1.bat in system view at 12:00 in the current day (supposing that the current time is 11:43).
<Sysname> schedule job at 12:00 view system execute 1.bat
Info: Command execute 1.bat in system view will be executed at 12:00 10/31/2007 (in 0 hours and 16 minutes).
schedule reboot at
schedule reboot at hh:mm [ date ]
undo schedule reboot
View
Default level
3: Manage level
hh:mm: Reboot time for the device, in the hh:mm format. The hh value is in the range of 0 to 23, and the mm value is in the range of 0 to 59.
date: Reboot date for the device, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value is in the range of 2000 to 2035, the MM value is in the range of 1 to 12, and the DD value is in the range of 1 to 31.
CAUTION
CAUTION:
·     Changing any clock setting can cancel the reboot schedule.
Use schedule reboot at to schedule a device reboot to occur at a specific time and date.
Use undo schedule reboot to disable the scheduled reboot function.
By default, the scheduled reboot function is disabled.
In an IRF fabric, the device reboot schedule applies to all member switches.
The interval between the reboot date and the current date cannot exceed 30 x 24 hours, or 30 days.
When no reboot date is specified:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The switch supports only one device reboot schedule. If you configure the schedule reboot at command multiple times, the most recent configuration takes effect. The schedule reboot at command and the schedule reboot delay command overwrite each other. The command that is configured most recently takes effect.
The alert "REBOOT IN ONE MINUTE" appears 1 minute before the reboot time.
# Configure the switch to reboot at 12:00 AM. This example assumes that the current time is 11:43.
<Sysname> schedule reboot at 12:00
Reboot system at 12:00 06/06/2008(in 0 hour(s) and 16 minute(s))
 confirm? [Y/N]:
Enter y at the prompt. If you have used the terminal logging command to enable the log display function (enabled by default) on the terminal, the system automatically displays a reboot schedule log message.
<Sysname>
%Jun  6 11:43:11:629 2006 Sysname CMD/5/REBOOT:
vty0(192.168.1.54): Set schedule reboot parameters at 11:43:11 06/06/2006, and system will reboot at 12:00 06/06/2008.
schedule reboot delay { hh:mm | mm }
View
Default level
3: Manage level
hh:mm: Device reboot wait time, in the hh:mm format. The hh value is in the range of 0 to 720, and the mm value is in the range of 0 to 59. When the hh value is 720, the mm value cannot be more than 0.
mm: Device reboot wait time in minutes, in the range of 0 to 43200.
CAUTION
CAUTION:
Use schedule reboot delay to schedule a device reboot to occur after a delay.
The reboot delay cannot exceed 30 x 24 x 60 minutes, or 30 days.
The switch supports only one device reboot schedule. If you configure the schedule reboot delay command multiple times, the most recent configuration takes effect. The schedule reboot at command and the schedule reboot delay command overwrite each other. The command that is configured most recently takes effect.
# Configure the device to reboot in 88 minutes. This example assumes that the current time is 11:48.
<Sysname> schedule reboot delay 88
Reboot system at 13:16 06/06/2006(in 1 hour(s) and 28 minute(s)). confirm? [Y/N]:
<Sysname>
%Jun  6 11:48:44:860 2006 Sysname CMD/5/REBOOT:
vty0(192.168.1.54): Set schedule reboot parameters at 11:48:44 06/06/2006, and system will reboot at 13:16 06/06/2006.
shutdown-interval
shutdown-interval time
undo shutdown-interval
View
Default level
2: System level
time: Port status detection timer in seconds, which is in the range of 0 to 300.
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
By default, the port status detection timer is 30 seconds.
Some protocols might shut down ports under specific circumstances. For example, MSTP shuts down a BPDU guard-enabled port when the port receives a BPDU, and the loop detection function in shutdown mode shuts down a port when a loop is detected on the port. You can set the port status detection timer so the device restores the port to its original physical status if the port is still down when the timer expires.
