H3C S9500 Command Manual-Release2132[V2.03]-02 IP Services Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-02 IP Services Volume
07-IPv6 Basics Commands
07-IPv6 Basics Commands 185.75 KB
Table of Contents
Chapter 1 IPv6 Basics Configuration Commands. 1-1
1.1 IPv6 Basics Configuration Commands. 1-1
1.1.1 debugging ipv6 icmpv6. 1-1
1.1.2 debugging ipv6 nd. 1-2
1.1.3 debugging ipv6 packet 1-3
1.1.4 debugging ipv6 pathmtu. 1-5
1.1.5 debugging tcp ipv6. 1-6
1.1.6 debugging udp ipv6 packet 1-8
1.1.7 display dns ipv6 dynamic-host 1-10
1.1.8 display ipv6 fib. 1-11
1.1.9 display ipv6 fibcache. 1-12
1.1.10 display ipv6 host 1-13
1.1.11 display ipv6 interface. 1-14
1.1.12 display ipv6 neighbors. 1-16
1.1.13 display ipv6 neighbors count 1-17
1.1.14 display ipv6 pathmtu. 1-18
1.1.15 display ipv6 socket 1-19
1.1.16 display tcp ipv6 statistics. 1-21
1.1.17 display tcp ipv6 status. 1-24
1.1.18 display udp ipv6 statistics. 1-25
1.1.19 dns server ipv6. 1-26
1.1.20 ipv6. 1-27
1.1.21 ipv6 address. 1-28
1.1.22 ipv6 address auto link-local 1-28
1.1.23 ipv6 address eui-64. 1-29
1.1.24 ipv6 address link-local 1-30
1.1.25 ipv6 fibcache. 1-31
1.1.26 ipv6 fib-loadbalance-type hash-based. 1-31
1.1.27 ipv6 host 1-32
1.1.28 ipv6 icmp-error 1-33
1.1.29 ipv6 mtu. 1-33
1.1.30 ipv6 nd autoconfig managed-address-flag. 1-34
1.1.31 ipv6 nd autoconfig other-flag. 1-35
1.1.32 ipv6 nd dad attempts. 1-36
1.1.33 ipv6 nd hop-limit 1-36
1.1.34 ipv6 nd ns retrans-timer 1-37
1.1.35 ipv6 nd nud reachable-time. 1-38
1.1.36 ipv6 nd ra halt 1-39
1.1.37 ipv6 nd ra interval 1-39
1.1.38 ipv6 nd ra prefix. 1-40
1.1.39 ipv6 nd ra router-lifetime. 1-41
1.1.40 ipv6 neighbor 1-42
1.1.41 ipv6 neighbors max-learning-num.. 1-43
1.1.42 ipv6 pathmtu. 1-44
1.1.43 ipv6 pathmtu age. 1-45
1.1.44 reset dns ipv6 dynamic-host 1-45
1.1.45 reset ipv6 fibcache. 1-46
1.1.46 reset ipv6 neighbors. 1-46
1.1.47 reset ipv6 pathmtu. 1-47
1.1.48 reset ipv6 statistics. 1-48
1.1.49 reset tcp ipv6 statistics. 1-48
1.1.50 reset udp ipv6 statistics. 1-49
1.1.51 tcp ipv6 timer fin-timeout 1-49
1.1.52 tcp ipv6 timer syn-timeout 1-50
1.1.53 tcp ipv6 window. 1-50
undo debugging ipv6 icmpv6
View
Default Level
1: Monitor level
None
Use the debugging ipv6 icmpv6 command to enable ICMPv6 debugging to display the received and transmitted ICMPv6 packets.
Use the undo debugging ipv6 icmpv6 command to disable ICMPv6 debugging.
By default, ICMPv6 debugging is disabled.
# Enable ICMPv6 debugging on an IPv6 interface of an IPv6-supported device.
<Sysname> debugging ipv6 icmpv6
*Mar 23 15:03:40:599 2007 Sysname ICMPV6/7/debug_ipv6 ICMPv6:
ICMPv6 Sent: Type=128, Code=0, Dst = 3000::3
// An ICMPv6 packet is sent.
*Mar 23 15:03:40:727 2007 Sysname ICMPV6/7/debug_ipv6 ICMPv6:
ICMPv6 Received: Type=129, Code=0,
Src = 3000::3, Dst = 3000::2
*Mar 23 15:03:40:888 2007 Sysname ICMPV6/7/debug_ipv6 ICMPv6:Slot=2;
// An ICMPv6 packet is received.
Table 1-1 Description on fields of the debugging ipv6 icmpv6 command
Sent
Send a packet
Received
Receive a packet
Type of an ICMPv6 packet
Code
Code of an ICMPv6 packet
Src
Source IP address
Dst
Destination IP address
debugging ipv6 nd
undo debugging ipv6 nd
View
Default Level
1: Monitor level
None
Use the debugging ipv6 nd command to enable debugging for neighbor state and neighbor messages.
Use the undo debugging ipv6 nd command to disable the debugging.
By default, the debugging for neighbor state and neighbor messages is disabled.
# Enable debugging for neighbor state and neighbor messages on an IPv6 interface of an IPv6-supported device.
<Sysname> debugging ipv6 nd
*Mar 23 15:08:37:939 2007 Sysname ND/7/debug_ipv6 ND:
 Adding INCOMPLETE NB Entry: 3000::3 on Vlan-interface3000
// A neighbor entry in the incomplete state is added.
*Mar 23 15:08:38:77 2007 Sysname ND/7/debug_ipv6 ND:
 Address Resolution started for 3000::3 on Vlan-interface3000
// Resolution of the IP address 3000::3 of the neighbor starts.
*Mar 23 15:08:38:217 2007 Sysname ND/7/debug_ipv6 ND:
 Sending NS to FF02::1:FF00:3, on the interface Vlan-interface3000
// An NS message is sent to the MAC address FF02::1:FF00:3.
