06-Security Volume
HomeSupportSwitchesH3C S3610[S5510] Switch SeriesConfigure & DeployConfiguration GuidesH3C S3610[S5510] Series Ethernet Switches Operation Manual-Release 5309-6W10006-Security Volume
06-Security Volume
Title Size Downloads
09-PKI Configuration.pdf 197.54 KB
Table of Contents
Related Documents
09-PKI Configuration 197.54 KB
PKI Configuration
When configuring PKI, go to these sections for information you are interested in:
l          Introduction to PKI
l          PKI Configuration Task List
l          Displaying and Maintaining PKI
l          PKI Configuration Examples
l          Troubleshooting PKI
Introduction to PKI
This section covers these topics:
l          PKI Overview
l          PKI Terms
l          Architecture of PKI
l          Applications of PKI
l          Operation of PKI
PKI Overview
The Public Key Infrastructure (PKI) is a hierarchical framework designed for providing information security through public key technologies and digital certificates and verifying the identities of the digital certificate owners.
PKI employs digital certificates, which are bindings of certificate owner identity information and public keys. PKI allows users to obtain certificates, use certificates, and revoke certificates. By leveraging digital certificates and relevant services like certificate distribution and blacklist publication, PKI supports authenticating the entities involved in communication, and thus guaranteeing the confidentiality, integrity and non-repudiation of data.
PKI Terms
Digital certificate
A digital certificate is a file signed by a certificate authority (CA) that contains a public key and the related user identity information. A simplest digital certificate contains a public key, an entity name, and a digital signature from the CA. Generally, a digital certificate also includes the validity period of the key, the name of the CA and the sequence number of the certificate. A digital certificate must comply with the international standard of ITU-T X.509. This manual involves two types of certificates: local certificate and CA certificate. A local certificate is a digital certificate signed by a CA for an entity, while a CA certificate, also known as root certificate, is signed by the CA for itself.
CRL
An existing certificate may need to be revoked when, for example, the user name changes, the private key leaks, or the user stops the business. Revoking a certificate is to remove the binding of the public key with the user identity information. In PKI, the revocation is made through certificate revocation lists (CRLs). Whenever a certificate is revoked, the CA publishes one or more CRLs to show all certificates that have been revoked. The CRLs contain the serial numbers of all revoked certificates and provide an effective way for checking the validity of certificates.
A CA may publish multiple CRLs when the number of revoked certificates is so large that publishing them in a single CRL may degrade network performance.
CA policy
A CA policy is a set of criteria that a CA follows in processing certificate requests, issuing and revoking certificates, and publishing CRLs. Usually, a CA advertises its policy in the form of certification practice statement (CPS). A CA policy can be acquired through out-of-band means such as phone, disk, and e-mail. As different CAs may use different methods to check the binding of a public key with an entity, make sure that you understand the CA policy before selecting a trusted CA for certificate request.
Architecture of PKI
A PKI system consists of entities, a CA, a registration authority (RA) and a PKI repository, as shown in Figure 1-1.
Figure 1-1 PKI architecture
Entity
An entity is an end user of PKI products or services, such as a person, an organization, a device like a switch, or a process running on a computer.
CA
A CA is a trusted authority responsible for issuing and managing digital certificates. A CA issues certificates, specifies the validity periods of certificates, and revokes certificates as needed by publishing CRLs.
RA
A registration authority (RA) is an extended part of a CA or an independent authority. An RA can implement functions including identity authentication, CRL management, key pair generation and key pair backup. The PKI standard recommends that an independent RA be used for registration management to achieve higher security of application systems.
PKI repository
A PKI repository can be a Lightweight Directory Access Protocol (LDAP) server or a common database. It stores and manages information like certificate requests, certificates, keys, CRLs and logs while providing a simple query function.
LDAP is a protocol for accessing and managing PKI information. An LDAP server stores user information and digital certificates from the RA server and provides directory navigation service. From an LDAP server, an entity can retrieve local and CA certificates of its own as well as certificates of other entities.
Applications of PKI
The PKI technology can satisfy the security requirements of online transactions. As an infrastructure, PKI has a wide range of applications. Here are some application examples.
