H3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
11-IPv6 RIPng Commands
11-IPv6 RIPng Commands 80.11 KB
Chapter 1  IPv6 RIPng Configuration Commands
1.1  RIPng Configuration Commands
1.1.1  checkzero
checkzero
undo checkzero
View
RIPng view
Default Level
2: System level
Parameter
None
Use the checkzero command to enable the zero field check on RIPng packets.
Use the undo checkzero command to disable the zero field check.
The zero field check is enabled by default.
Some fields in RIPng packet headers must be zero. These fields are called zero fields.  You can enable the zero field check on RIPng packet headers. If any such field contains a non-zero value, the RIPng packet will be discarded.
Example
# Disable the zero field check on RIPng packet headers of RIPng 100.
[Sysname] ripng 100
[Sysname-ripng-100] undo checkzero
1.1.2  debugging ripng
debugging ripng process-id [ brief | event | packet | receive | send | timer ]
undo debugging ripng process-id { brief | event | packet | receive | send | timer }
debugging ripng process-id { packet | receive | send } [ interface interface-type interface-number ]
undo debugging ripng process-id { packet | receive | send } [ interface interface-type interface-number ]
View
Default Level
1: Monitor level
Parameter
process-id: RIPng process ID.
brief: Displays brief RIPng debugging information.
event: RIPng event debugging.
packet: RIPng packet debugging.
receive: Debugging of received RIPng packets.
send: Debugging of sent RIPng packets.
timer: RIPng timer debugging.
interface interface-type interface-number: Displays the specified RIPng debugging information of an interface.
Use the debugging ripng command to enable specified RIPng debugging.
Use the undo debugging ripng command to disable specified RIPng debugging.
The keyword interface is usable only when the keyword packet, receive or send is included.
The debugging ripng command with the keyword interface not specified displays the debugging information of RIPng packets sent and received by all interfaces. With the keyword interface included, the command displays the debugging information of RIPng packets sent and received by the interface.
Table 1-1 Description on the fields of the debugging ripng command
Adding interface-type interface-number to Network List
Enabling RIPng on the interface
Removing interface-type interface-number from Network List
Disabling RIPng on the interface
Table 1-2 Description on the fields of the debugging ripng receive command
Ignoring this packet. Packet originated by us
The RIPng packet was self-originated; therefore, it was ignored.
Example
# Enable the debugging of sent RIPng packets.
<Sysname> debugging ripng 1 send
*Apr 11 01:05:59:974 2004 Sysname RM/6/RMDEBUG:RIPng 1 : Sending response message on Vlan-interface1500 to FF02::9
*Apr 11 01:06:00:112 2004 Sysname RM/6/RMDEBUG: Packet : vers 1, cmd response, length 44
*Apr 11 01:06:00:212 2004 Sysname RM/6/RMDEBUG: Dest 150::/64, cost 1, tag 0
*Apr 11 01:06:00:302 2004 Sysname RM/6/RMDEBUG: Dest 151::/64, cost 1, tag 0
[Sysname]
[Sysname]
*Apr 11 01:06:29:975 2004 Sysname RM/6/RMDEBUG:RIPng 1 : Sending response message on Vlan-interface1500 to FF02::9
*Apr 11 01:06:30:112 2004 Sysname RM/6/RMDEBUG: Packet : vers 1, cmd response, length 44
*Apr 11 01:06:30:212 2004 Sysname RM/6/RMDEBUG: Dest 150::/64, cost 1, tag 0
*Apr 11 01:06:30:302 2004 Sysname RM/6/RMDEBUG: Dest 151::/64, cost 1, tag 0
1.1.3  default cost (RIPng view)
default cost cost
undo default cost
View
RIPng view
Parameter
cost: Default metric of redistributed routes. The default is 0.
Use the default cost command to specify the default metric of redistributed routes.
Use the undo default cost command to restore the default.
By default, the default metric of redistributed routes is 0.
The specified default metric applies to routes redistributed by the import-route command that has no metric specified.