If you change the detection timer to T1 during port detection, the interval from when you change the timer to the time when the protocol module shuts down the port is T. If T<T1, the down port will be recovered after T1-T time. If T>=T1, the down port is recovered immediately. For example, if the detection timer is set to 30 seconds and you change it to 10 seconds (T1=10) 2 seconds after the port is shut down (T=2), this port will be recovered 8 seconds later. If the detection timer is set to 30 seconds and you change it to 2 seconds 10 seconds after the port is shut down, this port is recovered immediately.
If the detection timer is set to 0, the protocol module never automatically recovers the port. You must manually bring up the port by using the undo shutdown command or change the detection timer to a non-zero value.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
sysname
sysname sysname
undo sysname
View
Default level
2: System level
sysname: Name of the device, which is a string of 1 to 64 characters.
Use sysname to set the name of the device.
Use undo sysname to restore the device name to the default.
Changing device name affects the prompt of the CLI. For example, if the device name is Sysname, the prompt of user view is <Sysname>.
# Set the name of the device to test.
[Sysname] sysname test
[test]
system working mode
system working mode { { advance | bridgee | routee | standard } [ hybrid ] }
undo system working mode
View
Default level
3: Manage level
advance: Advanced mode.
bridgee: Enhanced L2 mode.
routee: Enhanced L3 mode.
standard: Standard mode.
hybrid: Hybrid mode. If bridge and hybrid are both configured, the switch supports enhanced L2 hybrid mode.
Use system working mode to configure the system working mode to adjust allocation of the hardware resources of the system.
Use undo system working mode to restore the default.
By default, the system working mode is standard.
Restart the switch immediately to make your changes on the working mode effective.
An IRF member switch cannot operate in hybrid mode. A switch operating in hybrid mode can operate in standalone mode instead of IRF mode.
# Configure the system working mode as enhanced L3.
[Sysname] system working mode routee
routeE mode has been set. It will take effect after system restart.
system-failure
system-failure { maintain | reboot }
undo system-failure
View
Default level
3: Manage level
maintain: Specifies that when the system detects any software abnormality, it maintains the current situation, and does not take any measure to recover itself.
reboot: Specifies that when the system detects any software abnormality, it recovers itself through automatic reboot.
·     Standalone mode:
Use system-failure to configure the exception handling method of the MPUs.
By default, an MPU reboots when an exception occurs to it.
The system always reboots an interface card or the auxiliary CPU system when an exception occurs to them.
The exception handling method is effective only for the failed card, and does not influence the functions of other cards.
·     IRF mode:
The exception handling method is effective only for the failed card, and does not influence the operations of other cards or the IRF fabric.
The system cannot ignore all exceptions when the preferred exception handling method is set to maintain. If the system ignore exceptions, some functions might fail.
# Set the exception handling method to reboot.
[Sysname] system-failure reboot
temperature-limit
Standalone mode:
temperature-limit slot slot-number { inflow | hotspot | outflow } sensor-num LowerLimit WarningLimit [ AlarmLimit ]
undo temperature-limit slot slot-number { inflow | hotspot | outflow } sensor-num
IRF mode:
temperature-limit chassis chassis-number slot slot-number { inflow | hotspot | outflow } sensor-num LowerLimit WarningLimit [ AlarmLimit ]
undo temperature-limit chassis chassis-number slot slot-number { inflow | hotspot | outflow } sensor-num
View
Default level
2: System level
chassis chassis-number: Specifies an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, which you can display with the display device command.
slot-number: Specifies the temperature limit of the card in the specified slot.
hotspot: Specifies a hotspot sensor, which is typically placed near the chip that generates a great amount of heat for temperature monitoring.
inflow: Specifies an intake sensor, which is placed near the air inlet for temperature monitoring.
outflow: Specifies an exhaust sensor, which is placed near the air exhaust for temperature monitoring.
sensor-number: Specifies the sensor number. It is an integer starting from 1, each number representing a temperature sensor of a device or card.
sensor-num: Temperature sensor ID.
LowerLimit: Low temperature threshold in Celsius degrees.
WarningLimit: Warning temperature threshold in Celsius degrees.
AlarmLimit: Alarming temperature threshold in Celsius degrees. If you do not specify this argument, the command uses the current AlarmLimit configuration of the switch.
Use temperature-limit to set the temperature thresholds on a card.
Use undo temperature-limit to restore the temperature thresholds to the default.
