01-ACL Commands | 288.72 KB |
display acl ipv6 { inbound | outbound }
display flow-template interface
display flow-template user-defined
packet-filter forwarding-layer route outbound
acl
acl number acl-number [ name acl-name ] [ match-order { auto | config } ]
undo acl { all | name acl-name | number acl-number }
View
Default level
2: System level
number acl-number: Specifies the number of an access control list (ACL):
· 2000 to 2999 for IPv4 basic ACLs
· 3000 to 3999 for IPv4 advanced ACLs
· 4000 to 4999 for Ethernet frame header ACLs
· 5000 to 5999 for user-defined ACLs
name acl-name: Assigns a name to the ACL for easy identification. The acl-name argument takes a case-insensitive string of 1 to 63 characters. It must start with an English letter, and to avoid confusion, cannot be all.
match-order: Sets the order in which ACL rules are compared against packets:
· auto—Compares ACL rules in depth-first order. The depth-first order differs with ACL categories. For more information, see ACL and QoS Configuration Guide.
· config—Compares ACL rules in ascending order of rule ID. The rule with a smaller ID has higher priority. If no match order is specified, the config order applies by default.
The match-order keyword is not available for user-defined ACLs. They always use the config order.
all: Deletes all IPv4 ACLs, including IPv4 basic, IPv4 advanced, Ethernet frame header, and user-defined ACLs.
Use the acl command to create an IPv4 basic, IPv4 advanced, Ethernet frame header, or user-defined ACL and enter its view. If the ACL has been created, you enter its view directly.
Use the undo acl command to delete the specified IPv4 ACL or all IPv4 ACLs (including IPv4 basic, IPv4 advanced, Ethernet frame header, and user-defined ACLs).
By default, no ACL exists.
You can assign a name to an IPv4 ACL only when you create it. After an ACL is created with a name, you cannot rename it or remove its name.
You can change match order only for ACLs that do not contain any rules.
To display any ACLs you have created, use the display acl command.
# Create IPv4 basic ACL 2000, and enter its view.
[Sysname] acl number 2000
[Sysname-acl-basic-2000]
# Create IPv4 basic ACL 2001 with the name flow, and enter its view.
[Sysname] acl number 2001 name flow
[Sysname-acl-basic-2001-flow]
acl copy
acl copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
View
Default level
2: System level
source-acl-number: Specifies a source IPv4 ACL that already exists by its number:
name source-acl-name: Specifies a source IPv4 ACL that already exists by its name. The source-acl-name argument takes a case-insensitive string of 1 to 63 characters.
dest-acl-number: Assigns a unique number to the IPv4 ACL you are creating. This number must be from the same ACL category as the source ACL. Available value ranges include:
name dest-acl-name: Assigns a unique name to the IPv4 ACL you are creating. The dest-acl-name takes a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, cannot be all. For this ACL, the system automatically picks the smallest number from all available numbers in the same ACL category as the source ACL.
Use the acl copy command to create an IPv4 ACL by copying an IPv4 ACL that already exists. The new ACL has the same properties and content as the source ACL, but not the same ACL number and name.
You can assign a name to an IPv4 ACL only when you create it. After an IPv4 ACL is created with a name, you cannot rename it or remove its name.
# Create IPv4 basic ACL 2002 by copying IPv4 basic ACL 2001.
[Sysname] acl copy 2001 to 2002
acl ipv6
acl ipv6 number acl6-number [ name acl6-name ] [ match-order { auto | config } ]
undo acl ipv6 { all | name acl6-name | number acl6-number }
View
Default level
2: System level
number acl6-number: Specifies the number of an IPv6 ACL:
· 2000 to 2999 for IPv6 basic ACLs
· 3000 to 3999 for IPv6 advanced ACLs
name acl6-name: Assigns a name to the IPv6 ACL for easy identification. The acl6-name argument takes a case-insensitive string of 1 to 63 characters. It must start with an English letter, and to avoid confusion, cannot be all.
all: Delete all IPv6 ACLs.
Use the acl ipv6 command to create an IPv6 ACL and enter its ACL view. If the ACL has been created, you enter its view directly.
Use the undo acl ipv6 command to delete the specified IPv6 ACL or all IPv6 ACLs.
You can assign a name to an IPv6 ACL only when you create it. After an IPv6 ACL is created, you cannot rename it or remove its name.
To display any ACLs you have created, use the display acl ipv6 command.
# Create IPv6 ACL 2000 and enter its view.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000]
# Create IPv6 basic ACL 2001 with the name flow, and enter its view.
[Sysname] acl ipv6 number 2001 name flow
[Sysname-acl6-basic-2001-flow]
acl ipv6 copy
acl ipv6 copy { source-acl6-number | name source-acl6-name } to { dest-acl6-number | name dest-acl6-name }
View
Default level
2: System level
source-acl6-number: Specifies a source IPv6 ACL that already exists by its number:
name source-acl6-name: Specifies a source IPv6 ACL that already exists by its name. The source-acl6-name argument takes a case-insensitive string of 1 to 63 characters.
dest-acl6-number: Assigns a unique number to the IPv6 ACL you are creating. This number must be from the same ACL category as the source ACL. Available value ranges include:
name dest-acl6-name: Assigns a unique name to the IPv6 ACL you are creating. The dest-acl6-name takes a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, cannot be all. For this ACL, the system automatically picks the smallest number from all available numbers in the same ACL category as the source ACL.
Use the acl ipv6 copy command to create an IPv6 ACL by copying an IPv6 ACL that already exists. The new ACL has the same properties and content as the source ACL, but not the same ACL number and name.
You can assign a name to an IPv6 ACL only when you create it. After an ACL is created with a name, you cannot rename it or remove its name.
# Create IPv6 basic ACL 2002 by copying IPv6 basic ACL 2001.
[Sysname] acl ipv6 copy 2001 to 2002
acl ipv6 enable
acl ipv6 enable
acl ipv6 disable
View
Default level
3: Manage level
None
Use the acl ipv6 enable command to enable 80-byte ACL rule match mode on an EC or EF card, for example, LSR1GP48LEC1 or LSR1GP48LEF1. This command sets the length limit for the match criteria in each ACL rule to 80 bytes. You must restart the switch to validate the command.
Use the acl ipv6 disable command to restore the default on an EC or EF card.
By default, the 40-byte ACL rule match mode applies to an EC or EF card. The length limit for the match criteria in each ACL rule is 40 bytes.
The acl ipv6 enable command is valid only for an EC or EF card. To support user-defined, IPv6 basic, and IPv6 advanced ACLs on an EC or EF card, you must configure the acl ipv6 enable command first. The other cards support user-defined and IPv6 ACLs by default.
To create an IRF fabric from two switches, make sure that they are using the same ACL rule match mode. For more information about IRF, see IRF Configuration Guide.
For more information about EC and EF cards, see Fundamentals Configuration Guide.
# Enable 80-byte ACL rule match mode.
[Sysname] acl ipv6 enable
acl ipv6 logging frequence
acl ipv6 logging frequence frequence
undo acl ipv6 logging frequence
View
Default level
2: System level
frequence: Specifies the interval in minutes at which IPv6 packet filtering logs are generated and output. It must be a multiple of 5, in the range of 0 to 1440. To disable generating IPv6 logs, assign 0 to the argument.
Use the acl ipv6 logging frequence command to set the interval for generating and outputting IPv6 packet filtering logs. The log information includes the number of matching IPv6 packets and the matching IPv6 ACL rules. This command logs only for IPv6 basic and advanced ACL rules that have the logging keyword.
Use the undo acl ipv6 logging frequence command to restore the default.
By default, the interval is 0. No IPv6 packet filtering logs are generated.
Related commands: packet-filter ipv6, rule (IPv6 advanced ACL view), and rule (IPv6 basic ACL view).
