| 00-1Cover | 54.68 KB |
H3C S9500 Series Routing Switches |
Command Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08194H-20080520-C-2.03 Product Version: S9500-CMW520-R2132 |
Copyright © 2007-2008, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C,
, Aolynk,
, H3Care,
, TOP G,
, IRF, NetPilot, Neocean, NeoVTL, SecPro,
SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G,
VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www.h3c.com
Technical Support
service@h3c.com
http://www.h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S9500 Series Routing Switches documentation set includes the following:
Manual |
H3C S9500 Series Routing Switches Installation Manual |
It introduces the installation procedure, commissioning, maintenance and monitoring of the S9500 series routing switches. |
H3C S9500 Series Routing Switches Operation Manual |
It includes Product Overview, Access Volume, IP Service Volume, IP Routing Volume, IP Multicast Volume, MPLS VPN Volume, QoS ACL Volume, Security Volume, System Volume , OAA Volume and Acronyms. |
Organization
H3C Command Manual is organized as follows:
Part |
Contents |
00 Feature List and Command Index |
includes Feature List and Command Index. |
01 Access Volume |
includes Ethernet Interface Commands, POS Interface Commands, GVRP Commands, Link Aggregation Commands, Port Mirroring Commands, RPR Commands, Ethernet OAM Commands, MSTP Commands, VLAN Commands, QinQ Commands, BPDU Tunneling Commands, and Port Isolation Commands. |
02 IP Services Volume |
includes ARP Commands, DHCP Commands, DNS Commands, IP Addressing Commands, IP Performance Commands, UDP Helper Commands, IPv6 Basics Commands, Dual Stack Commands, Tunneling Commands, and Adjacency Table Command. |
03 IP Routing Volume |
includes IP Routing Table Display Commands, BGP Commands, IS-IS Commands, OSPF Commands, RIP Commands, Routing Policy Commands, Static Routing Commands, IPv6 BGP Commands, IPv6 IS-IS Commands, IPv6 OSPFv3 Commands, IPv6 RIPng Commands, and IPv6 Static Routing Commands. |
04 IP Multicast Volume |
includes Multicast Routing and Forwarding Commands, IGMP Snooping Commands, IGMP Commands, PIM Commands, MSDP Commands, IPv6 Multicast Routing, and Forwarding Commands, MLD Snooping Commands, MLD Commands, IPv6 PIM Commands, Multicast VLAN Commands. |
05 MPLS VPN Volume |
includes MPLS Basics Commands, MPLS TE Commands, VPLS Commands, MPLS L2VPN Commands, MPLS L3VPN Commands, MPLS Hybrid Insertion Commands, and GRE Commands. |
06 QoS ACL Volume |
includes QoS Commands and ACL Commands. |
07 Security Volume |
includes 802.1x Commands, AAA, RADIUS HWTACACS Commands, MAC Authentication Commands, L3+NAT Commands, Password Control Commands, SSH2.0 Commands, and Portal Commands. |
08 System Volume |
includes GR Commands, VRRP Commands, HA Commands, Device Management Commands, NQA Commands, NetStream Commands, NTP Commands, RMON Commands, SNMP Commands, File System Management Commands, System Maintaining and Debugging Commands, Basic System Configuration Commands, Information Center Commands, User Interface Commands, MAC Address Table Management Commands, PoE Commands, and Clock Monitoring Commands. |
09 OAA Volume |
includes OAP Module Commands and ACSEI Commands. |
10 Unsupported Commands |
List of Unsupported Commands. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> |
The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
