- 01-Fundamentals Command Reference
- 01-CLI Commands
- 02-Login Management Commands
- 03-FTP and TFTP Commands
- 04-File System Management Commands
- 05-Configuration File Management Commands
- 06-Software Upgrade Commands
- 07-ISSU Commands
- 08-Device Management Commands
- 09-Password recovery control command
| 02-Login Management Commands | 238.8 KB |
acl (user interface view)
To use a basic or advanced ACL:
acl [ ipv6 ] acl-number { inbound | outbound }
undo acl [ ipv6 ] acl-number { inbound | outbound }
To use an Ethernet frame header ACL:
acl acl-number inbound
undo acl acl-number inbound
View
VTY user interface view
Default level
2: System level
ipv6: When this keyword is present, the command supports IPv6; otherwise, it supports IPv4.
acl-number: Specifies an ACL number in the range of 2000 to 4999:
· 2000 to 2999 for a basic ACL.
· 3000 to 3999 for an advanced ACL.
· 4000 to 4999 for an Ethernet frame header ACL.
inbound: Restricts Telnet or SSH connections established in the inbound direction through the VTY user interface. If the received packets for establishing a Telnet or SSH connection are permitted by an ACL rule, the connection is allowed to be established. When the switch functions as a Telnet server or SSH server, this keyword is used to control access of Telnet clients or SSH clients.
outbound: Restricts Telnet connections established in the outbound direction through the VTY user interface. If the packets sent for establishing a Telnet connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet client, this keyword is used to define Telnet servers accessible to the client.
Use acl to reference ACLs to control access to the VTY user interface.
Use undo acl to cancel the ACL application. For more information about ACL, see ACL and QoS Command Reference.
By default, access to the VTY user interface is not restricted.
If no ACL is referenced in VTY user interface view, the VTY user interface has no access control over establishing a Telnet or SSH connection.
If an ACL is referenced in VTY user interface view, the connection is permitted to be established only when packets for establishing a Telnet or SSH connection match a permit statement in the ACL.
The system regards the basic/advanced ACL with the inbound keyword, the basic/advanced ACL with the outbound keyword, and Ethernet frame header ACL as three different types of ACLs, which can coexist in one VTY user interface. The match order is basic/advanced ACL with the inbound keyword or outbound keyword, Ethernet frame header ACL. At most one ACL of each type can be referenced in the same VTY user interface, and the most recent configuration takes effect.
# Allow only the user with the IP address of 192.168.1.26 to access the device through Telnet or SSH.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 192.168.1.26 0
[Sysname-acl-basic-2001] quit
[Sysname] user-interface vty 0
[Sysname-ui-vty0] acl 2001 inbound
After your configuration, user A (with the IP address 192.168.1.26) can Telnet to the device while user B (with the IP address 192.168.1.60) cannot Telnet to the device. Upon a connection failure, a message appears, saying "%connection closed by remote host!"
# Allow the device to only Telnet to the Telnet server with IP address 192.168.1.41.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp destination 192.168.1.41 0
[Sysname-acl-adv-3001] quit
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] acl 3001 outbound
[Sysname-ui-vty0-4] return
<Sysname>
After your configuration, if you Telnet to 192.168.1.46, your operation fails.
<Sysname> telnet 192.168.1.46
%Can't access the host from this terminal!
But you can Telnet to 192.168.1.41.
<Sysname> telnet 192.168.1.41
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
activation-key
activation-key character
undo activation-key
View
User interface view
Default level
3: Manage level
character: Shortcut key for starting a terminal session, a single character (or its ASCII code value in the range of 0 to 127) or a string of 1 to 3 characters. However, only the first character functions as the shortcut key. For example, if you enter an ASCII code value of 97, the system uses its corresponding character a as the shortcut key. If you enter string b@c, the system uses the first character b as the shortcut key.
Use activation-key to define a shortcut key for starting a terminal session.
Use undo activation-key to restore the default.
By default, pressing the Enter key starts a terminal session. However, if a new shortcut key is defined by the activation-key command, the Enter key no longer functions. To display the shortcut key you have defined, use the display current-configuration | include activation-key command.
The activation-key command is not supported by the VTY user interface.
# Configure character s as the shortcut key for starting a terminal session on the console port.
[Sysname] user-interface console 0
[Sysname-ui-console0] activation-key s
To verify the configuration:
[Sysname-ui-console0] return
<Sysname> quit
* Copyright (c) 2004-2010 Hangzhou H3C Tech. Co., Ltd. All rights reserved. *
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
User interface con0 is available.
Please press ENTER.
<Sysname>
%Mar 2 18:40:27:981 2005 Sysname SHELL/5/LOGIN: Console login from con0
auto-execute command
auto-execute command command
undo auto-execute command
View
User interface view
Default level
3: Manage level
command: Specifies a command to be automatically executed.
Use auto-execute command to specify a command to be automatically executed when a user logs in to the current user interface.
Use undo auto-execute command to remove the configuration.
By default, command auto-execution is disabled.
