H3C S7500E Series Command Manual(Release 6100 series V1.01)
HomeSupportSwitchesH3C S7500E Switch SeriesReference GuidesCommand ReferencesH3C S7500E Series Command Manual(Release 6100 series V1.01)
Title Size Downloads
21-QoS Commands.pdf 160.23 KB
21-QoS Commands
21-QoS Commands 160.23 KB
Table of Contents
Chapter 1 LR Configuration Commands. 1-1
1.1 LR Configuration Commands. 1-1
1.1.1 display qos lr interface. 1-1
1.1.2 qos lr outbound. 1-2
Chapter 2 QoS Policy Configuration Commands. 2-1
2.1 Commands for Defining Classes. 2-1
2.1.1 display traffic classifier 2-1
2.1.2 if-match. 2-2
2.1.3 traffic classifier 2-5
2.2 Traffic Behavior Configuration Commands. 2-6
2.2.1 accounting. 2-6
2.2.2 car 2-6
2.2.3 display traffic behavior 2-8
2.2.4 filter 2-9
2.2.5 nest 2-10
2.2.6 redirect 2-10
2.2.7 remark customer-vlan-id. 2-11
2.2.8 remark dot1p. 2-12
2.2.9 remark drop-precedence. 2-13
2.2.10 remark dscp. 2-13
2.2.11 remark ip-precedence. 2-15
2.2.12 remark local-precedence. 2-15
2.2.13 remark service-vlan-id. 2-16
2.2.14 traffic behavior 2-17
2.3 QoS Policy Configuration Commands. 2-18
2.3.1 classifier behavior 2-18
2.3.2 display qos policy. 2-19
2.3.3 display qos policy global 2-20
2.3.4 display qos policy interface. 2-21
2.3.5 display qos vlan-policy. 2-22
2.3.6 qos apply policy. 2-24
2.3.7 qos apply policy global 2-27
2.3.8 qos policy. 2-27
2.3.9 qos vlan-policy. 2-28
2.3.10 reset qos policy global 2-29
2.3.11 reset qos vlan-policy. 2-29
Chapter 3 Congestion Management Configuration Commands. 3-1
3.1 Congestion Management Configuration Commands. 3-1
3.1.1 display qos sp interface. 3-1
3.1.2 display qos wrr interface. 3-1
3.1.3 qos sp. 3-3
3.1.4 qos wrr 3-3
Chapter 4 Priority Mapping Configuration Commands. 4-1
4.1 Priority Mapping Table Configuration Commands. 4-1
4.1.1 display qos map-table. 4-1
4.1.2 qos map-table. 4-2
4.1.3 import 4-3
4.2 Port Priority Configuration Commands. 4-3
4.2.1 qos priority. 4-3
4.3 Port Priority Trust Mode Configuration Commands. 4-4
4.3.1 display qos trust interface. 4-4
4.3.2 qos trust 4-5
Chapter 5 Traffic Mirroring Configuration Commands. 5-1
5.1 Traffic Mirroring Configuration Commands. 5-1
5.1.1 mirror-to. 5-1
View
interface-type: Port type.
interface-number: Port number.
Use the display qos lr interface command to display the LR configuration information of a certain interface or all interfaces.
If the interface argument is not specified, this command will display the LR configuration information of all the interfaces.
# Display the LR configuration and statistics information of all the interfaces.
Interface: Ethernet2/0/10
Direction: Outbound
 CIR 64000 (kbps),  CBS 4000000 (byte)
Table 1-1 Description on the fields of the display qos lr command
Port name, composed of port type and port number
Direction
Specify the direction of limited rate as outbound
CIR
Committed information rate, in kbps
CBS
Committed burst size, in byte
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
View
Ethernet interface view, port group view
outbound: Limits the rate of the outbound traffic.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps.
cbs committed-burst-size: Specifies the committed burst size in bytes.
l           The committed-burst-size argument ranges from 4000 to 16000000.
l           If the cbs keyword is not used, the system uses the default committed burst size, that is, 500 ms x committed-information-rate, or 16000000 if the multiplication is more than 16000000.
Use the qos lr outbound command to limit the rate of outbound traffic via physical interfaces.
Use the undo qos lr outbound command to cancel the limit.
#  Limit the outbound traffic rate on Ethernet 2/0/1 within 640 kbps.
[Sysname] interface Ethernet 2/0/1
[Sysname-Ethernet2/0/1] qos lr outbound cir 640
display traffic classifier user-defined [ classifier-name ]
View
classifier-name: Class name.
Use the display traffic classifier command to display the information about a class.
If no class name is provided, this command displays the information about all the user-defined classes.
