01-QoS Commands | 241.74 KB |
Table of Contents
1 Traffic Shaping and Line Rate Configuration Commands
Traffic Shaping Configuration Commands
2 QoS Policy Configuration Commands
Traffic Behavior Configuration Commands
3 Congestion Management Configuration Commands
4 Congestion Avoidance Configuration Commands
5 Priority Mapping Configuration Commands
Priority Mapping Table Configuration Commands
Port Priority Configuration Commands
Port Priority Trust Mode Configuration Commands
6 QoS Configuration Commands in an EPON System
QoS Configuration Commands at the OLT Side
bandwidth downstream high-priority enable
bandwidth downstream policy enable
bandwidth downstream priority-queue
QoS Configuration Commands at the ONU Side
display qos gts interface
View
Default Level
1: Monitor level
interface-type: Port type.
interface-number: Port number.
Use the display qos gts interface command to display traffic shaping configuration information.
If no port is specified, traffic shaping configuration information of all ports is displayed.
# Display traffic shaping configuration information of all ports.
Interface: GigabitEthernet2/0/1
Rule(s): If-match queue 2
CIR 640 (kbps), CBS 40960 (byte)
Table 1-1 Description on the fields of the display qos gts command
Port name identified by port type and port number |
Rule(s) |
Match criteria. “If-match queue 2” indicates that traffic shaping is performed for traffic in queue 2. |
CIR |
Committed information rate (CIR) in kbps |
CBS |
Committed burst size (CBS) in bytes |
qos gts
qos gts queue queue-number cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts queue queue-number
View
Ethernet interface view, port group view
Default Level
2: System level
queue queue-number: Specifies a queue by its number, which ranges from 0 to 7.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps.
cbs committed-burst-size: Specifies the CBS (in bytes), which ranges from 4096 to 268435456 and must be a multiple of 4096.
If the cbs keyword is not specified, the default CBS is 62.5 ms × committed-information-rate and must be a multiple of 4096. If 62.5 ms × committed-information-rate is not a multiple of 4096, the default CBS is the multiple of 4096 that is bigger than and nearest to 62.5 ms × committed-information-rate. The maximum CBS is 268435456. For example, if the CIR is 640 kbps, then 62.5 ms × CIR is 62.5 ms × 640 = 40000. As 40000 is not a multiple of 4096, 40960, which is the multiple of 4096 that is bigger than and nearest to 40000, is taken as the default CBS.
Use the qos gts command to configure traffic shaping.
Use the undo qos gts command to remove the traffic shaping configuration.
In Ethernet interface view, the configuration takes effect on the current port. In port group view, the configuration takes effect on all ports in the port group.
# Configure traffic shaping on GigabitEthernet 2/0/1 to limit the outgoing traffic rate of queue 2 to 640 kbps.
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] qos gts queue 2 cir 640
display qos lr interface
View
Default Level
1: Monitor level
Use the display qos lr interface command to display the line rate configuration information of the specified port or all ports if no port is specified.
# Display the line rate configuration and statistics information of all the interfaces.
Interface: GigabitEthernet2/0/10
Direction: Outbound
CIR 64000 (kbps), CBS 4000000 (byte)
Table 1-2 Description on the fields of the display qos lr command
Port name, composed of port type and port number |
Direction |
Specify the direction of limited rate as outbound |
CIR |
Committed information rate, in kbps |
CBS |
Committed burst size, in byte |
qos lr outbound
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
View
Default Level
2: System Level
outbound: Limits the rate of the outbound traffic.
cbs committed-burst-size: Specifies the committed burst size in bytes.
l The committed-burst-size argument ranges from 4000 to 16000000.
l If the cbs keyword is not used, the system uses the default committed burst size, that is, 62.5 ms x committed-information-rate, or 16000000 if the multiplication is more than 16000000.
Use the qos lr outbound command to limit the rate of outbound traffic via physical interfaces.
Use the undo qos lr outbound command to cancel the limit.
# Limit the outbound traffic rate on GigabitEthernet 2/0/1 within 640 kbps.
[Sysname-GigabitEthernet2/0/1] qos lr outbound cir 640
Commands for Defining Classes
display traffic classifier
display traffic classifier user-defined [ classifier-name ]
View
Default Level
1: Monitor level
classifier-name: Class name.
Use the display traffic classifier command to display the information about a class.
If no class name is provided, this command displays the information about all the user-defined classes.
# Display the information about the user-defined classes.
User Defined Classifier Information:
Classifier: p
Operator: AND
Rule(s) : If-match acl 2001
Table 2-1 Description on the fields of the display traffic classifier user-defined command
User Defined Classifier Information |
The information about the user-defined classes is displayed. |
Classifier |
Class name and its contents, which could be of multiple types |
Operator |
Logical relationship among the classification rules |
Rule |
Classification rules |
if-match
if-match match-criteria
undo if-match match-criteria
View
Class view
Default Level
2: System Level
match-criteria: Matching rule to be defined. Table 2-2 describes the available forms of this argument.
Table 2-2 The forms of the match-criteria argument
acl access-list-number |
Specifies an ACL to match packets. The access-list-number argument is in the range 2000 to 4999. In a class configured with the operator and, the logical relationship between rules defined in the referenced IPv4 ACL is or. |
acl ipv6 access-list-number |
Specifies an IPv6 ACL to match IPv6 packets. The access-list-number argument is in the range 2000 to 3999. In a class configured with the operator and, the logical relationship between rules defined in the referenced IPv6 ACL is or. |
any |
Specifies to match all packets. |
customer-dot1p 8021p-list |
Specifies to match packets by 802.1p precedence of the customer network. The 8021p-list argument is a list of CoS values. You can provide up to eight space-separated CoS values for this argument. CoS is in the range 0 to 7. |
dscp dscp-list |
Specifies to match packets by DSCP precedence. The dscp-list argument is a list of DSCP values. You can provide up to eight space-separated DSCP values for this argument. DSCP is in the range 0 to 63. |
destination-mac mac-address |
Specifies to match the packets with a specified destination MAC address. |
ip-precedence ip-precedence-list |
Specifies to match packets by IP precedence. The ip-precedence-list argument is a list of IP precedence values. You can provide up to eight space-separated IP precedence values for this argument. IP precedence is in the range 0 to 7. |
protocol protocol-name |
Specifies to match the packets of a specified protocol. The protocol-name argument can be IP or IPv6. |
service-dot1p 8021p-list |
Specifies to match packets by 802.1p precedence of the service provider network. The 8021p-list argument is a list of CoS values. You can provide up to eight space-separated CoS values for this argument. CoS is in the range 0 to 7. |
source-mac mac-address |
Specifies to match the packets with a specified source MAC address. |
customer-vlan-id vlan-id-list |
Specifies to match the packets of specified VLANs of user networks. The vlan-id-list argument specifies a list of VLAN IDs, in the form of vlan-id to vlan-id or multiple discontinuous VLAN IDs (separated by space). You can specify up to eight VLAN IDs for this argument at a time. VLAN ID is in the range 1 to 4094. In a class configured with the operator and, the logical relationship between the customer VLAN IDs specified for the customer-vlan-id keyword is or. |
service-vlan-id vlan-id-list |
Specifies to match the packets of specified VLANs of the operator’s network. The vlan-id-list argument is a list of VLAN IDs, in the form of vlan-id to vlan-id or multiple discontinuous VLAN IDs (separated by space). You can specify up to eight VLAN IDs for this argument at a time. VLAN ID is in the range 1 to 4094. In a class configured with the operator and, the logical relationship between the service VLAN IDs specified for the service-vlan-id keyword is or. |
Use the if-match command to define a rule to match a specific type of packets.