The console port does not support the auto-execute command command.
The system automatically executes the specified command when a user logs in to the user interface, and terminates the user connection after the command completes. If the command triggers another task, the system does not terminate the user connection until that task completes.
Typically, you use can use the auto-execute command telnet command in user interface view to enable a user to automatically Telnet to the specified host when the user logs in to the device. After the user terminates the connection with the host, the user's connection with the device is automatically terminated.
IMPORTANT: The auto-execute command command might disable you from configuring the system through the user interface to which the command is applied. Therefore, before configuring the command and saving the configuration (by using the save command), make sure that you can access the switch by other VTY, console, or AUX interfaces to remove the configuration in case a problem occurs. |
# Configure the device to automatically Telnet to 192.168.1.41 after a user logs in to interface VTY 0.
[Sysname -ui-vty0] auto-execute command display telnet 192.168.1.41
% This action will lead to configuration failure through ui-vty0. Are you sure?
[Y/N]:y
[Sysname-ui-vty0]
Telnet to 192.168.1.40. The device automatically Telnets to 192.168.1.41. The following output is displayed:
C:\> telnet 192.168.1.40
<Sysname>
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41. If the Telnet connection to 192.168.1.41 is broken down, the Telnet connection to 192.168.1.40 breaks down at the same time.
authentication-mode
In non-FIPS mode:
authentication-mode { none | password | scheme }
undo authentication-mode
In FIPS mode:
authentication-mode scheme
View
User interface view
Default level
3: Manage level
none: Performs no authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
Use authentication-mode to set the authentication mode when users log in to the user interface.
Use undo authentication-mode to restore the default.
In non-FIPS mode, the default authentication mode is password for VTY and AUX user interfaces and none for the console user interface.
In FIPS mode, the authentication mode can only be scheme.
Related commands: set authentication password.
# Specify that no authentication is needed when users log in to the device through VTY 0. (This mode is insecure.)
[Sysname-ui-vty0] authentication-mode none
# Set to use password authentication when users log in to the device through VTY 0, and set the authentication password to 321.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password simple 321
# Set to authenticate users by username and password when the users log in to the device through VTY 0. Set the username to 123 and the password to 321.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
[Sysname] local-user 123
[Sysname-luser-123] password simple 321
[Sysname-luser-123] service-type telnet
[Sysname-luser-123] authorization-attribute level 3
command accounting
command accounting
undo command accounting
View
User interface view
Default level
3: Manage level
None
Use command accounting to enable command accounting.
Use undo command accounting to restore the default.
By default, command accounting is disabled. The accounting server does not record the commands that users have executed.
When command accounting is enabled and command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only the authorized and executed commands are recorded on the HWTACACS server.
# Enable command accounting on VTY 0. Then the HWTACACS server records the commands executed by users that have logged in through VTY 0.
[Sysname-ui-vty0] command accounting
undo command authorization
View
User interface view
Default level
3: Manage level
None
Use command authorization to enable command authorization.
Use undo command authorization to restore the default.
By default, command authorization is disabled. Logged-in users can execute commands without authorization.
With command authorization enabled, users logging in from the current user interface can perform only commands authorized by the server.
# Enable command accounting for VTY 0 so that users logging in from VTY 0 can perform only the commands authorized by the HWTACACS server.
[Sysname-ui-vty0] command authorization
databits
databits { 5 | 6 | 7 | 8 }
undo databits
View
User interface view
Default level
2: System level
5: Sets 5 data bits for each character.
6: Sets 6 data bits for each character.
7: Sets 7 data bits for each character.
8: Sets 8 data bits for each character.
Use databits to set data bits for each character.
Use undo databits to restore the default.
By default, 8 data bits are set for each character.
The command is only applicable to asynchronous serial interfaces (including AUX and console ports).
The device does not support data bits 5 and 6.
The data bits settings must be identical for the user interfaces of the connecting ports on the redirect device and the terminal device for communication.
# Specify 5 data bits for each character.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] databits 5
display ip http
display ip http [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ip http to display HTTP information.
# Display information about HTTP.
<Sysname> display ip http
HTTP port: 80
WLAN ACL: 100
Basic ACL: 2222
Current connection: 0
Operation status: Running
HTTP port |
Port number used by the HTTP service. |
WLAN ACL |
WLAN ACL associated with the HTTP service. |
Basic ACL |
Basic ACL number associated with the HTTP service. |
Current connection |
Number of current connections. |
Operation status |
Operation status: · Running—The HTTP service is enabled. Stopped—The HTTP service is disabled. |
display ip https
Use display ip https to display HTTPS information.
display ip https [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
# Display HTTPS information.
<Sysname> display ip https
HTTPS port: 443
SSL server policy: test
Certificate access-control-policy:
WLAN ACL: 100
Basic ACL: 2222
HTTPS port |
Port number used by the HTTPS service. |
SSL server policy |
SSL server policy associated with the HTTPS service. |
Certificate access-control-policy |
Certificate attribute-based access control policy associated with the HTTPS service. |
WLAN ACL |
WLAN ACL associated with the HTTPS service. |
Basic ACL |
Basic ACL associated with the HTTPS service. |
Operation status |
Operation status: · Running—The HTTPS service is enabled. · Stopped—The HTTPS service is disabled. |
display telnet client configuration
display telnet client configuration [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display telnet client configuration to display the related configuration information when the device serves as the Telnet client.