*Mar 23 15:08:39:107 2007 Sysname ND/7/debug_ipv6 ND:Slot=2;
 Received NA from 3000::3, on the interface Vlan-interface3000
// An NA message is received from 3000::3.
*Mar 23 15:08:39:257 2007 Sysname ND/7/debug_ipv6 ND:Slot=2;
 INCOMPLETE->REACHABLE : 3000::3 on Vlan-interface3000
// The state of a neighbor entry is changed from incomplete to reachable.
Table 1-2 Description on fields of the debugging ipv6 nd command
Adding
Add a neighbor entry
Address Resolution
Start address resolution
Sending
Send a packet
Received
Receive a packet
NS
Neighbor solicitation message
NA
Neighbor advertisement message
undo debugging ipv6 packet
View
Default Level
1: Monitor level
None
Use the debugging ipv6 packet command to enable IPv6 packet debugging.
Use the undo debugging ipv6 packet command to disable the debugging.
By default, IPv6 packet debugging is disabled.
# Enable IPv6 packet debugging on an IPv6 interface of an IPv6-supported device.
<Sysname> terminal debugging
% Current terminal debugging is on
<Sysname> debugging ipv6 packet
*Mar 23 15:13:20:766 2007 Sysname IPV6PP/7/debug_ipv6:Slot=2;
Sending, interface = Vlan-interface3000, version = 6, traffic class = 0,
flow label = 0, payload length = 64, protocol = 58, hop limit = 255,
Src = 3000::2, Dst = 3000::3,
prompt: Sending the packet from local at Vlan-interface3000
// A packet is sent.
*Mar 23 15:13:21:136 2007 Sysname IPV6PP/7/debug_ipv6:Slot=2;
Receiving, interface = Vlan-interface3000, version = 6, traffic class = 0,
flow label = 0, payload length = 64, protocol = 58, hop limit = 64,
Src = 3000::3, Dst = 3000::2,
prompt: Input an IPv6 Package
// A packet is received from the Ethernet.
*Mar 23 15:13:21:466 2007 Sysname IPV6PP/7/debug_ipv6:Slot=2;
Delivering, interface = Vlan-interface3000, version = 6, traffic class = 0,
prompt: IPv6 packet is delivering up!
// The received packet is delivered to the upper layer.
Table 1-3 Description on major fields of the debugging ipv6 packet command
Sending
Send a packet.
Receiving
Receive a packet.
Delivering
The packet is delivered from the IP layer to the upper layer.
Receiving/sending interface
Version
Version of the IP protocol
Traffic class
Class of the traffic
Protocol
Next packet header
Src
Source IP address
Dst
undo debugging ipv6 pathmtu
View
Default Level
1: Monitor level
None
Use the debugging ipv6 pathmtu command to enable IPv6 path maximum transmission unit (PMTU) debugging.
Use the undo debugging ipv6 pathmtu command to disable the debugging.
By default, the IPv6 PMTU debugging is disabled.
# Enable PMTU debugging.
<Sysname> debugging ipv6 pathmtu
# Add a PMTU entry to view the corresponding debugging information.
*Mar 23 15:15:21:972 2007 Sysname IPV6PMTU/7/Debug_ipv6_pathmtu:
Information-> Adding PMTU Entry at MultipleIndex,
Value = 128,
Prompt-> Successful Addition of PMTU entry
*Mar 23 15:15:22:186 2007 Sysname IPV6PMTU/7/Debug_ipv6_pathmtu:Slot=1;
Information-> PMTU IPC ReceivedEvent,
Value = 0,
Prompt-> Successful in Synchronizing
Table 1-4 Description on major fields of the debugging ipv6 pathmtu command
Adding
Add a PMTU entry
Value
PMTU entry index
debugging tcp ipv6 { event | packet } [ task-id socket-id ]
undo debugging tcp ipv6 { event | packet } [ task-id socket-id ]
View
Default Level
1: Monitor level
event: Enables event debugging.
packet: Enables packet debugging.
task-id socket-id: Task ID and socket ID. All tasks and sockets apply if this argument is not specified.
Use the debugging tcp ipv6 command to enable TCPv6 packet and event debugging for the specified task ID or socket ID.
Use the undo debugging tcp ipv6 command to disable TCPv6 packet and event debugging.
By default, TCPv6 packet and event debugging is disabled.
The packet debugging displays information of each input and output packet, and the event debugging displays only the TCP packet header information.
# Enable the telnet server function on an IPv6 interface of an IPv6-supported device.
% Start Telnet server
# Create a VTY user.
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] authentication-mode none
[Sysname-ui-vty0-4] user privilege level 3
# Enable IPv6 TCP event debugging.
<Sysname> debugging tcp ipv6 event
# Use the telnet ipv6 function to telnet the local device from another device. The debugging information is displayed as follows:
*Mar 23 15:30:12:454 2007 Sysname IPV6TCP/7/TCP6 EVENT:
1174663812: task = VTYD(57), socketid = 0,
TCP6CB 0x063b8184 created
// A TCP control block is created.
*Mar 23 15:30:12:611 2007 Sysname IPV6TCP/7/TCP6 EVENT:
state Closed changed to Listening
// The state is changed.
*Mar 23 15:30:12:782 2007 Sysname IPV6TCP/7/TCP6 EVENT:
Received MSS 1440, LA = 3000::3:23, FA = 3000::2:1024
// The maximum segment size (MSS) is received from the peer.
*Mar 23 15:30:12:971 2007 Sysname IPV6TCP/7/TCP6 EVENT:
state Listening changed to Syn_Rcvd
*Mar 23 15:30:13:141 2007 Sysname IPV6TCP/7/TCP6 EVENT:
Advertising MSS 1440, LA = 3000::3:23, FA = 3000::2:1024
// The local MSS is advertised to the peer.