VPN
A virtual private network (VPN) is a private data communication network built on the public communication infrastructure. A VPN can leverage network layer security protocols (for instance, IPSec) in conjunction with PKI-based encryption and digital signature technologies for confidentiality.
Secure E-mail
E-mails require confidentiality, integrity, authentication, and non-repudiation. PKI can address these needs. The secure E-mail protocol that is currently developing rapidly is Secure/Multipurpose Internet Mail Extensions (S/MIME), which is based on PKI and allows for transfer of encrypted mails with signature.
Web security
For Web security, two peers can establish a Secure Sockets Layer (SSL) connection first for transparent and secure communications at the application layer. With PKI, SSL enables encrypted communications between a browser and a server. Both the communication parties can verify the identity of each other through digital certificates.
Operation of PKI
In a PKI-enabled network, an entity can request a local certificate from the CA and the device can check the validity of certificates. Here is how it works:
1)        An entity submits a certificate request to the RA.
2)        The RA reviews the identity of the entity and then sends the identity information and the public key with a digital signature to the CA.
3)        The CA verifies the digital signature, approves the application, and issues a certificate.
4)        The RA receives the certificate from the CA, sends it to the LDAP server to provide directory navigation service, and notifies the entity that the certificate is successfully issued.
5)        The entity retrieves the certificate. With the certificate, the entity can communicate with other entities safely through encryption and digital signature.
6)        The entity makes a request to the CA when it needs to revoke its certificate, while the CA approves the request, updates the CRLs and publishes the CRLs on the LDAP server.
Complete the following tasks to configure PKI:
Remarks
Configuring an Entity DN
Required
Configuring a PKI Domain
Required
Submitting a PKI Certificate Request
Submitting a Certificate Request in Auto Mode
Required
Use either approach
Submitting a Certificate Request in Manual Mode
Retrieving a Certificate Manually
Optional
Configuring PKI Certificate
Optional
Destroying a Local RSA Key Pair
Optional
Deleting a Certificate
Optional
Configuring an Access Control Policy
Optional
A certificate is the binding of a public key and the identity information of an entity, where the identity information is identified by an entity distinguished name (DN). A CA identifies a certificate applicant uniquely by entity DN.
An entity DN is defined by these parameters:
l          Common name of the entity.
l          Country code of the entity, a standard 2-character code. For example, CN represents China and US represents the United States of America.
l          Fully qualified domain name (FQDN) of the entity, a unique identifier of an entity on the network. It consists of a host name and a domain name and can be resolved to an IP address. For example, www.whatever.com is an FQDN, where www is a host name and whatever.com a domain name.
l          IP address of the entity.
l          Locality where the entity resides.
l          Organization to which the entity belongs.
l          Unit of the entity in the organization.
l          State where the entity resides.
The configuration of an entity DN must comply with the CA certificate issue policy. You need to determine, for example, which entity DN parameters are mandatory and which are optional. Otherwise, certificate request may be rejected.
Follow these steps to configure an entity DN:
To do…
Use the command…
Remarks
Enter system view
Create an entity and enter its view
pki entity entity-name
Required
No entity exists by default.
Configure the common name for the entity
common-name name
Optional
No common name is specified by default.
Configure the country code for the entity
country country-code-str
Optional
No country code is specified by default.
Configure the FQDN for the entity
fqdn name-str
Optional
No FQDN is specified by default.
Configure the IP address for the entity
ip ip-address
Optional
No IP address is specified by default.
Configure the locality of the entity
locality locality-name
Optional
No locality is specified by default.
Configure the organization name for the entity
organization org-name
Optional
No organization is specified by default.
Configure the unit name for the entity
organization-unit org-unit-name
Optional
No unit is specified by default.
Configure the state or province for the entity
state state-name
Optional
No state or province is specified by default.
l          Currently, up to two entities can be created on a device.
l          The Windows 2000 CA server has some restrictions on the data length of a certificate request. If the entity DN in a certificate request goes beyond a certain limit, the server will not respond to the certificate request.
Before requesting a PKI certificate, an entity needs to be configured with some enrollment information, which is referred to as a PKI domain. A PKI domain is intended only for convenience of reference by other applications like SSL, and has only local significance.
