Security Configuration Guide
HomeSupportWirelessWA2200 Series WLAN Access PointsConfigure & DeployConfiguration GuidesH3C WA Series WLAN Access Points Configuration Guide-6W100Security Configuration Guide
06-PKI Configuration
06-PKI Configuration 140.8 KB
l          Support of the H3C WA series WLAN access points (APs) for features may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
l          The term AP in this document refers to common APs, wireless bridges, and mesh APs.
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
1  PKI Configuration
This chapter includes these sections:
l          Introduction to PKI
l          PKI Configuration Task List
l          Displaying and Maintaining PKI
l          PKI Configuration Examples
l          Troubleshooting PKI
Introduction to PKI
This section covers these topics:
l          PKI Overview
l          PKI Terms
l          Architecture of PKI
l          Applications of PKI
l          Operation of PKI
PKI Overview
The Public Key Infrastructure (PKI) is a general security infrastructure for providing information security through public key technologies.
PKI, also called asymmetric key infrastructure, uses a key pair to encrypt and decrypt the data. The key pair consists of a private key and a public key. The private key must be kept secret while the public key needs to be distributed. Data encrypted by one of the two keys can only be decrypted by the other.
A key problem of PKI is how to manage the public keys. Currently, PKI employs the digital certificate mechanism to solve this problem. The digital certificate mechanism binds public keys to their owners, helping distribute public keys in large networks securely.
With digital certificates, the PKI system provides network communication and e-commerce with security services such as user authentication, data non-repudiation, data confidentiality, and data integrity.
Currently, H3C's PKI system provides certificate management for IP Security (IPsec) and Secure Sockets Layer (SSL).
PKI Terms
Digital certificate
A digital certificate is a file signed by a certificate authority (CA) for an entity. It includes mainly the identity information of the entity, the public key of the entity, the name and signature of the CA, and the validity period of the certificate, where the signature of the CA ensures the validity and authority of the certificate. A digital certificate must comply with the international standard of ITU-T X.509. Currently, the most common standard is X.509 v3.
This manual involves two types of certificates: local certificate and CA certificate. A local certificate is a digital certificate signed by a CA for an entity, while a CA certificate is the certificate of a CA. If multiple CAs are trusted by different users in a PKI system, the CAs will form a CA tree with the root CA at the top level. The root CA has a CA certificate signed by itself while each lower level CA has a CA certificate signed by the CA at the next higher level.
CRL
An existing certificate may need to be revoked when, for example, the user name changes, the private key leaks, or the user stops the business. Revoking a certificate is to remove the binding of the public key with the user identity information. In PKI, the revocation is made through certificate revocation lists (CRLs). Whenever a certificate is revoked, the CA publishes one or more CRLs to show all certificates that have been revoked. The CRLs contain the serial numbers of all revoked certificates and provide an effective way for checking the validity of certificates.
A CA may publish multiple CRLs when the number of revoked certificates is so large that publishing them in a single CRL may degrade network performance, and it uses CRL distribution points to indicate the URLs of these CRLs.
CA policy
A CA policy is a set of criteria that a CA follows in processing certificate requests, issuing and revoking certificates, and publishing CRLs. Usually, a CA advertises its policy in the form of certification practice statement (CPS). A CA policy can be acquired through out-of-band means such as phone, disk, and e-mail. As different CAs may use different methods to check the binding of a public key with an entity, make sure that you understand the CA policy before selecting a trusted CA for certificate request.
Architecture of PKI
A PKI system consists of entities, a CA, a registration authority (RA) and a PKI repository, as shown in Figure 1-1.
Figure 1-1 PKI architecture
Entity
An entity is an end user of PKI products or services, such as a person, an organization, a device like a router or a switch, or a process running on a computer.
CA
A CA is a trusted authority responsible for issuing and managing digital certificates. A CA issues certificates, specifies the validity periods of certificates, and revokes certificates as needed by publishing CRLs.
RA
A registration authority (RA) is an extended part of a CA or an independent authority. An RA can implement functions including identity authentication, CRL management, key pair generation and key pair backup. The PKI standard recommends that an independent RA be used for registration management to achieve higher security of application systems.