This command displays the source IPv4 address or source interface information of the Telnet client.
Related commands: telnet client source.
# Display the related configuration information when the device serves as the Telnet client.
<Sysname> display telnet client configuration
The source IP address is 1.1.1.1.
The output shows that the device serves as the Telnet client and it sends the Telnet packets with the source IPv4 address 1.1.1.1.
display user-interface
display user-interface [ num1 | { aux | console | vty } num2 ] [ summary ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
num1: Absolute number of a user interface.
aux: Specifies an AUX user interface.
console: Specifies a console user interface.
vty: Specifies a VTY user interface.
num2: Relative number of a user interface, 0 or 1 for an AUX or console user interface and 0 to 15 for a VTY user interface.
summary: Displays summary about user interfaces.
Use display user-interface to display information about the specified or all user interfaces.
If the summary keyword is not included, the command displays the type of the user interface, the absolute or relative number, the transmission rate, the user privilege level, the authentication mode, and the access port.
If the summary keyword is included, the command displays all user interface numbers and types.
# Display information about user interface 0.
<Sysname> display user-interface 0
Idx Type Tx/Rx Modem Privi Auth Int
+ 0 CON 0 9600 - 3 N -
+ : Current user-interface is active.
F : Current user-interface is active and work in async mode.
Idx : Absolute index of user-interface.
Type : Type and relative index of user-interface.
Privi: The privilege of user-interface.
Auth : The authentication mode of user-interface.
Int : The physical location of UIs.
A : Authentication use AAA.
L : Authentication use local database.
N : Current UI need not authentication.
P : Authentication use current UI's password.
The current user interface is active. |
F |
The current user interface is active and operating in asynchronous mode. |
Idx |
Absolute number of the user interface. |
Type |
Type and relative number of the user interface. |
Tx/Rx |
Transmission rate of the user interface. |
Modem |
Whether the modem is allowed to dial in (in), dial out (out), or both (inout). By default, the character - is displayed to indicate that this function is disabled. |
Privi |
Command level of a user under that user interface. |
Auth |
Authentication mode for users logging in from the interface, which can be A, P, L, and N. |
Int |
Physical port that corresponds to the user interface. |
A |
AAA authentication. |
L |
Local authentication. This value is not supported on the device. |
N |
No authentication. |
P |
Password authentication. |
# Display summary about all user interfaces.
<Sysname> display user-interface summary
User interface type : [CON]
0:UX
User interface type : [AUX]
2:XX
User interface type : [VTY]
20:UXXX XXXX XXXX XXXX
2 character mode users. (U)
18 UI never used. (X)
2 total UI in use
User interface type |
Type of user interface (CON/AUX/VTY). |
0:UX |
0 represents the absolute number of the user interface. X means this user interface is not used; U means this user interface is in use. For example, 9:UXXX X shows that the absolute number of the first user interface is 9, and the user interface is in use. User interfaces 10, 11, 12, and 13 are not in use. |
character mode users. (U) |
Number of users, that is, the total number of character U. |
UI never used. (X) |
Number of user interfaces not used, that is, the total number of character X. |
total UI in use |
Total number of user interfaces in use. |
display users
display users [ all ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays information about all user interfaces that the device supports.
Use display users to display information about the user interfaces that are being used.
Use display users all to display information about all user interfaces supported by the device.
# Display information about the user interfaces that are being used.
<Sysname> display users
The user application information of the user interface(s):
Idx UI Delay Type Userlevel
+ 9 VTY 0 00:00:00 TEL 3
10 VTY 1 00:02:34 TEL 3
Following are more details.
VTY 0 :
VTY 1 :
+ : Current operation user.
F : Current operation user work in async mode.
The output shows that two users have logged in to the device. The user with IP address 192.168.1.54 uses VTY 0, and the other with IP address 192.168.1.58 uses VTY 1.
Table 5 Command output
Idx |
UI |
Relative number of the user interface. The first column, for example, VTY, represents user interface type, and the second column, for example, 0, represents the relative number of the user interface. |
Delay |
Time elapsed since the user's final input, in the format of hh:mm:ss. |
Type |
User type, such as Telnet or SSH. |
Userlevel |
User level: 0 for visit, 1 for monitor, 2 for system, and 3 for manage. |
Location |
IP address of the user. |
display web users
display web users [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display web users to display information about the Web users.
