| 05-Port Security Commands | 101.11 KB |
Table of Contents
1 Port Security Configuration Commands
display port-security mac-address block
display port-security mac-address security
display port-security preshared-key user
port-security authorization ignore
port-security timer disableport
port-security tx-key-type 11key
l The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l Support of the H3C WA series WLAN access points for features may vary by device model. For more information, see Feature Matrix.
l The interface types and numbers supported by the H3C WA series WLAN access points vary by device model. In the H3C WA series, some access points support GigabitEthernet interfaces while some support only Ethernet interfaces. Throughout this document, Ethernet interfaces are used for example.
display port-security [ interface interface-list ]
View
Default Level
2: System level
interface-list: Ethernet port list, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> means that you can specify up to 10 port or port ranges. The starting port and ending port of a port range must be of the same type and the ending port number must be greater than the starting port number.
Use the display port-security command to display port security configuration information, operation information, and statistics about one or more ports.
If no interface list is specified, the command displays port security configuration information, operation information, and statistics about all ports.
Related commands: port-security enable, port-security port-mode, port-security ntk-mode, port-security intrusion-mode, port-security max-mac-count, port-security authorization ignore, port-security oui, and port-security trap.
# Display port security configuration information, operation information, and statistics about all ports.
<Sysname> display port-security
Equipment port-security is enabled
AddressLearn trap is enabled
Intrusion trap is enabled
Dot1x logon trap is enabled
Dot1x logoff trap is enabled
Dot1x logfailure trap is enabled
RALM logon trap is enabled
RALM logoff trap is enabled
RALM logfailure trap is enabled
Disableport Timeout: 20s
OUI value:
Index is 1, OUI value is 000d1a
Index is 2, OUI value is 003c12
Ethernet1/0/1 is link-down
Port mode is UserloginWithOUI
NeedtoKnow mode is NeedToKnowOnly
Intrusion Portection is DisablePort
Max MAC address number is 50
Stored MAC address number is 0
Authorization is ignored
Ethernet1/0/2 is link-down
Port mode is noRestriction
NeedtoKnow mode is disabled
Intrusion mode is NoAction
Max MAC address number is not configured
Authorization is permitted
WLAN-BSS5 is link-down
Port mode is macAddressWithRadius
NeedToKnow mode is disabled
Intrusion Protection mode is NoAction
Table 1-1 display port-security command output description
Equipment port-security |
Whether port security is enabled or not. |
AddressLearn trap |
Whether address learning trap is enabled or not. If it is enabled, the port sends trap information after it learns a new MAC address. |
Intrusion trap |
Whether trapping for intrusion protection is enabled or not. If it is enabled, the port sends trap information after it detects illegal packets. |
Dot1x logon trap |
Whether trapping for 802.1X logon is enabled or not. If it is enabled, the port sends trap information after a user passes 802.1X authentication. |
Dot1x logoff trap |
Whether trapping for 802.1X logoff is enabled or not. If it is enabled, the port sends trap information after an 802.1X user logs off. |
Dot1x logfailure |
Whether trapping for 802.1X authentication failure is enabled or not. If it is enabled, the port sends trap information after a user fails the 802.1X authentication. |
RALM logon trap |
Whether trapping for MAC authentication success is enabled or not. If it is enabled, the port sends trap information when a user passes MAC address authentication. |
RALM logoff trap |
Whether trapping for MAC authenticated user logoff is enabled or not. If it is enabled, traps are sent when a MAC address authenticated user logs off. |
RALM logfailure trap |
Whether trapping for MAC authentication failure is enabled or not. If it is enabled, the port sends trap information when a user fails MAC address authentication. |
Disableport Timeout |
Silence timeout of the port that receives illegal packets, in seconds. |
OUI value |
List of OUI values allowed |
Index |
OUI index |
Port mode |
Port security mode, which can be: l macAddressWithRadius l macAddressElseUserLoginSecure l macAddressElseUserLoginSecureExt l secure l userLogin l userLoginSecure l userLoginSecureExt l macAddressOrUserLoginSecure l macAddressOrUserLoginSecureExt l userLoginWithOUI l presharedKey l macAddressAndPresharedKey l userLoginSecureExtOrPresharedKey |
NeedtoKnow mode |
Need to know (NTK) mode, which can be: l NeedToKnowOnly: Allows only unicasts with authenticated destination MAC addresses. l NeedToKnowWithBroadcast: Allows only unicasts and broadcasts with authenticated destination MAC addresses. l NeedToKnowWithMulticast: Allows unicasts, multicasts and broadcasts with authenticated destination MAC addresses. |
Intrusion mode |
Intrusion protection action mode, which can be: l BlockMacAddress: Adds the source MAC address of the illegal packet to the blocked MAC address list. l DisablePort: Shuts down the port that receives illegal packets permanently. l DisablePortTemporarily: Shuts down the port that receives illegal packets for some time. l NoAction: Performs no intrusion protection. |
Max MAC address number |
Maximum number of secure MAC addresses allowed on the port |
Stored MAC address number |
Number of secure MAC addresses stored |
Authorization |
Whether the authorization information from the server is ignored or not: l permitted: Authorization information from the RADIUS server takes effect. l ignored: Authorization information from the RADIUS server does not take effect. |
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
View
Default Level
2: System level
interface interface-type interface-number: Specifies a port by its type and number.
