H3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
01-IP Routing Table Display Commands
01-IP Routing Table Display Commands 110.68 KB
Chapter 1  IP Routing Table Display Commands
1.1  IP Routing Table Display Commands
1.1.1  display ip routing-table
display ip routing-table [ vpn-instance vpn-instance-name ] [ verbose | | { begin | exclude | include } regular-expression ]
View
Default Level
1: Monitor level
vpn-instance vpn-instance-name: Displays routing table information for a VPN instance. The vpn-instance-name argument represents the instance name.
verbose: Displays detailed routing table information, including that for inactive routes. With this argument absent, the command displays only summary information about active routes.
|: Uses a regular expression to filter output information.
begin: Displays routing table entries starting from the one specified by the regular expression.
include: Displays routing table entries specified by the regular expression.
exclude: Displays routing table entries other than those specified by the regular expression.
regular-expression: Regular expression.
Table 1-1 Special characters for regular expressions
Character
Meaning
Remarks
_
Underscore, functions similarly as a wildcard and matches one of the following:
or a space, the beginning of a string, the end of a string.
If it is not the first character in a regular expression, it can appear as many times as the command line length permits.
If it is the first character in a regular expression, it can be followed with up to four underscores.
If it appears intermittently in a regular expression, only the first group takes effect.
Left parenthesis, represents a stack push operation in a program.
It is not recommended to use this character in a regular expression.
Full stop, a wildcard that matches any character, including a space.
Asterisk, indicates that the character(s) to its left can appear 0 or more times.
zo* matches z and zoo.
Plus, indicates that the character(s) to its left can appear one or more times.
zo+ matches zo and zoo, but not z.
Use the display ip routing-table command to display brief information about active routes in the routing table.
Use the display ip routing-table verbose command to display detailed information about all routes in the routing table.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 6        Routes : 6
2.2.2.0/24          Direct 0    0            2.2.2.1         vlan12
2.2.2.1/32          Direct 0    0            127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0            192.168.80.10   vlan12
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
Table 1-2 Description on the fields of the display ip routing-table command
Destinations
Number of destination addresses
Routes
Number of routes
Destination/Mask
Destination address/mask length
Proto
Protocol that presents the route
Pre
Priority of the route
Cost
Cost of the route
NextHop
Address of the next hop on the route
Outbound interface for packets to be forwarded along the route
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Table : Public
         Destinations : 5        Routes : 5
  Destination: 10.1.1.0/24
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
      NextHop: 10.1.1.1         Interface: vlan-interface12
  RelyNextHop: 0.0.0.0          Neighbour: 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Active Adv             Age: 00h00m30s
          Tag: 0
  Destination: 10.1.1.1/32
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 00h00m30s
          Tag: 0
  Destination: 10.1.1.2/32
      NextHop: 10.1.1.2         Interface: vlan-interface16
          Tag: 0
  Destination: 127.0.0.0/8
        State: Active NoAdv           Age: 00h00m36s
          Tag: 0
  Destination: 127.0.0.1/32
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Table 1-3 Description on the fields of the display ip routing-table verbose command
Destination
Protocol
Process ID
Process ID
Preference
Cost
Cost of the route
NextHop
RelyNextHop
The next hop address obtained through routing stack.
Neighbour
Neighboring address determined by Routing Protocol
Tunnel ID
Tunnel ID
Label
Label
Status of the route, which could be Active, Inactive, Adv, or NoAdv.
Age
Time for which the route has been in the routing table
Tag
Route tag
1.1.2  display ip routing-table acl
display ip routing-table acl acl-number [ verbose ]
View
Default Level
1: Monitor level
acl-number: Basic ACL number.
verbose: Displays detailed routing table information, including that for inactive routes. With this argument absent, the command displays only brief information about active routes.
Use the display ip routing-table acl command to display information about routes permitted by a specified basic ACL.
This command is intended for the follow-up display of routing policies.
For more information about routing policy, refer to Routing Policy Commands.
