01-Fundamentals Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71001-Fundamentals Command Reference
04-FTP and TFTP commands
04-FTP and TFTP commands 209.01 KB
FTP commands
FTP server commands
display ftp-server
Use display ftp-server to display FTP server configuration and status information.
display ftp-server
# Display FTP server configuration and status information.
<Sysname> display ftp-server
 FTP server is running.
 Max user number:                 5
 User count:                      1
 Idle-timeout timer (in minutes): 30
Max user number
Maximum number of concurrent logged-in users.
User count
Number of the current logged-in users.
If no packet is exchanged between the FTP server and client during this period, the FTP connection is broken.
·           ftp server enable
·           ftp timeout
display ftp-user
Use display ftp-user to display detailed information about logged-in FTP users.
display ftp-user
# Display detailed information about logged-in FTP users.
<Sysname> display ftp-user
UserName     HostIP             Port     HomeDir
user2        2000:2000:2000:    1499     flash:/user2
             2000:2000:2000:
                  2000:2000
administra   100.100.100.100    10001    flash:/123456789/123456789/12345678
       tor                               9/123456789/123456789/123456789/123
                                                            456789/123456789
UserName
Name of the user.
HostIP
IP address of the user.
Port
Port number of the user.
HomeDir
Authorized directory for the user.
free ftp user
Use free ftp user to manually release the FTP connection that was established by using a specific user account.
free ftp user username
username: Specifies a username. You can use the display ftp-user command to display FTP user information.
# Manually release the FTP connection that was established by using the user account named ftpuser.
<Sysname> free ftp user ftpuser
Are you sure to free FTP connection? [Y/N]:y
<Sysname>
free ftp user-ip
Use free ftp user-ip to manually release the FTP connection that was established from a specific IPv4 address.
free ftp user-ip ipv4-address [ port port ]
ipv4-address: Specifies the source IP address of an FTP connection to be released. You can use the display ftp-user command to view the source IP address of the FTP connection.
port port: Specifies the source port of an FTP connection to be released. You can use the display ftp-user command to view the source port of the FTP connection.
# Manually release the FTP connection that was established from IP address 192.168.20.184.
<Sysname> free ftp user-ip 192.168.20.184
<Sysname>
free ftp user-ip ipv6
Use free ftp user-ip ipv6 to manually release the FTP connection that was established from a specific IPv6 address.
free ftp user-ip ipv6 ipv6-address [ port port ]
ipv6-address: Specifies the source IPv6 address of an FTP connection to be released. You can use the display ftp-user command to view the source IPv6 address of the FTP connection.
# Manually release the FTP connection that was established from IPv6 address 2000::154.
<Sysname> free ftp user-ip ipv6 2000::154
<Sysname>
ftp server acl
Use ftp server acl to use an ACL to control FTP clients' access to the FTP server.
Use undo ftp server acl to restore the default.
ftp server acl { acl-number | ipv6 acl-number6 }
undo ftp server acl [ ipv6 ]
No ACL is used to control FTP clients' access to the FTP server.
acl-number: Specifies an IPv4 ACL number in the range of 2000 to 3999.
ipv6 acl-number6: Specifies an IPv6 ACL number in the range of 2000 to 3999.
You can use this command to permit only FTP requests from specific FTP clients. This configuration takes effect only for FTP connections to be established. It does not impact existing FTP connections. If you execute the command multiple times, the last specified ACL takes effect.
# Use ACL 2001 to allow only client 1.1.1.1 to access the FTP server.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule 0 permit source 1.1.1.1 0
[Sysname-acl-basic-2001] rule 1 deny source any
[Sysname-acl-basic-2001] quit
[Sysname] ftp server acl 2001
ftp server enable
Use ftp server enable to enable the FTP server.
Use undo ftp server enable to disable the FTP server.
ftp server enable
The FTP server is disabled.
# Enable the FTP server.
[Sysname] ftp server enable
ftp timeout
Use ftp timeout to set the idle-timeout interval for FTP connections.
Use undo ftp timeout to restore the default.
ftp timeout minute
undo ftp timeout
The FTP idle-timeout interval is 30 minutes.
Minute: Specifies an idle-timeout interval in the range of 1 to 35791 minutes.
If no packet is exchanged on an FTP connection within the idle-timeout interval, the FTP server breaks the FTP connection to release resources.
# Set the idle-timeout interval to 36 minutes.
[Sysname] ftp timeout 36
FTP client commands
Before executing FTP client configuration commands, make sure you have configured authorization settings for users on the FTP server. Authorized operations include view the files under the working directory, read/download specified files, create directories, upload files, and rename/remove files.
