01-Fundamentals Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71001-Fundamentals Command Reference
11-MDC commands
11-MDC commands 116.2 KB
MDC commands
MDC commands for the default MDC
This section describes the MDC commands you can use after logging in to the default MDC (the physical device).
All commands indicated to be in "MDC view" are only available in the view for a non-default MDC. You can use the mdc command to enter the view of the default MDC, but in this view you can only display the relevant settings.
Unless otherwise stated, the term "MDC" in this section refers to a non-default MDC.
allocate interface
Use allocate interface to assign a physical interface to an MDC.
Use undo allocate interface to reclaim a physical interface assigned to an MDC.
allocate interface { interface-type interface-number }&<1-24>
undo allocate interface { interface-type interface-number }&<1-24>
allocate interface interface-type interface-number1 to interface-type interface-number2
undo allocate interface interface-type interface-number1 to interface-type interface-number2
All physical interfaces on the device belong to the default MDC, and a non-default MDC has no physical interfaces to use.
MDC view
{ interface-type interface-number }&<1-24>: Specifies individual interfaces by their types and numbers. &<1-24> indicates that you can specify up to 24 interfaces.
interface-type interface-number1 to interface-type interface-number2: Specifies a range of interfaces. The interface-number1 argument indicates the number of the first interface for the range, and the interface-number2 argument indicates the number of the last interface for the range. All interfaces in the range must be of the same type and on the same interface card.
The console port and AUX port of the device always belong to the default MDC. They cannot be assigned to a non-default MDC.
The management Ethernet interface of the device always belongs to the default MDC. When a non-default MDC is created, the system automatically creates a management Ethernet interface for the MDC. The management Ethernet interfaces of all non-default MDCs use the same type and number and the same physical port and link as that of the default MDC. However,  you must assign them different IP addresses so administrators of different MDCs access and manage their respective MDCs. The IP addresses for the MDCs' management Ethernet interfaces might belong to the same network segment or different segments.
Only a physical interface that belongs to the default MDC can be assigned to a non-default MDC.
You can assign multiple physical interfaces to an MDC.
One physical interface can belong to only one MDC. To assign a physical interface that belongs to one non-default MDC to another non-default MDC, you must first remove the existing assignment by using the undo allocate interface command.
Because of hardware restrictions, the interfaces on some interface cards are grouped. The interfaces in a group must be assigned to the same MDC at the same time.
Assigning a physical interface to or reclaiming a physical interface from an MDC restores the settings of the interface to the defaults.
To configure parameters for a physical interface assigned to an MDC, you must log in to the MDC.
After you change the configuration of a physical IRF port, you must use the save command to save the running configuration. Otherwise, after a reboot, the master and subordinate devices in the IRF fabric will have different physical IRF port configurations and you must use the undo allocate interface command and the undo port group interface command to restore the default and reconfigure the physical IRF port. For more information about the undo port group interface command, see IRF Command Reference.
# Assign interfaces GigabitEthernet 3/0/1 through GigabitEthernet3/0/48 to MDC sub1.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] allocate interface GigabitEthernet 3/0/1 to GigabitEthernet 3/0/48
The configuration of the interfaces will be lost. Continue? [Y/N]:Y
Execute the location slot command in this view to make the configuration take effect.
display mdc
Use display mdc to display MDCs and their status.
display mdc [ name mdc-name ]
name mdc-name: Specifies an MDC by its name, a case-insensitive string of 1 to 15 characters. If you do not specify this option, the command displays all MDCs.
# Display all MDCs.
<Sysname> display mdc
ID         Name            Status
1          Admin           active
2          sub1            inactive
Status
Status of the MDC:
·       inactive—The MDC is stopped or not started yet.
·       starting—The device is executing the mdc start command to start the MDC.
·       active—The MDC is operating normally.
·       updating—The device is executing the location command to authorize the MDC to use an interface card.
·       stopping—The device is executing the undo mdc start command to stop the MDC.
mdc
display mdc interface
Use display mdc interface to display the interfaces of MDCs.
display mdc [ name mdc-name ] interface
name mdc-name: Specifies an MDC by its name, a case-insensitive string of 1 to 15 characters. If you do not specify this option, the command displays the interfaces of all MDCs.