*Mar 23 15:30:13:331 2007 Sysname IPV6TCP/7/TCP6 EVENT:
1174663812: task = VTYD(57), socketid = 3,
state Syn_Rcvd changed to Established
# Enable IPv6 TCP packet debugging.
<Sysname> debugging tcp ipv6 packet
*Mar 23 15:31:43:92 2007 Sysname IPV6TCP/7/TCP6 PACKET:
1174663897: Input: task = VTYD(57), socketid = 3, state = Established,
src = 3000::2->1025, dst = 3000::3->23,
seq = 1849193033, ack = 2118699532, optlen = 12, flag = ACK,
window = 8192
// A packet is received.
*Mar 23 15:31:43:392 2007 Sysname IPV6TCP/7/TCP6 PACKET:Slot=5;Distributed to board 0
*Mar 23 15:31:46:703 2007 Sysname IPV6TCP/7/TCP6 PACKET:
1174663906: Output: src = 3000::3->23, dst = 3000::2->1025,
seq = 2118699531, ack = 1849193033, flag = ACK,
Table 1-5 Description on fields of the debugging tcp ipv6 command
TCP connection establishment task
Socketid
Socket ID used for establishing a TCP connection
TCP connection state
Received MSS
MSS advertised by the peer.
LA
Local IP address and port number
FA
Peer IP address and port number
Advertising
The local end advertises the local information to the peer.
Src
Source IP address
Dst
Seq
Packet sequence number
Ack
Packet acknowledgement number
Optlen
Packet option length
Flag
Flag bit
Window
Window size
debugging udp ipv6 packet [ task-id socket-id ]
undo debugging udp ipv6 packet [ task-id socket-id ]
View
Default Level
1: Monitor level
Use the debugging udp ipv6 packet command to enable IPv6 User Datagram Protocol (UDP) packet debugging.
Use the undo debugging udp ipv6 packet command to disable IPv6 UDP packet debugging.
By default, IPv6 UDP packet debugging is disabled.
# Use the tracert ipv6 function to telnet an IPv6-supported device with the interfaces configured with IPv6 IP addresses.
# Enable IPv6 UDP packet debugging for all sockets and tasks.
<Sysname> debugging udp ipv6 packet
*Mar 23 15:50:58:903 2007 Sysname IPV6UDP/7/debug_case:
1174665058: O: task = co0(16), socketid = 2,
src = ::->30016,
dst = 3000::3->33434, datalen = 12
*Mar 23 15:51:27:231 2007 Sysname IPV6UDP/7/debug_case:
1174665087: I: unreachable port
src = 3000::2->30016,
# Disable IPv6 UDP packet debugging.
<Sysname> undo debugging udp ipv6 packet
Table 1-6 Description on the fields of the debugging udp ipv6 command
Socketid
Src
Source IP address
Dst
I
Input packets
O
Output packets
Datalen
Data length
View
Default Level
1: Monitor level
None
Use the display dns ipv6 dynamic-host command to display IPv6 dynamic domain name cache information.
# Display IPv6 dynamic domain name cache information.
<Sysname> display dns ipv6 dynamic-host
No      Domain-name    Ipv6 Address     TTL
1           aaa            3001::2            6
Table 1-7 Description on fields of the display dns ipv6 dynamic-host command
No
Sequence number
Domain-name
Host name
Ipv6 Address
IPv6 address of the host
TTL
Time an entry can be cached in seconds
&  Note:
A domain name in the fields of the display dns ipv6 dynamic-host command contains 20 characters at most. If a domain name consists of more than 20 characters, only the first 20 characters are displayed.
display ipv6 fib [ slot-number ] [ ipv6-address ]
View
Default Level
1: Monitor level
slot-number: Number of the slot whose IPv6 forwarding information base (FIB) entries are to be displayed.
ipv6-address: Destination IPv6 address whose IPv6 FIB entries are to be displayed.
Use the display ipv6 fib command to display IPv6 FIB entries. If no argument is specified, all FIB entries will be displayed.
# Display all IPv6 FIB entries.
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
 Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination:    ::1                                     PrefixLength : 128
NextHop    :    ::1                                     Flag         : HU
Label      :    NULL                                    Tunnel ID    : 0
TimeStamp  :    Date- 7/14/2007, Time- 15:17:15
Interface  :    InLoopBack0
Table 1-8 Description on fields of the display ipv6 fib command
Total number of routes in the FIB
Destination
Destination address to which a packet is to be forwarded
PrefixLength
Prefix length of the destination address
NextHop
Next hop of the route to the destination
Flag
Route flag:
l      U — Usable route
l      G — Gateway route
l      H — Host route
l      B — Black hole route
l      D — Dynamic route
l      S — Static route
Label
Label
Tunnel ID
ID of a tunnel
TimeStamp
Generation time of a FIB entry
Outgoing interface that forwards packets
display ipv6 fibcache slot-number
View
Default Level
1: Monitor level
slot-number: Number of the slot whose IPv6 FIB cache information is to be displayed.
Use the display ipv6 fibcache command to display the total number of routes in the IPv6 FIB cache.
# Display the IPv6 FIB information in the cache.
<Sysname> display ipv6 fibcache
FIB Cache:
 Total number of Routes : 0
display ipv6 host
View
Default Level
1: Monitor level
None
Use the display ipv6 host command to display the mappings between host names and IPv6 addresses in the static DNS database.
# Display the mappings between host names and IPv6 addresses.
<Sysname> display ipv6 host
Host                 Age           Flags           IPv6Address
aaa                  0             static           2002::1
bbb                  0             static           2002::2
Table 1-9 Description on fields of the display ipv6 host command
Host
Host name
Age
Time for the entry to live. “0” is displayed in the case of static configuration.
Flags
Flag indicating the type of mapping between a host name and an IPv6 address. Static indicates a static mapping.
IPv6Address
IPv6 address of a host
display ipv6 interface [ interface-type interface-number | brief ]
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface.
brief: Displays brief IPv6 information of an interface.
Use the display ipv6 interface command to display the IPv6 information of an interface for which an IPv6 interface can be configured.
When interface-type interface-number is not specified, the IPv6 information of all interfaces for which IPv6 addresses can be configured is displayed.