The FTP client commands in this section are supported by the device, but whether they can be executed successfully depends on the FTP server.
append
Use append to add the content of a file on the FTP client to a file on the FTP server.
append localfile [ remotefile ]
FTP client view
localfile: Specifies a local file on the FTP client.
remotefile: Specifies a remote file on the FTP server.
You can perform this operation only after you log in to the FTP server.
# Append the content of the local a.txt file to the b.txt file on the FTP server.
ftp> append a.txt b.txt
227 Entering Passive Mode (192,168,3,51,7,40)
150 "D:\test\a.txt" file ready to receive in ASCII mode
226 Transfer finished successfully.
2749 bytes sent in 0.000239 seconds (10.97 Mbyte/s)
ascii
Use ascii to set the file transfer mode to ASCII.
ascii
The file transfer mode is ASCII.
FTP client view
The carriage return characters vary with operating systems. For example, H3C and Windows use /r/n, and Linux uses /n. To transfer files between two systems that use different carriage return characters, select the FTP transfer mode according to the file type.
FTP transfers files in either of the following modes:
·           Binary modeTransfers image files or pictures.
·           ASCII modeTransfers text files.
# Set the file transfer mode to ASCII.
ftp> ascii
200 Type is ASCII
binary
binary
Use binary to set the file transfer mode to binary, which is also called the "flow mode".
binary
FTP client view
The carriage return characters vary with operating systems. For example, H3C and Windows use /r/n, and Linux uses /n. To transfer files between two systems that use different carriage return characters, determine FTP transfer mode according to the file type.
FTP transfers files in the following modes:
·           Binary modeTransfers program file or pictures.
# Set the file transfer mode to binary.
ftp> binary
200 Type is Image (Binary)
ascii
bye
Use bye to terminate the connection to the FTP server and return to user view.
If no connection is established between the device and the remote FTP server, use this command to return to user view.
bye
FTP client view
# Terminate the connection to the FTP server and return to user view.
ftp> bye
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye
<Sysname>
cd
Use cd to change the current working directory to another directory on the FTP server.
cd { directory | .. | / }
FTP client view
directory: Specifies the name of the target directory in the format [drive:][/]path, where drive represents the storage medium name, typically flash or cf. If the target directory does not exist, the cd command does not change the current working directory. If no drive information is provided, the argument represents a folder or subfolder in the current directory. For more information about the drive and path arguments, see Fundamentals Configuration Guide.
..: Returns to the upper directory. Executing the cd .. command is the same as executing the cdup command. If the current working directory is the FTP root directory, the cd .. command does not change the current working directory.
/: Returns to the FTP root directory.
The directory that can be accessed must be authorized by the FTP server.
# Change the working directory to the subdirectory logfile of the current directory.
ftp> cd logfile
250 "D:\test\logfile " is current directory
# Change the working directory to the subdirectory folder of the FTP root directory.
ftp> cd /folder
250 "D:\folder" is current directory
# Change the working directory to the upper directory of the current directory.
ftp> cd ..
250 "D:\test" is current directory
# Change the working directory to the FTP root directory.
ftp> cd /
250 "D:\" is current directory
·           cdup
·           pwd
cdup
Use cdup to enter the upper directory of the FTP server.
This command does not change the working directory if the current directory is the FTP root directory.
cdup
FTP client view
# Change the working directory to the upper directory.
ftp> pwd
257 "D:\test" is current directory
ftp> cdup
ftp> pwd
257 "D:\" is current directory
·           cd
·           pwd
close
Use close to terminate the connection to the FTP server without exiting FTP client view.
close
FTP client view
# Terminate the connection to the FTP server without exiting the FTP client view.
ftp> close
ftp>
disconnect
debug
Use debug to enable or disable FTP client debugging.
debug
FTP client debugging is disabled.
FTP client view
When FTP client debugging is enabled, executing this command disables FTP client debugging.
When FTP client debugging is disabled, executing this command enables FTP client debugging.
# Enable and then disable FTP client debugging.
ftp> debug
Debugging on (debug=1).
ftp> debug
Debugging off (debug=0).
# When the device serves as the FTP client, enable FTP client debugging and download file a.txt from the current directory of the FTP server.
ftp> debug
ftp> get a.txt
---> PASV
227 Entering Passive Mode (192,168,3,51,7,145)
---> RETR a.txt
150 "D:\test\a.txt" file ready to send (83916 bytes) in ASCII mode
83916 bytes received in 0.228 seconds (359.4 kbyte/s)
---> PASV
FTP command.