If the temperature is lower than the low temperature threshold, the device logs the event and sends a trap. If the temperature reaches the warning threshold, the device logs the event and sends a trap. If the temperature is higher than the alarming threshold, the device not only repeatedly outputs the log information and send traps, but also alerts users through the LED on the device panel.
The warning and alarming temperature thresholds must be higher than the low temperature threshold.
The alarming temperature threshold must be higher than the warning temperature threshold.
Only cards configured with a hotspot temperature sensor support the hotspot keyword.
The temperature threshold range and default vary with switch models. For more information, see Table 14 and Table 15.
Table 14 Temperature alarm thresholds of MPU
Temperature sensor
–15°C to –5°C, –10°C by default (5°F to 23°F, 14°F by default)
50°C to 60°C, 55°C by default (122°F to 140°F, 131°F by default)
80°C to 90°C, 85°C by default (176°F to 194°F, 185°F by default)
0°C to 10°C, 5°C by default (32°F to 50°F, 41°F by default)
70°C to 80°C, 75°C by default (158°F to 176°F, 167°F by default)
85°C to 95°C, 90°C by default (185°F to 203°F, 194°F by default)
No. 1 hotspot temperature sensor
–5°C to +5°C, 0°C by default (23°F to 41°F, 32°F by default)
65°C to 75°C, 70°C by default (149°F to 167°F, 158°F by default)
No. 2 hotspot temperature sensor
15°C to 25°C, 20°C by default (59°F to 77°F, 68°F by default)
75°C to 85°C, 80°C by default (167°F to 185°F, 176°F by default)
90°C to 100°C, 95°C by default (194°F to 212°F, 203°F by default)
Table 15 Temperature alarm thresholds of interface cards
Temperature sensor
–10°C to 0°C, –5°C by default (14°F to 32°F, 23°F by default)
60°C to 70°C, 65°C by default (140°F to 158°F, 149°F by default)
# Set the low temperature threshold of inflow temperature sensor 1 configured on card 0 to –10°C (14°F), the warning temperature threshold to 60°C (140°F), and the alarming temperature threshold to 90°C (194°F).
[Sysname] temperature-limit slot 0 inflow 1 -10 60 90
test diag-offline
Standalone mode:
test diag-offline slot slot-number
IRF mode:
test diag-offline chassis chassis-number slot slot-number
View
Default level
3: Manage level
slot-number: Slot number of a card.
chassis chassis-number slot slot-number: Specifies the card on the specified member switch to be diagnosed. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. To view the member ID and slot number information, use the display device command.
Use test diag-offline to diagnose problems of the isolated card.
With the command executed, the system implements a set of self-test and diagnosis operations and records the diagnosis information. The diagnosis information is displayed and saved in the format of logs in the root directory of the flash. Each log is named in the format of diag_slot_time, where slot indicates the location of the card and time indicates when the diagnosis operation is performed.
When you execute the test diag-offline command, the path where the diagnosis information is saved is displayed following the diagnosis information on the terminal. For example, you can see flash:/diag_slot3_20080522_103458.txt.
H3C recommends that you send the diagnosis information to qualified engineers for analysis.
Related commands: board-offline.
# Diagnose problems of the isolated card in slot 3.
[Sysname] test diag-offline slot 3
Now we begin testing. please don't pull out this board until test finished!