# Enable the device to generate and output IPv6 packet filtering logs at 10-minute intervals.
[Sysname] acl ipv6 logging frequence 10
acl ipv6 name
acl ipv6 name acl6-name
View
Default level
2: System level
acl6-name: Specifies the name of an existing IPv6 ACL, a case-insensitive string of 1 to 63 characters. It must start with an English letter.
Use the acl ipv6 name command to enter the view of an IPv6 ACL that has a name.
Related commands: acl ipv6.
# Enter the view of IPv6 ACL flow.
[Sysname] acl ipv6 name flow
acl logging frequence
acl logging frequence frequence
undo acl logging frequence
View
Default level
2: System level
frequence: Specifies the interval in minutes at which IPv4 packet filtering logs are generated and output. It must be a multiple of 5, in the range of 0 to 1440. To disable generating IPv4 logs, assign 0 to the argument.
Use the acl logging frequence command to set the interval for generating and outputting IPv4 packet filtering logs. The log information includes the number of matching IPv4 packets and the matching IPv4 ACL rules. This command logs only for IPv4 basic and advanced ACL rules that have the logging keyword.
Use the undo acl logging frequence command to restore the default.
By default, the interval is 0. No IPv4 packet filtering logs are generated.
Related commands: packet-filter, rule (IPv4 advanced ACL view), and rule (IPv4 basic ACL view).
# Enable the device to generate and output IPv4 packet filtering logs at 10-minute intervals.
[Sysname] acl logging frequence 10
acl name
acl name acl-name
View
Default level
2: System level
acl-name: Specifies the name of an existing IPv4 ACL, a case-insensitive string of 1 to 63 characters. It must start with an English letter.
Use the acl name command to enter the view of an IPv4 ACL that has a name.
Related commands: acl.
# Enter the view of IPv4 ACL flow.
[Sysname] acl name flow
[Sysname-acl-basic-2002-flow]
description
View
IPv4 basic/advanced ACL view, IPv6 basic/advanced ACL view, Ethernet frame header ACL view, user-defined ACL view
Default level
2: System level
text: ACL description, a case-sensitive string of 1 to 127 characters.
Use the description command to configure a description for an ACL.
Use the undo description command to remove the ACL description.
By default, an ACL has no ACL description.
Related commands: display acl and display acl ipv6.
# Configure a description for IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] description This is an IPv4 basic ACL.
# Configure a description for IPv6 basic ACL 2000.
[Sysname-acl6-basic-2000] description This is an IPv6 basic ACL.
display acl
Standalone mode:
display acl { acl-number | all | name acl-name } [ | { begin | exclude | include } regular-expression ]
IRF mode:
display acl { acl-number | all | name acl-name } [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl-number: Specifies an IPv4 ACL by its number:
· 2000 to 2999 for basic ACLs
· 3000 to 3999 for advanced ACLs
all: Displays information for all IPv4 ACLs.
name acl-name: Specifies an IPv4 ACL by its name. The acl-name argument takes a case-insensitive string of 1 to 63 characters. It must start with an English letter.
slot slot-number: Displays the match statistics for IPv4 ACLs on a card. The slot-number argument specifies a card by its slot number. Use this option when your switch is operating in standalone (the default) mode. If no slot is provided, the command displays configuration information about IPv4 ACLs on the device.
chassis chassis-number slot slot-number: Displays the match statistics for IPv4 ACLs on an IRF member device. The chassis-number argument represents the member ID of the device in the IRF fabric, and the slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode. For the IRF member ID of a switch, use the display device command. If no IRF member switch is specified, the command displays configuration information about all IPv4 ACLs on the IRF fabric.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display acl command to display configuration and match statistics for the specified or all IPv4 ACLs.
This command displays ACL rules in config or depth-first order, whichever is configured.
# Display the configuration and match statistics for all IPv4 ACLs.
<Sysname> display acl 2001
Basic ACL 2001, named –flow-, 2 rules,
Statistics is enabled
ACL's step is 5
rule 1 permit source 1.1.1.1 0 (5 times matched)
rule 2 permit source 1.1.1.2 0 (No statistics resource)
Table 1 Output description
Basic ACL 2001 |
Category and number of the ACL. The following field information is about IPv4 basic ACL 2001. |
named flow |
The name of the ACL is flow. "-none-" means the ACL is not named. |
2 rules |
The ACL contains two rules. |
Statistics is enabled |
The rule match counting is enabled for this ACL. |
ACL's step is 5 |
The rule numbering step is 5. |
5 times matched |
There have been five matches for the rule. The statistic counts only ACL matches in the packet filter. This field is not displayed when no packets have matched the rule. |
No statistics resource |
Resources are not enough for counting matches for the IPv4 rules. This information indicates that the switch failed to allocate resources for counting matches for the rule when you applied the packet-filter command to an interface. Even if resources have become available after that, the switch does not change the information or count matches for the rule. To count matches for the rule, you must delete and then add the rule. |
Uncompleted |
Applying the rule to hardware failed because no sufficient resources were available or the hardware does not support the rule. This event might occur when you modify a rule in an ACL that has been applied. |
display acl ipv6
Standalone mode:
display acl ipv6 { acl6-number | all | name acl6-name } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display acl ipv6 { acl6-number | all | name acl6-name } [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
acl6-number: Specifies an IPv6 ACL by its number:
all: Displays information for all IPv6 ACLs.
name acl6-name: Specifies an IPv6 ACL by its name. The acl6-name argument takes a case-insensitive string of 1 to 63 characters. It must start with an English letter.
slot slot-number: Displays the match statistics for IPv6 ACLs on a card. The slot-number argument represents the slot number of the card. Use this option when your switch is operating in standalone (the default) mode. If no slot number is provided, the command displays configuration information about all IPv6 ACLs on the device.
chassis chassis-number slot slot-number: Displays the match statistics for IPv6 ACLs on an IRF member device. The chassis-number argument represents the member ID of the device in an IRF fabric, and the slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in IRF mode. For the IRF member ID of a switch, use the display device command. If no IRF member device is specified, the command displays configuration information about all IPv6 ACLs on the device.
Use the display acl ipv6 command to display the configuration and match statistics for the specified IPv6 ACL or all IPv6 ACLs.
# Display the configuration and match statistics for IPv6 ACL 2001.
<Sysname> display acl ipv6 2001
Basic IPv6 ACL 2001, named flow, 1 rule,
ACL's step is 5
rule 0 permit source ::1/128 (No statistics resource)
Table 2 Output description
Basic IPv6 ACL 2001 |
Category and number of the ACL. The following field information is about this IPv6 basic ACL 2001. |
named flow |
1 rule |
The ACL contains one rule. |
ACL's step is 5 |
5 times matched |
There have been five matches for the rule. The statistic counts only IPv6 ACL matches in the packet filter. This field is not displayed when no packets have matched the rule. |
Resources are not enough for counting matches for the IPv6 ACL rules. This information shows that the switch failed to allocate resources for counting matches for the rule when you applied the packet-filter command to an interface. Even if resources have become available after that, the switch does not change the information or count matches for the rule. To count matches for the rule, you must delete and then add the rule. |
Uncompleted |
display acl ipv6 { inbound | outbound } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
inbound: Displays the status of the ACL rule match mode in the inbound direction, namely, the length limit for the match criteria in each ACL rule applied in the inbound direction.
outbound: Displays the status of the ACL rule match mode in the outbound direction, namely, the length limit for the match criteria in each ACL rule applied in the outbound direction.
Use the display acl ipv6 { inbound | outbound } command to display the status of the ACL rule match mode.
When the switch operates in standard mode, this command does not take effect.
Related command: acl ipv6 enable.
# Display the status of the ACL rule match mode in the inbound direction.
<Sysname> display acl ipv6 inbound
Current ACL IPv6 inbound mode : Disable
ACL IPv6 inbound mode after system restart: Enable
Notice: Changing ACL IPv6 mode will take effect only after system restart.