# Display information about the Web users.
<Sysname> display web users
UserID Name Language Level State LinkCount LoginTime LastTime
ab890000 admin Chinese Management Enable 0 14:13:46 14:14:18
Table 6 Command output
UserID |
Web user ID. |
Name |
Web username. |
Language |
Language used in Web login. |
Level |
Web user level. |
State |
Web user status. |
LinkCount |
Number of tasks running for the Web user. |
LoginTime |
Login time. |
LastTime |
Last time when the Web user accessed the device. |
escape-key
escape-key { default | character }
undo escape-key
View
User interface view
Default level
3: Manage level
character: Specifies the shortcut key for aborting a task, a single character (or its ASCII code value in the range of 0 to 127) or a string of 1 to 3 characters. Only the first character of a string functions as the shortcut key. For example, if you enter an ASCII code value 113, the system uses its corresponding character q as the shortcut key. If you enter the string q@c, the system uses the first character q as the shortcut key.
default: Restores the default escape key sequence Ctrl+C.
Use escape-key to define a shortcut key for aborting a task.
Use undo escape-key to disable the shortcut key for aborting tasks.
By default, a task is terminated by using Ctrl+C.
After defining a new shortcut key by using the escape-key command, the new shortcut key functions to terminate a task. To display the shortcut key you have defined, use the display current-configuration command.
If you set the character argument in a user interface of a device, when you use the user interface to log in to the device and then Telnet to another device, the character argument can only be used as a control character to terminate a task, rather than as a common character. For example, if you specify character as e in VTY 0 user interface of Device A, when you log in to Device A by using VTY 0 on a PC (Hyper Terminal), you can enter e as a common character on the PC, and you can also use e to terminate the task running on Device A. If you Telnet to Device B from Device A, however, you can only use e to terminate the task running on Device B, rather than as a common character. A good practice is to configure character as a key sequence.
# Define key a as the shortcut key for aborting a task.
[Sysname-ui-console0] escape-key a
# Verify the configuration:
1. Use the ping command to check the reachability of the device with the IP address of 192.168.1.49 and use the -c argument to specify the number of ICMP echo packets to be sent as 20.
<Sysname> ping -c 20 192.168.1.49
PING 192.168.1.49: 56 data bytes, press a to break
Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
2. Enter a. The task terminates immediately and the system returns to system view.
--- 192.168.1.49 ping statistics ---
2 packet(s) transmitted
2 packet(s) received
0.00% packet loss
round-trip min/avg/max = 3/3/3 ms
<Sysname>
flow-control
undo flow-control
View
User interface view
Default level
2: System level
hardware: Performs hardware flow control.
none: Performs no flow control.
software: Performs software flow control.
Use flow-control to configure flow control mode.
Use undo flow-control to restore the default.
By default, no flow control is performed.
A flow control mode takes effect on both inbound and outbound directions. In inbound flow control, the local device listens to the remote device for flow control information while in the outbound flow control, the local device sends flow control information to the remote device.
Two ends must be configured with the same flow control mode.
The device does support hardware and software flow control.
# Configure software flow control in the inbound and outbound directions for port console 0.
[Sysname-ui-console0] flow-control software
free user-interface
free user-interface { num1 | { aux | console | vty } num2 }
View
Default level
3: Manage level
Use free user-interface to release the connection established on the specified user interface.
This command cannot release the connection that you are using.
# Release the connection to user interface VTY 1:
1. Display which user interfaces are being used on the switch.
+ 82 VTY 0 00:00:00 TEL 3
83 VTY 1 00:00:03 TEL 3
VTY 0 :
VTY 1 :
2. To prevent the user on VTY 1 from operating the switch, release the connection to VTY 1.
<Sysname> free user-interface vty 1
Are you sure to free user-interface vty1? [Y/N]:y
free web-users
free web-users { all | user-id user-id | user-name user-name }
View
Default level
2: System level
all: Specifies all Web users.
user-id: Web user ID, a hexadecimal number of eight digits.
user-name: Web user name, a string of 1 to 80 characters.
Use free web-users to log out Web users.
Related commands: display web users.
# Log out all Web users.
<Sysname> free web-users all
history-command max-size
history-command max-size size-value
undo history-command max-size
View
User interface view
Default level
2: System level
size-value: Specifies the number of history commands that the buffer can store. The value range is 0 to 256.
Use history-command max-size to set the size of history command buffer of the current user interface.
Use undo history-command max-size to restore the default.
By default, the buffer saves 10 history commands.
The history command buffer saves validated history commands individually per user interface and buffers for different user interfaces do not affect each other. To display the commands that are stored in the history buffer, use the display history-command command. To view the recently executed commands, press the upper arrow key or lower arrow key. For more information about the display history-command command, see "CLI configuration commands."
After you terminate the current session, the system automatically removes the commands saved in the related history buffer.
# Set the buffer to store 20 history commands at most.
[Sysname-ui-console0] history-command max-size 20
idle-timeout
undo idle-timeout
View
User interface view
Default level
2: System level
minutes: Specifies timeout time in minutes, in the range of 0 to 35791. The default is 10 minutes.
seconds: Specifies timeout time in seconds, in the range of 0 to 59. The default is 0 seconds.