PKI repository
A PKI repository can be a Lightweight Directory Access Protocol (LDAP) server or a common database. It stores and manages information like certificate requests, certificates, keys, CRLs and logs while providing a simple query function.
LDAP is a protocol for accessing and managing PKI information. An LDAP server stores user information and digital certificates from the RA server and provides directory navigation service. From an LDAP server, an entity can retrieve local and CA certificates of its own as well as certificates of other entities.
Applications of PKI
The PKI technology can satisfy the security requirements of online transactions. As an infrastructure, PKI has a wide range of applications. Here are some application examples.
VPN
A virtual private network (VPN) is a private data communication network built on the public communication infrastructure. A VPN can leverage network layer security protocols (for instance, IPsec) in conjunction with PKI-based encryption and digital signature technologies for confidentiality.
Secure E-mail
E-mails require confidentiality, integrity, authentication, and non-repudiation. PKI can address these needs. The secure E-mail protocol that is currently developing rapidly is Secure/Multipurpose Internet Mail Extensions (S/MIME), which is based on PKI and allows for transfer of encrypted mails with signature.
Web security
For Web security, two peers can establish an SSL connection first for transparent and secure communications at the application layer. With PKI, SSL enables encrypted communications between a browser and a server. Both the communication parties can verify the identity of each other through digital certificates.
Operation of PKI
In a PKI-enabled network, an entity can request a local certificate from the CA and the AP can check the validity of certificates. Here is how it works:
1)        An entity submits a certificate request to the RA.
2)        The RA reviews the identity of the entity and then sends the identity information and the public key with a digital signature to the CA.
3)        The CA verifies the digital signature, approves the application, and issues a certificate.
4)        The RA receives the certificate from the CA, sends it to the LDAP server to provide directory navigation service, and notifies the entity that the certificate is successfully issued.
5)        The entity retrieves the certificate. With the certificate, the entity can communicate with other entities safely through encryption and digital signature.
6)        The entity makes a request to the CA when it needs to revoke its certificate, while the CA approves the request, updates the CRLs and publishes the CRLs on the LDAP server.
Complete the following tasks to configure PKI:
Remarks
Configuring an Entity DN
Required
Configuring a PKI Domain
Required
Submitting a PKI Certificate Request
Submitting a Certificate Request in Auto Mode
Required
Use either approach
Submitting a Certificate Request in Manual Mode
Retrieving a Certificate Manually
Optional
Configuring PKI Certificate
Optional
Destroying a Local RSA or ECDSA Key Pair
Optional
Deleting a Certificate
Optional
Configuring an Access Control Policy
Optional
A certificate is the binding of a public key and the identity information of an entity, where the identity information is identified by an entity distinguished name (DN). A CA identifies a certificate applicant uniquely by entity DN.
An entity DN is defined by these parameters:
l          Common name of the entity.
l          Country code of the entity, a standard 2-character code. For example, CN represents China and US represents the United States of America.
l          Fully qualified domain name (FQDN) of the entity, a unique identifier of an entity on the network. It consists of a host name and a domain name and can be resolved to an IP address. For example, www.whatever.com is an FQDN, where www is a host name and whatever.com a domain name.
l          IP address of the entity.
l          Locality where the entity resides.
l          Organization to which the entity belongs.
l          Unit of the entity in the organization.
l          State where the entity resides.
The configuration of an entity DN must comply with the CA certificate issue policy. You need to determine, for example, which entity DN parameters are mandatory and which are optional. Otherwise, certificate request may be rejected.
Follow these steps to configure an entity DN:
To do…
Use the command…
Remarks
Enter system view
Create an entity and enter its view
pki entity entity-name
Required
No entity exists by default.
Configure the common name for the entity
common-name name
Optional
No common name is specified by default.
Configure the country code for the entity
country country-code-str
Optional
No country code is specified by default.
Configure the FQDN for the entity
fqdn name-str
Optional
No FQDN is specified by default.
Configure the IP address for the entity
ip ip-address
Optional
No IP address is specified by default.
Configure the locality of the entity
locality locality-name
Optional
No locality is specified by default.
Configure the organization name for the entity
organization org-name
Optional
No organization is specified by default.
Configure the unit name for the entity
organization-unit org-unit-name
Optional
No unit is specified by default.