# Display the information about the user-defined classes.
  User Defined Classifier Information:
   Classifier: p
    Operator: AND
    Rule(s) : If-match acl 2001
Table 2-1 Description on the fields of the display traffic classifier user-defined command
The information about the user-defined classes is displayed.
Classifier
Class name and its contents, which could be of multiple types
Operator
Logical relationship among the classification rules
Rule
Classification rules
2.1.2  if-match
if-match match-criteria
undo if-match match-criteria
View
Class view
match-criteria: Matching rule to be defined. Table 2-2 describes the available forms of this argument.
Table 2-2 The forms of the match-criteria argument
acl access-list-number
Specifies an ACL to match packets. The access-list-number argument is in the range 2000 to 4999.
In a class configured with the operator and, the logical relationship between rules defined in the referenced IPv4 ACL is or.
acl ipv6 access-list-number
Specifies an IPv6 ACL to match IPv6 packets. The access-list-number argument is in the range 2000 to 3999.
In a class configured with the operator and, the logical relationship between rules defined in the referenced IPv6 ACL is or.
any
Specifies to match all packets.
customer-dot1p 8021p-list
Specifies to match packets by 802.1p precedence of the customer network. The 8021p-list argument is a list of CoS values. You can provide up to eight space-separated CoS values for this argument. CoS is in the range 0 to 7.
dscp dscp-list
Specifies to match packets by DSCP precedence. The dscp-list argument is a list of DSCP values. You can provide up to eight space-separated DSCP values for this argument. DSCP is in the range 0 to 63.
destination-mac mac-address
Specifies to match the packets with a specified destination MAC address.
ip-precedence ip-precedence-list
Specifies to match packets by IP precedence. The ip-precedence-list argument is a list of IP precedence values. You can provide up to eight space-separated IP precedence values for this argument. IP precedence is in the range 0 to 7.
protocol protocol-name
Specifies to match the packets of a specified protocol. The protocol-name argument can be IP or IPv6.
service-dot1p 8021p-list
Specifies to match packets by 802.1p precedence of the service provider network. The 8021p-list argument is a list of CoS values. You can provide up to eight space-separated CoS values for this argument. CoS is in the range 0 to 7.
source-mac mac-address
Specifies to match the packets with a specified source MAC address.
customer-vlan-id vlan-id-list
Specifies to match the packets of specified VLANs of user networks. The vlan-id-list argument specifies a list of VLAN IDs, in the form of vlan-id to vlan-id or multiple discontinuous VLAN IDs (separated by space). You can specify up to eight VLAN IDs for this argument at a time. VLAN ID is in the range 1 to 4094.
In a class configured with the operator and, the logical relationship between the customer VLAN IDs specified for the customer-vlan-id keyword is or.
service-vlan-id vlan-id-list
Specifies to match the packets of specified VLANs of the operator’s network. The vlan-id-list argument is a list of VLAN IDs, in the form of vlan-id to vlan-id or multiple discontinuous VLAN IDs (separated by space). You can specify up to eight VLAN IDs for this argument at a time. VLAN ID is in the range 1 to 4094.
In a class configured with the operator and, the logical relationship between the service VLAN IDs specified for the service-vlan-id keyword is or.
Use the if-match command to define a rule to match a specific type of packets.
Use the undo if-match command to remove a matching rule.
&  Note:
Suppose the logical relationship between classification rules is and. Note the following when using the if-match command to define matching rules.
l      If multiple matching rules with the acl or acl ipv6 keyword specified are defined in a class, the actual logical relationship between these rules is or when the policy is applied.
l      If multiple matching rules with the customer-vlan-id or service-vlan-id keyword specified are defined in a class, the actual logical relationship between these rules is or when the policy is applied.
# Define a rule for class1 to match the packets with their destination MAC addresses being 0050-ba27-bed3.
# Define a rule for class2 to match the packets with their source MAC addresses being 0050-ba27-bed2.
# Define a rule for class1 to match the advanced IPv4 ACL 3101.
# Define a rule for class1 to match the advanced IPv6 ACL 3101.
# Define a rule for class1 to match all the packets.
# Define a rule for class1 to match the packets with their DSCP precedence values being 1.
[Sysname-classifier-class1] if-match dscp 1
# Define a rule for class1 to match the packets with their IP precedence values being 1.
[Sysname-classifier-class1] if-match ip-precedence 1
# Define a rule for class 1 to match IP packets.
# Define a rule for class 1 to match the packets with the customer network 802.1p precedence 2.
[Sysname-classifier-class1] if-match customer-dot1p 2
# Define a rule for class 1 to match the packets with the service provider network 802.1p precedence 5.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a rule for class1 to match the packets of VLAN 1024 of the user networks.