&  Note:
If the specified ACL does not exit or it has no rules configured, the entire routing table is displayed.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes Matched by Access list : 2000
Summary Count : 6
Destination/Mask    Proto  Pre  Cost         NextHop       Interface
10.1.1.0/24         Direct 0    0            10.1.1.2      Vlan1
10.1.1.2/32         Direct 0    0            127.0.0.1     InLoop0
10.1.2.0/24         Direct 0    0            10.1.2.1      Vlan12
10.1.2.1/32         Direct 0    0            127.0.0.1     InLoop0
10.1.3.0/24         Direct 0    0            10.1.3.1      Vlan14
10.1.3.1/32         Direct 0    0            127.0.0.1     InLoop0
For detailed description of the above output, see Table 1-2.
# Display detailed information about both active and inactive routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary Count: 4
      NextHop: 10.1.1.2         Interface: Vlan1
        State: Active Adv             Age: 00h25m32s
          Tag: 0
      NextHop: 127.0.0.1        Interface: InLoop0
        State: Active NoAdv           Age: 00h41m34s
          Tag: 0
Destination: 10.1.2.0/24
      NextHop: 10.1.2.1         Interface: Vlan2
        State: Active Adv             Age: 00h05m42s
          Tag: 0
Destination: 10.1.2.1/32
        State: Active NoAdv           Age: 00h05m42s
          Tag: 0
Destination: 10.1.3.0/24
      NextHop: 10.1.3.1         Interface: Vlan4
        State: Active Adv             Age: 00h05m31s
          Tag: 0
Destination: 10.1.3.1/32
        State: Active NoAdv           Age: 00h05m32s
          Tag: 0
Table 1-4 Description on the fields of the display ip routing-table command
Destination
Destination address
Mask
Mask
Protocol
Routing protocol that discovered the route
Preference
Preference of the route
Nexthop
Nexthop address
Route status:
ActiveU
This is an active unicast route. U means unicast.
Blackhole
A blackhole route is similar to a reject route except that a router drops packets matching a blackhole route without sending ICMP unreachable messages to the sources of the packets.
Delete
This route is deleted.
Gateway
This is an indirect route.
Hidden
This route is hidden. For routes that are temporarily unusable for some reasons (because of a policy configured or because the interface is down), you can hide them for later use.
Holddown
Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a holddown route during a period regardless of whether a new route to the same destination is found. For details, refer to corresponding routing protocols.
Int
The route was discovered by an Internal Gateway Protocol (IGP).
NoAdvise
The route is not advertised when the router advertises routes based on policies.
NotInstall
Normally, among routes to a destination, the route with the highest preference is installed into the core routing table and advertised, while a NotInstall route cannot be installed into the core routing table but may be advertised.
Reject
The packets matching a reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
Retain
A retain route in the core routing table cannot be deleted. You can keep static routes in the core routing table by configuring them as retain routes.
Static
Static routes are not lost after you perform the save operation and then restart the router. Routes configured manually are marked as static.
Unicast
Unicast routes
Age
Age of the route in the routing table, in the form of hh:mm:ss.
Cost
Route cost
1.1.3  display ip routing-table ip-address
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } [ verbose ]
View
Default Level
1: Monitor level
ip-address: Destination IP address, in dotted decimal format.
mask-length: IP address mask length.
mask: IP address mask in dotted decimal format.
longer-match: Displays the matched route with the longest mask.
Use the display ip routing-table ip-address command to display information about routes to a specified destination address.
Executing the command with different parameters yields different output:
l           display ip routing-table ip-address
The system ANDs the input destination IP address with the subnet mask in each route entry; and ANDs the destination IP address in each route entry with its corresponding subnet mask.
If the two operations yield the same result for an entry and this entry is active, it is displayed.
l           display ip routing-table ip-address mask
The system ANDs the input destination IP address with the input subnet mask; and ANDs the destination IP address in each route entry with the input subnet mask.
If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
Only route entries that exactly match the input destination address and mask are displayed.
l           display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries that are active, the one with longest mask length is displayed.
l           display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the one that is active with longest mask length is displayed.
Use the display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } command to display route entries with destination addresses within a specified range.
