09-ACL and QoS Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guide-Release7128-6W71009-ACL and QoS Configuration Guide
04-Data buffer configuration
04-Data buffer configuration 86.09 KB
Configuring data buffers
The switch operates in IRF or standalone (the default) mode. For information about the IRF mode, see IRF Configuration Guide.
Overview
Data buffers temporarily store packets to avoid packet loss.
An interface card has an ingress buffer and an egress buffer. An interface stores outgoing packets in the egress buffer when congestion occurs, and stores incoming packets in the ingress buffer when the CPU is busy.
Buffer resource
As the smallest unit of a buffer, buffer resources are used to store packets. An interface uses buffer resources based on packet sizes. Suppose a buffer resource provides 512 bytes. The interface allocates one buffer resource to a 504-byte packet and two buffer resources to a 520-byte packet. The switch provides 512 bytes per buffer resource for the egress buffer and 1024 bytes per buffer resource for the ingress buffer.
Shared area and fixed area
Both an ingress buffer and an egress buffer have a shared area and a fixed area. The shared area is partitioned into queues, as shown in Figure 1.
·           The shared area is shared by the queues of all interfaces. When an interface or a queue receives traffic bursts, it can temporarily preempt buffer resources of the shared area. After sending out the traffic bursts, the interface releases the preempted resources for use by other interfaces or queues. You can manually configure the number of buffer resources for the shared area, and the rest is automatically assigned to the fixed area.
·           The fixed area is allocated to interfaces and then to queues of each interface. The switch allocates the buffer resources of the fixed area equally among all interfaces on an interface card and then allocates the buffer resources of each interface equally among all its queues. In this manner, all queues of all interfaces have an equal number of dedicated buffer resources.
Figure 1 Shared area and fixed area
When congestion occurs:
1.      An interface first uses the buffer resources of the shared area to store packets.
2.      When no buffer resources are available in the shared area, the interface uses the buffer resources of the corresponding queue in the fixed area.
3.      When no buffer resources of the queue in the fixed area are available, the interface discards subsequent packets.
When an interface uses the egress buffer, packets with drop precedence 0 can use buffer resources in both the shared area and fixed area, but packets with drop precedence 1 or 2 can use only buffer resources in the fixed area.
·       Only cards with silk screen LST1XP16LEB1 or LST1XP16LEC1 support configuring the ingress buffer.
·       The configuration of the ingress buffer takes effect only on the default MDC. For information about MDC, see Fundamentals Configuration Guide.
Configuring a data buffer
CAUTION
CAUTION:
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device.
Configuring the shared-area size
The data buffer on an interface card has a fixed size. After you set the shared-area size for a data buffer, the rest is automatically assigned to the fixed area.
To configure the shared area size:
Step
Remarks
1.     Enter system view.
N/A
2.     Configure the shared-area size.
·       In standalone mode:
buffer { ingress | egress } [ slot slot-number ] packet total-shared size-value
·       In IRF mode:
buffer { ingress | egress } [ chassis chassis-number slot slot-number ] packet total-shared size-value
The default setting is 1024 buffer resources for the ingress buffer and 4096 buffer resources for the egress buffer.
Applying data buffer configuration
Perform this task to apply the data buffer configuration.
You cannot directly modify the applied configuration. To modify the configuration, you must cancel the application, re-configure data buffers, and re-apply the configuration.
To apply data buffer configuration:
Step
2.     Apply data buffer configuration.
buffer apply
Displaying and maintaining data buffers
Display data buffer configuration (in standalone mode).
display buffer [ slot slot-number ]
Display data buffer configuration (in IRF mode).
display buffer [ chassis chassis-number slot slot-number ]
applying data buffer configuration, 3
buffer resource
data buffer configuration, 1
data buffer shared-area size configuration, 2
configuring
data buffer shared-area size, 2
data buffers, 1
data buffer
applying configuration, 3
configuration, 1
displaying, 3
maintaining, 3
displaying data buffers, 3
drop precedence
shared area, 1
fixed area
drop precedence, 1
maintaining data buffers, 3
network
network management
overview
buffer resource, 1
congestion, 1
drop precedence, 1
fixed area, 1
shared area, 1
procedure
configuring data buffer shared-area size, 2
displaying data buffer, 3
maintaining data buffer, 3
shared area
drop precedence, 1
