H3C S9500 Command Manual-Release2132[V2.03]-02 IP Services Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-02 IP Services Volume
04-IP Addressing Commands
04-IP Addressing Commands 62.78 KB
Chapter 1  IP Addressing Configuration Commands
1.1  IP Addressing Configuration Commands
1.1.1  display ip interface
display ip interface [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display ip interface command to display information about a specified or all Layer 3 interfaces.
# Display information about the interface VLAN-interface 1.
<Sysname> display ip interface vlan-interface 1
Vlan-interface1 current state :DOWN
Line protocol current state :DOWN
Internet Address is 2.2.2.2/24 Primary
Broadcast address : 2.2.2.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
ARP packet input number:           0
  Request packet:                  0
  Reply packet:                    0
  Unknown packet:                  0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
DHCP packet deal mode:  global
Table 1-1 Description on fields of the display ip interface command
current state
Current physical state of an interface
Current state of the link layer protocol
Internet Address
IP address of the interface:
l      Primary: Identifies a primary IP address, or
l      Sub: Identifies a secondary IP address.
Broadcast address
Broadcast address of the subnet attached to an interface
Maximum transmission units on an interface
Unicast packets, bytes, and multicast packets received on an interface
Unicast packets, bytes, and multicast packets sent on an interface
Total number of ARP packets received on an interface
Request packet
Number of ARP request packets received on an interface
Reply packet
Number of ARP reply packets received on an interface
Unknown packet
Number of unknown packets received on an interface
Number of TTL-invalid packets received on an interface
Total number of ICMP packets received on an interface
DHCP packet processing mode.
1.1.2  display ip interface brief
display ip interface brief [ interface-type [ interface-number ] ]
View
Default Level
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
Use the display ip interface brief command to display brief information about a specified or all Layer 3 interfaces.
If neither interface type nor interface number is specified, information about all layer 3 interfaces is displayed; with only the interface type specified, information about all layer 3 interfaces of the specified type is displayed; with both the interface type and interface number specified, only information about the specified interface is displayed.
Related commands: display ip interface.
# Display brief information about VLAN-interface 22.
<Sysname> display ip interface brief vlan-interface 22
*down: administratively down
(s): spoofing
Interface                         Physical   Protocol   IP Address
Vlan-interface22                    down       down     10.2.2.2
Table 1-2 Description on fields of the display ip interface brief command
*down
The interface is administratively shut down with the shutdown command.
(s)
Spoofing attribute of the interface. It indicates that an interface whose link layer protocol is displayed up may have no link present or the link is set up only on demand.
Interface name
Physical
Physical state of interface
Protocol
Link layer protocol state of interface
IP Address
IP address of interface (if no IP address is configured, “unassigned” is displayed.)
1.1.3  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
Interface view
Default Level
2: System level
ip-address: IP address of interface, in dotted decimal notation.
mask: Subnet mask in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask.
sub: Indicates the specified IP address is a secondary IP address.
Use the ip address command to assign an IP address and mask to the specified interface.
Use the undo ip address command to remove all IP addresses from the interface.
Use the undo ip address ip-address { mask | mask-length } command to remove the primary IP address.
Use the undo ip address ip-address { mask | mask-length } sub command to remove a secondary IP address.
You cannot assign a secondary IP address when the interface is configured to obtain an IP address through PPP negotiation, or to borrow an IP address through IP unnumbered.
By default, no IP address is assigned to any interface.
When assigning IP addresses to an interface, consider the following:
l           You can assign only one primary IP address to an interface.
l           The primary and secondary IP addresses can be located in the same network segment.
l           Before removing the primary IP address, remove all secondary IP addresses.
# Assign VLAN-interface 1 a primary IP address and a secondary IP address, with subnet masks being 255.255.255.0.
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
1.1.4  ip address unnumbered
undo ip address unnumbered
View
POS interface view
Default Level
2: System level
interface interface-type interface-number: Type and number of an interface from which the current interface can borrow an IP address.
Use the ip address unnumbered command to configure the current interface as IP unnumbered to borrow an IP address from another interface.
Use the undo ip address unnumbered command to disable IP unnumbered on the interface.
By default, the interface does not borrow IP addresses from other interfaces.
  Caution:
l      One interface cannot borrow an IP address from an unnumbered interface.
l      Multiple interfaces can use the same unnumbered IP address.
l      One interface borrows only the primary IP address among multiple IP addresses from another interface.
l      The IP address of the borrowing interface always varies and keeps consistent with that of the borrowed interface. That is, if an IP address is configured for the borrowed interface, the IP address of the borrowing interface is the same as that of the borrowed interface; if no IP address is configured for the borrowed interface, no IP address is assigned for the borrowing interface.
l      VLAN interfaces, tunnel interfaces, and loopback interfaces cannot borrow IP addresses of other interfaces, but other interfaces can borrow IP addresses of these interfaces.
l      A VLAN interface should be created before its IP address can be borrowed.
# Configure the POS interface with PPP encapsulation to borrow the IP address from VLAN-interface 22.
[Sysname] interface pos 2/1/2
[Sysname-Pos2/1/2] ip address unnumbered interface vlan-interface 22