# Display the IPv6 information of VLAN-interface 2.
<Sysname> display ipv6 interface vlan-interface 2
Vlan-interface2 current state :DOWN
Line protocol current state :DOWN
IPv6 is enabled, link-local address is FE80::1234:56FF:FE65:4322 [TENTATIVE]
  Global unicast address(es):
    2001::1, subnet is 2001::/64 [TENTATIVE]
  Joined group address(es):
    FF02::1:FF00:1
    FF02::1:FF65:4322
    FF02::2
    FF02::1
  MTU is 1500 bytes
Table 1-10 Description on fields of the display ipv6 interface command (on a switch)
Physical state of the interface
Link layer protocol state of the interface
IPv6 is enabled
IPv6 packet forwarding state of the interface (IPv6 packet forwarding is enabled in the example)
link-local address
Link-local address configured for the interface
Global unicast address(es) configured for the interface(s)
Address(es) of multicast group(s) that the interface joins
MTU
Maximum transmission unit of the interface
Number of DAD attempts, with DAD enabled
ND reachable time
Neighbor reachable time
Interval for retransmitting a neighbor solicitation (NS) message
Hosts use stateless auto-configuration mode to acquire IPv6 addresses
# Display the brief IPv6 information of all interfaces for which IPv6 addresses can be configured.
<Sysname> display ipv6 interface brief
*down: administratively down
(s): spoofing
Interface                 Physical      Protocol        IPv6 Address
Vlan-interface1             down         down            Unassigned
Vlan-interface2             down         down            Unassigned
Vlan-interface100           down         down            Unassigned
Table 1-11 Description on fields of display ipv6 interface brief (on a switch)
*down
The interface is down, that is, the interface is closed by using the shutdown command.
(s)
Spoofing attribute of the interface, that is, the link protocol state of the interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Name of the interface
Physical
Protocol
Link protocol state of the interface
IPv6 Address
IPv6 address of the interface. (If no address is configured for the interface, “Unassigned” will be displayed.)
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ | { begin | exclude | include } text ]
View
Default Level
1: Monitor level
ipv6-address: IPv6 address whose neighbor information is to be displayed.
all: Displays information of all neighbors, including neighbors acquired dynamically and configured statically.
dynamic: Displays information of all neighbors acquired dynamically.
static: Displays information of all neighbors configured statically.
slot slot-number: Displays information of the neighbors of a specified slot.
interface interface-type interface-number: Displays information of the neighbors of a specified interface.
vlan vlan-id: Displays information of the neighbors of a specified VLAN.
|: Uses a regular expression to match neighbor entries. For detailed information about regular expression, refer to CLI display in Basic System Configuration in the System Volume.
begin: Displays the neighbor entries from the first one containing the specified character string.
include: Displays the neighbor entries containing the specified character string.
exclude: Displays the neighbor entries without the specified character string.
text: Character string.
Use the display ipv6 neighbors command to display neighbor information.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address              Link-layer      VID  Interface  State  T  Age
FE80::200:5EFF:FE32:B800  0000-5e32-b800  100  GE4/2/1    REACH  S   -
Table 1-12 Description on fields of the display ipv6 neighbors command
IPv6 Address
IPv6 address of a neighbor
Link-layer
Link layer address (MAC address of a neighbor)
VID
VLAN to which the interface connected with a neighbor belongs
Interface connected with a neighbor
State of a neighbor, including:
l      INCMP: The address is being resolved. The link layer address of the neighbor is unknown.
l      REACH: The neighbor is reachable.
l      STALE: The reachability of the neighbor is unknown. The device will not verify the reachability any longer unless data is sent to the neighbor.
l      DELAY: The reachability of the neighbor is unknown. The device sends an NS message after a delay.
l      PROBE: The reachability of the neighbor is unknown. The device sends an NS message to verify the reachability of the neighbor.
T
Type of neighbor information, including static configuration and dynamic acquisition.
Age
For a static entry, a hyphen “-“ is displayed. For a dynamic entry, the reachable time (in seconds) elapsed is displayed. Therefore, the aging time can only be displayed after a neighbor goes into the REACH state. If the directly generated ND entry is in the STALE state, “#” is displayed (for a neighbor acquired dynamically).
View
Default Level
1: Monitor level
all: Displays the total number of all neighbor entries, including neighbor entries acquired dynamically and configured statically.
dynamic: Displays the total number of all neighbor entries acquired dynamically.
static: Displays the total number of neighbor entries configured statically.
slot slot-number: Displays the total number of neighbor entries of a specified slot.
interface interface-type interface-number: Displays the total number of neighbor entries of a specified interface.
vlan vlan-id: Displays the total number of neighbor entries of a specified VLAN.
Use the display ipv6 neighbors count command to display the total number of neighbor entries satisfying the specified condition.
# Display the total number of neighbor entries acquired dynamically.
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 pathmtu { ipv6-address | all | dynamic | static }
View
Default Level
1: Monitor level
ipv6-address: IPv6 address whose PMTU is to be displayed.
all: Displays all PMTU information.
dynamic: Displays all dynamic PMTU information.
dynamic: Displays all static PMTU information.
Use the display ipv6 pathmtu command to display the PMTU information of IPv6 addresses.
# Display all PMTU values.
<Sysname> display ipv6 pathmtu all
Ipv6 Destination Address ZoneID  PathMTU     Age     Type
 fe80::12                    0       1300            40      Dynamic
 2222::3                 0       1280            -       Static
Table 1-13 Description on fields of the display ipv6 pathmtu command
ZoneID
ID of address zone, currently invalid
PathMTU
PMTU of an IPv6 address
Age
Time for a PMTU to live. For a static PMTU, a hyphen “-“ is displayed.
Indicates the PMTU is dynamically negotiated or statically configured.
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ slot slot-number ]
View
Default Level
1: Monitor level
socktype socket-type: Displays the socket information of this type. The socket type is in the range of 1 to 3. The value “1” is for TCP socket, “2” for UDP socket, and “3” for raw IP socket.
task-id: Displays the socket information of the task. The task ID is in the range 1 to 100.
socket-id: Displays the information of the socket. The socket ID is in the range 0 to 3072.
slot slot-number: Displays the IPv6 socket information on a specified slot.