Use the undo if-match command to remove a matching rule.
Suppose the logical relationship between classification rules is and. Note the following when using the if-match command to define matching rules.
l If multiple matching rules with the acl or acl ipv6 keyword specified are defined in a class, the actual logical relationship between these rules is or when the policy is applied.
l If multiple matching rules with the customer-vlan-id or service-vlan-id keyword specified are defined in a class, the actual logical relationship between these rules is or when the policy is applied.
# Define a rule for class1 to match the packets with their destination MAC addresses being 0050-ba27-bed3.
# Define a rule for class2 to match the packets with their source MAC addresses being 0050-ba27-bed2.
# Define a rule for class3 to match the advanced IPv4 ACL 3101.
[Sysname] traffic classifier class3
[Sysname-classifier-class3] if-match acl 3101
# Define a rule for class4 to match the advanced IPv6 ACL 3101.
[Sysname] traffic classifier class4
[Sysname-classifier-class4] if-match acl ipv6 3101
# Define a rule for class5 to match all the packets.
[Sysname] traffic classifier class5
[Sysname-classifier-class5] if-match any
# Define a rule for class6 to match the packets with their DSCP precedence values being 1.
[Sysname] traffic classifier class6
[Sysname-classifier-class6] if-match dscp 1
# Define a rule for class7 to match the packets with their IP precedence values being 1.
[Sysname] traffic classifier class7
[Sysname-classifier-class7] if-match ip-precedence 1
# Define a rule for class8 to match IP packets.
[Sysname] traffic classifier class8
[Sysname-classifier-class8] if-match protocol ip
# Define a rule for class9 to match the packets with the customer network 802.1p precedence 2.
[Sysname] traffic classifier class9
[Sysname-classifier-class9] if-match customer-dot1p 2
# Define a rule for class10 to match the packets with the service provider network 802.1p precedence 5.
[Sysname] traffic classifier class10
[Sysname-classifier-class10] if-match service-dot1p 5
# Define a rule for class11 to match the packets of VLAN 1024 of the customer network.
[Sysname] traffic classifier class11
[Sysname-classifier-class11] if-match customer-vlan-id 1024
# Define a rule for class12 to match the packets of VLAN 1000 of the service provider network.
[Sysname] traffic classifier class12
[Sysname-classifier-class12] if-match service-vlan-id 1000
traffic classifier
View
Default Level
2: System Level
and: Specifies the relationship among the rules in the class as logic AND. That is, a packet is matched only when it matches all the rules defined for the class.
or: Specifies the relationship among the rules in the class as logic OR. That is, a packet is matched if it matches a rule defined for the class.
classifier-name: Name of the class to be created.
Use the traffic classifier command to create a class. This command also leads you to class view.
Use the undo traffic classifier command to remove a class.
By default, a packet is matched only when it matches all the rules configured for the class.
# Create a class named class 1.
accounting
accounting
undo accounting
View
Traffic behavior view
Default Level
2: System Level
None
Use the accounting command to configure the traffic accounting action for a traffic behavior.
Use the undo accounting command to remove the traffic accounting action.
Related commands: qos policy, traffic behavior, classifier behavior.
# Configure the traffic accounting action for a traffic behavior.
[Sysname-behavior-database] accounting
car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ green action ] [ red action ] [ yellow action ]
undo car
View
Default Level
2: System Level
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The committed-burst-size argument ranges from 4000 to 16000000, the default is 4000.
ebs excess-burst-size: Specifies excess burst size (EBS) in bytes. The excess-burst-size argument ranges from 0 to 16000000, the default is 4000.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps.
green action: Specifies the action to be conducted for the traffic conforming to CIR. The action argument can be:
l discard: Drops the packets.
l pass: Forwards the packets.
l remark-dscp-pass new-dscp: Marks the packets with a new DSCP precedence and forwards them to their destinations. The new-dscp argument is in the range 0 to 63.
By default, packets conforming to CIR are forwarded.
red action: Specifies the action to be conducted for the traffic conforms to neither CIR nor PIR. The action argument can be:
By default, packets conforming to neither CIR nor PIR are dropped.
yellow action: Specifies the action to be conducted for the traffic conforms to PIR but does not conform to CIR. The action argument can be:
By default, packets conforming to PIR but not conforming to CIR are forwarded.
Use the car command to configure TP action for a traffic behavior.
Use the undo car command to remove the TP action.
Note that, if you configure the TP action for a traffic behavior for multiple times, only the last configuration takes effect.
# Configure TP action for a traffic behavior. When the traffic rate is lower than 6400 kbps, packets are forwarded normally. When the traffic rate exceeds 6400 kbps, the packets beyond 6400 kbps are dropped.
[Sysname-behavior-database] car cir 6400 red discard
display traffic behavior
display traffic behavior user-defined [ behavior-name ]
View
Default Level
1: Monitor level
behavior-name: Name of a user defined traffic behavior.
Use the display traffic behavior command to display the information about a user defined traffic behavior.
If no behavior name is provided, this command displays the information about all the user-defined behaviors.
# Display the information about all the user defined traffic behaviors.
User Defined Behavior Information:
Behavior: test
Marking:
Remark dot1p COS 4
Committed Access Rate:
CIR 640 (kbps), CBS 4000 (byte), EBS 4000 (byte), PIR 640 (kbps)
Green Action: pass
Red Action: discard
Yellow Action: pass
Table 2-3 Description on the fields of the display traffic behavior user-defined command
User Defined Behavior Information |
The information about user defined traffic behaviors is displayed |
Behavior |
Name of a traffic behavior, which can be of multiple types |
Marking |
Information about priority marking |
Committed Access Rate |
Information about traffic rate limit |
CIR |
Committed information rate in bytes |
CBS |
Committed burst size in bytes |
EBS |
Excessive burst size in bytes |
PIR |
Peak information rate in bytes |
Green Action |
Action conducted to packets conforming to CIR |
Red Action |
Action conducted for packets conforming to neither CIR nor PIR |
Yellow Action |
Action conducted to packets conforming to PIR but not conforming to CIR |
filter
filter { deny | permit }
undo filter
View
Default Level
2: System Level
deny: Drops packets.
permit: Forwards packets.
Use the filter command to configure traffic filtering action for a traffic behavior.
Use the undo filter command to remove the traffic filtering action.
# Configure traffic filtering action for a traffic behavior.
mirror-to
mirror-to { cpu | interface interface-type interface-number }
undo mirror-to { cpu | interface interface-type interface-number }
View
Default Level
2: System Level
cpu: Redirects packets to the CPU.
interface interface-type interface-number: Port type and port number of the destination port for the traffic mirroring action.
Use the mirror-to command to configure traffic mirroring action for a traffic behavior.
Use the undo mirror-to command to remove the traffic mirroring action.
Note that when the action of mirroring traffic is applied in the outbound direction of an SC LPU, any other action cannot be configured in the same traffic behavior. Otherwise, the corresponding QoS policy cannot be applied successfully.
# Configure traffic behavior 1 and define the action of mirroring traffic to GigabitEthernet2/0/2 in the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface GigabitEthernet 2/0/2
nest
nest top-most vlan-id vlan-id
undo nest
View
Default Level
2: System Level
vlan-id vlan-id: ID of the VLAN. The vlan-id argument is in the range 1 to 4094.