Use idle-timeout to set the idle-timeout timer. When it expires, user sessions are terminated.
Use undo idle-timeout to restore the default.
The default idle-timeout is 10 minutes.
The system automatically terminates the user's connection if there is no information interaction between the device and the user in timeout time.
Setting idle-timeout to zero disables the timer. In this case, connections are maintained unless you terminate them.
# Set the idle-timeout timer to 1 minute and 30 seconds.
[Sysname-ui-console0] idle-timeout 1 30
ip alias
ip alias ip-address port-number
undo ip alias ip-address
View
Default level
2: System level
ip-address: IP address associated with the Telnet redirect listening port. The IP address cannot be an interface's address on the switch, but can be in the same subnet as an interface's address.
port-number: Specifies the Telnet redirect listening port in the range of 2000 to 50000.
Use ip alias to associate a Telnet redirect listening port with an IP address.
Use undo ip alias to restore the default.
By default, a Telnet redirect listening port is not associated with any IP address.
For example, a user is connected to device A, and device A is connected to device B through its serial port. If the redirect enable and redirect listen-port port-number commands are configured on device A, the user can log in to device B by Telnetting to the IP address of device A and the specified port number. If you associate device A's IP address with the specified port number with the ip alias ip-address port-number command, the user can log in to device B by only Telnetting to the IP address of device A.
# Associate the Telnet redirect listening port 2000 with the IP address 1.1.1.1.
[Sysname] ip alias 1.1.1.1 2000
ip http acl
ip http acl acl-number
undo ip http acl
View
Default level
2: System level
acl-number: ACL number. A basic IPv4 ACL is in the range of 2000 to 2999.
Use ip http acl to associate the HTTP service with an ACL.
Use undo ip http acl to remove the association.
By default, the HTTP service is not associated with any ACL.
After the HTTP service is associated with an ACL, only the clients permitted by the ACL can access the device through HTTP.
Related commands: display ip http; acl number (ACL and QoS Command Reference).
# Associate the HTTP service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network to access the device through HTTP.
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] ip http acl 2001
ip http enable
ip http enable
undo ip http enable
View
Default level
2: System level
None
Use ip http enable to enable the HTTP service.
Use undo ip http enable to disable the HTTP service.
By default, the HTTP service is disabled.
The device can act as the HTTP server that can be accessed only after the HTTP service is enabled.
Related commands: display ip http.
# Enable the HTTP service.
[Sysname] ip http enable
# Disable the HTTP service.
[Sysname] undo ip http enable
ip http port
ip http port port-number
undo ip http port
View
Default level
3: Manage level
port-number: Port number of the HTTP service, in the range of 1 to 65535.
Use ip http port to configure the port number of the HTTP service.
Use undo ip http port to restore the default.
By default, the port number of the HTTP service is 80.
Verify that the port number is not used by another service, because this command does not check for conflicts with configured port numbers.
# Configure the port number of the HTTP service as 8080.
[Sysname] ip http port 8080
ip https acl
Use ip https acl to associate the HTTPS service with an ACL.
Use undo ip https acl to remove the association.
ip https acl acl-number
undo ip https acl
The HTTPS service is not associated with any ACL.
3: Manage level
acl-number: ACL number in the range of 2000 to 2999.
After the HTTPS service is associated with an ACL, only clients permitted by the ACL can access the switch.
If you execute the ip https acl command multiple times to associate the HTTPS service with multiple ACLs, the HTTPS service is only associated with the most recently specified ACL.
# Associate the HTTPS service with ACL 2001 to allow only clients within the 10.10.0.0/16 network segment to access the HTTPS server through HTTPS.
[Sysname] ip https acl 2001
· display ip https
· acl number (ACL and QoS Command Reference)
ip https certificate access-control-policy
Use ip https certificate access-control-policy to associate the HTTPS service with a certificate attribute-based access control policy.
Use undo ip https certificate access-control-policy to remove the association.
The HTTPS service is not associated with any certificate attribute-based access control policy.
3: Manage level
policy-name: Name of the certificate attribute-based access control policy, a string of 1 to 16 characters.
The switch uses the associated certificate attribute-based access control policy to control client access rights.
# Associate the HTTPS server with certificate attribute-based access control policy myacl.
[Sysname] ip https certificate access-control-policy myacl
· display ip https
· pki certificate access-control-policy (Security Command Reference)
ip https enable
Use ip https enable to enable the HTTPS service.
Use undo ip https enable to disable the HTTPS service.
ip https enable
3: Manage level
After the HTTPS service is enabled, the device can act as the HTTPS server and you can access and manage the switch through HTTPS.
Enabling the HTTPS service triggers an SSL handshake negotiation process:
· If a local certificate exists on the switch, the SSL negotiation succeeds and the HTTPS service starts up.
· If no local certificate exists, a certificate application process is triggered. Because the application process takes much time, the SSL negotiation often fails and the HTTPS service cannot be started. In that case, execute this command multiple times to start the HTTPS service.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https port
Use ip https port to set the HTTPS service port number.
