| 03-Modem Management Commands | 65.79 KB |
modem
modem [ both | call-in | call-out ]
undo modem [ both | call-in | call-out ]
View
User interface view
Default level
2: System level
both: Enables both modem call-in and modem call-out.
call-in: Enables only modem call-in.
call-out: Enables only modem call-out.
Use the modem command to enable modem call-in, modem call-out, or both on a user interface.
Use the undo modem command to disable modem call-in, modem call-out, or both.
By default, both modem call-in and call-out are disabled.
NOTE: The modem command applies to only auxiliary (AUX) ports. |
# Enable modem call-in on port AUX 0.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] modem call-in
modem auto-answer
modem auto-answer
undo modem auto-answer
View
User interface view
Default level
2: System level
None
Use the modem auto-answer command to configure a modem to operate in auto-answer mode.
Use the undo modem auto-answer command to configure a modem to operate in non-auto-answer mode. In this mode, the modem answers a call only when it receives the corresponding AT command sent by the switch.
By default, a modem operates in non-auto answer mode.
When the modem operates in auto-answer mode (the AA LED of the modem lights up), specify the modem auto-answer command to prevent the switch from issuing answer instructions. If the modem is in non-auto answer mode, use the undo modem auto-answer command to enable the switch to issue answer instructions upon the arrival of incoming calls.
NOTE: · This command applies only to AUX ports. · Make sure you set the same answer mode as on the modem. If a different answer mode is set, the modem might operate improperly. |
# Configure the modem connected to port AUX 0 to operate in auto-answer mode.
[Sysname-ui-aux0] modem auto-answer
modem timer answer
modem timer answer time
undo modem timer answer
View
User interface view
Default level
2: System level
time: Timeout time in seconds, ranging from 0 to 65535.
Use the modem timer answer command to set the maximum interval allowed between off-hook and dialing.
Use the undo modem timer answer command to restore the default.
By default, the interval is 60 seconds.
NOTE: This command applies to only AUX ports. |
# Set the maximum interval between off-hook and dialing to 50 seconds.
[Sysname-ui-aux0] modem timer answer 50
service modem-callback
undo service modem-callback
View
Default level
3: Manage level
None
Use the service modem-callback command to enable the callback function.
Use the undo service modem-callback command to disable the callback function.
By default, the callback function is disabled.
The service modem-callback command enables the modem to initiate a callback upon activation of the line when the modem detects the carrier or data is being received. Because the callback occurs before the PPP process starts and accounting is performed, costs are saved.
# Enable the callback function.
[Sysname] service modem-callback