[Sysname-classifier-class1] if-match customer-vlan-id 1024
# Define a rule for class1 to match the packets of VLAN 1000 of the operator’s network.
[Sysname-classifier-class1] if-match service-vlan-id 1000
View
and: Specifies the relationship among the rules in the class as logic AND. That is, a packet is matched only when it matches all the rules defined for the class.
or: Specifies the relationship among the rules in the class as logic OR. That is, a packet is matched if it matches a rule defined for the class.
classifier-name: Name of the class to be created.
Use the traffic classifier command to create a class. This command also leads you to class view.
Use the undo traffic classifier command to remove a class.
By default, a packet is matched only when it matches all the rules configured for the class.
# Create a class named class 1.
2.2.1  accounting
accounting
undo accounting
View
Traffic behavior view
None
Use the accounting command to configure the traffic accounting action for a traffic behavior.
Use the undo accounting command to remove the traffic accounting action.
Related commands: qos policy, traffic behavior, classifier behavior.
# Configure the traffic accounting action for a traffic behavior.
[Sysname-behavior-database] accounting
2.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ green action ] [ red action ] [ yellow action ]
undo car
View
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps. cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The committed-burst-size argument ranges from 4000 to 16000000, the default is 4000.
ebs excess-burst-size: Specifies excess burst size (EBS) in bytes. The excess-burst-size argument ranges from 0 to 16000000, the default is 4000.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps.
green action: Specifies the action to be conducted for the traffic conforming to CIR. The action argument can be:
l           discard: Drops the packets.
l           pass: Forwards the packets.
l           remark-dscp-pass new-dscp: Marks the packets with a new DSCP precedence and forwards them to their destinations. The new-dscp argument is in the range 0 to 63.
By default, packets conforming to CIR are forwarded.
red action: Specifies the action to be conducted for the traffic conforms to neither CIR nor PIR. The action argument can be:
By default, packets conforming to neither CIR nor PIR are dropped.
yellow action: Specifies the action to be conducted for the traffic conforms to PIR but does not conform to CIR. The action argument can be:
By default, packets conforming to PIR but not conforming to CIR are dropped.
Use the car command to configure TP action for a traffic behavior.
Use the undo car command to remove the TP action.
Note that, if you configure the TP action for a traffic behavior for multiple times, only the last configuration takes effect.
# Configure TP action for a traffic behavior. When the traffic rate is lower than 6400 kbps, packets are forwarded normally. When the traffic rate exceeds 6400 kbps, the packets beyond 6400 kbps are dropped.
[Sysname-behavior-database] car cir 6400 red discard
display traffic behavior user-defined [ behavior-name ]
View
behavior-name: Name of a user defined traffic behavior.
Use the display traffic behavior command to display the information about a user defined traffic behavior.
If no behavior name is provided, this command displays the information about all the user-defined behaviors.
# Display the information about all the user defined traffic behaviors.
  User Defined Behavior Information:
    Behavior: test
      Marking:
        Remark dot1p COS 4
      Committed Access Rate:
        CIR 640 (kbps), CBS 4000 (byte), EBS 4000 (byte), PIR 640 (kbps)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
Table 2-3 Description on the fields of the display traffic behavior user-defined command
The information about user defined traffic behaviors is displayed
Behavior
Name of a traffic behavior, which can be of multiple types
Marking
Information about priority marking
Information about traffic rate limit
CIR
Committed information rate in bytes
CBS
Committed burst size in bytes
EBS
Excessive burst size in bytes
PIR
Peak information rate in bytes
Green Action
Action conducted to packets conforming to CIR
Red Action
Action conducted for packets conforming to neither CIR nor PIR
Yellow Action
Action conducted to packets conforming to PIR but not conforming to CIR
2.2.4  filter
filter { deny | permit }
undo filter
View
deny: Drops packets.
permit: Forwards packets.
Use the filter command to configure traffic filtering action for a traffic behavior.
Use the undo filter command to remove the traffic filtering action.
# Configure traffic filtering action for a traffic behavior.
2.2.5  nest
nest top-most vlan-id vlan-id
undo nest
View
vlan-id vlan-id: ID of the VLAN. The vlan-id argument is in the range 1 to 4094.
Use the nest command configure an outer VLAN tag for a traffic behavior.
Use the undo nest command to remove the outer VLAN tag.
Note that the action of creating an outer VLAN tag cannot be configured simultaneously with any other action except the traffic filtering action or the action of setting 802.1p precedence in the same traffic behavior. And the action of creating an outer VLAN tag must be applied to basic QinQ-enabled ports or port groups. Otherwise, the corresponding QoS policy cannot be applied successfully.