Use the nest command to configure an outer VLAN tag for a traffic behavior.
Use the undo nest command to remove the outer VLAN tag.
Note that:
l If the nest action will be applied to the inbound direction of a port or port group on an EA LPU, the classification rule must be configured with the if-match customer-vlan-id command, and the other actions except remark dot1p cannot be configured in the traffic behavior. Additionally, you must enable basic QinQ on the port or port group before applying the QoS policy.
l If the nest action will be applied to the inbound direction of a port or port group on an SA or SC LPU, you must enable basic QinQ on the port or port group first.
l The nest action cannot be applied to a VLAN or globally.
# Configure an outer VLAN tag for a traffic behavior.
[Sysname-behavior-database] nest top-most vlan-id 100
redirect
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add [ ipv4-add ] | ipv6-add [ interface-type interface-number ] [ ipv6-add [ interface-type interface-number ] ] } }
undo redirect { cpu | interface interface-type interface-number | next-hop }
View
Default Level
2: System Level
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface identified by its type and number.
next-hop: Specifies the next hop to redirect the traffic to.
ipv4-add: IPv4 address of the next hop.
ipv6-add: IPv6 address of the next hop. The interface-type interface-number argument is a VLAN interface number. If the IPv6 address is a link-local address, you must specify a VLAN interface for the IPv6 address of the next hop; if the IPv6 address is not a link-local address, you need not specify a VLAN interface for the IPv6 address of the next hop.
Use the redirect command to configure traffic redirecting action for a traffic behavior.
Use the undo redirect command to remove the traffic redirecting action.
# Configure the redirecting action to redirect traffic to GigabitEthernet2/0/1 port.
[Sysname-behavior-database] redirect interface GigabitEthernet 2/0/1
remark customer-vlan-id
remark customer-vlan-id vlan-id-value
undo remark customer-vlan-id
View
Default Level
2: System Level
vlan-id-value: VLAN ID to be set for packets, in the range of 1 to 4094.
Use the remark customer-vlan-id command to configure the action of setting the customer network VLAN ID for a traffic behavior.
Use the undo remark customer-vlan-id command to remove the action of setting the customer network VLAN ID.
Note that the action of setting the customer network VLAN ID cannot be applied to a VLAN or applied globally.
# Configure the action of setting the customer network VLAN ID to 2 for a traffic behavior.
[Sysname-behavior-database] remark customer-vlan-id 2
remark dot1p
remark dot1p 8021p
undo remark dot1p
View
Default Level
2: System Level
8021p: 802.1p precedence to be set for packets, in the range 0 to 7.
Use the remark dot1p command to configure the action of setting 802.1p precedence for a traffic behavior.
Use the undo remark dot1p command to remove the action of setting 802.1p precedence
Note that, when the remark dot1p command is used together with the remark local-precedence command, the 802.1p precedence to be set for packets must be the same as the local precedence to be set for packets. Otherwise, the corresponding policy cannot be applied successfully.
# Configure the action to set 802.1p precedence to 2 for a traffic behavior.
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence
remark drop-precedence drop-precedence-value
undo remark drop-precedence
View
Default Level
2: System Level
drop-precedence-value: Drop precedence to be set for packets, in the range 0 to 2.
Use the remark drop-precedence command to configure the action of setting drop precedence for a traffic behavior.
Use the undo remark drop-precedence command to remove the action of setting drop precedence.
# Configure the action to set drop precedence to 2 for a traffic behavior.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
remark dscp dscp-value
undo remark dscp
View
Default Level
2: System Level
dscp-value: DSCP precedence to be set for packets, in the range of 0 to 63. This argument can also be the keywords listed in Table 2-4.
Table 2-4 DSCP keywords and values
Keyword |
DSCP value (binary) |
DSCP value (decimal) |
default |
000000 |
0 |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
ef |
101110 |
46 |
Use the remark dscp command to configure the action of setting DSCP precedence for a traffic behavior.
Use the undo remark dscp command to remove the action of setting DSCP precedence.
# Configure the action to set DSCP precedence to 6 for a traffic behavior.
remark ip-precedence
remark ip-precedence ip-precedence-value
undo remark ip-precedence
View
Default Level
2: System Level
ip-precedence-value: IP precedence to be set for packets, in the range of 0 to 7.
Use the remark ip-precedence command to configure the action of setting IP precedence for a traffic behavior.
Use the undo remark ip-precedence command to remove the action of setting IP precedence.
# Configure the action to set IP precedence to 6 for a traffic behavior.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
View
Default Level
2: System Level
local-precedence: Local precedence to be set for packets, in the range of 0 to 7.
Use the remark local-precedence command to configure the action of setting local precedence for a traffic behavior.
Use the undo remark local-precedence command to remove the action of remarking local precedence.
# Configure the action to set local precedence to 2 for a traffic behavior.
remark service-vlan-id
remark service-vlan-id vlan-id-value
undo remark service-vlan-id
View
Default Level
2: System Level
Use the remark service-vlan-id command to configure the action of setting the service provider network VLAN ID for a traffic behavior.
Use the undo remark service-vlan-id command to remove the action of setting the service provider network VLAN ID.
l Note that: If the remark service-vlan-id action will be applied to the inbound direction of a port or port group on an EA LPU, the classification rule must be configured with the if-match customer-vlan-id command, and the other actions except remark dot1p cannot be configured in the traffic behavior.
l If the remark service-vlan-id action will be applied to the outbound direction of a port or port group on an SC LPU, any other actions except filer and remark dot1p cannot be configured in the traffic behavior.
l The remark service-vlan-id action cannot be applied to a VLAN or applied globally.
# Configure the action of setting the service provider network VLAN ID to 2 for a traffic behavior.
[Sysname-behavior-database] remark service-vlan-id 2
traffic behavior
View
Default Level
2: System Level
behavior-name: Name of the traffic behavior to be created.
Use the traffic behavior command to create a traffic behavior. This command also leads you to traffic behavior view.
Use the undo traffic classifier command to remove a traffic behavior.
Related commands: qos policy, qos apply policy, classifier behavior.
# Define a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
classifier behavior
classifier classifier-name behavior behavior-name [ mode do1q-tag-manipulation ]
View
Policy view
Default Level
2: System Level
classifier-name: Name of an existing class.
behavior–name: Name of an existing traffic behavior.
mode dot1q-tag-manipulation: Specifies that the association relationship between the class and the traffic behavior is used for the VLAN mapping function.
Use the classifier behavior command to associate a traffic behavior with a class.
Use the undo classifier command to remove a class from a policy.
Note that each class can be associated with only one traffic behavior.
Related commands: qos policy.
In a QoS policy with multiple class-to-traffic-behavior associations, if the action of creating an outer VLAN tag, the action of setting customer network VLAN ID, or the action of setting service provider network VLAN ID is configured in a traffic behavior, we recommend you not to configure any other action in this traffic behavior. Otherwise, the QoS policy may not function as expected after it is applied.
# Associate the behavior named test with the class named database in the policy user1.
[Sysname] qos policy user1
display qos policy
display qos policy user-defined [ policy-name [ classifier classifier-name ] ]
View
Default Level
1: Monitor level
policy-name: Policy name. If it is not provided, the configuration of all the user defined policies is displayed.
classifier-name: Name of a class in the policy. If it is not provided, all the classes in the policy are specified.