Use undo ip https port to restore the default.
ip https port port-number
undo ip https port
The HTTPS service port number is 443.
3: Manage level
port-number: HTTPS service port number in the range of 1 to 65535.
Make sure the port number is not used by any other service. This command does not check for port number conflicts.
# Set the HTTPS service port number to 6000.
[Sysname] ip https port 6000
display ip https
ip https ssl-server-policy
Use ip https ssl-server-policy to associate the HTTPS service with an SSL server policy.
Use undo ip https ssl-server-policy to remove the association.
The HTTPS service is not associated with any SSL server policy, and the device uses a self-signed certificate for authentication. (A self-signed certificate is generated and signed by the device itself, rather than the CA.)
3: Manage level
policy-name: SSL server policy name, a string of 1 to 16 characters.
If you disable the HTTPS service, the system automatically de-associates the HTTPS service from the SSL service policy. Before re-enabling the HTTPS service, re-associate the HTTPS service with an SSL server policy.
If the HTTPS service has been enabled, any changes to the SSL server policy associated with it do not take effect.
# Associate the HTTPS service with SSL server policy myssl.
[Sysname] ip https ssl-server-policy myssl
· display ip https
· ssl server-policy (Security Command Reference)
lock
lock
View
Default level
3: Manage level
None
Use lock to lock the user interface by password protection. This method prevents unauthorized users from using the user interface.
This command is supported only in non-FIPS mode.
When entering the lock command, you are asked to enter a password (up to 16 characters) and then confirm it by entering the password again. To successfully set the password, enter the same passwords. After locking the user interface, next time you enter this user interface, you must press Enter and enter the correct password.
By default, this function is disabled.
# Lock the current user interface.
<Sysname> lock
Please input password<1 to 16> to lock current user terminal interface:
Password:
Again:
locked !
Password:
parity
undo parity
View
User interface view
Default level
2: System level
even: Performs an even parity check.
mark: Performs a mark parity check.
none: Performs no parity check.
odd: Performs an odd parity check.
space: Performs a space parity check.
Use parity to set a parity check method.
Use undo parity to restore the default.
By default, no parity check is performed.
The parity check settings must be identical for the user interfaces of the connecting ports on the redirect device and the target terminal device for communication.
# Configure the AUX port to perform odd parity check.
[Sysname-ui-aux0] parity odd
protocol inbound
In non-FIPS mode:
undo protocol inbound
In FIPS mode:
protocol inbound { all | ssh }
View
VTY interface view
Default level
3: Manage level
all: Supports both Telnet and SSH. Telnet is not included in FIPS mode.
ssh: Supports SSH only.
telnet: Supports Telnet only. This keyword is not supported in FIPS mode.
Use protocol inbound to enable the current user interface to support either Telnet or SSH, or both of them.
Use undo protocol inbound to restore the default.
By default, all the three protocols are supported.
The configuration takes effect next time you log in.
Before configuring a user interface to support SSH, set the authentication mode to scheme for users logging in through the user interface; otherwise, the protocol inbound ssh command fails. For more information, see authentication-mode.
By default, the authentication mode of the Telnet protocol is password.
# Enable the VTYs 0 through 15 to support SSH only.
[Sysname] user-interface vty 0 15
[Sysname-ui-vty0-15] authentication-mode scheme
[Sysname-ui-vty0-15] protocol inbound ssh
screen-length
screen-length screen-length
undo screen-length
View
User interface view
Default level
2: System level
screen-length: Number of lines on a screen, in the range of 0 to 512. The value of 0 disables pausing between screens of output.
Use screen-length to set the maximum number of lines on a screen.
Use undo screen-length to restore the default.
By default, a screen displays 24 lines at most.
When screen output pauses, press the Space key to display the next screen. Not all display terminals support this command setting. For example, assume that you set screen-length to 40, but the terminal screen can display 24 lines at most. When you press Space, the device sends 40 lines to the terminal display, but the next screen displays only lines 18 through 40. To view the first 17 lines, you must press Page Up or Page Down.
To disable pausing between screens of output for the current session, use the screen-length disable command.
# Set the user interface of console port 0 to display up to 30 lines on a screen.
[Sysname-ui-console0] screen-length 30
send
send { all | num1 | { aux | console | vty } num2 }
View
Default level
1: Monitor level
all: Sends messages to all user interfaces.
aux: Sends messages to an AUX user interface.
console: Sends messages to a console user interface.
vty: Sends messages to a VTY user interface.
Use send to send messages to the specified user interfaces.
To end message input, press Ctrl+Z. To cancel message input and exit to user view, press Ctrl+C.