Table 3 Output description
Current ACL IPv6 inbound mode |
Status of the current ACL rule match mode in the inbound direction. Disable means that 40-byte ACL rule match mode is adopted. |
ACL IPv6 inbound mode after system restart |
Status of the ACL rule match mode in the inbound direction after system restart. Enable means that 80-byte ACL rule match mode is adopted. |
display acl resource
Standalone mode:
display acl resource [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display acl resource [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the usage of ACL rules on a card. The slot-number argument specifies the slot number of the card. If no slot number is specified, the usage of ACL rules on the main board is displayed. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Displays the usage of ACL resources of a card on an IRF member device. The chassis-number argument represents the member ID of the device in an IRF fabric, and the slot-number argument represents the number of the slot that holds the card. If no IRF member device is specified, the usage of ACL resources of all main boards in the IRF fabric is displayed. Use this option when your switch is operating in IRF mode. For more information about IRF, see IRF Configuration Guide.
Use the display acl resource command to display the usage of ACL rules.
If a card does not support counting for ACL rules, the command displays only the slot number of the card.
# Display the usage of ACL rules for slot 3 on a device.
<Sysname> display acl resource slot 3
Interface:
GE3/0/1 to GE3/0/24
Type Total Reserved Configured Remaining Usage
ACL rule 8192 96 3 8093 1%
Inbound ACL 8192 96 3 8093 1%
Outbound ACL 8192 0 0 8093 0%
Table 4 Output description
Name of the start and end interfaces on the card |
Type |
Resource type. |
Total |
Total number of ACL rules supported |
Reserved |
Number of reserved ACL rules |
Configured |
Number of ACL rules that have been applied |
Remaining |
Number of ACL rules that you can apply |
Usage |
The percentage of the reserved and configured ACL rules in the total number of ACL rules |
display flow-template interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Specifies an interface by its type and number. If no interface is specified, information about all user-defined flow templates applied to interfaces is displayed.
Use the display flow-template interface command to display information about user-defined flow templates applied to interfaces.
This command is supported only on POS subcards.
# Display information about all user-defined flow templates applied to interfaces.
<Sysname> display flow-template interface
Interface: Pos3/1/1
user-defined flow template: basic
name:aaa, index:1, total reference counts:1
fields: sip dip
Table 5 Output description
Interface where the user-defined flow template is referenced |
user-defined flow template |
Type of the user-defined flow template |
name |
Name of the user-defined flow template |
index |
Index of the user-defined flow template |
total reference counts |
Total number of times that the user-defined flow template has been referenced |
fields |
Fields included in the user-defined flow template |
display flow-template user-defined [ flow-template-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
flow-template-name: Name of a user-defined flow template, a case-insensitive string of 1 to 31 characters. If no user-defined flow template name is specified, information about all user-defined flow templates is displayed.
Use the display flow-template user-defined command to display information about user-defined flow templates.
# Display information about all user-defined flow templates.
<Sysname> display flow-template user-defined
name:f1, index:1, total reference counts:1
fields: ip-protocol fragments ip-precedence
name:f3, index:3, total reference counts:1
fields: tos
Table 6 Output description
name |
index |
Total number of times that the user-defined flow template has been referenced by switching chips |
fields |
display packet-filter
Standalone mode:
display packet-filter { { all | interface interface-type interface-number } [ inbound | outbound ] | interface vlan-interface vlan-interface-number [ inbound | outbound ] [ slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
IRF mode:
display packet-filter { { all | interface interface-type interface-number } [ inbound | outbound ] | interface vlan-interface vlan-interface-number [ inbound | outbound ] [ chassis chassis-number slot slot-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. VLAN interfaces are not supported.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
interface vlan-interface vlan-interface-number: Specifies a VLAN interface by its number.
slot slot-number: Specifies a card by its slot number. If no slot number is specified, the command displays application information of ACLs for packet filtering on VLAN interfaces of the device. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the device in an IRF fabric, which you can display with the display device command. The slot-number argument represents the number of the slot that holds the card. If no IRF member device is specified, the command displays application information of ACLs for packet filtering on VLAN interfaces of the IRF fabric. Use this option when your switch is operating in IRF mode.
Use the display packet-filter command to display whether an ACL has been successfully applied to an interface for packet filtering.
If you specify neither the inbound keyword nor the outbound keyword, the command displays the application status of both incoming and outgoing packet filtering ACLs.
# Display the application status of inbound and outbound packet filtering ACLs for interface GigabitEthernet 3/0/1.
<Sysname> display packet-filter interface GigabitEthernet 3/0/1
Interface: GigabitEthernet 3/0/1
In-bound Policy:
acl 2001, Successful
Out-bound Policy:
acl6 2500, Fail
Table 7 Output description
Interface to which the ACL applies |
In-bound Policy |
The ACL used for filtering incoming traffic on the interface |
Out-bound Policy |
The ACL used for filtering outgoing traffic on the interface |
acl 2001, Successful |
IPv4 ACL 2001 has been applied to the interface |
acl6 2500, Fail |
The device has failed to apply IPv6 ACL 2500 to the interface |
# Display the application status of the inbound and outbound packet filtering ACLs for interface VLAN-interface 4094.
[Sysname-Vlan-interface4094] display packet-filter interface Vlan-interface 4094
Interface: Vlan-interface4094
In-bound Policy:
acl 3000, Successful
Out-bound Policy:
Table 8 Output description
acl 3000, Successful |
IPv4 ACL 3000 has been applied to the main processing unit and all or some of the cards for the VLAN interface. NOTE: When an application failure occurs on an interface card, an error message appears. You can specify the slot number in the display command to check the ACL application status on the card. |
# Display the application status of inbound and outbound packet filtering ACLs for the card in slot 3.
[Sysname-Vlan-interface4094] display packet-filter interface Vlan-interface 4094 slot 3
In-bound Policy:
acl 3000, Fail
Out-bound Policy:
Table 9 Output description
acl 3000, Fail |
The device has failed to apply IPv6 ACL 3000 to the specified card. |
NOTE: · The switch applies the packet filtering ACL configured on a VLAN interface to the main processing unit and all interface cards. If the switch fails to apply the ACL on one interface card, you must use the undo packet-filter command to remove the packet filter from the VLAN interface, because the switch cannot automatically remove the ACL that has been applied to the main processing unit and other cards. · You must also use the undo packet-filter command to remove the packet filter from the VLAN interface if the switch fails to update the packet filter on an interface card after you edit the ACL rules, for example, because of hardware resource insufficiency. If you do not remove the packet filter, the old ACL rules continue to take effect and the display packet-filter command shows the initial ACL application status. |
display time-range
display time-range { time-range-name | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
time-range-name: Specifies a time range name, a case-insensitive string of 1 to 32 characters. It must start with an English letter.
all: Displays the configuration and status of all existing time ranges.
Use the display time-range command to display the configuration and status of the specified time range or all time ranges.
# Display the configuration and status of time range trname.
<Sysname> display time-range trname
Current time is 10:45:15 1/26/2010 Tuesday
Time-range : trname ( Inactive )
from 08:00 1/2/2010 to 23:59 1/3/2010
Table 10 Output description
Current time |
Current system time |
Time-range |
Configuration and status of the time range, including its name, status (active or inactive), and start time and end time. |
flow-template
flow-template flow-template-name
undo flow-template
View
Interface view, port group view
Default level
2: System level
flow-template-name: Specifies the name of an existing user-defined flow template, a case-insensitive string of 1 to 31 characters.
Use the flow-template command to apply a user-defined flow template to an interface or port group.
Use the undo flow-template command to restore the default.
By default, an interface uses the default flow template.
The user-defined flow template applied to a port group takes effect on all interfaces in the group.
You can apply only one user-defined flow template on an interface.
Related commands: display flow-template interface, and flow-template basic.