vlan vlan-id: Specifies a VLAN by its ID, which ranges from 1 to 4094.
count: Displays only the count of the blocked MAC addresses.
Use the display port-security mac-address block command to display information about blocked MAC addresses.
With no keyword or argument specified, the command displays information about all blocked MAC addresses.
Related commands: port-security intrusion-mode.
# Display information about all blocked MAC addresses.
<Sysname> display port-security mac-address block
MAC ADDR From Port VLAN ID
0002-0002-0002 Ethernet1/0/1 1
000d-88f8-0577 Ethernet1/0/1 1
--- 2 mac address(es) found ---
# Display the count of all blocked MAC addresses.
<Sysname> display port-security mac-address block count
# Display information about all blocked MAC addresses in VLAN 1.
<Sysname> display port-security mac-address block vlan 1
# Display information about all blocked MAC addresses of port Ethernet 1/0/1.
<Sysname> display port-security mac-address block interface ethernet1/0/1
--- 1 mac address(es) found ---
# Display information about all blocked MAC addresses of port Ethernet 1/0/1 in VLAN 1.
<Sysname> display port-security mac-address block interface ethernet 1/0/1 vlan 1
Table 1-2 display port-security mac-address block command output description
MAC ADDR |
Blocked MAC address |
From Port |
Port having received frames with the blocked MAC address |
VLAN ID |
ID of the VLAN to which the port belongs |
2 mac address(es) found |
Number of blocked MAC addresses |
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
View
Default Level
2: System level
count: Displays only the count of the secure MAC addresses.
Use the display port-security mac-address security command to display information about secure MAC addresses. Secure MAC addresses are those that are automatically learned by the port in autoLearn mode.
With no keyword or argument specified, the command displays information about all secure MAC addresses.
# Display information about all secure MAC addresses.
MAC ADDR VLAN ID STATE PORT INDEX AGING TIME(s)
0002-0002-0002 1 Security Ethernet1/0/1 NOAGED
000d-88f8-0577 1 Security Ethernet1/0/1 NOAGED
# Display only the count of the secure MAC addresses.
<Sysname> display port-security mac-address security count
# Display information about secure MAC addresses in the specified VLAN.
<Sysname> display port-security mac-address security vlan 1
# Display information about secure MAC addresses on the specified port.
<Sysname> display port-security mac-address security interface ethernet1/0/1
# Display information about secure MAC addresses that are on the specified port and in the specified VLAN.
<Sysname> display port-security mac-address security interface ethernet 1/0/1 vlan 1
Table 1-3 display port-security mac-address command output description
MAC ADDR |
Secure MAC address |
VLAN ID |
STATE |
Type of the MAC address added. "Security" means it is a secure MAC address. |
PORT INDEX |
Port to which the secure MAC address belongs |
AGING TIME(s) |
Period of time before the secure MAC address ages out. "NOAGED" means do not age out the secure MAC address. |
1 max address(es) found |
display port-security preshared-key user [ interface interface-type interface-number ]
View
Default Level
2: System level
Use the display port-security preshared-key user command to display information about pre-shared key (PSK) users on the specified or all PSK users.
If no interface is specified, the command displays information about all PSK users on all ports.
The display port-security preshared-key user command applies to only WLAN-BSS ports.