[diag]test cpu chipcheck
CPLD0   test...................ok
PHY0    test...................ok
test result : pass
[diag]test chipcheck
PP0     test...................ok
PHY1    test...................ok
PHY2    test...................ok
PHY3    test...................ok
PHY4    test...................ok
PHY5    test...................ok
PHY6    test...................ok
PHY7    test...................ok
PHY8    test...................ok
PHY9    test...................ok
PHY10   test...................ok
PHY11   test...................ok
LSW0    test...................ok
test result : pass
[diag]test temperature
CHIP  LOW_LIMIT  CURRENT_TEMPERATURE HIGH_LIMIT     STATUS
0     -5         27                  75             ok
1     -5         30                  75             ok
2.0   20         56                  90             ok
2.2   -5         33                  75             ok
test result : pass
[diag]test junction temperature
0     -5         27                  75             ok
1     -5         30                  75             ok
2.0   20         56                  90             ok
2.2   -5         34                  75             ok
test result : pass
[diag]test extchip description pp
QDR_TYPE   : QDR II+
EB_RL      : 2.5
EB_SPEED   : 400.0MHz
EB_SIZE    : 8MB
IB_RL      : 2.5
IB_SPEED   : 400.0MHz
IB_SIZE    : 4MB
LPM_TYPE   : DDR II+
LPM_RL     : 2.5
LPM_SPEED  : 400.0MHz
LPM1_SIZE  : 2MB
LPM2_SIZE  : 4MB
LPM3_SIZE  : 2MB
CS_TYPE    : DDR II+
CS_RL      : 2.5
CS_SPEED   : 400.0MHz
CS_SIZE    : 4MB
TCAM_TYPE  : IDT
TCAM_SPEED : 250.0MHz
TCAM_SIZE  : 5Mbit
test result : pass
[diag]test external-ram
PP0 ingress buffer test..........................ok
PP0 egress buffer test...........................ok
PP0 LPM0 test....................................ok
PP0 LPM1 test....................................ok
PP0 LPM2 test....................................ok
PP0 control SRAM test............................ok
PP0 TCAM test....................................ok
test result : pass
[diag]test prbs
slot 3  prbs test......ok
test result : pass
[diag]test mbus status
error : please check mbus card present and active, communication is abnormal
test result : fail
[diag]test mbus voltage
test result : fail
[diag]test management channel
slot 3  test...................ok
test result : pass
The test of this offline-board finished, final test result as below :
Test result : this board is abnormal
You can view the file in flash to see the test information : flash:/diag_slot3_20080522_103458.txt.
time
time timeid at time1 date command command
time timeid { one-off | repeating } at time1 [ month-date month-day | week-day week-daylist ] command command
time timeid { one-off | repeating } delay time2 command command
undo time timeid
View
Job view
Default level
3: Manage level
timeid: Time index, an integer between 1 and 10.
at time1: Specifies the execution time, in the hh:mm format, where the hh value is in the range of 0 to 23 and the mm value is in the range of 0 to 59.
date: Specifies the execution date, in the MM/DD/YYYY or YYYY/MM/DD format. The YYYY value is in the range of 2000 to 2035, the MM value is in the range of 1 to 12, and the DD value is in the range of 1 to 31. The specified execution date must be ahead of the current date.
command command: Specifies the command to be automatically executed, in the text format. The command must be executable in the view specified by the view command; otherwise this command cannot be automatically executed. Therefore, ensure the correctness of the configuration.
one-off: Specifies that the specified command is executed for once.
repeating: Specifies a recurring time schedule.
month-date month-day: Specifies the date for executing the command. month-day specifies the date, and is in the range of 1 to 31.
week-day week-daylist: Specifies the day or days for executing the command. week-daylist specifies 1 to 7 days, which can be any combination of Sun, Mon, Tue, Wed, Thu, Fri, and Sat. For example, to have a command executed on Monday, you can enter week-day Mon; to have a command executed on Friday and Saturday, enter week-day Fri Sat. Use a space between every 2 days for separation.
delay time2: Specifies the delay time for executing the command, in the hh:mm format or mm format.
·     When the time argument is in the hh:mm format, the hh value is in the range of 0 to 720, and the mm value is in the range of 0 to 59. When the hh value is 720, the mm value can be only 00.
·     When the time argument is in the mm format , the mm value is in the range of 1 to 43,200. That is, the maximum value of the delay timer is 30 days.
Use time to add an entry in the job schedule.
Use undo time to remove an entry from the job schedule.
The commands in a job must be in the same view.
Every job can have up to 10 commands.
The time ID (time-id) must be unique in a job. If two time and command bindings have the same time ID, the most recent configuration takes effect.
Changing a clock setting does not affect the schedule set by using the time command.
Use Table 16 when you add commands in a job.