# Configure an outer VLAN tag for a traffic behavior.
[Sysname-behavior-database] nest top-most vlan-id 100
2.2.6  redirect
redirect { cpu | interface interface-type interface-number | link-aggregation group agg-id | next-hop { ipv4-add [ ipv4-add ] | ipv6-add [ interface-type interface-number ] [ ipv6-add [ interface-type interface-number ] ] } }
undo redirect
View
cpu: Redirects traffic to the CPU.
interface interface-type interface-number: Redirects traffic to an interface identified by its type and number.
link-aggregation group agg-id: Redirects traffic to a manual aggregation group. The agg-id argument is an aggregation group ID. Note that the specified aggregation group must be an existing manual aggregation group.
next-hop: Specifies the next hop to redirect the traffic to.
ipv4-add: IPv4 address of the next hop.
ipv6-add: IPv6 address of the next hop. The interface-type interface-number argument is a VLAN interface number. If the IPv6 address is a link-local address, you must specify a VLAN interface for the IPv6 address of the next hop; if the IPv6 address is not a link-local address, you need not specify a VLAN interface for the IPv6 address of the next hop.
Use the redirect command to configure traffic redirecting action for a traffic behavior.
Use the undo redirect command to remove the traffic redirecting action.
# Configure the redirecting action to redirect traffic to Ethernet2/0/1 port.
[Sysname-behavior-database] redirect interface Ethernet 2/0/1
remark customer-vlan-id vlan-id-value
undo remark customer-vlan-id
View
vlan-id-value: VLAN ID to be set for packets, in the range of 1 to 4094.
Use the remark customer-vlan-id command to configure the action of setting the customer network VLAN ID for a traffic behavior.
Use the undo remark customer-vlan-id command to remove the action of setting the customer network VLAN ID.
Note that the action of setting the customer network VLAN ID cannot be applied to a VLAN or applied globally.
# Configure the action of setting the customer network VLAN ID to 2 for a traffic behavior.
[Sysname-behavior-database] remark customer-vlan-id 2
2.2.8  remark dot1p
remark dot1p 8021p
undo remark dot1p
View
8021p: 802.1p precedence to be set for packets, in the range 0 to 7.
Use the remark dot1p command to configure the action of setting 802.1p precedence for a traffic behavior.
Use the undo remark dot1p command to remove the action of setting 802.1p precedence
Note that, when the remark dot1p command is used together with the remark local-precedence command, the 802.1p precedence to be set for packets must be the same as the local precedence to be set for packets. Otherwise, the corresponding policy cannot be applied successfully..
# Configure the action to set 802.1p precedence to 2 for a traffic behavior.
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
View
drop-precedence-value: Drop precedence to be set for packets, in the range 0 to 2.
Use the remark drop-precedence command to configure the action of setting drop precedence for a traffic behavior.
Use the undo remark drop-precedence command to remove the action of setting drop precedence.
# Configure the action to set drop precedence to 2 for a traffic behavior.
[Sysname-behavior-database] remark drop-precedence 2
2.2.10  remark dscp
remark dscp dscp-value
undo remark dscp
View
dscp-value: DSCP precedence to be set for packets, in the range of 0 to 63. This argument can also be the keywords listed in Table 2-4.
Table 2-4 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
Use the remark dscp command to configure the action of setting DSCP precedence for a traffic behavior.
Use the undo remark dscp command to remove the action of setting DSCP precedence.
# Configure the action to set DSCP precedence to 6 for a traffic behavior.
remark ip-precedence ip-precedence-value
undo remark ip-precedence
View
ip-precedence-value: IP precedence to be set for packets, in the range of 0 to 7.
Use the remark ip-precedence command to configure the action of setting IP precedence for a traffic behavior.
Use the undo remark ip-precedence command to remove the action of setting IP precedence.
# Configure the action to set IP precedence to 6 for a traffic behavior.
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
View
local-precedence: Local precedence to be set for packets, in the range of 0 to 7.
Use the remark local-precedence command to configure the action of setting local precedence for a traffic behavior.
Use the undo remark local-precedence command to remove the action of remarking local precedence.
# Configure the action to set local precedence to 2 for a traffic behavior.
remark service-vlan-id vlan-id-value
undo remark service-vlan-id
View
Use the remark service-vlan-id command to configure the action of setting the service provider network VLAN ID for a traffic behavior.
Use the undo remark service-vlan-id command to remove the action of setting the service provider network VLAN ID.
Note that:
l           When the action of setting the service provider network VLAN ID is applied in the inbound direction, any other action except the traffic filtering action or the action of setting 802.1p precedence cannot be configured in the same traffic behavior. Otherwise, the corresponding QoS policy cannot be applied successfully.
l           The action of setting the service provider network VLAN ID cannot he applied to a VLAN or applied globally.