Related commands: import-route.
# Set the default metric of redistributed routes to 2.
[Sysname] ripng 100
[Sysname-ripng-100] default cost 2
1.1.4  display ripng
display ripng [ process-id ]
View
Default Level
1: Monitor level
Use the display ripng command to display the running status and configuration information of a RIPng process. If process-id is not specified, information of all RIPng processes will be displayed.
# Display the running status and configuration information of all configured RIPng processes.
<Sysname> display ripng
    RIPng process : 1
       Preference : 100
       Checkzero : Enabled
       Default Cost : 0
       Maximum number of balanced paths : 3
       Update time   :   30 sec(s)  Timeout time           :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-Collect time :  120 sec(s)
       Number of periodic updates sent : 0
       Number of trigger updates sent : 0
Table 1-3 Description on the fields of the display ripng command
RIPng Process
RIPng process ID
Preference
RIPng route priority
Checkzero
Whether zero field check for RIPng packet headers is enabled
Default Cost
Maximum number of load balanced routes
Update time
RIPng updating interval, in seconds
Timeout time
RIPng timeout interval, in seconds
Suppress time
RIPng suppress interval, in seconds
RIPng garbage collection interval, in seconds
Number of triggered updates sent
1.1.5  display ripng database
display ripng process-id database
View
Default Level
1: Monitor level
Use the display ripng database command to display all active routes in the RIPng advertising database, which are sent in normal RIPng update messages.
# Display the active routes in the database of RIPng process 100.
<Sysname> display ripng 100 database
   2001:7B::2:2A1:5DE/64,
        cost 4, Imported
   1:13::/120,
        cost 4, Imported
   1:32::/120,
        cost 4, Imported
   1:33::/120,
        cost 4, Imported
   100::/32,
       via FE80::200:5EFF:FE04:3302, cost 2
   3FFE:C00:C18:1::/64,
       via FE80::200:5EFF:FE04:B602, cost 2
       via FE80::200:5EFF:FE04:B601, cost 2
   3FFE:C00:C18:2::/64,
   3FFE:C00:C18:3::/64,
   4000:1::/64,
   4000:2::/64,
Table 1-4 Description on fields of the display ripng database command
IPv6 destination address/prefix length
via
Next hop IPv6 address
cost
Route metric value
Imported
Routes learnt from other routing protocols
1.1.6  display ripng interface
display ripng process-id interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Specified an interface.
Use the display ripng interface command to display the interface information of the RIPng process.
# Display the interface information of RIPng process 1.
<Sysname> display ripng 1 interface
Interface-name: vlan-interface 12
         Link Local Address: FE80::200:5EFF:FE19:3E00
         Split-horizon: on               Poison-reverse: off
         MetricIn: 0                      MetricOut: 1
         Default route: off
          Summary address:
                 3::/64
                 3::/16
Table 1-5 Description on the fields of the display ripng interface command
Interface-name
Name of an interface running RIPng.
Link Local Address
Link-local address of an interface running RIPng
Split-horizon
Indicates whether the split horizon function is enabled (on: Enabled off: Disabled).
Poison-reverse
Indicates whether the poison reverse function is enabled (on: Enabled off: Disabled).
MetricIn/MetricOut
Additional metric to incoming and outgoing routes
Default route
l      Only/Originate: Only means that the interface advertises only the default route. Originate means that the default route and other RIPng routes are advertised.
l      Off, indicates that no default route is advertised or the garbage-collect time expires after the default route advertisement was disabled.
l      In garbage-collect status: With default route advertisement disabled, the interface advertises the default route with metric 16 during the garbage-collect time.
Summary address
The summarized IPv6 prefix and the summary IPv6 prefix on the interface
1.1.7  display ripng route
display ripng process-id route
View
Default Level
1: Monitor level
Use the display ripng route command to display all RIPng routes and timers associated to each route of a RIPng process.