Table 16 Command schedule options
Schedules a command to run at a specific time and date. The time or date must be later than the current system time or date.
time timeid one-off at time1 command command
Schedules a command to run at a specific time on the current day. If the specified time has passed, the command runs the next day. The command runs only once.
time timeid one-off at time1 month-date month-day command command
Schedules a command to run at a specific day in the current month. If the specified time or day has passed, the command runs in the next month.
time timeid one-off at time1 week-day week-daylist command command
Schedules a command to run at a specific time on a specific day or days in the current week. If the specified time or day has passed, the command runs in the next week.
time timeid repeating at time1 command command
Schedules a command to run at a specific time every day.
time timeid repeating at time1 month-date month-day command command
Schedules a command to run on a specific day every month.
time timeid repeating at time1 week-day week-daylist command command
Schedules a command to run at a specific time in a specific day or days every week.
time timeid one-off delay time2 command command
Schedules a command to run after a delay time.
time timeid repeating delay time2 command command
Schedules a command to run every the delay time.
Related commands: job and view.
# Configure the switch to save the configuration file a.cfg at 24:00 on May 18, 2009.
[Sysname-job-saveconfig] view monitor
[Sysname-job-saveconfig] time 1 at 24:00 2009/05/18 command save a.cfg
# Configure the switch to save the configuration file at 12:00 every day.
[Sysname-job-saveconfig] time 1 repeating at 12:00 command save a.cfg
# Configure the switch to save the configuration file at 8:00 AM on 5th in the current month. This job might be executed in the second month if the time has passed.
[Sysname-job-saveconfig] time 1 one-off at 8:00 month-date 5 command save a.cfg
# Configure the switch to save the configuration file at 8:00 AM on 5th every month.
[Sysname-job-saveconfig] time 1 repeating at 8:00 month-date 5 command save a.cfg
# Configure the switch to save the configuration file at 8:00 AM on Friday and Saturday in the current week. This job might be delayed to the next week if the time has passed.
[Sysname-job-saveconfig] time 1 one-off at 8:00 week-day fri sat command save a.cfg
# Configure the switch to save the configuration file at 8:00 on Friday and Saturday every week.
[Sysname-job-saveconfig] time 1 repeating at 8:00 week-day fri sat command save a.cfg
# Configure the switch to save the configuration file 5 minutes behind the current system time.
[Sysname-job-saveconfig] time 1 one-off delay 5 command save a.cfg
# Configure the switch to save the configuration file every 5 minutes.
[Sysname-job-saveconfig] time 1 repeating delay 5 command save a.cfg
view
view view-name
undo view
View
Job view
Default level
3: Manage level
view-name: Specifies a view name, a string of 1 to 90 characters. All commands in the job are executed in the specified view.
Use view to specify a view for a job.
Use undo view to remove the view of a job.
By default, no view is specified for a job.
Every job can have only one view. If you specify multiple views, the view specified most recently takes effect.
Input a view name in its complete form and make sure that the view name is available on the switch. Most commonly used view names include monitor for user view, system for system view, GigabitEthernet x/x/x for Ethernet interface view, and Vlan-interfacex for VLAN interface view.
Related commands: job and time.
# Specify system view for the job creatvlan.
[Sysname] job creatvlan
[Sysname-job-creatvlan] view system
xbar
Standalone mode:
xbar { load-balance | load-single }
IRF mode:
xbar chassis chassis-number { load-balance | load-single }
View
Default level
2: System level
load-balance: Balances load (processing and forwarding packets) between the active MPU and standby MPU.
load-single: The active MPU processes and forwards packets, whereas the standby MPU only backs up data and monitors the state of the active MPU.
chassis chassis-number: Configures the load mode for the active MPU and standby MPU of a specified member switch. The chassis-number argument is the ID of an IRF member switch of the current IRF fabric.
Use xbar to set the load mode for the active MPU and the standby MPU of the switch.
By default, the active MPU and the standby MPU operate in the load-single mode.
The load-balance mode be valid only when both the active MPU and the standby MPU are in their slots. Otherwise, even if the load-balance mode is configured the active MPU automatically switches to the load-single mode.
The models of the active MPU and the standby MPU must be consistent; otherwise, the standby MPU cannot start correctly.
Related commands: display xbar.
# Set the load mode for the active MPU and the standby MPU to load-balance.
[Sysname] xbar load-balance