Configure the state or province for the entity
state state-name
Optional
No state or province is specified by default.
l          Currently, up to two entities can be created on an AP.
l          The Windows 2000 CA server has some restrictions on the data length of a certificate request. If the entity DN in a certificate request goes beyond a certain limit, the server will not respond to the certificate request.
Before requesting a PKI certificate, an entity needs to be configured with some enrollment information, which is referred to as a PKI domain. A PKI domain is intended only for convenience of reference by other applications like IKE and SSL, and has only local significance.
A PKI domain is defined by these parameters:
l          Trusted CA
An entity requests a certificate from a trusted CA.
l          Entity
A certificate applicant uses an entity to provide its identity information to a CA.
l          RA
Generally, an independent RA is in charge of certificate request management. It receives the registration request from an entity, checks its qualification, and determines whether to ask the CA to sign a digital certificate. The RA only checks the application qualification of an entity; it does not issue any certificate. Sometimes, the registration management function is provided by the CA, in which case no independent RA is required. You are recommended to deploy an independent RA.
l          URL of the registration server
An entity sends a certificate request to the registration server through Simple Certification Enrollment Protocol (SCEP), a dedicated protocol for an entity to communicate with a CA.
l          Polling interval and count
After an applicant makes a certificate request, the CA may need a long period of time if it verifies the certificate request manually. During this period, the applicant needs to query the status of the request periodically to get the certificate as soon as possible after the certificate is signed. You can configure the polling interval and count to query the request status.
l          IP address of the LDAP server
An LDAP server is usually deployed to store certificates and CRLs. If this is the case, you need to configure the IP address of the LDAP server.
l          Fingerprint for root certificate verification
Upon receiving the root certificate of the CA, an entity needs to verify the fingerprint of the root certificate, namely, the hash value of the root certificate content. This hash value is unique to every certificate. If the fingerprint of the root certificate does not match the one configured for the PKI domain, the entity will reject the root certificate.
Follow these steps to configure a PKI domain:
To do…
Use the command…
Remarks
Enter system view
Create a PKI domain and enter its view
pki domain domain-name
Required
No PKI domain exists by default.
Specify the trusted CA
ca identifier name
Required
No trusted CA is specified by default.
Specify the entity for certificate request
certificate request entity entity-name
Required
No entity is specified by default.
The specified entity must exist.
Specify the authority for certificate request
certificate request from { ca | ra }
Required
No authority is specified by default.
Configure the URL of the server for certificate request
certificate request url url-string
Required
No URL is configured by default.
Configure the polling interval and attempt limit for querying the certificate request status
certificate request polling { count count | interval minutes }
Optional
The polling is executed for up to 50 times at the interval of 20 minutes by default.
Specify the LDAP server
ldap-server ip ip-address [ port port-number ] [ version version-number ]
Optional
No LDP server is specified by default.
Configure the fingerprint for root certificate verification
root-certificate fingerprint { md5 | sha1 } string
Required when the certificate request mode is auto and optional when the certificate request mode is manual. In the latter case, if you do not configure this command, the fingerprint of the root certificate must be verified manually.
No fingerprint is configured by default.
Specify the certificate signature algorithm
signature-algorithm { ecdsa | rsa }
Optional
RSA by default
l          Currently, up to two PKI domains can be created on a device.
l          The CA name is required only when you retrieve a CA certificate. It is not used when in local certificate request.
l          Currently, the URL of the server for certificate request does not support domain name resolving.
When requesting a certificate, an entity introduces itself to the CA by providing its identity information and public key, which will be the major components of the certificate. A certificate request can be submitted to a CA in two ways: online and offline. In offline mode, a certificate request is submitted to a CA by an “out-of-band” means such as phone, disk, or e-mail.
Online certificate request falls into two categories: manual mode and auto mode.
In auto mode, an entity automatically requests a certificate through the SCEP protocol when it has no local certificate or the present certificate is about to expire.
Follow these steps to configure an entity to submit a certificate request in auto mode:
To do…
Use the command…
Remarks
Enter system view
Enter PKI domain view
Set the certificate request mode to auto
certificate request mode auto [ key-length key-length | password { cipher | simple } password ] *
Required
Manual by default
In manual mode, you need to retrieve a CA certificate, generate a local RSA key pair, and submit a local certificate request for an entity.