# Display the routing information of RIPng process 100.
<Sysname> display ripng 100 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::200:5EFF:FE04:B602  on vlan-interface 12
 Dest 3FFE:C00:C18:1::/64,
     via FE80::200:5EFF:FE04:B602, cost  2, tag 0, A, 34 Sec
 Dest 3FFE:C00:C18:2::/64,
 Peer FE80::200:5EFF:FE04:B601 on vlan-interface 12
     via FE80::200:5EFF:FE04:B601, cost  2, tag 0, A, 13 Sec
 Dest 3FFE:C00:C18:3::/64,
 Peer FE80::200:5EFF:FE04:3302  on vlan-interface 12
 Dest 100::/32,
     via FE80::200:5EFF:FE04:3302, cost  2, tag 0, A, 6 Sec
 Dest 4000:1::/64,
 Dest 4000:2::/64,
 Dest 4000:3::/64,
 Dest 4000:4::/64,
Table 1-6 Description on the fields of the display ripng route command
Peer
Neighbor connected to the interface
Dest
via
cost
Routing metric value
tag
Route tag
Sec
Time that a route entry stays in a particular state
“A”
The route is in the aging state
“S”
The route is in the suppressed state
“G”
The route is in the Garbage-collect state
1.1.8  filter-policy export
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
View
RIPng view
Default Level
2: System level
acl6-number: Specifies the number of an ACL to filter outgoing routing information, in the range of 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list used to filter outgoing routing information.
protocol: Filter routes redistributed from a routing protocol, currently including bgp4+, direct, isisv6, ospfv3, ripng, and static.
process-id: Process ID of the specified routing protocol. This argument is specified only when the routing protocol is rip, ospf, or isis.
Use the filter-policy export command to define an outbound route filtering policy. Only routes passing the filter can be advertised in the update messages.
Use the undo filter-policy export command to disable the filtering.
By default, RIPng does not filter any outbound routing information.
With the protocol argument specified, only routing information redistributed from the specified routing protocol will be filtered. Otherwise, all outgoing routing information will be filtered.
# Use IPv6 prefix list Filter 2 to filter outgoing RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter2 export
1.1.9  filter-policy import (RIPng view)
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
undo filter-policy import
View
RIPng view
Default Level
2: System level
acl6-number: Specifies the number of an ACL to filter incoming routing information.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 Prefix list to filter incoming routes.
Use the filter-policy import command to define an inbound route filtering policy. Only routes which match the filtering policy can be received.
Use the undo filter-policy import command to disable incoming route filtering.
By default, RIPng does not filter incoming routing information.
# Reference IPv6 prefix list Filter1 to filter incoming RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter1 import
1.1.10  import-route
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | route-policy route-policy-name ] *
undo import-route protocol [ process-id ]
View
RIPng view
Default Level
2: System level
protocol: Specifies a routing protocol from which to redistribute routes, currently including bgp4+, direct, isisv6, ospfv3, ripng, and static.
process-id: Process ID of the specified routing protocol, available for isisv6, ospfv3, and ripng.
cost: Routing metric of redistributed routes. If cost value is not specified, the metric is the default metric specified with the default cost command.
route-policy route-policy-name: Specifies a routing policy by its name.
allow-ibgp: Optional keyword when the specified protocol is bgp4+. The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command redistributes additionally IBGP routes, thus be cautious when using it.
Use the import-route command to redistribute routes from another routing protocol.
Use the undo import-route command to disable redistributing routes from another routing protocol.
By default, RIPng does not redistribute routes from other routing protocols.
l           You can configure a routing policy to redistribute only needed routes.
l           You can specify a cost for redistributed routes using keyword cost.
Related commands: default cost.
# Redistribute routes from IPv6-IS-IS process 7 and specify the metric as 7.
[Sysname] ripng 100
[Sysname-ripng-100] import-route isisv6 7 cost 7
1.1.11  maximum load-balancing
maximum load-balancing number
undo maximum load-balancing
View
RIPng view
Default Level
2: System level
number: Maximum number of equal-cost load-balanced routes.