# Configure the action of setting the service provider network VLAN ID to 2 for a traffic behavior.
[Sysname-behavior-database] remark service-vlan-id 2
View
behavior-name: Name of the traffic behavior to be created.
Use the traffic behavior command to create a traffic behavior. This command also leads you to traffic behavior view.
Use the undo traffic classifier command to remove a traffic behavior.
Related commands: qos policy, qos apply policy, classifier behavior.
# Define a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
classifier classifier-name behavior behavior-name
View
Policy view
classifier-name: Name of an existing class.
behavior–name: Name of an existing traffic behavior.
Use the classifier behavior command to associate a traffic behavior with a class.
Use the undo classifier command to remove a class from a policy.
Note that each class can be associated with only one traffic behavior.
Related commands: qos policy.
&  Note:
In a QoS policy with multiple class-to-traffic-behavior associations, if the action of creating an outer VLAN tag, the action of setting customer network VLAN ID, or the action of setting service provider network VLAN ID is configured in a traffic behavior, we recommend you not to configure any other action in this traffic behavior. Otherwise, the QoS policy may not function as expected after it is applied.
# Associate the behavior named test with the class named database in the policy user1.
[Sysname] qos policy user1
display qos policy user-defined [ policy-name [ classifier classifier-name ] ]
View
policy-name: Policy name. If it is not provided, the configuration of all the user defined policies is displayed.
classifier-name: Name of a class in the policy. If it is not provided, all the classes in the policy are specified.
Use the display qos policy command to display the configuration of a specified policy, including the configuration of the classes and the associated traffic behaviors in the policy.
# Display the configuration of all the user specified policies.
  User Defined QoS Policy Information:
  Policy: test
   Classifier: test
     Behavior: test
      Accounting Enable
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
Table 2-5 Description on the fields of the display qos policy command
Policy
Policy name
Classifier
Class name and the corresponding configuration information
Behavior
Traffic behavior name and the corresponding configuration information
display qos policy global { inbound | outbound } [ slot slot-id ]
View
inbound: Displays the QoS policy applied globally in the inbound direction of all ports.
outbound: Displays the QoS policy applied globally in the outbound direction of all ports.
slot slot-number: Displays the global QoS policy applied on a board. If the slot-number argument is not specified, the global QoS policy applied on the main control board are displayed.
Use the display qos policy global command to display information about a global QoS policy.
# Display information about the global QoS policy in the inbound direction.
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: test
   Classifier: test
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: test
      Accounting Enable:
        0 (Packets)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
        Green : 0(Packets)
Table 2-6 Description on the fields of the display qos policy global command
Direction
Direction in which the policy is applied globally
Policy
Policy name
Classifier
Class name
Behavior
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
View
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
Use the display qos policy interface command to display the configuration and statistics information about the policy applied on a port.
If no interface is provided, the configuration and statistics information about the policies applied on all the ports is displayed.
# Display the configuration and statistics information about the policy applied on Ethernet2/0/1 port.
<Sysname> display qos policy interface Ethernet 2/0/1
  Direction: Inbound
  Policy: test
   Classifier: test
     Operator: AND
     Behavior: test
      Marking:
        Remark dot1p COS 4
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
        Green : 0(Packets)
Table 2-7 Description on the fields of the display qos policy interface command
Port name, comprising of port type and port number
Direction
Direction of the port where the policy is applied
Policy
Name of the policy applied to the port
Classifier
Name of the class in the policy and its configuration
Operator
Logical relationship among the classification rules in a class
Rule(s)
Classification rules in the class
Behavior
Name of the behavior in the policy and its configuration
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-id ]
View
name policy-name: Specifies to display the information about the VLAN policy with the specified name.
vlan vlan-id: Specifies to display the information about the VLAN policy applied to the specified VLAN.
slot-id: Specifies to display the information about the VLAN policies applied to VLANs on the board seated in the specific slot. If the slot-id argument is not specified, this command displays the information about the VLAN policies applied to the SRPU.
Use the display qos vlan-policy command to display the information about VLAN policies.
If the vlan-id argument is not specified, the information about all the VLAN policies will be displayed.
# Display the information about the VLAN policy named test.
<Sysname> display qos vlan-policy name test
  Policy test
    Vlan 300: inbound
Table 2-8 Description on the fields of the display qos vlan-policy command
Policy
Name of the VLAN policy
Vlan 300
ID of the VLAN where the VLAN policy is applied
inbound
VLAN policy is applied in the inbound direction of the VLAN.