# Display route entries for the destination IP address 11.1.1.1.
[Sysname] display ip routing-table  11.1.1.1
Summary Count : 4
0.0.0.0/0           Static 60   0            0.0.0.0         NULL0
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
11.1.1.0/24         Static 60   0            0.0.0.0         NULL0
For detailed description about the output, see Table 1-2.
# Display route entries by specifying a destination IP address and the longer-match keyword.
[Sysname] display ip routing-table  11.1.1.1 longer-match
Summary Count : 1
# Display route entries by specifying a destination IP address and mask.
[Sysname] display ip routing-table  11.1.1.1 24
Summary Count : 3
# Display route entries by specifying a destination IP address and mask and the longer-match keyword.
[Sysname] display ip routing-table  11.1.1.1 24 longer-match
Summary Count : 1
For detailed description of the above output, see Table 1-3.
# Display route entries for destination addresses in the range 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1       Vlan1
1.1.1.1/32          Direct 0    0            127.0.0.1     InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1       Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1       vlan4
3.3.3.1/32          Direct 0    0            127.0.0.1     InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1       vlan6
4.4.4.1/32          Direct 0    0            127.0.0.1     InLoop0
1.1.4  display ip routing-table ip-prefix
display ip routing-table ip-prefix ip-prefix-name [ verbose ]
View
Default Level
1: Monitor level
ip-prefix-name: IP Prefix list name, which is a character string.
Use the display ip routing-table ip-prefix command to display information about routes permitted by a specified prefix list.
This command is intended for the follow-up display of routing policies. If the specified prefix list is not configured, detailed information about all routes (with the verbose keyword) or brief information about all active routes (without the verbose keyword) is displayed.
# Configure a prefix list named abc, permitting routes with a prefix of 2.2.2.0 and a mask length between 24 and 32.
[Sysname] ip ip-prefix abc permit 2.2.2.0 24 less-equal 32
# Display brief information about active routes permitted by the prefix list abc.
[Sysname] display ip routing-table ip-prefix abc
Routes Matched by Prefix list : abc
Summary Count : 2
# Display detailed information about both active and inactive routes permitted by IP prefix list abc.
[Sysname] display ip routing-table ip-prefix abc verbose
Routes Matched by Prefix list  abc :
Summary Count : 2
Destination: 2.2.2.0/24
      NextHop: 2.2.2.1                  Interface: Vlan2
        State: Active Adv                     Age: 00h20m52s
          Tag: 0
Destination: 2.2.2.1/32
        State: Active NoAdv                   Age: 00h20m52s
          Tag: 0
1.1.5  display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ]
View
Default Level
1: Monitor level
protocol: Routing protocol. It can be BGP, DIRECT, ISIS, OSPF, RIP, or STATIC.
inactive: Displays information about only inactive routes. With this argument absent, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. With this argument absent, the command displays brief routing table information.
Use the display ip routing-table protocol command to display routing information of a specified routing protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 6
Direct Routing table Status : < Active>
Summary Count :  6
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0          192.168.80.10   Vlan3
Direct Routing table Status : < Inactive>
Summary Count : 0
# Display summary information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing table Status : < Active>
Summary Count :  0
Static Routing table Status : < Inactive>
Summary Count : 2
1.2.3.0/24          Static  60   0          1.2.4.5      Vlan10
3.0.0.0/8           Static  60   0           2.2.2.2     Vlan4
1.1.6  display ip routing-table statistics
display ip routing-table [ vpn-instance vpn-instance-name ] statistics
View
Default Level
1: Monitor level
vpn-instance vpn-instance-name: Displays routing table information for a VPN instance. The VPN instance name is a character string.
Use the display ip routing-table statistics command to display statistics about the public network routing table or a VPN routing table.
