11-High Availability Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10011-High Availability Configuration Examples
03-S12500_Smart_Link_and_Monitor_Link_Configuration_Examples
Introduction
This document provides Smart Link and Monitor Link configuration examples.
Monitor Link collaborates with Smart Link when it is configured on the upstream device of the smart link group. Monitor Link adapts the up/down state of downlink ports to uplink ports, and triggers Smart Link to perform link switchover on the downstream device.
This document assumes that you have basic knowledge of Smart Link and Monitor Link.
Example: Configuring Smart Link and Monitor Link
Network requirements
As shown in Figure 1, in an enterprise network, VLAN 10 and VLAN 11 are assigned to the finance department and the marketing department, respectively. To improve connection reliability, Device A at  the access layer provides two uplinks to Device D at the distribution layer.
·     Configure Smart Link to implement link redundancy and load sharing. When the link between Device A and Device B and the link between Device A and Device C are both available, the finance and marketing departments' traffic flows are forwarded along different paths. When one link fails, link switchover occurs. When the link recovers, traffic flows are switched to the original path.
·     Configure Monitor Link to adapt the state of port GE 9/0/1 to the state of port GE 9/0/2 on Device B and Device C. If a link failure occurs, Smart Link performs link switchover to avoid traffic interruption.
Figure 1 Network diagram
Port
VLAN
Port
VLAN
Device A
GE9/0/1
VLANs 10 and 11
Device C
GE9/0/1
VLANs 10 and 11
GE9/0/2
VLANs 10 and 11
GE9/0/2
VLANs 10 and 11
GE9/0/3
VLAN 10
Device D
GE9/0/1
VLANs 10 and 11
GE9/0/4
VLAN 11
GE9/0/2
VLANs 10 and 11
Device B
GE9/0/1
VLANs 10 and 11
GE9/0/3
VLANs 10 and 11
GE9/0/2
VLANs 10 and 11
Requirements analysis
To implement link load sharing on the two uplinks, create two smart link groups with the same members on Device A. The role of the same port must be different in the two smart link groups.
To switch traffic to the original path upon link recovery, enable role preemption for the two smart link groups.
To notify the upstream device to refresh MAC address forwarding entries and ARP/ND entries when link switchover occurs in a smart link group, enable flush message sending on Device A, and enable flush message receiving on ports of the primary and secondary links from Device A to Device D.
Software version used
This configuration example was created and verified on S12500-CMW520-R1825P01.
When you configure Smart Link and Monitor Link, follow these restrictions and guidelines:
·     Before specifying a multiple spanning tree instance (MSTI), configure the MSTI.
·     Configure the VLANs to which the member ports of a smart link group are assigned as the protected VLANs of the smart link group.
·     STP- or RRPP-enabled ports and link aggregation group member ports cannot be assigned to a smart link group as member ports.
·     You cannot enable flush message receiving on a link aggregation group member port.
·     Make sure the control VLANs already exist and assign the flush message receiving-enabled ports to the control VLANs.
Configuration procedures
Configuring Device A
# Configure ports GigabitEthernet 9/0/1 and GigabitEthernet 9/0/2 as trunk ports, assign them to VLANs 10 and 11, and disable STP. Configure ports GigabitEthernet 9/0/3 and GigabitEthernet 9/0/4 as access ports and assign them to VLAN 10 and VLAN 11, respectively.
[DeviceA] vlan 10 to 11
 Please wait... Done.
[DeviceA] interface GigabitEthernet 9/0/1
[DeviceA-GigabitEthernet9/0/1] port link-type trunk
[DeviceA-GigabitEthernet9/0/1] port trunk permit vlan 10 11
[DeviceA-GigabitEthernet9/0/1] undo port trunk permit vlan 1
[DeviceA-GigabitEthernet9/0/1] undo stp enable
[DeviceA-GigabitEthernet9/0/1] undo shutdown
[DeviceA-GigabitEthernet9/0/1] quit
[DeviceA] interface GigabitEthernet 9/0/2
[DeviceA-GigabitEthernet9/0/2] port link-type trunk
[DeviceA-GigabitEthernet9/0/2] port trunk permit vlan 10 11
[DeviceA-GigabitEthernet9/0/2] undo port trunk permit vlan 1
[DeviceA-GigabitEthernet9/0/2] undo stp enable
[DeviceA-GigabitEthernet9/0/2] undo shutdown
[DeviceA-GigabitEthernet9/0/2] quit
[DeviceA] interface GigabitEthernet 9/0/3
[DeviceA-GigabitEthernet9/0/3] port access vlan 10
[DeviceA-GigabitEthernet9/0/3] undo shutdown
[DeviceA-GigabitEthernet9/0/3] quit
[DeviceA] interface GigabitEthernet 9/0/4
[DeviceA-GigabitEthernet9/0/4] port access vlan 11
[DeviceA-GigabitEthernet9/0/4] undo shutdown
[DeviceA-GigabitEthernet9/0/4] quit
# Map VLAN 10 to MSTI 1 and VLAN 11 to MSTI 2.
[DeviceA] stp region-configuration
[DeviceA-mst-region] instance 1 vlan 10
[DeviceA-mst-region] instance 2 vlan 11
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Create smart link group 1, and configure VLAN 10 that is mapped to MSTI 1 as a protected VLAN for smart link group 1.