# Apply user-defined flow template aaa to interface POS 3/1/1.
[Sysname] interface Pos 3/1/1
[Sysname-Pos3/1/1] flow-template aaa
# Apply user-defined flow template f1 to port group 1.
[Sysname] port-group manual 1
[Sysname-port-group-manual-1] group-member GigabitEthernet 3/1/1 to GigabitEthernet 3/1/6
[Sysname-port-group-manual-1] flow-template f1
flow-template basic
flow-template flow-template-name basic { customer-vlan-id | dip | dmac | dport | dscp | ethernet-protocol | fragments | icmp-code | icmp-type | ip-precedence | ip-protocol | mpls-exp | service-cos | sip | smac | sport | tcp-flag | tos } *
undo flow-template { all | name flow-template-name }
View
Default level
2: System level
flow-template-name: Assigns a name to a user-defined flow template, a case-insensitive string of 1 to 31 characters.
basic: Sets the type of the user-defined flow template to basic.
customer-vlan-id: Customer VLAN ID.
dip: Destination IP address.
dmac: Destination MAC address.
dport: Destination port.
dscp: Differentiated service code point (DSCP) field in the IP header.
ethernet-protocol: Protocol type field in the Ethernet frame header.
fragments: Fragments field in the IP header.
icmp-code: ICMP code field.
icmp-type: ICMP type field.
ip-precedence: Precedence field in the IP header.
ip-protocol: Protocol type field in the IP header.
mpls-exp: EXP field in the MPLS label.
service-cos: Service provider 802.1p COS field.
sip: Source IP address.
smac: Source MAC address.
sport: Source port.
tcp-flag: Flags field in the TCP header.
tos: ToS field in the IP header.
all: Deletes all user-defined flow templates.
Use the flow-template basic command to create a basic user-defined flow template.
Use the undo flow-template command to delete one or all user-defined flow templates. To ensure a successful removal, check that the template you are deleting has not applied to any interface.
By default, no user-defined flow template exists.
The POS interface does not support the keywords smac, dmac, and customer-vlan-id for user-defined flow templates.
Related commands: display flow-template user-defined, and flow-template.
# Create a basic user-defined flow template.
[Sysname] flow-template f1 basic dip ip-protocol tcp-flag
hardware-count enable
undo hardware-count enable
View
Default level
2: System level
None
Use the hardware-count enable command to enable counting ACL rule matches performed in hardware. The device automatically counts the rule match counting performed in software.
Use the undo hardware-count enable command to disable counting ACL rule matches performed in hardware. This command also resets the hardware match counters for all rules in the ACL. For a rule configured with the counting keyword, this command only resets the rule’s hardware match counter.
By default, ACL rule matches performed in hardware are not counted.
The hardware-count enable command enables match counting for all rules in an ACL, and the counting keyword in the rule command enables match counting specific to rules. For an individual rule, rule match counting works as long as either the hardware-count enable command or the counting keyword is configured.
The switch does not count ACL rule matches for the outbound ACL deny rules.
Related commands: display acl, display acl ipv6, and rule.
# Enable rule match counting for IPv4 ACL 2000.
[Sysname-acl-basic-2000] hardware-count enable
# Enable rule match counting for IPv6 ACL 2000.
[Sysname-acl6-basic-2000] hardware-count enable
packet-filter
packet-filter { acl-number | name acl-name } { inbound | outbound }
undo packet-filter { acl-number | name acl-name } { inbound | outbound }
View
Interface view
Default level
2: System level
inbound: Filters incoming packets.
outbound: Filters outgoing packets.
Use the packet-filter command to apply an IPv4 basic, IPv4 advanced, Ethernet frame header, or user-defined ACL to an interface to filter packets.
Use the undo packet-filter command to restore the default.
By default, an interface does not filter Layer 2 or IPv4 packets.
The rule you add to an ACL that has been used by a packet filter cannot take effect if hardware resources are insufficient or the packet filter does not support the rule. Such rules are marked as uncompleted in the output of the display acl { acl-number | all | name acl-name } slot slot-number command. To successfully apply the rule, you must delete the rule and reconfigure it when hardware resources are sufficient.
Follow these guidelines when you configure a packet filter on a VLAN interface:
· Use the undo packet-filter command to remove the packet filter from the VLAN interface if the ACL application fails on an interface card, for example, because of hardware resource insufficiency. The switch applies the packet filter configured on a VLAN interface to the main processing unit and all interface cards. When an application failure occurs on an interface card, the switch cannot automatically remove the ACL that has been applied to the main processing unit or any other interface card.
· You must also use the undo packet-filter to remove the packet filter if the switch fails to update the packet filter on an interface card after you edit the ACL rules. If you do not remove the packet filter, the old ACL rules continue to take effect and the display packet-filter command shows the initial ACL application status.
Related commands: display packet-filter.
NOTE: · In IRF mode, the switch does not support cross-chassis IP packet filtering. · Avoid the case that multiple users configure the packet-filter command at the same time. Otherwise, the configuration may fail. |
# Apply IPv4 ACL 2001 to filter incoming traffic on GigabitEthernet 3/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] packet-filter 2001 inbound
packet-filter ipv6
packet-filter ipv6 { acl6-number | name acl6-name } { inbound | outbound }
undo packet-filter ipv6 { acl6-number | name acl6-name } { inbound | outbound }
View
Interface view
Default level
2: System level
inbound: Filters incoming IPv6 packets.
outbound: Filters outgoing IPv6 packets.
Use the packet-filter ipv6 command to apply an IPv6 basic or IPv6 advanced ACL to an interface to filter IPv6 packets.
Use the undo packet-filter ipv6 command to restore the default.
By default, an interface does not filter IPv6 packets.
The rule you add to an ACL that has been used by a packet filter cannot take effect if hardware resources are insufficient or the packet filter does not support the rule. Such rules are marked as uncompleted in the output of the display acl ipv6 { acl-number | all | name acl-name } slot slot-number command. To successfully apply the rule, you must delete the rule and reconfigure it when hardware resources are sufficient.
· Use the undo packet-filter ipv6 command to remove the packet filter from the VLAN interface if the ACL application fails on an interface card, for example, because of hardware resource insufficiency. The switch applies the packet filter configured on a VLAN interface to the main processing unit and all interface cards. When an application failure occurs on an interface card, the switch cannot automatically remove the ACL that has been applied to the main processing unit or any other interface card.
· You must also use the undo packet-filter ipv6 to remove the packet filter if the switch fails to update the packet filter on an interface card after you edit the ACL rules. If you do not remove the packet filter, the old ACL rules continue to take effect and the display packet-filter ipv6 command shows the initial ACL application status.
NOTE: · In IRF mode, the switch does not support cross-chassis IP packet filtering. · Avoid the case that multiple users configure the packet-filter ipv6 command at the same time. Otherwise, the configuration may fail. |
# Apply IPv6 ACL 2500 to filter incoming packets on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] packet-filter ipv6 2500 outbound
undo packet-filter forwarding-layer route outbound
View
Default level
2: System level
None
Use the packet-filter forwarding-layer route outbound command to set the outbound packet filters on VLAN interfaces to filter only Layer 3 (routed) unicast packets. After you execute this command, the packet-filter outbound command on a VLAN interface filters only Layer 3 unicast packets.
Use the undo packet-filter forwarding-layer route outbound command to restore the default.
By default, an outbound packet filter on a VLAN interface filters all packets, including Layer 2 packets.
When you use the packet-filter forwarding-layer route outbound command or its undo form to specify the outbound packet filter on a VLAN interface to filter only Layer 3 unicast packets or all packets, follow these guidelines:
· The packet-filter forwarding-layer route outbound command is available only for Ethernet interface cards.