# Display statistics about the routes in the routing table.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted       freed
DIRECT     24          4           25          1             0
STATIC     4           1           4           0             0
RIP        0           0           0           0             0
OSPF       0           0           0           0             0
IS-IS      0           0           0           0             0
BGP        0           0           0           0             0
Total      28          5           29          1             0
Table 1-5 Description on the fields of display ip routing-table statistics
Proto
Origin of the routes. Possible values include OSPF, IS-IS, RIP, BGP, direct or static.
route
Number of routes from the origin
active
Number of active routes from the origin
added
Number of routes added into the routing table since the device starts up or the last routing table reset operation
deleted
Number of routes marked as deleted, which will be freed after a period.
freed
Number of routes that got freed, that is, got removed permanently
Total
Sums for the numerical items above
1.1.7  display ipv6 routing-table
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table command to display brief routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and outbound interface.
The command displays only active routes, namely, the brief information about the current optimal routes.
# Display brief routing table information
<Sysname> display ipv6 routing-table
Routing Table :
        Destinations : 1        Routes : 1
Destination : ::1/128                           Protocol     : Direct
NextHop     : ::1                               Preference   : 0
Interface   : InLoop0                           Cost         : 0
Table 1-6 Description on the fields of the display ipv6 routing-table command
Destination
Destination IPv6 address
NextHop
Next hop
Preference
Routing preference
Outbound interface
Protocol
Routing protocol of the route
Cost
Routing cost
1.1.8  display ipv6 routing-table acl
display ipv6 routing-table acl acl6-number [ verbose ]
View
Default Level
1: Monitor level
acl6-number: Basic IPv6 ACL number.
Verbose: Displays both active and inactive verbose routing information permitted by the ACL. Without this keyword, only brief active routing information is displayed.
Use the display ipv6 routing-table acl command to display routing information permitted by the IPv6 ACL.
If the specified IPv6 ACL is not available, all routing information is displayed.
# Display brief routing information permitted by ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Routes Matched by Access list  2000  :
Summary Count : 2
Destination : 1:1::/64                            Protocol   : Static
NextHop     : ::                                Preference : 60
Interface   : NULL0                             Cost       : 0
Refer to Table 1-6 for description about the above output.
1.1.9  display ipv6 routing-table ipv6-address
display ipv6 routing-table ipv6-address prefix-length [ longer-match ] [ verbose ]
View
Default Level
1: Monitor level
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length.
longer-match: Displays the matched route with the longest prefix.
verbose: Displays both active and inactive verbose routing information. Without this keyword, only brief active routing information is displayed.
Use the display ipv6 routing-table ipv6-address command to display routing information about the specified destination IPv6 address.
l           display ipv6 routing-table ipv6-address prefix-length
The system ANDs the input destination IPv6 address with the input prefix length, and ANDs the destination IPv6 address in each route entry with the input prefix length.
If the two operations yield the same result for an entry and the entry is active with a prefix length less than or equal to the input prefix length, the entry is displayed.
Only route entries that exactly match the input destination address and prefix length are displayed.
l           display ipv6 routing-table ipv6-address prefix-length longer-match
The system ANDs the input destination IPv6 address with the input prefix length; and ANDs the destination IPv6 address in each route entry with the input prefix length.
If the two operations yield the same result for multiple entries with a prefix length less than or equal to the input prefix length, the one that is active and has the longest prefix length is displayed.
# Display brief information about the route matching the specified destination IPv6 address.
<Sysname> display ipv6 routing-table 10::1 127
Routing Table:
Summary Count: 3
Destination: 10::/64                                    Protocol  : Static
NextHop    : ::                                         Preference: 60
Destination: 10::/68                                    Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the route matching the specified destination IPv6 address and having the longest prefix.
<Sysname> display ipv6 routing-table 10:: 127 longer-match
Routing Tables:
Summary Count : 1
1.1.10  display ipv6 routing-table ipv6-address1 ipv6-address2
display ipv6 routing-table ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ]
View
Default Level
1: Monitor level
ipv6-address1/ipv6-address2: An IPv6 address range from IPv6 address1 to IPv6 address2.
prefix-length1/prefix-length2: Prefix length.
Use the display ipv6 routing-table ipv6-address1 ipv6-address2 command to display routes with destinations falling into the specified IPv6 address range.
