| 01-CLI Commands | 106.13 KB |
command-alias enable
undo command-alias enable
View
Default level
2: System level
Use the command-alias enable command to enable the command keyword alias function.
Use the undo command-alias enable command to disable the command keyword alias function.
By default, the command keyword alias function is disabled.
Disabling the command keyword alias function does not delete the configured aliases, but the aliases do not take effect anymore.
Related commands: command-alias mapping.
# Enable the command keyword alias function.
[Sysname] command-alias enable
# Disable the command keyword alias function.
[Sysname] undo command-alias enable
command-alias mapping cmdkey alias
undo command-alias mapping cmdkey
View
Default level
2: System level
cmdkey: Complete form of the first keyword of a non-undo command, or the second keyword of an undo command.
alias: Alias for the keyword, which must be different from the first keyword of any non-undo command.
Use the command-alias mapping command to configure a command keyword alias.
Use the undo command-alias mapping command to delete a command keyword alias.
By default, a command keyword has no alias.
Command keyword aliases take effect only after you enable the command keyword alias function.
# Define show as the alias of the display keyword.
[Sysname] command-alias mapping display show
After you configure the alias, you can enter show to execute a display command. For example, you can enter show clock to execute the display clock command.
# Delete the alias of the display keyword.
[Sysname] undo command-alias mapping display
command-privilege
command-privilege level level view view command
undo command-privilege view view command
View
Default level
3: Manage level
level level: Command level, which ranges from 0 to 3.
view view: Specifies a view.
command: Command to be set in the specified view.
Use the command-privilege command to assign a level for a specific command in a view.
Use the undo command-privilege command to restore the default.
By default, each command in a view has a specified level.
Command levels include four privileges: visit (0), monitor (1), system (2), and manage (3). You can assign a privilege level according to the user’s need. When logging in to the switch, the user can access the assigned level and all levels below it.
Level changes can cause maintenance, operation, and security problem. H3C recommends that you use the default command level or modify the command level under the guidance of professional staff.
The command specified in the command-privilege command must be complete, and has valid arguments. For example, the default level of the tftp server-address { get | put | sget } source-filename [ destination-filename ] [ source { interface interface-type interface-number | ip source-ip-address } ] command is 3. After the command-privilege level 0 view shell tftp 1.1.1.1 put a.cfg command is executed, when users with the user privilege level of 0 log in to the switch, they can execute the tftp server-address put source-filename command (such as the tftp 192.168.1.26 put syslog.txt command), but cannot execute the command with the get, sget or source keyword, and cannot specify the destination-filename argument.
The command specified in the undo command-privilege view command can be incomplete. For example, after the undo command-privilege view system ftp command is executed, all commands starting with the keyword ftp (such as ftp server acl, ftp server enable, and ftp timeout) are restored to their default level. If you have modified the level of commands ftp server enable and ftp timeout, and you want to restore only the ftp server enable command to its default level, you should use the undo command-privilege view system ftp server command.
If you modify the command level of a command in a specified view from the default command level to a lower level, remember to modify the command levels of the quit command and the command used to enter this view. For example, the default command level of commands interface and system-view is 2 (system level). If you want to make the interface command available to the level 1 users, execute the following three commands: command-privilege level 1 view shell system-view, command-privilege level 1 view system interface gigabitethernet 3/0/1, and command-privilege level 1 view system quit. Then, the level 1 users can enter system view, execute the interface gigabitethernet command, and return to user view.
# Set the command level of the interface command to 0 in system view.
[Sysname] command-privilege level 0 view system interface
display clipboard
display clipboard [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display clipboard command to view the contents of the clipboard.
To copy the specified content to the clipboard:
1. Move the cursor to the starting position of the content and press the Esc+Shift+, combination.
2. Move the cursor to the ending position of the content and press the Esc+Shift+. combination.
# View the content of the clipboard.
<Sysname> display clipboard
---------------- CLIPBOARD-----------------
display current-configuration
display command-alias
display command-alias [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display command-alias command to display configuration information about the command keyword alias function.