· The packet-filter forwarding-layer route outbound or its undo form must be configured before the packet-filter { acl-number | name acl-name } outbound command. If you have configured the packet-filter { acl-number | name acl-name } outbound command on a VLAN interface, you must remove the packet filter setting, configure the packet-filter forwarding-layer route outbound or its undo form, and then re-configure the packet-filter { acl-number | name acl-name } outbound command on the VLAN interface.
· The packet-filter forwarding-layer route outbound command can cause the switch to discard BFD packets. To avoid this problem, configure an advanced ACL rule by using the rule [ rule-id ] permit udp destination-port range 3784 3785 command to permit BFD packets.
· In IRF mode, the packet-filter forwarding-layer route outbound command can cause the switch to discard sFlow packets. To avoid this problem, configure an advanced ACL rule by using the rule [ rule-id ] permit udp destination-port range eq udp-port command to permit sFlow packets. The udp-port is the port number of the sFlow collector and defaults to 6343. For information about sFlow, see Network Management and Monitoring Configuration Guide.
# Apply IPv4 ACL 2001 to filter only outbound Layer 3 unicast packets on VLAN-interface 2.
[Sysname] packet-filter forwarding-layer route outbound
[Sysname-Vlan-interface2] packet-filter 2001 outbound
reset acl counter
reset acl counter { acl-number | all | name acl-name }
View
Default level
2: System level
all: Clears statistics for all IPv4 ACLs.
Use the reset acl counter command to clear statistics for the specified IPv4 ACL or all IPv4 ACLs.
Related commands: display acl.
# Clear statistics for IPv4 basic ACL 2001.
# Clear statistics for IPv4 ACL flow.
<Sysname> reset acl counter name flow
reset acl ipv6 counter
reset acl ipv6 counter { acl6-number | all | name acl6-name }
View
Default level
2: System level
all: Clears statistics for all IPv6 basic and advanced ACLs.
Use the reset acl ipv6 counter command to clear statistics for the specified IPv6 ACL or all IPv6 basic and IPv6 advanced ACLs.
Related commands: display acl ipv6.
# Clear statistics for IPv6 basic ACL 2001.
<Sysname> reset acl ipv6 counter 2001
# Clear statistics for IPv6 ACL flow.
<Sysname> reset acl ipv6 counter name flow
rule (Ethernet frame header ACL view)
rule [ rule-id ] { deny | permit } [ cos vlan-pri | counting | dest-mac dest-addr dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac sour-addr source-mask | time-range time-range-name ] *
undo rule rule-id [ counting | time-range ] *
View
Default level
2: System level
rule-id: Specifies a rule ID, in the range of 0 to 65534. If no rule ID is provided when you create an ACL rule, the system automatically assigns it a rule ID. This rule ID takes the nearest higher multiple of the numbering step to the current highest rule ID, starting from 0. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the rule is numbered 30.
deny: Drops matching packets if the ACL rule is used for packet filtering. When the ACL is used for traffic classification, the processing of deny rules vary with feature modules. For example, if you use an ACL for classifying traffic in a QoS policy, the switch does not perform the traffic behavior associated with the traffic class for the packets that match a deny rule.
permit: Allows matching packets to pass if the rule is used for packet filtering. When the ACL is used for traffic classification, the traffic that matches a permit rule matches the class. For example, if you use an ACL for classifying traffic in a QoS policy, the switch performs the traffic behavior associated with the traffic class for the packets that match a permit rule.
cos vlan-pri: Matches an 802.1p priority. The vlan-pri argument can be a number in the range of 0 to 7, or in words, best-effort (0), background (1), spare (2), excellent-effort (3), controlled-load (4), video (5), voice (6), or network-management (7).
counting: Counts the number of times the IPv4 ACL rule has been matched.
dest-mac dest-addr dest-mask: Matches a destination MAC address range. The dest-addr and dest-mask arguments represent a destination MAC address and mask in H-H-H format.
lsap lsap-type lsap-type-mask: Matches the DSAP and SSAP fields in LLC encapsulation. The lsap-type argument is a 16-bit hexadecimal number that represents the encapsulation format. The lsap-type-mask argument is a 16-bit hexadecimal number that represents the LSAP mask. The switch does not support this keyword.
type protocol-type protocol-type-mask: Matches one or more protocols in the Ethernet frame header. The protocol-type argument is a 16-bit hexadecimal number that represents a protocol type in Ethernet_II and Ethernet_SNAP frames. The protocol-type-mask argument is a 16-bit hexadecimal number that represents a protocol type mask. For example, to match ARP, IPv4, or IPv6 packets, specify protocol-type protocol-type-mask as 0x0806 0xFFFF, 0x0800 0xFFFF, or 0x86DD 0xFFFF.
source-mac sour-addr source-mask: Matches a source MAC address range. The sour-addr argument represents a source MAC address, and the sour-mask argument represents a mask in H-H-H format.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument is a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule; however, the rule using the time range can take effect only after you configure the timer range.
Use the rule command to create or edit an Ethernet frame header ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an Ethernet frame header ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specified attributes.
By default, an Ethernet frame header ACL does not contain any rule.
Within an ACL, the permit or deny statement of each rule must be unique. If the ACL rule you are creating or editing has the same deny or permit statement as another rule in the ACL, your creation or editing attempt fails.
To view rules in an ACL and their rule IDs, use the display acl all command.
Related commands: acl, display acl, step, and time-range.
# Create a rule in ACL 4000 to permit ARP packets and deny RARP packets.
[Sysname] acl number 4000
[Sysname-acl-ethernetframe-4000] rule permit type 0806 ffff
[Sysname-acl-ethernetframe-4000] rule deny type 8035 ffff
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { dest-addr dest-wildcard | any } | destination-port operator port1 [ port2 ] | dscp dscp | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | logging | precedence precedence | source { sour-addr sour-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-range-name | tos tos | vpn-instance vpn-instance-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | dscp | fragment | icmp-type | logging | precedence | source | source-port | time-range | tos | vpn-instance ] *
View
Default level
2: System level
protocol: Protocol carried by IPv4. It can be a number in the range of 0 to 255, or in words, gre (47), icmp (1), igmp (2), ip, ipinip (4), ospf (89), tcp (6), or udp (17). Table 11 describes the parameters that you can specify regardless of the value that the protocol argument takes.
Table 11 Match criteria and other rule information for IPv4 advanced ACL rules
Parameters |
Function |
Specifies a source address |
The sour-addr sour-wildcard arguments represent a source IP address and wildcard mask in dotted decimal notation. An all-zero wildcard specifies a host address. The any keyword specifies any source IP address. |
Specifies a destination address |
The dest-addr dest-wildcard arguments represent a destination IP address and wildcard mask in dotted decimal notation. An all-zero wildcard specifies a host address. The any keyword represents any destination IP address. |
counting |
Counts the number of times the IPv4 ACL rule has been matched |
If a rule has the counting keyword while the hardware-count enable command is not configured for the ACL, the counting function is enabled for this rule. |
Specifies an IP precedence value |
The precedence argument can be a number in the range of 0 to 7, or in words, routine (0), priority (1), immediate (2), flash (3), flash-override (4), critical (5), internet (6), or network (7). |
tos tos |
Specifies a ToS preference |
The tos argument can be a number in the range of 0 to 15, or in words, max-reliability (2), max-throughput (4), min-delay (8), min-monetary-cost (1), or normal (0). |
dscp dscp |
Specifies a DSCP priority |
The dscp argument can be a number in the range of 0 to 63, or in words, af11 (10), af12 (12), af13 (14), af21 (18), af22 (20), af23 (22), af31 (26), af32 (28), af33 (30), af41 (34), af42 (36), af43 (38), cs1 (8), cs2 (16), cs3 (24), cs4 (32), cs5 (40), cs6 (48), cs7 (56), default (0), or ef (46). |
logging |
Logs matching packets |
This keyword supports only the packet filter function. |
vpn-instance vpn-instance-name |
Applies the rule to packets in a VPN instance |
The vpn-instance-name argument takes a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the rule applies to all packets. |
fragment |
Applies the rule to fragments |
Without this keyword, the rule applies to all fragments and non-fragments. |
Specifies a time range for the rule |
The time-range-name argument takes a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule; however, the rule using the time range can take effect only after you configure the timer range. |
NOTE: If you provide the precedence or tos keyword in addition to the dscp keyword, only the dscp keyword takes effect. |
If the protocol argument takes tcp (6) or udp (7), set the parameters shown in Table 12.
