H3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-03 IP Routing Volume
09-IPv6 IS-IS Commands
09-IPv6 IS-IS Commands 58.53 KB
Chapter 1  IPv6 IS-IS Configuration Commands
1.1  IPv6 IS-IS Configuration Commands
&  Note:
1.1.1  display isis route ipv6
display isis route ipv6 [ [ level-1 | level-2 ] | verbose ]* [ process-id ]
View
Default Level
1: Monitor level
verbose: Displays detailed IPv6 IS-IS routing information.
process-id: IS-IS process ID.
level-1: Display Level-1 IPv6 IS-IS routes only.
level-2: Displays Level-2 IPv6 IS-IS routes only.
&  Note:
If no level is specified, both Level-1 and Level-2 (namely Level-1-2) routing information will be displayed.
Use the display isis route ipv6 command to display IPv6 IS-IS routing information.
With the verbose keyword included, preferences and tags of routing information are also displayed.
# Display IPv6 IS-IS routing information.
<Sysname> display isis route ipv6
                         Route information for ISIS(1)
                     ISIS(1) IPv6 Level-1 Forwarding Table
 Destination: 2001::                                 PrefixLen: 64
 Flag        : R/L/-                                   Cost     : 10
 Next Hop   : Direct                                 Interface: vlan12
 Destination: 2002::                                 PrefixLen: 64
 Next Hop   : Direct                                 Interface: vlan14
 Destination: ::                                      PrefixLen: 0
 Flag        : R/-/-                                   Cost     : 10
 Next Hop   : FE80::200:5EFF:FE01:3D04            Interface: vlan12
      Flags: R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
Table 1-1  Description on the fields of the display isis route ipv6 command
Destination
IPv6 destination address prefix
PrefixLen
Length of the prefix
Flag
Flag of routing information status
R: The route has been added into the routing table.
L: The route has been advertised in a LSP.
U: Route leaking flag, indicating the Level-1 route is from Level-2. “UP” means the route will not be returned to Level-2.
Cost
Value of cost
Next Hop
Next hop
Outbound interface
# Display detailed IPv6 IS-IS routing information.
<Sysname> display isis route ipv6 verbose
 IPV6 Dest  : 2001::/64                   Cost : 10            Flag : R/L/-
 Preference : 15                     Admin Tag : -
 Interface  : vlan12                  Next Hop : Direct
 IPV6 Dest  : 2002::/64                   Cost : 10            Flag : R/L/-
 Interface  : vlan14                  Next Hop : Direct
 IPV6 Dest  : ::/0                         Cost : 10            Flag : R/-/-
 Interface  : vlan12                  Next Hop : FE80::200:5EFF:FE01:3D04
Table 1-2  Description on the fields of the display isis route ipv6 verbose command
IPV6 Dest
Cost
Value of cost
Flag
Preference
Protocol Preference
Admin Tag
Administrative tag
Outbound interface
Next Hop
Next hop
1.1.2  ipv6 default-route-advertise
ipv6 default-route-advertise [ [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name ]*
undo ipv6 default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
Default Level
2: System level
route-policy-name: Name of a routing policy.
level-1: Specifies the default route as Level-1.
level-2: Specifies the default route as Level-2.
level-1-2: Specifies the default route as Level-1-2.
&  Note:
If no level is specified, the default route belongs to Level-2.
Use the ipv6 default-route-advertise command to generate a Level-1 or Level-2 IPv6 IS-IS default route.
Use the undo ipv6 default-route-advertise command to disable generating a default route.
No IPv6 IS-IS default route is generated by default.
With a routing policy, you can configure IPv6 IS-IS to generate the default route that must match the routing policy. You can use the apply isis level-1 command in routing policy view to generate a default route in L1 LSPs, or use the apply isis level-2 command in routing policy view to generate a default route in L2 LSPs, and use the apply isis level-1-2 in routing policy view to generate a default route in L1 and L2 LSPs respectively.
# Configure the device to generate a default route.
[Sysname] isis
[Sysname-isis-1] ipv6 default-route-advertise
1.1.3  ipv6 enable
ipv6 enable
undo ipv6 enable
View
IS-IS view
Default Level
2: System level
None
Use the ipv6 enable command to enable IPv6 for the IPv6 IS-IS process.
Use the undo ipv6 enable command to disable IPv6.
IPv6 is disabled by default.