The default MDC can use only the physical interfaces that are not assigned to a non-default MDC. When you assign physical interfaces to MDCs on an IRF member device, make sure the default MDC always has at least one physical IRF port in up state. Assigning the default MDC's last physical IRF port in up state to a non-default MDC splits the IRF fabric.
# Display the interfaces of all MDCs.
MDC Admin's interface(s):
  M-Ethernet0/0/0
 MDC sub1's interface(s):
  GigabitEthernet7/0/1                 GigabitEthernet7/0/2
  GigabitEthernet7/0/3                 GigabitEthernet7/0/4
  GigabitEthernet7/0/5                 GigabitEthernet7/0/6
  GigabitEthernet7/0/7                 GigabitEthernet7/0/8
  GigabitEthernet7/0/9                 GigabitEthernet7/0/10
  GigabitEthernet7/0/11                GigabitEthernet7/0/12
  GigabitEthernet7/0/13                GigabitEthernet7/0/14
  GigabitEthernet7/0/15                GigabitEthernet7/0/16
  GigabitEthernet7/0/17                GigabitEthernet7/0/18
  GigabitEthernet7/0/19                GigabitEthernet7/0/20
  GigabitEthernet7/0/21                GigabitEthernet7/0/22
  GigabitEthernet7/0/23                GigabitEthernet7/0/24
  GigabitEthernet7/0/25                GigabitEthernet7/0/26
  GigabitEthernet7/0/27                GigabitEthernet7/0/28
  GigabitEthernet7/0/29                GigabitEthernet7/0/30
  GigabitEthernet7/0/31                GigabitEthernet7/0/32
  GigabitEthernet7/0/33                GigabitEthernet7/0/34
  GigabitEthernet7/0/35                GigabitEthernet7/0/36
  GigabitEthernet7/0/37                GigabitEthernet7/0/38
  GigabitEthernet7/0/39                GigabitEthernet7/0/40
  GigabitEthernet7/0/41                GigabitEthernet7/0/42
  GigabitEthernet7/0/43                GigabitEthernet7/0/44
  GigabitEthernet7/0/45                GigabitEthernet7/0/46
  GigabitEthernet7/0/47                GigabitEthernet7/0/48
allocate interface
display mdc resource
Use display mdc resource to display the CPU, disk space, and memory usage of MDCs.
In standalone mode:
display mdc [ name mdc-name ] resource [ cpu | disk | memory ] [ slot slot-number ]
In IRF mode:
display mdc [ name mdc-name ] resource [ cpu | disk | memory ] [ chassis chassis-number slot slot-number ]
name mdc-name: Specifies an MDC by its name, a case-insensitive string of 1 to 15 characters. If you do not specify this option, the command displays the usage of all MDCs.
cpu: Displays the CPU usage.
disk: Displays the disk space usage.
memory: Displays the memory space usage.
slot slot-number: Specifies a card. If you do not specify this option, the command displays the usage on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the command displays the usage on all cards in the IRF fabric. (In IRF mode.)
# Display the CPU, disk space, and memory usage of all MDCs on all cards in standalone mode.
<Sysname> display mdc resource
Memory:
Slot 0:
 Used 149.4MB, Free 3260.9MB, Total 3410.3MB:
    ID    Name             Quota(MB)    Used(MB)    Available(MB)
    1     Admin            3410.3       149.4        3260.9
    2     sub1             3410.3       0.0          3260.9
Slot 7:
 Used 69.3MB, Free 429.3MB, Total 498.6MB:
    1     Admin            498.6        69.3         429.3
CPU:
Slot 0:
    ID    Name             Weight       Usage(%)
    1     Admin            10           0
    2     sub1             10           0
Slot 7:
    1     Admin            10           0
Disk:
Slot 0:
cfa0:: Used 194.8MB, Free 802.3MB, Total 997.2MB:
    1     Admin            997.2        194.8        802.3
    2     sub1             997.2        0.0          802.3
flash:: Used 3.4MB, Free 124.6MB, Total 128.0MB:
    1     Admin            128.0        3.4          124.6
    2     sub1             128.0        0.0          124.6
# Display the CPU, disk space, and memory space usage of all MDCs on all cards in the IRF fabric in IRF mode.
<sub1> display mdc resource
Memory:
Chassis 1 Slot 0:
Chassis 1 Slot 7:
CPU:
Chassis 1 Slot 0:
    1     Admin            10           0
    2     sub1             10           0
Chassis 1 Slot 7:
    1     Admin            10           0
Disk:
Chassis 1 Slot 0:
Memory
Memory usage.