Table 12 TCP/UDP-specific parameters for IPv4 advanced ACL rules
Parameters |
Function |
Specifies one or more UDP or TCP source ports |
The operator argument can be lt (lower than), gt (greater than), eq (equal to), neq (not equal to), or range (inclusive range). The port1 and port2 arguments are TCP or UDP port numbers in the range of 0 to 65535. port2 is needed only when the operator argument is range. TCP port numbers can be represented in these words: chargen (19), bgp (179), cmd (514), daytime (13), discard (9), domain (53), echo (7), exec (512), finger (79), ftp (21), ftp-data (20), gopher (70), hostname (101), irc (194), klogin (543), kshell (544), login (513), lpd (515), nntp (119), pop2 (109), pop3 (110), smtp (25), sunrpc (111), tacacs (49), talk (517), telnet (23), time (37), uucp (540), whois (43), and www (80). UDP port numbers can be represented in these words: biff (512), bootpc (68), bootps (67), discard (9), dns (53), dnsix (90), echo (7), mobilip-ag (434), mobilip-mn (435), nameserver (42), netbios-dgm (138), netbios-ns (137), netbios-ssn (139), ntp (123), rip (520), snmp (161), snmptrap (162), sunrpc (111), syslog (514), tacacs-ds (65), talk (517), tftp (69), time (37), who (513), and xdmcp (177). |
Specifies one or more UDP or TCP destination ports |
Specifies one or more TCP flags including ACK, FIN, PSH, RST, SYN, and URG |
Parameters specific to TCP. The value for each argument can be 0 (flag bit not set) or 1 (flag bit set). The TCP flags in a rule are ANDed. |
established |
Specifies the flags for indicating the established status of a TCP connection |
Parameter specific to TCP. |
If the protocol argument takes icmp (1), you can set the parameters shown in Table 13.
Table 13 ICMP-specific parameters for IPv4 advanced ACL rules
Parameters |
Function |
Specifies the ICMP message type and code |
The icmp-type argument is in the range of 0 to 255. The icmp-code argument is in the range of 0 to 255. The icmp-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 14. |
Table 14 ICMP message names supported in IPv4 advanced ACL rules
ICMP message name |
ICMP message type |
ICMP message code |
echo |
8 |
0 |
echo-reply |
0 |
0 |
fragmentneed-DFset |
3 |
4 |
host-redirect |
5 |
1 |
host-tos-redirect |
5 |
3 |
host-unreachable |
3 |
1 |
information-reply |
16 |
0 |
information-request |
15 |
0 |
net-redirect |
5 |
0 |
net-tos-redirect |
5 |
2 |
net-unreachable |
3 |
0 |
parameter-problem |
12 |
0 |
port-unreachable |
3 |
3 |
protocol-unreachable |
3 |
2 |
reassembly-timeout |
11 |
1 |
source-quench |
4 |
0 |
source-route-failed |
3 |
5 |
timestamp-reply |
14 |
0 |
timestamp-request |
13 |
0 |
ttl-exceeded |
11 |
0 |
Use the rule command to create or edit an IPv4 advanced ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv4 advanced ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specified attributes.
By default, an IPv4 advanced ACL does not contain any rule.
# Create an IPv4 advanced ACL rule to permit TCP packets with the destination port 80 from 129.9.0.0/16 to 202.38.160.0/24, and enable logging matching packets.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit tcp source 129.9.0.0 0.0.255.255 destination 202.38.160.0 0.0.0.255 destination-port eq 80 logging
# Create IPv4 advanced ACL rules to permit all IP packets but the ICMP packets destined for 192.168.1.0/24.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit ip
[Sysname-acl-adv-3001] rule deny icmp destination 192.168.1.0 0.0.0.255
# Create IPv4 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl number 3002
[Sysname-acl-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv4 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl number 3003
[Sysname-acl-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl-adv-3003] rule permit udp destination-port eq snmptrap
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | source { sour-addr sour-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ counting | fragment | logging | source | time-range | vpn-instance ] *
View
IPv4 basic ACL view
Default level
2: System level
fragment: Applies the rule only to non-first fragments. A rule without this keyword applies to both fragments and non-fragments.
logging: Logs matching packets. The keyword supports only the packet filter function.
source { sour-addr sour-wildcard | any }: Matches a source address. The sour-addr sour-wildcard arguments represent a source IP address and wildcard mask in dotted decimal notation. A wildcard mask of zeros specifies a host address. The any keyword represents any source IP address.
vpn-instance vpn-instance-name: Applies the rule to packets in a VPN instance. The vpn-instance-name argument takes a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the rule applies only to all packets.
Use the rule command to create or edit an IPv4 basic ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv4 basic ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specified attributes.
By default, an IPv4 basic ACL does not contain any rule.
# Create a rule in IPv4 basic ACL 2000 to deny the packets from any source IP segment but 10.0.0.0/8, 172.17.0.0/16, or 192.168.1.0/24.
[Sysname-acl-basic-2000] rule permit source 10.0.0.0 0.255.255.255
[Sysname-acl-basic-2000] rule permit source 172.17.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-basic-2000] rule deny source any
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { dest dest-prefix | dest/dest-prefix | any } | destination-port operator port1 [ port2 ] | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | logging | source { source source-prefix | source/source-prefix | any } | source-port operator port1 [ port2 ] | time-range time-range-name | vpn-instance vpn-instance-name ] *
undo rule rule-id [ { { ack | fin | psh | rst | syn | urg } * | established } | counting | destination | destination-port | dscp | flow-label | fragment | icmp6-type | logging | source | source-port | time-range | vpn-instance ] *
View
Default level
2: System level
protocol: Matches protocol carried over IPv6. It can be a number in the range of 0 to 255, or in words, gre (47), icmpv6 (58), ipv6, ipv6-ah (51), ipv6-esp (50), ospf (89), tcp (6), or udp (17). Table 15 describes the parameters that you can specify regardless of the value that the protocol argument takes.
Table 15 Match criteria and other rule information for IPv6 advanced ACL rules
Parameters |
Function |
Specifies a source IPv6 address |
The source and source-prefix arguments represent an IPv6 source address, and prefix length in the range of 1 to 128. The any keyword represents any IPv6 source address. |
Specifies a destination IPv6 address |
The dest and dest-prefix arguments represent a destination IPv6 address, and prefix length in the range of 1 to 128. The any keyword specifies any IPv6 destination address. |
counting |
Counts the number of times the IPv6 ACL rule has been matched |
dscp dscp |
Specifies a DSCP preference |
Specifies a flow label value in an IPv6 packet header |
The flow-label-value argument is in the range of 0 to 1048575. |
logging |
The keyword supports only the packet filter function. |
fragment |
Applies the rule to only non-first fragments |
The vpn-instance-name argument takes a case-sensitive string of 1 to 31 characters. The switch does not support this option. |
If the protocol argument takes tcp (6) or udp (17), set the parameters shown in Table 16.
Table 16 TCP/UDP-specific parameters for IPv6 advanced ACL rules
Parameters |
Function |
Specifies one or more TCP flags, including ACK, FIN, PSH, RST, SYN, and URG |
Parameters specific to TCP. The value for each argument can be 0 (flag bit not set) or 1 (flag bit set). The TCP flags in a rule are ANDed. The switch does not support these options. |
established |
If the protocol argument takes icmpv6 (58), set the parameters shown in Table 17.