The goal of retrieving a CA certificate is to verify the authenticity and validity of a local certificate.
Generating an RSA key pair is an important step in certificate request. The key pair includes a public key and a private key. The private key is kept by the user, while the public key is transferred to the CA along with some other information. For more information about RSA and ECDSA key pair configuration, see Public Key in the Security Configuration Guide.
Follow these steps to submit a certificate request in manual mode:
To do…
Use the command…
Remarks
Enter system view
Set the certificate request mode to manual
certificate request mode manual
Optional
Manual by default
Return to system view
Retrieve a CA certificate manually
See Retrieving a Certificate Manually
Required
Generate a local RSA or ECDSA key pair
public-key local create { ecdsa | rsa }
Required
No local RSA or ECDSA key pair exists by default.
Submit a local certificate request manually
pki request-certificate domain domain-name [ password ] [ pkcs10 [ filename filename ] ]
Required
l          If a PKI domain already has a local certificate, creating an RSA key pair will result in inconsistency between the key pair and the certificate. To generate a new RSA key pair, delete the local certificate and then issue the public-key local create command. For information about the public-key local create command, see Public Key in the Security Command Reference.
l          A newly created key pair will overwrite the existing one. If you perform the public-key local create command in the presence of a local RSA or ECDSA key pair, the system will ask you whether you want to overwrite the existing one.
l          If a PKI domain has already a local certificate, you cannot request another certificate for it. This is to avoid inconsistency between the certificate and the registration information resulting from configuration changes. To request a new certificate, use the pki delete-certificate command to delete the existing local certificate and the CA certificate stored locally.
l          When it is impossible to request a certificate from the CA through SCEP, you can save the request information by using the pki request-certificate domain command with the pkcs10 and filename keywords, and then send the file to the CA by an out-of-band means.
l          Make sure the clocks of the entity and the CA are synchronous. Otherwise, the validity period of the certificate will be abnormal.
l          The pki request-certificate domain configuration will not be saved in the configuration file.
You can download an existing CA certificate or local certificate from the CA server and save it locally. To do so, you can use two ways: online and offline. In offline mode, you need to retrieve a certificate by an out-of-band means like FTP, disk, e-mail and then import it into the local PKI system.
Certificate retrieval serves two purposes:
l          Locally store the certificates associated with the local security domain for improved query efficiency and reduced query count,
l          Prepare for certificate verification.
Before retrieving a local certificate in online mode, be sure to complete LDAP server configuration.
Follow these steps to retrieve a certificate manually:
To do…
Use the command…
Remarks
Enter system view
Retrieve a certificate manually
Online
pki retrieval-certificate { ca | local } domain domain-name
Required
Use either command.
Offline
pki import-certificate { ca | local } domain domain-name { der | p12 | pem } [ filename filename ]
l          If a PKI domain already has a CA certificate, you cannot retrieve another CA certificate for it. This is in order to avoid inconsistency between the certificate and registration information due to related configuration changes. To retrieve a new CA certificate, use the pki delete-certificate command to delete the existing CA certificate and local certificate first.
l          The pki retrieval-certificate configuration will not be saved in the configuration file.
Configuring PKI Certificate Verification
A certificate needs to be verified before being used. Verifying a certificate is to check that the certificate is signed by the CA and that the certificate has neither expired nor been revoked.
Before verifying a certificate, you need to retrieve the CA certificate.
You can specify whether CRL checking is required in certificate verification. If you enable CRL checking, CRLs will be used in verification of a certificate.
Configuring CRL-checking-enabled PKI certificate verification
Follow these steps to configure CRL-checking-enabled PKI certificate verification:
To do…
Use the command…
Remarks
Enter system view
Specify the URL of the CRL distribution point
crl url url-string
Optional
No CRL distribution point URL is specified by default.
Set the CRL update period
crl update-period hours
Optional
By default, the CRL update period depends on the next update field in the CRL file.