Received the FTP reply code 227 and entering passive mode.
---> RETR a.txt
FTP command for downloading file a.txt.
delete
Use delete to permanently delete a file on the FTP server.
delete remotefile
FTP client view
remotefile: Specifies the name of a file on the FTP server.
To perform this operation, you must have delete permission on the FTP server.
# Delete file b.txt.
ftp> delete b.txt
250 File deleted from remote host.
dir
Use dir to display detailed information about the files and subdirectories under the current directory on the FTP server.
Use dir remotefile to display detailed information about a specific file or directory on the FTP server.
Use dir remotefile localfile to save detailed information about a specific file or directory on the FTP server to a local file.
dir [ remotefile [ localfile ] ]
FTP client view
remotefile: Specifies the name of a file or directory on the FTP server.
localfile: Specifies the name of the local file used for saving the displayed information.
In FTP client view, executing the dir command is the same as executing the ls command.
# Display detailed information about the files and subdirectories under the current directory on the FTP server.
ftp> dir
150 File Listing Follows in ASCII mode
drwxrwxrwx   1 noone    nogroup        0 Jun 11 16:18 .
drwxrwxrwx   1 noone    nogroup        0 Jun 11 16:18 ..
-rwxrwxrwx   1 noone    nogroup   439291 Jan 12 14:50 a.txt
-rwxrwxrwx   1 noone    nogroup        0 Oct 14  2011 bintest.txt
-rwxrwxrwx   1 noone    nogroup   439291 Jan 12 14:50 diatest.txt
# Save detailed information about file a.txt to s.txt.
ftp> dir a.txt s.txt
output to local-file: s.txt ? [Y/N]:y
# Display the content of file s.txt.
ftp> bye
<Sysname> more s.txt
-rwxrwxrwx   1 noone    nogroup   439291 Jan 12 14:50 s.txt
ls
disconnect
Use disconnect to terminate the connection to the FTP server without exiting FTP client view.
disconnect
FTP client view
ftp> disconnect
ftp>
close
display ftp client source
Use display ftp client source to display the source address settings on the FTP client.
# Display the source address settings on the FTP client.
<Sysname> display ftp client source
The source IP address of the FTP client is 1.1.1.1.
The source IPv6 address of the FTP client is 2001::1.
ftp
Use ftp to log in to the FTP server and enter FTP client view.
ftp [ server-address [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip source-ip-address } ] ]
server-address: Specifies the IP address or host name (a string of 1 to 20 characters) of the FTP server.
service-port: Specifies the TCP port number of the FTP server, in the range of 0 to 65535. The default value is 21.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the FTP server belongs to. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the FTP server is on the public network, do not specify this option.
source { interface interface-type interface-number | ip source-ip-address }: Specifies the source address used to establish the FTP connection.
·           interface interface-type interface-number: Specifies the source interface by its type and number. The primary IP address of this interface is the source address for sent FTP packets. If no primary IP address is configured on the source interface, the connection cannot be established.
·           ip source-ip-address: Specifies the source IP address for sent FTP packets. This source address must be an address that has been configured on the device.
This command is only applicable to IPv4 networks.
If no parameters are specified, this command enters the FTP client view without logging in to the FTP server.
If the server parameters are specified, you are prompted to enter the username and password for logging in to the FTP server.
# Log in to the FTP server 192.168.0.211, and specify the source IP address of sent FTP packets as 192.168.0.212.
<Sysname>ftp 192.168.0.211 source ip 192.168.0.212
Connected to 192.168.3.51 (192.168.3.51).
User (192.168.3.51:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
ftp client source
Use ftp client source to specify the source IPv4 address for FTP packets sent by the FTP client.
Use undo ftp client source to restore the default.
No source IP address is configured for sent FTP packets. The device uses the primary IP address of the output interface of the route to the server as the source IP address.
interface interface-type interface-number: Specifies the source interface for establishing FTP connections. The primary IP address of the source interface is used as the source IP address of packets sent to a FTP server. Make sure the interface is up and has the primary IP address configured. Otherwise, the transmission fails.
ip source-ip-address: Specifies the source IP address of sent FTP packets. The source address must be an IP address that has been configured on the device, and its interface must be up. Otherwise, the transmission fails.
Usages guidelines
The source address specified with the ftp command takes precedence over the one specified with the ftp client source command.
The source IP address specified with the ftp client source command applies to all FTP connections while the one specified with the ftp command applies only to the current FTP connection.