Use the display qos policy command to display the configuration of a specified policy, including the configuration of the classes and the associated traffic behaviors in the policy.
# Display the configuration of all the user specified policies.
User Defined QoS Policy Information:
Policy: test
Classifier: test
Behavior: test
Accounting Enable
Green Action: pass
Red Action: discard
Yellow Action: pass
Table 2-5 Description on the fields of the display qos policy command
Policy |
Policy name |
Classifier |
Class name and the corresponding configuration information |
Behavior |
Traffic behavior name and the corresponding configuration information |
display qos policy global
display qos policy global { inbound | outbound } [ slot slot-id ]
View
Default Level
1: Monitor level
inbound: Displays the QoS policy applied globally in the inbound direction of all ports.
outbound: Displays the QoS policy applied globally in the outbound direction of all ports.
slot slot-number: Displays the global QoS policy applied on a board. If the slot-number argument is not specified, the global QoS policy applied on the main control board are displayed.
Use the display qos policy global command to display information about a global QoS policy.
# Display information about the global QoS policy in the inbound direction.
<Sysname> display qos policy global inbound
Direction: Inbound
Policy: abc_policy
Classifier: abc
Operator: AND
Rule(s) : If-match dscp cs1
Behavior: abc
Green Action: pass
Red Action: discard
Yellow Action: pass
Green : 0(Packets)
Table 2-6 Description on the fields of the display qos policy global command
Direction |
Direction in which the policy is applied globally |
Policy |
Policy name |
Classifier |
Class name Failed indicates that the policy is not successfully applied |
Behavior |
Traffic behavior name |
display qos policy interface
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
View
Default Level
1: Monitor level
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
Use the display qos policy interface command to display the configuration and statistics information about the policy applied on a port.
If no interface is provided, the configuration and statistics information about the policies applied on all the ports is displayed.
# Display the configuration and statistics information about the policy applied on GigabitEthernet2/0/1 port.
<Sysname> display qos policy interface GigabitEthernet 2/0/1
Direction: Inbound
Policy: abc_policy
Classifier: abc
Operator: AND
Behavior: abc
Green Action: pass
Red Action: discard
Yellow Action: pass
Green : 0(Packets)
Table 2-7 Description on the fields of the display qos policy interface command
Port name, comprising of port type and port number |
Direction |
Direction of the port where the policy is applied |
Policy |
Name of the policy applied to the port |
Classifier |
Name of the class in the policy and its configuration Failed indicates that the policy is not successfully applied |
Operator |
Logical relationship among the classification rules in a class |
Rule(s) |
Classification rules in the class |
Behavior |
Name of the behavior in the policy and its configuration |
display qos vlan-policy
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-id ]
View
Default Level
1: Monitor level
name policy-name: Specifies to display the information about the VLAN policy with the specified name.
vlan vlan-id: Specifies to display the information about the VLAN policy applied to the specified VLAN.
slot-id: Specifies to display the information about the VLAN policies applied to VLANs on the board seated in the specific slot. If the slot-id argument is not specified, this command displays the information about the VLAN policies applied to the SRPU.
Use the display qos vlan-policy command to display the information about VLAN policies.
If the vlan-id argument is not specified, the information about all the VLAN policies will be displayed.
# Display the information about the VLAN policy named test.
<Sysname> display qos vlan-policy name test
Policy test
Vlan 300: inbound
Table 2-8 Description on the fields of the display qos vlan-policy command
Policy |
Name of the VLAN policy |
Vlan 300 |
ID of the VLAN where the VLAN policy is applied |
inbound |
VLAN policy is applied in the inbound direction of the VLAN. |
# Display the information about the VLAN policy applied to VLAN 300.
<Sysname> display qos vlan-policy vlan 300
Vlan 300
Direction: Inbound
Policy: test
Classifier: test
Operator: AND
Rule(s) : If-match customer-vlan-id 3
Behavior: test
Accounting Enable:
0 (Packets)
CIR 6400 (kbps), CBS 4000 (byte), EBS 4000 (byte)
Green Action: pass
Red Action: discard
Yellow Action: pass
Green : 0(Packets)
Table 2-9 Description on the fields of the display qos vlan-policy command
Vlan 300 |
Inbound |
Classifier |
Name of the class in the policy and its configuration |
Behavior |
qos apply policy
undo qos apply policy { inbound | outbound }
View
Default Level
2: System Level
policy-name: Specifies the policy name.
Use the qos apply policy command to apply a policy on a port or a port group.
Use the undo qos apply policy command to remove the policy applied on a port or a port group.
Note that, when you apply a policy by using the qos apply policy command, whether or not the inbound/outbound keyword can take effect depends on the actions defined in the traffic behavior and LPU types, as described in Table 2-10.
Table 2-10 The support for the inbound direction and the outbound direction
LPU type
Action |
SC LPU |
SA LPU |
EA LPU |
Inbound |
Outbound |
Inbound |
Outbound |
Inbound |
Outbound |
Traffic accounting |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
TP |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Traffic filtering |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Traffic mirroring |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Configuring the outer VLAN tag |
Supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Traffic redirecting |
Supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Remarking the customer network VLAN ID for packets |
Not supported |
Supported |
Not supported |
Not supported |
Not supported |
Not supported |
Remarking the 802.1p precedence for packets |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Remarking the drop precedence for packets |
Supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Remarking the DSCP precedence for packets |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Remarking the IP precedence for packets |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
Remarking the local precedence for packets |
Supported |
Not supported |
Supported |
Not supported |
Supported |
Not supported |
Remarking the service provider network VLAN ID for packets |
Supported |
Supported |
Supported |
Not supported |
Supported |
Not supported |
SC LPUs include LSQ1GP24SC LPUs and so on, SA LPUs include LSQ1FP48SA LPUs and so on, EA LPUs include LSQ1GP12EA LPUs and so on. For the detailed information about LPU types, refer to the installation manual.
You can apply a QoS policy in the outbound direction of a basic QinQ-enabled port on an SA LPU or EA LPU to implement one-to-one VLAN mapping. In this policy, only one matching rule, if-match service-vlan-id, can be defined, and the action can only be remark customer-vlan-id or remark customer-vlan-id together with remark dot1p.
# Apply the policy named test in the inbound direction of GigabitEthernet2/0/1 port.
[Sysname-GigabitEthernet2/0/1] qos apply policy test inbound
qos apply policy global
undo qos apply policy global { inbound | outbound }
View
Default Level
2: System Level
inbound: Applies the QoS policy to the incoming packets on all ports.
outbound: Applies the QoS policy to the outgoing packets on all ports.
Use the qos apply policy global command to apply a QoS policy globally. A QoS policy applied globally takes effect on all inbound or outbound traffic depending on the direction in which the policy is applied.
Use the undo qos apply policy global command to cancel the global application of the QoS policy.
Note that, when you apply a QoS policy with the qos apply policy global command, support for the inbound/outbound keyword depends on the actions defined in the traffic behavior and LPU types, as described in Table 2-10.
# Apply the QoS policy user1 in the inbound direction globally.
[Sysname] qos apply policy user1 global inbound
qos policy
qos policy policy-name
undo qos policy policy-name
View
Default Level
2: System Level
policy-name: Name of the policy to be created.
Use the qos policy command to create a policy. This command also leads you to policy view.
Use the undo qos policy command to remove a policy.