[DeviceA] smart-link group 1
[DeviceA-smlk-group1] protected-vlan reference-instance 1
# Configure GigabitEthernet 9/0/1 as the primary port and GigabitEthernet 9/0/2 as the secondary port.
[DeviceA-smlk-group1] port GigabitEthernet 9/0/1 master
[DeviceA-smlk-group1] port GigabitEthernet 9/0/2 slave
# Enable flush message sending and configure VLAN 10 as the transmit control VLAN for smart link group 1.
[DeviceA-smlk-group1] flush enable control-vlan 10
# Enable role preemption and use the default preemption delay.
[DeviceA-smlk-group1] preemption mode role
[DeviceA-smlk-group1] quit
# Create smart link group 2, and configure VLAN 11 that is mapped to MSTI 2 as a protected VLAN for smart link group 1.
[DeviceA] smart-link group 2
[DeviceA-smlk-group2] protected-vlan reference-instance 2
# Configure GigabitEthernet 9/0/2 as the primary port and GigabitEthernet 9/0/1 as the secondary port.
[DeviceA-smlk-group2] port GigabitEthernet 9/0/2 master
[DeviceA-smlk-group2] port GigabitEthernet 9/0/1 slave
# Enable flush message sending and configure VLAN 11 as the transmit control VLAN for smart link group 2.
[DeviceA-smlk-group2] flush enable control-vlan 11
[DeviceA-smlk-group2] preemption mode role
[DeviceA-smlk-group2] quit
Configuring Device B
# Configure ports GigabitEthernet 9/0/1 and GigabitEthernet 9/0/2 as trunk ports, and assign them to VLAN 10 and VLAN 11. Enable flush message receiving on the ports, and configure VLANs 10 and 11 as the receive control VLANs.
[DeviceB] vlan 10 to 11
[DeviceB] interface GigabitEthernet 9/0/1
[DeviceB-GigabitEthernet9/0/1] port link-type trunk
[DeviceB-GigabitEthernet9/0/1] port trunk permit vlan 10 11
[DeviceB-GigabitEthernet9/0/1] undo port trunk permit vlan 1
[DeviceB-GigabitEthernet9/0/1] smart-link flush enable control-vlan 10 11
[DeviceB-GigabitEthernet9/0/1] undo shutdown
[DeviceB-GigabitEthernet9/0/1] quit
[DeviceB] interface GigabitEthernet 9/0/2
[DeviceB-GigabitEthernet9/0/2] port link-type trunk
[DeviceB-GigabitEthernet9/0/2] port trunk permit vlan 10 11
[DeviceB-GigabitEthernet9/0/2] undo port trunk permit vlan 1
[DeviceB-GigabitEthernet9/0/2] smart-link flush enable control-vlan 10 11
[DeviceB-GigabitEthernet9/0/2] undo shutdown
[DeviceB-GigabitEthernet9/0/2] quit
# Create monitor link group 1.
[DeviceB] monitor-link group 1
# Configure GigabitEthernet 9/0/2 as an uplink port and GigabitEthernet 9/0/1 as a downlink port.
[DeviceB-mtlk-group1] port GigabitEthernet 9/0/2 uplink
[DeviceB-mtlk-group1] port GigabitEthernet 9/0/1 downlink
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10 to 11
[DeviceC] interface GigabitEthernet 9/0/1
[DeviceC-GigabitEthernet9/0/1] port link-type trunk
[DeviceC-GigabitEthernet9/0/1] port trunk permit vlan 10 11
[DeviceC-GigabitEthernet9/0/1] undo port trunk permit vlan 1
[DeviceC-GigabitEthernet9/0/1] smart-link flush enable control-vlan 10 11
[DeviceC-GigabitEthernet9/0/1] undo shutdown
[DeviceC-GigabitEthernet9/0/1] quit
[DeviceC] interface GigabitEthernet 9/0/2
[DeviceC-GigabitEthernet9/0/2] port link-type trunk
[DeviceC-GigabitEthernet9/0/2] port trunk permit vlan 10 11
[DeviceC-GigabitEthernet9/0/2] undo port trunk permit vlan 1
[DeviceC-GigabitEthernet9/0/2] smart-link flush enable control-vlan 10 11
[DeviceC-GigabitEthernet9/0/2] undo shutdown
[DeviceC-GigabitEthernet9/0/2] quit
[DeviceC] monitor-link group 1
[DeviceC-mtlk-group1] port GigabitEthernet 9/0/2 uplink
[DeviceC-mtlk-group1] port GigabitEthernet 9/0/1 downlink
Configuring Device D
# Configure ports GigabitEthernet 9/0/1, GigabitEthernet 9/0/2, and GigabitEthernet 9/0/3 as trunk ports, and assign the ports to VLAN 10 and VLAN 11. Enable flush message receiving and configure VLANs 10 and 11 as the receive control VLANs on GigabitEthernet 9/0/1 and GigabitEthernet 9/0/2.