Use the maximum load-balancing command to specify the maximum number of equal cost routes for load balancing.
Use the undo maximum load-balancing command to restore the default.
# Set the maximum number of equal cost load balanced routes to 2.
[Sysname] ripng 100
[Sysname-ripng-100] maximum load-balancing 2
# Restore the default.
[Sysname-ripng-100] undo maximum load-balancing
1.1.12  preference
preference [ route-policy route-policy-name ] preference
undo preference [ route-policy ]
View
RIPng view
Default Level
2: System level
preference: RIPng route priority. The default is 100. The smaller the value, the higher the priority.
route-policy-name: Name of a routing policy.
Use the preference command to specify the RIPng route priority.
Use the undo preference route-policy command to restore the default.
By default, the priority of a RIPng route is 100.
Using the route-policy keyword can set a priority for routes filtered in by the routing policy:
l           If a priority is set in the routing policy, the priority applies to matched routes, and the priority set by the preference command applies to routes not matched.
l           If no priority is set in the routing policy, the one set by the preference command applies to all routes.
# Set the RIPng route priority to 120.
[Sysname] ripng 100
[Sysname-ripng-100] preference 120
# Restore the default RIPng route priority.
[Sysname-ripng-100] undo preference
1.1.13  ripng
undo ripng [ process-id ]
View
Default Level
2: System level
Use the ripng command to create a RIPng process and enter RIPng view.
Use the undo ripng command to disable a RIPng process.
By default, no RIPng process is enabled.
# Create RIPng process 100 and enter its view.
[Sysname] ripng 100
[Sysname-ripng-100]
# Disable RIPng process 100.
[Sysname] undo ripng 100
1.1.14  ripng default-route
ripng default-route { only | originate } [ cost cost ]
undo ripng default-route
View
Interface view
Default Level
2: System level
only: Indicates that only the IPv6 default route is advertised via the interface.
originate: Indicates that the IPv6 default route is advertised without suppressing other routes.
cost: Metric of the advertised default route. The default value is 1.
Use the ripng default-route command to advertise a default route with the specified routing metric to a RIPng neighbor.
Use the undo ripng default-route command to stop advertising and forwarding the default route.
By default, a RIP process does not advertise any default route.
After you execute this command, the generated RIPng default route is advertised in a route update over the specified interface. This IPv6 default route is advertised without considering whether it already exists in local IPv6 routing table.
# Advertise only the default route through VLAN-interface 100.
[Sysname-Vlan-interface100] ripng default-route only
# Advertise the default route together with other routes through VLAN-interface 101.
[Sysname] interface vlan-interface 101
[Sysname-Vlan-interface101] ripng default-route originate
1.1.15  ripng enable
ripng process-id enable
undo ripng
View
Interface view
Default Level
2: System level
Use the ripng enable command to enable RIPng on the specified interface.
Use the undo ripng enable command to disable RIPng on the specified interface.
# Enable RIPng100 on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng 100 enable
1.1.16  ripng metricin
ripng metricin value
undo ripng metricin
View
Interface view
Default Level
2: System level
value: Additional metric for received routes.
Use the ripng metricin command to specify an additional metric for received RIPng routes.
Use the undo ripng metricin command to restore the default.
By default, the additional metric to received routes is 0.
Related commands: ripng metricout.
# Specify the additional routing metric as 12 for RIPng routes received by VLAN-interface 100.
[Sysname-Vlan-interface100] ripng metricin 12
1.1.17  ripng metricout
ripng metricout value
undo ripng metricout
View
Interface view
Default Level
2: System level
value: Additional metric for advertised routes. The default is 1.
Use the ripng metricout command to configure an additional metric for RIPng routes advertised by an interface.
Use the undo rip metricout command to restore the default.
The default additional routing metric is 1.
Related commands: ripng metricin.