CPU
CPU usage.
Disk
Disk space usage.
Slot 0
Usage on a card. (In standalone mode.)
Chassis 1 Slot 0
Usage on a card of an IRF member device. (In IRF mode.)
Weight
CPU weight.
Quota (MB)
Maximum amount of memory or disk space for the MDC, in MB.
Available(MB)
Available amount of memory or disk space for the MDC, in MB.
limit-resource cpu
Use limit-resource cpu to specify a CPU weight for an MDC.
Use undo limit-resource cpu to restore the default.
limit-resource cpu weight weight-value
The default MDC has a CPU weight of 10 (unchangeable) on each MPU and each interface card, and each non-default MDC has a CPU weight of 10 on each MPU and each interface card that it is authorized to use.
MDC view
weight weight-value: Specifies a CPU weight value in the range of 1 to 10.
The amount of CPU resources an MDC can use depends on the CPU weight settings for all MDCs that share the same CPU. For example, if three MDCs share the same CPU and their weights are 10, 10, and 5, the two MDCs with the same weight can use the CPU for approximately the same period of time, and the MDC with a weight of 5 can use the CPU for about half of the time for each of the other two MDCs. Specifying the following weights for the MDCs has the same effect: 2, 2, and 1.
After you specify a CPU weight for an MDC, the MDC can use the same percentage of CPU resources on the MPUs and the interface cards assigned to it. To enable an MDC to use the CPU on an interface card, use the location command to authorize the MDC to use the interface card first.
# Set the CPU weight of MDC sub1 to 2.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] limit-resource cpu weight 2
limit-resource disk
Use limit-resource disk to specify a disk space percentage for an MDC.
Use undo limit-resource disk to restore the default.
In standalone mode:
limit-resource disk slot slot-number ratio limit-ratio
undo limit-resource disk slot slot-number
In IRF mode:
limit-resource disk chassis chassis-number slot slot-number ratio limit-ratio
undo limit-resource disk chassis chassis-number slot slot-number
All MDCs share the disk space in the system, and an MDC can use all free disk space in the system.
MDC view
slot slot-number: Specifies an MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU on an IRF member device. (In IRF mode.)
ratio limit-ratio: Specifies the ratio of the disk space an MDC can use on the specified card to the total disk space of the card, in the range of 1 to 100.
An MDC can apply for and use more space only when the space it is using is less than the space indicated by its disk space percentage.
The amount of space indicated by the percentage for an MDC must be greater than the least space the MDC requires for operation. If the amount of space indicated by the percentage for an MDC is less than the least space required, the MDC does not release the extra part it has occupied, but no more folders or files can be created or saved for the MDC.
Different MDCs might have different basic space requirements. Before you specify a disk space percentage for an MDC, use the display mdc resource command to view how much space the MDC is using. If the MDC administrators have not accessed the MDC, you can assume that the amount of space used by the MDC is the basic space requirement of the MDC.
# Allow MDC sub1 to use up to 30 percent of the disk space on the MPU in slot 1. (In standalone mode.)
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] limit-resource disk slot 1 ratio 30
# Allow MDC sub1 to use up to 30 percent of the disk space on the MPU in slot 1 on IRF member device 2. (In IRF mode.)
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] limit-resource disk chassis 2 slot 1 ratio 30
limit-resource memory
Use  limit-resource memory to specify a memory space percentage for an MDC.
Use undo limit-resource memory to restore the default.
In standalone mode:
limit-resource memory slot slot-number ratio limit-ratio
undo limit-resource memory slot slot-number
In IRF mode:
limit-resource memory chassis chassis-number slot slot-number ratio limit-ratio
undo limit-resource memory chassis chassis-number slot slot-number
All MDCs share the memory space in the system, and an MDC can use all free memory space in the system.