# Send message hello abc to the console user interface.
<Sysname> send console 0
Enter message, end with CTRL+Z or Enter; abort with CTRL+C:
hello abc^Z
Send message? [Y/N]:y
<Sysname>
***Message from con0 to con0
hello abc
<Sysname>
# Before you restart the device, inform the user on user interface VTY 1 so the user prepare for the reboot.
<Sysname> send vty 1
Note please, I will reboot the system!^Z
<Sysname>
The message should appear on the screen of the user's configuration terminal. The following example assumes that the user was executing the interface GigabitEthernet command when the message arrived:
[Sysname] interface Giga
***Message from vty0 to vty1
set authentication password [ hash ] { cipher | simple } password
undo set authentication password
View
User interface view
Default level
3: Manage level
hash: Enables hash-based encryption.
{ cipher | simple } password: Specifies a case-sensitive password string. The password length and form requirements vary with the keyword combinations (see Table 7).
Table 7 Password length and form requirements for the password argument
Keyword combination |
Password string form |
Length (in characters) |
simple |
Plain text |
1 to 16 |
hash simple |
Plain text |
1 to 16 |
cipher |
Plain text, ciphertext |
Plain text: 1 to 16 Ciphertext: 1 to 53 |
hash cipher |
Ciphertext (hashed form) |
1 to 110 |
Use set authentication password to set a local authentication password.
Use undo set authentication password to remove the local authentication password.
By default, no local authentication password is set.
For security purposes, all passwords, including passwords configured in plain text, are saved in cipher text.
Store the plaintext forms of the local authentication password in a safe place. If a user interface is password protected, you must provide the password in plain text when logging in to the user interface.
Related commands: authentication-mode.
# Set the local authentication password for user interface console 0 to hello.
[Sysname-ui-console0] authentication-mode password
[Sysname-ui-console0] set authentication password simple hello
shell
shell
undo shell
View
User interface view
Default level
3: Manage level
None
Use shell to enable terminal services on the user interface.
Use undo shell to disable terminal services.
You cannot disable the terminal services on the user interface where you are logged in.
The undo shell command is not supported by the console port.
By default, terminal services are enabled on all user interfaces.
# Disable terminal services on VTYs 0 through 4, which means you cannot log in to the switch from VTYs 0 through 4.
[Sysname-ui-vty0-4] undo shell
% Disable ui-vty0-4 , are you sure? [Y/N]:y
[Sysname-ui-vty0-4]
The following message appears when a terminal tries to Telnet to the device:
The connection was closed by the remote host!
speed (user interface view)
speed speed-value
undo speed
View
User interface view
Default level
2: System level
speed-value: Transmission rate in bps.
Use speed to set the transmission rate on the user interface.
Use undo speed to restore the default transmission rate.
By default, the transmission rate is 9600 bps.
The transmission rate settings must be identical for the user interfaces of the connecting ports on the redirect device and the target terminal device for communication.
# Set the transmission rate on the user interface AUX 0 to 19200 bps.
[Sysname-ui-aux0] speed 19200
stopbits
stopbits { 1 | 1.5 | 2 }
undo stopbits
View
User interface view
Default level
2: System level
1: One stop bit.
1.5: One and a half stop bits.
2: Two stop bits.
Use stopbits to set the number of stop bits transmitted per byte.
Use undo stopbits to restore the default.
By default, one stop bit is used.
The device does not support stop bits 1.5.
The stop bits settings must be the identical for the user interfaces of the connecting ports on the redirect device and the target device for communication.
# Set the stop bits on the user interface AUX 0 to 1.
[Sysname-ui-aux0] stopbits 1
telnet
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } ]
View
Default level
0: Visit level
remote-host: IPv4 address or host name of the remote host. The host name is a case-insensitive string of 1 to 20 characters.
service-port: TCP port number for the remote Telnet server, in the range of 0 to 65535. The default is 23.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the remote system belongs to, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the remote system is on the public network, do not specify this option.
source: Specifies the source interface or source IPv4 address of Telnet packets.
interface interface-type interface-number: Specifies the source interface. The source IPv4 address of the Telnet packets sent is the IPv4 address of the specified source interface. interface-type interface-number represents the interface type and number.
ip ip-address: Specifies the source IPv4 address of Telnet packets.
Use telnet to Telnet to a remote host. To stop the current Telnet login, press Ctrl+K or use the quit command.
The source IPv4 address or source interface specified by this command is applicable to the current Telnet connection only.
# Telnet to the remote host with the IP address 1.1.1.2, and specify the source IP address of Telnet packets as 1.1.1.1.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
undo telnet client source
View
Default level
2: System level
interface interface-type interface-number: Specifies the source interface. The source IPv4 address of the Telnet packets sent is the IPv4 address of the specified interface. interface-type interface-number represents the interface type and number.
Use telnet client source to specify the source IPv4 address or source interface for sending Telnet packets when the device serves as the Telnet client.
Use undo telnet client source to remove the configuration.
By default, no source IPv4 address or source interface is specified for Telnet packets, and the system uses the IPv4 address of the interface determined by the matched route as the source IPv4 address of Telnet packets.
The source IPv4 address or source interface specified by this command is applicable to all Telnet connections.
If you use both this command and the telnet command to specify the source IPv4 address or source interface, the source IPv4 address or interface specified by the telnet command takes effect.