# Display the information about the VLAN policy applied to VLAN 300.
<Sysname> display qos vlan-policy vlan 300
  Vlan 300
  Direction: Inbound
  Policy: test
   Classifier: test
     Operator: AND
     Rule(s) : If-match customer-vlan-id 3
     Behavior: test
      Accounting Enable:
        0 (Packets)
        CIR 6400 (kbps), CBS 4000 (byte), EBS 4000 (byte)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
        Green : 0(Packets)
Table 2-9 Description on the fields of the display qos vlan-policy command
Vlan 300
Inbound
Classifier
Behavior
undo qos apply policy { inbound | outbound }
View
Ethernet port view, port group view
policy-name: Specifies the policy name.
Use the qos apply policy command to apply a policy on a port or a port group.
Use the undo qos apply policy command to remove the policy applied on a port or a port group.
Note that, when you apply a policy by using the qos apply policy command, whether or not the inbound/outbound keyword can take effect depends on the actions defined in the traffic behavior and LPU types, as described in Table 2-10.
Table 2-10 The support for the inbound direction and the outbound direction
LPU type
Action
SC LPU
SA LPU
EA LPU
Inbound
Outbound
Inbound
Outbound
Inbound
Outbound
Traffic accounting
Supported
Supported
Supported
Not supported
Supported
Not supported
TP
Supported
Supported
Supported
Not supported
Supported
Not supported
Traffic filtering
Supported
Supported
Supported
Not supported
Supported
Not supported
Traffic mirroring
Supported
Supported
Supported
Not supported
Supported
Not supported
Configuring the outer VLAN tag
Supported
Not supported
Supported
Not supported
Supported
Not supported
Traffic redirecting
Supported
Not supported
Supported
Not supported
Supported
Not supported
Remarking the customer network VLAN ID for packets
Not supported
Supported
Not supported
Not supported
Not supported
Not supported
Remarking the 802.1p precedence for packets
Supported
Supported
Supported
Not supported
Supported
Not supported
Remarking the drop precedence for packets
Supported
Not supported
Supported
Not supported
Supported
Not supported
Remarking the DSCP precedence for packets
Supported
Supported
Supported
Not supported
Supported
Not supported
Remarking the IP precedence for packets
Supported
Supported
Supported
Not supported
Supported
Not supported
Remarking the local precedence for packets
Supported
Not supported
Supported
Not supported
Supported
Not supported
Remarking the service provider network VLAN ID for packets
Supported
Supported
Supported
Not supported
Supported
Not supported
&  Note:
SC LPUs include LSQ1GP24SC LPUs and so on, SA LPUs include LSQ1FP48SA LPUs and so on, EA LPUs include LSQ1GP12EA LPUs. For the detailed information about LPU types, refer to the installation manual.
  Caution:
You can apply a QoS policy in the outbound direction of a basic QinQ-enabled port on an SA LPU or EA LPU to implement one-to-one VLAN mapping. In this policy, only one matching rule, if-match service-vlan-id, can be defined, and the action can only be remark customer-vlan-id or remark customer-vlan-id together with remark dot1p.
# Apply the policy named test in the inbound direction of Ethernet2/0/1 port.
[Sysname-Ethernet2/0/1] qos apply policy test inbound
undo qos apply policy global { inbound | outbound }
View
inbound: Applies the QoS policy to the incoming packets on all ports.
outbound: Applies the QoS policy to the outgoing packets on all ports.
Use the qos apply policy global command to apply a QoS policy globally. A QoS policy applied globally takes effect on all inbound or outbound traffic depending on the direction in which the policy is applied.
Use the undo qos apply policy global command to cancel the global application of the QoS policy.
Note that, when you apply a QoS policy with the qos apply policy global command, support for the inbound/outbound keyword depends on the actions defined in the traffic behavior and LPU types, as described in Table 2-10.
# Apply the QoS policy user1 in the inbound direction globally.
[Sysname] qos apply policy user1 global inbound
2.3.8  qos policy
qos policy policy-name
undo qos policy policy-name
View
policy-name: Name of the policy to be created.
Use the qos policy command to create a policy. This command also leads you to policy view.
Use the undo qos policy command to remove a policy.
To remove a policy that is currently applied on a port, you need to disable it on the port first.
Related commands: classifier behavior, qos apply policy.
# Create a policy named user1.
undo qos vlan-policy vlan vlan-id-list { inbound | outbound }
View
vlan-id-list: List of VLAN IDs, presented in the form of vlan-id to vlan-id or discontinuous VLAN IDs. Up to eight VLAN IDs can be specified at a time.
inbound: Specifies to apply the VLAN policy in the inbound direction of the VLAN.
outbound: Specifies to apply the VLAN policy in the outbound direction of the VLAN.
Use the qos vlan-policy command to apply the VLAN policy to the specific VLAN(s).