Use the display ipv6 socket command to display IPv6 socket information.
# Display the information of a specified socket.
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
Task = AGNT(51), socketid = 2, Proto = 17,
LA = ::->161, FA = ::->0,
sndbuf = 9216, rcvbuf = 42080, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = TRAP(52), socketid = 2, Proto = 17,
LA = ::->1024, FA = ::->0,
socket option =,
SOCK_RAW:
Task = ROUT(86), socketid = 5, Proto = 89,
LA = ::, FA = ::,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEADDR,
Table 1-14 Description on fields of the display ipv6 socket command
SOCK_STREAM
TCP socket
SOCK_DGRAM
UDP socket
SOCK_RAW
Raw IP socket
Task ID of the created socket
Socketid
ID assigned by the kernel to the created socket
Proto
Protocol ID
LA
Local address and local port number
FA
Remote address and remote port number
Sndbuf
Size of the send buffer
Rcvbuf
Size of the receive buffer
sb_cc
Number of bytes sent by the send buffer
rb_cc
Number of bytes received by the receive buffer
Socket option
Socket option set by the application
Socket state
State of the socket
View
Default Level
1: Monitor level
None
Use the display tcp ipv6 statistics command to display IPv6 TCP statistics.
# Display the statistics of received and sent IPv6 TCP packets.
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, Keepalive probe: 0, keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Table 1-15 Description on fields of the display tcp ipv6 statistics command
Received packets:
  Total: 0
  checksum error:                 0
  offset error:                        0
  short error:                        0
Statistics of received packets, including
l      Total number of received packets
l      Number of packets received in sequence
l      Number of  window probe packets/number of  window size update packets
l      Number of packets with checksum errors
l      Number of packets with offset errors
l      Number of packets whose total length is less than specified in the packet header
l      Number of duplicate packets
l      Number of partially duplicate packets
l      Number of out-of-order packets
l      Number of packets exceeding the size of the receiving window
l      Number of packets received after the connection is closed
l      Number of  ACK packets
l      Number of duplicate/excessive ACK packets
Sent packets:
     Total: 0
     urgent packets:               0
Statistics of sent packets, including
l      Total number of packets
l      Number of packets containing an urgent indicator
l      Number of  control packets
l      Number of window update packets
l      Number of data packets
l      Number of retransmitted packets
Number of packets whose retransmission times out
Number of connections dropped because of retransmission timeout
Keepalive timeout
Number of keepalive timeouts
Keepalive probe
Number of keepalive probes
Keepalive timeout, so connections disconnected
Number of connections dropped because of keepalive response timeout
Number of initiated connections
Number of accepted connections
Number of established connections
Closed connections
Number of closed connections
dropped
Number of dropped connections (after SYN is received from the peer)
initiated dropped
Number of initiated but dropped connections (before SYN is received from the peer)
View
Default Level
1: Monitor level
None
Use the display tcp ipv6 command to display the IPv6 TCP connection status.
# Display the IPv6 TCP connection status.
<Sysname> display tcp ipv6 status
TCP6CB       Local Address       Foreign Address      State
045d8074     ::->21                ::->0              Listening
Table 1-16 Description on fields of the display tcp ipv6 status command
TCP6CB
IPv6 address of the TCP control block (hexadecimal)
Local Address
Local IPv6 address
Foreign Address
Remote IPv6 address
IPv6 TCP connection status, including
l      Closed
l      Listening
l      Syn_Sent
l      Syn_Rcvd
l      Established
l      Close_Wait
l      Fin_Wait1
l      Closing
l      Last_Ack
l      Fin_Wait2
l      Time_Wait
View
Default Level
1: Monitor level
None
Use the display udp ipv6 statistics command to display statistics of IPv6 UDP packets.
# Display statistics information of IPv6 UDP packets.
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 1-17 Description on fields of the display udp ipv6 statistics command
Total
Total number of received/sent packets
checksum error
Total number of packets with a checksum error
shorter than header
Total number of IPv6 UDP packets whose total length is less than specified by the packet header
Total number of packets whose data length exceeds that specified by the packet header
Total number of unicast packets without any socket received on a port
Total number of broadcast/multicast packets without any socket received on a port
Number of packets not handled because of the receive buffer being full
input packet missing pcb cache
Number of packets failing to match the PCB cache
dns server ipv6 ipv6-address [ interface-type interface-number ]
undo dns server ipv6 ipv6-address [ interface-type interface-number ]
View
Default Level
2: System level
ipv6-address: IPv6 address of a DNS server.
interface-type interface-number: Specifies an interface. When the IPv6 address of the DNS server is a link-local address, this argument must be specified.
Use the dns server ipv6 command to configure an IPv6 address for a DNS server.
Use the undo dns server ipv6 command to remove the configured DNS server.
By default, no DNS server is configured.
# Configure the IPv6 address 2002::1 for a DNS server.
[Sysname] dns server ipv6 2002::1
1.1.20  ipv6
ipv6
undo ipv6
View
Default Level
2: System level
None
Use the ipv6 command to enable the IPv6 packet forwarding function.
Use the undo ipv6 command to disable the IPv6 packet forwarding function.
By default, the IPv6 packet forwarding function is disabled.
# Enable the IPv6 packet forwarding function.
[Sysname] ipv6
1.1.21  ipv6 address
undo ipv6 address [ ipv6-address prefix-length | ipv6-address/prefix-length ]
View
Interface view
Default Level
2: System level
ipv6-address: IPv6 address.
prefix-length: Prefix length of the IPv6 address, in the range 1 to 128.
Use the ipv6 address command to configure an IPv6 site-local address or global unicast address for an interface.
Use the undo ipv6 address command to remove the IPv6 address from the interface.
By default, no site-local address or global unicast address is configured for an interface.