# Specify the source IP address for sent FTP packets as 192.168.20.222.
[Sysname] ftp client source ip 192.168.20.222
ftp
ftp client ipv6 source
Use ftp client ipv6 source to specify the source address for FTP packets sent by the IPv6 FTP client.
Use undo ftp client ipv6 source to restore the default.
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
No source address is configured. The device automatically selects a source IPv6 address as defined in RFC 3484.
interface interface-type interface-number: Specifies the source interface by its type and number. The IPv6 address configured on the source interface is the source address of sent FTP packets. Make sure the interface is up. Otherwise, the transmission fails.
ip source-ip-address: Specifies the source IPv6 address for sent FTP packets. The source address must be an IPv6 address that has been configured on the device, and its interface must be up. Otherwise, the transmission fails.
Usages guidelines
The source IPv6 address specified with the ftp ipv6 command takes precedence over the one specified with the ftp client ipv6 source command.
The source IPv6 address specified with the ftp client ipv6 source command applies to all FTP connections while the one specified with the ftp ipv6 command applies only to the current FTP connection.
# Specify source IPv6 address 2000::1 for sent FTP packets.
<Sysname> system–view
[Sysname] ftp client ipv6 source ipv6 2000::1
ftp ipv6
ftp ipv6
Use ftp ipv6 to log in to the FTP server and enter FTP client view.
ftp ipv6 [ server-address [ service-port ] [ vpn-instance vpn-instance-name ] [ source { ipv6 source-ipv6-address | interface interface-type interface-number } ] [ -i interface-type interface-number ] ]
server-address: Specifies the IP address or host name of the FTP server.
source ipv6 source-ipv6-address: Specifies the source IPv6 address for sent FTP packets. This address must be an IPv6 address that has been configured on the device.
source interface interface-type interface-number: Specifies a source interface by its type and number. This parameter can be used only when the FTP server address is a link local address and the specified output interface has a link local address. For more information about link local addresses, see Layer 3—IP Services Configuration Guide.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the FTP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the FTP server is on the public network, do not specify this option.
-i interface-type interface-number: Specifies an output interface by its type and number. This parameter can be used only when the FTP server address is a link local address and the specified output interface has a link local address.
This command is only applicable to IPv6 networks.
If no parameters are specified, this command enters the FTP client view.
If the FTP server parameters are specified, you are prompted to enter the username and password for logging in to the FTP server.
# Log in to the FTP server 2000::154.
<Sysname> ftp ipv6 2000::154
Connected to 2000::154 (2000::154)..
220 FTP service ready.
User (2000::154): root
331 Password required for root.
Password:
230 User logged in
Remote system type is H3C
get
Use get to download a file from the FTP server and save the file.
get remotefile [ localfile ]
FTP client view
remotefile: Specifies the name of the file to be downloaded.
localfile: Specifies a name for the downloaded file.
To save the downloaded file to the working directory accessed by the ftp command, the localfile argument must specify a file name such as a.cfg. If you do not provide the localfile argument, the downloaded file uses its original name.
To save the downloaded file to some other directory, the localfile argument must specify the target directory plus the file name such as flash:/subdirectory/a.cfg. Otherwise, the command fails to take effect.
# Download file a.txt and save it as b.txt in the working directory accessed by the ftp command.
ftp> get a.txt b.txt
227 Entering Passive Mode (192,168,3,51,6,249)
150 "D:\test\a.txt" file ready to send (1 bytes) in ASCII mode
1 bytes received in 0.0012 seconds (835 byte/s)
put
help
Use help to display all commands supported by an FTP client.
Use help command-name to display the help information of a specific command.
help [ command-name ]
FTP client view
command-name: Specifies a command supported by the FTP client.
In FTP client view, executing the help command is the same as entering?.
# Display all commands supported by the FTP client.
ftp> help
Commands may be abbreviated.  Commands are:
append           delete          ls              quit            rmdir
ascii            debug           mkdir           reget           status
binary           dir             newer           rstatus         system
bye              disconnect      open            rhelp           user
cd               get             passive         rename          verbose
cdup             help            put             reset           ?
close            lcd             pwd             restart
# Display the help information for the dir command.
ftp> help dir
dir              list contents of remote directory
lcd
Use lcd to display the local working directory of the FTP client.
Use lcd directory to change the local working directory of the FTP client to the specified directory.
Use lcd / to change the local working directory of the FTP client to the local root directory.
lcd [ directory | / ]
FTP client view
directory: Specifies a local directory of the FTP client. There must be a slash sign (/) before the name of the storage medium, for example, /flash:/logfile.
/: Specifies the root directory of the FTP client.