Use the undo qos vlan-policy command to remove the VLAN policy from the specific VLAN(s).
Note that, when you apply a QoS policy with the qos vlan-policy command, support for the inbound/outbound keyword varies with the actions defined in the traffic behavior and the type of the LPU to which the ports in the VLAN belong, as described in Table 2-10.
&  Note:
Do not apply policies to a VLAN and the ports in the VLAN at the same time.
# Apply the VLAN policy named test in the inbound direction of VLAN 200, VLAN 300, VLAN 400, VLAN 500, VLAN 600, VLAN 700, VLAN 800, and VLAN 900.
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
reset qos policy global { inbound | outbound }
View
Use the reset qos vlan-policy command to clear the statistics of a global QoS policy.
# Clear the statistics of the global QoS policy in the inbound direction.
<Sysname> reset qos policy global inbound
reset qos vlan-policy [ vlan vlan-id ]
View
vlan-id: VLAN ID, in the range 1 to 4,094.
Use the reset qos vlan-policy command to clear the statistics information about VLAN policies.
# Clear the statistics information about the VLAN policy applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
display qos sp interface [ interface-type interface-number ]
View
Use the display qos sp interface command to display the strict priority (SP) queuing configuration on a specified port.
If no port is specified, this command displays the SP queuing configuration on all ports.
Related commands: qos sp.
# Display the SP queuing configuration on Ethernet 2/0/1.
<Sysname> display qos sp interface Ethernet 2/0/1
Output queue: Strict-priority queue
display qos wrr interface [ interface-type interface-number ]
View
Use the display qos wrr interface command to display the configuration of weighted round robin (WRR) queues of a port.
If no port number is specified, the command displays the configurations of WRR queues of all ports.
Related commands: qos wrr.
# Display the configuration of WRR queues of Ethernet 2/0/1.
<Sysname> display qos wrr interface Ethernet 2/0/1
Output queue:   Weighted round robin queue
Queue ID    Group    Weight
   0         sp       N/A
   1         sp       N/A
   2         1        3
   3         1        4
   4         1        5
   5         1        6
   6         1        7
   7         1        8
Table 3-1 Description on the fields of the display qos wrr interface command
Output queue
The type of the current output queue
Queue ID
ID of the queue
Group
Group ID, indicating which group a queue belongs to.
Weight
The weight of each queue during scheduling. N/A indicates that SP queue scheduling algorithm is adopted.
3.1.3  qos sp
qos sp
undo qos sp
View
None
Use the qos sp command to configure SP queuing on the current port.
Use the undo qos sp command to restore the default queuing algorithm on the port.
By default, the switch adopts the SP queue-scheduling algorithm.
Related commands: display qos sp interface.
# Configure SP queuing on Ethernet 2/0/1.
<H3C> system-view
[H3C] interface Ethernet 2/0/1
[H3C-Ethernet2/0/1] qos sp
3.1.4  qos wrr
qos wrr queue-id group { sp | group-id weight queue-weight }
undo qos wrr
View
queue-id: ID of the queue, in the range of 0 to 7.
group-id: It can only be 1.
weight schedule-value: Specifies the scheduling weight of a queue, rang from 1 to 15.
sp: Configures SP queuing.
Use the qos wrr command to configure Weighted Round Robin (WRR) queue scheduling algorithm or the SP + WRR queue scheduling algorithm on a port or port group.
Use the undo qos wrr command to restore the default queue-scheduling algorithm on the port.
As required, you can configure part of the queues on the port to adopt the SP queue-scheduling algorithm and parts of queues to adopt the WRR queue-scheduling algorithm. Through adding the queues on a port to the SP scheduling group and WRR scheduling group (namely, group 1), the SP + WRR queue scheduling is implemented. During the queue scheduling process, the queues in the SP scheduling group is scheduled preferentially. When no packet is to be sent in the queues in the SP scheduling group, the queues in the WRR scheduling group are scheduled. The queues in the SP scheduling group are scheduled according to the strict priority of each queue, while the queues in the WRR queue scheduling group are scheduled according the weight value of each queue.
Related commands: display qos wrr interface.
# Configure SP+WRR queue scheduling algorithm on Ethernet 2/0/1 as follows: assign queue 0, queue 1, queue 2, and queue 3 to the SP scheduling group; and assign queue 4, queue 5, queue 5, and queue 7 to WRR scheduling group, with the weight 2, 4, 6, and 8.