Note that you will remove all IPv6 addresses except the automatically configured link-local address if you carry out the undo ipv6 address command without any parameter specified.
# Set the global unicast address of the interface VLAN-interface 1 to 2001::1/64.
[Sysname-Vlan-interface1] ipv6 address 2001::1/64
undo ipv6 address auto link-local
View
Interface view
Default Level
2: System level
None
Use the ipv6 address auto link-local command to automatically generate a link-local address for an interface.
Use the undo ipv6 address auto link-local command to remove the automatically generated link-local address for an interface.
By default, no link-local address is automatically generated for an interface.
# Configure the interface VLAN-interface 1 to automatically generate a link-local address.
[Sysname-Vlan-interface1] ipv6 address auto link-local
ipv6 address ipv6-address/prefix-length eui-64
undo ipv6 address ipv6-address/prefix-length eui-64
View
Interface view
Default Level
2: System level
ipv6-address/prefix-length: IPv6 address and IPv6 prefix. The ipv6-address and prefix-length arguments jointly specify the prefix of an IPv6 address in the EUI-64 format.
Use the ipv6 address eui-64 command to configure a site-local address or global unicast address in the EUI-64 format for an interface.
Use the undo ipv6 address eui-64 command to remove the configured site-local address or global unicast address in the EUI-64 format for an interface.
By default, no site-local or global unicast address in EUI-64 format is configured for an interface.
# Configure an IPv6 address in EUI-64 format for the interface VLAN-interface 1.
[Sysname-Vlan-interface1] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
View
Interface view
Default Level
2: System level
ipv6-address: IPv6 link-local address. The first ten bits of an address must be 1111111010 (binary), that is, the first group of hexadecimals in the address must be FE80 to FEBF.
Use the ipv6 address link-local command to configure a link-local address manually for a specified interface. Use the undo ipv6 address link-local command to remove the configured link-local address for an interface.
# Configure a link-local address for the interface VLAN-interface 1.
[Sysname-Vlan-interface1] ipv6 address fe80::1 link-local
ipv6 fibcache { slot-number | all }
undo ipv6 fibcache { slot-number | all }
View
Default Level
2: System level
slot-number: Slot number.
all: Specifies all slots.
Use the ipv6 fibcache command to enable the caching function of the IPv6 FIB.
Use the undo ipv6 fibcache command to disable the caching function of the IPv6 FIB.
By default, the caching function of the IPv6 FIB is disabled.
Note that the caching function of the IPv6 FIB is valid only for packets to be forwarded.
# Enable the caching function of the IPv6 FIB.
[Sysname] ipv6 fibcache all
undo ipv6 fib-loadbalance-type hash-based
View
Default Level
2: System level
None
Use the ipv6 fib-loadbalance-type hash-based command to specify the load sharing mode based on the HASH algorithm for packet forwarding.
Use the undo ipv6 fib-loadbalance-type hash-based command to restore the load sharing mode to the default.
By default, the load sharing based on polling is adopted, that is, each equal cost multi-path (ECMP) route is used in turn to forward packets.
# Specify the load sharing mode based on the HASH algorithm for packet forwarding.
[Sysname] ipv6 fib-loadbalance-type hash-based
1.1.27  ipv6 host
ipv6 host hostname ipv6-address
undo ipv6 host hostname [ ipv6-address ]
View
Default Level
2: System level
hostname: Host name, a string of 1 to 20 characters. The character string can contain letters, numerals, “_”, “-“ or “.” and must contain at least one letter.
Use the ipv6 host command to configure the mappings between host names and IPv6 addresses.
Use the undo ipv6 host command to remove the mappings between host names and IPv6 addresses.
Each host name can correspond to only one IPv6 address.
# Configure the mapping between a host name and an IPv6 address.
[Sysname] ipv6 host aaa 2001::1
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
undo ipv6 icmp-error
View
Default Level
2: System level
bucket-size: Number of tokens in a token bucket.
interval: Update period of the token bucket in milliseconds. The update period “0” indicates that the number of ICMPv6 error packets sent is not restricted.
Use the ipv6 icmp-error command to configure the maximum number of ICMPv6 error packets that can be sent within the specified period.
Use the undo ipv6 icmp-error command to restore the default size and update period of the token bucket.
By default, the size is 10 and the update period is 100 milliseconds. That is, at most 10 IPv6 ICMP error packets can be sent within these 100 milliseconds.
# Set the capacity of the token bucket to 50 and the update period to 100 milliseconds.
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
1.1.29  ipv6 mtu
ipv6 mtu mtu-size
undo ipv6 mtu
View
Interface view
Default Level
2: System level
mtu-size: Size of the maximum transmission units (MTUs) of an interface in bytes, in the range 1280 to 10240.
Use the ipv6 mtu command to set the MTU of IPv6 packets sent over an interface.
Use the undo ipv6 mtu command to restore the default.
# Set the MTU of IPv6 packets sent over the interface VLAN-interface 12 to 1,280 bytes.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] ipv6 mtu 1280
undo ipv6 nd autoconfig managed-address-flag
View
Interface view
Default Level
2: System level
None
Use the ipv6 nd autoconfig managed-address-flag command to set the managed address configuration (M) flag to 1 so that the host can acquire an IPv6 address through stateful auto-configuration (for example, DHCP server).
Use the undo ipv6 nd autoconfig managed-address-flag command to restore the default.
By default, the M flag is set to 0 so that the host can acquire an IPv6 address through stateless autoconfiguration.
By default, the M flag is set to 0.
# Configure the host to acquire an IPv6 address through stateful auto-configuration.
[Sysname-Vlan-interface1] ipv6 nd autoconfig managed-address-flag
undo ipv6 nd autoconfig other-flag
View
Interface view
Default Level
2: System level
None
Use the ipv6 nd autoconfig other-flag command to set the other stateful configuration flag (O) flag to 1 so that the host can acquire information other than IPv6 address through stateful auto-configuration (for example, DHCP server).
Use the undo ipv6 nd autoconfig other-flag command to restore the default.