# Display the local working directory.
ftp> lcd
Local directory now /flash:
# Change the local working directory to flash:/logfile.
ftp> lcd /flash:/logfile
Local directory now /flash:/logfile
ls
Use ls to display detailed information about the files and subdirectories under the current directory on the FTP server.
Use ls remotefile to display detailed information about a specific file or directory on the FTP server.
Use ls remotefile localfile to save detailed information about a specific file or directory on the FTP server to a local file.
ls [ remotefile [ localfile ] ]
FTP client view
remotefile: Specifies the file name or directory on the FTP server.
localfile: Specifies the local file used to save the displayed information.
In FTP client view, executing the ls command is the same as executing the dir command.
ftp> ls
227 Entering Passive Mode (192,168,3,51,6,116)
ftp> ls a.txt s.txt
227 Entering Passive Mode (192,168,3,51,6,139)
ftp> bye
dir
mkdir
Use mkdir to create a subdirectory in the current directory on the FTP server.
mkdir directory
FTP client view
directory: Specifies the name of the directory to be created.
You must have permissions to perform this operation on the FTP server.
# Create subdirectory newdir in the current directory of the remote FTP server.
ftp> mkdir newdir
257 "newdir" directory created
newer
Use newer to update a local file by using a remote file on the FTP server.
newer remotefile [ localfile ]
FTP client view
remotefile: Specifies the name of the remote file on the FTP server.
localfile: Specifies the name of the local file to be updated.
If the local file does not exist, this command downloads the file from the FTP server and saves it locally.
If the remote file on the FTP server is not newer than the local file, this command does not update the local file.
# Update the local file with the file a.txt on the FTP server.
ftp> newer a.txt
500 Unidentified command MDTM a.txt
open
Use open to log in to the FTP server in FTP client view.
open server-address [ service-port ]
FTP client view
After you issue this command, you are prompted to enter the username and password. You must provide correct username and password before you can log in to the server.
If you have logged in to an FTP server, you cannot use the open command to log in to another server. To do so, you must first disconnect from the current server.
# In FTP client view, log in to the FTP server 192.168.3.51.
<Sysname> ftp
ftp> open 192.168.3.51
User (192.168.3.51:(none)): root
Password:
ftp>
passive
Use passive to set the FTP operation mode to passive.
passive
The FTP operation mode is passive.
FTP client view
FTP can operate in either of the following modes:
·           Active mode—The FTP server initiates the TCP connection.
·           Passive mode—The FTP client initiates the TCP connection.
You can use this command multiple times to change between active and passive modes.
This command is mainly used together with a firewall to control FTP session establishment between private network users and public network users.
# Set the FTP operation mode to passive.
ftp> passive
Passive mode on.
ftp> passive
Passive mode off.
put
Use put to upload a file on the client to the remote FTP server.
put localfile [ remotefile ]
FTP client view
localfile: Specifies the name of the local file to be uploaded.
remotefile: Specifies the file name for saving the uploaded file on the FTP server.
To upload a file in the working directory accessed by the ftp command, the localfile argument must specify a file name such as a.cfg.
To upload a file in some other directory, the localfile argument must specify the target directory plus the file name such as flash:/subdirectory/a.cfg. Otherwise, the command fails to take effect.
# Upload the file a.txt in the working directory accessed by the ftp command and save the file as b.txt on the FTP server.
ftp> put a.txt b.txt
227 Entering Passive Mode (192,168,3,51,7,100)
150 "D:\test\b.txt" file ready to receive in ASCII mode
2749 bytes sent in 0.000284 seconds (9.23 Mbyte/s)
get
pwd
Use pwd to display the currently accessed directory on the FTP server.
pwd
FTP client view
# Display the currently accessed directory on the remote FTP server.
ftp> pwd
Use quit to terminate the connection to the FTP server and return to user view.
FTP client view
ftp> quit
<Sysname>
bye
reget
Use reget to get the missing part of a file from the FTP server.
reget remotefile [ localfile ]
FTP client view
remotefile: Specifies the name of the file on the FTP server.
localfile: Specifies the name of the local file.
If a file download is not completed due to network problems or insufficient storage space, you can use the reget command to get the missing part of the file from the FTP server after you solve the problem.
# Get the part of the s.bin file that is missing due to transmission interruption.
ftp> reget s.bin
350 Restarting at 1749706
150-Connecting to port 47429
150 38143.3 kbytes to download
226 File successfully transferred
39058742 bytes received in 66.2 seconds (576.1 kbyte/s)
rename
Use rename to rename a file.
rename [ oldfilename [ newfilename ] ]
FTP client view
oldfilename: Specifies the original file name.
newfilename: Specifies the new file name.