# Display configuration information about the command keyword alias function.
<Sysname> display command-alias
Command alias is enabled
index alias command key
1 show display
display history-command
display history-command [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display history-command command to display commands saved in the command history buffer.
By default, the system can save up to 10 commands in the buffer. You can use the history-command max-size command to change the buffer size.
# Display all commands saved in the command history buffer.
<Sysname> display history-command
vlan 2
display hotkey
display hotkey [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display hotkey command to display hotkey information.
# Display hotkey information.
<Sysname> display hotkey
----------------- HOTKEY -----------------
=Defined hotkeys=
Hotkeys Command
CTRL_G display current-configuration
CTRL_L display ip routing-table
CTRL_O undo debug all
=Undefined hotkeys=
Hotkeys Command
CTRL_T NULL
CTRL_U NULL
=System hotkeys=
Hotkeys Function
CTRL_A Move the cursor to the beginning of the current line.
CTRL_B Move the cursor one character left.
CTRL_C Stop current command function.
CTRL_D Erase current character.
CTRL_E Move the cursor to the end of the current line.
CTRL_F Move the cursor one character right.
CTRL_H Erase the character left of the cursor.
CTRL_K Kill outgoing connection.
CTRL_N Display the next command from the history buffer.
CTRL_P Display the previous command from the history buffer.
CTRL_R Redisplay the current line.
CTRL_V Paste text from the clipboard.
CTRL_W Delete the word left of the cursor.
CTRL_X Delete all characters up to the cursor.
CTRL_Y Delete all characters after the cursor.
CTRL_Z Return to the User View.
CTRL_] Kill incoming connection or redirect connection.
ESC_B Move the cursor one word back.
ESC_D Delete remainder of word.
ESC_F Move the cursor forward one word.
ESC_N Move the cursor down a line.
ESC_P Move the cursor up a line.
ESC_< Specify the beginning of clipboard.
ESC_> Specify the end of clipboard.
hotkey
hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U } command
undo hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U }
View
Default level
2: System level
CTRL_G: Assigns a command to Ctrl+G.
CTRL_L: Assigns a command to Ctrl+L.
CTRL_O: Assigns a command to Ctrl+O.
CTRL_T: Assigns a command to Ctrl+T.
CTRL_U: Assigns a command to Ctrl+U.
command: Command to be assigned to the hotkey.
Use the hotkey command to assign a command to a configurable hotkey.
Use the undo hotkey command to restore the default.
The defaults are as follows:
· Ctrl_G: display current-configuration (display the running configuration)
· Ctrl_L: display ip routing-table (display the IPv4 routing table information)
· Ctrl_O: undo debugging all (disable all debugging functions)
· Ctrl_T: No command is assigned to this hotkey.
· Ctrl_U: No command is assigned to this hotkey.
# Assign the display tcp status command to the hotkey Ctrl+T.
[Sysname] hotkey ctrl_t display tcp status
View
Default level
0: Visit level (executed in user view)
2: System level (executed in other views)
Use the quit command to return to the upper-level view.
In user view, the quit command disconnects you from the switch.
# Return from GigabitEthernet 3/0/18 interface view to system view and then to user view.
[Sysname-GigabitEthernet3/0/18] quit
[Sysname] quit
<Sysname>
return
return
View
Any view except user view
Default level
2: System level
Use the return command to return to user view from any other view. Pressing Ctrl+Z has the same effect.
Related commands: quit.
# Return to user view from GigabitEthernet 3/0/18 interface view.
[Sysname-GigabitEthernet3/0/18] return
<Sysname>
screen-length disable
undo screen-length disable
View
Default level
1: Monitor level
Use the screen-length disable command to disable pausing between screens of output for the current session.
Use the undo screen-length disable command to enable pausing between screens of output for the current session.
By default, a login user uses the settings of the screen-length command. The default settings of the screen-length command are: pausing between screens of output and displaying up to 24 lines on a screen.
Disabling pausing between screens of output prevents you from viewing the information in time because the information refreshes continuously.
This command only takes effect for the current session. When you log out, the setting by this command is restored to the default.