Table 17 ICMPv6-specific parameters for IPv6 advanced ACL rules
Parameters |
Function |
Specifies the ICMPv6 message type and code |
The icmp6-type argument is in the range of 0 to 255. The icmp6-code argument is in the range of 0 to 255. The icmp6-message argument specifies a message name. Supported ICMP message names and their corresponding type and code values are listed in Table 18. |
Table 18 ICMPv6 message names supported in IPv6 advanced ACL rules
ICMPv6 message name |
ICMPv6 message type |
ICMPv6 message code |
echo-reply |
129 |
0 |
echo-request |
128 |
0 |
err-Header-field |
4 |
0 |
frag-time-exceeded |
3 |
1 |
hop-limit-exceeded |
3 |
0 |
host-admin-prohib |
1 |
1 |
host-unreachable |
1 |
3 |
neighbor-advertisement |
136 |
0 |
neighbor-solicitation |
135 |
0 |
network-unreachable |
1 |
0 |
packet-too-big |
2 |
0 |
port-unreachable |
1 |
4 |
redirect |
137 |
0 |
router-advertisement |
134 |
0 |
router-solicitation |
133 |
0 |
unknown-ipv6-opt |
4 |
2 |
unknown-next-hdr |
4 |
1 |
Use the rule command to create or edit an IPv6 advanced ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv6 advanced ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specified attributes.
By default, an IPv6 advanced ACL does not contain any rule.
To view rules in an ACL and their rule IDs, use the display acl ipv6 all command.
Related commands: acl ipv6, display ipv6 acl, step, and time-range.
# Create an IPv6 ACL rule to permit TCP packets with the destination port 80 from 2030:5060::/64 to FE80:5060::/96, and enable logging matching packets.
[Sysname-acl6-adv-3000] rule permit tcp source 2030:5060::/64 destination fe80:5060::/96 destination-port eq 80 logging
# Create IPv6 advanced ACL rules to permit all IPv6 packets but the ICMPv6 packets destined for FE80:5060:1001::/48.
[Sysname] acl ipv6 number 3001
[Sysname-acl6-adv-3001] rule permit ipv6
[Sysname-acl6-adv-3001] rule deny icmpv6 destination fe80:5060:1001:: 48
# Create IPv6 advanced ACL rules to permit inbound and outbound FTP packets.
[Sysname] acl ipv6 number 3002
[Sysname-acl6-adv-3002] rule permit tcp source-port eq ftp
[Sysname-acl6-adv-3002] rule permit tcp source-port eq ftp-data
[Sysname-acl6-adv-3002] rule permit tcp destination-port eq ftp
[Sysname-acl6-adv-3002] rule permit tcp destination-port eq ftp-data
# Create IPv6 advanced ACL rules to permit inbound and outbound SNMP and SNMP trap packets.
[Sysname] acl ipv6 number 3003
[Sysname-acl6-adv-3003] rule permit udp source-port eq snmp
[Sysname-acl6-adv-3003] rule permit udp source-port eq snmptrap
[Sysname-acl6-adv-3003] rule permit udp destination-port eq snmp
[Sysname-acl6-adv-3003] rule permit udp destination-port eq snmptrap
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | source { ipv6-address prefix-length | ipv6-address/prefix-length | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
View
IPv6 basic ACL view
Default level
2: System level
counting: Counts the number of times the IPv6 ACL rule has been matched.
source { ipv6-address prefix-length | ipv6-address/prefix-length | any }: Matches a source IP address. The ipv6-address and prefix-length arguments represent a source IPv6 address and address prefix length in the range of 1 to 128. The any keyword represents any IPv6 source address.
time-range time-range-name: Specifies a time range for the rule. The time-range-name argument takes a case-insensitive string of 1 to 32 characters. It must start with an English letter. If the time range is not configured, the system creates the rule; however, the rule using the time range can take effect only after you configure the timer range.
vpn-instance vpn-instance-name: Applies the rule to packets in a VPN. The vpn-instance-name argument takes a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the rule applies to non-VPN packets. The switch does not support this option.
Use the rule command to create or edit an IPv6 basic ACL rule. You can edit ACL rules only when the match order is config.
Use the undo rule command to delete an entire IPv6 basic ACL rule or some attributes in the rule. If no optional keywords are provided, you delete the entire rule. If optional keywords or arguments are provided, you delete the specified attributes.
By default, an IPv6 basic ACL does not contain any rule.
# Create an IPv6 basic ACL rule to deny the packets from any source IP segment but 1001::/16, 3124:1123::/32, or FE80:5060:1001::/48.
[Sysname-acl6-basic-2000] rule permit source 1001:: 16
[Sysname-acl6-basic-2000] rule permit source 3124:1123:: 32
[Sysname-acl6-basic-2000] rule permit source fe80:5060:1001:: 48
[Sysname-acl6-basic-2000] rule deny source any
rule (user-defined ACL view)
rule [ rule-id ] { deny | permit } [ { { ipv4 | ipv6 | l2 | l4 } rule-string rule-mask offset }&<1-8> ] [ counting | time-range time-range-name ] *
undo rule rule-id
View
User-defined ACL view
Default level
2: System level
ipv4: Specifies that the offset starts 20 bytes after the beginning of the IPv4 header.
ipv6: Specifies that the offset starts 40 bytes after the beginning of the IPv6 header. Only EC and EF cards support this keyword.
l2: Specifies that the offset starts two bytes before the Layer 3 header.
l4: Specifies that the offset starts 20 bytes after the Layer 4 header.
rule-string: Defines a match pattern in hexadecimal format. Its length must be a multiple of two.
rule-mask: Defines a match pattern mask in hexadecimal format. Its length must be the same as that of the match pattern. A match pattern mask is used for ANDing the selected string of a packet.
offset: Offset in bytes after which the match operation begins.
&<1-8>: Specifies that up to eight match patterns can be defined in the ACL rule.
Use the rule command to create a user-defined ACL rule. You cannot edit a user-defined ACL rule. If you number the ACL rule the same as an existing rule in the ACL, the new rule overwrites the old one.
Use the undo rule command to delete an entire user-defined ACL rule.
By default, a user-defined ACL does not contain any rule.
Table 19 User-defined ACL usage description
Keyword |
Start offset |
Configurable offset length (in bytes) |
Packets to be matched |
40-byte ACL rule length mode |
48-byte ACL rule length mode |
80-byte ACL rule length mode |
ipv4 |
Beginning of the IPv4 header + 20 bytes |
Not supported |
9 |
12 |
IPv4 packets except IPv4 UDP/TCP packets |
ipv6 |
Beginning of the IPv6 header + 40 bytes |
Not supported |
Not supported |
14 |
IPv6 packets |
l2 |
Layer 3 header – 2 bytes |
Not supported |
10 |
13 |
Non-IPv4 packets, non-IPv6 packets, and non-MPLS packets |
l4 |
Beginning of the Layer 4 header + 20 bytes |
Not supported |
4 |
12 |
NOTE: EC and EF cards, for example, LSR1GP48LEC1 and LSR1GP48LEF1, support user-defined ACLs only after you configure the acl ipv6 enable command. For more information about the command, see “acl ipv6 enable.” The other cards by default support user-defined ACLs. |
# Create a rule for user-defined ACL 5005 to permit packets that carry 0x0808 for the two bytes that are 22 bytes from the beginning of the Layer 2 header.
[Sysname] acl number 5005
[Sysname-acl-user-5005] rule 0 permit ipv4 0808 ffff 2
rule comment
rule rule-id comment text
undo rule rule-id comment
View
Default level
2: System level
rule-id: Specifies the ID of an existing ACL rule. The ID is in the range of 0 to 65534.
text: Adds a comment about the ACL rule, a case-sensitive string of 1 to 127 characters.