Enable CRL checking
crl check enable
Optional
Enabled by default
Retrieve the CA certificate
Required
Retrieve CRLs
pki retrieval-crl domain domain-name
Required
Verify the validity of a certificate
pki validate-certificate { ca | local } domain domain-name
Required
Configuring CRL-checking-disabled PKI certificate verification
Follow these steps to configure CRL-checking-disabled PKI certificate verification:
To do…
Use the command…
Remarks
Enter system view
Disable CRL checking
crl check disable
Required
Enabled by default
Required
Verify the validity of the certificate
Required
l          The CRL update period refers to the interval at which the entity downloads CRLs from the CRL server. The CRL update period configured manually is prior to that specified in the CRLs.
l          The pki retrieval-crl domain configuration will not be saved in the configuration file.
l          Currently, the URL of the CRL distribution point does not support domain name resolving.
A certificate has a lifetime, which is determined by the CA. When the private key leaks or the certificate is about to expire, you can destroy the old RSA or ECDSA key pair and then create a pair to request a new certificate.
Follow these steps to destroy a local RSA key pair:
To do…
Use the command…
Remarks
Enter system view
Destroy a local RSA or ECDSA key pair
public-key local destroy { ecdsa | rsa }
Required
For more information about the public-key local destroy command, see Public Key in the Security Command Reference.
When a certificate requested manually is about to expire or you want to request a new certificate, you can delete the current local certificate or CA certificate.
Follow these steps to delete a certificate:
To do…
Use the command…
Remarks
Enter system view
Delete certificates
pki delete-certificate { ca | local } domain domain-name
Required
By configuring a certificate attribute-based access control policy, you can further control access to the server, providing additional security for the server.
Follow these steps to configure a certificate attribute-based access control policy:
To do…
Use the command…
Remarks
Enter system view
Create a certificate attribute group and enter its view
pki certificate attribute-group group-name
Required
No certificate attribute group exists by default.
Configure an attribute rule for the certificate issuer name, certificate subject name, or alternative subject name
attribute id { alt-subject-name { fqdn | ip } | { issuer-name | subject-name } { dn | fqdn | ip } } { ctn | equ | nctn | nequ } attribute-value
Optional
There is no restriction on the issuer name, certificate subject name and alternative subject name by default.
Create a certificate attribute-based access control policy and enter its view
pki certificate access-control-policy policy-name
Required
No access control policy exists by default.
Configure a certificate attribute-based access control rule
rule [ id ] { deny | permit } group-name
Required
No access control rule exists by default.
A certificate attribute group must exist to be associated with a rule.
To do…
Use the command…
Remarks
Display the contents or request status of a certificate
display pki certificate { { ca | local } domain domain-name | request-status }
Available in any view
Display CRLs
display pki crl domain domain-name
Display information about one or all certificate attribute groups
display pki certificate attribute-group { group-name | all }
Display information about one or all certificate attribute-based access control policies
display pki certificate access-control-policy { policy-name | all }
For PKI configuration examples, see:
l          SSH2.0 in the Security Configuration Guide
l          HTTP in the Fundamentals Configuration Guide
Troubleshooting PKI
Failed to Retrieve a CA Certificate
Symptom
Failed to retrieve a CA certificate.
Analysis
Possible reasons include these:
l          The network connection is not proper. For example, the network cable may be damaged or loose.
l          No trusted CA is specified.
l          The URL of the registration server for certificate request is not correct or not configured.
l          No authority is specified for certificate request.
l          The system clock of the AP is not synchronized with that of the CA.
Solution
l          Make sure that the network connection is physically proper.
l          Check that the required commands are configured properly.
l          Use the ping command to check that the RA server is reachable.
l          Specify the authority for certificate request.
l          Synchronize the system clock of the AP with that of the CA.
Failed to Request a Local Certificate
Symptom
Failed to request a local certificate.
Analysis
l          No CA certificate has been retrieved.
l          The current key pair has been bound to a certificate.
l          Some required parameters of the entity DN are not configured.
Solution
l          Retrieve a CA certificate.
l          Regenerate a key pair.
l          Specify a trusted CA.
l          Configure the required entity DN parameters.
Failed to Retrieve CRLs
Symptom
Failed to retrieve CRLs.
Analysis
l          No CA certificate has been retrieved before you try to retrieve CRLs.
l          The IP address of LDAP server is not configured.
l          The CRL distribution URL is not configured.
l          The LDAP server version is wrong.
Solution
l          Specify the IP address of the LDAP server.
l          Specify the CRL distribution URL.
l          Re-configure the LDAP version.