Related commands: screen-length.
# Disable pausing between screens of output for the current session.
<Sysname> screen-length disable
super
super [ level ]
View
Default level
0: Visit level
level: User level, which ranges from 0 to 3 and defaults to 3.
Use the super command to switch from the current user privilege level to a specified user privilege level.
If a level is not specified, the command switches the user privilege level to 3.
There are four user privilege levels: visit (0), monitor (1), system (2), and manage (3). You can assign different privilege levels to different users. After login, a user can access the commands that are at or under the assigned level.
A user can switch to a lower privilege level unconditionally. To switch to a higher privilege level, a console user does not need to provide any password, but a AUX or VTY user must enter the switching password set with the super password command. If the entered password is incorrect or no password is configured for switching to the level, the switching operation fails.
Related commands: super password and super authentication-mode.
# Switch to user privilege level 2 from user privilege level 3.
<Sysname> super 2
User privilege level is 2, and only those commands can be used
whose level is equal or less than this.
Privilege note: 0-VISIT, 1-MONITOR, 2-SYSTEM, 3-MANAGE
# Switch back to user privilege level 3 (suppose that the switching password is 123. If no password is set, users cannot switch to user privilege level 3).
<Sysname> super 3
Password:
User privilege level is 3, and only those commands can be used
super authentication-mode { local | scheme } *
undo super authentication-mode
View
Default level
2: System level
local: Authenticates a user by using the local password set with the super password command. When no password is set with the super password command, two results can occur: The privilege level switching succeeds if the user is logged in through the console port or the AUX port used as the console port. The switching fails if the user logs in through any of the AUX or VTY user interfaces or enters an incorrect switching password.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
local scheme: Authenticates a user by using the local password first. If no password is set for the user logged in through the console port, the privilege level switching succeeds. If no password is set for the user logged in through any of the AUX, or VTY user interfaces, the AAA authentication is performed.
scheme local: Performs AAA authentication first. If the AAA configuration is invalid (the domain parameters or authentication scheme is not configured) or the server does not respond, the local password authentication is performed.
Use the super authentication-mode command to set the authentication mode for user privilege level switching.
Use the undo super authentication-mode command to restore the default.
By default, the authentication mode for the user privilege level switching is local.
Related commands: super password.
# Set the authentication mode for the user privilege level switching to local.
[Sysname] super authentication-mode local
# Set the authentication mode for the user privilege level switching to scheme local.
[Sysname] super authentication-mode scheme local
super password
super password [ level user-level ] { cipher | simple } password
undo super password [ level user-level ]
View
Default level
2: System level
level user-level: User privilege level, which ranges from 1 to 3 and defaults to 3.
cipher: Displays the password in cipher text.
simple: Displays the password in plain text.
password: Password used for user privilege level switching, case sensitive. It must be in plain text if you specify the simple keyword and can be in plain or cipher text if you specify the cipher keyword. A password in plain text must be a string of 1 to 16 characters. A password in cipher text must be a string of 24 characters. For example, if you specify the cipher keyword, you can enter the plaintext string 1234567 or ciphertext string _(TT8F]Y\5SQ=^Q`MAF4<1!! to achieve the same effect.
Use the super password command to set the password used to switch from the current user privilege level to a higher one.
Use the undo super password command to restore the default.
By default, no password is set for switching to a higher privilege level.
For security, specify the cipher keyword.
During authentication, a user must enter the password in plain text, regardless of the password type you set.
# Use the password abc in plain text to authenticate a user switching to privilege level 3.
[Sysname] super password level 3 simple abc
# Display the configured level switching password.
[Sysname] display current-configuration
# Use the password abc in cipher text to authenticate a user switching to privilege level 3.
[Sysname] super password level 3 cipher abc
[Sysname] display current-configuration | include super
super password level 3 cipher ;)<01%^&;YGQ=^Q`MAF4<1!!
View
Default level
2: System level
Use the system-view command to enter system view from user view.
Related commands: quit and return.
# Enter system view from user view.
[Sysname]