# Display information about all PSK users on all ports.
<Sysname> display port-security preshared-key user
Index Mac-Address VlanID Interface
0 0000-1122-3344 1 WLAN-BSS 1
1 0000-1133-2244 2 WLAN-BSS 2
# Display information about PSK users on WLAN port WLAN-BSS1.
<Sysname> display port-security preshared-key user interface WLAN-BSS 1
Table 1-4 display port-security preshared-key user command output description
Index |
Index of the user |
Mac-Address |
MAC address of the user |
VlanID |
VLAN ID of the user |
Port that the user accesses |
undo port-security authorization ignore
View
Layer 2 Ethernet interface view, WLAN-BSS interface view
Default Level
2: System level
None
Use the port-security authorization ignore command to configure a port to ignore the authorization information from the RADIUS server.
Use the undo port-security port-mode ignore command to restore the default.
After a user passes RADIUS authentication, the RADIUS server performs authorization based on the authorization attributes configured for the user’s account. For example, it may assign a VLAN.
Related commands: display port-security.
# Configure port Ethernet 1/0/1 to ignore the authorization information from the RADIUS server.
[Sysname-Ethernet1/0/1] port-security authorization ignore
undo port-security enable
View
Default Level
2: System level
None
Use the port-security enable command to enable port security.
Use the undo port-security enable command to disable port security.
By default, port security is enabled.
Note that:
1) You cannot enable port security when 802.1X or MAC authentication is globally enabled.
2) Enabling port security resets the following configurations on a port to the defaults bracketed, making them dependent completely on the port security mode:
l 802.1X (disabled), port access control method (macbased), and port authorization mode (auto)
l MAC authentication (disabled)
3) Disabling port security resets the following configurations on a port to the defaults bracketed:
l Port security mode (noRestrictions)
4) Port security cannot be disabled if there is any user present on a port.
Related commands: display port-security (Port Security in the Security Command Reference); dot1x, dot1x port-method, and dot1x port-control (802.1X in the Security Command Reference); mac-authentication (MAC Authentication in the Security Command Reference).
# Enable port security.
[Sysname] port-security enable
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
undo port-security intrusion-mode
View
Default Level
2: System level
blockmac: Adds the source MAC addresses of illegal frames to the blocked MAC address list and discards frames with blocked source MAC addresses. This implements illegal traffic filtering on the port. A blocked MAC address is restored to normal after being blocked for three minutes, which is fixed and cannot be changed. You can use the display port-security mac-address block command to view the blocked MAC address list.
disableport: Disables the port permanently upon detecting an illegal frame received on the port. The disableport keyword is not supported on the WLAN-BSS port.
disableport-temporarily: Disables the port for a specified period of time whenever it receives an illegal frame. Use the port-security timer disableport command to set the period.
Use the port-security intrusion-mode command to configure the intrusion protection feature so that the port takes the pre-defined actions when intrusion protection is triggered on the port.
Use the undo port-security intrusion-mode command to restore the default.
By default, intrusion protection is disabled.
You can use the undo shutdown command to restore the connection of the port.
Related commands: display port-security, display port-security mac-address block, and port-security timer disableport.
# Configure port Ethernet 1/0/1 to block the source MAC addresses of illegal frames after intrusion protection is triggered.
[Sysname-Ethernet1/0/1] port-security intrusion-mode blockmac
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
undo port-security ntk-mode
View
Default Level
2: System level
ntk-withbroadcasts: Forwards only broadcast frames and unicast frames with authenticated destination MAC addresses.
ntk-withmulticasts: Forwards only broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses.
ntkonly: Forwards only unicast frames with authenticated destination MAC addresses.
Use the port-security ntk-mode command to configure the NTK feature. The need to know (NTK) feature checks the destination MAC addresses in outbound frames to allow frames to be sent to only devices passing authentication, thus preventing illegal devices from intercepting network traffic.
Use the undo port-security ntk-mode command to restore the default.
Be default, NTK is disabled on a port and all frames are allowed to be sent.
On a wireless port with users online, you cannot change the configuration of the NTK feature.
# Set the NTK mode of port Ethernet 1/0/1 to ntkonly, allowing the port to forward received packets to only devices passing authentication.
[Sysname-Ethernet1/0/1] port-security ntk-mode ntkonly
port-security oui
port-security oui oui-value index index-value
undo port-security oui index index-value
View
Default Level
2: System level
oui-value: Organizationally unique identifier (OUI) string, a 48-bit MAC address in the H-H-H format. The system automatically uses only the 24 high-order bits as the OUI value.
index-value: OUI index, in the range 1 to 16.
Use the port-security oui command to configure an OUI value for user authentication. This value is used when the port security mode is UserLoginWithOUI.
Use the undo port-security oui command to delete an OUI value with the specified OUI index.
By default, no OUI value is configured.