Use the rule comment command to add a comment about an existing ACL rule or edit its comment to make the rule easy to understand.
Use the undo rule comment command to delete the ACL rule comment.
By default, an IPv4 ACL rule has no rule comment.
# Create a rule in IPv4 basic ACL 2000 and add a comment about the rule.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule 0 deny source 1.1.1.1 0
[Sysname-acl-basic-2000] rule 0 comment This rule is used in vlan 2
# Create a rule in IPv6 basic ACL 2000 and add a comment about the rule.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule 0 permit source 2030:5060::9050/64
[Sysname-acl6-basic-2000] rule 0 comment This rule is used in vlan 2
rule remark
rule [ rule-id ] remark text
undo rule [ rule-id ] remark [ text ]
View
Default level
2: System level
rule-id: Specifies a rule number in the range of 0 to 65535. The specified rule can be one that has been created or not. If you specify no rule ID when adding a remark, the system automatically picks the rule ID that is the nearest higher multiple of the numbering step to the current highest rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 28, the system picks rule 30.
text: Specifies a remark, a case-sensitive string of 1 to 63 characters.
Use the rule remark command to add a start or end remark for a range of rules that are created for the same purpose.
Use the undo rule remark command to delete the specified or all rule range remarks.
By default, no rule range remarks are configured.
A rule range remark always appears immediately above the specified rule. If the specified rule has not been created yet, the position of the comment in the ACL is as follows:
· If the match order is config, the remark is inserted into the ACL in descending order of rule ID.
· If the match order is auto, the remark is placed at the end of the ACL. After you create the rule, the remark appears above the rule.
To display rule range remarks in an ACL, use the display this or display current-configuration.
When you delete rule range remarks, follow these guidelines:
· If neither rule-id nor text is specified, all rule range remarks are removed.
· Use the undo rule remark text command to remove all remarks that are the same as the text argument.
· Use the undo rule rule-id remark command to delete a specific rule range remark. If you also specify the text argument, you must type in the remark the same as was specified to successfully remove the remark.
TIP: When adding an end remark for a rule range, you can specify the end rule number plus 1 for the rule-id argument so all rules in this range appears between the two remarks. You can also specify the end rule number for the rule-id argument. In this approach, the end rule appears below the end remark. Whichever approach you use, be consistent. |
Related commands: display this, display current-configuration (Fundamentals Configuration Commands).
# Display the running configuration of IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] display this
acl number 2000
rule 0 permit source 14.1.1.0 0.0.0.255
rule 5 permit source 10.1.1.1 0 time-range work-time
rule 10 permit source 192.168.0.0 0.0.0.255
rule 15 permit source 1.1.1.1 0
rule 20 permit source 10.1.1.1 0
rule 25 permit counting
return
# Add a start comment “Rules for VIP_start” and an end comment “Rules for VIP_end” for the rule range 10 to 25.
[Sysname-acl-basic-2000] rule 10 remark Rules for VIP_start
[Sysname-acl-basic-2000] rule 26 remark Rules for VIP_end
# Verify the configuration.
acl number 2000
return
step
step step-value
undo step
View
Default level
2: System level
step-value: ACL rule numbering step, in the range of 1 to 20.
Use the step command to set a rule numbering step for an ACL. The rule numbering step sets the increment by which the system numbers rules automatically. For example, the default ACL rule numbering step is 5. If you do not assign IDs to rules you are creating, they are numbered 0, 5, 10, 15, and so on. The wider the numbering step, the more rules you can insert between two rules. Whenever the step changes, the rules are renumbered, starting from 0. For example, if there are five rules numbered 5, 10, 13, 15, and 20, changing the step from 5 to 2 causes the rules to be renumbered 0, 2, 4, 6 and 8.
Use the undo step command to restore the default.
The default rule numbering step is 5. After you restore the default numbering step by the undo step command, the rules are renumbered in steps of 5.
Related commands: display acl and display acl ipv6.
# Set the rule numbering step to 2 for IPv4 basic ACL 2000.
[Sysname-acl-basic-2000] step 2
# Set the rule numbering step to 2 for IPv6 basic ACL 2000.
[Sysname-acl6-basic-2000] step 2
time-range
time-range time-range-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
undo time-range time-range-name [ start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 ]
View
Default level
2: System level
time-range-name: Specifies a time range name. The name is a case-insensitive string of 1 to 32 characters. It must start with an English letter and to avoid confusion, cannot be all.
start-time to end-time: Specifies a periodic statement. Both start-time and end-time are in hh:mm format (24-hour clock), and each value is in the range of 00:00 to 23:59. The end time must be greater than the start time.
days: Specifies the day or days of the week (in words or digits) on which the periodic statement is valid. If you specify multiple values, separate each value with a space, and make sure that they do not overlap. These values can take one of the following forms:
· A digit in the range of 0 to 6, respectively for Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, and Saturday.
· A day of a week in words, sun, mon, tue, wed, thu, fri, and sat.
· working-day for Monday through Friday.
· off-day for Saturday and Sunday.
· daily for the whole week.
from time1 date1: Specifies the start time and date of an absolute statement. The time1 argument specifies the time of the day in hh:mm format (24-hour clock). Its value is in the range of 00:00 to 23:59. The date1 argument specifies a date in MM/DD/YYYY or YYYY/MM/DD format, where MM is the month of the year in the range of 1 to 12, DD is the day of the month with the range depending on MM, and YYYY is the year in the calendar in the range of 1970 to 2100. If not specified, the start time is 01/01/1970 00:00 AM, the earliest time available in the system.
to time2 date2: Specifies the end time and date of the absolute time statement. The time2 argument has the same format as the time1 argument, but its value is in the range of 00:00 to 24:00. The date2 argument has the same format and value range as the date1 argument. The end time must be greater than the start time. If not specified, the end time is 12/31/2100 24:00 PM, the maximum time available in the system.
Use the time-range command to configure a time range.
Use the undo time-range command to delete a time range or a statement in the time range.
By default, no time range exists.
You can create multiple statements in a time range. Each time statement can take one of the following forms:
· Periodic statement in the start-time to end-time days format. A periodic statement recurs periodically on a day or days of the week.
· Absolute statement in the from time1 date1 to time2 date2 format. An absolute statement does not recur.
· Compound statement in the start-time to end-time days from time1 date1 to time2 date2 format. A compound statement recurs on a day or days of the week only within the specified period. For example, to create a time range that is active from 08:00 to 12:00 on Monday between January 1, 2010 00:00 and December 31, 2010 23:59, use the time-range test 08:00 to 12:00 mon from 00:00 01/01/2010 to 23:59 12/31/2010 command.
The active period of a time range is calculated as follows:
1. Combining all periodic statements
2. Combining all absolute statements
3. Taking the intersection of the two statement sets as the active period of the time range
You can create a maximum of 256 time ranges, each with a maximum of 32 periodic statements and 12 absolute statements.
Related commands: display time-range.
# Create a periodic time range t1, setting it to be active between 8:00 to 18:00 during working days.
[Sysname] time-range t1 8:0 to 18:0 working-day
# Create an absolute time range t2, setting it to be active in the whole year of 2010.
[Sysname] time-range t2 from 0:0 1/1/2010 to 23:59 12/31/2010
# Create a compound time range t3, setting it to be active from 08:00 to 12:00 on Saturdays and Sundays of the year 2010.
[Sysname] time-range t3 8:0 to 12:0 off-day from 0:0 1/1/2010 to 23:59 12/31/2010
# Create a compound time range t4, setting it to be active from 10:00 to 12:00 on Mondays and from 14:00 to 16:00 on Wednesdays in the period of January through June of the year 2010.
[Sysname] time-range t4 10:0 to 12:0 1 from 0:0 1/1/2010 to 23:59 1/31/2010
[Sysname] time-range t4 14:0 to 16:0 3 from 0:0 6/1/2010 to 23:59 6/30/2010