To remove a policy that is currently applied on a port, you need to disable it on the port first.
Related commands: classifier behavior, qos apply policy.
# Create a policy named user1.
qos vlan-policy
undo qos vlan-policy vlan vlan-id-list { inbound | outbound }
View
Default Level
2: System Level
vlan-id-list: List of VLAN IDs, presented in the form of vlan-id to vlan-id or discontinuous VLAN IDs. Up to eight VLAN IDs can be specified at a time.
inbound: Specifies to apply the VLAN policy in the inbound direction of the VLAN.
outbound: Specifies to apply the VLAN policy in the outbound direction of the VLAN.
Use the qos vlan-policy command to apply the VLAN policy to the specific VLAN(s).
Use the undo qos vlan-policy command to remove the VLAN policy from the specific VLAN(s).
Note that, when you apply a QoS policy with the qos vlan-policy command, support for the inbound/outbound keyword varies with the actions defined in the traffic behavior and the type of the LPU to which the ports in the VLAN belong, as described in Table 2-10.
Do not apply policies to a VLAN and the ports in the VLAN at the same time.
# Apply the VLAN policy named test in the inbound direction of VLAN 200, VLAN 300, VLAN 400, VLAN 500, VLAN 600, VLAN 700, VLAN 800, and VLAN 900.
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
reset qos policy global
reset qos policy global { inbound | outbound }
View
Default Level
1: Monitor level
Use the reset qos vlan-policy command to clear the statistics of a global QoS policy.
# Clear the statistics of the global QoS policy in the inbound direction.
<Sysname> reset qos policy global inbound
reset qos vlan-policy [ vlan vlan-id ]
View
Default Level
1: Monitor level
vlan-id: VLAN ID, in the range 1 to 4,094.
Use the reset qos vlan-policy command to clear the statistics information about VLAN policies.
# Clear the statistics information about the VLAN policy applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
display qos sp interface
display qos sp interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos sp interface command to display the strict priority (SP) queuing configuration on a specified port.
If no port is specified, this command displays the SP queuing configuration on all ports.
Related commands: qos sp.
# Display the SP queuing configuration on GigabitEthernet 2/0/1.
<Sysname> display qos sp interface GigabitEthernet 2/0/1
Output queue: Strict-priority queue
display qos wfq interface
display qos wfq interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wfq interface command to display the configuration of Weighted Fair Queuing (WFQ) queues of a port.
If no port number is specified, the command displays the configurations of WFQ queues of all ports.
Related commands: qos wfq.
# Display the configuration of the WFQ queues on port GigabitEthernet 3/0/1 on an EA LPU.
<Sysname> display qos wfq interface e 3/0/1
Interface: Ethernet3/0/1
Output queue: Hardware weighted fair queue
Queue ID Weight Min-Bandwidth
0 1 8
1 1 8
2 1 8
3 1 8
4 1 8
5 1 8
6 1 8
7 1 8
# Display the configuration of the WFQ queues on port GigabitEthernet 2/0/1 on a non-EA LPU.
<Sysname> display qos wfq interface GigabitEthernet 2/0/1
0 1 8
1 2 8
2 4 8
3 6 8
4 8 8
5 10 8
6 12 8
7 14 8
Table 3-1 Description on the fields of the display qos wfq interface command
Output queue |
The type of the current output queue |
Queue ID |
ID of the queue |
Weight |
The weight of each queue during scheduling. |
Min-Bandwidth |
Minimum guaranteed bandwidth of the queue |
display qos wrr interface
display qos wrr interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display qos wrr interface command to display the configuration of weighted round robin (WRR) queues of a port.
If no port number is specified, the command displays the configurations of WRR queues of all ports.
Related commands: qos wrr.
# Display the configuration of WRR queues of GigabitEthernet 2/0/1.
<Sysname> display qos wrr interface GigabitEthernet 2/0/1
Output queue: Weighted round robin queue
Queue ID Group Weight
0 sp N/A
1 sp N/A
2 1 3
3 1 4
4 1 5
5 1 6
6 1 7
7 1 8
Table 3-2 Description on the fields of the display qos wrr interface command
Output queue |
Queue ID |
ID of the queue |
Group |
Group ID, indicating which group a queue belongs to. |
Weight |
The weight of each queue during scheduling. N/A indicates that SP queue scheduling algorithm is adopted. |
qos bandwidth queue
undo qos bandwidth queue queue-id [ min bandwidth-value ]
View
Default Level
2: System level
queue-id: Queue ID, in the range of 0 to 7.
bandwidth-value: Minimum guaranteed bandwidth (in kbps), that is, the minimum bandwidth guaranteed for a queue when the port is congested.
Use the qos bandwidth queue command to set the minimum guaranteed bandwidth for a specified queue on the port or ports in the port group.
Use the undo qos bandwidth queue command to remove the configuration.
Note that:
l In Ethernet interface view, the configuration takes effect only on the current port; in port group view, the configuration takes effect on all ports in the port group.
l To configure minimum guaranteed bandwidth for queues on a port/port group, enable WFQ on the port/port group first.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet 2/0/1] qos wfq
[Sysname-GigabitEthernet 2/0/1] qos bandwidth queue 0 min 100
qos sp
qos sp
undo qos sp
View
Default Level
2: System Level
None
Use the qos sp command to configure SP queuing on the current port.
Use the undo qos sp command to restore the default queuing algorithm on the port.
By default, the switch adopts the SP queue-scheduling algorithm.
Related commands: display qos sp interface.
# Configure SP queuing on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos sp
qos wfq
qos wfq
undo qos wfq
View
Default Level
2: System Level
None
Use the qos wfq command to enable weighted fair queuing (WFQ) on a port or port group.
Use the undo qos wfq command to restore the default.
Related commands: display qos wrr interface.
# Enable WFQ on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos wfq
qos wfq weight
qos wfq queue-id weight schedule-value
undo qos wfq queue-id weight
View
Default Level
2: System Level
queue-id: ID of the queue, in the range of 0 to 7.
weight schedule-value: Specifies the scheduling weight of a queue. The range for the scheduling weight depends on the LPU type of your S7500E series switch:
l For EA LPUs, the scheduling weight of each queue is 1, that is, all queues share the allocable bandwidth (allocable bandwidth = total bandwidth – the sum of the minimum guaranteed bandwidth for each queue).
l For non-EA LPUs, the scheduling weight ranges from 0 to 15, and each queue is allocated with part of the allocable bandwidth based on its scheduling weight.
Use the qos wfq command to enable weighted fair queuing (WFQ) on a port or port group and configure a scheduling weight for the specified queue.
On a WFQ-enable port/port group, the scheduling weight of a queue is 1 by default.
Related commands: display qos wfq interface, qos bandwidth queue.
# Enable WFQ on GigabitEthernet 2/0/1 on a non-EA LPU and assign weight values 1, 2, 4, 6, 8, 10, 12, and 14 to queues 0 through 7.
[Sysname-GigabitEthernet2/0/1] qos wfq 0 weight 1
[Sysname-GigabitEthernet2/0/1] qos wfq 1 weight 200
[Sysname-GigabitEthernet2/0/1] qos wfq 2 weight 4
[Sysname-GigabitEthernet2/0/1] qos wfq 3 weight 6
[Sysname-GigabitEthernet2/0/1] qos wfq 4 weight 8
[Sysname-GigabitEthernet2/0/1] qos wfq 5 weight 10
[Sysname-GigabitEthernet2/0/1] qos wfq 6 weight 12
[Sysname-GigabitEthernet2/0/1] qos wfq 7 weight 14
qos wrr
qos wrr
undo qos wrr
View
Default Level
2: System Level
None
Use the qos wrr command to enable weighted round robin (WRR) on a port or port group.