A PKI domain is defined by these parameters:
l          Trusted CA
An entity requests a certificate from a trusted CA.
l          Entity
A certificate applicant uses an entity to provide its identity information to a CA.
l          RA
Generally, an independent RA is in charge of certificate request management. It receives the registration request from an entity, checks its qualification, and determines whether to ask the CA to sign a digital certificate. The RA only checks the application qualification of an entity; it does not issue any certificate. Sometimes, the registration management function is provided by the CA, in which case no independent RA is required. You are recommended to deploy an independent RA.
l          URL of the registration server
An entity sends a certificate request to the registration server through Simple Certification Enrollment Protocol (SCEP), a dedicated protocol for an entity to communicate with a CA.
l          Polling interval and count
After an applicant makes a certificate request, the CA may need a long period of time if it verifies the certificate request manually. During this period, the applicant needs to query the status of the request periodically to get the certificate as soon as possible after the certificate is signed. You can configure the polling interval and count to query the request status.
l          IP address of the LDAP server
An LDAP server is usually deployed to store certificates and CRLs. If this is the case, you need to configure the IP address of the LDAP server.
l          Fingerprint for root certificate verification
Upon receiving the root certificate of the CA, an entity needs to verify the fingerprint of the root certificate, namely, the hash value of the root certificate content. This hash value is unique to every certificate. If the fingerprint of the root certificate does not match the one configured for the PKI domain, the entity will reject the root certificate.
Follow these steps to configure a PKI domain:
To do…
Use the command…
Remarks
Enter system view
Create a PKI domain and enter its view
pki domain domain-name
Required
No PKI domain exists by default.
Specify the trusted CA
ca identifier name
Required
No trusted CA is specified by default.
Specify the entity for certificate request
certificate request entity entity-name
Required
No entity is specified by default.
The specified entity must exist.
Specify the authority for certificate request
certificate request from { ca | ra }
Required
No authority is specified by default.
Configure the URL of the server for certificate request
certificate request url url-string
Required
No URL is configured by default.
Configure the polling interval and attempt limit for querying the certificate request status
certificate request polling { count count | interval minutes }
Optional
The polling is executed for up to 50 times at the interval of 20 minutes by default.
Specify the LDAP server
ldap-server ip ip-address [ port port-number ] [ version version-number ]
Optional
No LDP server is specified by default.
Configure the fingerprint for root certificate verification
root-certificate fingerprint { md5 | sha1 } string
Required
No fingerprint is configured by default.
l          Currently, up to two PKI domains can be created on a device.
l          The CA name is required only when you retrieve a CA certificate. It is not used when in local certificate request.
l          Currently, the URL of the server for certificate request does not support domain name resolving.
When requesting a certificate, an entity introduces itself to the CA by providing its identity information and public key, which will be the major components of the certificate. A certificate request can be submitted to a CA in two ways: online and offline. In offline mode, a certificate request is submitted to a CA by an “out-of-band” means such as phone, disk, or e-mail.
Online certificate request falls into two categories: manual mode and auto mode.
In auto mode, an entity automatically requests a certificate through the SCEP protocol when it has no local certificate or the present certificate is about to expire.
Follow these steps to configure an entity to submit a certificate request in auto mode:
To do…
Use the command…
Remarks
Enter system view
Enter PKI domain view
Set the certificate request mode to auto
certificate request mode auto [ key-length key-length | password { cipher | simple } password ] *
Required
Manual by default
In manual mode, you need to retrieve a CA certificate, generate a local RSA key pair, and submit a local certificate request for an entity.
The goal of retrieving a CA certificate is to verify the authenticity and validity of a local certificate.
Generating an RSA key pair is an important step in certificate request. The key pair includes a public key and a private key. The private key is kept by the user, while the public key is transferred to the CA along with some other information. For detailed information about RSA key pair configuration, refer to SSH2.0 Configuration in the Security Volume.
Follow these steps to submit a certificate request in manual mode:
To do…
Use the command…
Remarks
Enter system view
Set the certificate request mode to manual
certificate request mode manual
Optional
Manual by default
Return to system view
Retrieve a CA certificate manually
Refer to Retrieving a Certificate Manually
Required
Generate a local RSA key pair
public-key local create rsa
Required
No local RSA key pair exists by default.