# Rename the file a.txt as b.txt
Method 1:
ftp> rename
(from-name) a.txt
(to-name) b.txt
350 Enter the name to rename it to...
250 File renamed successfully
Method 2:
ftp> rename a.txt
(to-name) b.txt
Method 3:
ftp> rename a.txt b.txt
reset
Use reset to clear the reply information received from the FTP server in the buffer.
reset
FTP client view
# Clear the reply information received from the FTP server.
ftp> reset
restart
Use restart to specify the marker to retransmit a file.
restart marker
FTP client view
marker: Specifies the retransmit marker.
# Retransmit the file h.c (82 bytes) from 2 bytes.
ftp> restart 2
restarting at 2. execute get, put or append to initiate transfer
ftp> put h.c h.c
227 Entering Passive Mode (192,168,3,51,6,157)
150 "D:\test\h.c" file ready to receive in ASCII mode
61 bytes sent in 0.000139 seconds (428.6 kbyte/s)
ftp> dir
227 Entering Passive Mode (192,168,3,51,6,159)
drwxrwxrwx   1 noone    nogroup        0 Jun 11 17:04 .
drwxrwxrwx   1 noone    nogroup        0 Jun 11 17:04 ..
-rwxrwxrwx   1 noone    nogroup   439291 Jun 11 16:58 b1.txt
drwxrwxrwx   1 noone    nogroup        0 Jun 11 16:53 newdir
-rwxrwxrwx   1 noone    nogroup       61 Jun 11 17:04 s2.txt
rhelp
Use rhelp to display the FTP-related commands supported by the FTP server.
Use rhelp protocol-command to display the help information of an FTP-related command supported by the FTP server.
rhelp [ protocol-command ]
FTP client view
protocol-command: Specifies an FTP-related command.
# Display the FTP-related commands supported by the FTP.
ftp> rhelp
214-The following commands are recognized (* =>'s unimplemented).
   USER    PORT    STOR    MSAM*   RNTO    NLST    MKD     CDUP
   PASS    PASV    APPE    MRSQ*   ABOR    SITE*   XMKD    XCUP
   ACCT    TYPE    MLFL*   MRCP*   DELE    SYST    RMD     STOU
   SMNT*   STRU    MAIL*   ALLO*   CWD     STAT    XRMD    SIZE*
   REIN    MODE    MSND*   REST*   XCWD    HELP    PWD     MDTM*
   QUIT    RETR    MSOM*   RNFR    LIST    NOOP    XPWD
214 Direct comments about WFTPD to [email protected].
USER
Username, corresponding to the xx command in FTP client view.
PASS
Password.
NOOP
Null operation.
SYST
System parameters.
TYPE
Request type.
CWD
Changes the current working directory.
XCWD
Extended command with the meaning of CWD.
PWD
Prints the working directory.
CDUP
Changes the directory to the upper directory.
XCUP
Extended command with the meaning of CDUP.
XPWD
Extended command with the meaning of PWD.
LIST
Lists files.
NLST
Lists brief file description.
MLSD
Lists file content.
PORT
Active mode (IPv4).
EPRT
Active mode (IPv6).
PASV
Passive mode (IPv4).
EPSV
Passive mode (IPv6).
REST
Restarts.
RETR
Downloads files.
STOR
Uploads files.
APPE
Appends uploading.
DELE
Deletes files.
MKD
Creates folders.
XMKD
Extended command with the meaning of MKD.
RMD
Removes folders.
XRMD
Extended command with the meaning of RMD.
ABOR
Aborts the transmission.
SIZE
Size of the transmission file.
RNFR
Original name.
RNTO
New name.
rmdir
Use rmdir to permanently delete a directory on the FTP server.
rmdir directory
FTP client view
directory: Specifies the name of a directory on the remote FTP server.
To perform this operation, you must have delete permissions on the FTP server.
Delete all files and subdirectories under a directory before you delete the directory. For more information about how to delete files, see the delete command.
Executing the rmdir command also deletes the files in the recycle bin of the specified directory.
# Delete the empty directory subdir1.
ftp>rmdir subdir1
200 Directory subdir1 removed
delete
rstatus
Use rstatus to display FTP server status.
Use rstatus remotefile to display detailed information about a specific directory or file on the FTP server.
rstatus [ remotefile ]
FTP client view
remotefile: Specifies a directory or file on the FTP server.