Use the undo qos wrr command to restore the default.
On a port or port group with WRR enabled, the weight values of queues 0 through 7 are 1, 2, 3, 4, 5, 6, 7, and 8 respectively.
# Enable WRR on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos wrr
qos wrr weight
qos wrr queue-id group { sp | group-id weight schedule-value }
undo qos wrr
View
Default Level
2: System Level
group-id: It can only be 1.
weight schedule-value: Specifies the scheduling weight of a queue, rang from 1 to 15.
sp: Configures SP queuing.
Use the qos wrr command to configure Weighted Round Robin (WRR) queue scheduling algorithm or the SP + WRR queue scheduling algorithm on a port or port group.
Use the undo qos wrr command to restore the default queue-scheduling algorithm on the port.
As required, you can configure part of the queues on the port to adopt the SP queue-scheduling algorithm and parts of queues to adopt the WRR queue-scheduling algorithm. Through adding the queues on a port to the SP scheduling group and WRR scheduling group (namely, group 1), the SP + WRR queue scheduling is implemented. During the queue scheduling process, the queues in the SP scheduling group is scheduled preferentially. When no packet is to be sent in the queues in the SP scheduling group, the queues in the WRR scheduling group are scheduled. The queues in the SP scheduling group are scheduled according to the strict priority of each queue, while the queues in the WRR queue scheduling group are scheduled according the weight value of each queue.
# Configure SP+WRR queue scheduling algorithm on GigabitEthernet 2/0/1 as follows: assign queue 0, queue 1, queue 2, and queue 3 to the SP scheduling group; and assign queue 4, queue 5, queue 5, and queue 7 to WRR scheduling group, with the weight 2, 4, 6, and 8.
[Sysname-GigabitEthernet2/0/1] qos wrr 0 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 1 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 2 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 3 group sp
[Sysname-GigabitEthernet2/0/1] qos wrr 4 group 1 weight 2
[Sysname-GigabitEthernet2/0/1] qos wrr 5 group 1 weight 4
[Sysname-GigabitEthernet2/0/1] qos wrr 6 group 1 weight 6
[Sysname-GigabitEthernet2/0/1] qos wrr 7 group 1 weight 8
display qos wred interface
View
Default Level
1: Monitor level
Use the display qos wred interface command to display the WRED configuration of a port.
If no port number is specified, the command displays the WRED configurations of all ports.
Related commands: qos wred apply.
# Display the WRED configuration of GigabitEthernet 2/0/1.
<Sysname> display qos wred interface GigabitEthernet 2/0/1
Current WRED configuration:
Applied WRED table name: queue-table1
display qos wred table
display qos wred table [ table-name ]
View
Default Level
1: Monitor level
table-name: Name of the WRED table to be displayed.
Use the display qos wred table command to display the WRED table configuration information.
If no WRED table name is specified, the configuration of all the WRED tables is displayed.
Related commands: queue.
# Display the configuration of WRED table queue-table1.
<Sysname> display qos wred table queue-table1
Table Name: queue-table1
Table Type: Queue based WRED
QID: gmin gmax gprob ymin ymax yprob rmin rmax rprob
0 10 NA 10 10 NA 10 10 NA 10
1 10 NA 10 10 NA 10 10 NA 10
2 10 NA 10 10 NA 10 10 NA 10
3 10 NA 10 10 NA 10 10 NA 10
4 10 NA 10 10 NA 10 10 NA 10
5 10 NA 10 10 NA 10 10 NA 10
6 10 NA 10 10 NA 10 10 NA 10
7 10 NA 10 10 NA 10 10 NA 10
Table 4-1 display qos wred table command output description
Table name |
Name of a WRED table |
Table type |
Type of a WRED table |
Queue ID |
ID of the queue |
gmin |
Lower threshold configured for green packets, whose drop precedence is 0 |
gmax |
Upper threshold configured for green packets, whose drop precedence is 0 |
gprob |
Drop probability slope configured for green packets, whose drop precedence is 0 |
ymin |
Lower threshold configured for yellow packets, whose drop precedence is 1 |
ymax |
Upper threshold configured for yellow packets, whose drop precedence is 1 |
yprob |
Drop probability slope configured for yellow packets, whose drop precedence is 1 |
rmin |
Lower threshold configured for red packets, whose drop precedence is 2 |
rmax |
Upper threshold configured for red packets, whose drop precedence is 2 |
rprob |
Drop probability slope configured for red packets, whose drop precedence is 2 |
qos wred apply
qos wred apply table-name
undo qos wred apply
View
Interface view, port group view
Default Level
2: System Level
table-name: Name of a global WRED table.
Use the qos wred apply command to apply a WRED table to the current port or port group.
Use the undo qos wred apply command to cancel the application.
By default, no WRED table is applied to any port or port group.
Related commands: display qos wred interface.
# Apply the WRED table queue-table1 to the GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] qos wred apply queue-table1
qos wred queue table
undo qos wred table table-name
View
Default Level
2: System Level
table table-name: Specifies a name for the table, a string of 1 to 32 characters..
Use the qos wred queue table command to create a WRED table and enter WRED table view.
Use the undo qos wred table command to remove a WRED table.
By default, no WRED table is created.
A WRED table in use cannot be removed.
# Create a WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
queue queue-id [ drop-level drop-level ] low-limit low-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
View
WRED table view
Default Level
2: System Level
drop-level drop-level: Specifies a drop level, in the range of 0 to 2. If this argument is not specified, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low-limit low-limit: Specifies a lower threshold. When the queue length exceeds the lower threshold, WRED begins to drop packets. The low-limit argument ranges from 0 to 100 and defaults to 10.
discard-probability discard-prob: Specifies the discard-prob argument, which ranges from 0 to 90 and defaults to 10. Each drop level is configured with an independent drop probability. The meaning of discard-probability discard-prob depends on the type of the LPU where the WRED table-applied port resides, as shown in Table 4-2.
Table 4-2 Description on discard-probability discard-prob
LPU type |
Description on discard-probability discard-prob |
EA |
In a coordinate graph with the queue length percentage as the abscissa and drop probability as the ordinate, discard-prob specifies the degree of the included angle between the abscissa and the straight line starting at (low-limit, 0) and ending at (100%, max-drop-probability). The degree of the included angel ranges from 0 to 90. l When the queue length is fixed, the bigger the argument, the bigger the drop-probability. l When the argument is fixed, the bigger the queue length, the bigger the drop-probability. |
SC |
Reciprocal of the drop probability. The argument corresponds to the drop probability as follows: l 0 corresponds to 100% l 1 through 8 corresponds to 1/8 l 9 through 16 corresponds to 1/16 l 17 through 32 corresponds to 1/32 l 33 through 64 corresponds to 1/64 l 65 through 90 corresponds to 1/128 |
Use the queue command to configure the drop-related parameters for a specified queue in the WRED table.
Use the undo queue command to restore the default.
By default, the lower threshold is 10 and the discard-prob argument is 10 for all the drop levels in the WRED table.
Related commands: qos wred queue table.