Submit a local certificate request manually
pki request-certificate domain domain-name [ password ] [ pkcs10 [ filename filename ] ]
Required
l          If a PKI domain already has a local certificate, creating an RSA key pair will result in inconsistency between the key pair and the certificate. To generate a new RSA key pair, delete the local certificate and then issue the public-key local create command. For information about the public-key local create command, refer to SSH2.0 Commands in the Security Volume.
l          A newly created key pair will overwrite the existing one. If you perform the public-key local create command in the presence of a local RSA key pair, the system will ask you whether you want to overwrite the existing one.
l          If a PKI domain has already a local certificate, you cannot request another certificate for it. This is to avoid inconsistency between the certificate and the registration information resulting from configuration changes. To request a new certificate, use the pki delete-certificate command to delete the existing local certificate and the CA certificate stored locally.
l          When it is impossible to request a certificate from the CA through SCEP, you can save the request information by using the pki request-certificate domain command with the pkcs10 and filename keywords, and then send the file to the CA by an out-of-band means.
l          Make sure the clocks of the entity and the CA are synchronous. Otherwise, the validity period of the certificate will be abnormal.
l          The pki request-certificate domain configuration will not be saved in the configuration file.
You can download an existing CA certificate, local certificate, or peer entity certificate from the CA server and save it locally. To do so, you can use two ways: online and offline. In offline mode, you need to retrieve a certificate by an out-of-band means like FTP, disk, e-mail and then import it into the local PKI system.
Certificate retrieval serves two purposes:
l          Locally store the certificates associated with the local security domain for improved query efficiency and reduced query count,
l          Prepare for certificate verification.
Before retrieving a local certificate, be sure to complete LDAP server configuration.
Follow these steps to retrieve a certificate manually:
To do…
Use the command…
Remarks
Enter system view
Retrieve a certificate manually
Online
pki retrieval-certificate { ca | local } domain domain-name
Required
Use either command.
Offline
pki import-certificate { ca | local } domain domain-name { der | p12 | pem } [ filename filename ]
l          If a PKI domain already has a CA certificate, you cannot retrieve another CA certificate for it. This is in order to avoid inconsistency between the certificate and registration information due to related configuration changes. To retrieve a new CA certificate, use the pki delete-certificate command to delete the existing CA certificate and local certificate first.
l          The pki retrieval-certificate configuration will not be saved in the configuration file.
Configuring PKI Certificate Verification
A certificate needs to be verified before being used. Verifying a certificate is to check that the certificate is signed by the CA and that the certificate has neither expired nor been revoked.
Before verifying a certificate, you need to retrieve the CA certificate.
You can specify whether CRL checking is required in certificate verification. If you enable CRL checking, CRLs will be used in verification of a certificate.
Configuring CRL-checking-enabled PKI certificate verification
Follow these steps to configure CRL-checking-enabled PKI certificate verification:
To do…
Use the command…
Remarks
Enter system view
Specify the URL of the CRL distribution point
crl url url-string
Optional
No CRL distribution point URL is specified by default.
Set the CRL update period
crl update-period hours
Optional
By default, the CRL update period depends on the next update field in the CRL file.
Enable CRL checking
crl check enable
Optional
Enabled by default
Retrieve the CA certificate
Required
Retrieve CRLs
pki retrieval-crl domain domain-name
Required
Verify the validity of a certificate
pki validate-certificate { ca | local } domain domain-name
Required
Configuring CRL-checking-disabled PKI certificate verification
Follow these steps to configure CRL-checking-disabled PKI certificate verification:
To do…
Use the command…
Remarks
Enter system view
Disable CRL checking
crl check disable
Required
Enabled by default
Required
Verify the validity of the certificate
Required
l          The CRL update period refers to the interval at which the entity downloads CRLs from the CRL server. The CRL update period configured manually is prior to that specified in the CRLs.
l          The pki retrieval-crl domain configuration will not be saved in the configuration file.
l          Currently, the URL of the CRL distribution point does not support domain name resolving.