# Display FTP server status.
ftp> rstatus
211- FTP server status:
WFTPD (by Texas Imperial Software) 32-bit version 2.03 12/3/1995
 Connected to 192.168.3.125
 Logged in as root
 TYPE: ASCII, FORM: Nonprint; STRUcture: File; transfer MODE: Stream
 Server type: WFTPD by Texas Imperial Software
211 End of status
# Display file a.txt.
ftp> rstatus a.txt
 Logged in as root
211 End of status
status
Use status to display FTP status.
status
FTP client view
# Display FTP status.
ftp> status
Connected to 192.168.3.51.
No proxy connection.
Not using any security mechanism.
Mode: stream; Type: ascii; Form: non-print; Structure: file
Verbose: on; Bell: off; Prompting: on; Globbing: off
Store unique: off; Receive unique: off
Case: off; CR stripping: on
Ntrans: off
Nmap: off
Hash mark printing: off; Use of PORT cmds: on
Table 5 Command output
IP address of the FTP server that is connected to the FTP client.
Displays debugging information.
The name of the file on the FTP server is unique and the name of the local file is unique.
Does not support obtaining multiple files once and deletes "\r" when downloading text files.
Ntrans: off
Does not use the input-output transmission table.
Nmap: off
The file name does not use the input-to-output mapping template.
Does not end with a pound sign (#) and uses "PORT" data transmission.
system
Use system to display the system information of the FTP server.
system
FTP client view
# Display the system information of the FTP server.
ftp> system
215 MSDOS A N (WFTPD by Texas Imperial Software)
user
Use user to switch to another user account after login.
user [ username [ password ] ]
FTP client view
username: Specifies the username of the target user account.
password: Specifies the password of the target user account.
The username and password of the target user account must have been configured. Otherwise, switch to the target user account fails and the FTP connection is closed.
# After logging in to the FTP server, use the username ftp and password 123456 to re-log in to the FTP server (the output might vary by the FTP server):
·           Method 1
ftp> user ftp 123456
·           Method 2
ftp> user ftp
Password:
·           Method 3:
ftp> user
(username) ftp
Password:
verbose
Use verbose to enable or disable the device to display FTP operation information.
verbose
The device displays FTP operation information.
FTP client view
# Disable and then enable the device to display FTP operation information.
ftp> verbose
Verbose mode off.
ftp> verbose
Verbose mode on.
# Execute the get command when FTP operation information display is disabled.
ftp> verbose
Verbose mode off.
ftp> get a.txt
# Execute the get command when FTP operation information display is enabled.
ftp> verbose
Verbose mode on.
ftp> get a.txt
Use ? to display all commands supported by an FTP client.
Use ? command-name to display the help information for a specific command.
? [ command-name ]
FTP client view
In FTP client view, entering ? is the same as executing the help command.
ftp> ?
ftp> ? dir
help
tftp
Use tftp to download a file from the TFTP server to the local device or upload a local file to the TFTP server in an IPv4 network.
tftp server-address { get | put } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip source-ip-address } ]
server-address: Specifies the IP address or host name of a TFTP server, a string of 1 to 20 characters.
get: Downloads a file.
put: Uploads a file.
source-filename: Specifies the source file name, a case-insensitive string of 1 to 1 to 255 characters.
destination-filename: Specifies the destination file name, a case-insensitive string of 1 to 255 characters. If this argument is not specified, the file uses the source file name.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN where the TFTP server belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the TFTP server is on the public network, do not specify this option.
source: Configures the source IP address for sent TFTP packets. If this keyword is not specified, the device uses the primary IP address of the output interface of the route to the server as the source IP address of sent TFTP packets.
·           interface interface-type interface-number: Specifies the source interface by its type and number. The primary IP address configured on the source interface is the source IP address of the TFTP packets. Make sure the interface is up and has the primary IP address configured. Otherwise, the transmission fails.
·           ip source-ip-address: Specifies the source IP address of sent TFTP packets. The source address must be an IP address that has been configured on the device, and its interface must be up.
Usages guidelines
The source address specified with the tftp command takes precedence over the one specified with the tftp client source command.
The source IP address specified with the tftp client source command applies to all TFTP connections while the one specified with the tftp command applies only to the current TFTP connection.
# Download the new.bin file from the TFTP server at 192.168.1.1 and save it as new.bin.
<Sysname> tftp 192.168.1.1 get new.bin
   % Total    % Received % Xferd  Average Speed   Time    Time     Time   Current
                                  Dload  Upload   Total   Spent    Left   Speed
100 13.9M  100 13.9M    0     0  1206k      0  0:00:11  0:00:11  --:--:-- 1206k
<System>
Table 6 Command output
Percentage of file transmission progress.