# Display routes with destinations falling into the IPv6 address range.
<Sysname> display ipv6 routing-table 3:: 32 4:4:: 64
Routing Table :
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
1.1.11  display ipv6 routing-table ipv6-prefix
display ipv6 routing-table ipv6-prefix ipv6-prefix-name [ verbose ]
View
Default Level
1: Monitor level
ipv6-prefix-name: Name of the IPv6 prefix list.
Use the display ipv6 routing-table ipv6-prefix command to display routes permitted by the IPv6 prefix list.
# Display brief active routing information permitted by the IPv6 prefix list abc2.
<Sysname> display ipv6 routing-table ipv6-prefix abc2
Routes Matched by Prefix list  abc2  :
Summary Count : 1
1.1.12  display ipv6 routing-table protocol
display ipv6 routing-table protocol protocol [ inactive | verbose ]
View
Default Level
1: Monitor level
protocol: Displays routes of a routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng and static.
inactive: Displays only inactive routes. Without the keyword, all active and inactive routes are displayed.
Use the display ipv6 routing-table protocol command to display routes of a specified routing protocol.
# Display brief information about all direct routes.
<Sysname> display ipv6 routing-table protocol direct
Direct Routing Table :
Summary Count : 1
Direct Routing Table's Status : < Active >
Summary Count : 1
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Direct Routing Table's Status : < Inactive >
Summary Count : 0
1.1.13  display ipv6 routing-table statistics
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table statistics command to display routing statistics, including total route number, added route number and deleted route number.
# Display routing statistics.
<Sysname> display ipv6 routing-table statistics
Protocol   route      active     added      deleted     freed
DIRECT       1           1           1           0            0
STATIC       3           0           3           0            0
RIPng        0           0           0           0            0
OSPFv3       0           0           0           0            0
IS-ISv6      0           0           0           0            0
BGP4+        0           0           0           0            0
Total        4           1           4           0            0
Table 1-7 Description on the fields of the display ipv6 routing-table statistics command
Protocol
Routing protocol
route
Route number of the protocol
active
Active route number
added
Routes added after the last startup of the router
deleted
Deleted routes, which will be released after a specified time
freed
Released (totally removed from the routing table) route number
Total
Total route number
1.1.14  display ipv6 routing-table verbose
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table verbose command to display detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display detailed information about all active and inactive routes.
<Sysname> display ipv6 routing-table verbose
Routing Table :
 Destination  : ::1                                     PrefixLength : 128
 RelayNextHop : ::                                      Tag          : 0H
 Neighbour    : ::                                      ProcessID    : 0
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active NoAdv                            Cost         : 0
 Tunnel ID    : 0x0                                     Label        : NULL
 Age          : 22161sec
Table 1-8 Description on the fields of the display ipv6 routing-table verbose command
Destination
PrefixLength
Prefix length of the address
Nexthop
Next hop
Preference
Routing preference
RelayNextHop
Relay next hop
Tag
Tag of the route
Neighbour
Neighbor address
ProcessID
Process ID
Outbound interface
Protocol
Routing protocol
State of the route, Active, Inactive, Adv (advertised), or NoAdv (not advertised)
Cost
Cost of the route
Tunnel ID
Tunnel ID
Label
Label
Age
Time that has elapsed since the route was generated
1.1.15  reset ip routing-table statistics protocol
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { all | protocol }
View
Default Level
2: System level
vpn-instance-name: VPN instance name, which is a character string.
all: All protocols.
Use the reset ip routing-table statistics protocol command to clear routing statistics for the public network routing table or VPN routing table.
# Clear private network routing statistics for the VPN instance Sysname1.
<Sysname> reset ip routing-table statistics protocol vpn-instance Sysname1 all
1.1.16  reset ipv6 routing-table statistics
reset ipv6 routing-table statistics protocol { all | protocol }
View
Default Level
2: System level
all: Clears statistics for all routing protocols.
protocol: Clears statistics for the routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
Use the reset ipv6 routing-table statistics command to clear the route statistics of the routing table.
# Clears statistics for all routing protocols.
<Sysname> reset ipv6 routing-table statistics protocol all