A certificate has a lifetime, which is determined by the CA. When the private key leaks or the certificate is about to expire, you can destroy the old RSA key pair and then create a pair to request a new certificate.
Follow these steps to destroy a local RSA key pair:
To do…
Use the command…
Remarks
Enter system view
Destroy a local RSA key pair
public-key local destroy rsa
Required
For details about the public-key local destroy rsa command, refer to SSH2.0 Commands in the Security Volume.
When a certificate requested manually is about to expire or you want to request a new certificate, you can delete the current local certificate or CA certificate.
Follow these steps to delete a certificate:
To do…
Use the command…
Remarks
Enter system view
Delete certificates
pki delete-certificate { ca | local } domain domain-name
Required
By configuring a certificate attribute-based access control policy, you can further control access to the server, providing additional security for the server.
Follow these steps to configure a certificate attribute-based access control policy:
To do…
Use the command…
Remarks
Enter system view
Create a certificate attribute group and enter its view
pki certificate attribute-group group-name
Required
No certificate attribute group exists by default.
Configure an attribute rule for the certificate issuer name, certificate subject name, or alternative subject name
attribute id { alt-subject-name { fqdn | ip } | { issuer-name | subject-name } { dn | fqdn | ip } } { ctn | equ | nctn | nequ } attribute-value
Optional
There is no restriction on the issuer name, certificate subject name and alternative subject name by default.
Create a certificate attribute-based access control policy and enter its view
pki certificate access-control-policy policy-name
Required
No access control policy exists by default.
Configure a certificate attribute-based access control rule
rule [ id ] { deny | permit } group-name
Required
No access control rule exists by default.
A certificate attribute group must exist to be associated with a rule.
To do…
Use the command…
Remarks
Display the contents or request status of a certificate
display pki certificate { { ca | local } domain domain-name | request-status }
Available in any view
Display CRLs
display pki crl domain domain-name
Display information about one or all certificate attribute groups
display pki certificate attribute-group { group-name | all }
Display information about one or all certificate attribute-based access control policies
display pki certificate access-control-policy { policy-name | all }
l          The SCEP plug-in is required when you use the Windows Server as the CA. In this case, when configuring the PKI domain, you need to use the certificate request from ra command to specify that the entity requests a certificate from an RA.
l          The SCEP plug-in is not required when RSA Keon is used. In this case, when configuring a PKI domain, you need to use the certificate request from ca command to specify that the entity requests a certificate from a CA.
Requesting a Certificate from a CA Running RSA Keon
The CA server runs RSA Keon in this configuration example.
Network requirements
l          The device submits a local certificate request to the CA server.
l          The device acquires the CRLs for certificate verification.
Network diagram
Figure 1-2 Request a certificate from a CA running RSA Keon
Configuration procedure
1)        Configure the CA server
# Create a CA server named myca.
In this example, you need to configure these basic attributes on the CA server at first:
l          Nickname: Name of the trusted CA.
l          Subject DN: DN information of the CA, including the Common Name (CN), Organization Unit (OU), Organization (O), and Country (C).
The other attributes may be left using the default values.
# Configure extended attributes.
After configuring the basic attributes, you need to perform configuration on the jurisdiction configuration page of the CA server. This includes selecting the proper extension profiles, enabling the SCEP autovetting function, and adding the IP address list for SCEP autovetting.
# Configure the CRL distribution behavior.
After completing the above configuration, you need to perform CRL related configurations. In this example, select the local CRL distribution mode of HTTP and set the HTTP URL to http://4.4.4.133:447/myca.crl.
After the above configuration, make sure that the system clock of the device is synchronous to that of the CA, so that the device can request certificates and retrieve CRLs properly.
2)        Configure the switch
l          Configure the entity DN
# Configure the entity name as aaa and the common name as switch.
<Switch> system-view
[Switch] pki entity aaa
[Switch-pki-entity-aaa] common-name switch
[Switch-pki-entity-aaa] quit
l          Configure the PKI domain
# Create PKI domain torsa and enter its view.
[Switch] pki domain torsa
# Configure the name of the trusted CA as myca.
[Switch-pki-domain-torsa] ca identifier myca
# Configure the URL of the registration server in the format of http://host:port/Issuing Jurisdiction ID, where Issuing Jurisdiction ID is a hexadecimal string generated on the CA server.