# Set the additional metric to 12 for routes advertised by VLAN-interface 100.
[Sysname-Vlan-interface100] ripng metricout 12
1.1.18  ripng poison-reverse
undo ripng poison-reverse
View
Interface view
Default Level
2: System level
None
Use the rip poison-reverse command to enable the poison reverse function.
Use the undo rip poison-reverse command to disable the poison reverse function.
By default, the poison reverse function is disabled.
# Enable the poison reverse function on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng poison-reverse
1.1.19  ripng split-horizon
ripng split-horizon
undo ripng split-horizon
View
Interface view
Default Level
2: System level
None
Use the rip split-horizon command to enable the split horizon function.
Use the undo rip split-horizon command to disable the split horizon function.
By default, the split horizon function is enabled.
Note that:
l           The split horizon function is necessary for preventing routing loops. Therefore, you are not recommended to disable it.
l           In special cases, make sure that it is necessary to disable the split horizon function before doing so.
&  Note:
If both the poison reverse and split horizon functions are enabled, only the poison reverse function takes effect.
# Enable the split horizon function on Van-interface100.
[Sysname-Vlan-interface100] ripng split-horizon
1.1.20  ripng summary-address
ripng summary-address ipv6-address prefix-length
undo ripng summary-address ipv6-address prefix-length
View
Interface view
Default Level
2: System level
ipv6-address: IPv6 network address of the summary route.
prefix-length: IPv6 prefix length. It indicates the number of consecutive ones of the prefix, which represents the network ID.
Use the ripng summary-address command to configure a summary advertised through the interface.
Use the undo ripng summary-address command to remove the summary.
If the prefix and the prefix length of a route match the specified IPv6 prefix, the IPv6 prefix will be advertised instead. Thus, one route can be advertised on behalf of many routes. After summarization, the summary route cost is the lowest cost among summarized routes.
# Assign an IPv6 address with the 64-bit prefix to VLAN-interface 100 and configure a summary with the 35-bit prefix.
[Sysname-Vlan-interface100] ipv6 address 2001:200::3EFF:FE11:6770/64
[Sysname-Vlan-interface100] ripng summary-address 2001:200:: 35
1.1.21  timers
timers { garbage-collect garbage-collect-value | suppress suppress-value | timeout timeout-value | update update-value }*
undo timers { garbage-collect | suppress | timeout | update }*
View
RIPng view
Default Level
2: System level
garbage-collect-value: Interval of the garbage-collect timer in seconds.
suppress-value: Interval of the suppress timer in seconds.
timeout-value: Interval  of the timeout timer in seconds.
update-value: Interval of the update timer in seconds.
Use the timers command to configure RIPng timers.
Use the undo timers command to restore the default.
By default, the garbage-collect timer is 120 seconds, the suppress timer 120 seconds, the timeout timer 180 seconds, and the update timer 30 seconds.
RIPng is controlled by the above four timers.
l           The update timer defines the interval between update messages.
l           The timeout timer defines the route aging time. If no update message related to a route is received within the aging time, the metric of the route is set to 16 in the routing table.
l           The suppress timer defines how long a RIPng route stays in the suppressed state. When the metric of a route is 16, the route enters the suppressed state. In the suppressed state, only routes which come from the same neighbor and whose metric is less than 16 will be received by the device to replace unreachable routes.
l           The garbage-collect timer defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIPng advertises the route with the routing metric set to 16. If no update message is announced for that route before the garbage-collect timer expires, the route will completely be deleted from the routing table.
Note that:
l           You are not recommended to change the default values of these timers under normal circumstances.
l           The lengths of these timers must be kept consistent on all devices and access servers in the network
# Configure the update, timeout, suppress, and garbage-collect timers as 5 seconds, 15 seconds, 15 seconds and 30 seconds.
[Sysname] ripng 100
[Sysname-ripng-100] timers update 5
[Sysname-ripng-100] timers timeout 15
[Sysname-ripng-100] timers suppress 15
[Sysname-ripng-100] timers garbage-collect 30