# Create IS-IS routing process 1, and enable IPv6 for the process.
[Sysname] ipv6
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] ipv6 enable
1.1.4  ipv6 filter-policy export
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol process-id ]
undo ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol process-id ]
View
IS-IS view
Default Level
2: System level
acl6-number: Number of a basic or advanced IPv6 ACL used to filter redistributed routes before advertisement.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter the redistributed routes before advertisement.
route-policy-name: Name of a routing policy used to filter the redistributed routes before advertisement.
protocol: Filter routes redistributed from the specified routing protocol before advertisement. The routing protocol can be bgp4+, direct, isisv6, ospfv3, ripng or static at present. If no protocol is specified, routes redistributed from all protocols are filtered before advertisement.
process-id: Process ID of the routing protocol. This argument is available when the protocol is isisv6, ospfv3 or ripng.
Use the ipv6 filter-policy export command to configure IPv6 IS-IS to filter outgoing redistributed routes.
Use the undo ipv6 filter-policy export command to disable the filtering.
The filtering is not configured by default.
In some cases, only routes satisfying certain conditions will be advertised. You can configure the filtering conditions using the ipv6 filter-policy command.
You can use the ipv6 filter-policy export command, which filters redistributed routes only when they are advertised to other routers, in combination with the ipv6 import-route command.
l           If no protocol is specified, routes redistributed from all protocols are filtered before advertisement.
l           If a protocol is specified, only routes redistributed from the protocol are filtered before advertisement.
Related commands: ipv6 filter-policy import.
# Reference the ACL6 2006 to filter all the outgoing redistributed routes.
[Sysname] isis
[Sysname-isis-1] ipv6 filter-policy 2006 export
1.1.5  ipv6 filter-policy import
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
undo ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
View
IS-IS view
Default Level
2: System level
acl6-number: Number of a basic or advanced IPv6 ACL used to filter incoming routes.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter incoming routes.
route-policy-name: Name of a routing policy used to filter incoming routes.
Use the ipv6 filter-policy import command to configure IPv6 IS-IS to filter the received routes.
Use the undo ipv6 filter-policy import command to disable the filtering.
The filtering is disabled by default.
In some cases, only the routing information satisfying certain conditions will be received. You can configure the filtering conditions using the ipv6 filter-policy command.
Related commands: ipv6 filter-policy export.
# Reference the IPv6 ACL 2003 to filter the received routes.
[Sysname] isis
[Sysname-isis-1] ipv6 filter-policy 2003 import
1.1.6  ipv6 import-route
ipv6 import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name | tag tag ] *
undo ipv6 import-route protocol [ process-id ]
View
IS-IS view
Default Level
2: System level
protocol: Redistributes routes from a specified routing protocol, which can be direct, static, ripng, isisv6, bgp4+ or ospfv3.
process-id: Process ID of the routing protocol of ripng, isisv6 or ospfv3. The default is 1.
cost: Cost for redistributed routes.
level-1: Redistributes routes into Level-1 routing table.
level-2: Redistributes routes into Level-2 routing table.
level-1-2: Redistributes routes into Level-1 and Level-2 routing tables.
route-policy-name: Name of a routing policy used to filter routes when they are being redistributed.
tag: Specifies an administrative tag number for the redistributed routes.
allow-ibgp: Allows to redistribute IBGP routes. This keyword is optional when the protocol is bgp4+.
Use the ipv6 import-route command to enable IPv6 IS-IS to redistribute routes from another routing protocol.
Use the undo ipv6 import-route command to disable route redistribution.
Route redistribution is disabled by default.
If no level is specified, the routes are imported to Level-2 routing table by default.
IPv6 IS-IS considers redistributed routes as routes to destinations outside the local routing domain.
You can specify a cost and a level for redistributed routes.
  Caution:
Using the import-route bgp4+ allow-ibgp command will redistribute both EBGP and IBGP routes. The redistributed IBGP routes may cause routing loops. Therefore, be cautious with this command.
# Configure IPv6–IS-IS to redistribute static routes and sets the cost 15 for them.
[Sysname] isis
[Sysname-isis-1]ipv6 import-route static cost 15
1.1.7  ipv6 import-route isisv6 level-2 into level-1
ipv6 import-route isisv6 level-2 into level-1 [ filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } | tag tag ]*
undo ipv6 import-route isisv6 level-2 into level-1
View
IS-IS view
Default Level
2: System level
acl6-number: Number of a basic or advanced ACL6 used to filter routes when they are leaking from Level-2 to Level-1.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter routes when they are leaking from Level-2 to Level-1.
route-policy-name: Name of a routing policy used to filter routes when they are leaking from Level-2 to Level-1.
tag: Specifies an administrative tag number for the leaked routes.