[Switch-pki-domain-torsa] certificate request url http://4.4.4.133:446/c95e970f632d27be5e8cbf80e971d9c4a9a93337
# Set the registration authority to CA.
[Switch-pki-domain-torsa] certificate request from ca
# Specify the entity for certificate request as aaa.
[Switch-pki-domain-torsa] certificate request entity aaa
# Configure the URL for the CRL distribution point.
[Switch-pki-domain-torsa] crl url http://4.4.4.133:447/myca.crl
[Switch-pki-domain-torsa] quit
l          Generate a local key pair using RSA
[Switch] public-key local create rsa
NOTES: If the key modulus is greater than 512,
       It may take a few minutes.
Press CTRL+C to abort.
Input the bits in the modulus [default = 1024]:
Generating keys...
l          Apply for certificates
# Retrieve the CA certificate and save it locally.
[Switch] pki retrieval-certificate ca domain torsa
Retrieving CA/RA certificates. Please wait a while......
The trusted CA's finger print is:
    MD5  fingerprint:EDE9 0394 A273 B61A F1B3 0072 A0B1 F9AB
    SHA1 fingerprint: 77F9 A077 2FB8 088C 550B A33C 2410 D354 23B2 73A8
Is the finger print correct?(Y/N):y
Saving CA/RA certificates chain, please wait a moment......
CA certificates retrieval success.
# Retrieve CRLs and save them locally.
[Switch] pki retrieval-crl domain torsa
Connecting to server for retrieving CRL. Please wait a while.....
CRL retrieval success!
# Request a local certificate manually.
[Switch] pki request-certificate domain torsa challenge-word
Enrolling the local certificate,please wait a while......
Certificate request Successfully!
Saving the local certificate to device......
Done!
3)        Verify your configuration
# Use the following command to view information about the local certificate acquired.
<Switch> display pki certificate local domain torsa
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            9A96A48F 9A509FD7 05FFF4DF 104AD094
        Signature Algorithm: sha1WithRSAEncryption
        Issuer:
            C=cn
            O=org
            OU=test
            CN=myca
        Validity
            Not Before: Jan  8 09:26:53 2007 GMT
            Not After : Jan  8 09:26:53 2008 GMT
        Subject:
            CN=switch
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
            RSA Public Key: (1024 bit)
                Modulus (1024 bit):
                    00D67D50 41046F6A 43610335 CA6C4B11
                    F8F89138 E4E905BD 43953BA2 623A54C0
                    EA3CB6E0 B04649CE C9CDDD38 34015970
                    981E96D9 FF4F7B73 A5155649 E583AC61
                    D3A5C849 CBDE350D 2A1926B7 0AE5EF5E
                    D1D8B08A DBF16205 7C2A4011 05F11094
                    73EB0549 A65D9E74 0F2953F2 D4F0042F
                    19103439 3D4F9359 88FB59F3 8D4B2F6C
                    2B
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 CRL Distribution Points:
            URI:http://4.4.4.133:447/myca.crl
        836213A4 F2F74C1A 50F4100D B764D6CE
        B30C0133 C4363F2F 73454D51 E9F95962
        EDE9E590 E7458FA6 765A0D3F C4047BC2
        9C391FF0 7383C4DF 9A0CCFA9 231428AF
        987B029C C857AD96 E4C92441 9382E798
        8FCC1E4A 3E598D81 96476875 E2F86C33
        75B51661 B6556C5E 8F546E97 5197734B
        C8C29AC7 E427C8E4 B9AAF5AA 80A75B3C
You can also use some other display commands to view detailed information about the CA certificate and CRLs. Refer to the parts related to display pki certificate ca domain and display pki crl domain commands in PKI Commands of the Security Volume.
Requesting a Certificate from a CA Running Windows 2003 Server
The CA server runs the Windows 2003 server in this configuration example.
Configure PKI entity Switch to request a local certificate from the CA server.