# Modify drop parameters for queue 1 in the WRED table queue-table1: set the lower threshold to 10 and the degree of the included angle between the drop probability and queue length percentage to 30 for packets with drop level 1 in queue 1 (assuming the WRED table queue-table1 is applied to a port on an EA LPU).
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 discard-probability 30
display qos map-table
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp ]
View
Default Level
1: Monitor level
dot1p-lp: Specifies the 802.1p precedence-to-local precedence mapping table.
dot1p-dp: Specifies the 802.1p precedence-to-drop precedence mapping table.
dscp-dp: Specifies the DSCP-to-drop precedence mapping table.
dscp-dot1p: Specifies the DSCP-to-802.1p precedence mapping table.
dscp-dscp: Specifies the DSCP-to-DSCP mapping table.
Use the display qos map-table command to display the configuration of a priority mapping table.
If the type of the priority mapping table is not specified, the configuration of all the priority mapping tables is displayed.
Related commands: qos map-table.
# Display the configuration of the 802.1p precedence-to-drop precedence mapping table.
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 2
2 : 2
3 : 1
4 : 1
5 : 1
6 : 0
7 : 0
Table 5-1 Description on the fields of the display qos map-table command
MAP-TABLE NAME |
Name of the mapping table |
TYPE |
Type of the mapping table |
IMPORT |
Input entries of the mapping table |
EXPORT |
Output entries of the mapping table |
import
View
Priority mapping table view
Default Level
2: System Level
import-value-list: List of input parameters.
export-value: Output parameter in the mapping table.
all: Removes all the parameters in the priority mapping table.
Use the import command to configure entries for a priority mapping table, that is, to define one or more mapping rules.
Use the undo import command to restore specific entries of a priority mapping table to the default.
Note that, you cannot configure to map any DSCP value to drop precedence 1.
Related commands: display qos map-table.
# Configure the 802.1p precedence-to-drop precedence mapping table to map 802.1p precedence 4 and 5 to drop precedence 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
qos map-table
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp }
View
Default Level
2: System Level
Use the qos map-table command to enter specific priority mapping table view.
# Enter 802.1p precedence-to-drop precedence mapping table view.
qos priority
qos priority priority-value
undo qos priority
View
Default Level
2: System Level
priority-value: Port priority to be configured. This argument is in the range 0 to 7.
Use the qos priority command to set the port priority for a port.
Use the undo qos priority command to restore the default port priority.
By default, the port priority is 0.
Note that, if a port receives packets without an 802.1q tag, the switch takes the priority of the receiving port as the 802.1p precedence of the packets and then searches the dot1p-dp/lp mapping table for the local/drop precedence for the packets according to the priority of the receiving port.
# Set the port priority of GigabitEthernet2/0/1 port to 2.
[Sysname-GigabitEthernet2/0/1] qos priority 2
display qos trust interface
View
Default Level
1: Monitor level
Use the display qos trust interface command to display the port priority trust mode of a port.
If no port is specified, this command displays the port priority trust modes of all the ports.
# Display the port priority trust mode of GigabitEthernet2/0/1 port.
<Sysname> display qos trust interface GigabitEthernet 2/0/1
Port priority information
Port priority :0
Port priority trust type : dscp
Table 5-2 Description on the fields of the display qos trust interface command
Port priority |
Port priority |
Port priority trust type |
Port priority trust mode l dscp indicates that the DSCP precedence of the received packets is trusted l dot1p indicates that the 802.1p precedence of the received packets is trusted |
qos trust
qos trust dscp
undo qos trust
View
Default Level
2: System Level
dscp: Specifies to trust DSCP precedence carried in the packet and adopt this priority for priority mapping.
Use the qos trust command to configure the port priority trust mode.
Use the undo qos trust command to restore the default port priority trust mode.
By default, the 802.1p precedence of the received packets is trusted.
# Specify to trust the DSCP precedence carried in packets on GigabitEthernet 2/0/1 port.
[Sysname-GigabitEthernet2/0/1] qos trust dscp
bandwidth downstream { max-bandwidth value | max-burstsize value } *
undo bandwidth downstream { max-bandwidth | max-burstsize } *
View
ONU port view
Default Level
2: System level
max-bandwidth value: Specifies the maximum bandwidth in kbps. The value argument ranges from 0 to 999994. The system default is 999994 kbps.
max-burstsize value: Specifies the maximum burst buffer size in bytes. The value argument ranges from 0 to 8388480. The system default is 8388480 bytes.
Use the bandwidth downstream command to configure the downlink bandwidth limit.
Use the undo bandwidth downstream command to restore the default.
Related commands: bandwidth downstream policy enable.
l This command takes effect only when the downlink bandwidth allocation policy is enabled.
l The configured downlink bandwidth limit takes effect only on known unicasts, but not on unknown unicasts, multicasts, or broadcasts.
# Set the downstream bandwidth limit to 800000 kbps and maximum burst size to 8000000 bytes on ONU 2/0/1:1.
[Sysname] interface onu 2/0/1:1
[Sysname-Onu2/0/1:1] bandwidth downstream max-bandwidth 800000 max-burstsize 8000000
bandwidth downstream high-priority enable
undo bandwidth downstream high-priority enable
View
ONU port view
Default Level
2: System level
None
Use the bandwidth downstream high-priority enable command to reserve high-priority buffer for the ONU corresponding to the current port.
Use the undo bandwidth downstream high-priority enable command to restore the default.
By default, no high-priority packet buffer is reserved for any ONU.
Related commands: bandwidth downstream priority-queue.
The high-priority packet buffer configuration takes effect only when the downlink bandwidth allocation policy is enabled.
# Enable the high-priority packet buffer for the ONU corresponding to ONU 2/0/1:1.
[Sysname-Onu2/0/1:1] bandwidth downstream high-priority enable
undo bandwidth downstream policy enable
View
ONU port view
Default Level
2: System level
None
Use the bandwidth downstream command to enable the downlink bandwidth allocation policy for the ONU port.
By default, the downlink bandwidth allocation policy is disabled.
Related commands: bandwidth downstream.
The downlink bandwidth limit configuration commands take effect only when the downlink bandwidth allocation policy is enabled.
# Enable the downlink bandwidth allocation policy for ONU 2/0/1:1.
[Sysname-Onu2/0/1:1] bandwidth downstream policy enable
bandwidth downstream priority-queue priority high-priority-reserved value
undo bandwidth downstream priority-queue high-priority-reserved
View
OLT port view
Default Level
2: System level
priority: Queue priority, in the range 0 to 7.
value: Buffer size reserved for packets of high-priority queues, in bytes. It is in the range 0 to 131070 and defaults to 0.
Use the bandwidth downstream priority-queue command to configure thresholds for high-priority queues and reserve user-defined buffer sizes for high-priority queues based on the thresholds.
Use the undo bandwidth downstream priority-queue high-priority-reserved command to cancel the configuration.
By default, no priority threshold or buffer size is set for high-priority packet buffer.
The downlink packets on an OLT port are considered as high-priority only if their priority is greater than or equal to the priority value.
This command just configures buffer parameters. To make these parameters take effect, use the bandwidth downstream high-priority enable command to enable high-priority packet buffer for the specified ONU.
# Reserve 100 bytes of buffer for the packets whose priorities are greater than or equal to 3.
[Sysname] interface olt 3/0/1
[Sysname-Olt3/0/1] bandwidth downstream priority-queue 3 high-priority-reserved 100
priority-queue-mapping
priority-queue-mapping { downstream | upstream} { value } &<1-8>
undo priority-queue-mapping { downstream | upstream}
View
OLT port view
Default Level
2: System level
downstream: Downlink packets.
upstream: Uplink packets.
value : Local precedence, in the range 0 to 7.
