| 02-IP Routing Basics Commands | 42.15 KB |
1 IP Routing Basics Configuration Commands
display ipv6 routing-table verbose
l The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l Support of the H3C WA series WLAN access points (APs) for commands may vary by AP model. For more information, see Feature Matrix.
l The interface types and the number of interfaces vary by AP model.
l The term router in this document refers to both routers and APs configured with routing capabilities.
l Support for IPv6 depends on the AP model.
display ip routing-table
display ip routing-table [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays detailed routing table information, including that for inactive routes. With this keyword absent, the command displays only summary information about active routes.
Use the display ip routing-table command to display brief information about active routes in the routing table.
This command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, preference, cost, next hop and outbound interface. This command only displays the routes currently in use, that is, the optimal routes.
Use the display ip routing-table verbose command to display detailed information about all routes in the routing table.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
Destinations : 3 Routes : 3
192.168.0.0/24 Static 60 0 0.0.0.0 NULL0
Table 1-1 display ip routing-table command output description
Destinations |
Number of destination addresses |
Routes |
Number of routes |
Destination/Mask |
Destination address/mask length |
Proto |
Protocol that presents the route |
Pre |
Priority of the route |
Cost |
Cost of the route |
Nexthop |
Address of the next hop on the route |
Outbound interface for packets to be forwarded along the route |
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Table : Public
Destinations : 5 Routes : 5
Destination: 0.0.0.0/0
Protocol: Static Process ID: 0
Preference: 60 Cost: 0
NextHop: 1.1.4.2 Interface:
BkNexthop: 0.0.0.0 BkInterface:
RelyNextHop: 0.0.0.0 Neighbor : 0.0.0.0
Tunnel ID: 0x0 Label: NULL
State: Inactive Adv WaitQ Age: 05h37m52s
Tag: 0
Destination: 1.1.1.0/24
NextHop: 2.2.2.2 Interface:
State: Inactive Adv WaitQ Age: 05h04m52s
Tag: 0
Destination: 127.0.0.0/8
Protocol: Direct Process ID: 0
Preference: 0 Cost: 0
NextHop: 127.0.0.1 Interface: InLoopBack0
State: Active NoAdv Age: 1d19h42m41s
Tag: 0
Destination: 127.0.0.1/32
State: Active NoAdv Age: 1d19h42m43s
Tag: 0
Destination: 192.168.0.0/24
NextHop: 0.0.0.0 Interface: NULL0
State: Active Adv Age: 00h00m33s
Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Table 1-2 display ip routing-table verbose command output description
Destination |
Protocol |
Process ID |
Process ID |
Preference |
Cost |
Cost of the route |
NextHop |
BkNexthop |
Address of the backup next hop |
BkInterface |
Backup interface |
RelyNextHop |
The next hop address obtained through routing stack. |
Neighbour |
Neighboring address determined by Routing Protocol |
Tunnel ID |
Tunnel ID |
Label |
Label |
State |
Route status: |
Active |
This is an active unicast route. |
Adv |
This route can be advertised. |
Delete |
This route is deleted. |
Gateway |
This is an indirect route. |
Holddown |
Number of holddown routes. Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For details, refer to corresponding routing protocols. |
Int |
The route was discovered by an Interior Gateway Protocol (IGP). |
NoAdv |
The route is not advertised when the router advertises routes based on policies. |
NotInstall |
Normally, among routes to a destination, the route with the highest preference is installed into the core routing table and advertised, while a NotInstall route cannot be installed into the core routing table but may be advertised. |
Reject |
The packets matching a Reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing. |
Static |
A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static. |
Unicast |
Unicast routes |
Inactive |
Inactive routes |
Invalid |
Invalid routes |
WaitQ |
The route is the WaitQ during route recursion. |
TunE |
Tunnel |
GotQ |
The route is in the GotQ during route recursion. |
Age |
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right. |
Tag |
Route tag |
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table command to display brief routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and outbound interface.
The command displays only active routes, namely, the brief information about the current optimal routes.
# Display brief routing table information
<Sysname> display ipv6 routing-table
Routing Table :
Destinations : 1 Routes : 1
Destination : ::1/128 Protocol : Direct
NextHop : ::1 Preference : 0
Interface : InLoop0 Cost : 0
Table 1-3 display ipv6 routing-table command output description
Destination |
IPv6 address of the destination network/host |
NextHop |
Nexthop address |
Preference |
Route preference |
Outbound interface |
Protocol |
Routing protocol |
Cost |
Route cost |
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table verbose command to display detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display detailed information about all active and inactive routes.
<Sysname> display ipv6 routing-table verbose
Destination : ::1 PrefixLength : 128
Interface : InLoopBack0 Protocol : Direct
State : Active Cost : 0
Age : 21659sec
Table 1-4 display ipv6 routing-table verbose command output description
Destination |
Destination IPv6 address |
PrefixLength |
Prefix length of the address |
Nexthop |
Next hop |
Preference |
Routing preference |
Protocol |
Routing protocol |
State |
State of the route, Active, Inactive, Adv (advertised), or NoAdv (not advertised) |
Cost |
Cost of the route |
Age |
Time that has elapsed since the route was generated |