Network diagram
Figure 1-3 Request a certificate from a CA running Windows 2003 server
l          Install the certificate server suites
From the start menu, select Control Panel > Add or Remove Programs, and then select Add/Remove Windows Components > Certificate Services and click Next to begin the installation.
l          Install the SCEP plug-in
As a CA server running the Windows 2003 server does not support SCEP by default, you need to install the SCEP plug-in so that the switch can register and obtain its certificate automatically. After the SCEP plug-in installation completes, a URL is displayed, which you need to configure on the switch as the URL of the server for certificate registration.
l          Modify the certificate service attributes
From the start menu, select Control Panel > Administrative Tools > Certificate Authority. If the CA server and SCEP plug-in have been installed successfully, there should be two certificates issued by the CA to the RA. Right-click on the CA server in the navigation tree and select Properties > Policy Module. Click Properties and then select Follow the settings in the certificate template, if applicable. Otherwise, automatically issue the certificate.
l          Modify the Internet Information Services (IIS) attributes
From the start menu, select Control Panel > Administrative Tools > Internet Information Services (IIS) Manager and then select Web Sites from the navigation tree. Right-click on Default Web Site in the right pane and select Properties > Home Directory. Specify the path for certificate service in the Local path text box. In addition, you are recommended to specify an available port number as the TCP port number of the default Web site to avoid conflict with existing services.
After completing the above configuration, check that the system clock of the switch is synchronous to that of the CA server, ensuring that the switch can request a certificate normally.
# Configure the URL of the registration server in the format of http://host:port/ certsrv/mscep/mscep.dll, where host:port indicates the IP address and port number of the CA server.
[Switch-pki-domain-torsa] certificate request url http://4.4.4.1:8080/certsrv/mscep/mscep.dll
# Set the registration authority to RA.
[Switch-pki-domain-torsa] certificate request from ra
Generating keys...
    MD5  fingerprint:766C D2C8 9E46 845B 4DCE 439C 1C1F 83AB
    SHA1 fingerprint:97E5 DDED AB39 3141 75FB DB5C E7F8 D7D7 7C9B 97B4
Done!
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            48FA0FD9 00000000 000C
        Issuer:
            CN=CA server
        Validity
            Not Before: Nov 21 12:32:16 2007 GMT
            Not After : Nov 21 12:42:16 2008 GMT
        Subject:
            CN=switch
                Modulus (1024 bit):
                    00A6637A 8CDEA1AC B2E04A59 F7F6A9FE
                    5AEE52AE 14A392E4 E0E5D458 0D341113
                    0BF91E57 FA8C67AC 6CE8FEBB 5570178B
                    10242FDD D3947F5E 2DA70BD9 1FAF07E5
                    1D167CE1 FC20394F 476F5C08 C5067DF9
                    CB4D05E6 55DC11B6 9F4C014D EA600306
                    81D403CF 2D93BC5A 8AF3224D 1125E439
                    78ECEFE1 7FA9AE7B 877B50B8 3280509F
                    6B
        X509v3 extensions:
            X509v3 Subject Key Identifier:
            B68E4107 91D7C44C 7ABCE3BA 9BF385F8 A448F4E1
            X509v3 Authority Key Identifier:
            keyid:9D823258 EADFEFA2 4A663E75 F416B6F6 D41EE4FE
            URI:http://l00192b/CertEnroll/CA%20server.crl
            URI:file://\\l00192b\CertEnroll\CA server.crl
            Authority Information Access:
            CA Issuers - URI:http://l00192b/CertEnroll/l00192b_CA%20server.crt
            CA Issuers - URI:file://\\l00192b\CertEnroll\l00192b_CA server.crt
            1.3.6.1.4.1.311.20.2:
                .0.I.P.S.E.C.I.n.t.e.r.m.e.d.i.a.t.e.O.f.f.l.i.n.e
        81029589 7BFA1CBD 20023136 B068840B
(Omitted)
You can also use some other display commands to view detailed information about the CA certificate. Refer to the display pki certificate ca domain command in PKI Commands of the Security Volume.
Configuring a Certificate Attribute-Based Access Control Policy
l          The client accesses the remote HTTP Security (HTTPS) server through the HTTPS protocol.
l          SSL is configured to ensure that only legal clients log into the HTTPS server.
l          Create a certificate attribute-based access control policy to control access to the HTTPS server.