&<1-8>: Indicates that you can specify up to eight priority queue values.
Use the priority-queue-mapping command to configure the mapping between the CoS precedence and local precedence of uplink and downlink packets on the OLT port.
The default mapping between CoS precedence and local precedence on an OLT port is as shown in Table 6-1.
CoS precedence |
Local precedence |
0 |
0 |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
# Configure the mapping between the CoS precedence and local precedence of downlink packets on the OLT port.
[Sysname-Olt3/0/1] priority-queue-mapping downstream 1 1 2 3 4 5 6 7
Table 6-2 shows the mapping between CoS precedence and local precedence of downlink packets on the OLT port after the configuration is compete.
Table 6-2 Mapping between CoS precedence and local precedence
CoS precedence |
Local precedence |
0 |
1 |
1 |
1 |
2 |
2 |
3 |
3 |
4 |
4 |
5 |
5 |
6 |
6 |
7 |
7 |
QoS Configuration Commands at the ONU Side
qos cos-local-precedence-map
qos cos-local-precedence-map cos0-map-local-prec cos1-map-local-prec cos2-map-local-prec cos3-map-local-prec cos4-map-local-prec cos5-map-local-prec cos6-map-local-prec cos7-map-local-prec
undo qos cos-local-precedence-map
View
ONU port view
Default Level
2: System level
cos0-map-local-prec: Local precedence to which CoS 0 is to be mapped, in the range of 0 to 3.
cos1-map-local-prec: Local precedence to which CoS 1 is to be mapped, in the range of 0 to 3.
cos2-map-local-prec: Local precedence to which CoS 2 is to be mapped, in the range of 0 to 3.
cos3-map-local-prec: Local precedence to which CoS 3 is to be mapped, in the range of 0 to 3.
cos4-map-local-prec: Local precedence to which CoS 4 is to be mapped, in the range of 0 to 3.
cos5-map-local-prec: Local precedence to which CoS 5 is to be mapped, in the range of 0 to 3.
cos6-map-local-prec: Local precedence to which CoS 6 is to be mapped, in the range of 0 to 3.
cos7-map-local-prec: Local precedence to which CoS 7 is to be mapped, in the range of 0 to 3.
Use the qos cos-local-precedence-map command to configure the mappings between CoS precedence values to local precedence values on an ONU port.
Use the undo qos cos-local-precedence-map command to restore the mappings between CoS precedence values to local precedence values on an ONU port to defaults.
Table 6-3 shows the default CoS precedence values and the corresponding local precedence queues of the packets on an ONU port.
This command takes effect on the downlink data stream only.
Table 6-3 Default mapping between CoS precedence and local precedence
CoS precedence |
Local precedence |
0 |
0 |
1 |
0 |
2 |
1 |
3 |
1 |
4 |
2 |
5 |
2 |
6 |
3 |
7 |
3 |
# Configure the CoS precedence-to-local precedence mapping of the packets on the ONU port.
[Sysname] interface onu2/0/1:1
[Sysname-Onu2/0/1:1] qos cos-local-precedence-map 0 1 1 0 2 2 3 3
Table 6-4 shows the CoS precedence-to-local precedence mapping after the configuration is compete.
Table 6-4 CoS precedence-to-local precedence mapping
CoS precedence |
Local precedence |
0 |
0 |
1 |
1 |
2 |
1 |
3 |
0 |
4 |
2 |
5 |
2 |
6 |
3 |
7 |
3 |
uni classification-marking
uni uni-number classification-marking index index queue qid priority priority { selector operator matched-value } &<1-4>
undo uni uni-number classification-marking index index
View
ONU port view
Default Level
2: System level
uni-number: UNI number, in the range 1 to the number of UNI ports of the current ONU. The number of UNIs can be up to 80.
index: UNI index number, in the range 1 to 8. The match rule configured on the UNI port with the smallest index number is used first.
qid: Queue ID, in the range 0 to 7.
priority: Mapping priority, in the range 0 to 7.
selector: Match field.. Table 6-5 lists possible selector values.
operator: Match rule. Table 6-6 lists possible operator values.
matched-value: Match field value.
Selector |
always-match |
Perform a match on physical ports for traffic classification |
dst-ip |
Perform a match on the destination IP addresses of the packets |
dst-mac |
Perform a match on the destination MAC addresses of the packets |
dst-port |
Perform a match on the port numbers of the packets |
eth-pri |
Perform a match on the CoS precedence of the packets |
eth-type |
Perform a match on the Ethernet frame types of the packets |
ip-precedence |
Perform a match on the IP precedence of the packets |
ip-tos-dscp |
Perform a match on the ToS precedence or DSCP precedence of the packets |
ip-type |
Perform a match on the IP protocol types of the packets |
never-match |
Performs no traffic classification for the traffic received by the specified UNI port |
src-ip |
Perform a match on the source IP addresses of the packets |
src-mac |
Perform a match on the source MAC addresses of the packets |
src-port |
Perform a match on the source port numbers of the packets |
vlan-id |
Perform a match on the VLAN numbers of the packets |
Operator |
equal |
The value of matched-value is equal to that of the corresponding field of the packet. |
not-equal |
The value of matched-value is not equal to that of the corresponding field of the packet. |
greater-equal |
The value of matched-value is greater than or equal to that of the corresponding field of the packet. |
less-equal |
The value of matched-value is less than or equal to that of the corresponding field of the packet. |
exist |
The corresponding packet field exists. |
not-exist |
The corresponding packet field does not exist. |
Use the uni classification-marking command to map packets to different priority queues based on the configured keywords.
Use the undo uni classification-marking command to remove the configuration.
# Set the priority of packets whose destination MAC address is 000F-E2D7-925A to 3.
[Sysname-Onu2/0/1:1] uni 1 classification-marking index 1 queue 3 priority 3 dst-mac equal 000F-E2D7-925A
uni port-policy
uni uni-number port-policy { { inbound { cir cir-value | bucket-depth bucket-depth-value | extra-burst-size ebs-value }* } | outbound cir cir-value [ pir pir-value] }
undo uni uni-number port-policy { inbound | outbound }
View
ONU port view
Default Level
2: System level
inbound: Configure the traffic policing parameters for inbound packets on the UNI port.
cir-value: Specifies the committed information rate (CIR) value – guaranteed bandwidth in kbps.
bucket-depth-value: Bucket depth – the maximum burst bandwidth, in the range 1522 to 65535 bytes. The default is 1522.
ebs-value: Available extra bandwidth when the maximum burst bandwidth is exceeded. It is in the range 0 to 1522 bytes, and the default is 0.
pir-value: Specifies the peak information rate in kbps.
outbound: Configure the traffic policing parameters for outbound packets on the UNI port.
Use the uni port-policing command to configure the traffic policing parameters for the inbound/outbound packets on a UNI port.
Use the undo uni port-policy command to restore the traffic policing parameters for the inbound/outbound packets on a UNI port to defaults.
By default, no traffic policing parameter is configured for a UNI.
# Configure the traffic policing parameters for UNI 1.
[Sysname-Onu2/0/1:1] uni 1 port-policy inbound cir 25600 bucket-depth 5608 extra-burst-size 800