MDC view
slot slot-number: Specifies a card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. (In IRF mode.)
ratio limit-ratio: Specifies the ratio of the memory space that an MDC can use on the specified card to the total memory space of the card, in the range of 1 to 100.
This command sets the maximum amount of memory space that an MDC can use. Make sure this amount is greater than the minimum amount of memory space that an MDC needs to start.
# Allow MDC sub1 to use up to 30 percent of the memory space on the card in slot 1. (In standalone mode.)
[Sysname] mdc sub1
[Sysname-MDC-2-sub1] limit-resource memory slot 1 ratio 30
# Allow MDC sub1 to use up to 30 percent of the memory space on the card in slot 1 on IRF member device 2. (In IRF mode.)
[Sysname] mdc sub1
[Sysname-MDC-2-sub1] limit-resource memory chassis 2 slot 1 ratio 30
location
Use location to authorize an MDC to use an interface card.
Use undo location to cancel the authorization.
In standalone mode:
location slot slot-number
undo location slot slot-number
In IRF mode:
location chassis chassis-number slot slot-number
undo location chassis chassis-number slot slot-number
All interface cards of the device belong to the default MDC, and a non-default MDC can use no interface cards.
MDC view
slot slot-number: Specifies an interface card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an interface card on an IRF member device. (In IRF mode.)
To assign physical interfaces to an MDC, you must authorize the MDC to use the interface cards that the physical interfaces belong to.
You can enter different MDC views to authorize multiple MDCs to use the same interface card.
# Authorize MDC sub1 to use the interface card in slot 3. (In standalone mode.)
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] location slot 3
# Authorize MDC sub1 to use the interface card in slot 3 on IRF member device 2. (In IRF mode.)
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] location chassis 2 slot 3
switchto mdc
Use switchto mdc to log in to a non-default MDC from the system view of the default MDC and enter MDC system view.
switchto mdc mdc-name
mdc-name: Specifies the MDC name, a case-insensitive string of 1 to 15 characters. The MDC must have been started.
You use this command to log in to only an MDC that is in active state.
# Log in to MDC sub1 from the system view of the default MDC.
[Sysname] switchto mdc sub1
* Copyright (c) 2004-2012 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
* no decompiling or reverse-engineering shall be allowed.                    *
<Sysname>
ID         Name            Status
2          sub1            active
switchback
mdc
Use mdc to create an MDC and enter MDC view. If the MDC already exists, you enter the MDC view directly.
Use undo mdc to delete an MDC.
mdc mdc-name [ id mdc-id ]
undo mdc mdc-name
There is a default MDC with the name Admin and the ID 1.
mdc-name: Specifies the MDC name, a case-sensitive string of 1 to 15 characters.
id mdc-id: Specifies an MDC ID in the range of 1 to 4. If you do not specify this option, the system assigns the lowest ID number among the available ones to the MDC.
·           The default MDC is system predefined. You do not need to create it, nor can you delete it.
·           The device supports creating up to three MDCs.
·           Only an MPU with 4G memory space supports creating MDCs.
·           To enter the view of an existing MDC, you can specify the MDC name, or specify both the MDC name and the MDC ID. If you specify both the MDC name and the MDC ID, make sure the two arguments identify the same MDC.
·           Delete an MDC with caution. Deleting an MDC removes all configurations and harddisk files of the MDC, and the configurations and files cannot be restored.
·           This command is mutually exclusive with the irf mode enhanced command. For more information about IRF, see IRF Configuration Guide.
# Create an MDC named sub1.
[Sysname] mdc sub1
It will take some time to create MDC...
This MDC was created successfully.
display mdc
mdc start
Use mdc start to start an MDC.
Use undo mdc start to stop an MDC.
mdc start
undo mdc start
MDC view
After an MDC is started, administrators of the MDC can log in to the MDC for MDC configuration and maintenance.
Stop an MDC with caution. Stopping an MDC interrupts all services on the MDC and logs out all users of the MDC.
To avoid configuration loss, save the running configuration of an MDC before stopping the MDC.