By default, the O flag is set to 0 so that the host can acquire other information through stateless autoconfiguration.
# Configure the host to acquire information other than IPv6 address through stateless auto-configuration.
[Sysname-Vlan-interface1] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
View
Interface view
Default Level
2: System level
value: Number of attempts to send a neighbor solicitation message for DAD. The default value is 1. When it is set to 0, the DAD is disabled.
Use the ipv6 nd dad attempts command to configure the number of attempts to send a neighbor solicitation message for DAD.
Use the undo ipv6 nd dad attempts command to restore the default.
By default, the number of attempts to send a neighbor solicitation message for DAD is 1.
# Set the number of attempts to send a neighbor solicitation message for DAD to 20.
[Sysname-Vlan-interface1] ipv6 nd dad attempts 20
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
View
Default Level
2: System level
value: Number of hops. When it is set to 0, the Cur Hop Limit field in RA messages sent by the device is 0. That is, the number of hops is determined by the host itself, but not specified by the device.
Use the ipv6 nd hop-limit command to configure the hop limit advertised by the device.
Use the undo ipv6 nd hop-limit command to restore the default.
By default, the hop limit advertised by the device is 64.
# Set the hop limit advertised by the device to 100.
[Sysname] ipv6 nd hop-limit 100
undo ipv6 nd ns retrans-timer
View
Interface view
Default Level
2: System level
value: Interval for sending NS messages in milliseconds.
Use the ipv6 nd ns retrans-timer command to set the interval for sending NS messages. The local interface sends NS messages at intervals of this value. Furthermore, the Retrans Timer field in RA messages sent by the local interface is equal to this value.
Use the undo ipv6 nd ns retrans-timer command to restore the default interval.
By default, the local interface sends NS messages at intervals of 1,000 milliseconds and the Retrans Timer field in RA messages sent by the local interface is 0.
# Specify VLAN-interface 100 to send NS messages at intervals of 10,000 milliseconds.
[Sysname-Vlan-interface1] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
View
Interface view
Default Level
2: System level
value: Neighbor reachable time in milliseconds.
Use the ipv6 nd nud reachable-time command to configure the neighbor reachable time on an interface. This time value serves as not only the neighbor reachable time on the local interface, but also the value of the Reachable Timer field in RA messages sent by the local interface.
Use the undo ipv6 nd nud reachable-time command to restore the default neighbor reachable time and to specify the value of the Reachable Timer field in RA messages as 0 so that the number of hops is determined by the host itself, but not specified by the device.
By default, the neighbor reachable time on the local interface is 30,000 milliseconds and the Reachable Timer field in RA messages is 0.
# Set the neighbor reachable time on the interface VLAN-interface 1 to 10,000 milliseconds.
[Sysname-Vlan-interface1] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
undo ipv6 nd ra halt
View
Interface view
Default Level
2: System level
None
Use the ipv6 nd ra halt command to suppress RA messages.
Use the undo ipv6 nd ra halt command to disable the RA message suppression.
By default, RA messages are suppressed.
# Suppress RA messages on the interface VLAN-interface 1.
[Sysname-Vlan-interface1] ipv6 nd ra halt
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
View
Interface view
Default Level
2: System level
max-interval-value: Maximum interval for advertising RA messages in seconds.
min-interval-value: Minimum interval for advertising RA messages in seconds.
Use the ipv6 nd ra interval command to set the maximum and minimum interval for advertising RA messages. The device advertises RA messages at intervals of a random value between the maximum interval and the minimum interval.
Use the undo ipv6 nd ra interval command to restore the default.
By default, the maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Note the following:
l           The minimum interval should be three-fourths of the maximum interval or less.
l           The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1,000 seconds and the minimum interval to 700 seconds.
[Sysname-Vlan-interface100] ipv6 nd ra interval 1000 700
ipv6 nd ra prefix { ipv6-address prefix-length | ipv6-address/prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix ipv6-prefix
View
Interface view
Default Level
2: System level
ipv6-address: IPv6 address or IPv6 address prefix.
prefix-length: Prefix length of an IPv6 address.
ipv6-prefix: IPv6 address prefix.
valid-lifetime: Valid lifetime of a prefix in seconds.
preferred-lifetime: Preferred lifetime of a prefix used for stateless autoconfiguration in seconds.
no-autoconfig: Specifies a prefix not to be used for stateless auto-configuration. If this keyword is not provided, the prefix is used for stateless auto-configuration.
off-link: Specifies the address with the prefix not to be directly reachable on the link. If this keyword is not provided, the address with the prefix is directly reachable on the link.
Use the ipv6 nd ra prefix command to configure the prefix information in RA messages.
Use the undo ipv6 nd ra prefix command to remove the prefix information from RA messages.
By default, no prefix information is configured in RA messages and the IPv6 address of the interface is used as the prefix information.
# Configure the prefix information for RA messages on the interface VLAN-interface 100.
[Sysname-Vlan-interface100] ipv6 nd ra prefix 2001:10::100/64 100 10
[Sysname-Ethernet1/0] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
View
Interface view
Default Level
2: System level
value: Routing device lifetime in seconds. When it is set to 0, the device does not serve as the default routing device.
Use the ipv6 nd ra router-lifetime command to configure the routing device lifetime in RA messages.
Use the undo ipv6 nd ra router-lifetime command to restore the default.
By default, the routing device lifetime in RA messages is 1,800 seconds.
Note that the routing device lifetime in RA messages should be greater than or equal to the advertising interval.
# Set the routing device lifetime in RA messages on the interface VLAN-interface 1 to 1,000 seconds.
[Sysname-Vlan-interface1] ipv6 nd ra router-lifetime 1000
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number }
undo ipv6 neighbor ipv6-address interface-type interface-number
View
Default Level
2: System level
ipv6-address: IPv6 address in a static neighbor entry.
mac-address: Link layer address in a static neighbor entry (48 bits long, in the format of H-H-H).
vlan-id: VLAN ID in a static neighbor entry.
port-type port-number: Type and number of  a Layer 2 port in a static neighbor entry.
interface-type interface-number: Type and number of a Layer 3 interface in a static neighbor entry.