Related commands: display telnet client configuration.
telnet ipv6
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ]
View
Default level
0: Visit level
remote-host: IP address or host name of the remote host. The host name is a case-insensitive string of 1 to 46 characters.
-i interface-type interface-number: Specifies the outbound interface for sending Telnet packets, where interface-type interface-number represents the interface type and number. You must provide the -i interface-type interface-number argument if the destination address is a link-local address.
port-number: TCP port number of the remote Telnet server, in the range of 0 to 65535. The default is 23.
Use telnet ipv6 to Telnet to a remote IPv6 host. To stop the current Telnet login, press Ctrl+K or use the quit command.
# Telnet the remote host with the IPv6 address 2000::1.
<Sysname> telnet ipv6 2000::1
telnet server enable
undo telnet server enable
View
Default level
3: Manage level
None
Use telnet server enable to enable the Telnet server.
Use undo telnet server enable to disable the Telnet server.
The Telnet server is disabled by default.
# Enable the Telnet server.
terminal type
undo terminal type
View
User interface view
Default level
2: System level
ansi: Specifies the terminal display type as ANSI.
vt100: Specifies the terminal display type as VT100.
Use terminal type to configure the type of terminal display under the current user interface.
Use undo terminal type to restore the default.
By default, the terminal display type is ANSI.
The device supports two terminal display types: ANSI and VT100. H3C recommends that you set the display type to VT100 on both the device and the configuration terminal. If either side uses the ANSI type, a display problem such as cursor positioning error might occur when a command line has more than 80 characters.
# Set the terminal display type to VT100.
[Sysname-ui-vty0] terminal type vt100
user privilege level level
undo user privilege level
View
User interface view
Default level
3: Manage level
level: Specifies a command level in the range of 0 to 3.
Use user privilege level to configure the command level for login users on the current user interface.
Use undo user privilege level to restore the default.
By default, the default command level is 3 for the console and AUX user interfaces and 0 for the other user interfaces.
Command levels include visit, monitor, system, and manage, represented by the number 0, 1, 2, and 3 respectively. You can change the command level of a user when necessary.
# Set the command level for the user logging in from VTY 0 to 0.
[Sysname-ui-vty0] user privilege level 0
After you Telnet to the device from VTY 0, the terminal only displays commands of level 0 in the help information:
<Sysname> ?
User view commands:
display Display current system information
ping Ping function
quit Exit from current command view
ssh2 Establish a secure shell client connection
super Set the current user priority level
telnet Establish one TELNET connection
tracert Trace route function
user-interface
user-interface { first-num1 [ last-num1 ] | { aux | console | vty } first-num2 [ last-num2 ] }
View
Default level
2: System level
first-num1: Absolute number of the first user interface.
last-num1: Absolute number of the last user interface. The value typically starts from 0 and cannot be smaller than the first-num1.
first-num2: Relative number of the first user interface, 0 or 1 for an AUX or console user interface and 0 to 15 for a VTY user interface.
last-num2: Relative number of the last user interface. For VTY user interfaces, the value range is (first-num2+1) to 15.
Use user-interface to enter a single or multiple user interface views.
In a single user interface view, the configuration takes effect in the user view only.
In multiple user interface views, the configuration takes effect in these user views.
# Enter console user interface view.
# Enter the user interface view of VTY 0 to 4.
[Sysname-ui-vty0-4]
web captcha
web captcha verification-code
undo web captcha
View
Default level
3: Manage level
verification-code: Fixed verification code for Web login, a case-sensitive 4-character string.
Use web captcha to specify a fixed verification code for Web login.
Use undo web captcha to restore the default.
By default, a Web user must enter the verification code indicated on the login page to log in.
After you configure a fixed verification code for Web login, a Web user can use the code for login, without caring about the verification code displayed on the login page. This feature is intended for test environments where a script is usually used for Web function tests. Eliminating the requirement for entering the verification code every time, this feature helps improve the test efficiency.
For Web access security, do not use this feature in production environments.
This command is not saved to the configuration file and cannot survive a reboot.
# Specify a fixed verification code for Web login
<Sysname> web captcha test
web https-authorization mode
Use web https-authorization mode to set the HTTPS user authentication mode.
Use undo web https-authorization mode to restore the default.
The HTTPS user authentication mode is manual.
2: System level
auto: Uses the PKI certificates of HTTPS clients to authenticate them.
manual: Provides a login page for HTTPS users to enter the correct username and password.
In manual mode, a user must enter the correct username and password to log in through HTTPS.
In auto mode, the switch first checks the certificate of the client:
· If the certificate is correct and not expired, the CN field in the certificate is used as the username to perform AAA authentication. If the authentication succeeds, the Web interface of the device appears on the user's terminal.
· If the certificate is correct and not expired, but the AAA authentication fails, the device shows the Web login page and the user must enter the correct username and password to log in.
· If the certificate is incorrect or expired, the HTTPS connection is terminated.
# Set the HTTPS user authentication mode to auto.
[Sysname] web https-authorization mode auto