An OUI (Organizational Unique Identifier), the first 24 binary bits of a MAC address, is assigned by IEEE to uniquely identify a device vendor. Use this command when you need to configure an AP to allow packets from certain wired devices to pass authentication or to allow packets from certain wireless devices to initiate authentication. For example, when a company allows only IP phones of vendor A in the Intranet, use this command to set the OUI of vendor A.
Note that an OUI value configured by using the port-security oui command takes effect only when the security mode is userLoginWithOUI.
# Configure an OUI value of 000d2a, setting the index to 4.
[Sysname] port-security oui 000d-2a10-0033 index 4
port-security port-mode { mac-and-psk | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | psk | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-ext-or-psk | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
View
Interface view
Default Level
2: System level
See the following for details about the keywords of port security modes:
Keyword |
Security mode |
mac-and-psk |
macAddressAnd PresharedKey |
In this mode, a user must pass MAC authentication and then use the PSK to negotiate with the device. Only when the negotiation succeeds, can the user access the device. |
macAddressWithRadius |
In this mode, a port performs MAC authentication and services multiple users. |
macAddressElseUserLoginSecure |
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority. l Upon receiving a non-802.1X frame, a port in this mode performs only MAC authentication. l Upon receiving an 802.1X frame, the port performs MAC authentication and then, if MAC authentication fails, 802.1X authentication. |
macAddressElseUserLoginSecureExt |
Similar to the macAddressElseUserLoginSecure mode except that a port in this mode supports multiple 802.1X and MAC authentication users. |
psk |
presharedKey |
In this mode, a user must use a pre-configured static key, namely the PSK, to negotiate with the device and can access the port only after the negotiation succeeds. |
secure |
secure |
In this mode, MAC address learning is disabled on the port and you can configure MAC addresses by using the mac-address static and mac-address dynamic commands. The port permits only frames sourced from secure MAC addresses and MAC addresses you manually configured by using the mac-address static and mac-address dynamic commands. |
userlogin |
userLogin |
In this mode, a port performs 802.1X authentication and implements port-based access control. If one 802.1X user passes authentication, all the other 802.1X users of the port can access the network without authentication. |
userlogin-secure |
userLoginSecure |
In this mode, a port performs 802.1X authentication and implements port-based access control. It services only one user passing 802.1X authentication. |
userLoginSecureExt |
In this mode, a port performs 802.1X authentication and implements MAC-based access control. It supports multiple online 802.1X users. |
In this mode, a user interacts with the device, choosing to undergo UserLoginSecure mode or PSK negotiation. |
macAddressOrUserLoginSecure |
This mode is the combination of the userLoginSecure and macAddressWithRadius modes. l For wired users, the port performs MAC authentication upon receiving non-802.1X frames and performs 802.1X authentication upon receiving 802.1X frames. l For wireless users, the port performs 802.1X authentication first. If 802.1X authentication fails, MAC authentication is performed. |
macAddressOrUserLoginSecureExt |
Similar to the macAddressOrUserLoginSecure mode except that a port in this mode supports multiple 802.1X and MAC authentication users. |
userlogin-withoui |
userLoginWithOUI |
Similar to the userLoginSecure mode. a The difference is that a port in this mode also permits frames from one user whose MAC address contains a specified OUI (organizationally unique identifier). l For wired users, the port performs 802.1X authentication upon receiving 802.1X frames, and performs OUI check upon receiving non-802.1X frames. l For wireless users, the port performs OUI check at first. If the OUI check fails, the port performs 802.1X authentication. |
Use the port-security port-mode command to set the port security mode of a port.
Use the undo port-security port-mode command to restore the default.
By default, a port operates in noRestrictions mode, where port security does not take effect.
Note that:
l The presharedKey, macAddressAndPresharedKey, and userlLoginSecureExtOrPresharedKey modes apply to only WLAN-ESS and WLAN-Ethernet ports.
l The secure, userLogin, and userLoginWithOUI modes apply to only Layer 2 Ethernet ports.