Use the ipv6 neighbor command to configure a static neighbor entry.
Use the undo ipv6 neighbor command to remove a static neighbor entry.
Note that you can adopt the IPv6 address and link layer address of the Layer 3 VLAN interface or those of the VLAN port to configure a static neighbor entry.
l           If a static neighbor entry is configured by using the first method, the neighbor entry is in the INCMP state. After the device obtains the corresponding Layer 2 VLAN port information through resolution, the neighbor entry will go into the REACH state.
l           If a static neighbor entry is configured by using the second method, the corresponding VLAN interface must exist and the port specified by port-type port-number must belong to the VLAN specified by vlan-id. After a static neighbor entry is configured, the device will relate the VLAN interface with the IPv6 address to identify a static neighbor entry uniquely and the entry will be in the REACH state.
You only need to specify the corresponding VLAN interface before removing a static neighbor entry.
# Configure a static neighbor entry for layer 2 port Ethernet 4/1/1 of VLAN 1.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 1 ethernet4/1/1
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
View
Interface view
Default Level
2: System level
number: Maximum number of neighbors that can be dynamically learned by an interface.
Use the ipv6 neighbors max-learning-num command to configure the maximum number of neighbors that can be dynamically learned on a specified interface.
Use the undo ipv6 neighbors max-learning-num command to restore the default.
By default, the maximum number of neighbors that can be dynamically learned on an interface is 1024.
# Set the maximum number of neighbors that can be dynamically learned on the interface VLAN-interface 1 to 10.
[Sysname-Vlan-interface1] ipv6 neighbors max-learning-num 10
1.1.42  ipv6 pathmtu
ipv6 pathmtu ipv6-address [ value ]
undo ipv6 pathmtu ipv6-address
View
Default Level
2: System level
ipv6-address: Specified IPv6 address.
value: PMTU of a specified IPv6 address in bytes.
Use the ipv6 pathmtu command to configure a static PMTU for a specified IPv6 address.
Use the undo ipv6 pathmtu command to remove the PMTU configuration for a specified IPv6 address.
By default, no static PMTU is configured.
# Configure a static PMTU for a specified IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
View
Default Level
2: System level
age-time: Aging time for PMTU in minutes.
Use the ipv6 pathmtu age command to configure the aging time for a dynamic PMTU.
Use the undo ipv6 pathmtu age command to restore the default.
By default, the aging time is 10 minutes.
Note that the aging time is invalid for a static PMTU.
Related commands: display ipv6 pathmtu.
# Set the aging time for a dynamic PMTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
View
Default Level
2: System level
None
Use the reset dns ipv6 dynamic-host command to clear IPv6 dynamic domain name cache information.
# Clear IPv6 dynamic domain name cache information.
<Sysname> reset dns ipv6 dynamic-host
reset ipv6 fibcache { slot-number | all }
View
Default Level
2: System level
slot-number: Clears FIB cache entries of the slot.
all: Clears the FIB cache entries of all slots.
Use the reset ipv6 fibcache command to clear IPv6 FIB cache entries.
# Clear FIB cache entries.
<Sysname> reset ipv6 fibcache
View
Default Level
2: System level
all: Clears the static and dynamic neighbor information on all interfaces.
dynamic: Clears the dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information on a specified interface.
slot slot-number: Clears the dynamic neighbor information on a specified slot.
static: Clears the static neighbor information on all interfaces.
Use the reset ipv6 neighbors command to clear corresponding IPv6 neighbor information.
# Clear neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
reset ipv6 pathmtu { all | static | dynamic }
View
Default Level
2: System level
all: Clears all PMTUs.
static: Clears all static PMTUs.
dynamic: Clears all dynamic PMTUs.
Use the reset ipv6 pathmtu the command to clear the corresponding PMTU information.
# Clear all PMTUs.
<Sysname> reset ipv6 pathmtu all
View
Default Level
2: System level
slot slot number: Clears the statistics of IPv6 packets and ICMPv6 packets on the slot.
Use the reset ipv6 statistics command to clear the statistics of IPv6 packets and ICMPv6 packets.
# Clear the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> reset ipv6 statistics
View
Default Level
2: System level
None
Use the reset tcp ipv6 statistics command to clear the statistics of all IPv6 TCP connections.
# Clear the statistics of all IPv6 TCP connections.
<Sysname> reset tcp ipv6 statistics
View
Default Level
2: System level
None
Use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
# Clear the statistics of all IPv6 UDP packets.
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
View
Default Level
2: System level
wait-time: Length of the finwait timer for IPv6 TCP connections in seconds.
Use the tcp ipv6 timer fin-timeout command to set the finwait timer for IPv6 TCP connections.
Use the undo tcp ipv6 timer fin-timeout command to restore the default.
By default, the length of the finwait timer is 675 seconds.
# Set the finwait timer length of IPv6 TCP connections to 800 seconds.
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
View
Default Level
2: System level
wait-time: Length of the synwait timer for IPv6 TCP connections in seconds.
Use the tcp ipv6 timer syn-timeout command to set the synwait timer for IPv6 TCP connections
Use the undo tcp ipv6 timer syn-timeout command to restore the default.
By default, the length of the synwait timer of IPv6 TCP connections is 75 seconds.
# Set the synwait timer length of IPv6 TCP connections to 100 seconds.
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window size
undo tcp ipv6 window
View
Default Level
2: System level
size: Size of the IPv6 TCP sending/receiving buffer in KB (kilobyte).
Use the tcp ipv6 window command to set the size of the IPv6 TCP sending/receiving buffer.
Use the undo tcp ipv6 window command to restore the default.
By default, the size of the IPv6 TCP sending/receiving buffer is 8 KB.
# Set the size of the IPv6 TCP packet buffer to 4 KB.
[Sysname] tcp ipv6 window 4
