01-Fundamentals Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18201-Fundamentals Command Reference
09-Password recovery control command
09-Password recovery control command 51.12 KB
password-recovery enable
undo password-recovery enable
View
Default level
3: Manage level
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
By default, password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus. This feature also determines the method for dealing with console login password loss.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Table 1 summarizes options whose availability varies with the password recovery capability setting.
Table 1 BootWare options and password recovery capability compatibility matrix
BootWare menu option
Password recovery enabled
Password recovery disabled
Tasks that can be performed
Download Application Program To SDRAM And Run
Yes
No
Load and run the system software image in SDRAM.
Update User Private File
Yes
No
Download a file to the current storage medium.
Clear Super Password
Yes
No
Clear the console login password to allow console login without authentication.
This is a one-time operation and takes effect only for the first system boot or reboot after you choose this option.
Modify Chassis ID Operation
Yes
No
Switch between IRF mode and standalone mode and change the member ID of the device. For more information about IRF, see IRF Configuration Guide.
Skip Current System Configuration
Yes
No
Load the factory-default configuration without deleting the next-startup configuration file.
This is a one-time operation and takes effect only for the first system boot or reboot after you perform the operation.
Restore to Factory Default Configuration
No
Yes
Delete the next-startup configuration file and load the factory-default configuration.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