Networking diagram
Figure 1-4 Configure a certificate attribute-based access control policy
l          For detailed information about SSL configuration, refer to SSL Configuration in the Security Volume.
l          For detailed information about HTTPS configuration, refer to HTTP Server Configuration in the System Volume.
l          The PKI domain to be referenced by the SSL policy must be created in advance. For detailed configuration of the PKI domain, refer to Configure the PKI domain.
1)        Configure the HTTPS server
# Configure the SSL policy for the HTTPS server to use.
[Switch] ssl server-policy myssl
[Switch-ssl-server-policy-myssl] pki-domain 1
[Switch-ssl-server-policy-myssl] client-verify enable
[Switch-ssl-server-policy-myssl] quit
2)        Configure the certificate attribute group
# Create certificate attribute group mygroup1 and add two attribute rules. The first rule defines that the DN of the subject name includes the string aabbcc, and the second rule defines that the IP address of the certificate issuer is 10.0.0.1.
[Switch] pki certificate attribute-group mygroup1
[Switch-pki-cert-attribute-group-mygroup1] attribute 1 subject-name dn ctn aabbcc
[Switch-pki-cert-attribute-group-mygroup1] attribute 2 issuer-name ip equ 10.0.0.1
[Switch-pki-cert-attribute-group-mygroup1] quit
# Create certificate attribute group mygroup2 and add two attribute rules. The first rule defines that the FQDN of the alternative subject name does not include the string of apple, and the second rule defines that the DN of the certificate issuer name includes the string aabbcc.
[Switch] pki certificate attribute-group mygroup2
[Switch-pki-cert-attribute-group-mygroup2] attribute 1 alt-subject-name fqdn nctn apple
[Switch-pki-cert-attribute-group-mygroup2] attribute 2 issuer-name dn ctn aabbcc
[Switch-pki-cert-attribute-group-mygroup2] quit
3)        Configure the certificate attribute-based access control policy
# Create the certificate attribute-based access control policy of myacp and add two access control rules.
[Switch] pki certificate access-control-policy myacp
[Switch-pki-cert-acp-myacp] rule 1 deny mygroup1
[Switch-pki-cert-acp-myacp] rule 2 permit mygroup2
[Switch-pki-cert-acp-myacp] quit
4)        Apply the SSL server policy and certificate attribute-based access control policy to HTTPS service and enable HTTPS service.
# Apply SSL server policy myssl to HTTPS service.
[Switch] ip https ssl-server-policy myssl
# Apply the certificate attribute-based access control policy of myacp to HTTPS service.
[Switch] ip https certificate access-control-policy myacp
# Enable HTTPS service.
[Switch] ip https enable
Troubleshooting PKI
Failed to Retrieve a CA Certificate
Symptom
Failed to retrieve a CA certificate.
Analysis
Possible reasons include these:
l          The network connection is not proper. For example, the network cable may be damaged or loose.
l          No trusted CA is specified.
l          The URL of the registration server for certificate request is not correct or not configured.
l          No authority is specified for certificate request.
l          The system clock of the device is not synchronized with that of the CA.
Solution
l          Make sure that the network connection is physically proper.
l          Check that the required commands are configured properly.
l          Use the ping command to check that the RA server is reachable.
l          Specify the authority for certificate request.
l          Synchronize the system clock of the device with that of the CA.
Failed to Request a Local Certificate
Symptom
Failed to request a local certificate.
Analysis
l          No CA certificate has been retrieved.
l          The current key pair has been bound to a certificate.
l          Some required parameters of the entity DN are not configured.
Solution
l          Retrieve a CA certificate.
l          Regenerate a key pair.
l          Specify a trusted CA.
l          Configure the required entity DN parameters.
Failed to Retrieve CRLs
Symptom
Failed to retrieve CRLs.
Analysis
l          No CA certificate has been retrieved before you try to retrieve CRLs.
l          The IP address of LDAP server is not configured.
l          The CRL distribution URL is not configured.
l          The LDAP server version is wrong.
Solution
l          Specify the IP address of the LDAP server.
l          Specify the CRL distribution URL.
l          Re-configure the LDAP version.