Use the ipv6 import-route isisv6 level-2 into level-1 to enable IPv6 IS-IS route leaking from Level-2 to Level-1.
Use the undo ipv6 import-route isisv6 level-2 into level-1 command to disable the leaking.
The leaking is disabled by default.
The route leaking feature enables a Level-1-2 router to advertise routes destined to the Level-2 area and other Level-1 areas to the Level-1 and Level-1-2 routers in the local area.
#  Enable IPv6 IS-IS route leaking from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1] ipv6 import-route isisv6 level-2 into level-1
1.1.8  ipv6 maximum load-balancing
ipv6 maximum load-balancing number
undo ipv6 maximum load-balancing
View
IS-IS view
Default Level
2: System level
number: Maximum number of equal-cost routes for load balancing.
Use the ipv6 maximum load-balancing command to configure the maximum number of equal cost routes for load-balancing. Use the undo ipv6 maximum load-balancing command to restore the default.
&  Note:
Configure the maximum number of equivalent load-balanced routes according to the memory capacity.
# Configure the maximum number of equivalent load-balanced routing as 2.
[Sysname] isis 100
[Sysname-isis-100] ipv6 maximum load-balancing 2
1.1.9  ipv6 preference
ipv6 preference { route-policy route-policy-name | preference } *
undo ipv6 preference
View
IS-IS view
Default Level
2: System level
preference: Preference for IPv6 IS-IS. The default is 15.
route-policy-name: Name of a routing policy in the format of characters.
Use the ipv6 preference command to configure the preference for IPv6 IS-IS protocol.
Use the undo ipv6 preference command to configure the default preference for IPv6 IS-IS protocol.
When a device runs multiple dynamic routing protocols at the same time, the system will assign a preference to each routing protocol. If several protocols find routes to the same destination, the route found by the protocol with the highest preference is selected.
# Configure the preference of IPv6 IS-IS protocol as 20.
[Sysname] isis
[Sysname-isis-1] ipv6 preference 20
1.1.10  ipv6 summary
ipv6 summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo ipv6 summary ipv6-prefix prefix-length [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Default Level
2: System level
ipv6-prefix: IPv6 prefix of the summary route.
prefix-length: Length of the IPv6 prefix.
avoid-feedback: Specifies to avoid learning summary routes via routing calculation.
generate_null0_route: Generates the NULL 0 route to avoid routing loops.
level-1: Specifies to summarize only the routes redistributed to Level-1 area.
level-1-2: Specifies to summarize all the routes redistributed to Level-1 and Level-2 areas.
level-2: Specifies to summarize only the routes redistributed to Level-2 area.
tag: Value of an administrative tag.
&  Note:
If no level is specified in the command, the default is level-2.
Use the ipv6 summary command to configure an IPv6 IS-IS summary route.
Use the undo ipv6 summary command to remove the summary route.
Route summarization is disabled by default.
Configuring summary routes can reduce the size of the route table, LSPs and LSDB. Routes to be summarized can be IS-IS routes or redistributed routes. The cost of a summary route is the smallest cost among all summarized routes.
# Configure a summary route of 2002::/32.
[Sysname] isis
[Sysname-isis-1] ipv6 summary 2002:: 32
1.1.11  isis ipv6 enable
isis ipv6 enable [ process-id ]
undo isis ipv6 enable
View
Interface view
Default Level
2: System level
Use the isis ipv6 enable command to enable IPv6 for the specified IS-IS process on the interface.
Use the undo isis ipv6 enable command to disable the configuration.
IPv6 is disabled on the interface by default.
# Enable global IPv6, create IS-IS routing process 1, enable IPv6 for the process, and enable IPv6 for the process on VLAN-interface 100.
[Sysname] ipv6
[Sysname] isis 1
[Sysname-isis-1] quit
[Sysname] interface Vlan-interface 100
[Sysname--Vlan-interface100] ipv6 address 2002::1/64
[Sysname--Vlan-interface100] isis ipv6 enable 1