Table 1-5 Port security modes supported by different types of ports
Port type |
Supported security modes |
Layer 2 Ethernet port |
mac-authentication, mac-else-userlogin-secure, mac-else-userlogin-secure-ext, secure, userlogin, userlogin-secure, userlogin-secure-ext, userlogin-secure-or-mac, userlogin-secure-or-mac-ext, userlogin-withoui |
WLAN-BSS port |
mac-and-psk, mac-authentication, mac-else-userlogin-secure, mac-else-userlogin-secure-ext, psk, userlogin-secure, userlogin-secure-ext, userlogin-secure-ext-or-psk, userlogin-secure-or-mac, userlogin-secure-or-mac-ext |
l Configuration of port security mode on a port is mutually exclusive with the configuration of 802.1X authentication, port access control method, port access control mode, and MAC authentication on the port.
l With port security enabled, you can change the port security mode of a port only when the port is operating in noRestrictions mode, the default mode. You can use the undo port-security port-mode command to restore the default port security mode.
l You cannot change the port security mode of a port with users online.
# Enable port security and configure the port security mode of port Ethernet 1/0/1 as secure.
[Sysname-Ethernet1/0/1] port-security port-mode secure
# Change the port security mode of port Ethernet 1/0/1 to userLogin.
[Sysname-Ethernet1/0/1] undo port-security port-mode
[Sysname-Ethernet1/0/1] port-security port-mode userlogin
# Configure the port security mode of WLAN port WLAN-BSS1 as userLogin-secure.
[Sysname] interface wlan-bss 1
[Sysname-WLAN-BSS1] port-security port-mode userLogin-secure
port-security pre-shared-key
port-security preshared-key { pass-phrase | raw-key } [ cipher | simple] key
undo port-security preshared-key
View
Default Level
2: System level
pass-phrase: Enters a PSK in the form of a character string.
raw-key: Enters a PSK in the form of a hexadecimal number.
cipher: Displays the PSK in cipher text.
simple: Displays the PSK in plain text.
key: PSK, a string of 8 to 63 displayable characters or a hexadecimal number of the length of 64.
Use the port-security preshared-key command to configure a PSK.
Use the undo port-security preshared-key command to remove the PSK.
By default, no PSK is configured.
# Configure a PSK of abcdefgh on port WLAN-BSS1.
[Sysname-WLAN-BSS1] port-security preshared-key pass-phrase abcdefgh
# Configure a PSK of 123456789abcdefg123456789abcdefg123456789abcdefg1234 56789abcdefg on port WLAN-BSS1.
[Sysname-WLAN-BSS1] port-security preshared-key raw-key 123456789abcdefg123456789abcdefg123456789abcdefg123456789abcdefg
port-security timer disableport time-value
undo port-security timer disableport
View
Default Level
2: System level
time-value: Silence timeout during which the port remains disabled, in seconds. It ranges from 20 to 300.
Use the port-security timer disableport command to set the silence timeout during which the port remains disabled.
Use the undo port-security timer disableport command to restore the default.
By default, the silence timeout is 20 seconds.
If you configure the intrusion protection policy as disabling the port temporarily whenever it receives an illegal frame, you can use this command to set the silence timeout.
# Configure the intrusion protection policy as disabling the port temporarily whenever it receives an illegal frame and set the silence timeout to 30 seconds.
[Sysname] port-security timer disableport 30
[Sysname-Ethernet1/0/1] port-security intrusion-mode disableport-temporarily
port-security trap
port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
undo port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
View
Default Level
2: System level
addresslearned: Trapping for learning of new MAC addresses. When enabled, this function allows the AP to send trap information when a port learns a new MAC address.
dot1xlogfailure: Trapping for 802.1X authentication failure.
dot1xlogon: Trapping for successful 802.1X authentication.
dot1xlogoff: Trapping for 802.1X user logoff events.
intrusion: Trapping for detection of illegal frames.
ralmlogfailure: Trapping for MAC authentication failure.
ralmlogoff: Trapping for MAC authentication user logoff events.
ralmlogon: Trapping for successful MAC authentication.
RALM (RADIUS Authenticated Login using MAC-address) means RADIUS authentication based on MAC address.
Use the port-security trap command to enable trapping for port security.
Use the undo port-security trap command to disable trapping for port security.
By default, trapping for port security is disabled.
With the trapping feature, an AP can send traps upon detecting frames that result from, for example, intrusion, abnormal login/logout operations, allowing you to monitor user behaviors.
# Enable address learning trap.
[Sysname] port-security trap addresslearned
undo port-security tx-key-type
View
Default Level
2: System level
None
Use the port-security tx-key-type command to enable key negotiation of the 11key type.
Use the undo port-security tx-key-type command to disable key negotiation of the 11key type.
Be default, key negotiation of the 11key type is disabled.
# Enable key negotiation of the 11key type on port WLAN-BSS1.
[Sysname-WLAN-BSS1] port-security tx-key-type 11key