<DeviceD> system-view
[DeviceD] vlan 10 to 11
[DeviceD] interface GigabitEthernet 9/0/1
[DeviceD-GigabitEthernet9/0/1] port link-type trunk
[DeviceD-GigabitEthernet9/0/1] port trunk permit vlan 10 11
[DeviceD-GigabitEthernet9/0/1] undo port trunk permit vlan 1
[DeviceD-GigabitEthernet9/0/1] smart-link flush enable control-vlan 10 11
[DeviceD-GigabitEthernet9/0/1] undo shutdown
[DeviceD-GigabitEthernet9/0/1] quit
[DeviceD] interface GigabitEthernet 9/0/2
[DeviceD-GigabitEthernet9/0/2] port link-type trunk
[DeviceD-GigabitEthernet9/0/2] port trunk permit vlan 10 11
[DeviceD-GigabitEthernet9/0/2] undo port trunk permit vlan 1
[DeviceD-GigabitEthernet9/0/2] smart-link flush enable control-vlan 10 11
[DeviceD-GigabitEthernet9/0/2] undo shutdown
[DeviceD-GigabitEthernet9/0/2] quit
[DeviceD] interface GigabitEthernet 9/0/3
[DeviceD-GigabitEthernet9/0/3] port link-type trunk
[DeviceD-GigabitEthernet9/0/3] port trunk permit vlan 10 11
[DeviceD-GigabitEthernet9/0/3] undo port trunk permit vlan 1
[DeviceD-GigabitEthernet9/0/3] undo shutdown
[DeviceD-GigabitEthernet9/0/3] quit
# Display the smart link configuration on Device A.
[DeviceA] display smart-link group all
 Smart link group 1 information:
 Device ID: 0020-6455-0000
 Preemption mode: ROLE
 Preemption delay: 1(s)
 Control VLAN: 10
 Protected VLAN: Reference Instance 1
 Member                     Role    State    Flush-count Last-flush-time
 GigabitEthernet9/0/1       MASTER  ACTIVE     0           NA
 GigabitEthernet9/0/2      SLAVE   STANDBY     0           NA
 Smart link group 2 information:
 Control VLAN: 11
 Protected VLAN: Reference Instance 2
 GigabitEthernet9/0/2       MASTER  ACTIVE     0           NA
 GigabitEthernet9/0/1      SLAVE   STANDBY     0           NA
# Display the monitor link configuration on Device B.
[DeviceB] display monitor-link group all
 Monitor link group 1 information:
 Group status: UP
 Last-up-time: 16:49:24 2009/01/16
 Last-down-time: -
 Member                    Role     Status
 GigabitEthernet9/0/2      UPLINK   UP
 GigabitEthernet9/0/1      DOWNLINK UP
# Display the monitor link configuration on Device C.
[DeviceC] display monitor-link group all
 Group status: UP
 Last-up-time: 16:53:13 2009/01/16
 Last-down-time: -
 Member                    Role     Status
After completing the configurations, send traffic of VLAN 10 and VLAN 11 to GigabitEthernet 9/0/3 and GigabitEthernet 9/0/4 on Device A, respectively. Traffic of VLAN 10 reaches Device D through Device B, and traffic of VLAN 11 reaches Device D through Device C.
Configuration files
·     Device A:
vlan 1
vlan 10 to 11
 instance 1 vlan 10
 instance 2 vlan 11
smart-link group 1
smart-link group 2
interface GigabitEthernet9/0/1
 port link-mode bridge
 port trunk permit vlan 10 to 11
 stp disable
 port smart-link group 1 master
 port smart-link group 2 slave
interface GigabitEthernet9/0/2
 stp disable
 port smart-link group 1 slave
 port smart-link group 2 master
·     Device B:
vlan 1
vlan 10 to 11
 smart-link flush enable control-vlan 10 to 11
 port monitor-link group 1 downlink
 port monitor-link group 1 uplink
·     Device C:
vlan 1
vlan 10 to 11
·     Device D:
vlan 1
vlan 10 to 11
interface GigabitEthernet9/0/3
Related documentation
·     H3C S12500 Routing Switch Series High Availability Configuration Guide
·     H3C S12500 Routing Switch Series High Availability Command Reference
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Configuration Guide
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Command Reference