Total
Size of files to be transmitted, in bytes.
Percentage of received file size to total file size.
Received
Received file size, in bytes.
Percentage of sent file size to total file size.
Xferd
Sent file size, in bytes.
Average Dload
Average download speed, in bps.
Speed Upload
Average upload speed, in bps.
tftp client source
tftp client source
Use tftp client source to specify the source IP address for TFTP packets sent by the TFTP client.
Use undo tftp client source to restore the default.
No source IP address is configured for sent TFTP packets. The device uses the primary IP address of the output interface of the route to the server as the source IP address.
interface interface-type interface-number: Specifies the source interface for establishing TFTP connections. The primary IP address of the source interface is used as the source IP address of packets sent to a TFTP server. Make sure the interface is up and has the primary IP address configured. Otherwise, the transmission fails.
ip source-ip-address: Specifies the source IP address of sent TFTP packets. The source address must be an IP address that has been configured on the device, and its interface must be up. Otherwise, the transmission fails.
Usages guidelines
# Specify the source IP address of sent TFTP packets as 192.168.20.222.
[Sysname] tftp client source ip 192.168.20.222
tftp
tftp ipv6
Use tftp ipv6 to download a file from a TFTP server or upload a local file to a TFTP server in an IPv6 network.
tftp ipv6 tftp-ipv6-server [ -i interface-type interface-number ] { get | put } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ipv6 source-ipv6-address } ]
tftp-ipv6-server: Specifies the IPv6 address or host name of a TFTP server, a string of 1 to 46 characters.
-i interface-type interface-number: Specifies an output interface by its type and number. This parameter can be used only when the TFTP server address is a link local address and the specified output interface has a link local address. For link local address configuration, see Layer 3—IP Services Configuration Guide.
source-file: Specifies the source file name, a case-insensitive string of 1 to 255 characters.
destination-file: Specifies the destination file name, a case-insensitive string of 1 to 255 characters. If this argument is not specified, the file uses the source file name.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN where the TFTP server belongs to. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the TFTP server is on the public network, do not specify this option.
source: Specifies the source address of sent IPv6 TFTP packets. If this keyword is not specified, the device automatically selects a source IPv6 address. For more information, see RFC 3484.
·           interface interface-type interface-number: Specifies the source interface by its type and number. The IPv6 address configured on the source interface is the source address of sent TFTP packets. Make sure the interface is up. Otherwise, the transmission fails.
·           ip source-ip-address: Specifies the source IPv6 address of sent TFTP packets, The source address must be an IPv6 address that has been configured on the device, and its interface must be up.
Usages guidelines
The source IPv6 address specified with the tftp ipv6 command takes precedence over the one specified with the tftp client ipv6 source command.
The source IPv6 address specified with the tftp client ipv6 source command applies to all TFTP connections while the one specified with the tftp ipv6 command applies only to the current TFTP connection.
# Download the new.bin file from the TFTP server at 2001::1 and save it as new.bin.
<Sysname> tftp ipv6 2001::1 get new.bin new.bin
For more information about the command output, see Table 6.
Use tftp client ipv6 source to specify the source address for TFTP packets sent by the IPv6 TFTP client.
Use undo tftp client ipv6 source to restore the default.
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
ip source-ip-address: Specifies the source IPv6 address of sent TFTP packets. The source address must be an IPv6 address that has been configured on the device, and its interface must be up. Otherwise, the transmission fails.
Usages guidelines
# Specify source IPv6 address 2000::1 for sent TFTP packets.
[Sysname] tftp client ipv6 source ipv6 2000::1
tftp ipv6
tftp-server acl
Use tftp-server acl to use an ACL to control the device's access to TFTP servers in an IPv4 network.
Use undo tftp-server acl to restore the default.
tftp-server acl acl-number
No ACL is used to control the device's access to TFTP servers.
acl-number: Specifies the number of a basic ACL, in the range of 2000 to 2999.
Usages guidelines
You can use an ACL to deny or permit the device's access to specific TFTP servers.
# Allow the device to access only the TFTP server at 1.1.1.1.
<Sysname> System-view
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 1.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname] tftp-server acl 2000
tftp-server ipv6 acl
Use tftp-server ipv6 acl to use an ACL to control the device's access to TFTP servers in an IPv6 network.
Use undo tftp-server ipv6 acl to restore the default.
tftp-server ipv6 acl acl-number
Usages guidelines
# Allow the device to access only the TFTP server at 2001::1.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2001::1/128
[Sysname-acl6-basic-2001] quit
[Sysname] tftp-server ipv6 acl 2001
