01-Fundamentals Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71001-Fundamentals Command Reference
12-TCL commands
12-TCL commands 46.51 KB
Tcl commands
tclsh
Use tclsh to enter Tcl configuration view from user view.
tclsh
From user view, you can use the tclsh command to enter Tcl configuration view, where you can execute the following commands:
·           All Tcl 8.5 commands.
·           Comware commands. In this case, the Tcl configuration view is equivalent to the user view. You can use Comware commands in Tcl configuration view in the same way that you do in user view.
# Enter Tcl configuration view from user view.
<Sysname> tclsh
<Sysname-tcl>
tclquit
tclquit
Use tclquit to return from Tcl configuration view to user view.
tclquit
After you execute Comware commands to enter the system view or a Comware feature view, you can use the quit command to return to the upper-level view, or use the return command to directly return to the Tcl configuration view. You cannot use the tclquit command for these purposes.
Executing the quit command in Tcl configuration view terminates your connection to the device.
# Return from Tcl configuration view to user view.
<Sysname-tcl> tclquit
<Sysname>
tclsh