[Sysname-Ethernet2/0/1] qos wrr
[Sysname-Ethernet2/0/1] qos wrr 0 group sp
[Sysname-Ethernet2/0/1] qos wrr 1 group sp
[Sysname-Ethernet2/0/1] qos wrr 2 group sp
[Sysname-Ethernet2/0/1] qos wrr 3 group sp
[Sysname-Ethernet2/0/1] qos wrr 4 group 1 weight 2
[Sysname-Ethernet2/0/1] qos wrr 5 group 1 weight 4
[Sysname-Ethernet2/0/1] qos wrr 6 group 1 weight 6
[Sysname-Ethernet2/0/1] qos wrr 7 group 1 weight 8
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp ]
View
dot1p-lp: Specifies the 802.1p precedence-to-local precedence mapping table.
dot1p-dp: Specifies the 802.1p precedence-to-drop precedence mapping table.
dscp-dp: Specifies the DSCP-to-drop precedence mapping table.
dscp-dot1p: Specifies the DSCP-to-802.1p precedence mapping table.
dscp-dscp: Specifies the DSCP-to-DSCP mapping table.
Use the display qos map-table command to display the configuration of a priority mapping table.
If the type of the priority mapping table is not specified, the configuration of all the priority mapping tables is displayed.
Related commands: qos map-table.
# Display the configuration of the 802.1p precedence-to-drop precedence mapping table.
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    2
   2    :    2
   3    :    1
   4    :    1
   5    :    1
   6    :    0
   7    :    0
Table 4-1 Description on the fields of the display qos map-table command
MAP-TABLE NAME
Name of the mapping table
TYPE
Type of the mapping table
IMPORT
Input entries of the mapping table
EXPORT
Output entries of the mapping table
4.1.2  qos map-table
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp }
View
Use the qos map-table command to enter specific priority mapping table view.
Related commands: display qos map-table.
# Enter 802.1p precedence-to-drop precedence mapping table view.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp]
4.1.3  import
View
Priority mapping table view
import-value-list: List of input parameters.
export-value: Output parameter in the mapping table.
all: Removes all the parameters in the priority mapping table.
Use the import command to configure entries for a priority mapping table, that is, to define one or more mapping rules.
Use the undo import command to restore specific entries of a priority mapping table to the default.
Note that, you cannot configure to map any DSCP value to drop precedence 1.
# Configure the 802.1p precedence-to-drop precedence mapping table to map 802.1p precedence 4 and 5 to drop precedence 1.
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
4.2.1  qos priority
qos priority priority-value
undo qos priority
View
priority-value: Port priority to be configured. This argument is in the range 0 to 7.
Use the qos priority command to set the port priority for a port.
Use the undo qos priority command to restore the default port priority.
By default, the port priority is 0.
Note that, if a port receives packets without an 802.1q tag, the switch takes the priority of the receiving port as the 802.1p precedence of the packets and then searches the dot1p-dp/lp mapping table for the local/drop precedence for the packets according to the priority of the receiving port.
# Set the port priority of Ethernet2/0/1 port to 2.
[Sysname-Ethernet2/0/1] qos priority 2
View
Use the display qos trust interface command to display the port priority trust mode of a port.
If no port is specified, this command displays the port priority trust modes of all the ports.
# Display the port priority trust mode of Ethernet2/0/1 port.
<Sysname> display qos trust interface Ethernet 2/0/1
Port priority information
Port priority :0
Port priority trust type : dscp
Table 4-2 Description on the fields of the display qos trust interface command
Port priority
Port priority
Port priority trust mode
l      dscp indicates that the DSCP precedence of the received packets is trusted
l      untrust indicates that the 802.1p precedence of the received packets is trusted
4.3.2  qos trust
qos trust dscp
undo qos trust
View
dscp: Specifies to trust DSCP precedence carried in the packet and adopt this priority for priority mapping.
Use the qos trust command to configure the port priority trust mode.
Use the undo qos trust command to restore the default port priority trust mode.
By default, the 802.1p precedence of the received packets is trusted.
# Specify to trust the DSCP precedence carried in packets on Ethernet 2/0/1 port.
[Sysname-Ethernet2/0/1] qos trust dscp
5.1.1  mirror-to
mirror-to { cpu | interface interface-type interface-number }
undo mirror-to { cpu | interface interface-type interface-number }
View
cpu: Redirects packets to the CPU.
interface interface-type interface-number: Port type and port number of the destination port for the traffic mirroring action.
Use the mirror-to command to configure traffic mirroring action for a traffic behavior.
Use the undo mirror-to command to remove the traffic mirroring action.
Note that when the action of mirroring traffic is applied in the outbound direction, any other action cannot be configured in the same traffic behavior. Otherwise, the corresponding QoS policy cannot be applied successfully.
# Configure traffic behavior 1 and define the action of mirroring traffic to Ethernet2/0/2 in the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface Ethernet 2/0/2