# Start MDC sub1.
[Sysname] mdc sub1
[Sysname-mdc-2-sub1] mdc start
It will take some time to start MDC...
This MDC was started successfully.
MDC commands for non-default MDCs
This section describes the MDC commands an administrator can use after logging in to a non-default MDC.
display mdc
Use display mdc to display the ID, name, and status of the current MDC.
display mdc
# Display the ID, name, and status of the current MDC.
<sub1> display mdc
ID      Name         Status
2       sub1         active
Status
MDC status:
·       active—The MDC is operating properly.
Use display mdc interface to display the interfaces of the current MDC.
# Display the interfaces of the current MDC.
<sub1> display mdc interface
  M-Ethernet0/0/0                      GigabitEthernet7/0/1
  GigabitEthernet7/0/2                 GigabitEthernet7/0/3
  GigabitEthernet7/0/4                 GigabitEthernet7/0/5
  GigabitEthernet7/0/6                 GigabitEthernet7/0/7
  GigabitEthernet7/0/8                 GigabitEthernet7/0/9
  GigabitEthernet7/0/10                GigabitEthernet7/0/11
  GigabitEthernet7/0/12                GigabitEthernet7/0/13
  GigabitEthernet7/0/14                GigabitEthernet7/0/15
  GigabitEthernet7/0/16                GigabitEthernet7/0/17
  GigabitEthernet7/0/18                GigabitEthernet7/0/19
  GigabitEthernet7/0/20                GigabitEthernet7/0/21
  GigabitEthernet7/0/22                GigabitEthernet7/0/23
  GigabitEthernet7/0/24                GigabitEthernet7/0/25
  GigabitEthernet7/0/26                GigabitEthernet7/0/27
  GigabitEthernet7/0/28                GigabitEthernet7/0/29
  GigabitEthernet7/0/30                GigabitEthernet7/0/31
  GigabitEthernet7/0/32                GigabitEthernet7/0/33
  GigabitEthernet7/0/34                GigabitEthernet7/0/35
  GigabitEthernet7/0/36                GigabitEthernet7/0/37
  GigabitEthernet7/0/38                GigabitEthernet7/0/39
  GigabitEthernet7/0/40                GigabitEthernet7/0/41
  GigabitEthernet7/0/42                GigabitEthernet7/0/43
  GigabitEthernet7/0/44                GigabitEthernet7/0/45
  GigabitEthernet7/0/46                GigabitEthernet7/0/47
Use display mdc resource to display the CPU, disk space, and memory usage of the current MDC.
In standalone mode:
display mdc resource [ cpu | disk | memory ] [ slot slot-number ]
In IRF mode:
display mdc resource [ cpu | disk | memory ] [ chassis chassis-number slot slot-number ]
# Display the CPU, disk space, and memory space usage of the MDC on all cards in standalone mode.
Memory:
Slot 0:
 Used 184.4MB, Free 3225.9MB, Total 3410.3MB:
    2     sub1             3410.3       35.0         3225.9
CPU:
Slot 0:
    2     sub1             2            0
Disk:
Slot 0:
cfa0:: Used 194.9MB, Free 802.2MB, Total 997.2MB:
    2     sub1             997.2        0.0          802.2
# Display the CPU, disk space, and memory space usage of the MDC on all cards in the IRF fabric in IRF mode.
Memory:
Chassis 1 Slot 0:
CPU:
Chassis 1 Slot 0:
    2     sub1             2            0
Disk:
Chassis 1 Slot 0:
Memory
Memory usage.
CPU
CPU usage.
Disk
Disk space usage.
Slot 0
Chassis 1 Slot 0
Weight
CPU weight.
Quota(MB)
Maximum amount of memory or disk space for the MDC. in MB.
Available(MB)
switchback
Use switchback to return from a non-default MDC to the default MDC. This command will bring you from the user view of the non-default MDC to the system view of the default MDC.
switchback
You can use the switchback command to return to the default MDC only after you use the switchto command to log in to a non-default MDC. A user who logs in to a non-default MDC by using any other method (such as Telnet) cannot use the switchback command to access the default MDC.
# Return from the current MDC to the default MDC.
<sub1> switchback
[Sysname]
switchto mdc
